Using i.MX6Q to Build a Palm-Sized Heterogeneous Mini-HPC
This work is the result of my daughter's idea, she finished it with my guidance.
Cradle-1 Palmsize mini-HPC
World's first full function heterogeneous mini-HPC, this is what it looks like:
摇篮1号 <wbr><wbr> <wbr><wbr>-- <wbr><wbr> <wbr><wbr> <wbr><wbr>世界首台CPU+GPU异构掌上超级计算机
1 Architecture
        Overall:  CPU+GPU heterogeneous, 4 nodes, connected by a 100M Ethernet switcher;
        Nodes FreeScale I.MX6 Quad core mini-pc, with 4 ARM Cortex-A9 cores and 1 Vivante GC2000 GPU
2  Software
        OS:   Ubuntu 11.10 linaro
        OpenCL driver: Vivante GC2000 OpenCL driver
        Compiler C/C++: gcc 4.6.1, Fortan90/95:  gfortran 4.6.1,
        MPI Parallel Computing: MPICH2 1.4-1
        NFS network file system: nfs-kernel-server 1.2.4
        SSH security:   openssh   1:5.8
3 Hardware
        The hardware of all nodes are the same, only the software configurations are slightly different. One of them was assigned as the master node, the others are slave nodes. They were TV sticks originally, with android 4.0 installed. The node's hardware specification is:
        CPU: 4 1.2G Cortex-A9 cores
        GPU: 1 Vivante GC2000 GPU
        RAM: 1G DDR
        ROM: 8G SD
        NIC:   usb2.0 100M Ethernet Adapter (this NIC is not the TV stick's component, we added it)
        WIFI: 150M
        Display Interface:  HDMI
        Network Switcher: 5 port 100M Ethernet Switcher
Network
        Each node has one USB2.0 NIC and one WIFI interface, the WIFI is used as the backup connection for NIC connection. Network configurations are:
        IP Address assignment:  (baby1 - baby4 are the four computing nodes)
        baby1: 100M NIC 192.168.10.1 WIFI 192.168.0.111
        baby2: 100M NIC 192.168.10.2 WIFI 192.168.0.112
        baby3: 100M NIC 192.168.10.3 WIFI 192.168.0.113
        baby4: 100M NIC 192.168.10.4 WIFI 192.168.0.114
Performance
        Cradle-1 has 16 1.2G ARM Cortex-A9 cores and 4 Vivante GC2000 GPU cores, the total computing power of these 20 computing devices is more than 100GFLOPS,   more powerful than an ordinary desktop. The whole machine is only a little bigger than a palm, and the total power consumption is less than 15 watts.
         The overall architecture of Cradle-1 is almost the same as Chinese Tianhe-1A or the Titan in the oak ridge lab. they used the same set of software, LINUX+OPENCL+OPENMPI. Cradle-1 supports C/C++, Fortran90/95. And almost all kinds of parallel computing algorithms can run on it, the only difference is the scale.
        We coded a MPI parallel computing program for large matrix multiplication with 4 processes, each process had 5 threads, four threads for the four CPU cores, and one thread for GPU computing.
6 Appearance
Front
Back
Top
Left
Right
One node, it has three interfaces, the right is HDMI interface, upper-left is the wireless adapter for keyboard and mouse, down-left is the power connection.
One node is running Ubuntu 11.10.
Coded a simple OpenCL program to display OpenCL driver information
On a notebook, using remote desktop access function to obtan the node baby1's desktop. This is the sign in desktop of baby1 node. Baby 1 has X11VNC server installed.
sign in baby1, open a terminal
Ran a MPI testing program, ensuring that all babies (baby1 - baby4) were working
    Any comments? please mail to [email protected]
ラベル(3)
コメント
Nice.
Do you add some cooling fan or heatsink on it?
No fans. There is not much heat. it runs only a little warm. and, the shells of the babies are made of aluminium.
Congrats Nice Setup!
I wonder if doing the sample code in Fortran would speed up the processing (floating point operations per second). Are you using this setup to do some scientific/academic processing?
%3CLINGO-SUB%20id%3D%22lingo-sub-1123894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6Q%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%89%8B%E3%81%AE%E3%81%B2%E3%82%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%98%E3%83%86%E3%83%AD%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%B9Mini-HPC%E3%82%92%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E4%BD%9C%E5%93%81%E3%81%AF%E5%A8%98%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%BD%BC%E5%A5%B3%E3%81%AF%E7%A7%81%E3%81%AE%E6%8C%87%E5%B0%8E%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%8C%E6%88%90%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20font-size%3A%2024px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20font-size%3A%2024px%3B%22%3ECradle-1%3C%2FSPAN%3E%20Palmsize%20mini-HPC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%96%E7%95%8C%E5%88%9D%E3%81%AE%E3%83%95%E3%83%AB%E6%A9%9F%E8%83%BD%E3%83%98%E3%83%86%E3%83%AD%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%B9mini-HPC%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs8.sinaimg.cn%2Forignal%2Faea40d73gd9233c367a17%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20name%3D%22image_operate_39341364648046434%22%20src%3D%22http%3A%2F%2Fs8.sinaimg.cn%2Fmw690%2Faea40d73gd9233c367a17%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20sans-serif%3B%22%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E5%85%A8%E4%BD%93%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3ECPU%20%2B%20GPU%3C%2FSPAN%3E%E3%83%98%E3%83%86%E3%83%AD%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%B9%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3E4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%E3%83%8E%E3%83%BC%E3%83%89%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E100M%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%83%8E%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EFreeScale%20I.MX6%3C%2FSPAN%3E%20%E3%82%AF%E3%82%A2%E3%83%83%E3%83%89%E3%82%B3%E3%82%A2%E3%83%BB%E3%83%9F%E3%83%8B%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EPC%E3%80%814%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EARM%20Cortex-A9%3C%2FSPAN%3E%20%E3%82%B3%E3%82%A2%201%20%E5%80%8B%E3%80%81%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EVivante%20GC2000%20GPU%3C%2FSPAN%3E%201%E5%80%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20sans-serif%3B%22%3E%3CSPAN%3E2%3C%2FSPAN%3E%3C%2FSPAN%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3EOS%3A%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EUbuntu%2011.10%20linaro%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EOpenCL%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3A%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EVivante%20GC2000%20OpenCL%3C%2FSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3A%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EC%2FC%2B%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%3A%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3Egcc%204.6.1%2C%20Fortan90%2F95%3A%20gfortran%204.6.1%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EMPI%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E4%B8%A6%E5%88%97%E8%A8%88%E7%AE%97%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EMPICH2%201.4-1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3ENFS%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3Enfs-kernel-server%201.2.4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3ESSH%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%3A%20openssh%201%3A5.8%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20sans-serif%3B%22%3E%3CSPAN%3E3%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90%E3%81%8C%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%E3%81%AE%201%20%E3%81%A4%E3%81%AF%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%80%81%E4%BB%96%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%A8%E3%82%82%E3%81%A8%E3%81%AF%E3%83%86%E3%83%AC%E3%83%93%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%A7%E3%80%81Android%204.0%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E4%BB%95%E6%A7%98%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3ECPU%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3E4%3C%2FSPAN%3E%E3%81%A4%E3%81%AE%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3E1.2G%20Cortex-A9%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%82%B3%E3%82%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EGPU%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3E1%20Vivante%20GC2000%20GPU%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3ERAM%3A%201G%20DDR%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EROM%3A8G%20SD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3E%E3%83%8B%E3%83%83%E3%82%AF%3Ausb2.0%20100M%3C%2FSPAN%3E%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF(%E3%81%93%E3%81%AENIC%E3%81%AFTV%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EWI-FI%3A150M%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3EHDMI%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20sans-serif%3B%22%3E5%3C%2FSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88100M%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018px%3B%22%3E4%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3EE%20ach%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF1%E3%81%A4%E3%81%AEUSB2.0NIC%E3%81%A81%E3%81%A4%E3%81%AEWIFI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81WIFI%E3%81%AFNIC%E6%8E%A5%E7%B6%9A%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E6%8E%A5%E7%B6%9A%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3A%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E(%3C%2FSPAN%3Ebaby1%20-%20baby4%E3%81%AF4%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99)%3C%2FP%3E%3CP%3E%E8%B5%A4%E3%81%A1%E3%82%83%E3%82%931%3A100M%20NIC%20192.168.10.1%20WIFI%20192.168.0.111%3C%2FP%3E%3CP%3Ebaby2%3A%20100M%20NIC%20192.168.10.2%E7%84%A1%E7%B7%9ALAN%3A192.168.0.112%3C%2FP%3E%3CP%3Ebaby3%3A%20100M%20NIC%20192.168.10.3%E7%84%A1%E7%B7%9ALAN%3A192.168.0.113%3C%2FP%3E%3CP%3Ebaby4%3A%20100M%20NIC%20192.168.10.4%E7%84%A1%E7%B7%9ALAN%E3%81%AE192.168.0.114%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018px%3B%22%3E5%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3ECradle-1%20%E3%81%AB%E3%81%AF%201.2G%20%E3%81%8C%2016%20%E5%80%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3EARM%20Cortex-A9%E3%82%B3%E3%82%A2%E3%81%A84%E3%81%A4%E3%81%AEVivante%20GC2000%20GPU%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%E3%82%B3%E3%82%A2%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%80%81%E3%81%93%E3%82%8C%E3%82%8920%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%90%88%E8%A8%88%E8%A8%88%E7%AE%97%E8%83%BD%E5%8A%9B%E3%81%AF100GFLOPS%E3%82%92%E8%B6%85%E3%81%88%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%88%E3%82%8A%E3%82%82%E5%BC%B7%E5%8A%9B%E3%81%A7%E3%81%99%E3%80%82%E3%83%9E%E3%82%B7%E3%83%B3%E5%85%A8%E4%BD%93%E3%81%AF%E6%89%8B%E3%81%AE%E3%81%B2%E3%82%89%E3%82%88%E3%82%8A%E5%B0%91%E3%81%97%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E7%B7%8F%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%AF15%E3%83%AF%E3%83%83%E3%83%88%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3ECradle-1%E3%81%AE%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AF%E3%80%81%E4%B8%AD%E5%9B%BD%E3%81%AETianhe-1A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%82%84%E3%82%AA%E3%83%BC%E3%82%AF%E3%83%AA%E3%83%83%E3%82%B8%E3%83%A9%E3%83%9C%E3%81%AETitan%E3%81%A8%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E5%BD%BC%E3%82%89%E3%81%AF%E5%90%8C%E3%81%98%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%20LINUX%2BOPENCL%2BOPENMPI%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%E3%81%A7%E3%81%99%E3%80%82Cradle-1%20%3C%2FSPAN%3E%E3%81%AFC%2FC%2B%2B%E3%80%81Fortran90%2F95%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%81%AE%E4%B8%A6%E5%88%97%E8%A8%88%E7%AE%97%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%94%AF%E4%B8%80%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%20lang%3D%22zh-CN%22%3E%20%3CSPAN%20style%3D%22font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E4%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E5%A4%A7%E8%A6%8F%E6%A8%A1%E3%81%AA%E8%A1%8C%E5%88%97%E4%B9%97%E7%AE%97%E3%82%92%E8%A1%8C%E3%81%86MPI%E4%B8%A6%E5%88%97%E8%A8%88%E7%AE%97%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%80%81%E5%90%84%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF5%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%80%814%E3%81%A4%E3%81%AECPU%E3%82%B3%E3%82%A2%E3%81%AB4%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%80%81GPU%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E6%8C%81%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018px%3B%22%3E6%20%E5%A4%96%E8%A6%B3%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs8.sinaimg.cn%2Forignal%2Faea40d73gd92313c23417%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_85561364648047533%22%20src%3D%22http%3A%2F%2Fs8.sinaimg.cn%2Fmw690%2Faea40d73gd92313c23417%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%E5%89%8D%E7%B7%9A%3CBR%20%2F%3E%20%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs9.sinaimg.cn%2Forignal%2Faea40d73gd92314795c68%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_94011364646969178%22%20src%3D%22http%3A%2F%2Fs9.sinaimg.cn%2Fmw690%2Faea40d73gd92314795c68%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%E6%88%BB%E3%82%8B%3CBR%20%2F%3E%20%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs9.sinaimg.cn%2Forignal%2Faea40d73gd92316647198%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_40721364648047648%22%20src%3D%22http%3A%2F%2Fs9.sinaimg.cn%2Fmw690%2Faea40d73gd92316647198%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%88%E3%83%83%E3%83%97%E3%81%B8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs5.sinaimg.cn%2Forignal%2Faea40d73gd9231ba0e1d4%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_67971364646967350%22%20src%3D%22http%3A%2F%2Fs5.sinaimg.cn%2Fmw690%2Faea40d73gd9231ba0e1d4%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%E5%B7%A6%3CBR%20%2F%3E%20%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs13.sinaimg.cn%2Forignal%2Faea40d73gd9231c4d358c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_75161364648047774%22%20src%3D%22http%3A%2F%2Fs13.sinaimg.cn%2Fmw690%2Faea40d73gd9231c4d358c%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%E5%8F%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs5.sinaimg.cn%2Forignal%2Faea40d73gd9231fbe0e54%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_39011364648047890%22%20src%3D%22http%3A%2F%2Fs5.sinaimg.cn%2Fmw690%2Faea40d73gd9231fbe0e54%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%201%E3%81%A4%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF3%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%8F%B3%E5%81%B4%E3%81%AFHDMI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%80%81%E5%B7%A6%E4%B8%8A%E3%81%AF%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%83%9E%E3%82%A6%E3%82%B9%E7%94%A8%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%80%81%E5%B7%A6%E4%B8%8B%E3%81%AF%E9%9B%BB%E6%BA%90%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs5.sinaimg.cn%2Forignal%2Faea40d73gd9232085d174%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_4581364648048012%22%20src%3D%22http%3A%2F%2Fs5.sinaimg.cn%2Fmw690%2Faea40d73gd9232085d174%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E1%E3%81%A4%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8CUbuntu11.10%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs4.sinaimg.cn%2Forignal%2Faea40d73gd923215c78c3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_30151364648048130%22%20src%3D%22http%3A%2F%2Fs4.sinaimg.cn%2Fmw690%2Faea40d73gd923215c78c3%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3EOpenCL%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E6%83%85%E5%A0%B1%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E7%B0%A1%E5%8D%98%E3%81%AAOpenCL%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs5.sinaimg.cn%2Forignal%2Faea40d73td92395d2b2f4%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_83411364648048256%22%20src%3D%22http%3A%2F%2Fs5.sinaimg.cn%2Fmw690%2Faea40d73td92395d2b2f4%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%8E%E3%83%BC%E3%83%88%E3%83%96%E3%83%83%E3%82%AF%E4%B8%8A%E3%81%A7%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%8E%E3%83%BC%E3%83%89baby1%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFbaby1%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AE%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82Baby%201%20%E3%81%AB%E3%81%AF%20X11VNC%20%E3%82%B5%E3%83%BC%E3%83%90%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs11.sinaimg.cn%2Forignal%2Faea40d73gd9239a08cd8a%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_58851364648048374%22%20src%3D%22http%3A%2F%2Fs11.sinaimg.cn%2Fmw690%2Faea40d73gd9239a08cd8a%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3EBABY1%E3%81%AB%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A4%E3%83%B3%E3%81%97%E3%80%81%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fphoto.blog.sina.com.cn%2Fshowpic.html%23blogid%3Daea40d7301016hs0%26amp%3Burl%3Dhttp%3A%2F%2Fs16.sinaimg.cn%2Forignal%2Faea40d73gd9239df26b6f%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CIMG%20alt%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20class%3D%22jiveImage%22%20height%3D%22517%22%20name%3D%22image_operate_18691364648049290%22%20src%3D%22http%3A%2F%2Fs16.sinaimg.cn%2Fmw690%2Faea40d73gd9239df26b6f%26amp%3B690%22%20title%3D%22%E6%91%87%E7%AF%AE1%E5%8F%B7%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B--%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%20%26lt%3Bwbr%26gt%3B%26lt%3Bwbr%26gt%3B%E4%B8%96%E7%95%8C%E9%A6%96%E5%8F%B0CPU%2BGPU%E5%BC%82%E6%9E%84%E6%8E%8C%E4%B8%8A%E8%B6%85%E7%BA%A7%E8%AE%A1%E7%AE%97%E6%9C%BA%22%20width%3D%22690%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3EMPI%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%AE%9F%E6%96%BD%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%B5%A4%E3%81%A1%E3%82%83%E3%82%93(%E8%B5%A4%E3%81%A1%E3%82%83%E3%82%931%E3%80%9C%E8%B5%A4%E3%81%A1%E3%82%83%E3%82%934)%E3%81%8C%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014px%3B%20font-family%3A%20WenQuanYi%20Zen%20Hei%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aaudrey.tao%40hotmail.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%94%E6%84%8F%E8%A6%8B%E3%83%BB%E3%81%94%E6%84%9F%E6%83%B3%E3%81%AF%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81audrey.tao%40hotmail.com%20%E3%81%BE%E3%81%A7%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%89%8B%E3%81%AE%E3%81%B2%E3%82%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%98%E3%83%86%E3%83%AD%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%B9Mini-HPC%E3%82%92%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E3%82%81%E3%81%A7%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E7%B4%A0%E6%95%B5%E3%81%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97!%3C%2FP%3E%3CP%3EFortran%E3%81%A7%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%87%A6%E7%90%86(%3CEM%3E%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%BC%94%E7%AE%97%2F%E7%A7%92%3C%2FEM%3E)%E3%81%8C%E9%80%9F%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AA%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E7%A7%91%E5%AD%A6%E7%9A%84%2F%E5%AD%A6%E8%A1%93%E7%9A%84%E3%81%AA%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%89%8B%E3%81%AE%E3%81%B2%E3%82%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%98%E3%83%86%E3%83%AD%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%B9Mini-HPC%E3%82%92%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%82%A1%E3%83%B3%E3%81%AF%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%86%B1%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E5%B0%91%E3%81%97%E6%9A%96%E3%81%8B%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E8%B5%A4%E3%81%A1%E3%82%83%E3%82%93%E3%81%AE%E6%AE%BB%E3%81%AF%E3%82%A2%E3%83%AB%E3%83%9F%E3%83%8B%E3%82%A6%E3%83%A0%E3%81%A7%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%89%8B%E3%81%AE%E3%81%B2%E3%82%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%98%E3%83%86%E3%83%AD%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%B9Mini-HPC%E3%82%92%E6%A7%8B%E7%AF%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ENice.%3C%2FP%3E%3CP%3E%E5%86%B7%E5%8D%B4%E3%83%95%E3%82%A1%E3%83%B3%E3%82%84%E3%83%92%E3%83%BC%E3%83%88%E3%82%B7%E3%83%B3%E3%82%AF%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎03-30-2013 09:11 PM
更新者:
