i.MX51 Android ADB over USB
How to connect i.MX51 and Ubuntu using USB cable:
i.MX51 Side
Plug in USB cable.
  • getprop debug.adb.usb - Shows that debug.adb.usb are not set by default
  • setprop persist.service.adb.enable 0 -> disable adb
  • setprop debug.adb.usb 1 - adb will be through USB (for Ethernet, use setprop debug.adb.usb 0)
  • setprop persist.service.adb.enable 1 -> enable adb
Example:
# getprop debug.adb.usb
# setprop persist.service.adb.enable 0
disabling adb
# adb_release
android_usb gadget: high speed config #1: android
# setprop persist.service.adb.enable 1
enabling adb
# adb_open
adb_release
adb_open
Ubuntu Side
On Ubuntu side, the most important tip is regarding permission. ADB server MUST be started with root right.
Example of right mistake:
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb devices
List of devices attached
????????????    no permissions
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb shell
error: insufficient permissions for device
How to proceed to get permission:
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb kill-server
$ sudo <AND_SDK_DIR>/android-sdk-linux_86/tools/adb start-server
* daemon not running. starting it now *
* daemon started successfully *
0123456789ABCDEF    device
ADB over Ethernet/Wi-Fi
To make ADB work in i.MX51 using TCP:
  • In your host machine:
- Install Android SDK
- export ADBHOST=BOARD_IP (setenv ADBHOST=xxx.xxx.xxx.xxx)
- adb kill-server
  • In your board:
- make sure that ro.secure property is *not* set when the adbd daemon is launched, so edit the file default.prop
- make sure that /dev/android_adb or /dev/android do *not* exist
- stop adbd
- start adbd
Now you will be able to list the device:
hamilton@saygon:/opt/work/androidsdk/android-sdk-linux_86/tools$ ./adb kill-server
hamilton@saygon:/opt/work/androidsdk/android-sdk-linux_86/tools$ ./adb devices
emulator-5554   device
ラベル(3)
コメント
mbp
Nice.
Now could someone PLEASE add the steps necessary for iMx51 Android adb over USB (for R10.4) with 32-bit Windows-XP system?
...had it working for years on R9.2, R9.3.   NO-GO (even after all User-Guide mods and following a million forum suggestions/issues).
thanks,
mike
%3CLINGO-SUB%20id%3D%22lingo-sub-1098886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX51%20Android%20ADB%20over%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1098886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX51%E3%81%A8Ubuntu%E3%82%92USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CH4%20id%3D%22toc-hId--735472998%22%20id%3D%22toc-hId--735472998%22%20id%3D%22toc-hId-207323647%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CH2%20id%3D%22toc-hId-1050975257%22%20id%3D%22toc-hId-1050975257%22%20id%3D%22toc-hId-1993771902%22%3E%3CSPAN%20class%3D%22mw-headline%22%3Ei.MX51%20%E3%82%B5%E3%82%A4%E3%83%89%20%3C%2FSPAN%3E%3C%2FH2%3E%3CPRE%20class%3D%22jive-pre%22%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Egetprop%20debug.adb.usb%3C%2FSTRONG%3E%20-%20debug.adb.usb%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esetprop%20persist.service.adb.enable%200%3C%2FSTRONG%3E%20-%26gt%3B%20adb%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esetprop%20debug.adb.usb%201%3C%2FSTRONG%3E%20-%20adb%E3%81%AFUSB%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88Ethernet%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81setprop%20debug.adb.usb%200%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Esetprop%20persist.service.adb.enable%201%3C%2FSTRONG%3E-%26gt%3B%20adb%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%23%20getprop%20debug.adb.usb%26nbsp%3B%0A%23%0A%23%20%0A%23%20setprop%20persist.service.adb.enable%200%20%0Aadb%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%0A%23%20adb_release%20%0Aandroid_usb%E3%82%AC%E3%82%B8%E3%82%A7%E3%83%83%E3%83%88%3A%20%E9%AB%98%E9%80%9F%E6%A7%8B%E6%88%90%231%3A%20android%20%0Asetprop%20debug.adb.usb%201%20%0A%23%20%0A%23%20setprop%20persist.service.adb.enable%201%20%0Aadb%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%0A%23%20adb_open%20%0Aadb_release%20%0Aadb_open%20%0Aandroid_usb%E3%82%AC%E3%82%B8%E3%82%A7%E3%83%83%E3%83%88%3A%E9%AB%98%E9%80%9F%E8%A8%AD%E5%AE%9A%20%231%3A%20android%20%0A%23%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId--756479206%22%20id%3D%22toc-hId--756479206%22%20id%3D%22toc-hId-186317439%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EUbuntu%20Side%20%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3EUbuntu%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E3%82%82%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%92%E3%83%B3%E3%83%88%E3%81%AF%E6%A8%A9%E9%99%90%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82ADB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81root%E6%A8%A9%E9%99%90%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A8%A9%E9%99%90%E3%81%AE%E9%96%93%E9%81%95%E3%81%84%E3%81%AE%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20devices%20%0A%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%0A%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%26nbsp%3B%26nbsp%3B%26nbsp%3B%E6%A8%A9%E9%99%90%E3%81%AA%E3%81%97%26nbsp%3B%0A%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20shell%20%0A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E6%A8%A9%E9%99%90%E3%81%8C%E4%B8%8D%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%0A%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FPRE%3E%3CP%3E%E8%A8%B1%E5%8F%AF%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20kill-server%0A%20%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DIMX51_Android_ADB_over_USB%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22Powered%20by%20Text-Enhance%22%20target%3D%22_blank%22%3Estart%3C%2FA%3E-server%0A%20*%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%8A%E3%81%99%E3%81%90%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99*%20%0A*%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F*%20%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20devices%20%0A%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%0A0123456789ABCDEF%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%26nbsp%3B%0A%0A%24%20sudo%20%3CAND_SDK_DIR%3E%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20shell%0A%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FAND_SDK_DIR%3E%3C%2FPRE%3E%3CH4%20id%3D%22toc-hId--1862869091%22%20id%3D%22toc-hId--1862869091%22%20id%3D%22toc-hId--920072446%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CH2%20id%3D%22toc-hId--76420836%22%20id%3D%22toc-hId--76420836%22%20id%3D%22toc-hId-866375809%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EEthernet%2FWi-Fi%E7%B5%8C%E7%94%B1%E3%81%AEADB%3C%2FSPAN%3E%3C%2FH2%3E%3CH4%20id%3D%22toc-hId--1182810721%22%20id%3D%22toc-hId--1182810721%22%20id%3D%22toc-hId--240014076%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH4%3E%3CP%3ETCP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20i.MX51%20%E3%81%A7%20ADB%20%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E-%20Android%20SDK%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E-%20export%20ADBHOST%3DBOARD_IP%20(setenv%20ADBHOST%3Dxxx.xxx.xxx.xxx)%3C%2FP%3E%3CP%3E-%20adb%20kill-server%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E5%86%85%E3%81%A7%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E-%20adbd%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81ro.secure%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81default.prop%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E-%20%2Fdev%2Fandroid_adb%20%E3%81%BE%E3%81%9F%E3%81%AF%20%2Fdev%2Fandroid%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E-%20adbd%E3%82%92%E5%81%9C%E6%AD%A2%3C%2FP%3E%3CP%3E-%20adbd%E3%82%92%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ehamilton%40saygon%3A%2Fopt%2Fwork%2Fandroidsdk%2Fandroid-sdk-linux_86%2Ftools%24%20.%2Fadbkill-server%0Ahamilton%40saygon%3A%2Fopt%2Fwork%2Fandroidsdk%2Fandroid-sdk-linux_86%2Ftools%24%20.%2Fadb%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%0A*%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%96%8B%E5%A7%8B%E4%B8%AD*%20%0A*%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F*%0A%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%0A%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF-5554%26nbsp%3B%26nbsp%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1098886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1098887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX51%20Android%20ADB%20over%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1098887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ENice.%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%8132%E3%83%93%E3%83%83%E3%83%88Windows%20XP%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7iMx51%20Android%E3%81%AEadb%20over%20USB%EF%BC%88R10.4%E7%94%A8%EF%BC%89%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E...R9.2%E3%80%81R9.3%E3%81%A7%E4%BD%95%E5%B9%B4%E3%82%82%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%26nbsp%3B%26nbsp%3BNO-GO%EF%BC%88%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%94%B9%E9%80%A0%E3%82%84%E3%80%81100%E4%B8%87%E4%BB%B6%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E6%8F%90%E6%A1%88%2F%E5%95%8F%E9%A1%8C%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%A6%E3%82%82%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A4%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:39 AM
更新者:
