Task #9 - How to add bad/ugly
Bad and Ugly gstreamer plugins has their own special licensing, so it cannot be released formally inside any tarball. (I do not understand it deeply, if you want more info, please go to GStreamer: Licensing advice)
But you can add it on your own image, and you only need to change the local.conf
Please, add the following code to your local.conf:
LICENSE_FLAGS_WHITELIST = "commercial"
COMMERCIAL_AUDIO_PLUGINS ?= " \
gst-plugins-ugly-mad \
gst-plugins-ugly-mpegaudioparse \
COMMERCIAL_VIDEO_PLUGINS ?= " \
gst-plugins-ugly-mpeg2dec \
gst-plugins-ugly-mpegstream \
gst-plugins-bad-mpegvideoparse \
CORE_IMAGE_EXTRA_INSTALL += " \
packagegroup-fsl-gstreamer \
gst-plugins-base-videotestsrc \
gst-plugins-bad-fbdevsink \
gst-ffmpeg alsa-utils \
gst-plugins-good-isomp4 \
Please, note that this will not install *every* plugin from ugly or bad. It will only install the plugins from the list.
Go to Yocto Training - HOME
Go to Task #8 - Build kernel manually using created toolchain
コメント
I try to follow your instructions but I keep getting this error:
Trying to install gst-plugins-bad-mpegtddemux and I get:
DEBUG: Executing shell function do_rootfs
| Note: configuring RPM platform settings
| Note: configuring RPM system provides
| Note: configuring RPM DB settings
| Note: configuring Smart settings
| Note: adding Smart channel nitrogen6x (80)
| Note: adding Smart channel armv7a_vfp_neon (75)
| Note: adding Smart channel all (10)
| Note: configuring RPM cross-install scriptlet_wrapper
| Updating cache...               ######################################## [100%]
| Saving cache...
| Note: adding Smart RPM DB channel
| Note: to be installed:  libsoup-2.4@armv7a_vfp_neon firmware-imx-vpu-imx6q@nitrogen6x libgtop-2.0-7@armv7a_vfp_neon rpm-postinsts@all packagegroup-core-nfs-server@all python-subprocess@armv7a_vfp_neon vbmediaserver@armv7a_vfp_neon gst-plugins-base-tcp@nitrogen6x packagegroup-fsl-gstreamer@nitrogen6x python-datetime@armv7a_vfp_neon python-json@armv7a_vfp_neon packagegroup-core-boot@nitrogen6x
| Loading cache...
| Computing transaction...error: Can't install libglib-2.0-utils-1:2.34.3-r2@armv7a_vfp_neon: no package provides /usr/local/bin/python
| Saving cache...
| ERROR: Function failed: do_rootfs (see /home/tim/imx/yocto/fsl-community-bsp/build/tmp/work/nitrogen6x-poky-linux-gnueabi/n6x-min/1.0-r0/temp/log.do_rootfs.18452 for further information)
ERROR: Task 7 (/home/tim/imx/yocto/fsl-community-bsp/sources/meta-n6x-min/recipes-fsl/images/n6x-min.bb, do_rootfs) failed with exit code '1'
Any help would be appreciated.
Tim
Sorry for my delay.
Could you, please, let me know which branch are you using? (master or dylan?)
Sorry for delay as well. I didn't seem to get email with notification.
I followed the steps according to:
http://www.ossystems.com.br/blog/2013/04/15/yocto-with-boundary-devices-nitrogen6x-5-steps-only
So, I assume dylan according to the post.
I need to get it resolved ASAP if you have any ideas. I have posted to Yocto forum without much support as of yet in getting it resolved.
I have verified on my host machine that /usr/local/bin/python does exist.
Tim
how are you trying to install the package?
I tried a few different ways.
1. I tried to add gst-plugins-bad-mpegtsdemux to the packagebase (I think that is the name, I dont' have it in front of me) where the -gstreamer packages are included (gst-plugins-good-meta).
2. The above post. But I removed everything except the LICENSE_FLAGS_WHITELIST and COMMERCIAL_VIDEO_PLUGINS and I changed it to gst-plugins-bad-mpegtsdemux.
Both resulted in the same error. Can you add it to your build and see if it runs?
Tim
Any idea Daiane?
Sorry for delay ~very busy here~ :smileysad:
I will let it building over here and let you know tomorrow
OK thank you... I think it may be possible to just copy for now the mpeg2tsdemux plugin from my LTIB build for temporary fix. But, I would like to get it resolved. Please let me know what you come up with.
Tim
Please, see my local.conf. I did build fsl-image-test (on dylan) until the end. I think you can clean some packages, or remove your tmp completely and try again.
~/fsl-community-bsp/dylan/build$ cat conf/local.conf
MACHINE ??= 'nitrogen6x'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
    STOPTASKS,${TMPDIR},1G,100K \
    STOPTASKS,${DL_DIR},1G,100K \
    STOPTASKS,${SSTATE_DIR},1G,100K \
    ABORT,${TMPDIR},100M,1K \
    ABORT,${DL_DIR},100M,1K \
    ABORT,${SSTATE_DIR},100M,1K"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '4'
PARALLEL_MAKE = '-j 4'
ACCEPT_FSL_EULA = "1"
    gst-plugins-bad-mpegtsdemux \
Hello Diane,
When I am running bitbake with above changes, I am getting an error for both gst-ffmpeg and gst-plugins-ugly.
The error I have pasted here is for gst-ffmpeg.
pshah9@ubuntu:~/Documents/yocto/fsl-community-bsp/build$ bitbake fsl-image-guiParsing recipes: 100% |#########################################| Time: 00:13:37
Parsing of 1278 .bb files complete (0 cached, 1278 parsed). 1646 targets, 58 skipped, 0 masked, 0 errors.
Build Configuration:
BB_VERSION        = "1.18.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-12.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "wandboard-dual"
DISTRO            = "poky"
DISTRO_VERSION    = "1.4.2"
TUNE_FEATURES     = "armv7a vfp neon"
TARGET_FPU        = "vfp-neon"
meta
meta-yocto        = "wvsnp_imx6slevk1:4e399f08d596197859214fdb3b06403b87bf8789"
meta-oe           = "wvsnp_imx6slevk1:a108b2203a997634f87ac687e81712badaf3c546"
meta-fsl-arm      = "wvsnp_imx6slevk1:afe2162644544a92a517f1d51211fdcb76bb1a29"
meta-fsl-arm-extra = "wvsnp_imx6slevk1:5f5a9cfcad223f5a1c623346780510ffcdc012ab"
meta-fsl-demos    = "wvsnp_imx6slevk1:724cfb929748f47782dea3b1dc412b028f6f3515"
NOTE: Resolving any missing task queue dependencies
NOTE: multiple providers are available for jpeg (jpeg, libjpeg-turbo)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg
NOTE: multiple providers are available for jpeg-native (jpeg-native, libjpeg-turbo-native)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg-native
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_configure (see /home/pshah9/Documents/yocto/fsl-community-bsp/build/tmp/work/armv7a-vfp-neon-poky-linux-gnueabi/libav/0.8.4+gitAUTOINC+2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0/temp/log.do_configure.13483 for further information)
ERROR: Logfile of failure stored in: /home/pshah9/Documents/yocto/fsl-community-bsp/build/tmp/work/armv7a-vfp-neon-poky-linux-gnueabi/libav/0.8.4+gitAUTOINC+2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0/temp/log.do_configure.13483
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
| DEBUG: Executing shell function autotools_preconfigure
| Previously configured separate build directory detected, cleaning /home/pshah9/Documents/yocto/fsl-community-bsp/build/tmp/work/armv7a-vfp-neon-poky-linux-gnueabi/libav/0.8.4+gitAUTOINC+2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0/git/build.arm-poky-linux-gnueabi.arm-poky-linux-gnueabi
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing shell function do_configure
| arm-poky-linux-gnueabi-gcc is unable to create an executable file.
| C compiler test failed.
| If you think configure made a mistake, make sure you are using the latest
| version from Git.  If the latest version fails, report the problem to the
| libav-user@libav.org mailing list or IRC #libav on irc.freenode.net.
| Include the log file "config.log" produced by configure as this will help
| solving the problem.
ERROR: Task 1726 (/home/pshah9/Documents/yocto/fsl-community-bsp/sources/meta-openembedded/meta-oe/recipes-multimedia/libav/libav_0.8.4.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6690 tasks of which 6688 didn't need to be rerun and 1 failed.
No currently running tasks (6688 of 6709)
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Somehow I am not able to attach a config.log file. Please let me know how to do it if the file is needed.
It is very urgent for me to resolve this error.
Sorry for my delay...
Which branch are you using? I will try to reproduce the error on my side
I am using dylan branch.
Hi Daiane,
I made a switch from Dylan to master branch and it solved the above error for me.
Now I want to add h264 encoder(x264enc) to my image. For this I added
gst-plugins-ugy-meta to CORE_IMAGE_EXTRA_INSTALL as you have shown
for adding particular element to the image.
Everything compiled properly here but still I didn't get x264enc element in my image.
Can you help me adding x264enc to my image?
Tejas,
Make sure the gst-plugins-ugly-meta recipe contains the SW encoder you want. BTW, why do you need SW encoding if you got vpuenc?
leo
Hi Leo,
I am performing power consumption of sending a video from wandboard to a network we have set it up.
Basically here I am comparing the power consumption of video captured using software with video captured
using hardware accelerator on the board.
Hi Leo,
I am looking at the file inside ~/yocto/fsl-community-bsp/sources/poky/meta/recipes-multimedia/gstreamer/gst-plugins-ugly_0.10.19.bb
Is this the correct place to look up?
Hi Tejas,
why are you including gst-plugins-ugly-meta? seems  that the recipe does not exist. As Daiane mentioned, have you add that element this way?
    gst-plugins-ugly-x264enc \
In the other hand, That recipe (./poky/meta/recipes-multimedia/gstreamer/gst-plugins-ugly_0.10.19.bb) can also be used to include the element but I think the way Daiane mentioned is better for your purposes.
Leo
Good to hear it´s fixed on newer code. And I would like to see your results comparing both encoders, if you don´t mind to share, in future.
Looking on http://git.yoctoproject.org/cgit/cgit.cgi/poky/tree/meta/recipes-multimedia/gstreamer/gstreamer1.0-p...
It looks like the x264 is not selected by default:
PACKAGECONFIG ??= " \
  a52dec lame mad mpeg2dec \
So, could you try, please, to add the following line you your local.conf?
PACKAGECONFIG_pn_gstreamer1.0-plugins-ugly += "x264"
Please, let me know the results
The reason is that I get a error when I add element that way. Here is the error I get:
| Computing transaction...error: Can't install gst-meta-video-0.10-r13@cortexa9hf_vfp_neon: no package provides gst-plugins-ugly-x264enc
| Saving cache...
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_rootfs (log file is located at /home/pshah9/Desktop/yocto-master/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/fsl-image-gui/1.0-r0/temp/log.do_rootfs.16656)
ERROR: Task 7 (/home/pshah9/Desktop/yocto-master/fsl-community-bsp/sources/meta-fsl-demos/recipes-fsl/images/fsl-image-gui.bb, do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6575 tasks of which 6522 didn't need to be rerun and 1 failed.
No currently running tasks (6575 of 6576)
Summary: There was 1 WARNING message shown.
Due to this error I am using gst-plugins-ugly-meta
Here is my config file when I add element as you suggested:
MACHINE ??= 'wandboard-dual'
DISTRO ?= 'poky'
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '2'
PARALLEL_MAKE = '-j 2'
ACCEPT_FSL_EULA = ""
gst-plugins-bad-meta \
gst-ffmpeg \
gst-plugins-base-meta \
Hi Daiane,
As I mentioned earlier I am using gst-plugins-ugly-meta in CORE_IMAGE_EXTRA_INSTALL.
After adding the line of code that you asked for in the local.conf, it doesn't change anything.
I still get the same error that there is no element as x264enc.
Here is my config file. Please let me know if I have something wrong in there.
DISTRO ?= 'poky'
CONF_VERSION = "1"
gst-plugins-ugly-meta \
gst-ffmpeg \
Instead of using gst-plugins-ugly-meta, if I were to use gst-plugins-ugly-x264enc or gst-plugins-ugly-x264 as Leo suggested, then I get the below error.
Ok, I would need to spend more time debugging this, I need to reproduce it on my side.
Tejas Shah, could you, please, make me a favor? Could you, please, open a new discussion on imx-community, With title something like "How to include x264enc on yocto"
This way it would be much easier for another person to find the solution, in future (them among a lot of comments on a Doc).
Please, mention me (use @ and my name daiane_angolini). I´m going to test it using dora and let you know the results.
Oh, please, remember to add your log error :smileywink:
Thanks in advance,
%3CLINGO-SUB%20id%3D%22lingo-sub-1112008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EBad%20and%20Ugly%20gstreamer%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81tarball%20%E5%86%85%E3%81%A7%E6%AD%A3%E5%BC%8F%E3%81%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82(%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%B7%B1%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81GStreamer%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E8%87%AA%E5%88%86%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%80%81local.conf%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E6%B8%88%E3%81%BF%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%20local.conf%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3ELICENSE_FLAGS_WHITELIST%20%3D%20%E3%80%8C%E5%95%86%E7%94%A8%E3%80%8D%20%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3ECOMMERCIAL_AUDIO_PLUGINS%20%3F%3D%20%22%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-ugly-mad%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-ugly-mpegaudioparse%20%5C%20%3C%2FP%3E%0A%3CP%3E%22%20%3C%2FP%3E%0A%3CP%3ECOMMERCIAL_VIDEO_PLUGINS%20%3F%3D%20%22%20%5C%20%3C%2FP%3E%0A%3CP%3Egst%20-plugins%20-%20ugly%20-%20mpeg2dec%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-ugly-mpegstream%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-bad-mpegvideoparse%20%5C%20%3C%2FP%3E%0A%3CP%3E%22%20%3C%2FP%3E%0A%3CP%3ECORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22%20%5C%20%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97-FSL-gstreamer%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-base-videotestsrc%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-bad-fbdevsink%20%5C%20%3C%2FP%3E%0A%3CP%3EGST%20-%20FFMPEG%20ALSA-UTILS%20%5C%20%3C%2FP%3E%0A%3CP%3Egst-plugins-good-isomp4%20%5C%20%3C%2FP%3E%0A%3CP%3E%22%20%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E9%86%9C%E3%81%84%E3%81%BE%E3%81%9F%E3%81%AF%E6%82%AA%E3%81%84%E3%81%8B%E3%82%89*%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE*%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E3%81%BF%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20Training%E3%81%B8%20-%20HOME%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95225%22%20target%3D%22_blank%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%20%238%20-%20%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%E3%81%99%E3%82%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1112008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%82%82%E3%81%A3%E3%81%A8%E6%99%82%E9%96%93%E3%82%92%E8%B2%BB%E3%82%84%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B8%E3%83%A3%E3%82%B9%E3%83%BB%E3%82%B7%E3%83%A3%E3%83%BC%E3%80%81%E3%81%8A%E9%A1%98%E3%81%84%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82imx-community%E3%81%A7%E3%80%8Cyocto%E3%81%ABx264enc%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%BF%E3%82%A4%E3%83%88%E3%83%AB%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E5%B0%86%E6%9D%A5%E3%80%81%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%8C%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%81%8C%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99(%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E5%A4%9A%E3%81%8F%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E4%B8%AD%E3%81%A7%E5%BD%BC%E3%82%89)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E7%A7%81%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(%40%E3%81%A8%E7%A7%81%E3%81%AE%E5%90%8D%E5%89%8Ddaiane_angolini%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82dora%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%82%E3%80%81%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%88%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AFCORE_IMAGE_EXTRA_INSTALL%E3%81%A7gst-plugins-ugly-meta%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Elocal.conf%20%E3%81%A7%E8%A6%81%E6%B1%82%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E4%BD%95%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Ex264enc%20%E3%81%A8%E3%81%97%E3%81%A6%E8%A6%81%E7%B4%A0%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'wandboard-dual'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0-%E5%BE%AE%E8%AA%BF%E6%95%B4%20ssh-server-openssh%20%22%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%22buildstats%20image-mklibs%20image-prelink%22%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'2'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%202'%3C%2FP%3E%3CP%3EACCEPT_FSL_EULA%20%3D%20%22%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELICENSE_FLAGS_WHITELIST%20%3D%20%E3%80%8C%E5%95%86%E7%94%A8%E3%80%8D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22%20%5C%3C%2FP%3E%3CP%3Egst-plugins-ugly-meta%20%5C%3C%2FP%3E%3CP%3Egst-plugins-bad-meta%20%5C%3C%2FP%3E%3CP%3EGST-FFMPEG%20%5C%3C%2FP%3E%3CP%3Egst-plugins-base-meta%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn_gstreamer1.0-plugins-ugly%20%2B%3D%20%22x264%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-plugins-ugly-meta%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81Leo%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%ABgst-plugins-ugly-x264enc%E3%81%BE%E3%81%9F%E3%81%AFgst-plugins-ugly-x264%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%81%E7%B4%A0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%8C%E5%BE%97%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7C%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%A8%E3%83%A9%E3%83%BC%3Agst-meta-video-0.10-r13%40cortexa9hf_vfp_neon%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3Agst-plugins-ugly-x264enc%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%7C%3C%2FP%3E%3CP%3E%7C%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%7C%3C%2FP%3E%3CP%3E%7C%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Ado_rootfs(%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%2Fhome%2Fpshah9%2FDesktop%2Fyocto-master%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fwandboard_dual-poky-linux-gnueabi%2Ffsl-image-gui%2F1.0-r0%2Ftemp%2Flog.do_rootfs.16656%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF7%EF%BC%88%2Fhome%2Fpshah9%2FDesktop%2Fyocto-master%2Ffsl-community-bsp%2Fsources%2Fmeta-fsl-demos%2Frecipes-fsl%2Fimages%2Ffsl-image-gui.bb%2Cdo_rootfs)%20%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%206575%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%206522%20%E5%80%8B%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(6576%20%E3%81%AE%206575)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fhome%2Fpshah9%2FDesktop%2Fyocto-master%2Ffsl-community-bsp%2Fsources%2Fmeta-fsl-demos%2Frecipes-fsl%2Fimages%2Ffsl-image-gui.bb%2C%20do_rootfs%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C1%E3%81%A4%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E4%BB%B6%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%BB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E9%9D%9E%E3%82%BC%E3%83%AD%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81gst-plugins-ugly-meta%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E8%A6%81%E7%B4%A0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AE%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'wandboard-dual'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0-%E5%BE%AE%E8%AA%BF%E6%95%B4%20ssh-server-openssh%20%22%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%22buildstats%20image-mklibs%20image-prelink%22%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%20%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'2'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%202'%3C%2FP%3E%3CP%3EACCEPT_FSL_EULA%20%3D%20%22%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELICENSE_FLAGS_WHITELIST%20%3D%20%E3%80%8C%E5%95%86%E7%94%A8%E3%80%8D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EOMMERCIAL_VIDEO_PLUGINS%20%3F%3D%20%22%20%5C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-plugins-ugly-x264enc%20%5C%20%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3ECORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22%20%5C%3C%2FP%3E%3CP%3Egst-plugins-bad-meta%20%5C%3C%2FP%3E%3CP%3EGST-FFMPEG%20%5C%3C%2FP%3E%3CP%3Egst-plugins-base-meta%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn_gstreamer1.0-plugins-ugly%20%2B%3D%20%22x264%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%81%9E%E3%81%84%E3%81%A6%E3%82%88%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B5%90%E6%9E%9C%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E5%B0%86%E6%9D%A5%E3%80%81%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E6%A7%8B%E3%82%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fpoky%2Ftree%2Fmeta%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-plugins-ugly.inc%22%20title%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fpoky%2Ftree%2Fmeta%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-plugins-ugly.inc%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fpoky%2Ftree%2Fmeta%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-plugins-ugly.inc%3C%2FA%3E%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AFx264%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3EPACKAGECONFIG%20%3F%3F%3D%20%22%20%5C%3CBR%20%2F%3E%26nbsp%3B%20a52dec%20lame%20mad%20mpeg2dec%20%5C%3CBR%20%2F%3E%26nbsp%3B%20%22%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CCODE%20translate%3D%22no%22%3E%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3ESo%2C%20could%20you%20try%2C%20please%2C%20to%20add%20the%20following%20line%20you%20your%20local.conf%3F%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn_gstreamer1.0-plugins-ugly%20%2B%3D%20%22x264%22%3CBR%20%2F%3E%3CCODE%20translate%3D%22no%22%3E%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tejas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%9Cgst-plugins-ugly-meta%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%AC%E3%82%B7%E3%83%94%20%3CSTRONG%3E%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%20%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%80%E3%82%A4%E3%82%A2%E3%83%B3%E3%81%8C%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%92%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3ECOMMERCIAL_VIDEO_PLUGINS%20%3F%3D%20%22%20%5C%20%3CBR%20%2F%3Egst-plugins-ugly-x264enc%20%5C%20%3CBR%20%2F%3E%22%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E6%96%B9%E3%80%81%E3%81%9D%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94(.%2Fpoky%2Fmeta%2Frecipes-multimedia%2Fgstreamer%2Fgst-plugins-ugly_0.10.19.bb)%E3%82%82%E8%A6%81%E7%B4%A0%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Daiane%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF~%2Fyocto%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-multimedia%2Fgstreamer%2Fgst-plugins-ugly_0.10.19.bb%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%AE%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E6%89%80%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E5%8B%95%E7%94%BB%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ETejas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-plugins-ugly-meta%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AB%E7%9B%AE%E7%9A%84%E3%81%AESW%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81vpuenc%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%AA%E3%81%9CSW%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eleo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDylan%E3%81%8B%E3%82%89%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81h264%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC(x264enc)%E3%82%92%E7%94%BB%E5%83%8F%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%AF%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Egst-plugins-ugy-meta%20%E3%82%92%E3%80%81%E3%81%94%E8%A6%A7%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%ABCORE_IMAGE_EXTRA_INSTALL%20%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E7%A7%81%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AB%E3%81%AFx264enc%E8%A6%81%E7%B4%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ex264enc%E3%82%92%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%81%85%E3%82%8C%E3%81%A6%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%80%E3%82%A4%E3%82%A2%E3%83%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6bitbake%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81gst-ffmpeg%E3%81%A8gst-plugins-ugly%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AFgst-ffmpeg%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epshah9%40ubuntu%3A~%2FDocuments%2Fyocto%2Ffsl-community-bsp%2Fbuild%24%20bitbake%20fsl-image-guiParsing%20recipes%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%E6%99%82%E9%96%93%3A%2000%3A13%3A37%3C%2FP%3E%3CP%3E1278%20.bb%E3%81%AE%E8%A7%A3%E6%9E%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(0%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%811278%20%E8%A7%A3%E6%9E%90)%E3%80%821646%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%8158%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%80%810%20%E3%83%9E%E3%82%B9%E3%82%AF%E3%80%810%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%EF%BC%9A%3C%2FP%3E%3CP%3EBB_VERSION%20%3D%20%221.18.0%22%3C%2FP%3E%3CP%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3C%2FP%3E%3CP%3ENATIVELSBSTRING%20%3D%20%22Ubuntu%E3%81%AE-12.04%22%3C%2FP%3E%3CP%3ETARGET_SYS%20%3D%20%22arm-poky-linux-gnueabi%22%3C%2FP%3E%3CP%3EMACHINE%20%3D%20%22%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89-%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%22%3C%2FP%3E%3CP%3EDISTRO%20%3D%20%22poky%22%3C%2FP%3E%3CP%3EDISTRO_VERSION%20%3D%20%221.4.2%22%3C%2FP%3E%3CP%3ETUNE_FEATURES%20%3D%20%22armv7a%20vfp%20neon%22%3C%2FP%3E%3CP%3ETARGET_FPU%20%3D%20%22vfp-neon%22%3C%2FP%3E%3CP%3Emeta%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Emeta-yocto%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22wvsnp_imx6slevk1%3A4e399f08d596197859214fdb3b06403b87bf8789%22%3C%2FP%3E%3CP%3Emeta-oe%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22wvsnp_imx6slevk1%3Aa108b2203a997634f87ac687e81712badaf3c546%22%3C%2FP%3E%3CP%3Emeta-fsl-arm%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22wvsnp_imx6slevk1%3Aafe2162644544a92a517f1d51211fdcb76bb1a29%22%3C%2FP%3E%3CP%3E%E3%83%A1%E3%82%BF-fsl-arm-extra%20%3D%20%22wvsnp_imx6slevk1%3A5f5a9cfcad223f5a1c623346780510ffcdc012ab%22%3C%2FP%3E%3CP%3Emeta-fsl-demos%20%3D%20%22wvsnp_imx6slevk1%3A724cfb929748f47782dea3b1dc412b028f6f3515%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9A%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%BB%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%3C%2FP%3E%3CP%3E%E6%B3%A8%3AJPEG%E3%81%AB%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99(jpeg%E3%80%81libjpeg-turbo)%3C%2FP%3E%3CP%3E%E6%B3%A8%3Ajpeg%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABPREFERRED_PROVIDER%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E6%B3%A8%3Ajpeg-native(jpeg-native%E3%80%81libjpeg-turbo-native)%E3%81%AB%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E6%B3%A8%3Ajpeg-native%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABPREFERRED_PROVIDER%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9A%E5%AE%9F%E8%A1%8C%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E6%BA%96%E5%82%99%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9ASetScene%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9ARunQueue%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Ado_configure(%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%2Fhome%2Fpshah9%2FDocuments%2Fyocto%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Flibav%2F0.8.4%2BgitAUTOINC%2B2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0%2Ftemp%2Flog.do_configure.13483%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2Fhome%2Fpshah9%2FDocuments%2Fyocto%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Flibav%2F0.8.4%2BgitAUTOINC%2B2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0%2Ftemp%2Flog.do_configure.13483%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%E9%96%A2%E6%95%B0%20sysroot_cleansstate%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3C%2FP%3E%3CP%3E%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%20%E9%96%A2%E6%95%B0%20sysroot_cleansstate%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%7C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20SITE%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%5B'endian-little'%2C%20'bit-32'%2C%20'arm-common'%2C%20'common-linux'%2C%20'common-glibc'%2C%20'arm-linux'%2C%20'arm-linux-gnueabi'%2C%20'common'%5D%3C%2FP%3E%3CP%3E%7CDEBUG%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20autotools_preconfigure%20%E3%81%AE%E5%AE%9F%E8%A1%8C%3C%2FP%3E%3CP%3E%7C%E4%BB%A5%E5%89%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%88%A5%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%2Fhome%2Fpshah9%2FDocuments%2Fyocto%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Flibav%2F0.8.4%2BgitAUTOINC%2B2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0%2Fgit%2Fbuild.arm-poky-linux-gnueabi.arm-poky-linux-gnueabi%3C%2FP%3E%3CP%3E%7C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%E3%82%B7%E3%82%A7%E3%83%AB%E6%A9%9F%E8%83%BDautotools_preconfigure%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%EF%BD%9C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%EF%BC%9A%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0do_configure%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%7Carm-poky-linux-gnueabi-gcc%20%E3%81%AF%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%7CC%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%7C%3C%2FP%3E%3CP%3E%7Cconfigure%20%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%7CGit%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%82%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%3C%2FP%3E%3CP%3E%3CSPAN%3E%7C%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Alibav-user%40libav.org%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elibav-user%40libav.org%3C%2FA%3E%3CSPAN%3E%20%E3%83%A1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AA%E3%82%B9%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AFIRC%20%23libav%20irc.freenode.net%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cconfig.log%E3%80%8D%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%81%93%E3%82%8C%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%82%88%E3%81%86%E3%81%ABconfigure%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%7C%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Ado_configure(%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%2Fhome%2Fpshah9%2FDocuments%2Fyocto%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Flibav%2F0.8.4%2BgitAUTOINC%2B2c8ce46250ff78191fe6565876ddc4bc03fdf519-r8.0%2Ftemp%2Flog.do_configure.13483%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF1726(%2F%20home%20%2F%20pshah9%20%2F%20Documents%20%2F%20yoc%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-openembedded%20%2F%20meta-oe%20%2F%20recipes%20-%20multimedia%20%2F%20libav%20%2F%20libav_0.8.4.bb%E3%80%81do_configure)%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%206690%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%206688%20%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(6688%2F6709)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fhome%2Fpshah9%2FDocuments%2Fyocto%2Ffsl-community-bsp%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-multimedia%2Flibav%2Flibav_0.8.4.bb%2C%20do_configure%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E4%BB%B6%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%BB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E9%9D%9E%E3%82%BC%E3%83%AD%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E3%82%8F%E3%81%91%E3%81%8B%E3%80%81config.log%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%B7%8A%E6%80%A5%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AElocal.conf%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%BE%E3%81%A7fsl-image-test%E3%82%92(%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%81%A7)%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81tmp%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E~%2Ffsl-community-bsp%2Fdylan%2Fbuild%24%20cat%20conf%2Flocal.conf%3CBR%20%2F%3E%E6%A9%9F%E6%A2%B0%E3%80%82%E3%80%82%3D%20'%E7%AA%92%E7%B4%A06x'%3CBR%20%2F%3EDISTRO%20%3F%3D%20'%E3%83%9D%E3%83%83%E3%82%AD%E3%83%BC'%3CBR%20%2F%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3CBR%20%2F%3EEXTRA_IMAGE_FEATURES%20%3D%20%22%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%AA%BF%E6%95%B4%22%3CBR%20%2F%3EUSER_CLASSES%20%3F%3D%20%22buildstats%20image-mklibs%20image-prelink%22%3CBR%20%2F%3EPATCHRESOLVE%20%3D%20%22noop%22%3CBR%20%2F%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3CBR%20%2F%3ESTOPTASKS%E3%80%81%24%7BTMPDIR%7D%E3%80%811G%E3%80%81100K%20%5C%3CBR%20%2F%3ESTOPTASKS%E3%80%81%24%7BDL_DIR%7D%E3%80%811G%E3%80%81100K%20%5C%3CBR%20%2F%3ESTOPTASKS%E3%80%81%24%7BSSTATE_DIR%7D%E3%80%811G%E3%80%81100K%20%5C%3CBR%20%2F%3E%E4%B8%AD%E6%AD%A2%E3%80%81%24%7BTMPDIR%7D%E3%80%81100M%E3%80%811K%20%5C%3CBR%20%2F%3E%E4%B8%AD%E6%AD%A2%E3%80%81%24%7BDL_DIR%7D%E3%80%81100M%E3%80%811K%20%5C%3CBR%20%2F%3E%E4%B8%AD%E6%AD%A2%E3%80%81%24%7BSSTATE_DIR%7D%E3%80%81100M%E3%80%811K%22%20%3CBR%20%2F%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'4'%3CBR%20%2F%3EPARALLEL_MAKE%20%3D%20'-j%204'%3CBR%20%2F%3EACCEPT_FSL_EULA%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELICENSE_FLAGS_WHITELIST%20%3D%20%E3%80%8C%E5%95%86%E7%94%A8%E3%80%8D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECOMMERCIAL_AUDIO_PLUGINS%20%3F%3D%20%22%20%5C%20%3CBR%20%2F%3Egst-plugins-ugly-mad%20%5C%20%3CBR%20%2F%3Egst-plugins-ugly-mpegaudioparse%20%5C%20%3CBR%20%2F%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECOMMERCIAL_VIDEO_PLUGINS%20%3F%3D%20%22%20%5C%20%3CBR%20%2F%3Egst%20-plugins%20-%20ugly%20-%20mpeg2dec%20%5C%20%3CBR%20%2F%3Egst-plugins-ugly-mpegstream%20%5C%20%3CBR%20%2F%3Egst-plugins-bad-mpegvideoparse%20%5C%20%3CBR%20%2F%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22%20%5C%20%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97-FSL-gstreamer%20%5C%20%3CBR%20%2F%3Egst-plugins-base-videotestsrc%20%5C%20%3CBR%20%2F%3Egst-plugins-bad-mpegtsdemux%20%5C%3CBR%20%2F%3Egst-plugins-bad-fbdevsink%20%5C%20%3CBR%20%2F%3EGST%20-%20FFMPEG%20ALSA-UTILS%20%5C%20%3CBR%20%2F%3Egst-plugins-good-isomp4%20%5C%20%3CBR%20%2F%3E%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%80%82%E3%80%82%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AA%E4%BF%AE%E6%AD%A3%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81LTIB%E3%83%93%E3%83%AB%E3%83%89%E3%81%8B%E3%82%89mpeg2tsdemux%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%95%E3%82%92%E6%80%9D%E3%81%84%E3%81%A4%E3%81%84%E3%81%9F%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETim%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%81%85%E3%82%8C%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93~%E3%81%93%E3%81%93%E3%81%A7%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BF%99%E3%81%97%E3%81%84~%20%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E6%A7%8B%E7%AF%89%E3%81%95%E3%81%9B%E3%81%A6%E3%80%81%E6%98%8E%E6%97%A5%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.-gstreamer%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%99%E3%83%BC%E3%82%B9(gst-plugins-good-meta)%E3%81%ABgst-plugins-bad-mpegtsdemux%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(%E3%81%9D%E3%82%8C%E3%81%8C%E5%90%8D%E5%89%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E5%89%8D%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%20%3C%2FP%3E%3CP%3E2.%E4%B8%8A%E8%A8%98%E3%81%AE%E6%8A%95%E7%A8%BF%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81LICENSE_FLAGS_WHITELIST%E3%81%A8COMMERCIAL_VIDEO_PLUGINS%E4%BB%A5%E5%A4%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81gst-plugins-bad-mpegtsdemux%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETim%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E9%81%85%E3%82%8C%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%80%9A%E7%9F%A5%E4%BB%98%E3%81%8D%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%8C%E5%B1%8A%E3%81%8B%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.ossystems.com.br%2Fblog%2F2013%2F04%2F15%2Fyocto-with-boundary-devices-nitrogen6x-5-steps-only%22%20title%3D%22http%3A%2F%2Fwww.ossystems.com.br%2Fblog%2F2013%2F04%2F15%2Fyocto-with-boundary-devices-nitrogen6x-5-steps-only%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.ossystems.com.br%2Fblog%2F2013%2F04%2F15%2Fyocto-with-boundary-devices-nitrogen6x-5-steps-only%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E6%8A%95%E7%A8%BF%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFYocto%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%2F%20usr%20%2F%20local%20%2F%20bin%20%2F%20python%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETim%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%81%85%E3%82%8C%E3%81%A6%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F(%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8B%E3%83%87%E3%82%A3%E3%83%A9%E3%83%B3%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%239%20-%20%E6%82%AA%E3%81%84%2F%E9%86%9C%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%8A%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%3Egst-plugins-bad-mpegtddemux%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CP%3E%3C%2FP%3EDEBUG%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_rootfs%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%E6%B3%A8%3A%20RPM%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E8%A8%AD%E5%AE%9A%E3%81%AE%E6%A7%8B%E6%88%90%3CBR%20%2F%3E%7C%E6%B3%A8%3ARPM%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%E6%B3%A8%3A%20RPM%20DB%20%E8%A8%AD%E5%AE%9A%E3%81%AE%E6%A7%8B%E6%88%90%3CBR%20%2F%3E%7C%E6%B3%A8%3A%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E6%A7%8B%E6%88%90%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E6%B3%A8%3A%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABnitrogen6x(80)%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E6%B3%A8%3A%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABarmv7a_vfp_neon%E3%81%AE%E8%BF%BD%E5%8A%A0%20(75)%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E6%B3%A8%3A%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E8%BF%BD%E5%8A%A0(10)%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E6%B3%A8%3A%20RPM%20%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%ABscriptlet_wrapper%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20Saving%20cache...%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20Note%3A%20adding%20Smart%20RPM%20DB%20channel%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%20Note%3A%20to%20be%20installed%3A%26nbsp%3B%20libsoup-2.4%40armv7a_vfp_neon%20firmware-imx-vpu-imx6q%40nitrogen6x%20libgtop-2.0-7%40armv7a_vfp_neon%20rpm-postinsts%40all%20packagegroup-core-nfs-server%40all%20python-subprocess%40armv7a_vfp_neon%20vbmediaserver%40armv7a_vfp_neon%20gst-plugins-base-tcp%40nitrogen6x%20packagegroup-fsl-gstreamer%40nitrogen6x%20python-datetime%40armv7a_vfp_neon%20python-json%40armv7a_vfp_neon%20packagegroup-core-boot%40nitrogen6x%3CBR%20%2F%3E%7C%20Loading%20cache...%3CBR%20%2F%3E%7C%20Updating%20cache...%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B6%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%A8%E3%83%A9%E3%83%BC%3Alibglib-2.0-utils-1%3A2.34.3-r2%40armv7a_vfp_neon%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%2F%20usr%20%2F%20local%20%2F%20bin%20%2F%20python%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%7C%20%3CBR%20%2F%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Ado_rootfs(%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%2Fhome%2Ftim%2Fimx%2Fyocto%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fnitrogen6x-poky-linux-gnueabi%2Fn6x-min%2F1.0-r0%2Ftemp%2Flog.do_rootfs.18452%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF7%EF%BC%88%2Fhome%2Ftim%2Fimx%2Fyocto%2Ffsl-community-bsp%2Fsources%2Fmeta-n6x-min%2Frecipes-fsl%2Fimages%2Fn6x-min.bb%2Cdo_rootfs)%20%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%E3%81%A9%E3%82%93%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%A7%E3%82%82%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETim%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-30-2013 11:59 AM
更新者:
