WM8960 audio codec
WM8960 audio codec
WM8960 audio codec
Introduction
This is a sharing of my experience about porting the audio codec WM8960 in Linux BSP. I know this driver is not the perfect one.  If you find any place is not good in the driver, please let me know.
This driver is modified base on the wm8960.c in L3.0.35 Linux BSP. This document is talking about how to modify the codec driver. The Audio Codec driver is located in linux/sound/soc/codec/wm8960.c.
ALSA
The Audio Codec driver is based on ALSA to setup up all the things. For details, please see :
AlsaProject
Advanced Linux Sound Architecture - Wikipedia, the free encyclopedia.
kcontrols are defined in linux/include/sound/soc.h and soc-dapm.h.
Audio controls and path in WM8960
Left and Right Input signal path
Output signal path
Base on the input and output signal diagrams, we can setup all the controls that we want in the driver. Such as switches, volume controls, PGA controls and so on. All the controls below can be used in the alsamixer.
static const struct snd_kcontrol_new wm8960_snd_controls[] = {
SOC_DOUBLE_R_TLV("PCM DAC Playback Volume", WM8960_LDAC, WM8960_RDAC, 0, 255, 0, dac_tlv), //LDACVOL , RDACVOL
SOC_DOUBLE_R_TLV("PCM ADC Capture Volume", WM8960_LADC, WM8960_RADC, 0, 255, 0, adc_tlv), //LADCVOL, RADCVOL
SOC_DOUBLE_R_TLV("Headphone Volume", WM8960_LOUT1, WM8960_ROUT1, 0, 127, 0, out_tlv),
SOC_DOUBLE_R("Headphone ZC Switch", WM8960_LOUT1, WM8960_ROUT1,    7, 1, 0),
SOC_DOUBLE_R_TLV("Speaker Volume", WM8960_LOUT2, WM8960_ROUT2, 0, 127, 0, out_tlv),
SOC_DOUBLE_R("Speaker ZC Switch", WM8960_LOUT2, WM8960_ROUT2, 7, 1, 0),
SOC_DOUBLE_R("Capture Volume ZC Switch", WM8960_LINVOL, WM8960_RINVOL, 6, 1, 0),
SOC_SINGLE_TLV("Input Volume of LINPUT1", WM8960_LINVOL, 0, 63, 0, in_tlv),  //LINVOL
SOC_SINGLE_TLV("Input Volume of RINPUT1", WM8960_RINVOL, 0, 63, 0, in_tlv),  //RINVOL
SOC_SINGLE_TLV("Input Boost Volume LINPUT3", WM8960_INBMIX1, 4, 7, 0, boost_tlv),    //RIN3BOOST
SOC_SINGLE_TLV("Input Boost Volume LINPUT2", WM8960_INBMIX1, 1, 7, 0, boost_tlv),    //RIN2BOOST
SOC_SINGLE_TLV("Input Boost Volume RINPUT3", WM8960_INBMIX2, 4, 7, 0, boost_tlv),    //LIN3BOOST
SOC_SINGLE_TLV("Input Boost Volume RINPUT2", WM8960_INBMIX2, 1, 7, 0, boost_tlv),    //LIN2BOOST
SOC_SINGLE_TLV("PGA LB2LOVOL-Bypass from Left Boost", WM8960_BYPASS1, 4, 7, 1, bypass_tlv),    //LB2LOVOL
SOC_SINGLE_TLV("PGA LI2LOVOL-Bypass from LINPUT3", WM8960_LOUTMIX, 4, 7, 1, bypass_tlv),    //LI2LOVOL
SOC_SINGLE_TLV("PGA RB2ROVOL-Bypass from Right Boost", WM8960_BYPASS2, 4, 7, 1, bypass_tlv),    //RB2ROVOL
SOC_SINGLE_TLV("PGA RI2ROVOL-Bypass from RINPUT3", WM8960_ROUTMIX, 4, 7, 1, bypass_tlv),    //RI2ROVOL
SOC_SINGLE("Capture Mute (Left)", WM8960_LINVOL, 7, 1, 0), // LINMUTE
SOC_SINGLE("Capture Mute (Right)", WM8960_RINVOL, 7, 1, 0), // RINMUTE
SOC_SINGLE("PCM Playback -6dB Switch", WM8960_DACCTL1, 7, 1, 0),
SOC_SINGLE("Speaker DC gain", WM8960_CLASSD3, 3, 5, 0),
SOC_SINGLE("Speaker AC gain", WM8960_CLASSD3, 0, 5, 0),
SOC_ENUM("ADC Polarity", wm8960_enum[0]),
SOC_SINGLE("ADC High Pass Filter Switch", WM8960_DACCTL1, 0, 1, 0),
SOC_ENUM("DAC Polarity", wm8960_enum[2]),
SOC_SINGLE_BOOL_EXT("DAC Deemphasis Switch", 0, wm8960_get_deemph, wm8960_put_deemph),
SOC_ENUM("3D Filter Upper Cut-Off", wm8960_enum[2]),
SOC_ENUM("3D Filter Lower Cut-Off", wm8960_enum[3]),
SOC_SINGLE("3D Depth", WM8960_3D, 1, 15, 0),
SOC_SINGLE("3D", WM8960_3D, 0, 1, 0),
SOC_ENUM("ALC Function", wm8960_enum[4]),
SOC_SINGLE("ALC Max Gain", WM8960_ALC1, 4, 7, 0),
SOC_SINGLE("ALC Target", WM8960_ALC1, 0, 15, 1),
SOC_SINGLE("ALC Min Gain", WM8960_ALC2, 4, 7, 0),
SOC_SINGLE("ALC Hold Time", WM8960_ALC2, 0, 15, 0),
SOC_ENUM("ALC Mode", wm8960_enum[5]),
SOC_SINGLE("ALC Decay", WM8960_ALC3, 4, 15, 0),
SOC_SINGLE("ALC Attack", WM8960_ALC3, 0, 15, 0),
SOC_SINGLE("Noise Gate Threshold", WM8960_NOISEG, 3, 31, 0),
SOC_SINGLE("Noise Gate Switch", WM8960_NOISEG, 0, 1, 0),
SOC_ENUM("Capture Left Boost", wm8960_enum[6]), //LMICBOOST
SOC_ENUM("Capture Right Boost", wm8960_enum[7]), //RMICBOOT
1. SOC_SINGLE(xname, reg, shift, max, invert)
To setup a simple switch, we can use SOC_SINGLE.
e.g
- The name of this control is “PCM Playback -6dB Switch”.
- The register in WM8960 is WM8960_DACCTL1 . (the register address is 0x5, defined in wm8960.h)
- ‘7’ : The 7th bit in DACCTL1 register is used to enable/disable the DAC 6dB Attenuate.
- ‘1’ : Only one enable or disable option.
- ‘0’ : the value you set is not inverted.
2. SOC_SINGLE_TLV(xname, reg, shift, max, invert, tlv_array)
To setup a switch with levels, we can use SOC_SINGLE_TLV.
e.g.
In this example, the left input volume control is from 000000(-17.25dB) to 111111(+30dB). Each step is 0.75dB. Total is 63 steps.
The scale of in_tlv declare like this:
static const DECLARE_TLV_DB_SCALE(in_tlv, -1725, 75, 0);
in_tlv : the name of the scale.
-1725 : start from -17.25dB
75: each step is 0.75dB
0: the step is start from 0. For some volume control case the first step is "mute", then the step is start from 1 so change this number to 1.
for example: The 0000 0000 of the DAC volume control is digital mute.
static const DECLARE_TLV_DB_SCALE(dac_tlv, -12700, 50, 1);
3. SOC_DOUBLE_R(xname, reg_left, reg_right, xshift, xmax, xinvert)
SOC_DOUBLE_R is a stereo version of SOC_SINGLE. You can control the left and right channel at the same time.
e.g.
4. SOC_DOUBLE_R_TLV(xname, reg_left, reg_right, xshift, xmax, xinvert, tlv_array)
SOC_DOUBLE_R_TLV is the stereo version of SOC_SINGLE_TLV.
e.g.
5. SOC_ENUM_SINGLE(xreg, xshift, xmax, xtexts)
When the control option are some texts, we can use SOC_ENUM to enum the options.
e.g. MIC boost
5.1. setup the array for the texts.
static const char *wm8960_micboost[] = {"0dB","+13dB","+20dB","+29dB"};
5.2. use the SOC_ENUM_SINGLE.
static const struct soc_enum wm8960_enum[] = {
     SOC_ENUM_SINGLE(WM8960_DACCTL1, 5, 4, wm8960_polarity),
     SOC_ENUM_SINGLE(WM8960_DACCTL2, 5, 4, wm8960_polarity),
     SOC_ENUM_SINGLE(WM8960_3D, 6, 2, wm8960_3d_upper_cutoff),
     SOC_ENUM_SINGLE(WM8960_3D, 5, 2, wm8960_3d_lower_cutoff),
     SOC_ENUM_SINGLE(WM8960_ALC1, 7, 4, wm8960_alcfunc),
     SOC_ENUM_SINGLE(WM8960_ALC3, 8, 2, wm8960_alcmode),
     SOC_ENUM_SINGLE(WM8960_LINPATH, 4, 4, wm8960_micboost),
     SOC_ENUM_SINGLE(WM8960_RINPATH, 4, 4, wm8960_micboost),
5.3.  use SOC_ENUM to add the controls for MIC boost.
After created all the controls, we can start to create the switches.
The following switches created base on the input and output diagrams. I used the same name from datasheet of each switch. It will more easy to find out the proper switch in alsamixer.
static const struct snd_kcontrol_new wm8960_lin[] = {
SOC_DAPM_SINGLE("<- LMP2", WM8960_LINPATH, 6, 1, 0), //LMP2
SOC_DAPM_SINGLE("<- LMP3", WM8960_LINPATH, 7, 1, 0), //LMP3
SOC_DAPM_SINGLE("<- LMN1", WM8960_LINPATH, 8, 1, 0), //LMN1
static const struct snd_kcontrol_new wm8960_lin_boost[] = {
SOC_DAPM_SINGLE("<- LMIC2B", WM8960_LINPATH, 3, 1, 0), //LMIC2B
static const struct snd_kcontrol_new wm8960_rin[] = {
SOC_DAPM_SINGLE("<- RMP2", WM8960_RINPATH, 6, 1, 0), //RMP2
SOC_DAPM_SINGLE("<- RMP3", WM8960_RINPATH, 7, 1, 0), //RMP3
SOC_DAPM_SINGLE("<- RMN1", WM8960_RINPATH, 8, 1, 0), //RMN1
static const struct snd_kcontrol_new wm8960_rin_boost[] = {
SOC_DAPM_SINGLE("<- RMIC2B", WM8960_RINPATH, 3, 1, 0), //RMIC2B
static const struct snd_kcontrol_new wm8960_loutput_mixer[] = {
SOC_DAPM_SINGLE("<- LD2LO", WM8960_LOUTMIX, 8, 1, 0), //LD2LO
SOC_DAPM_SINGLE("<- LI2LO", WM8960_LOUTMIX, 7, 1, 0), //LI2LO
SOC_DAPM_SINGLE("<- LB2LO", WM8960_BYPASS1, 7, 1, 0), //LB2LO
static const struct snd_kcontrol_new wm8960_routput_mixer[] = {
SOC_DAPM_SINGLE("<- RD2RO", WM8960_ROUTMIX, 8, 1, 0), //RD2RO
SOC_DAPM_SINGLE("<- RI2RO", WM8960_ROUTMIX, 7, 1, 0), //RI2RO
SOC_DAPM_SINGLE("<- RB2RO", WM8960_BYPASS2, 7, 1, 0), //RB2RO
static const struct snd_kcontrol_new wm8960_mono_out[] = {
SOC_DAPM_SINGLE("<- L2MO", WM8960_MONOMIX1, 7, 1, 0), //L2MO
SOC_DAPM_SINGLE("<- R2MO", WM8960_MONOMIX2, 7, 1, 0), //R2MO
Then, create the inputs, ADC, DAC, mixers, PGA and outputs.
static const struct snd_soc_dapm_widget wm8960_dapm_widgets[] = {
SND_SOC_DAPM_INPUT("LINPUT1"),
SND_SOC_DAPM_INPUT("RINPUT1"),
SND_SOC_DAPM_INPUT("LINPUT2"),
SND_SOC_DAPM_INPUT("RINPUT2"),
SND_SOC_DAPM_INPUT("LINPUT3"),
SND_SOC_DAPM_INPUT("RINPUT3"),
SND_SOC_DAPM_MICBIAS("MICB", WM8960_POWER1, 1, 0),
SND_SOC_DAPM_MIXER("Left Boost Mixer", WM8960_POWER1, 5, 0, wm8960_lin_boost, ARRAY_SIZE(wm8960_lin_boost)),
SND_SOC_DAPM_MIXER("Right Boost Mixer", WM8960_POWER1, 4, 0, wm8960_rin_boost, ARRAY_SIZE(wm8960_rin_boost)),
SND_SOC_DAPM_MIXER("Left Input PGA", WM8960_POWER3, 5, 0, wm8960_lin, ARRAY_SIZE(wm8960_lin)),
SND_SOC_DAPM_MIXER("Right Input PGA", WM8960_POWER3, 4, 0, wm8960_rin, ARRAY_SIZE(wm8960_rin)),
SND_SOC_DAPM_ADC("Left ADC", "Capture", WM8960_POWER1, 3, 0),
SND_SOC_DAPM_ADC("Right ADC", "Capture", WM8960_POWER1, 2, 0),
SND_SOC_DAPM_DAC("Left DAC", "Playback", WM8960_POWER2, 8, 0),
SND_SOC_DAPM_DAC("Right DAC", "Playback", WM8960_POWER2, 7, 0),
SND_SOC_DAPM_MIXER("Left Output Mixer", WM8960_POWER3, 3, 0, wm8960_loutput_mixer, ARRAY_SIZE(wm8960_loutput_mixer)),
SND_SOC_DAPM_MIXER("Right Output Mixer", WM8960_POWER3, 2, 0, wm8960_routput_mixer, ARRAY_SIZE(wm8960_routput_mixer)),
SND_SOC_DAPM_PGA("Left HP PGA", WM8960_POWER2, 6, 0, NULL, 0),
SND_SOC_DAPM_PGA("Right HP PGA", WM8960_POWER2, 5, 0, NULL, 0),
SND_SOC_DAPM_PGA("Left Speaker PGA", WM8960_POWER2, 4, 0, NULL, 0),
SND_SOC_DAPM_PGA("Right Speaker PGA", WM8960_POWER2, 3, 0, NULL, 0),
SND_SOC_DAPM_PGA("Right Speaker Output", WM8960_CLASSD1, 7, 0, NULL, 0), //SPK_OP_EN
SND_SOC_DAPM_PGA("Left Speaker Output", WM8960_CLASSD1, 6, 0, NULL, 0),
SND_SOC_DAPM_OUTPUT("SPK_LP"),
SND_SOC_DAPM_OUTPUT("SPK_LN"),
SND_SOC_DAPM_OUTPUT("HP_L"),
SND_SOC_DAPM_OUTPUT("HP_R"),
SND_SOC_DAPM_OUTPUT("SPK_RP"),
SND_SOC_DAPM_OUTPUT("SPK_RN"),
SND_SOC_DAPM_OUTPUT("OUT3"),
Now, we can start to route the audio path.
The path is from right to left , like : { “destination”, “switch”, “source” }
So, lets take the LINPUT1 to ADC as an example:
{ "Left Input PGA", "<- LMN1", "LINPUT1" },
{ "Left Boost Mixer", "<- LMIC2B", "Left Input PGA" },
{ "Left ADC", NULL, "Left Boost Mixer" },
Another example is DAC to Headphone.
                { "Left Output Mixer", "<- LD2LO", "Left DAC" },
                { "Right Output Mixer", "<- RD2RO", "Right DAC" },
                { "Left HP PGA", NULL, "Left Output Mixer" },
                { "Right HP PGA", NULL, "Right Output Mixer" },
                { "HP_L", NULL, "Left HP PGA" },
                { "HP_R", NULL, "Right HP PGA" },
In linux, you can run "alsamixer" to turn on/off the switches and adjust the volumes.
(this picture is an example of alsamixer of other codec, not for wm8960)
In alsamixer, use 'M' to turn the switch on/off,  use arrow keys to control the volumes.
wm8960_dai_ops is another important part in the driver.
Here is the ops of the wm8960_dai.
static struct snd_soc_dai_ops wm8960_dai_ops = {
                .hw_params = wm8960_hw_params,
                .digital_mute = wm8960_mute,
                .set_fmt = wm8960_set_dai_fmt,
                .set_clkdiv = wm8960_set_dai_clkdiv,
                .set_pll = wm8960_set_dai_pll,
wm8960_hw_params : used to set the PCM format (16bit/24bit), set the deemph, alc_rates and etc.
wm8960_mute:  used to mute the output
wm8960_set_dai_fmt : used to set the Master/Slave mode, set the interface format (I2S, DSP, Left justified and Right justified) and set the clock inversion.
wm8960_set_dai_clkdiv: used to set the CLK divider such as DACDIV, ADCDIV, BCLKDIV and so on.
wm8960_set_dai_pll: used to calculate the proper PLL values.
In the wm8960_set_dai_pll, we need to calculate the proper PLL values.
Base on the table, if the MCLK >14.4, the sysclk prescale divider is 2. So, set the sysclk pre-divider to 2 before finding pll_factors.
if (freq_in > 15000000 ) {
                                /* update sysclk div */
                                reg = snd_soc_read(codec, WM8960_CLOCK1) & 0x1f9;
                                snd_soc_write(codec, WM8960_CLOCK1, reg | 0x4);
                                clk_in = clk_in/2;
                if (freq_in && freq_out) {
                                ret = pll_factors(clk_in, freq_out, &pll_div);
                                if (ret != 0)
                                                return ret;
In the driver, there are two names are important. One is the name of codec dai. The name is “wm8960”. Make sure this codec dai name is the same codec dai name used in the imx-wm8960.c.
static struct snd_soc_dai_driver wm8960_dai = {
                .name = "wm8960",
                .playback = {
                                .stream_name = "Playback",
                                .channels_min = 1,
                                .channels_max = 2,
                                .rates = WM8960_RATES,
                                .formats = WM8960_FORMATS,},
                .capture = {
                                .stream_name = "Capture",
                                .channels_min = 1,
                                .channels_max = 2,
                .ops = &wm8960_dai_ops,
                .symmetric_rates = 1,
Another name is the I2C device id. Make sure the I2C name is same as the name used in your_board.c file.
static const struct i2c_device_id wm8960_i2c_id[] = {
                { "wm8960", 0 },
MODULE_DEVICE_TABLE(i2c, wm8960_i2c_id);
static struct i2c_driver wm8960_i2c_driver = {
                .driver = {
                                .name = "wm8960",
                                .owner = THIS_MODULE,
                .probe =    wm8960_i2c_probe,
                .remove =   __devexit_p(wm8960_i2c_remove),
                .id_table = wm8960_i2c_id,
Here is the name used in your_board.c
static struct i2c_board_info mxc_i2c0_board_info[] __initdata = {
        I2C_BOARD_INFO("wm8960", 0x1a),
Machine driver imx-wm8960.c
Basically, the machine driver is the connection between wm8960.c and the i.MX.
It is modified base on the imx-wm8962.c. I didn't add the HP and MIC detection in this driver. If you need the HP and MIC detection, please take the imx-wm8962.c for reference.
Here is an example of my_board.c. The following platform data pass to the machine driver from my board.
static struct platform_device audio_wm8960_device = {
    .name = "imx-wm8960",
static struct mxc_audio_platform_data wm8960_pdata;
static int wm8960_clk_enable(int enable)
    if (enable)
        clk_enable(clko);
    else
        clk_disable(clko);
    return 0;
static int mxc_wm8960_init(void)
    int rate;
    clko = clk_get(NULL, "clko_clk");
    if (IS_ERR(clko)) {
        pr_err("can't get CLKO clock.\n");
        return PTR_ERR(clko);
    /* both audio codec and comera use CLKO clk*/
    rate = clk_round_rate(clko, 24000000);
    clk_set_rate(clko, rate);
    wm8960_pdata.sysclk = rate;
    return 0;
static struct mxc_audio_platform_data wm8960_pdata = {
    .ssi_num = 1,
    .src_port = 2,
    .ext_port = 3,
    .init = mxc_wm8960_init,
    .clock_enable = wm8960_clk_enable,
I attach the driver and the machine driver here. I hope this document is useful for you.
タグ(2)
添付
コメント
Hi Jimmy,
Very good document. But for a external reference I´d rather point to a different link like the Linux Documentation or maybe AlsaProject
Very good point. I added your suggestion to my document. thanks.
Thanks jimmychan,
    Worthy Document.Really useful for Developers.
Hi all!
Thanks jimmychan​ for this document!
Please tell me, can I route audio paths in this codec accordingly to this scheme:
Mic1 (LINPUT1/2) directly to OUT3,
Line In (LINPUT3) directly to SPK_R,
Mic2 (RINPUT1/2) to CPU,
CPU to SPK_L.
"directly" means that sound passes through the codec with no help of CPU.
Is this configuration feasible?
Now I am able only to capture Mic1/2 with CPU and play captured sound.
%3CLINGO-SUB%20id%3D%22lingo-sub-1119101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWM8960%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20882px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111164i329DDA6AF68F98C7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233334ca%3B%20text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81Linux%20BSP%E3%81%A7%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AFWM8960%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E7%A7%81%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%AE%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E5%AE%8C%E7%92%A7%E3%81%AA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E8%89%AF%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E6%89%80%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81L3.0.35%20%E3%81%AE%20wm8960.c%20%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99Linux%20BSP%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Audio%20Codec%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%80%81linux%2Fsound%2Fsoc%2Fcodec%2Fwm8960.c%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233334ca%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2011pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3EALSA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3EAudio%20Codec%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81ALSA%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.alsa-project.org%2Fmain%2Findex.php%2FMain_Page%22%20title%3D%22http%3A%2F%2Fwww.alsa-project.org%2Fmain%2Findex.php%2FMain_Page%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%82%A2%E3%83%AB%E3%82%B5%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%20%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FAdvanced_Linux_Sound_Architecture%22%20title%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FAdvanced_Linux_Sound_Architecture%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAdvanced%20Linux%20Sound%20Architecture%20-%20Wikipedia%20(%E8%8B%B1%E8%AA%9E%3C%2FA%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%20kcontrols%20%E3%81%AF%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Elinux%2Finclude%2Fsound%2Fsoc.h%20%E3%81%A8%20soc-dapm.h%3C%2FSPAN%3E%20%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233334ca%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2011pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3EWM8960%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%A8%E3%83%91%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2011pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%E5%B7%A6%E3%81%A8%E5%8F%B3%E3%81%AE%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%83%91%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20857px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111165i0B9EFDA185396037%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20849px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29700i18B0E22C1E595402%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%87%BA%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%83%91%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%20style%3D%22width%3A%20831px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111166iC1663F0A4AD010CD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_17.png%22%20alt%3D%22pastedImage_17.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E5%9B%B3%E3%81%A8%E5%87%BA%E5%8A%9B%E4%BF%A1%E5%8F%B7%E5%9B%B3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%81%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%80%81PGA%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AA%E3%81%A9%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81alsamixer%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_snd_controls%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R_TLV(%22PCM%20DAC%E5%86%8D%E7%94%9F%E9%9F%B3%E9%87%8F%22%2C%20WM8960_LDAC%2C%20WM8960_RDAC%2C%200%2C%20255%2C%200%2C%20dac_tlv)%2C%20%2F%2FLDACVOL%20%2C%20RDACVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R_TLV(%22PCM%20ADC%20Capture%20Volume%22%2C%20WM8960_LADC%2C%20WM8960_RADC%2C%200%2C%20255%2C%200%2C%20adc_tlv)%2C%20%2F%2FLADCVOL%2C%20RADCVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R_TLV(%E3%80%8C%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%80%8D%E3%80%81WM8960_LOUT1%E3%80%81WM8960_ROUT1%E3%80%810%E3%80%81127%E3%80%810%E3%80%81out_tlv)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R(%E3%80%8C%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3ZC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_LOUT1%E3%80%81WM8960_ROUT1%E3%80%817%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R_TLV%20(%E3%80%8C%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%E9%9F%B3%E9%87%8F%E3%80%8D%E3%80%81WM8960_LOUT2%E3%80%81WM8960_ROUT2%E3%80%810%E3%80%81127%E3%80%810%E3%80%81out_tlv)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R(%E3%80%8C%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BCZC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_LOUT2%E3%80%81WM8960_ROUT2%E3%80%817%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_DOUBLE_R(%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0ZC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_LINVOL%E3%80%81WM8960_RINVOL%E3%80%816%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV%20(%22Input%20Volume%20of%20the%20LINPUT1%22%2C%20WM8960_LINVOL%2C%200%2C%2063%2C%200%2C%20in_tlv)%2C%20%2F%2FLINVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8C%E5%85%A5%E5%8A%9B%E9%9F%B3%E9%87%8FRINPUT1%22%2C%20WM8960_RINVOL%2C%200%2C%2063%2C%200%2C%20in_tlv)%2C%20%2F%2FRINVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8C%E5%85%A5%E5%8A%9B%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0LINPUT3%E3%80%8D%E3%80%81WM8960_INBMIX1%E3%80%814%E3%80%817%E3%80%810%E3%80%81boost_tlv)%E3%80%81%2F%2FRIN3BOOST%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8C%E5%85%A5%E5%8A%9B%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0LINPUT2%E3%80%8D%E3%80%81WM8960_INBMIX1%E3%80%811%E3%80%817%E3%80%810%E3%80%81boost_tlv)%E3%80%81%2F%2FRIN2BOOST%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8C%E5%85%A5%E5%8A%9B%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0RINPUT3%E3%80%8D%E3%80%81WM8960_INBMIX2%E3%80%814%E3%80%817%E3%80%810%E3%80%81boost_tlv)%E3%80%81%2F%2FLIN3BOOST%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8C%E5%85%A5%E5%8A%9B%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0RINPUT2%E3%80%8D%E3%80%81WM8960_INBMIX2%E3%80%811%E3%80%817%E3%80%810%E3%80%81boost_tlv)%E3%80%81%2F%2FLIN2BOOST%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8CPGA%20LB2LOVOL-%E5%B7%A6%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E3%81%AE%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%8D%E3%80%81WM8960_BYPASS1%E3%80%814%E3%80%817%E3%80%811%E3%80%81bypass_tlv)%E3%80%81%2F%2FLB2LOVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8CLINPUT3%E3%81%8B%E3%82%89%E3%81%AEPGA%20LI2LOVOL%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%8D%E3%80%81WM8960_LOUTMIX%E3%80%814%E3%80%817%E3%80%811%E3%80%81bypass_tlv)%E3%80%81%2F%2FLI2LOVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8CPGA%20RB2ROVOL-%E5%8F%B3%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E3%81%AE%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%8D%E3%80%81WM8960_BYPASS2%E3%80%814%E3%80%817%E3%80%811%E3%80%81bypass_tlv)%E3%80%81%2F%2FRB2ROVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_TLV(%E3%80%8CRINPUT3%E3%81%8B%E3%82%89%E3%81%AEPGA%20RI2ROVOL%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%80%8D%E3%80%81WM8960_ROUTMIX%E3%80%814%E3%80%817%E3%80%811%E3%80%81bypass_tlv)%E3%80%81%2F%2FRI2ROVOL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%22Capture%20Mute(Left)%22%2C%20WM8960_LINVOL%2C%207%2C%201%2C%200)%2C%20%2F%2F%20%E3%83%AA%E3%83%B3%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%22%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%88(%E5%8F%B3)%22%2C%20WM8960_RINVOL%2C%207%2C%201%2C%200)%2C%20%2F%2F%20%E3%83%AA%E3%83%B3%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8CPCM%E5%86%8D%E7%94%9F-6dB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_DACCTL1%E3%80%817%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8C%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BCDC%E3%82%B2%E3%82%A4%E3%83%B3%E3%80%8D%E3%80%81WM8960_CLASSD3%E3%80%813%E3%80%815%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8C%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BCAC%E3%82%B2%E3%82%A4%E3%83%B3%E3%80%8D%E3%80%81WM8960_CLASSD3%E3%80%810%E3%80%815%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM%20(%22ADC%20%E6%A5%B5%E6%80%A7%22%2C%20wm8960_enum%5B0%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8CADC%E3%83%8F%E3%82%A4%E3%83%91%E3%82%B9%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_DACCTL1%E3%80%810%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%E3%80%8CDAC%E6%A5%B5%E6%80%A7%E3%80%8D%E3%80%81wm8960_enum%5B2%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE_BOOL_EXT(%E3%80%8CDAC%E3%83%87%E3%82%A3%E3%82%A8%E3%83%B3%E3%83%95%E3%82%A1%E3%82%B7%E3%82%B9%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%810%E3%80%81wm8960_get_deemph%E3%80%81wm8960_put_deemph)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%E3%80%8C3D%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E4%B8%8A%E9%83%A8%E3%82%AB%E3%83%83%E3%83%88%E3%82%AA%E3%83%95%E3%80%8D%E3%80%81wm8960_enum%5B2%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%E3%80%8C3D%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E4%B8%8B%E9%83%A8%E3%82%AB%E3%83%83%E3%83%88%E3%82%AA%E3%83%95%E3%80%8D%E3%80%81wm8960_enum%5B3%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE%20(%223D%20%E6%B7%B1%E5%BA%A6%22%2C%20WM8960_3D%2C%201%2C%2015%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE%20(%223D%22%2C%20WM8960_3D%2C%200%2C%201%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%E3%80%8CALC%E6%A9%9F%E8%83%BD%E3%80%8D%E3%80%81wm8960_enum%5B4%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE%20(%22ALC%20Max%20Gain%22%2C%20WM8960_ALC1%2C%204%2C%207%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8CALC%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%8D%E3%80%81WM8960_ALC1%E3%80%810%E3%80%8115%E3%80%811)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE%20(%22ALC%20%E6%9C%80%E5%B0%8F%E3%82%B2%E3%82%A4%E3%83%B3%22%2C%20WM8960_ALC2%2C%204%2C%207%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE%20(%22ALC%20%E3%83%9B%E3%83%BC%E3%83%AB%E3%83%89%20%E3%82%BF%E3%82%A4%E3%83%A0%22%2C%20WM8960_ALC2%2C%200%2C%2015%2C%200)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%E3%80%8CALC%E3%83%A2%E3%83%BC%E3%83%89%E3%80%8D%E3%80%81wm8960_enum%5B5%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8CALC%E5%B4%A9%E5%A3%8A%E3%80%8D%E3%80%81WM8960_ALC3%E3%80%814%E3%80%8115%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8CALC%E6%94%BB%E6%92%83%E3%80%8D%E3%80%81WM8960_ALC3%E3%80%810%E3%80%8115%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE%20(%22%E3%83%8E%E3%82%A4%E3%82%BA%20%E3%82%B2%E3%83%BC%E3%83%88%E9%96%BE%E5%80%A4%22%2C%20WM8960_NOISEG%2C%203%2C%2031%2C%200)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_SINGLE(%E3%80%8C%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%B2%E3%83%BC%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_NOISEG%E3%80%810%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%22%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BC%E3%83%AC%E3%83%95%E3%83%88%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%22%2C%20wm8960_enum%5B6%5D)%2C%20%2F%2FLMICBOOST%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3ESOC_ENUM(%22%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%22%2C%20wm8960_enum%5B7%5D)%2C%20%2F%2FRMICBOOT%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-size%3A%2010pt%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E1.%20SOC_SINGLE(xname%E3%80%81reg%E3%80%81shift%E3%80%81max%E3%80%81invert)%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81SOC_SINGLE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_64.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_64.png%22%20style%3D%22width%3A%20682px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F21231i322D28DCBF91C7C2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_64.png%22%20alt%3D%22pastedImage_64.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_SINGLE(%E3%80%8CPCM%E5%86%8D%E7%94%9F-6dB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_DACCTL1%E3%80%817%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E-%20%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E3%80%8CPCM%E5%86%8D%E7%94%9F-6dB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E-%20WM8960%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AFWM8960_DACCTL1%E3%81%A7%E3%81%99%E3%80%82(%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0x5%E3%81%A7%E3%80%81WM8960.h%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E-%20'7'%20%3A%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%207%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%93%E3%83%83%E3%83%88DACCTL1%E3%80%81DAC%206dB%20%E6%B8%9B%E8%A1%B0%E3%82%92%E6%9C%89%E5%8A%B9%2F%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E-%20'1'%20%3A%20%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%BE%E3%81%9F%E3%81%AF%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%201%20%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E-%20'0'%20%3A%20%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E5%80%A4%E3%81%AF%E5%8F%8D%E8%BB%A2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E2.%20SOC_SINGLE_TLV(xname%2C%20reg%2C%20shift%2C%20max%2C%20invert%2C%20tlv_array)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81SOC_SINGLE_TLV%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_27.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_27.png%22%20style%3D%22width%3A%20839px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29814i47C069B1A1B285C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_27.png%22%20alt%3D%22pastedImage_27.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E5%B7%A6%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AF000000(-17.25dB)%E3%81%8B%E3%82%89111111(%2B30dB)%E3%81%A7%E3%81%99%E3%80%82%E5%90%84%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF0.75dB%E3%81%A7%E3%81%99%E3%80%82%E5%90%88%E8%A8%88%E3%81%AF63%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20'Courier%20New'%3B%22%3ESOC_SINGLE_TLV%20(%22%E5%85%A5%E5%8A%9B%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%20of%20LINPUT1%22%2C%20WM8960_LINVOL%2C%200%2C%2063%2C%200%2C%20in_tlv)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Ein_tlv%E3%81%AE%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%A3%E8%A8%80%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3Estatic%20const%20DECLARE_TLV_DB_SCALE(in_tlv%2C%20-1725%2C%2075%2C%200)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ein_tlv%20%3A%20%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%80%82%3C%2FP%3E%3CP%3E-1725%3A-17.25dB%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%3C%2FP%3E%3CP%3E75%3A%E5%90%84%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF0.75dB%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E0%3A%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%200%20%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E3%80%8C%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%88%E3%80%8D%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF1%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E6%95%B0%E5%80%A4%E3%82%921%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E4%BE%8Bample%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%20DAC%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AE0000%200000%E3%81%AF%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_62.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_62.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F57919iB2E6AEB972BAF9B5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_62.png%22%20alt%3D%22pastedImage_62.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3Estatic%20const%20DECLARE_TLV_DB_SCALE(dac_tlv%2C%20-12700%2C%2050%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E3.%20SOC_DOUBLE_R(xname%2C%20reg_left%2C%20reg_right%2C%20xshift%2C%20xmax%2C%20xinvert)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3ESOC_DOUBLE_R%E3%81%AFSOC_SINGLE%E3%81%AE%E3%82%B9%E3%83%86%E3%83%AC%E3%82%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E5%B7%A6%E5%8F%B3%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_DOUBLE_R(%E3%80%8C%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3ZC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%8D%E3%80%81WM8960_LOUT1%E3%80%81WM8960_ROUT1%E3%80%817%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E4.%20SOC_DOUBLE_R_TLV(xname%2C%20reg_left%2C%20reg_right%2C%20xshift%2C%20xmax%2C%20xinvert%2C%20tlv_array)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3ESOC_DOUBLE_R_TLV%E3%81%AFSOC_SINGLE_TLV%E3%81%AE%E3%82%B9%E3%83%86%E3%83%AC%E3%82%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_DOUBLE_R_TLV(%E3%80%8CPCM%20DAC%E5%86%8D%E7%94%9F%E9%9F%B3%E9%87%8F%E3%80%8D%E3%80%81WM8960_LDAC%E3%80%81WM8960_RDAC%E3%80%810%E3%80%81255%E3%80%810%E3%80%81dac_tlv)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E5.%20SOC_ENUM_SINGLE(xreg%2C%20xshift%2C%20xmax%2C%20xtexts)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%3CSTRONG%3E%E5%88%B6%E5%BE%A1%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81SOC_ENUM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%88%97%E6%8C%99%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%82MIC%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_63.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_63.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F57924i48ACCF5E3EF3E362%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_63.png%22%20alt%3D%22pastedImage_63.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E5.1.%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AE%E9%85%8D%E5%88%97%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20char%20*wm8960_micboost%5B%5D%20%3D%20%7B%220dB%22%2C%22%2B13dB%22%2C%22%2B20dB%22%2C%22%2B29dB%22%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E5.2.SOC_ENUM_SINGLE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20soc_enum%20wm8960_enum%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM_SINGLE(WM8960_DACCTL1%E3%80%815%E3%80%814%E3%80%81wm8960_polarity)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM_SINGLE(WM8960_DACCTL2%E3%80%815%E3%80%814%E3%80%81wm8960_polarity)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM_SINGLE(WM8960_3D%E3%80%816%E3%80%812%E3%80%81wm8960_3d_upper_cutoff)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM_SINGLE(WM8960_3D%E3%80%815%E3%80%812%E3%80%81wm8960_3d_lower_cutoff)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SOC_ENUM_SINGLE(WM8960_ALC1%2C%207%2C%204%2C%20wm8960_alcfunc)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SOC_ENUM_SINGLE(WM8960_ALC3%2C%208%2C%202%2C%20wm8960_alcmode)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM_SINGLE(WM8960_LINPATH%E3%80%814%E3%80%814%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Ewm8960_micboost%3C%2FSPAN%3E)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM_SINGLE(WM8960_RINPATH%E3%80%814%E3%80%814%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3Ewm8960_micboost%3C%2FSPAN%3E)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%20color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E5.3.SOC_ENUM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MIC%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM(%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%AC%E3%83%95%E3%83%88%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%80%8D%E3%80%81wm8960_enum%5B6%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3ESOC_ENUM(%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%80%8D%E3%80%81wm8960_enum%5B7%5D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E4%BD%9C%E6%88%90%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E5%85%A5%E5%8A%9B%E5%9B%B3%E3%81%A8%E5%87%BA%E5%8A%9B%E5%9B%B3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%84%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E5%90%8C%E3%81%98%E5%90%8D%E5%89%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82alsamixer%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%81%8C%E3%82%88%E3%82%8A%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_lin%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LMP2%22%2C%20WM8960_LINPATH%2C%206%2C%201%2C%200)%2C%20%2F%2FLMP2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LMP3%22%2C%20WM8960_LINPATH%2C%207%2C%201%2C%200)%2C%20%2F%2FLMP3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LMN1%22%2C%20WM8960_LINPATH%2C%208%2C%201%2C%200)%2C%20%2F%2FLMN1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_lin_boost%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LMIC2B%22%2C%20WM8960_LINPATH%2C%203%2C%201%2C%200)%2C%20%2F%2FLMIC2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_rin%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RMP2%22%2C%20WM8960_RINPATH%2C%206%2C%201%2C%200)%2C%20%2F%2FRMP2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RMP3%22%2C%20WM8960_RINPATH%2C%207%2C%201%2C%200)%2C%20%2F%2FRMP3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RMN1%22%2C%20WM8960_RINPATH%2C%208%2C%201%2C%200)%2C%20%2F%2FRMN1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_rin_boost%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RMIC2B%22%2C%20WM8960_RINPATH%2C%203%2C%201%2C%200)%2C%20%2F%2FRMIC2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_loutput_mixer%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LD2LO%22%2C%20WM8960_LOUTMIX%2C%208%2C%201%2C%200)%2C%20%2F%2FLD2LO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LI2LO%22%2C%20WM8960_LOUTMIX%2C%207%2C%201%2C%200)%2C%20%2F%2FLI2LO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20LB2LO%22%2C%20WM8960_BYPASS1%2C%207%2C%201%2C%200)%2C%20%2F%2FLB2LO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20%E6%A7%8B%E9%80%A0%E4%BD%93%20snd_kcontrol_new%20wm8960_routput_mixer%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RD2RO%22%2C%20WM8960_ROUTMIX%2C%208%2C%201%2C%200)%2C%20%2F%2FRD2RO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RI2RO%22%2C%20WM8960_ROUTMIX%2C%207%2C%201%2C%200)%2C%20%2F%2FRI2RO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20RB2RO%22%2C%20WM8960_BYPASS2%2C%207%2C%201%2C%200)%2C%20%2F%2FRB2RO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_kcontrol_new%20wm8960_mono_out%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20L2MO%22%2C%20WM8960_MONOMIX1%2C%207%2C%201%2C%200)%2C%20%2F%2FL2MO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESOC_DAPM_SINGLE(%22%26lt%3B-%20R2MO%22%2C%20WM8960_MONOMIX2%2C%207%2C%201%2C%200)%2C%20%2F%2FR2MO%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%AC%A1%E3%81%AB%E3%80%81%E5%85%A5%E5%8A%9B%E3%80%81ADC%E3%80%81DAC%E3%80%81%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E3%80%81PGA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E5%87%BA%E5%8A%9B%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_soc_dapm_widget%20wm8960_dapm_widgets%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_INPUT(%E3%80%8CLINPUT1%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_INPUT(%E3%80%8CRINPUT1%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_INPUT(%E3%80%8CLINPUT2%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_INPUT(%E3%80%8CRINPUT2%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_INPUT(%E3%80%8CLINPUT3%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_INPUT(%E3%80%8CRINPUT3%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MICBIAS(%E3%80%8CMICB%E3%80%8D%E3%80%81WM8960_POWER1%E3%80%811%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MIXER(%E3%80%8C%E5%B7%A6%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E3%80%8D%E3%80%81WM8960_POWER1%E3%80%815%E3%80%810%E3%80%81wm8960_lin_boost%E3%80%81ARRAY_SIZE(wm8960_lin_boost))%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MIXER(%E3%80%8C%E5%8F%B3%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E3%80%8D%E3%80%81WM8960_POWER1%E3%80%814%E3%80%810%E3%80%81wm8960_rin_boost%E3%80%81ARRAY_SIZE(wm8960_rin_boost))%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MIXER(%E3%80%8C%E5%B7%A6%E5%85%A5%E5%8A%9BPGA%E3%80%8D%E3%80%81WM8960_POWER3%E3%80%815%E3%80%810%E3%80%81wm8960_lin%E3%80%81ARRAY_SIZE(wm8960_lin))%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MIXER(%E3%80%8C%E5%8F%B3%E5%85%A5%E5%8A%9BPGA%E3%80%8D%E3%80%81WM8960_POWER3%E3%80%814%E3%80%810%E3%80%81wm8960_rin%E3%80%81ARRAY_SIZE(wm8960_rin))%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_ADC%20(%22%E5%B7%A6%20ADC%22%2C%20%22%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%22%2C%20WM8960_POWER1%2C%203%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_ADC%20(%22%E5%8F%B3ADC%22%E3%80%81%20%22%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%22%E3%80%81WM8960_POWER1%E3%80%812%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_DAC(%E3%80%8C%E5%B7%A6DAC%E3%80%8D%E3%80%81%E3%80%8C%E5%86%8D%E7%94%9F%E3%80%8D%E3%80%81WM8960_POWER2%E3%80%818%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_DAC(%E3%80%8C%E5%8F%B3DAC%E3%80%8D%E3%80%81%E3%80%8C%E5%86%8D%E7%94%9F%E3%80%8D%E3%80%81WM8960_POWER2%E3%80%817%E3%80%810)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MIXER%20(%22%E5%B7%A6%E5%87%BA%E5%8A%9B%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%2C%20WM8960_POWER3%2C%203%2C%200%2C%20wm8960_loutput_mixer%2C%20ARRAY_SIZE(wm8960_loutput_mixer))%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_MIXER(%E3%80%8C%E5%8F%B3%E5%87%BA%E5%8A%9B%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E3%80%8D%E3%80%81WM8960_POWER3%E3%80%812%E3%80%810%E3%80%81wm8960_routput_mixer%E3%80%81ARRAY_SIZE(wm8960_routput_mixer))%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_PGA%20(%22%E5%B7%A6%20HP%20PGA%22%2C%20WM8960_POWER2%2C%206%2C%200%2C%20NULL%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_PGA%20(%22%E5%8F%B3%20HP%20PGA%22%2C%20WM8960_POWER2%2C%205%2C%200%2C%20NULL%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_PGA%20(%22%E5%B7%A6%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%20PGA%22%2C%20WM8960_POWER2%2C%204%2C%200%2C%20NULL%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_PGA%20(%22%E5%8F%B3%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%20PGA%22%2C%20WM8960_POWER2%2C%203%2C%200%2C%20NULL%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_PGA(%22%E5%8F%B3%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%E5%87%BA%E5%8A%9B%22%2C%20WM8960_CLASSD1%2C%207%2C%200%2C%20NULL%2C%200)%2C%20%2F%2FSPK_OP_EN%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_PGA%20(%22%E5%B7%A6%E3%82%B9%E3%83%94%E3%83%BC%E3%82%AB%E3%83%BC%E5%87%BA%E5%8A%9B%22%2C%20WM8960_CLASSD1%2C%206%2C%200%2C%20NULL%2C%200)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8CSPK_LP%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8CSPK_LN%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8CHP_L%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8CHP_R%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8CSPK_RP%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8CSPK_RN%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ESND_SOC_DAPM_OUTPUT(%E3%80%8COUT3%E3%80%8D)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%91%E3%82%B9%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%B9%E3%81%AF%E5%8F%B3%E3%81%8B%E3%82%89%E5%B7%A6%E3%81%B8%E3%80%81%7B%20%22destination%22%2C%20%22switch%22%2C%20%22source%22%20%7D%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81ADC%E3%81%AELINPUT1%E3%82%92%E4%BE%8B%E3%81%AB%E3%81%A8%E3%82%8A%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_59.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_59.png%22%20style%3D%22width%3A%20579px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F57925iB68B3131BF592B4C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_59.png%22%20alt%3D%22pastedImage_59.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%20%22%E5%B7%A6%E5%85%A5%E5%8A%9BPGA%22%2C%20%22%26lt%3B-%20LMN1%22%2C%20%22LINPUT1%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%20%22%E5%B7%A6%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%2C%20%22%26lt%3B-%20LMIC2B%22%2C%20%22%E5%B7%A6%E5%85%A5%E5%8A%9BPGA%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%20%22%E5%B7%A6ADC%22%2C%20NULL%2C%20%22%E5%B7%A6%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81DAC%E3%81%8B%E3%82%89%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%81%B8%E3%81%AE%E7%BF%BB%E8%A8%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_61.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_61.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F21233i824B6D8106597A9A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_61.png%22%20alt%3D%22pastedImage_61.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%20%22%E5%B7%A6%E5%87%BA%E5%8A%9B%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%2C%20%22%26lt%3B-%20LD2LO%22%2C%20%22%E5%B7%A6DAC%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%237ed529%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233a0699%3B%22%3E%20%7B%20%22%E5%8F%B3%E5%87%BA%E5%8A%9B%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%2C%20%22%26lt%3B-%20RD2RO%22%2C%20%22%E5%8F%B3DAC%22%20%7D%3C%2FSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%20%22%E5%B7%A6%20HP%20PGA%22%2C%20NULL%2C%20%22%E5%B7%A6%E5%87%BA%E5%8A%9B%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%233a0699%3B%22%3E%7B%20%22%E5%8F%B3%20HP%20PGA%22%2C%20NULL%2C%20%22%E5%8F%B3%E5%87%BA%E5%8A%9B%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%7B%20%22HP_L%22%2C%20NULL%2C%20%22%E5%B7%A6HP%20PGA%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%233a0699%3B%22%3E%7B%20%22HP_R%22%2C%20NULL%2C%20%22%E5%8F%B3HP%20PGA%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ELinux%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8Calsamixer%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%95%E3%82%84%E9%9F%B3%E9%87%8F%E3%81%AE%E8%AA%BF%E6%95%B4%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_66.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_66.png%22%20style%3D%22width%3A%20738px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111167i75CFE9282E419D5B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_66.png%22%20alt%3D%22pastedImage_66.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E(%E3%81%93%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AF%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AEAlsaMixer%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81WM8960%E7%94%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%3CP%3Ealsamixer%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8CM%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%95%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81%E7%9F%A2%E5%8D%B0%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%9F%B3%E9%87%8F%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ewm8960_dai_ops%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E9%83%A8%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8Cwm8960_dai%E3%81%AE%E9%81%8B%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20snd_soc_dai_ops%20wm8960_dai_ops%20%3D%20%7B%3C%2FP%3E%3CP%3E.hw_params%3D%20wm8960_hw_params%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.digital_mute%20%3D%20wm8960_mute%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.set_fmt%20%3D%20wm8960_set_dai_fmt%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.set_clkdiv%20%3D%20wm8960_set_dai_clkdiv%2C%3C%2FP%3E%3CP%3E.set_pll%3D%20wm8960_set_dai_pll%E3%80%81%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ewm8960_hw_params%3APCM%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88(16bit%2F24bit)%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81deemph%E3%80%81alc_rates%E3%81%AA%E3%81%A9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ewm8960_mute%3A%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%9F%E3%83%A5%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ewm8960_set_dai_fmt%20%3A%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(I2S%E3%80%81DSP%E3%80%81%E5%B7%A6%E6%8F%83%E3%81%88%E3%80%81%E5%8F%B3%E6%8F%83%E3%81%88)%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%8F%8D%E8%BB%A2%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ewm8960_set_dai_clkdiv%3ADACDIV%E3%80%81ADCDIV%E3%80%81BCLKDIV%E3%81%AA%E3%81%A9%E3%81%AECLK%E3%83%87%E3%82%A3%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ewm8960_set_dai_pll%3A%E9%81%A9%E5%88%87%E3%81%AAPLL%E5%80%A4%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ewm8960_set_dai_pll%E3%81%A7%E3%81%AF%E3%80%81%E9%81%A9%E5%88%87%E3%81%AAPLL%E5%80%A4%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_68.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_68.png%22%20style%3D%22width%3A%20794px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111168iCAB1E881A14AA6DF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_68.png%22%20alt%3D%22pastedImage_68.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%80%81MCLK%20%26gt%3B14.4%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81SysCLK%E3%83%97%E3%83%AA%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E9%99%A4%E5%91%A8%E5%99%A8%E3%81%AF2%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81pll_factors%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E5%89%8D%E3%81%AB%20sysclk%20%E3%83%97%E3%83%AA%E3%83%87%E3%82%A3%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%82%92%202%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E3%82%82%E3%81%97%20(freq_in%20%26gt%3B%2015000000)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20update%20sysclk%20div%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3Ereg%20%3D%20snd_soc_read(%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%80%81WM8960_CLOCK1)%20%26amp%3B%200x1f9%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3Esnd_soc_write(%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%80%81WM8960_CLOCK1%E3%80%81reg%20%7C%200x4)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3Eclk_in%20%3D%20clk_in%2F2%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3Eif%20(freq_in%20%26amp%3B%20freq_out)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3Eret%20%3D%20pll_factors(clk_in%2C%20freq_out%2C%20%26amp%3Bpll_div)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20(ret%20!%3D%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20ret%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%20font-family%3A%20courier%20new%2Ccourier%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%81%AF%E3%80%81%E9%87%8D%E8%A6%81%E3%81%AA%E5%90%8D%E5%89%8D%E3%81%8C2%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%821%E3%81%A4%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AFdai%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%99%E3%80%82%E5%90%8D%E5%89%8D%E3%81%AF%E3%80%8Cwm8960%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%20dai%20%E5%90%8D%E3%81%8C%20imx-wm8960.c%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%20dai%20%E5%90%8D%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20snd_soc_dai_driver%20wm8960_dai%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%80%82%E5%90%8D%E5%89%8D%3D%20%22wm8960%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%80%82%E5%86%8D%E7%94%9F%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.stream_name%20%3D%20%E3%80%8C%E5%86%8D%E7%94%9F%E3%80%8D%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.channels_min%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.channels_max%20%3D%202%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.rates%20%3D%20WM8960_RATES%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.formats%20%3D%20WM8960_FORMATS%2C%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%80%82%E6%8D%95%E7%8D%B2%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.stream_name%20%3D%20%22%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%22%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.channels_min%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.channels_max%20%3D%202%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.rates%20%3D%20WM8960_RATES%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.formats%20%3D%20WM8960_FORMATS%2C%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.ops%3D%20%26amp%3Bwm8960_dai_ops%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.symmetric_rates%3D%201%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A5%E5%90%8D%E3%81%AF%20I2C%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20ID%20%E3%81%A7%E3%81%99%E3%80%82I2C%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%8Cyour_board.c%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%90%8D%E5%89%8D%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E9%9D%99%E7%9A%84%20const%3C%2FSPAN%3E%20struct%20i2c_device_id%20wm8960_i2c_id%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7B%20%22wm8960%22%2C%200%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3EMODULE_DEVICE_TABLE(i2c%E3%80%81wm8960_i2c_id)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20i2c_driver%20wm8960_i2c_driver%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%80%82%E9%81%8B%E8%BB%A2%E6%89%8B%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.name%20%3D%20%22wm8960%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.owner%20%3D%20THIS_MODULE%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%80%82%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3D%20wm8960_i2c_probe%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%80%82%E5%8F%96%E3%82%8A%E5%8E%BB%E3%82%8B%3D%20__devexit_p(wm8960_i2c_remove)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.id_table%20%3D%20wm8960_i2c_id%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eyour_board.c%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%90%8D%E5%89%8D%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20i2c_board_info%20mxc_i2c0_board_info%5B%5D%20__initdata%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3EI2C_BOARD_INFO%20(%22WM8960%22%E3%80%810x1a)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCimx-wm8960.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFwm8960.c%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%99%E3%81%9D%E3%81%97%E3%81%A6%20i.MX%E3%80%82%20%3C%2FP%3E%3CP%3Eimx-wm8962.c%20%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%81%AF%20HP%20%E3%81%A8%20MIC%20%E3%81%AE%E6%A4%9C%E5%87%BA%E3%81%AF%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82HP%E3%81%A8MIC%E3%81%AE%E6%A4%9C%E5%87%BA%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81imx-wm8962.c%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AFmy_board.c%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20platform_device%20audio_wm8960_device%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.name%20%3D%20%22imx-wm8960%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93mxc_audio_platform_data%20wm8960_pdata%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Estatic%20int%20wm8960_clk_enable(int%20enable)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Eif%20(%E6%9C%89%E5%8A%B9)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Eclk_enable(CLKO)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Eclk_disable(CLKO)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Estatic%20int%20mxc_wm8960_init(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Eint%20%E3%83%AC%E3%83%BC%E3%83%88%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Eclko%20%3D%20clk_get(NULL%2C%20%22clko_clk%22)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20(IS_ERR(clko))%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Epr_err(%22CLKO%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%5Cn%22)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20PTR_ERR(clko)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%2F*%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%A8%20comera%20%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%20CLKO%20clk%20%E3%82%92%E4%BD%BF%E7%94%A8*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20clk_round_rate(CLKO%2C%2024000000)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Eclk_set_rate(CLKO%E3%80%81%E3%83%AC%E3%83%BC%E3%83%88)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3Ewm8960_pdata.sysclk%20%3D%20%E3%83%AC%E3%83%BC%E3%83%88%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20mxc_audio_platform_data%20wm8960_pdata%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.ssi_num%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.src_port%20%3D%202%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.ext_port%20%3D%203%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3D%20mxc_wm8960_init%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E.clock_enable%20%3D%20wm8960_clk_enable%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%20color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjimmychan%22%20target%3D%22_blank%22%3Ejimmychan%3C%2FA%3E!%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%BC%E3%83%A0%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%91%E3%82%B9%E3%82%92%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3EMic1(LINPUT1%2F2)%E3%82%92%E7%9B%B4%E6%8E%A5OUT3%E3%81%AB%E3%80%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E3%83%A9%E3%82%A4%E3%83%B3%E5%85%A5%E5%8A%9B(LINPUT3)%E3%82%92%E7%9B%B4%E6%8E%A5SPK_R%E3%81%AB%E3%80%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3EMic2(RINPUT1%2F2)%E3%81%8B%E3%82%89CPU%E3%81%B8%E3%80%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3ECPU%20%E3%81%8B%E3%82%89%20SPK_L%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E3%80%8C%E7%9B%B4%E6%8E%A5%E3%80%8D%E3%81%A8%E3%81%AF%E3%80%81%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%81%8CCPU%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E5%80%9F%E3%82%8A%E3%81%9A%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E9%80%9A%E9%81%8E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%20%3CSPAN%20class%3D%22translation-chunk%22%20data-align%3D%2219%3A29%22%3E%E5%AE%9F%E7%8F%BE%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22translation-chunk%22%20data-align%3D%2219%3A29%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CSPAN%20class%3D%22translation-chunk%22%20data-align%3D%2219%3A29%22%3E%E4%BB%8A%E3%81%A7%E3%81%AF%E3%80%81CPU%E3%81%A7Mic1%2F2%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%97%E3%81%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CSPAN%20style%3D%22color%3A%20%239aa9af%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014.2857141494751px%3B%22%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjimmychan%22%20target%3D%22_blank%22%3Ejimmychan%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BE%A1%E5%80%A4%E3%81%AE%E3%81%82%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%82%E9%96%8B%E7%99%BA%E8%80%85%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A8%E3%81%A6%E3%82%82%E8%89%AF%E3%81%84%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E7%A7%81%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%84%9F%E8%AC%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B8%E3%83%9F%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%89%AF%E3%81%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%A4%96%E9%83%A8%E5%8F%82%E7%85%A7%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Linux%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%84%3CA%20href%3D%22http%3A%2F%2Fwww.alsa-project.org%2F%22%20title%3D%22http%3A%2F%2Fwww.alsa-project.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAlsaProject%3C%2FA%3E%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%88%A5%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E6%8C%87%E3%81%97%E7%A4%BA%E3%81%99%E6%96%B9%E3%81%8C%E3%81%84%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-12-2015 08:17 PM
更新者:
