Yocto Project Package Management - smart
Introduction
The "smart" package management system is available in  Yocto Project for managing  packages on a target machine. A host is configured as a server for the packages and on the target the "package-management" feature is enabled for working with the packages. The steps for setup and usage are described below.
Resources
The Yocto Project package management system will work with many hosts and targets. The following were used for creating this document:
Host
You have successfully installed a Freescale Yocto Project release. (Refer to Freescale Yocto Project Release Documentation). There are two steps for adding package management and then building:
1. Modify conf/local.conf
EXTRA_IMAGE_FEATURES = "debug-tweaks package-management"
2. Build the image:
bitbake core-image-minimal
The core-image-minimal recipe provides an image enabling the target board to boot and support a serial console.
3. Create SDCARD:
$ cd <build>/tmp/deploy/images/imx6qsabresd
$ sudo dd if=core-image-minimal-imx6qsabresd.sdcard of=/dev/sdb bs=4M && sync
Note - verify location of SDCARD on your host, /dev/sdb in this example. Examine 'cat /proc/partitions'
4. Setup web server and add link to rpm packages
A web server, lighttpd, is installed.
$ sudo apt-get install lighttpd
Provide user write capability in /var/www
$ sudo chmod 777 /var/www
Create a soft link in the default web server directory to the rpm directory from the build. Note: Please update $HOME/<build> to your actual location:
$ ln -s $HOME/<build>/tmp/deploy/rpm /var/www/imx6qsd
Target
Insert the SDCARD created from step 3 above, connect power and console cable  and power on the MCIMX6Q-SDP. Login using the "root" id, no password required.
The /usr/bin/smart application is now used to setup the channels and perform package commands. For all smart options:
smart --help
1. Add channels
To add the packages from the host to your target, the smart  channel --add is used:
Please enter the IP adress of your server, replacing SERVERIP below:
smart channel --add all type=rpm-md name=all baseurl=
http://SERVERIP/imx6qsd/all
smart channel --add cortexa9hf_vfp_neon type=rpm-md name=cortexa9hf_vfp_neon baseurl=
http://SERVERIP/imx6qsd/cortexa9hf_vfp_neon
smart channel --add imx6qsabresd type=rpm-md name=imx6qsabresd baseurl=
http://SERVERIP/imx6qsd/imx6qsabresd
Check  the added channels:
root@imx6qsabresd:~# smart channel --list
all
imx6qsabresd
rpmsys
cortexa9hf_vfp_neon
2. Update  local package cache
Once the chanels have been added, the local package cache is updated.
Note  SERVERIP below will be the host IP address in your network.
root@imx6qsabresd:~# smart update
Loading cache...
Updating cache...               ######################################## [100%]
Fetching information for 'all'...
-> http://SERVERIP/imx6qsd/all/repodata/repomd.xml
repomd.xml                      ######################################## [ 16%]
Fetching information for 'imx6qsabresd'...
-> http://SERVERIP/imx6qsd/imx6qsabresd/repodata/repomd.xml
repomd.xml                      ######################################## [ 41%]
Fetching information for 'cortexa9hf_vfp_neon'...
-> http://SERVERIP/imx6qsd/cortexa9hf_vfp_neon/repodata/repomd.xml
repomd.xml                      ######################################## [ 66%]
Channels have no new packages.
3. Searching for packages
Let us look at all packages containing the string client
root@imx6qsabresd:~# smart search client*
Loading cache...
libice-dbg - ICE: Inter-Client Exchange library - Debugging files
libice-dev - ICE: Inter-Client Exchange library - Development files
libice-doc - ICE: Inter-Client Exchange library - Documentation files
libice-staticdev - ICE: Inter-Client Exchange library - Development files (Static Libraries)
libice6 - ICE: Inter-Client Exchange library
libsm-dbg - SM: Session Management library - Debugging files
libsm-dev - SM: Session Management library - Development files
libsm-doc - SM: Session Management library - Documentation files
libsm-staticdev - SM: Session Management library - Development files (Static Libraries)
libsm6 - SM: Session Management library
libx11-6 - Xlib: C Language X Interface library
libx11-dbg - Xlib: C Language X Interface library - Debugging files
libx11-dev - Xlib: C Language X Interface library - Development files
libx11-doc - Xlib: C Language X Interface library - Documentation files
libx11-locale - Xlib: C Language X Interface library
libx11-staticdev - Xlib: C Language X Interface library - Development files (Static Libraries)
libx11-xcb1 - Xlib: C Language X Interface library
libxau-dbg - Xau: X Authority Database library - Debugging files
libxau-dev - Xau: X Authority Database library - Development files
libxau-doc - Xau: X Authority Database library - Documentation files
libxau-staticdev - Xau: X Authority Database library - Development files (Static Libraries)
libxau6 - Xau: X Authority Database library
python-netclient - Python Internet Protocol clients
xtrans-dbg - XTrans: X Transport library - Debugging files
xtrans-dev - XTrans: X Transport library - Development files
xtrans-doc - XTrans: X Transport library - Documentation files
Adding openssh client to core-image minimal
The core-image-minimal does not provide openssh client applications like ssh or scp. Let's add them on the host then update the target cache of packages and then install.
Host
Run bitbake to exercise all the tasks for packagegroup-core-ssh-openssh
$ bitbake packagegroup-core-ssh-openssh
After building a package individually, always update the package-index
$ bitbake package-index
Target
Run smart to update the local cache which will pickup the new packages from the bake above.
Loading cache...
http://SERVERIP/imx6qsd/all/repodata/primary.xml.gz
primary.xml.gz                  ######################################## [ 25%]
http://SERVERIP/imx6qsd/all/repodata/filelists.xml.gz
filelists.xml.gz                ######################################## [ 33%]
repomd.xml                      ######################################## [ 50%]
http://SERVERIP/imx6qsd/imx6qsabresd/repodata/primary.xml.gz
http://SERVERIP/imx6qsd/imx6qsabresd/repodata/filelists.xml.gz
filelists.xml.gz                ######################################## [ 58%]
primary.xml.gz                  ######################################## [ 66%]
repomd.xml                      ######################################## [ 83%]
http://SERVERIP/imx6qsd/cortexa9hf_vfp_neon/repodata/primary.xml.gz
primary.xml.gz                  ######################################## [ 91%]
http://SERVERIP/imx6qsd/cortexa9hf_vfp_neon/repodata/filelists.xml.gz
filelists.xml.gz                ######################################## [100%]
Channels have 15 new packages.
Saving cache...
Examine information about local cache:
root@imx6qsabresd:~# smart stats
Loading cache...
Installed Packages: 80
Total Packages: 3586
Total Provides: 6580
Total Requires: 1611
Total Upgrades: 3565
Total Conflicts: 25
See what ssh packages are now available:
root@imx6qsabresd:~# smart search *ssh*
Loading cache...
openssh - Secure rlogin/rsh/rcp/telnet replacement
openssh-dbg - Secure rlogin/rsh/rcp/telnet replacement - Debugging files
openssh-dev - Secure rlogin/rsh/rcp/telnet replacement - Development files
openssh-doc - Secure rlogin/rsh/rcp/telnet replacement - Documentation files
openssh-keygen - Secure rlogin/rsh/rcp/telnet replacement
openssh-misc - Secure rlogin/rsh/rcp/telnet replacement
openssh-ptest - Secure rlogin/rsh/rcp/telnet replacement - Package test files
openssh-scp - Secure rlogin/rsh/rcp/telnet replacement
openssh-sftp - Secure rlogin/rsh/rcp/telnet replacement
openssh-sftp-server - Secure rlogin/rsh/rcp/telnet replacement
openssh-ssh - Secure rlogin/rsh/rcp/telnet replacement
openssh-sshd - Secure rlogin/rsh/rcp/telnet replacement
packagegroup-core-ssh-openssh - OpenSSH SSH client/server
packagegroup-core-ssh-openssh-dbg - OpenSSH SSH client/server - Debugging files
packagegroup-core-ssh-openssh-dev - OpenSSH SSH client/server - Development files
Install openssh
root@imx6qsabresd:~# smart install openssh
Loading cache...
Computing transaction...
Installing packages (9):
  openssh-6.7p1-r0@cortexa9hf_vfp_neon
  openssh-keygen-6.7p1-r0@cortexa9hf_vfp_neon
  openssh-scp-6.7p1-r0@cortexa9hf_vfp_neon
  openssh-ssh-6.7p1-r0@cortexa9hf_vfp_neon
  openssh-sshd-6.7p1-r0@cortexa9hf_vfp_neon
  shadow-4.2.1-r0@cortexa9hf_vfp_neon
  shadow-base-4.2.1-r0@cortexa9hf_vfp_neon
  shadow-securetty-4.2.1-r3@imx6qsabresd
  util-linux-sulogin-2.25.2-r1@cortexa9hf_vfp_neon
1.4MB of package files are needed. 3.2MB will be used.
Confirm changes? (Y/n): y
Fetching packages...
http://SERVERIP/imx6qsd/.../openssh-6.7p1-r0.cortexa9hf_vfp_neon.rpm
http://SERVERIP/imx6qsd/.../shadow-securetty-4.2.1-r3.imx6qsabresd.rpm
shadow-securetty-4.2.1-r3.imx.. ######################################## [ 11%]
http://SERVERIP/imx6qsd/.../openssh-scp-6.7p1-r0.cortexa9hf_vfp_neon.rpm
openssh-scp-6.7p1-r0.cortexa9.. ######################################## [ 22%]
openssh-6.7p1-r0.cortexa9hf_v.. ######################################## [ 33%]
http://SERVERIP/imx6qsd/.../openssh-sshd-6.7p1-r0.cortexa9hf_vfp_neon.rpm
openssh-sshd-6.7p1-r0.cortexa.. ######################################## [ 44%]
http://SERVERIP/imx6qsd/.../shadow-4.2.1-r0.cortexa9hf_vfp_neon.rpm
http://SERVERIP/imx6qsd/.../openssh-ssh-6.7p1-r0.cortexa9hf_vfp_neon.rpm
openssh-ssh-6.7p1-r0.cortexa9.. ######################################## [ 55%]
http://SERVERIP/imx6qsd/.../shadow-base-4.2.1-r0.cortexa9hf_vfp_neon.rpm
shadow-base-4.2.1-r0.cortexa9.. ######################################## [ 66%]
shadow-4.2.1-r0.cortexa9hf_vf.. ######################################## [ 77%]
http://SERVERIP/.../util-linux-sulogin-2.25.2-r1.cortexa9hf_vfp_neon.rpm
util-linux-sulogin-2.25.2-r1... ######################################## [ 88%]
http://SERVERIP/.../openssh-keygen-6.7p1-r0.cortexa9hf_vfp_neon.rpm
openssh-keygen-6.7p1-r0.corte.. ######################################## [100%]
Committing transaction...
Preparing...                    ######################################## [  0%]
   1:Installing openssh-ssh     ######################################## [ 11%]
Output from openssh-ssh-6.7p1-r0@cortexa9hf_vfp_neon:
update-alternatives: Linking /usr/bin/ssh to /usr/bin/ssh.openssh
   2:Installing openssh-scp     ######################################## [ 22%]
Output from openssh-scp-6.7p1-r0@cortexa9hf_vfp_neon:
update-alternatives: Linking /usr/bin/scp to /usr/bin/scp.openssh
   3:Installing shadow-secure.. ######################################## [ 33%]
   4:Installing shadow-base     ######################################## [ 44%]
Output from shadow-base-4.2.1-r0@cortexa9hf_vfp_neon:
update-alternatives: Linking /usr/bin/newgrp to /usr/bin/newgrp.shadow
update-alternatives: Linking /usr/bin/groups to /usr/bin/groups.shadow
update-alternatives: Linking /bin/login to /bin/login.shadow
update-alternatives: Linking /bin/su to /bin/su.shadow
   5:Installing util-linux-su.. ######################################## [ 55%]
Output from util-linux-sulogin-2.25.2-r1@cortexa9hf_vfp_neon:
update-alternatives: Linking /sbin/sulogin to /sbin/sulogin.util-linux
   6:Installing openssh-keygen  ######################################## [ 66%]
   7:Installing shadow          ######################################## [ 77%]
Output from shadow-4.2.1-r0@cortexa9hf_vfp_neon:
update-alternatives: Linking /usr/bin/passwd to /usr/bin/passwd.shadow
update-alternatives: Linking /usr/bin/chfn to /usr/bin/chfn.shadow
update-alternatives: Linking /usr/bin/chsh to /usr/bin/chsh.shadow
update-alternatives: Linking /usr/sbin/chpasswd to /usr/sbin/chpasswd.shadow
update-alternatives: Linking /sbin/vipw to /sbin/vipw.shadow
update-alternatives: Linking /sbin/vigr to /sbin/vigr.shadow
Output from openssh-sshd-6.7p1-r0@cortexa9hf_vfp_neon:
 Removing any system startup links for sshd ...
Running useradd commands...
NOTE: Performing useradd with [ --system --no-create-home --home-dir /var/run/sshd --shell /bin/false --user-group sshd] and 10 times of retry
   8:Installing openssh-sshd    ######################################## [ 88%]
 Adding system startup for /etc/init.d/sshd.
Starting OpenBSD Secure Shell server: sshd
  generating ssh RSA key...
  generating ssh ECDSA key...
  generating ssh DSA key...
  generating ssh ED25519 key...
done.
   9:Installing openssh         ######################################## [100%]
Check for the scp command:
root@imx6qsabresd:~# which scp
/usr/bin/scp
Summary
To add a new package on the server host, run bitbake <recipe> then bitbake package-index to update the rpm tracking information. On the target board, run smart update and then smart install <package>. Use smart search <regular expression string> to hunt for a package to install.
标签 (3)
评论
I have followed this document but, got following errors. Please, help as early as you can
After bitbake fsl-image-gui,  got following errors
WARNING: Failed to fetch URL http://ftp.gnu.org/gnu/automake/automake-1.15.tar.gz, attempting MIRRORS if available
WARNING: Failed to fetch URL http://ftp.gnu.org/gnu/libtool/libtool-2.4.6.tar.gz, attempting MIRRORS if available
WARNING: Failed to fetch URL http://tukaani.org/xz/xz-5.2.0.tar.gz, attempting MIRRORS if available
WARNING: Failed to fetch URL https://gmplib.org/download/gmp/gmp-6.0.0a.tar.bz2, attempting MIRRORS if available
WARNING: Failed to fetch URL http://download.savannah.gnu.org/releases/attr/attr-2.4.47.src.tar.gz, attempting MIRRORS if available
WARNING: Failed to fetch URL http://downloads.sourceforge.net/flex/flex-2.5.39.tar.bz2, attempting MIRRORS if available
WARNING: Failed to fetch URL http://ftp.gnu.org/gnu/binutils/binutils-2.24.tar.bz2, attempting MIRRORS if available
WARNING: Failed to fetch URL http://www.multiprecision.org/mpc/download/mpc-1.0.2.tar.gz, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 4, output:
wget: unable to resolve host address 'www.multiprecision.org'
ERROR: Function failed: Fetcher failure for URL: 'http://www.multiprecision.org/mpc/download/mpc-1.0.2.tar.gz'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/swapnil/fsl-release-bsp/build-x11/tmp/work/x86_64-linux/libmpc-native/1.0.2-r0/temp/log.do_fetch.25793
ERROR: Task 3407 (virtual:native:/home/swapnil/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.2.bb, do_fetch) failed with exit code '1'
Very usefull tutorial, thanks!!
I want to point something that may need a correction in the code you give to us CurtisWald.
The name of the folder in the host computer does not match in the next two steps, and it gives an error.
Step1:
  1. $ ln -s $HOME/<build>/tmp/deploy/rpm /var/www/imx6q
Step2:
1. Add channels
  1. smart channel --add all type=rpm-md name=all baseurl=http://SERVERIP/imx6qsd/all
  2. smart channel --add cortexa9hf_vfp_neon type=rpm-md name=cortexa9hf_vfp_neon baseurl=http://SERVERIP/imx6qsd/cortexa9hf_vfp_neon
  3. smart channel --add imx6qsabresd type=rpm-md name=imx6qsabresd baseurl=http://SERVERIP/imx6qsd/imx6qsabresd
Cheers.
Updated initial post, thanks.
Thank you for this post!
But Isn't there a web server "for everyone" (in world wide web...) to use rpm's for imx6 with smart (just like with normally use "apt-get" in ubunbtu) ?
Ran
I would like to ask if the SMART package management support the S32XX Platform?
Since i'm using the s32g Platform and I do excaly the same steps as the tutorial said. I didn't got any error, however when I successfully boot the SD card and insert it into the slot of my board. In the rootfs, I can't find the smart excuable file and the konsol said there is no command called smart.
Yihan
Yocto Project 2.4 Rocko release smart has been replaced with dnf:
https://www.yoctoproject.org/docs/2.4/mega-manual/mega-manual.html
24.11.8. Package Management Changes¶<https://www.yoctoproject.org/docs/2.4/mega-manual/mega-manual.html#migration-2.3-package-management-changes>
The following package management changes took place:
  • Smart package manager is replaced by DNF package manager. Smart has become unmaintained upstream, is not ported to Python 3.x. Consequently, Smart needed to be replaced. DNF is the only feasible candidate.
If the Yocto Project you are using is 2.4 or later, recommend using dnf.
Hello Curtis,
Thank you for the Rely. I got some error after use the command "bitbake package-index" in the <build-directory>
ERROR: package-index-1.0-r0 do_package_index: Error executing a python function in exec_python_func() autogenerated:
Subprocess output:
Temporary repodata directory /home/cheng/fsl-auto-yocto-bsp/build_s32g274aevb/tmp/deploy/rpm/.repodata/ already exists! (Another createrepo process is running?)
ERROR: package-index-1.0-r0 do_package_index: Function failed: do_package_index
ERROR: Logfile of failure stored in: /home/cheng/fsl-auto-yocto-bsp/build_s32g274aevb/tmp/work/aarch64-fsl-linux/package-index/1.0-r0/temp/log.do_package_index.39272
ERROR: Task (/home/cheng/fsl-auto-yocto-bsp/sources/poky/meta/recipes-core/meta/package-index.bb:do_package_index) failed with exit code '1'
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Do you know how to solve it?
Thanks!
Yihan
Hello Yihan,
From the info you shared:
already exists!
Remove that directory and try again?
Maybe something like:
$ rm -fr /home/cheng/fsl-auto-yocto-bsp/build_s32g274aevb/tmp/deploy/rpm/.repodata/
$ cd $BUILDDIR
I have not worked with S32 much, but for i.MX I can share some steps that worked for me:
On Ubuntu 64-bit host (18.04 currently)
Web Server – there are a few out there, this one worked for me:
$ sudo apt-get install python-twisted-web
Build your image, for example on i.MX this recipe:
$ cd $BUILDDIR
$ bitbake imx-image-full
Create the meta data for dnf:
Start web server: (Ubuntu host IP address 10.0.0.100, used on development system below)
$ twistd web –patch tmp/deploy/rpm –port tcp:8080
At this point, web server started with recipes from imx-image-full available for dnf.
On development system:
The /etc/yum.repos.d directory is where dnf default looks for information that contain the repositories.
I copy and paste the following in the console of the development system to setup dnf. You can modify for your setup:
mkdir /etc/yum.repos.d
cd /etc/yum.repos.d
cat > imx.repo << END
name=i.MX rpm repository
baseurl=http://10.0.0.100:8080
enabled=1
metadata_expire=0
gpgcheck=0
END
Last setup step is to create the local cache on the development system:
$ dnf makecache
Now you can “dnf search package” and “dnf install package”.
If on your development system you want to add something the overall flow is:
On Host:
$ bitbake newRecipe
$ bitbake package-index - need to update the meta data for dnf
$ dnf update or dnf makecache
$ dnf install newRecipe
That flow had worked for me, good luck.
-Curtis
%3CLINGO-SUB%20id%3D%22lingo-sub-1106337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYocto%20Project%20%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380666704%22%20id%3D%22toc-hId-380666704%22%20id%3D%22toc-hId-1303142291%22%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%E7%AE%80%E4%BB%8B%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%80%9C%E6%99%BA%E8%83%BD%E2%80%9D%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%8F%AF%E5%9C%A8%20Yocto%20Project%20%E4%B8%AD%E4%BD%BF%E7%94%A8%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%9C%A8%E7%9B%AE%E6%A0%87%E6%9C%BA%E5%99%A8%E4%B8%8A%E7%AE%A1%E7%90%86%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%E4%B8%BB%E6%9C%BA%E8%A2%AB%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%9A%84%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E8%80%8C%E5%9C%A8%E7%9B%AE%E6%A0%87%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E5%B7%B2%E5%90%AF%E7%94%A8%E2%80%9C%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E2%80%9D%E5%8A%9F%E8%83%BD%E4%BB%A5%E7%AE%A1%E7%90%86%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E8%AE%BE%E7%BD%AE%E5%92%8C%E4%BD%BF%E7%94%A8%E6%AD%A5%E9%AA%A4%E7%9A%84%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426787759%22%20id%3D%22toc-hId--1426787759%22%20id%3D%22toc-hId--504312172%22%3E%E7%9B%B8%E5%85%B3%E8%B5%84%E6%BA%90%3C%2FH1%3E%3CP%3EYocto%20Project%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%B0%86%E4%B8%8E%E5%A4%9A%E7%A7%8D%E4%B8%BB%E6%9C%BA%E5%92%8C%E7%9B%AE%E6%A0%87%E7%B3%BB%E7%BB%9F%E5%8D%8F%E5%90%8C%E5%B7%A5%E4%BD%9C%E3%80%82%E7%94%A8%E4%BA%8E%E5%88%9B%E5%BB%BA%E6%AD%A4%E6%96%87%E6%A1%A3%E7%9A%84%E5%86%85%E5%AE%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%B8%BB%E6%9C%BA%EF%BC%9AUbuntu%2014.04%2064%E4%BD%8D%3C%2FLI%3E%3CLI%3E%E7%9B%AE%E6%A0%87%EF%BC%9A%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fsabresdp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMCIMX6Q-SDP%3C%2FA%3E%3C%2FLI%3E%3CLI%3EFreescale%20Yocto%20Project%20%E5%8F%91%E5%B8%83%E6%96%87%E6%A1%A3%EF%BC%9A%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.38_6UL_LINUX_DOCS%26amp%3BParent_nodeId%3D1337699481071706174845%26amp%3BParent_pageType%3Dproduct%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELinux%203.14.38_6ul%20BSP%20%E5%92%8C%E5%A4%9A%E5%AA%92%E4%BD%93%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%96%87%E6%A1%A3%3C%2FA%3E%EF%BC%88fsl-yocto-L3.14.38_6ul-ga.tar.gz%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1060725074%22%20id%3D%22toc-hId-1060725074%22%20id%3D%22toc-hId-1983200661%22%3E%E4%B8%BB%E6%9C%BA%3C%2FH1%3E%3CP%3E%E6%82%A8%E5%B7%B2%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%20Freescale%20Yocto%20Project%20%E7%89%88%E6%9C%AC%E3%80%82%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20Freescale%20Yocto%20Project%20%E5%8F%91%E5%B8%83%E6%96%87%E6%A1%A3%EF%BC%89%E3%80%82%E6%B7%BB%E5%8A%A0%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E5%92%8C%E6%9E%84%E5%BB%BA%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%9C%89%E4%B8%A4%E4%B8%AA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId-655399767%22%20id%3D%22toc-hId-655399767%22%20id%3D%22toc-hId-1577875354%22%3E1.%20%E4%BF%AE%E6%94%B9%20conf%2Flocal.conf%E3%80%82%3C%2FH5%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3EEXTRA_IMAGE_FEATURES%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22debug-tweaks%20package-management%22%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CH5%20id%3D%22toc-hId--1152054696%22%20id%3D%22toc-hId--1152054696%22%20id%3D%22toc-hId--229579109%22%3E2.%20%E7%94%9F%E6%88%90%E6%98%A0%E5%83%8F%EF%BC%9A%3C%2FH5%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Ebitbake%20core%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eimage%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eminimal%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3Ecore-image-minimal%20%E9%85%8D%E6%96%B9%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%B8%AA%E6%98%A0%E5%83%8F%EF%BC%8C%E4%BD%BF%E7%9B%AE%E6%A0%87%E6%9D%BF%E8%83%BD%E5%A4%9F%E5%90%AF%E5%8A%A8%E5%B9%B6%E6%94%AF%E6%8C%81%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E3%80%82%3C%2FP%3E%3CH5%20id%3D%22toc-hId-1335458137%22%20id%3D%22toc-hId-1335458137%22%20id%3D%22toc-hId--2037033572%22%3E%E7%AC%AC%E4%B8%89%EF%BC%8C%E5%88%9B%E5%BB%BASDCARD%EF%BC%9A%3C%2FH5%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20cd%20%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3Ebuild%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etmp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edeploy%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimages%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsabresd%0A%24%20sudo%20dd%20%3CSPAN%20class%3D%22keyword%20token%22%3Eif%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Ecore%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eimage%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eminimal%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eimx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Esdcard%20of%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edev%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esdb%20bs%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E4M%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20sync%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%B3%A8%E6%84%8F%E2%80%94%E2%80%94%E8%AF%B7%E7%A1%AE%E8%AE%A4%E4%B8%BB%E6%9C%BA%E4%B8%8A%20SDCARD%20%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%8C%E5%9C%A8%E6%9C%AC%E7%A4%BA%E4%BE%8B%E4%B8%AD%E4%B8%BA%20%2Fdev%2Fsdb%E3%80%82%E6%A3%80%E6%9F%A5%20'cat%20%2Fproc%2Fpartitions'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId--471996326%22%20id%3D%22toc-hId--471996326%22%20id%3D%22toc-hId-450479261%22%3E4.%20%E8%AE%BE%E7%BD%AE%20Web%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%B9%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20rpm%20%E5%8C%85%E7%9A%84%E9%93%BE%E6%8E%A5%3C%2FH5%3E%3CP%3E%E5%B7%B2%E5%AE%89%E8%A3%85%E4%BA%86%E4%B8%80%E5%8F%B0%E5%90%8D%E4%B8%BA%20lighttpd%20%E7%9A%84%20Web%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20sudo%20apt%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eget%20install%20lighttpd%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20%2Fvar%2Fwww%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E4%B8%BA%E7%94%A8%E6%88%B7%E6%8F%90%E4%BE%9B%E5%86%99%E5%85%A5%E6%9D%83%E9%99%90%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20sudo%20chmod%20%3CSPAN%20class%3D%22number%20token%22%3E777%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evar%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ewww%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20Web%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E8%BD%AF%E9%93%BE%E6%8E%A5%EF%BC%8C%E6%8C%87%E5%90%91%E6%9E%84%E5%BB%BA%E7%94%9F%E6%88%90%E7%9A%84%20rpm%20%E7%9B%AE%E5%BD%95%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%B7%E5%B0%86%20%24HOME%2F%3CBUILD%3E%20%E6%9B%B4%E6%96%B0%E4%B8%BA%E6%82%A8%E5%AE%9E%E9%99%85%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FBUILD%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20ln%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Es%20%24HOME%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26lt%3B%3C%2FSPAN%3Ebuild%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etmp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Edeploy%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erpm%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evar%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ewww%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%0A%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-613387351%22%20id%3D%22toc-hId-613387351%22%20id%3D%22toc-hId-1535862938%22%3E%E7%9B%AE%E6%A0%87%3C%2FH1%3E%3CP%3E%E5%B0%86%E6%AD%A5%E9%AA%A4%203%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E7%9A%84%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%EF%BC%8C%E8%BF%9E%E6%8E%A5%E7%94%B5%E6%BA%90%E5%92%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%94%B5%E7%BC%86%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%93%E5%BC%80%20MCIMX6Q-SDP%20%E7%9A%84%E7%94%B5%E6%BA%90%E3%80%82%E4%BD%BF%E7%94%A8%20%E2%80%9Croot%E2%80%9D%20ID%20%E7%99%BB%E5%BD%95%EF%BC%8C%E6%97%A0%E9%9C%80%E5%AF%86%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Fusr%2Fbin%2Fsmart%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%8E%B0%E7%94%A8%E4%BA%8E%E8%AE%BE%E7%BD%AE%E9%80%9A%E9%81%93%E5%B9%B6%E6%89%A7%E8%A1%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%91%BD%E4%BB%A4%E3%80%82%E6%89%80%E6%9C%89%E6%99%BA%E8%83%BD%E9%80%89%E9%A1%B9%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Esmart%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ehelp%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId-208062044%22%20id%3D%22toc-hId-208062044%22%20id%3D%22toc-hId-1130537631%22%3E1.%20%E6%B7%BB%E5%8A%A0%E9%80%9A%E9%81%93%3C%2FH5%3E%3CP%3E%E8%A6%81%E5%B0%86%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%9B%AE%E6%A0%87%EF%BC%8C%E4%BD%BF%E7%94%A8%20smart%20%E9%80%9A%E9%81%93%E7%9A%84%20--add%20%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%82%A8%E8%BE%93%E5%85%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%B9%B6%E6%9B%BF%E6%8D%A2%E4%B8%8B%E6%96%B9%E7%9A%84%20SERVERIP%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Esmart%20channel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eadd%20all%20type%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Erpm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emd%20name%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Eall%20baseurl%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eall%0A%0Asmart%20channel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eadd%20cortexa9hf_vfp_neon%20type%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Erpm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emd%20name%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Ecortexa9hf_vfp_neon%20baseurl%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ecortexa9hf_vfp_neon%0A%0Asmart%20channel%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eadd%20imx6qsabresd%20type%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Erpm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emd%20name%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Eimx6qsabresd%20baseurl%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsabresd%0A%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A3%80%E6%9F%A5%E5%B7%B2%E6%B7%BB%E5%8A%A0%E7%9A%84%E9%A2%91%E9%81%93%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20smart%20channel%20--list%3C%2FSPAN%3E%0Aall%0Aimx6qsabresd%0Arpmsys%0Acortexa9hf_vfp_neon%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId--1599392419%22%20id%3D%22toc-hId--1599392419%22%20id%3D%22toc-hId--676916832%22%3E%E7%AC%AC%E4%BA%8C%E6%AD%A5%EF%BC%9A%E6%9B%B4%E6%96%B0%E6%9C%AC%E5%9C%B0%E5%8C%85%E7%BC%93%E5%AD%98%3C%2FH5%3E%3CP%3E%E4%B8%80%E6%97%A6%E6%B7%BB%E5%8A%A0%E4%BA%86%E9%80%9A%E9%81%93%EF%BC%8C%E6%9C%AC%E5%9C%B0%E5%8C%85%E7%BC%93%E5%AD%98%E5%B0%86%E8%A2%AB%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%B8%8B%E9%9D%A2%E7%9A%84%20SERVERIP%20%E5%B0%86%E6%98%AF%E6%82%A8%E7%BD%91%E7%BB%9C%E4%B8%AD%E7%9A%84%E4%B8%BB%E6%9C%BA%20IP%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6qsabresd%3A~%23%20smart%20update%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E6%9B%B4%E6%96%B0%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E8%8E%B7%E5%8F%96%20'all'%E7%9A%84%E4%BF%A1%E6%81%AF%E2%80%A6%E2%80%A6%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E-%26gt%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2FSERVERIP%2Fimx6qsd%2Fall%2Frepodata%2Frepomd.xml%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2FSERVERIP%2Fimx6qsd%2Fall%2Frepodata%2Frepomd.xml%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Erepomd.xml%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2016%25%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E8%8E%B7%E5%8F%96%E2%80%9Cimx6qsabresd%E2%80%9D%E7%9A%84%E4%BF%A1%E6%81%AF%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%3E%3CSPAN%3E-%26gt%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2FSERVERIP%2Fimx6qsd%2Fimx6qsabresd%2Frepodata%2Frepomd.xml%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2FSERVERIP%2Fimx6qsd%2Fimx6qsabresd%2Frepodata%2Frepomd.xml%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Erepomd.xml%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2041%25%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E8%8E%B7%E5%8F%96%E2%80%9Ccortexa9hf_vfp_neon%E2%80%9D%E7%9A%84%E4%BF%A1%E6%81%AF...%3C%2FP%3E%3CP%3E%3CSPAN%3E-%26gt%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2FSERVERIP%2Fimx6qsd%2Fcortexa9hf_vfp_neon%2Frepodata%2Frepomd.xml%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2FSERVERIP%2Fimx6qsd%2Fcortexa9hf_vfp_neon%2Frepodata%2Frepomd.xml%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Erepomd.xml%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2066%25%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E6%9B%B4%E6%96%B0%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A2%91%E9%81%93%E6%B2%A1%E6%9C%89%E6%96%B0%E7%9A%84%E5%A5%97%E9%A4%90%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId--249942205%22%20id%3D%22toc-hId--249942205%22%20id%3D%22toc-hId-672533382%22%3E3.%20%E6%90%9C%E7%B4%A2%E5%B0%81%E8%A3%85%3C%2FH5%3E%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E6%9F%A5%E7%9C%8B%E6%89%80%E6%9C%89%E5%8C%85%E5%90%AB%E5%AD%97%E7%AC%A6%E4%B8%B2%E2%80%9Cclient%E2%80%9D%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20smart%20search%20client*%3C%2FSPAN%3E%0ALoading%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0AUpdating%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0Alibice%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20ICE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Inter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EClient%20Exchange%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Alibice%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20ICE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Inter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EClient%20Exchange%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0Alibice%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edoc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20ICE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Inter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EClient%20Exchange%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Documentation%20files%0Alibice%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Estaticdev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20ICE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Inter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EClient%20Exchange%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EStatic%20Libraries%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0Alibice6%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20ICE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Inter%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EClient%20Exchange%20library%0Alibsm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20SM%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Session%20Management%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Alibsm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20SM%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Session%20Management%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0Alibsm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edoc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20SM%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Session%20Management%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Documentation%20files%0Alibsm%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Estaticdev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20SM%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Session%20Management%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EStatic%20Libraries%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0Alibsm6%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20SM%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Session%20Management%20library%0Alibx11%3CSPAN%20class%3D%22number%20token%22%3E-6%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%0Alibx11%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Alibx11%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0Alibx11%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edoc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Documentation%20files%0Alibx11%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elocale%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%0Alibx11%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Estaticdev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EStatic%20Libraries%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0Alibx11%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Excb1%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xlib%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20C%20Language%20X%20Interface%20library%0Alibxau%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xau%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Authority%20Database%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Alibxau%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xau%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Authority%20Database%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0Alibxau%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edoc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xau%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Authority%20Database%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Documentation%20files%0Alibxau%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Estaticdev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xau%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Authority%20Database%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EStatic%20Libraries%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0Alibxau6%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Xau%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Authority%20Database%20library%0Apython%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Enetclient%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Python%20Internet%20Protocol%20clients%0Axtrans%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20XTrans%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Transport%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Axtrans%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20XTrans%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Transport%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0Axtrans%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edoc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20XTrans%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20X%20Transport%20library%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Documentation%20files%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1721239752%22%20id%3D%22toc-hId-1721239752%22%20id%3D%22toc-hId--1651251957%22%3E%E5%B0%86%20openssh%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%B7%BB%E5%8A%A0%E5%88%B0%20core-image%20minimal%3C%2FH1%3E%3CP%3Ecore-image-minimal%20%E4%B8%8D%E6%8F%90%E4%BE%9B%20openssh%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BE%8B%E5%A6%82%20ssh%20%E6%88%96%20scp%E3%80%82%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E6%B7%BB%E5%8A%A0%E5%AE%83%E4%BB%AC%EF%BC%8C%E6%9B%B4%E6%96%B0%E7%9B%AE%E6%A0%87%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BC%93%E5%AD%98%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId-301033446%22%20id%3D%22toc-hId-301033446%22%20id%3D%22toc-hId-1223509033%22%3E%E4%B8%BB%E6%9C%BA%3C%2FH4%3E%3CP%3E%E8%BF%90%E8%A1%8C%20bitbake%20%E6%9D%A5%E6%89%A7%E8%A1%8C%20packagegroup-core-ssh-openssh%20%E5%8C%85%E7%BB%84%E7%9A%84%E6%89%80%E6%9C%89%E4%BB%BB%E5%8A%A1%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20bitbake%20packagegroup%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ecore%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eopenssh%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%8D%95%E7%8B%AC%E6%9E%84%E5%BB%BA%E5%8C%85%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%8A%A1%E5%BF%85%E6%9B%B4%E6%96%B0%E5%8C%85%E7%B4%A2%E5%BC%95%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20bitbake%20package%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eindex%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9B%AE%E6%A0%87%3C%2FP%3E%3CP%3E%E8%BF%90%E8%A1%8C%20smart%20%E6%9D%A5%E6%9B%B4%E6%96%B0%E6%9C%AC%E5%9C%B0%E7%BC%93%E5%AD%98%EF%BC%8C%E4%BB%A5%E4%BB%8E%E4%B8%8A%E9%9D%A2%E7%9A%84%20bake%20%E4%B8%AD%E8%8E%B7%E5%8F%96%E6%96%B0%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20smart%20update%3C%2FSPAN%3E%0ALoading%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0AUpdating%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0AFetching%20information%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E'all'%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eall%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepomd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Arepomd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2016%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eall%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eprimary%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Aprimary%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2025%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eall%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efilelists%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Afilelists%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2033%25%5D%3C%2FSPAN%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0AFetching%20information%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E'imx6qsabresd'%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsabresd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepomd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Arepomd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2050%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsabresd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eprimary%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsabresd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efilelists%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Afilelists%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2058%25%5D%3C%2FSPAN%3E%0Aprimary%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2066%25%5D%3C%2FSPAN%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0AFetching%20information%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E'cortexa9hf_vfp_neon'%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepomd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Arepomd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2083%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eprimary%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Aprimary%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2091%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erepodata%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efilelists%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Afilelists%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Exml%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0AUpdating%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0AChannels%20have%20%3CSPAN%20class%3D%22number%20token%22%3E15%3C%2FSPAN%3E%20new%20packages%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0ASaving%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A3%80%E6%9F%A5%E6%9C%89%E5%85%B3%E6%9C%AC%E5%9C%B0%E7%BC%93%E5%AD%98%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20smart%20stats%3C%2FSPAN%3E%0ALoading%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0AUpdating%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0AInstalled%20Packages%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E80%3C%2FSPAN%3E%0ATotal%20Packages%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3586%3C%2FSPAN%3E%0ATotal%20Provides%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E6580%3C%2FSPAN%3E%0ATotal%20Requires%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1611%3C%2FSPAN%3E%0ATotal%20Upgrades%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3565%3C%2FSPAN%3E%0ATotal%20Conflicts%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E25%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9F%A5%E7%9C%8B%E5%BD%93%E5%89%8D%E5%8F%AF%E7%94%A8%E7%9A%84%20ssh%20%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20smart%20search%20*ssh*%3C%2FSPAN%3E%0ALoading%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0AUpdating%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0Aopenssh%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edoc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Documentation%20files%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ekeygen%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emisc%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eptest%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Package%20test%20files%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Escp%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esftp%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esftp%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eserver%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esshd%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Secure%20rlogin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ersh%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ercp%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etelnet%20replacement%0Apackagegroup%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ecore%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eopenssh%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20OpenSSH%20SSH%20client%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eserver%0Apackagegroup%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ecore%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edbg%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20OpenSSH%20SSH%20client%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eserver%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Debugging%20files%0Apackagegroup%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ecore%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edev%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20OpenSSH%20SSH%20client%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eserver%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20Development%20files%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%89%E8%A3%85%20openssh%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20smart%20install%20openssh%3C%2FSPAN%3E%0ALoading%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0AUpdating%20cache%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0AComputing%20transaction%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%0A%0AInstalling%20packages%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E9%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%0A%26nbsp%3B%20openssh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ekeygen%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Escp%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esshd%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20shadow%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20shadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ebase%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20shadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esecuretty%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er3%40imx6qsabresd%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%20util%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elinux%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esulogin%3CSPAN%20class%3D%22number%20token%22%3E-2.25%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er1%40cortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0A%0A%3CSPAN%20class%3D%22number%20token%22%3E1.%3C%2FSPAN%3E4MB%20of%20package%20files%20are%20needed%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3.%3C%2FSPAN%3E2MB%20will%20be%20used%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%0A%0AConfirm%20changes%3F%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3EY%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3En%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20y%0A%0A%0AFetching%20packages%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eshadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esecuretty%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er3%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eimx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%26nbsp%3B%26nbsp%3B%20%0A%0Ashadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esecuretty%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er3%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eimx%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2011%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Escp%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%20%0A%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Escp%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2022%25%5D%3C%2FSPAN%3E%0Aopenssh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_v%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2033%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esshd%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esshd%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2044%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eshadow%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%20%0A%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2055%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eimx6qsd%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eshadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ebase%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%20%0A%0Ashadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ebase%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2066%25%5D%3C%2FSPAN%3E%0Ashadow%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vf%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2077%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eutil%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elinux%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esulogin%3CSPAN%20class%3D%22number%20token%22%3E-2.25%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er1%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%20%0A%0Autil%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elinux%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esulogin%3CSPAN%20class%3D%22number%20token%22%3E-2.25%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er1%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2088%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%0Ahttp%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3ESERVERIP%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ekeygen%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Erpm%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%0Aopenssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ekeygen%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecorte%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%0A%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0ACommitting%20transaction%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0APreparing%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%26nbsp%3B%200%25%5D%3C%2FSPAN%3E%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2011%25%5D%3C%2FSPAN%3E%0AOutput%20%3CSPAN%20class%3D%22keyword%20token%22%3Efrom%3C%2FSPAN%3E%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Essh%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Essh%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eopenssh%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Escp%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2022%25%5D%3C%2FSPAN%3E%0AOutput%20%3CSPAN%20class%3D%22keyword%20token%22%3Efrom%3C%2FSPAN%3E%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Escp%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Escp%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Escp%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eopenssh%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20shadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esecure%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2033%25%5D%3C%2FSPAN%3E%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20shadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ebase%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2044%25%5D%3C%2FSPAN%3E%0AOutput%20%3CSPAN%20class%3D%22keyword%20token%22%3Efrom%3C%2FSPAN%3E%20shadow%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ebase%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Enewgrp%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Enewgrp%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Egroups%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Egroups%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Elogin%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Elogin%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esu%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esu%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20util%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elinux%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esu%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2055%25%5D%3C%2FSPAN%3E%0AOutput%20%3CSPAN%20class%3D%22keyword%20token%22%3Efrom%3C%2FSPAN%3E%20util%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elinux%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esulogin%3CSPAN%20class%3D%22number%20token%22%3E-2.25%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er1%40cortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esulogin%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esulogin%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eutil%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elinux%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E6%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ekeygen%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2066%25%5D%3C%2FSPAN%3E%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E7%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20shadow%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2077%25%5D%3C%2FSPAN%3E%0AOutput%20%3CSPAN%20class%3D%22keyword%20token%22%3Efrom%3C%2FSPAN%3E%20shadow%3CSPAN%20class%3D%22number%20token%22%3E-4.2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Epasswd%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Epasswd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Echfn%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Echfn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Echsh%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Echsh%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Echpasswd%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Echpasswd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evipw%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evipw%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0Aupdate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ealternatives%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Linking%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evigr%20to%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esbin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evigr%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eshadow%0AOutput%20%3CSPAN%20class%3D%22keyword%20token%22%3Efrom%3C%2FSPAN%3E%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esshd%3CSPAN%20class%3D%22number%20token%22%3E-6.%3C%2FSPAN%3E7p1%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Er0%40cortexa9hf_vfp_neon%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%20Removing%20any%20system%20startup%20links%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20sshd%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0ARunning%20useradd%20commands%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0ANOTE%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20Performing%20useradd%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewith%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esystem%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eno%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ecreate%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ehome%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ehome%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edir%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Evar%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Erun%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esshd%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eshell%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efalse%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Euser%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Egroup%20sshd%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3Eand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20times%20of%20retry%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E8%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20openssh%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esshd%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B%2088%25%5D%3C%2FSPAN%3E%0A%20Adding%20system%20startup%20%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eetc%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Einit%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ed%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Esshd%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0AStarting%20OpenBSD%20Secure%20Shell%20server%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%20sshd%0A%26nbsp%3B%20generating%20ssh%20RSA%20key%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%26nbsp%3B%20generating%20ssh%20ECDSA%20key%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%26nbsp%3B%20generating%20ssh%20DSA%20key%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%26nbsp%3B%20generating%20ssh%20ED25519%20key%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0Adone%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%0A%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22number%20token%22%3E9%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3EInstalling%20openssh%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22comment%20token%22%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A3%80%E6%9F%A5%20scp%20%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx6qsabresd%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E~%3C%2FSPAN%3E%3CSPAN%20class%3D%22comment%20token%22%3E%23%20which%20scp%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eusr%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Escp%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1893669174%22%20id%3D%22toc-hId--1893669174%22%20id%3D%22toc-hId--971193587%22%3E%E6%91%98%E8%A6%81%3C%2FH1%3E%3CP%3E%E8%A6%81%E5%9C%A8%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E6%B7%BB%E5%8A%A0%E6%96%B0%E5%8C%85%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%20bitbake%20%3CRECIPE%3E%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20bitbake%20package-index%20%E4%BB%A5%E6%9B%B4%E6%96%B0%20RPM%20%E8%B7%9F%E8%B8%AA%E4%BF%A1%E6%81%AF%E3%80%82%E5%9C%A8%E7%9B%AE%E6%A0%87%E6%9D%BF%E4%B8%8A%EF%BC%8C%E8%BF%90%E8%A1%8C%E6%99%BA%E8%83%BD%E6%9B%B4%E6%96%B0%EF%BC%8C%E7%84%B6%E5%90%8E%E6%99%BA%E8%83%BD%E5%AE%89%E8%A3%85%3CPACKAGE%3E%E3%80%82%E4%BD%BF%E7%94%A8%E6%99%BA%E8%83%BD%E6%90%9C%E7%B4%A2%3CREGULAR%20expression%3D%22%22%20string%3D%22%22%3E%E6%9D%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E5%AE%89%E8%A3%85%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%3C%2FREGULAR%3E%3C%2FPACKAGE%3E%3C%2FRECIPE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CYihan%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E5%88%86%E4%BA%AB%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%BD%95%20%2Fhome%2Fcheng%2Ffsl-auto-yocto-bsp%2Fbuild_s32g274aevb%2Ftmp%2Fdeploy%2Frpm%2F.repodata%2F%3C%2FP%3E%3CP%3E%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A0%E9%99%A4%E8%AF%A5%E7%9B%AE%E5%BD%95%E5%B9%B6%E9%87%8D%E6%96%B0%E5%B0%9D%E8%AF%95%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20rm%20-fr%20%2Fhome%2Fcheng%2Ffsl-auto-yocto-bsp%2Fbuild_s32g274aevb%2Ftmp%2Fdeploy%2Frpm%2F.repodata%2F%3C%2FP%3E%3CP%3E%24%20cd%20%24BUILDDIR%3C%2FP%3E%3CP%3E%24%20bitbake%20package-index%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9S32%E7%9A%84%E4%BD%BF%E7%94%A8%E7%BB%8F%E9%AA%8C%E4%B8%8D%E5%A4%9A%EF%BC%8C%E4%BD%86%E5%AF%B9%E4%BA%8Ei.MX%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%E4%B8%80%E4%BA%9B%E5%AF%B9%E6%88%91%E6%9C%89%E6%95%88%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20Ubuntu%2064%20%E4%BD%8D%E4%B8%BB%E6%9C%BA%E4%B8%8A%EF%BC%88%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%E4%B8%BA%2018.04%EF%BC%89%3C%2FP%3E%3CP%3EWeb%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E2%80%94%E2%80%94%E5%B8%82%E5%9C%BA%E4%B8%8A%E6%9C%89%E5%87%A0%E7%A7%8D%E9%80%89%E6%8B%A9%EF%BC%8C%E8%BF%99%E6%AC%BE%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%95%88%E6%9E%9C%E4%B8%8D%E9%94%99%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20sudo%20apt-get%20install%20python-twisted-web%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E6%82%A8%E7%9A%84%E6%98%A0%E5%83%8F%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%9C%A8i.MX%E4%B8%8A%E4%BD%BF%E7%94%A8%E6%AD%A4%E9%85%8D%E6%96%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20cd%20%24BUILDDIR%3C%2FP%3E%3CP%3E%24%20bitbake%20imx-image-full%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%20dnf%20%E5%88%9B%E5%BB%BA%E5%85%83%E6%95%B0%E6%8D%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20bitbake%20package-index%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8Web%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%9A%EF%BC%88Ubuntu%E4%B8%BB%E6%9C%BAIP%E5%9C%B0%E5%9D%8010.0.0.100%EF%BC%8C%E7%94%A8%E4%BA%8E%E4%B8%8B%E6%96%87%E7%9A%84%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%EF%BC%89%3C%2FP%3E%3CP%3E%24%20twistd%20web%20%E2%80%93patch%20tmp%2Fdeploy%2Frpm%20%E2%80%93port%20tcp%3A8080%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E6%97%B6%EF%BC%8C%E5%9F%BA%E4%BA%8E%20imx-image-full%20%E9%95%9C%E5%83%8F%E7%9A%84%20Web%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E5%8F%AF%E9%80%9A%E8%BF%87%20DNF%20%E8%BF%9B%E8%A1%8C%E7%AE%A1%E7%90%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Fetc%2Fyum.repos.d%E7%9B%AE%E5%BD%95%E6%98%AF%20DNF%20%E9%BB%98%E8%AE%A4%E6%9F%A5%E6%89%BE%E5%8C%85%E5%90%AB%E4%BB%93%E5%BA%93%E4%BF%A1%E6%81%AF%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E7%B2%98%E8%B4%B4%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E4%BB%A5%E8%AE%BE%E7%BD%AE%20dnf%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%82%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emkdir%20%2Fetc%2Fyum.repos.d%3C%2FP%3E%3CP%3Ecd%20%2Fetc%2Fyum.repos.d%3C%2FP%3E%3CP%3Ecat%20%26gt%3B%20imx.repo%20%26lt%3B%26lt%3B%20END%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8D%E7%A7%B0%3Di.MX%20rpm%20%E4%BB%93%E5%BA%93%3C%2FP%3E%3CP%3Ebaseurl%3D%3CA%20href%3D%22http%3A%2F%2F10.0.0.100%3A8080%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2F10.0.0.100%3A8080%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%90%AF%E7%94%A8%3D1%3C%2FP%3E%3CP%3Emetadata_expire%3D0%3C%2FP%3E%3CP%3Egpgcheck%3D0%3C%2FP%3E%3CP%3EEND%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E8%AE%BE%E7%BD%AE%E6%AD%A5%E9%AA%A4%E6%98%AF%E5%9C%A8%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%88%9B%E5%BB%BA%E6%9C%AC%E5%9C%B0%E7%BC%93%E5%AD%98%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20dnf%20makecache%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%8F%AF%E4%BB%A5%E2%80%9Cdnf%20search%20package%E2%80%9D%E5%92%8C%E2%80%9Cdnf%20install%20package%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%E4%B8%AD%E6%83%B3%E8%A6%81%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%BA%9B%E5%86%85%E5%AE%B9%EF%BC%8C%E6%95%B4%E4%BD%93%E6%B5%81%E7%A8%8B%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20bitbake%20newRecipe%3C%2FP%3E%3CP%3E%24%20bitbake%20package-index%20-%20%E9%9C%80%E8%A6%81%E6%9B%B4%E6%96%B0%20dnf%20%E7%9A%84%E5%85%83%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%BC%80%E5%8F%91%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20dnf%20update%20%E6%88%96%20dnf%20makecache%3C%2FP%3E%3CP%3E%24%20dnf%20install%20newRecipe%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B8%AA%E6%B5%81%E7%A8%8B%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E5%BE%88%E6%9C%89%E6%95%88%EF%BC%8C%E7%A5%9D%E6%82%A8%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FP%3E%3CP%3E-Curtis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2015px%3B%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8CCurtis%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20font-size%3A%2015px%3B%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E5%9C%A8%26lt%3B%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%90%8E%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%9A%22%3CSTRONG%3E%20bitbake%20package-index%3C%2FSTRONG%3E%20%22%26gt%3B%3CBUILD-DIRECTORY%3E%3C%2FBUILD-DIRECTORY%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23ff0000%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9Apackage-index-1.0-r0do_package_index%3A%20%E5%9C%A8%20exec_python_func()%20%E4%B8%AD%E6%89%A7%E8%A1%8C%20Python%20%E5%87%BD%E6%95%B0%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%88%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23ff0000%3B%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23ff0000%3B%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23ff0000%3B%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23ff0000%3B%22%3E%E5%AD%90%E8%BF%9B%E7%A8%8B%E8%BE%93%E5%87%BA%EF%BC%9A%3CBR%20%2F%3E%E4%B8%B4%E6%97%B6%20repodata%20%E7%9B%AE%E5%BD%95%20%2Fhome%2Fcheng%2Ffsl-auto-yocto-bsp%2Fbuild_s32g274aevb%2Ftmp%2Fdeploy%2Frpm%2F.repodata%2F%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%EF%BC%81%EF%BC%88%E5%8F%A6%E4%B8%80%E4%B8%AA%20createrepo%20%E8%BF%9B%E7%A8%8B%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E5%90%97%EF%BC%9F%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23ff0000%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9Apackage-index-1.0-r0do_package_index%3A%20%E5%87%BD%E6%95%B0%E6%89%A7%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_package_index%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%A4%B1%E8%B4%A5%E6%97%A5%E5%BF%97%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fcheng%2Ffsl-auto-yocto-bsp%2Fbuild_s32g274aevb%2Ftmp%2Fwork%2Faarch64-fsl-linux%2Fpackage-index%2F1.0-r0%2Ftemp%2Flog.do_package_index.39272%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%20(%2Fhome%2Fcheng%2Ffsl-auto-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fmeta%2Fpackage-index.bb%3Ado_package_index)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E7%A0%81%E4%B8%BA%20'1'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E6%91%98%E8%A6%81%EF%BC%9A1%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%20%2Fhome%2Fcheng%2Ffsl-auto-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fmeta%2Fpackage-index.bb%3Ado_package_index%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%86%202%20%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E4%BA%86%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E7%A0%81%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E6%82%A8%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E5%AE%83%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3EYihan%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3EYocto%20Project%202.4%20Rocko%20%E7%89%88%E6%9C%AC%E7%9A%84%20smart%20%E5%B7%B2%E8%A2%AB%20dnf%20%E5%8F%96%E4%BB%A3%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F2.4%2Fmega-manual%2Fmega-manual.html%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F2.4%2Fmega-manual%2Fmega-manual.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E24.11.8%E3%80%82%E5%8C%85%E7%AE%A1%E7%90%86%E5%8F%98%E6%9B%B4%C2%B6%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E6%9B%B4%E6%94%B9%E5%B7%B2%E5%8F%91%E7%94%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%E6%99%BA%E8%83%BD%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E5%99%A8%E8%A2%AB%20DNF%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E5%99%A8%E6%9B%BF%E4%BB%A3%E3%80%82Smart%20%E5%B7%B2%E4%B8%8D%E5%86%8D%E7%94%B1%E4%B8%8A%E6%B8%B8%E7%BB%B4%E6%8A%A4%EF%BC%8C%E4%B8%94%E6%9C%AA%E7%A7%BB%E6%A4%8D%E5%88%B0%20Python%203.x%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8CSmart%20%E9%9C%80%E8%A6%81%E8%A2%AB%E6%9B%BF%E6%8D%A2%E3%80%82DNF%20%E6%98%AF%E5%94%AF%E4%B8%80%E5%8F%AF%E8%A1%8C%E7%9A%84%E5%80%99%E9%80%89%E4%BA%BA%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20Yocto%20Project%20%E7%89%88%E6%9C%AC%E6%98%AF%202.4%20%E6%88%96%E6%9B%B4%E9%AB%98%EF%BC%8C%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20dnf%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E8%AF%A2%E9%97%AE%20SMART%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%AE%A1%E7%90%86%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%20S32XX%20%E5%B9%B3%E5%8F%B0%EF%BC%9F%E7%94%B1%E4%BA%8E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20s32g%20%E5%B9%B3%E5%8F%B0%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%A5%E6%A0%BC%E6%8C%89%E7%85%A7%E6%95%99%E7%A8%8B%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%EF%BC%8C%E7%84%B6%E8%80%8C%E5%BD%93%E6%88%91%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8%20SD%20%E5%8D%A1%E5%B9%B6%E5%B0%86%E5%85%B6%E6%8F%92%E5%85%A5%E4%B8%BB%E6%9D%BF%E7%9A%84%E6%8F%92%E6%A7%BD%E6%97%B6%E3%80%82%E5%9C%A8%20rootfs%20%E4%B8%AD%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%20smart%20excuable%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E4%B8%94%20konsol%20%E8%AF%B4%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20smart%20%E7%9A%84%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EYihan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%EF%BC%81%3C%2FP%3E%3CP%3E%E9%9A%BE%E9%81%93%E6%B2%A1%E6%9C%89%E4%B8%80%E4%B8%AA%E9%80%82%E5%90%88%E6%89%80%E6%9C%89%E4%BA%BA%E7%9A%84%20Web%20%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%88%E5%9C%A8%3CA%20href%3D%22http%3A%2F%2Fwww...%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%B8%87%E7%BB%B4%E7%BD%91%E4%B8%AD%E2%80%A6%E2%80%A6%3C%2FA%3E%EF%BC%89%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%99%BA%E8%83%BD%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BD%BF%E7%94%A8%20imx6%20%E7%9A%84%20rpm%EF%BC%8C%E5%B0%B1%E5%83%8F%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E9%80%9A%E5%B8%B8%E4%BD%BF%E7%94%A8%E2%80%9Capt-get%E2%80%9D%E4%B8%80%E6%A0%B7%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ERan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B7%B2%E6%9B%B4%E6%96%B0%E5%88%9D%E5%A7%8B%E5%B8%96%E5%AD%90%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E5%AE%9E%E7%94%A8%E7%9A%84%E6%95%99%E7%A8%8B%EF%BC%8C%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%8C%87%E5%87%BA%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FCurtisWald%22%20target%3D%22_blank%22%3ECurtisWald%3C%2FA%3E%20%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%BF%AE%E6%AD%A3%E7%9A%84%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9C%BA%E7%94%B5%E8%84%91%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E5%90%8D%E7%A7%B0%E5%9C%A8%E4%BB%A5%E4%B8%8B%E4%B8%A4%E4%B8%AA%E6%AD%A5%E9%AA%A4%E4%B8%AD%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%8C%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A5%E9%AA%A41%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%9C%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20Web%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E8%BD%AF%E9%93%BE%E6%8E%A5%EF%BC%8C%E6%8C%87%E5%90%91%E6%9E%84%E5%BB%BA%E7%94%9F%E6%88%90%E7%9A%84%20rpm%20%E7%9B%AE%E5%BD%95%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%B7%E5%B0%86%20%24HOME%2F%3CBUILD%3E%20%E6%9B%B4%E6%96%B0%E4%B8%BA%E6%82%A8%E5%AE%9E%E9%99%85%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FBUILD%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23fbfbfb%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%201px%200px%200px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20padding%3A%200px%200px%200px%2045px%3B%22%3E%3CDIV%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20color%3A%20black%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%24%20ln%20-s%20%24HOME%2F%3CBUILD%3E%2Ftmp%2Fdeploy%2Frpm%20%2Fvar%2Fwww%2F%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Eimx6q%3C%2FSPAN%3E%3C%2FBUILD%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%AD%A5%E9%AA%A42%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CH5%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2014px%3B%22%20id%3D%22toc-hId-1782795862%22%20id%3D%22toc-hId-2032650122%22%3E1.%20%E6%B7%BB%E5%8A%A0%E9%80%9A%E9%81%93%3C%2FH5%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E8%A6%81%E5%B0%86%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%9B%AE%E6%A0%87%EF%BC%8C%E4%BD%BF%E7%94%A8%20smart%20%E9%80%9A%E9%81%93%E7%9A%84%20--add%20%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E8%AF%B7%E6%82%A8%E8%BE%93%E5%85%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%B9%B6%E6%9B%BF%E6%8D%A2%E4%B8%8B%E6%96%B9%E7%9A%84%20SERVERIP%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23fbfbfb%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%201px%200px%200px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20padding%3A%200px%200px%200px%2045px%3B%22%3E%3CDIV%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20color%3A%20black%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%3CSPAN%3Esmart%26nbsp%3Bchannel%26nbsp%3B--add%26nbsp%3Ball%26nbsp%3Btype%3Drpm-md%26nbsp%3Bname%3Dall%26nbsp%3Bbaseurl%3D%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252FSERVERIP%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2FSERVERIP%2F%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Eimx6qsd%3C%2FSPAN%3E%2Fall%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%3CSPAN%3Esmart%26nbsp%3Bchannel%26nbsp%3B--add%26nbsp%3Bcortexa9hf_vfp_neon%26nbsp%3Btype%3Drpm-md%26nbsp%3Bname%3Dcortexa9hf_vfp_neon%26nbsp%3Bbaseurl%3D%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252FSERVERIP%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2FSERVERIP%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%2Fimx6qsd%3C%2FSPAN%3E%2Fcortexa9hf_vfp_neon%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%3CSPAN%3Esmart%26nbsp%3Bchannel%26nbsp%3B--add%26nbsp%3Bimx6qsabresd%26nbsp%3Btype%3Drpm-md%26nbsp%3Bname%3Dimx6qsabresd%26nbsp%3Bbaseurl%3D%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252FSERVERIP%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2FSERVERIP%2F%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Eimx6qsd%3C%2FSPAN%3E%2Fimx6qsabresd%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%B9%B2%E6%9D%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8C%85%E7%AE%A1%E7%90%86%20-%20smart%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E5%B0%BD%E5%BF%AB%E5%8D%8F%E5%8A%A9%E8%A7%A3%E5%86%B3%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%89%A7%E8%A1%8C%20bitbake%20fsl-image-gui%20%E5%90%8E%E6%8A%A5%E9%94%99%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fftp.gnu.org%2Fgnu%2Fautomake%2Fautomake-1.15.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fftp.gnu.org%2Fgnu%2Fautomake%2Fautomake-1.15.tar.gz%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fftp.gnu.org%2Fgnu%2Flibtool%2Flibtool-2.4.6.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fftp.gnu.org%2Fgnu%2Flibtool%2Flibtool-2.4.6.tar.gz%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Ftukaani.org%2Fxz%2Fxz-5.2.0.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Ftukaani.org%2Fxz%2Fxz-5.2.0.tar.gz%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgmplib.org%2Fdownload%2Fgmp%2Fgmp-6.0.0a.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgmplib.org%2Fdownload%2Fgmp%2Fgmp-6.0.0a.tar.bz2%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fdownload.savannah.gnu.org%2Freleases%2Fattr%2Fattr-2.4.47.src.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.savannah.gnu.org%2Freleases%2Fattr%2Fattr-2.4.47.src.tar.gz%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fdownloads.sourceforge.net%2Fflex%2Fflex-2.5.39.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownloads.sourceforge.net%2Fflex%2Fflex-2.5.39.tar.bz2%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fftp.gnu.org%2Fgnu%2Fbinutils%2Fbinutils-2.24.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fftp.gnu.org%2Fgnu%2Fbinutils%2Fbinutils-2.24.tar.bz2%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.multiprecision.org%2Fmpc%2Fdownload%2Fmpc-1.0.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.multiprecision.org%2Fmpc%2Fdownload%2Fmpc-1.0.2.tar.gz%3C%2FA%3E%3CSPAN%3E%EF%BC%8C%E5%B0%86%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%99%A8%E6%95%85%E9%9A%9C%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%91%BD%E4%BB%A4%E6%89%A7%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%204%EF%BC%8C%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3Ewget%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E4%B8%BB%E6%9C%BA%E5%9C%B0%E5%9D%80%20'%3CA%20href%3D%22http%3A%2F%2Fwww.multiprecision.org%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.multiprecision.org%3C%2FA%3E'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E6%89%A7%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20'%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.multiprecision.org%2Fmpc%2Fdownload%2Fmpc-1.0.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.multiprecision.org%2Fmpc%2Fdownload%2Fmpc-1.0.2.tar.gz%3C%2FA%3E%3CSPAN%3E'%E3%80%82%E6%97%A0%E6%B3%95%E4%BB%8E%E4%BB%BB%E4%BD%95%E6%9D%A5%E6%BA%90%E8%8E%B7%E5%8F%96%E8%AF%A5%20URL%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fswapnil%2Ffsl-release-bsp%2Fbuild-x11%2Ftmp%2Fwork%2Fx86_64-linux%2Flibmpc-native%2F1.0.2-r0%2Ftemp%2Flog.do_fetch.25793%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%203407%EF%BC%88virtual%3Anative%3A%2Fhome%2Fswapnil%2Ffsl-release-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-support%2Flibmpc%2Flibmpc_1.0.2.bb%EF%BC%8Cdo_fetch%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 01:58 AM
更新人:
