i.MX51 Android ADB over USB
How to connect i.MX51 and Ubuntu using USB cable:
i.MX51 Side
Plug in USB cable.
  • getprop debug.adb.usb - Shows that debug.adb.usb are not set by default
  • setprop persist.service.adb.enable 0 -> disable adb
  • setprop debug.adb.usb 1 - adb will be through USB (for Ethernet, use setprop debug.adb.usb 0)
  • setprop persist.service.adb.enable 1 -> enable adb
Example:
# getprop debug.adb.usb
# setprop persist.service.adb.enable 0
disabling adb
# adb_release
android_usb gadget: high speed config #1: android
# setprop persist.service.adb.enable 1
enabling adb
# adb_open
adb_release
adb_open
Ubuntu Side
On Ubuntu side, the most important tip is regarding permission. ADB server MUST be started with root right.
Example of right mistake:
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb devices
List of devices attached
????????????    no permissions
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb shell
error: insufficient permissions for device
How to proceed to get permission:
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb kill-server
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb start-server
* daemon not running. starting it now *
* daemon started successfully *
0123456789ABCDEF    device
ADB over Ethernet/Wi-Fi
To make ADB work in i.MX51 using TCP:
  • In your host machine:
- Install Android SDK
- export ADBHOST=BOARD_IP (setenv ADBHOST=xxx.xxx.xxx.xxx)
- adb kill-server
  • In your board:
- make sure that ro.secure property is *not* set when the adbd daemon is launched, so edit the file default.prop
- make sure that /dev/android_adb or /dev/android do *not* exist
- stop adbd
- start adbd
Now you will be able to list the device:
hamilton@saygon:/opt/work/androidsdk/android-sdk-linux_86/tools$ ./adb kill-server
hamilton@saygon:/opt/work/androidsdk/android-sdk-linux_86/tools$ ./adb devices
emulator-5554   device
标签 (3)
评论
mbp
Nice.
Now could someone PLEASE add the steps necessary for iMx51 Android adb over USB (for R10.4) with 32-bit Windows-XP system?
...had it working for years on R9.2, R9.3.   NO-GO (even after all User-Guide mods and following a million forum suggestions/issues).
thanks,
mike
%3CLINGO-SUB%20id%3D%22lingo-sub-1098886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX51%20Android%20ADB%20%E9%80%9A%E8%BF%87%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1098886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20USB%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E8%BF%9E%E6%8E%A5%20i.MX51%20%E4%B8%8E%20Ubuntu%20%E7%B3%BB%E7%BB%9F%EF%BC%9A%3C%2FP%3E%3CH4%20id%3D%22toc-hId--735472998%22%20id%3D%22toc-hId--735472998%22%20id%3D%22toc-hId-207344723%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CH2%20id%3D%22toc-hId-1050975257%22%20id%3D%22toc-hId-1050975257%22%20id%3D%22toc-hId-1993792978%22%3E%3CSPAN%20class%3D%22mw-headline%22%3Ei.MX51%20%E7%AB%AF%20%3C%2FSPAN%3E%3C%2FH2%3E%3CPRE%20class%3D%22jive-pre%22%3E%E8%BF%9E%E6%8E%A5USB%E7%BA%BF%E7%BC%86%E3%80%82%20%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Egetprop%20debug.adb.usb%3C%2FSTRONG%3E%E2%80%94%E2%80%94%E6%98%BE%E7%A4%BA%20debug.adb.usb%20%E9%BB%98%E8%AE%A4%E6%9C%AA%E8%AE%BE%E7%BD%AE%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esetprop%20persist.service.adb.enable%200%3C%2FSTRONG%3E%20-%26gt%3B%20%E7%A6%81%E7%94%A8%20ADB%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esetprop%20debug.adb.usb%201%3C%2FSTRONG%3E%20-%20ADB%20%E5%B0%86%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%EF%BC%88%E8%8B%A5%E9%9C%80%E9%80%9A%E8%BF%87%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20setprop%20debug.adb.usb%200%EF%BC%89%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esetprop%20persist.service.adb.enable%201%3C%2FSTRONG%3E%20-%26gt%3B%20%E5%90%AF%E7%94%A8%20adb%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%23%20getprop%20debug.adb.usb%26nbsp%3B%20%0A%23%0A%23%20%0A%23%20setprop%20persist.service.adb.enable%200%20%0Adisabling%20adb%20%0A%23%20adb_release%20%0Aandroid_usb%20gadget%3A%20high%20speed%20config%20%231%3A%20android%20%0Asetprop%20debug.adb.usb%201%20%0A%23%20%0A%23%20setprop%20persist.service.adb.enable%201%20%0Aenabling%20adb%20%0A%23%20adb_open%20%0Aadb_release%20%0Aadb_open%20%0Aandroid_usb%20gadget%3A%20high%20speed%20config%20%231%3A%20android%20%0A%23%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId--756479206%22%20id%3D%22toc-hId--756479206%22%20id%3D%22toc-hId-186338515%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EUbuntu%20Side%20%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20Ubuntu%20%E7%AB%AF%EF%BC%8C%E6%9C%80%E9%87%8D%E8%A6%81%E7%9A%84%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A1%B9%E4%B8%8E%E6%9D%83%E9%99%90%E6%9C%89%E5%85%B3%E3%80%82ADB%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%BF%85%E9%A1%BB%E4%BB%A5%20root%20%E6%9D%83%E9%99%90%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%E6%9D%83%E9%99%90%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20devices%20%0AList%20of%20devices%20attached%20%0A%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%26nbsp%3B%26nbsp%3B%26nbsp%3B%20no%20permissions%26nbsp%3B%20%0A%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20shell%20%0Aerror%3A%20insufficient%20permissions%20for%20device%0A%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FPRE%3E%3CP%3E%E5%A6%82%E4%BD%95%E7%94%B3%E8%AF%B7%E8%8E%B7%E5%BE%97%E8%AE%B8%E5%8F%AF%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20kill-server%20%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DIMX51_Android_ADB_over_USB%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22%E7%94%B1%20Text-Enhance%20%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%22%20target%3D%22_blank%22%3Estart%3C%2FA%3E-server%20%0A*%20daemon%20not%20running.%20starting%20it%20now%20*%20%0A*%20daemon%20started%20successfully%20*%20%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20devices%20%0AList%20of%20devices%20attached%20%0A0123456789ABCDEF%26nbsp%3B%26nbsp%3B%26nbsp%3B%20device%26nbsp%3B%20%0A%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20shell%0A%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FPRE%3E%3CH4%20id%3D%22toc-hId--1862869091%22%20id%3D%22toc-hId--1862869091%22%20id%3D%22toc-hId--920051370%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CH2%20id%3D%22toc-hId--76420836%22%20id%3D%22toc-hId--76420836%22%20id%3D%22toc-hId-866396885%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E9%80%9A%E8%BF%87%E4%BB%A5%E5%A4%AA%E7%BD%91%20%2F%20Wi-Fi%20%E4%BD%BF%E7%94%A8%20ADB%3C%2FSPAN%3E%3C%2FH2%3E%3CH4%20id%3D%22toc-hId--1182810721%22%20id%3D%22toc-hId--1182810721%22%20id%3D%22toc-hId--239993000%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CP%3E%E8%A6%81%E4%BD%BF%20ADB%20%E5%9C%A8%20i.MX51%20%E4%B8%8A%E9%80%9A%E8%BF%87%20TCP%20%E5%B7%A5%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E4%B8%8A%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E-%20%E5%AE%89%E8%A3%85%20Android%20SDK%3C%2FP%3E%3CP%3E-%20export%20ADBHOST%3DBOARD_IP%20(setenv%20ADBHOST%3Dxxx.xxx.xxx.xxx)%3C%2FP%3E%3CP%3E-%20adb%20kill-server%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9C%A8%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E-%20%E7%A1%AE%E4%BF%9D%E5%9C%A8%20adbd%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8Cro.secure%20%E5%B1%9E%E6%80%A7%E6%9C%AA%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%AF%B7%E7%BC%96%E8%BE%91%20default.prop%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E-%20%E7%A1%AE%E4%BF%9D%20%2Fdev%2Fandroid_adb%20%E6%88%96%20%2Fdev%2Fandroid%20*%E4%B8%8D*%E5%AD%98%E5%9C%A8%3C%2FP%3E%3CP%3E-%20%E5%81%9C%E6%AD%A2%20adbd%3C%2FP%3E%3CP%3E-%20%E5%90%AF%E5%8A%A8%20adbd%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%82%A8%E5%B0%86%E8%83%BD%E5%A4%9F%E5%88%97%E5%87%BA%E8%AE%BE%E5%A4%87%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ehamilton%40saygon%3A%2Fopt%2Fwork%2Fandroidsdk%2Fandroid-sdk-linux_86%2Ftools%24%20.%2Fadb%20kill-server%20%0Ahamilton%40saygon%3A%2Fopt%2Fwork%2Fandroidsdk%2Fandroid-sdk-linux_86%2Ftools%24%20.%2Fadb%20%E8%AE%BE%E5%A4%87%0A*%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E6%9C%AA%E8%BF%90%E8%A1%8C%E3%80%82%E7%8E%B0%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%AE%83%20*%0A*%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%20*%0A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E7%9A%84%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%0Aemulator-5554%20%E8%AE%BE%E5%A4%87%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1098886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1098887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E9%80%9A%E8%BF%87%20USB%20%E7%9A%84%20i.MX51%20Android%20ADB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1098887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ENice.%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%9C%89%E4%BA%BA%E8%83%BD%E8%A1%A5%E5%85%85%E4%B8%80%E4%B8%8B%E5%9C%A8%2032%20%E4%BD%8D%20Windows%20XP%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E9%92%88%E5%AF%B9%20R10.4%20%E7%89%88%E6%9C%AC%E7%9A%84%20i.MX51%20Android%20%E9%80%9A%E8%BF%87%20USB%20%E4%BD%BF%E7%94%A8%20ADB%20%E6%89%80%E9%9C%80%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E...%E5%9C%A8%20R9.2%20%E5%92%8C%20R9.3%20%E4%B8%8A%E5%B7%B2%E7%BB%8F%E8%BF%90%E8%A1%8C%E5%A4%9A%E5%B9%B4%E3%80%82%E6%97%A0%E6%95%88%EF%BC%88%E5%8D%B3%E4%BD%BF%E5%9C%A8%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%89%80%E6%9C%89%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E7%9A%84%E4%BF%AE%E6%94%B9%E5%B9%B6%E9%81%B5%E5%BE%AA%E4%BA%86%E6%97%A0%E6%95%B0%E8%AE%BA%E5%9D%9B%E5%BB%BA%E8%AE%AE%2F%E9%97%AE%E9%A2%98%E4%B9%8B%E5%90%8E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%8C%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 03:39 AM
更新人:
