Task #4 - Deploy and test
Update
The source code is one week old now, so please, update it!
$ repo sync
Images - the result of a bitbake
Example of a content after bitbake
build_mx6/tmp/deploy/images:
fsl-image-gui-imx6qsabresd-20130505174618.rootfs.ext3
fsl-image-gui-imx6qsabresd-20130505174618.rootfs.sdcard
fsl-image-gui-imx6qsabresd-20130505174618.rootfs.tar.bz2
fsl-image-gui-imx6qsabresd-20130508162511.rootfs.ext3
fsl-image-gui-imx6qsabresd-20130508162511.rootfs.sdcard
fsl-image-gui-imx6qsabresd-20130508162511.rootfs.tar.bz2
fsl-image-gui-imx6qsabresd.ext3
fsl-image-gui-imx6qsabresd.sdcard
fsl-image-gui-imx6qsabresd.tar.bz2
modules-3.0.35-1.1.0+yocto+g0596856-r32.10-imx6qsabresd.tgz
README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
u-boot.imx
u-boot-imx6qsabresd.imx
u-boot-imx6qsabresd-v2013.04-r3.imx*
uImage
uImage-3.0.35-r32.10-imx6qsabresd-20130505174618.bin
uImage-imx6qsabresd.bin
Get used with generated images. Understand which file is a symbolic link and which one is the image in fact. Symbolic link will always point to latest image.
sdcard image
Take a look how sdcard is generated here meta-fsl-arm - Layer containing Freescale ARM hardware support metadata
The disk layout used is:
0-> IMAGE_ROOTFS_ALIGNMENT    reserved to bootloader (not partitioned)
IMAGE_ROOTFS_ALIGNMENT -> BOOT_SPACE    kernel and other data
BOOT_SPACE -> SDIMG_SIZE     rootfs
Use IMAGE_OVERHEAD_FACTOR to add more space
Please, go to original file in order to understand the disk layout.
It´s basically some initial space for u-boot. One partition for uImage. One partition for rootfs. The total sdcard size will be calculate for every image, if you want to add more empty space inside generated sdcard, use IMAGE_OVERHEAD_FACTOR.
Deploy
Deploy the sdcard image:
$ sudo dd if=fsl-image-gui-imx6qsabresd.sdcard of=/dev/sdX bs=1M
Or, deploy the ext3 rootfs
$ sudo dd if=fsl-image-gui-imx6qsabresd.ext3 of=/dev/sdX2 bs=1M
Or deploy only the tar.bz rootfs
$ sudo mount /dev/sdX2 /mnt/card
$ sudo tar xf imagename-imx53qsb.tar.bz2 -C /mnt/card
In order to deploy only kernel
$ sudo cp uImage-3.0.35-r32.10-imx6qsabresd-20130505174618.bin /media/Boot
In order to  deploy only u-boot
$ sudo dd if=u-boot-imx6qsabresd-v2012.10-r3.imx of=/dev/sdX bs=512 seek=2
If using HDMI please, modify u-boot environment arguments:
setenv mmcargs "setenv bootargs console=${console},${baudrate} root=${mmcroot} rootwait rw video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24"
This is the how sdcards are made by meta-fsl-arm. Of course you can use your own. But double check the u-boot bootenv.
Plug your sdcard and let the board boot
To login: root
Go to HOME
Go to Task #3 - The build result
Go to Task#5 - kernel
コメント
Hi Daiane,
to complete the guide at the first boot on imx6qsabresd using HDMI is better to add a note to modify the uboot envvar mmcargs with commands:
setenv mmcargs=setenv bootargs console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
saveenv
boot
Bye
Thanks a lot, Francesco. Nice comment!
Would you be available to change this bit directly in the source code and send us a patch? This is a "missing feature" that I would love to have integrated, and it´s quite simple to implement.
I could guide you if you feel like.
Hi Daiane,
I'm a newbie in this area, but I'll be happy to learn how make this
modification if you can help me!
If I can take advantage of your knowledge I would need to connect to SABRE
a CAN controller SJA1000 on bus EIM, do you have any suggestions for me on
hw and sw point of view?
Many thanks!
Francesco
For the CAN issue, could you, please, create a new discussion? I´m not the only one who can advice you about CAN (in fact, I´m not even the best one). Once you have created the new topic, please share with me :smileywink:
For the u-boot.
1- take the source code (git clone) from Commits · Freescale/u-boot-imx · GitHub
2- create one patch just like mx6qsabrelite: Change default environment to cope with OE changes · 08bb52d · Freescale/u-boot-imx ·...
But, instead, change the mmcarg for using HDMI by default.
3- OtavioSalvador, will receive your patch for u-boot and integrate it on github tree.
4- modify this file meta-fsl-arm - Layer containing Freescale ARM hardware support metadata
to make it point to the right commit id
I will be very glad to have someone working with CAN on the project. Please, ask any question during the process.
I only have one question. Would be HDMI the best default video output?
Hello, I have an error while using the setenv command on the Sabrelite board from element14.
The board has U-Boot 2009.08 (Aug 16 2012 - 10:06:42)
I think the correct format for the command should be:
setenv mmcargs 'setenv bootargs console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24'
saveenv
boot
At least this sentence doesn't give an error.
I have some trouble making the "fsl-image-gui-imx6qsabresd.sdcard" work with my Sabrelite board.
The build was ok all images were created.
Then I deployed the image to a micro SD card with the following command:
sudo dd if=fsl-image-gui-imx6qsabresd.sdcard of=/dev/sdb bs=1M
When I try to boot the Sabrelite board I have the following error in the debug console.
CPU:   Freescale i.MX 6 family 0.0V at 792 MHz
Temperature:   39 C, calibration data 0x5774ed7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 29333333Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 200000000Hz
usdhc2 clock  : 200000000Hz
usdhc3 clock  : 200000000Hz
usdhc4 clock  : 200000000Hz
nfc clock     : 24000000Hz
Board: MX6Q-SABRELITE:[ POR]
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1
JEDEC ID: 0xbf:0x25:0x41
Reading SPI NOR flash 0xc0000 [0x2000 bytes] -> ram 0x276009b8
SUCCESS
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot:  3     2     1     0
Card did not respond to voltage select!
mmc0(part 0) is current device
MMC: block number 0x1 exceeds max(0x0)
** Can't read from device 0 **
** Unable to use mmc 0:1 for fatload **
** Bad partition 1 **
mmc1 is current device
reading /6q_bootscript
** Unable to read "/6q_bootscript" from mmc 1:1 **
Loading file "/6q_bootscript" from mmc device 1:1 (xxb1)
Failed to mount ext2 filesystem...
** Bad ext2 partition or disk - mmc 1:1 **
MX6Q SABRELITE U-Boot >
Any idea, what is wrong ?
ssinfod
Him, yes you are right! The "=" is a my copy and paste error! I'm sorry!
Hi, I'm not sure this is the issue but you are using an image compiled for qsabresd on a qsabrelite?
Bye!
Please build nitrogen6x machine and give it a try in sabrelite; I will send the patch to fix this later today.
Nitrogen6x and SabreLITE are compatible so you can do it.
For sabrelite development, please, take a look here
https://community.freescale.com/message/335684#335684
A lot of good info regarding sabrelite bootloader/kernel and so on.
In addition, use Nitrogen config file to built it when using meta-fsl-arm
:smileywink:
Hi Daiane,
I apologize but I'm not so expert to follow your procedure (only point 1 is at my level! :-P)
I've also another possible setting of mmcargs variable to exit on LVDS0 1024x600:
setenv mmcargs 'setenv bootargs console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw video=mxcfb0:dev=ldb,1024x600M@60,if=RGB666'
Bye.
Ok :smileywink:
Thanks anyway :smileysilly:
I made a new bitbake with the new target machine nitrogen6x. The file was generated successfully. (fsl-image-gui-nitrogen6x.sdcard)
However, I still have the same error. (see log below)
Anyhow, I think the SD card seems to be written correctly:
The SD card volume name is "Boot nitrog". The files visible on the SD card are:  6x_bootscript, uImage
I notice that in the log that UBoot search for: 6q_bootscript instead of 6x_bootscript. (q verus x in the name)
Could it be related to this ? I rename the x to q but now the console displays another problem...
LOG1:
Temperature:   49 C, calibration data 0x5774ed7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
SUCCESS
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
MX6Q SABRELITE U-Boot > pprriinntteennvv
bootdelay=3
baudrate=115200
ipaddr=192.168.1.103
serverip=192.168.1.101
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
uboot=u-boot.bin
kernel=uImage
nfsroot=/opt/eldk/arm
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
bootcmd_net=run bootargs_nfs;tftpboot ${loadaddr} ${kernel}; bootm
bootcmd_mmc= for disk in 0 1 ; do mmc dev ${disk} ;for fs in fat ext2 ; do ${fs}load mmc ${disk}:1 10008000 /6q_bootscript && source 10008000 ; done ; done
bootcmd=run bootcmd_mmc
clearenv=sf probe 1 && sf erase 0xc0000 0x2000 && echo restored environment to factory default
upgradeu=for disk in 0 1 ; do mmc dev ${disk} ;for fs in fat ext2 ; do ${fs}load mmc ${disk}:1 10008000 /6q_upgrade && source 10008000 ; done ; done
ethact=FEC0
bootargs=console=ttymxc1,115200 root=/dev/mmcblk0p2 rootwait video=mxcfb0:dev=hdmi,1280x800M@60,if=RGB24 video=mxcfb1:dev=ldb,LDB-SVGA,if=RGB666
mmcargs=setenv bootargs console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw video=mxcfb0:dev=ldb,1024x600M@60,if=RGB666
stdin=serial
stdout=serial
stderr=serial
Environment size: 1129/8188 bytes
Same deploy "fsl-image-gui-nitrogen6x.sdcard":
Here is the other console log after I rename the file to 6q_bootscript (instead of 6x_bootscript)
LOG2:
Temperature:   69 C, calibration data 0x5774ed7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
SUCCESS
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
1523 bytes read
## Executing script at 10008000
Unknown command 'hdmidet' - try 'help'
------ no HDMI monitor
i2c - I2C sub-system
Usage:
i2c speed [speed] - show or set I2C bus speed
i2c md chip address[.0, .1, .2] [# of objects] - read from I2C device
i2c mm chip address[.0, .1, .2] - write to I2C device (auto-incrementing)
i2c mw chip address[.0, .1, .2] value [count] - write to I2C device (fill)
i2c nm chip address[.0, .1, .2] - write to I2C device (constant address)
i2c crc32 chip address[.0, .1, .2] count - compute CRC32 checksum
i2c probe - show devices on the I2C bus
i2c reset - re-init the I2C Controller
i2c loop chip address[.0, .1, .2] [# of objects] - looping read of device
Valid chip addresses: 00
Unknown command 'setexpr' - try 'help'
setenv - set environment variables
Usage:
setenv name value ...
    - set environment variable 'name' to 'value ...'
setenv name
    - delete environment variable 'name'
Usage:
setenv name
... The above message is repeated continuously... I quit with CTRL-C then..
reading uImage
3887912 bytes read
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35-1.1.0+g2dc5560
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3887848 Bytes =  3.7 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.35-1.1.0+g2dc5560 (dev@dev-virtual-machine) (gcc version 4.7.2 (GCC) ) #1 SMP PREEMPT Thu Jun 27 14:58:30 EDT 2013
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad Sabre-Lite Board
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.2
PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
Kernel command line: enable_wait_mode=off video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=ldb,1024x600M@60,if=RGB666 video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB666 video=mxcfb0:off vi
deo=mxcfb0:off video=mxcfb0:off video=mxcfb0:off video=mxcfb0:off video=mxcfb0:off video=mxcfb0:off video=mxcfb0:off video=mxcfb0:off video=mxcfb0:off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 640MB 256MB = 896MB total
Memory: 900528k/900528k available, 148048k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x8003a000   ( 200 kB)
      .text : 0x8003a000 - 0x806fe7b4   (6930 kB)
      .data : 0x80700000 - 0x8075a2c0   ( 361 kB)
       .bss : 0x8075a2e4 - 0x807a6584   ( 305 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=2
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole [ttymxc0] enabled
Console: colour dummy device 80x30
console [tty0] enabled, bootconsole disabled
OK, I finally got it working.
The old U-Boot was looking for 6q_bootscript instead of 6x_bootscript.
I had to update U-Boot on my Sabrelite board. I also had to clear the env variables. (command: env default -a && saveenv && boot)
More details here:
http://boundarydevices.com/6q_bootscript/
http://boundarydevices.com/switching-u-boot-versions-on-i-mx6/
http://boundarydevices.com/u-boot-on-i-mx6/
thanks
I went through the exact problems and output you got.
But I can't understand exactly what those 3 links you gave
say we should do to change the u-boot on BD-SL-i.MX6.
Can you be generous and be more specific on the exact steps you did?
i.e. To get through this final step of switching to 6x_bootscript?
I am also using Yocto "fsl-image-gui-nitrogen6x.sdcard" image to boot on
SABRE Lite Quad board (BD-SL-i.MX6)?
I am also confused on whether SD card root should be "root=/dev/mmcblk0p1"
or "root=/dev/mmcblk1p2".
Is this the only solution/work around possible on BD-SL-i.MX6 with this Yocto image?
Please clarify that in your steps.
Apparently Element14 is releasing boards with an odd configuration. From the output, I can see that:
  • The U-Boot version is based on 2009.08, and
  • The environment is still still configured for 6q_bootscript, and
  • The MAC address isn't programmed.
This U-Boot version is slightly in-compatible with the 6x_upgrade script generated by Yocto. It's possible to stick with this version, but you'll need to write a new boot script, and you won't get auto-detection of displays.
Just to clarify for everyone this is what I did to solve the problem above.
Thanks to EricNelson for help!
Here is a sequence of the actions to do in order on Ubuntu 13.04 host (Dylan Yocto):
1-- I used GParted to format a 4 GB SD card to one big fat32 file system partition.
2-- Mounted it as RW:
     $ sudo mount -t vfat -o rw /dev/sdb1 /home/aseema/Documents/my_sd_mnt
3-- Extracted the upgrade scripts from u-boot-2013-6-19.tar.gz tar ball
     into /home/aseema/extracted_u-boot-2013-6-19/
4-- Copied the files I had extracted above to the mounted fat SD card.
     $ cp /home/aseema/extracted_u-boot-2013-6-19/* /home/aseema/Documents/my_sd_mnt
5-- sudo umount /home/aseema/Documents/my_sd_mnt
     (Or eject the GUI way).
6-- To just verify, I unplugged the SD card and re-plugged to make sure
     the automatic mounting on Ubuntu 13.04 shows new files in there.
7-- I then plugged the SD card into the board and booted up to u-boot.
     Then I started running the Ubuntu commands below. Also shows
     the actual output I got (Note. if you are using microSD use "dev 1"
     else use "dev 0". I am using "dev 1" below.
MX6Q SABRELITE U-Boot > sf probe 1
2048 KiB SST25VF016B - 2MB at 0:1 is now current device
MX6Q SABRELITE U-Boot > mmc dev 1
MX6Q SABRELITE U-Boot > fatload mmc 1:1 0x10800000 u-boot.nitrogen6q
reading u-boot.nitrogen6q
338164 bytes read
MX6Q SABRELITE U-Boot > sf erase 0 0xc0000
Erasing SPI NOR flash 0x0 [0xc0000 bytes]
................................................................................................................................................................................................SUCCESS
MX6Q SABRELITE U-Boot > sf write 0x10800000 0x400 $filesize
Writing SPI NOR flash 0x400 [0x528f4 bytes] <- ram 0x10800000
.....SUCCESS
MX6Q SABRELITE U-Boot > sf read 0x12800000 0x400 $filesize
Reading SPI NOR flash 0x400 [0x528f4 bytes] -> ram 0x12800000
SUCCESS
MX6Q SABRELITE U-Boot > cmp.b 0x10800000 0x12800000 $filesize
Total of 338164 bytes were the same
MX6Q SABRELITE U-Boot > run clearenv
Erasing SPI NOR flash 0xc0000 [0x2000 bytes]
..SUCCESS
8-- Now "dd" the yocto SD image you tried before and boot as you did when
     when the problems happened.
i.e.
Now write out the new SD card image to the SD card.
$ sudo dd if=tmp/deploy/images/fsl-image-gui-nitrogen6x.sdcard of=/dev/sdb bs=1M
[sudo] password for aseema:
+++++++++++++++++++++++++++++++++OUTPUT+++++++++++++++++++++++++++++++++++++
864+0 records in
864+0 records out
905969664 bytes (906 MB) copied, 11.41 s, 79.4 MB/s
9--- After you eject the SD card make sure you get a Ubuntu popup saying it is OK
     to now remove it. If you don't get it there might be some corruption in the image.
     if so, try "dd" again. (This time) it should boot all the way.
More perspective here:
i.MX6x SABRE Lite SPI Flash Recovery
Hello, I followed the instructions from this page:
On my windows machine, I extracted the file 6q_upgrade-20121112.zip to a micro SD card.
Then I inserted this micro SD card in the sabre lite board.
Then, I connected my computer to the serial debug port at 115200 8N1.
At the prompt, I typed the command:
U-Boot> run upgradeu
... (then the UBoot update went through)
After the update I typed the command:
This is needed to clear the env variables.
After the reboot, UBoot was updated and was using the correct 6x_bootscript.
I put the micro SD card with Yocto and it booted perfectly.
I hope it helps.
ssinfod
Really annoying stuff happening on my end, and can't figure out what I did wrong. Here's what is up:
1) Completed first 3 tasks and successfully built an image for imx6q SabreLITE.
2) Insert formatted SD card with fat16/fat32/ext3/ext4 (tried all 4 file formats).
3) a) sudo dd if=fsl-image-gui-imx6qsabrelite.sdcard of=/dev/sdb1 bs=1M
    b) output:
        856+0 records in
        856+0 records out
        897581056 bytes (898 MB) copied, 124.273 s, 7.2 MB/s
4) try and access SD card...no contents, no file system, displaying weird files/filenames => file-space is corrupt.
Do I need to 'bit-bake' the image again, maybe smth went awry during build?
Tried a different SD card too, same issues.
I'm not sure how your sdcard is recognized on your linux distro. however, I *always* copy the image to /dev/sdb
I mean /dev/sdb ONLY not /dev/sdbX or /dev/sdb1
If you have a non formated sdcard, or a ext2/ext3/ext4/vfat it does not matter, because the *.sdcard image is partitioned.
it's not a bunch of files to be copied to a partition. It's have the partition table for the sdcards AND the partitions AND the files.
Could you, please, double check and let me know the result?
Yep, that "1" at the end of /dev/sdb was the culprit, removing that and writing just sudo dd if=fsl-image-gui-imx6qsabrelite.sdcard of=/dev/sdb bs=1M did the trick
Runing the image on the board gives following output:
perature:   49 C, calibration data 0x5894f87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
SUCCESS
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
Hit any key to stop autoboot:  0
MMC read: dev # 1, block # 2048, count 8192 ... 8192 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot 2009.08-dirty (Jan 17 2013 - 06:55:57)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Temperature:   48 C, calibration data 0x5894f87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
SUCCESS
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
What did i do wrong?
Hi Peter. Please, take a look on past comments on this doc (starting like on https://community.freescale.com/docs/DOC-94989#comment-5273) and see how you can ajust your board to load bootloader from sdcard.
from your log, your u-boot is 2009.08, the old one. You booting from your internal memory, not your sdcard.
Rightly so, u-boot is old, but have upgraded to 2013.06 via latest u-Boot production branch tar. However, I am still getting the same error. I have ran the setenv command from the u-Boot command line. If you think it's trying to boot from a different sd-card partition, please advise how I can alter that behavior.
NOTE: I've accessed the links from #comment-5273 beforehand, have made it through to make update of u-boot successfully, but not to change the primary boot partition...
the link I sent you only point to comments on this Doc.
anyway, I copy some reference:
I have never re-created the steps on sabre lite, so I´m not sure what you may try.
I just found another link that may help you
Hello, I followed your steps correctly,
now when i boot the SD image it says,
U-Boot 2013.01-rc1-00120-g7c28db0 (Nov 12 2012 - 09:15:04)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: Nitrogen6X
DRAM:  1 GiB
WARNING: Caches not enabled
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected SST25VF016B with page size 4 KiB, total 2 MiB
auto-detected panel wsvga-lvds
Display: wsvga-lvds (1024x600)
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
Warning: FEC using MAC address from net device
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part
No port device detected!
** Bad device size - sata 0 **
SATA device 1: unknown device
** Bad device sata 1 **
mmc0 is current device
reading /6x_bootscript
** Unable to read file /6x_bootscript **
** Unrecognized filesystem type **
MMC: no card present
mmc1(part 0) is current device
** Bad device mmc 1 **
6x_bootscript not found
serial console at 115200, 8N1
details at http://boundarydevices.com/6q_bootscript
U-Boot >
when i did, sudo dd if=fsl-image-gui-imx6qsabresd.sdcard of=/dev/sdb bs=1M
and check with windows The files visible on the SD card is only uImage
no 6x_bootscript is there.
Im using Yocto dora branch and fsl-image-gui
Hi Daiane,
Thank you for your excellent work.
Im following your tutorial.
I compiled the fsl-image-gui form dora branch.
did dd the fsl-image-gui-imx6qsabresd-20131101005105.rootfs.sdcard to SD card,
and boot form SD. got the following message.
Reset cause: POR
Board: Nitrogen6X
DRAM:  1 GiB
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
U-Boot >
It seems that 6x_bootscript is not placed on the SD card.
After reading all the comments it seems that after dd the sdcardimage to SD card there should be two files visible
(6x_bootscript, uImage), but in my case only uImage can be seen.
Hi Nil,
You need to set MACHINE="nitrogen6x" in your local.conf file for SABRE Lite or Nitrogen6x builds.
Note that in your image name above, you have a machine name of "imx6qsabresd"...
Again, you need MACHINE="nitrogen6x" in local.conf
Thanks Eric for information, Im working on that changing MACHINE variable, but unfortunately build failed because of the unavailability of
xserver-common-1.34.tar.gz . It appears that server is down for 2 days now. Do you have an idea about a way to resolve that except waiting for server up?
Im building fsl-image-gui on Dora branch
WARNING: Failed to fetch URL http://gpe.linuxtogo.org/download/source/xserver-common-1.34.tar.gz, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 4, no output
ERROR: Function failed: Fetcher failure for URL: 'http://gpe.linuxtogo.org/download/source/xserver-common-1.34.tar.gz'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/user/work/FreescaleYP/fsl-community-bsp/build/tmp/work/all-poky-linux/xserver-common/1.34-r8/temp/log.do_fetch.10417
ERROR: Task 6049 (/home/user/work/FreescaleYP/fsl-community-bsp/sources/meta-openembedded/meta-oe/recipes-graphics/xserver-common/xserver-common_1.34.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3618 tasks of which 3611 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
user@user-virtual-machine:~/work/FreescaleYP/fsl-community-bsp/build$
Seems that the linuxtogo site is down. As a workaround, find the tarball somewhere else, then move to downloads folder, from there do this
$ wget URL_OF_TAR_BALL -O xserver-common-1.34.tar.gz
$ > xserver-common-1.34.tar.gz.done
Then build again. I found a good tarball here
Leo
Thsnks Leo, it solved the problem.
I contacted OpenEmbedded admins and we now have this file in their mirror. This should be good for all users now.
%3CLINGO-SUB%20id%3D%22lingo-sub-1122965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH3%20id%3D%22toc-hId-1083465017%22%20id%3D%22toc-hId-2004417299%22%3EUpdate%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF1%E9%80%B1%E9%96%93%E5%89%8D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20repo%20sync%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--723989446%22%20id%3D%22toc-hId-196962836%22%3E%E7%94%BB%E5%83%8F%20-%20bitbake%E3%81%AE%E7%B5%90%E6%9E%9C%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebitbake%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AE%E4%BE%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Ebuild_mx6%2Ftmp%2Fdeploy%2Fimages%3A%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd-20130505174618.rootfs.ext3%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd-20130505174618.rootfs.sdcard%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd-20130505174618.rootfs.tar.bz2%3C%2FP%3E%0A%3CP%3EFSL%20-%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8GUI%20-%20IMX6QSABRESD-20130508162511.rootfs.ext3%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd-20130508162511.rootfs.sdcard%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd-20130508162511.rootfs.tar.bz2%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd.ext3%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd.sdcard%3C%2FP%3E%0A%3CP%3Efsl-image-gui-imx6qsabresd.tar.bz2%3C%2FP%3E%0A%3CP%3Emodules-3.0.35-1.1.0%2Byocto%2Bg0596856-r32.10-imx6qsabresd.tgz%3C%2FP%3E%0A%3CP%3EREADME_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt%3C%2FP%3E%0A%3CP%3Eu-boot.imx%20%E3%81%AE%3C%2FP%3E%0A%3CP%3Eu-boot-imx6qsabresd.imx%3C%2FP%3E%0A%3CP%3Eu-boot-imx6qsabresd-v2013.04-r3.imx*%3C%2FP%3E%0A%3CP%3EuImage%3C%2FP%3E%0A%3CP%3EuImage-3.0.35-r32.10-imx6qsabresd-20130505174618.bin%3C%2FP%3E%0A%3CP%3EuImage-imx6qsabresd.bin%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%AB%E6%85%A3%E3%82%8C%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%80%81%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E5%B8%B8%E3%81%AB%E6%9C%80%E6%96%B0%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E6%8C%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1763523387%22%20id%3D%22toc-hId--1610491627%22%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7sdcard%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%20%3CA%20href%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fmeta-fsl-arm%2Ftree%2Fclasses%2Fimage_types_fsl.bbclass%3Fh%3Ddylan%22%20title%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fmeta-fsl-arm%2Ftree%2Fclasses%2Fimage_types_fsl.bbclass%3Fh%3Ddylan%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-fsl-arm%20-%20Freescale%20ARM%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A1%E3%82%BF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%90%AB%E3%82%80%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E0%20%E3%81%8B%E3%82%89%20%26gt%3B%20IMAGE_ROOTFS_ALIGNMENT%3C%2FSTRONG%3E%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMAGE_ROOTFS_ALIGNMENT%20-%26gt%3B%20BOOT_SPACE%3C%2FSTRONG%3E%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%3C%2FP%3E%3CP%3E%3CSTRONG%3EBOOT_SPACE%20-%26gt%3B%20SDIMG_SIZE%3C%2FSTRONG%3E%20rootfs%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMAGE_OVERHEAD_FACTOR%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%85%83%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81U-boot%E3%81%AE%E5%88%9D%E6%9C%9F%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82uImage%E7%94%A8%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C1%E3%81%A4%E3%80%82rootfs%20%E7%94%A8%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%201%20%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E7%94%BB%E5%83%8F%E3%81%94%E3%81%A8%E3%81%AB%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9FSD%E3%82%AB%E3%83%BC%E3%83%89%E5%86%85%E3%81%AB%E7%A9%BA%E3%81%8D%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81IMAGE_OVERHEAD_FACTOR%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--43931076%22%20id%3D%22toc-hId-877021206%22%3E%E5%B1%95%E9%96%8B%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESD%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20dd%20if%3Dfsl-image-gui-imx6qsabresd.sdcard%20of%3D%2Fdev%2FsdX%20bs%3D1M%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%20%3CSTRONG%3Eext3%3C%2FSTRONG%3E%20rootfs%20%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20dd%20if%3Dfsl-image-gui-imx6qsabresd.ext3%20of%3D%2Fdev%2FsdX2%20bs%3D1M%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%20%3CSTRONG%3Etar.bz%3C%2FSTRONG%3E%20rootfs%20%E3%81%AE%E3%81%BF%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20mount%20%2Fdev%2FsdX2%20%2Fmnt%2Fcard%3C%2FP%3E%0A%3CP%3E%24%20sudo%20tar%20xf%20imagename-imx53qsb.tar.bz2%20-C%20%2Fmnt%2Fcard%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FSTRONG%3E%E3%81%AE%E3%81%BF%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20cp%20uImage-3.0.35-r32.10-imx6qsabresd-20130505174618.bin%20%2Fmedia%2FBoot%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eu-boot%3C%2FSTRONG%3E%E3%81%AE%E3%81%BF%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20dd%20if%3Du-boot-imx6qsabresd-v2012.10-r3.imx%20of%3D%2Fdev%2FsdX%20bs%3D512%20seek%3D2%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3EHDMI%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81u-boot%E7%92%B0%E5%A2%83%E3%81%AE%E5%BC%95%E6%95%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3Esetenv%20mmcargs%20%22setenv%20bootargs%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%24%7Bmmcroot%7D%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%22%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%20meta-fsl-arm%20%E3%81%AB%E3%82%88%E3%82%8B%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%9C%E3%82%8A%E6%96%B9%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E3%81%8A%E6%89%8B%E6%8C%81%E3%81%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%82%82%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81u-boot%20bootenv%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%93%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3Aroot%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3E%E3%83%9B%E3%83%BC%E3%83%A0%3C%2FA%3E%E3%81%AB%E7%A7%BB%E5%8B%95%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94959%22%20target%3D%22_blank%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%20%233%20-%20%E3%83%93%E3%83%AB%E3%83%89%E7%B5%90%E6%9E%9C%3C%2FA%3E%E3%81%AB%E9%80%B2%E3%82%80%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95045%22%20target%3D%22_blank%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%235%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FA%3E%E3%81%AB%E9%80%B2%E3%82%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EOpenEmbedded%E3%81%AE%E7%AE%A1%E7%90%86%E8%80%85%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BD%BC%E3%82%89%E3%81%AE%E3%83%9F%E3%83%A9%E3%83%BC%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E8%89%AF%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EThsnks%20Leo%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Elinuxtogo%E3%81%AE%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E5%88%A5%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%A7tarball%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20wget%20URL_OF_TAR_BALL%20-O%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Exserver-common-1.34.tar.gz%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%24%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%26gt%3B%3C%2FA%3E%20%3CSPAN%3Exserver-common-1.34.tar.gz.done%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E5%86%8D%E5%BA%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22http%3A%2F%2Fsourceforge.net%2Fprojects%2Fkaeilos%2Ffiles%2Frepo%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%3C%2FA%3E%E8%89%AF%E3%81%84tarball%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELeo%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AE%E5%A4%89%E6%9B%B4MACHINE%E5%A4%89%E6%95%B0%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%3C%2FP%3E%3CP%3Exserver-common-1.34.tar.gz%E3%80%82%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C2%E6%97%A5%E9%96%93%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%BE%85%E3%81%A4%E4%BB%A5%E5%A4%96%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFDora%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A7fsl-image-gui%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E----------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%3A%20URL%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%3C%2FA%3E%3CSPAN%3E%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E8%A1%8C%20%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%20%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%204%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%87%BA%E5%8A%9B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20URL%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20'%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%3C%2FA%3E%3CSPAN%3E'%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2Fhome%2Fuser%2Fwork%2FFreescaleYP%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fall-poky-linux%2Fxserver-common%2F1.34-r8%2Ftemp%2Flog.do_fetch.10417%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF6049(%2F%20home%20%2F%20user%20%2F%20work%20%2F%20Freescale%20YP%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-openembedded%20%2F%20meta-oe%20%2F%20recipes-graphics%20%2F%20xserver-common%20%2F%20xserver-common_1.34.bb%E3%80%81do_fetch)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%203618%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%203611%20%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E0%E5%80%8B%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fhome%2Fuser%2Fwork%2FFreescaleYP%2Ffsl-community-bsp%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-graphics%2Fxserver-common%2Fxserver-common_1.34.bb%2C%20do_fetch%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C1%E3%81%A4%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A2%E3%81%A4%E3%81%AEERROR%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E9%9D%9E%E3%82%BC%E3%83%AD%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Euser%40user-virtual-machine%3A~%2Fwork%2FFreescaleYP%2Ffsl-community-bsp%2Fbuild%24%3C%2FP%3E%3CP%3E----------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81local.conf%20%E3%81%AB%20MACHINE%3D%22nitrogen6x%22%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Nil%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESABRE%20Lite%20%E3%81%BE%E3%81%9F%E3%81%AF%20Nitrogen6x%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81local.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%20MACHINE%3D%22nitrogen6x%22%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%90%8D%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9E%E3%82%B7%E3%83%B3%E5%90%8D%E3%81%8C%20%22imx6qsabresd%22%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%8A%E4%BB%95%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Efsl-image-gui%20form%20dora%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%3C%2FSPAN%3E%E3%82%92%E3%81%BE%E3%81%A8%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3Efsl-image-gui-imx6qsabresd-20131101005105.rootfs.sdcard%3C%2FSTRONG%3E%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SD.%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88%202013.01-rc1-00120-g7c28db0(2012%E5%B9%B411%E6%9C%8812%E6%97%A5%20-%2009%3A15%3A04)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6Q%20rev1.2%20(792%20MHz)%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%E7%AA%92%E7%B4%A06X%3C%2FP%3E%3CP%3EDRAM%3A%201%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC%3AFSL_SDHC%3A0%E3%80%81FSL_SDHC%3A1%3C%2FP%3E%3CP%3ESF%3A%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%204%20KiB%E3%80%81%E5%90%88%E8%A8%88%202%20MiB%20%E3%81%A7%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FSST25VF016B%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E6%A4%9C%E5%87%BA%E3%83%91%E3%83%8D%E3%83%AB%20WSVGA-LVDS%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3Awsvga-lvds(1024x600)%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%E3%83%8D%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AEMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BFEC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A0%3C%2FP%3E%3CP%3EAHCI%200001.0300%2032%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%80%811%E3%83%9D%E3%83%BC%E3%83%88%E3%80%813%20Gbps%200x1%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A0SATA%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%82%B0%3ANCQ%E3%82%B9%E3%82%BF%E3%83%83%E3%82%B0PM%20LED%E3%81%AECLO%E3%81%AE%E3%81%BFPMP%E3%81%AEPIO%E3%82%B9%E3%83%A9%E3%83%A0%E9%83%A8%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%20sata%200%20**%3C%2FP%3E%3CP%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%20sata%200%20**%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESATA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%201%3A%20%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20SATA%201%20**%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20SATA%201%20**%3C%2FP%3E%3CP%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F6x_bootscript%3C%2FP%3E%3CP%3E**%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2F6x_bootscript%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FP%3E%3CP%3Eext2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%3C%2FP%3E%3CP%3E**%20%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E7%A8%AE%E9%A1%9E%20**%3C%2FP%3E%3CP%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc1(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E8%A1%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmc%201%20**%3C%2FP%3E%3CP%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmc%201%20**%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6x_bootscript%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20at%20115200%2C%208N1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2F6q_bootscript%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2F6q_bootscript%3C%2FA%3E%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF6x_bootscript%E3%81%8C%E7%BD%AE%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A0%E5%BE%8C%E3%80%81sdcardimage%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%ABdd%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%812%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E6x_bootscript%E3%80%81%20%3C%2FSPAN%3EuImage)%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFuImage%E3%81%97%E3%81%8B%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%3C%2FP%3E%3CP%3ESD%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88%202013.01-rc1-00120-g7c28db0(2012%E5%B9%B411%E6%9C%8812%E6%97%A5%20-%2009%3A15%3A04)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6Q%20rev1.2%20(792%20MHz)%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%E7%AA%92%E7%B4%A06X%3C%2FP%3E%3CP%3EDRAM%3A%201%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC%3AFSL_SDHC%3A0%E3%80%81FSL_SDHC%3A1%3C%2FP%3E%3CP%3ESF%3A%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%204%20KiB%E3%80%81%E5%90%88%E8%A8%88%202%20MiB%20%E3%81%A7%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FSST25VF016B%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E6%A4%9C%E5%87%BA%E3%83%91%E3%83%8D%E3%83%AB%20WSVGA-LVDS%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3Awsvga-lvds(1024x600)%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%E3%83%8D%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AEMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BFEC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A0%3C%2FP%3E%3CP%3EAHCI%200001.0300%2032%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%80%811%E3%83%9D%E3%83%BC%E3%83%88%E3%80%813%20Gbps%200x1%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A0SATA%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%82%B0%3ANCQ%E3%82%B9%E3%82%BF%E3%83%83%E3%82%B0PM%20LED%E3%81%AECLO%E3%81%AE%E3%81%BFPMP%E3%81%AEPIO%E3%82%B9%E3%83%A9%E3%83%A0%E9%83%A8%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%20sata%200%20**%3C%2FP%3E%3CP%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%20sata%200%20**%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESATA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%201%3A%20%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20SATA%201%20**%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20SATA%201%20**%3C%2FP%3E%3CP%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F6x_bootscript%3C%2FP%3E%3CP%3E**%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2F6x_bootscript%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FP%3E%3CP%3Eext2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%3C%2FP%3E%3CP%3E**%20%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E7%A8%AE%E9%A1%9E%20**%3C%2FP%3E%3CP%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc1(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E8%A1%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmc%201%20**%3C%2FP%3E%3CP%3EMMC%3A%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E8%89%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmc%201%20**%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6x_bootscript%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20at%20115200%2C%208N1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2F6q_bootscript%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2F6q_bootscript%3C%2FA%3E%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%82%84%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Esudo%20dd%20if%20%3D%20fsl-image-gui-imx6qsabresd.sdcard%20of%20%3D%20%2F%20dev%20%2F%20sdb%20bs%20%3D%201M%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EWindows%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20filesSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AFuImage%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%9D%E3%81%93%E3%81%AB%E3%81%AF6x_bootscript%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%A7%81%E3%81%AFYocto%20dora%20branch%E3%81%A8fsl-image-gui%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E9%80%81%E3%81%A3%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%81%BF%E3%82%92%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%80%81%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%8F%82%E7%85%A7%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2F6q_bootscript%2F%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2F6q_bootscript%2F%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fswitching-u-boot-versions-on-i-mx6%2F%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%20text-decoration%3A%20underline%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fswitching-u-boot-versions-on-i-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%A7%81%E3%81%AF%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%95%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E5%88%A5%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F335684%23335684%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F335684%23335684%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E7%84%B6%E3%81%AE%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81u-boot%E3%81%AF%E5%8F%A4%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%20%3CA%20href%3D%22http%3A%E2%80%8B%2F%E2%80%8B%2F%E2%80%8Bcommondatastorage.googleapis.com%2F%E2%80%8Bboundarydevices.com%2F%E2%80%8Bu-boot-production.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSTRONG%3E%E6%9C%80%E6%96%B0%E3%81%AEu-Boot%E3%83%97%E3%83%AD%E3%83%80%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81tar%3C%2FSTRONG%3E%3C%2FA%3E%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A62013.06%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%20%3CSTRONG%3E%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSTRONG%3E%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFu-Boot%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89%20%3CEM%3Esetenv%3C%2FEM%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%82%E3%81%97%E5%88%A5%E3%81%AE%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%E3%81%9D%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%E7%A7%81%E3%81%AF%E4%BA%8B%E5%89%8D%E3%81%AB%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%2294989%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94989%23comment-5273%22%20style%3D%22font-size%3A%2012.800000190734863px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3E%3CSTRONG%3E%23comment-5273%3C%2FSTRONG%3E%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%80%81u-boot%E3%81%AE%E6%9B%B4%E6%96%B0%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E9%81%8E%E5%8E%BB%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88(%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94989%23comment-5273%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94989%23comment-5273%3C%2FA%3E%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%96%8B%E5%A7%8B)%E3%82%92%E8%A6%8B%E3%81%A6%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%A2%E3%82%B8%E3%83%A3%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E3%80%81U-Boot%E3%81%AF%E5%8F%A4%E3%81%842009.08%E3%81%A7%E3%81%99%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%86%85%E9%83%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A49%C2%B0C%E3%80%81%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF0x5894f87d%20%3C%2FP%3E%3CP%3Emx6q%20pll1%3A792MHz%20%3C%2FP%3E%3CP%3Emx6q%20pll2%3A528MHz%E3%81%AE%20%3C%2FP%3E%3CP%3Emx6q%20pll3%3A480MHz%20%3C%2FP%3E%3CP%3Emx6q%20pll8%3A50MHz%E3%81%AE%20%3C%2FP%3E%3CP%3Eipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A66000000Hz%20%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Euart%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A80000000Hz%20%3C%2FP%3E%3CP%3Ecspi%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A60000000Hz%20%3C%2FP%3E%3CP%3Eahb%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%20%3C%2FP%3E%3CP%3E%E8%BB%B8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A264000000Hz%20%3C%2FP%3E%3CP%3Eemi_slow%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A29333333Hz%20%3C%2FP%3E%3CP%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A528000000Hz%20%3C%2FP%3E%3CP%3Eusdhc1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3Eusdhc2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3Eusdhc3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3Eusdhc4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3ENFC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A24000000Hz%20%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX6Q-SABRELITE%3A%5BPOR%5D%20%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AI2C%20%3C%2FP%3E%3CP%3EI2C%3A%E5%AF%BE%E5%BF%9C%20%3C%2FP%3E%3CP%3EDRAM%3A1%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%20%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200xc0000%20%5B0x2000%20%E3%83%90%E3%82%A4%E3%83%88%5D%20-%26gt%3B%20RAM%200x276009b8%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%20-%20%E4%B8%8D%E6%AD%A3%E3%81%AACRC%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E3%81%A7%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%A6%E3%83%88%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%3AIIM%E3%81%8B%E3%82%89MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%3A00%3A00%3A00%3A00%3A00%20%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A0%20%3C%2FP%3E%3CP%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3EMMC%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%E9%96%8B%E7%99%BA%231%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%232048%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%888192%20...8192%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3AOK%20%3C%2FP%3E%3CP%3Ebootm%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%BD%A2%E5%BC%8F%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%20%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88%202009.08-dirty(2013%E5%B9%B41%E6%9C%8817%E6%97%A5%20-%2006%3A55%3A57)%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AATO1.2(792MHz)%20%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A48%C2%B0C%E3%80%81%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF0x5894f87d%20%3C%2FP%3E%3CP%3Emx6q%20pll1%3A792MHz%20%3C%2FP%3E%3CP%3Emx6q%20pll2%3A528MHz%E3%81%AE%20%3C%2FP%3E%3CP%3Emx6q%20pll3%3A480MHz%20%3C%2FP%3E%3CP%3Emx6q%20pll8%3A50MHz%E3%81%AE%20%3C%2FP%3E%3CP%3Eipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A66000000Hz%20%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Euart%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A80000000Hz%20%3C%2FP%3E%3CP%3Ecspi%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A60000000Hz%20%3C%2FP%3E%3CP%3Eahb%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%20%3C%2FP%3E%3CP%3E%E8%BB%B8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A264000000Hz%20%3C%2FP%3E%3CP%3Eemi_slow%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A29333333Hz%20%3C%2FP%3E%3CP%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A528000000Hz%20%3C%2FP%3E%3CP%3Eusdhc1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3Eusdhc2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3Eusdhc3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3Eusdhc4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%20%3C%2FP%3E%3CP%3ENFC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A24000000Hz%20%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX6Q-SABRELITE%3A%5BPOR%5D%20%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AI2C%20%3C%2FP%3E%3CP%3EI2C%3A%E5%AF%BE%E5%BF%9C%20%3C%2FP%3E%3CP%3EDRAM%3A1%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%20%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200xc0000%20%5B0x2000%20%E3%83%90%E3%82%A4%E3%83%88%5D%20-%26gt%3B%20RAM%200x276009b8%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%20-%20%E4%B8%8D%E6%AD%A3%E3%81%AACRC%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E3%81%A7%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%A6%E3%83%88%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%3AIIM%E3%81%8B%E3%82%89MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%3A00%3A00%3A00%3A00%3A00%20%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A0%20%3C%2FP%3E%3CP%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3EMMC%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%E9%96%8B%E7%99%BA%231%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%232048%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%888192%20...8192%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3AOK%20%3C%2FP%3E%3CP%3Ebootm%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%BD%A2%E5%BC%8F%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%20%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BD%95%E3%82%92%E9%96%93%E9%81%95%E3%81%88%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%2Fdev%2Fsdb%20%E3%81%AE%E6%9C%AB%E5%B0%BE%E3%81%AB%E3%81%82%E3%82%8B%20%221%22%20%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%20%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.800000190734863px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Esudo%20dd%20if%3Dfsl-image-gui-imx6qsabrelite.sdcard%20of%3D%2Fdev%2Fsdb%3C%2FSTRONG%3E%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.800000190734863px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20bs%3D1M%20%3C%2FSTRONG%3E%20%E3%81%A8%E6%9B%B8%E3%81%8F%E3%81%A0%E3%81%91%E3%81%A7%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E6%9C%AC%E5%BD%93%E3%81%AB%E8%BF%B7%E6%83%91%E3%81%AA%E3%81%93%E3%81%A8%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E7%A7%81%E3%81%8C%E4%BD%95%E3%82%92%E9%96%93%E9%81%95%E3%81%88%E3%81%9F%E3%81%AE%E3%81%8B%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1)%20%E6%9C%80%E5%88%9D%E3%81%AE%203%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%80%81imx6q%20SabreLITE%20%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E2)fat16%20%2F%20fat32%20%2F%20ext3%20%2F%20ext4%E3%81%A7%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%9FSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99(4%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%3C%2FP%3E%3CP%3E3)%20a)%20sudo%20dd%20if%3Dfsl-image-gui-imx6qsabrelite.sdcard%20of%3D%2Fdev%2Fsdb1%20bs%3D1M%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Eb)%20%E5%87%BA%E5%8A%9B%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E856%2B0%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E856%2B0%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E5%87%BA%E5%8A%9B%3C%2FP%3E%3CP%3E897581056%E3%83%90%E3%82%A4%E3%83%88%20(898%20MB)%20%E3%82%B3%E3%83%94%E3%83%BC%E3%80%81124.273%20%E7%A7%92%E3%80%817.2%20MB%2F%E7%A7%92%3C%2FP%3E%3CP%3E4)SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AA%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AA%E3%81%97%E3%80%81%E5%A5%87%E5%A6%99%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%3D%26gt%3B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%86%8D%E5%BA%A6%E3%80%8C%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%80%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%ABsmth%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%82%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fswitching-u-boot-versions-on-i-mx6%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fswitching-u-boot-versions-on-i-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEWindows%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB6q_upgrade-20121112.zip%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%82%92%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%9D%E3%83%BC%E3%83%88(115200%208N1)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EU-Boot%20%26gt%3B%20upgrade%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%20%3CSTRONG%3E%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E...(%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81UBoot%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E5%BE%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CSTRONG%3Eenv%20default%20-a%20%26amp%3B%26amp%3B%20saveenv%20%26amp%3B%26amp%3B%20boot%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E5%86%8D%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%80%81UBoot%20%E3%81%AF%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%846x_bootscript%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92Yocto%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%8C%E7%92%A7%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Essinfod%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%81%AB%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E4%B8%8A%E8%A8%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FEricNelson%22%20target%3D%22_blank%22%3EEricNelson%3C%2FA%3E%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EUbuntu%2013.04%E3%83%9B%E3%82%B9%E3%83%88(Dylan%20Yocto)%E3%81%A7%E9%A0%86%E7%95%AA%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E4%B8%80%E9%80%A3%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E1%20--%20GParted%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%814%20GB%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%921%E3%81%A4%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AAfat32%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E2-RW%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%24%20sudo%20mount%20-t%20vfat%20-o%20rw%20%2Fdev%2Fsdb1%20%2Fhome%2Faseema%2FDocuments%2Fmy_sd_mnt%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E3--%20%3CA%20href%3D%22http%3A%2F%2Fcommondatastorage.googleapis.com%2Fboundarydevices.com%2Fu-boot-2013-6-19.tar.gz%22%20style%3D%22color%3A%20%23293f4c%3B%20font-family%3A%20Georgia%2C%20'Times%20New%20Roman'%2C%20Times%2C%20serif%3B%20font-size%3A%2016px%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eu-boot-2013-6-19.tar.g%3C%2FA%3Ez%20tar%20%E3%83%9C%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%2Fhome%2Faseema%2Fextracted_u-boot-2013-6-19%2F%3C%2FSPAN%3E%E3%81%B8%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E4-%E4%B8%8A%E8%A8%98%E3%81%A7%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9FfatSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%24%20cp%20%2Fhome%2Faseema%2Fextracted_u-boot-2013-6-19%2F*%20%2Fhome%2Faseema%2FDocuments%2Fmy_sd_mnt%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E5--%20sudo%20umount%20%2Fhome%2Faseema%2FDocuments%2Fmy_sd_mnt%20%3CBR%20%2F%3E(%E3%81%BE%E3%81%9F%E3%81%AFGUI%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%92%E5%8F%96%E3%82%8A%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E6-%E7%A2%BA%E8%AA%8D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%8A%9C%E3%81%8D%E5%B7%AE%E3%81%97%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EUbuntu%2013.04%E3%81%B8%E3%81%AE%E8%87%AA%E5%8B%95%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20class%3D%22gmail_extra%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E7-%E6%AC%A1%E3%81%AB%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81u-boot%E3%81%BE%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20class%3D%22gmail_extra%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEUbuntu%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%B7%E3%83%A7%E3%83%BC%3C%2FP%3E%3CP%20class%3D%22gmail_extra%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%A7%81%E3%81%8C%E5%BE%97%E3%81%9F%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%87%BA%E5%8A%9B(%E6%B3%A8%E3%80%82microSD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%8Cdev%201%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%20class%3D%22gmail_extra%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20%22dev%200%22%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%80%8Cdev%201%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22gmail_extra%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22gmail_extra%22%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U-Boot%20%26gt%3B%20SF%E3%83%97%E3%83%AD%E3%83%BC%E3%83%961%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%3C%2FP%3E%3CP%3E2048%20KiB%20SST25VF016B%20-%202MB%20at%200%3A1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%88%20%26gt%3B%20MMC%20DEV1%3C%2FP%3E%3CP%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U-Boot%20%26gt%3B%20%E8%84%82%E8%82%AA%E8%B2%A0%E8%8D%B7%20MMC%201%3A1%200x10800000%20U-BOOT.NITROGEN6Q%3C%2FP%3E%3CP%3Eu-boot.nitrogen6q%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E338164%E3%83%90%E3%82%A4%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%20%26gt%3B%20SF%20%E6%B6%88%E5%8E%BB%200%200xc0000%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200x0%20%E3%81%AE%E6%B6%88%E5%8E%BB%20%5B0xc0000%20%E3%83%90%E3%82%A4%E3%83%88%5D%3C%2FP%3E%3CP%3E................................................................................................................................................................................................%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U-Boot%20%26gt%3B%20SF%20%E3%83%A9%E3%82%A4%E3%83%880x10800000%200x400%20%24filesize%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200x400%20%5B0x528f4%20%E3%83%90%E3%82%A4%E3%83%88%5D%20%26lt%3B-%20RAM%200x10800000%20%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3E.....%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U-Boot%20%26gt%3B%20SF%200x12800000%200x400%20%24filesize%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200x400%20%5B0x528f4%20%E3%83%90%E3%82%A4%E3%83%88%5D%20-%26gt%3B%20RAM%200x12800000%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%20%26gt%3B%20CMP.B%200x10800000%200x12800000%20%24filesize%3C%2FP%3E%3CP%3E%E5%90%88%E8%A8%88%20338164%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U-Boot%20%26gt%3B%20CLEARENV%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%3C%2FP%3E%3CP%3E2048%20KiB%20SST25VF016B%20-%202MB%20at%200%3A1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200xc0000%20%5B0x2000%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E6%B6%88%E5%8E%BB%5D%3C%2FP%3E%3CP%3E..%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AB%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%81%9F%E7%92%B0%E5%A2%83%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E8%20-%20%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AB%E8%A9%A6%E3%81%97%E3%81%9Fyocto%20SD%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%80%8Cdd%E3%80%8D%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%A8%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.e.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2016px%3B%20font-family%3A%20Arial%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84SD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%230000ff%3B%22%3E%24%20sudo%20dd%20if%3Dtmp%2Fdeploy%2Fimages%2Ffsl-image-gui-nitrogen6x.sdcard%20of%3D%2Fdev%2Fsdb%20bs%3D1M%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%230000ff%3B%22%3E%5Bsudo%5D%20aseema%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2300ff00%3B%20background-color%3A%20%23ffffff%3B%22%3E%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%E5%87%BA%E5%8A%9B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2300ff00%3B%20background-color%3A%20%23ffffff%3B%22%3E864%2B0%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2300ff00%3B%20background-color%3A%20%23ffffff%3B%22%3E864%2B0%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E5%87%BA%E5%8A%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22margin-bottom%3A%203pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2300ff00%3B%20background-color%3A%20%23ffffff%3B%22%3E905969664%E3%83%90%E3%82%A4%E3%83%88%20(906%20MB)%20%E3%82%B3%E3%83%94%E3%83%BC%E3%80%8111.41%20%E7%A7%92%E3%80%8179.4%20MB%2F%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2300ff00%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20Arial%3B%22%3E%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2300ff00%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20Arial%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E9---SD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E3%82%8A%E5%87%BA%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86Ubuntu%E3%81%AE%E3%83%9D%E3%83%83%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%80%8Cdd%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E(%E4%BB%8A%E5%9B%9E%E3%81%AF)%E5%AE%8C%E5%85%A8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E8%A6%96%E7%82%B9%3A%3C%2FP%3E%3CH1%20class%3D%22with-breadcrumbs%20pagetitle%22%20style%3D%22font-weight%3A%20normal%3B%20color%3A%20%23000000%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%20id%3D%22toc-hId-382400499%22%20id%3D%22toc-hId--1631497835%22%3E%3CSPAN%20class%3D%22with-breadcrumbs%22%3E%3CA%20href%3D%22http%3A%2F%2Feewiki.net%2Fdisplay%2Flinuxonarm%2Fi.MX6x%2BSABRE%2BLite%2BSPI%2BFlash%2BRecovery%22%20style%3D%22color%3A%20%23000000%3B%20border-bottom-color%3A%20%23000000%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX6x%20SABRE%20Lite%20SPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%3C%2FA%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CA%20href%3D%22http%3A%2F%2Feewiki.net%2Fdisplay%2Flinuxonarm%2Fi.MX6x%2BSABRE%2BLite%2BSPI%2BFlash%2BRecovery%23i.MX6xSABRELiteSPIFlashRecovery-Upgradefactoryv2009.08-%26gt%3Bfactoryv2013.04%22%20style%3D%22color%3A%20%23326ca6%3B%20text-decoration%3A%20underline%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%AF%E3%83%88%E3%83%AA%E3%83%BCv2009.08%20-%26gt%3B%E3%83%95%E3%82%A1%E3%82%AF%E3%83%88%E3%83%AA%E3%83%BCv2013.04%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%86%E3%82%84%E3%82%89Element14%E3%81%AF%E5%A5%87%E5%A6%99%E3%81%AA%E6%A7%8B%E6%88%90%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%81%8B%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EU-Boot%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%202009.08%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%92%B0%E5%A2%83%E3%81%AF%E3%81%BE%E3%81%A0%20%3CTT%3E6q_bootscript%3C%2FTT%3E%20%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EMAC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%93%E3%81%AE%20U-Boot%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81Yocto%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20%3CTT%3E6x_upgrade%3C%2FTT%3E%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A8%E5%B0%91%E3%81%97%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E3%81%84%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E6%9B%B8%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E8%87%AA%E5%8B%95%E6%A4%9C%E5%87%BA%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%BE%97%E3%81%9F%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%A8%E5%87%BA%E5%8A%9B%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%B8%8E%E3%81%88%E3%81%9F3%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E4%BD%95%E3%81%AA%E3%81%AE%E3%81%8B%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EBD-SL-i.MX6%3C%2FSPAN%3E%E3%81%AEu-boot%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E5%AF%9B%E5%A4%A7%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E6%AD%A3%E7%A2%BA%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%88%E3%82%8A%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%816x_bootscript%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82Yocto%E3%81%AE%E3%80%8C%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Efsl-image-gui-nitrogen6x.sdcard%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%8D%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3ESABRE%20Lite%E3%82%AF%E3%82%A2%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89(BD-SL-i.MX6)%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%82%92%E3%80%8Croot%20%3D%20%2F%20dev%20%2F%20mmcblk0p1%E3%80%8D%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Eroot%3D%2Fdev%2Fmmcblk1p2%3C%2FSPAN%3E%E3%80%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%20Yocto%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20BD-SL-i.MX6%3C%2FSPAN%3E%20%E3%81%A7%E5%8F%AF%E8%83%BD%E3%81%AA%E5%94%AF%E4%B8%80%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%2F%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%9D%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E6%89%8B%E9%A0%86%E3%81%A7%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EOK%E3%80%81%E3%81%A4%E3%81%84%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A4%E3%81%84U-Boot%E3%81%AF%E3%80%816x_bootscript%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F6q_bootscript%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESabrelite%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEU-Boot%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20env%20default%20-a%20%26amp%3B%20saveenv%20%26amp%3B%20boot)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2F6q_bootscript%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2F6q_bootscript%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fswitching-u-boot-versions-on-i-mx6%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fswitching-u-boot-versions-on-i-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%90%8C%E3%81%98%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Efsl-image-gui-nitrogen6x.sdcard%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%22%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92(6x_bootscript%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E)6q_bootscript%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELOG2%20%E3%81%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08%20(2012%E5%B9%B48%E6%9C%8816%E6%97%A5%20-%2010%3A06%3A42)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX%206%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%200.0V%E3%80%81792MHz%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A69%C2%B0C%E3%80%81%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF0x5774ed7d%3C%2FP%3E%3CP%3Emx6q%20pll1%3A792MHz%3C%2FP%3E%3CP%3Emx6q%20pll2%3A528MHz%E3%81%AE%3C%2FP%3E%3CP%3Emx6q%20pll3%3A480MHz%3C%2FP%3E%3CP%3Emx6q%20pll8%3A50MHz%E3%81%AE%3C%2FP%3E%3CP%3Eipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A66000000Hz%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FP%3E%3CP%3Euart%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A80000000Hz%3C%2FP%3E%3CP%3Ecspi%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A60000000Hz%3C%2FP%3E%3CP%3Eahb%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%3C%2FP%3E%3CP%3E%E8%BB%B8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A264000000Hz%3C%2FP%3E%3CP%3Eemi_slow%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A29333333Hz%3C%2FP%3E%3CP%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A528000000Hz%3C%2FP%3E%3CP%3Eusdhc1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3ENFC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A24000000Hz%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX6Q-SABRELITE%3A%5BPOR%5D%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AI2C%3C%2FP%3E%3CP%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EDRAM%3A1%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200xc0000%20%5B0x2000%20%E3%83%90%E3%82%A4%E3%83%88%5D%20-%26gt%3B%20RAM%200x276009b8%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%3AIIM%E3%81%8B%E3%82%89MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%3A00%3A00%3A00%3A00%3A00%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A3%202%201%200%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E9%9B%BB%E5%9C%A7%E9%81%B8%E6%8A%9E%E3%81%AB%E5%8F%8D%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3Emmc0(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EMMC%3A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B70x1%E3%81%8C%E6%9C%80%E5%A4%A7(0x0)%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200%20%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E8%84%82%E8%82%AA%E8%B2%A0%E8%8D%B7%E3%81%AB%20mmc%200%3A1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FP%3E%3CP%3E**%20%E4%B8%8D%E6%AD%A3%E3%81%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%20**%3C%2FP%3E%3CP%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%2F6q_bootscript%20%E3%82%92%E8%AA%AD%E3%82%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1523%E3%83%90%E3%82%A4%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%23%23%2010008000%20%E3%81%A7%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'hdmidet'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E------%20HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3Ei2c%20-%20I2C%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3A%3C%2FP%3E%3CP%3Ei2c%20speed%20%5Bspeed%5D%20-%20I2C%E3%83%90%E3%82%B9%E9%80%9F%E5%BA%A6%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3EI2C%20MD%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B.0%E3%80%81.1%2C.2%5D%5B%23%20of%20objects%5D%20-%20I2C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3EI2C%20MM%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B.0%E3%80%81.1%2C.2%5D-%20I2C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF(%E8%87%AA%E5%8B%95%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88)%3C%2FP%3E%3CP%3EI2C%20MW%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B.0%E3%80%81.1%2C.2%5Dvalue%20%5Bcount%5D%20-%20I2C%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20(fill)%3C%2FP%3E%3CP%3EI2C%20NM%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B.0%E3%80%81.1%2C.2%5D-%20I2C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF(%E5%AE%9A%E6%95%B0%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9)%3C%2FP%3E%3CP%3EI2C%20CRC32%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B.0%E3%80%81.1%2C.2%5Dcount%20-%20CRC32%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%AE%E8%A8%88%E7%AE%97%3C%2FP%3E%3CP%3Ei2c%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20-%20I2C%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FP%3E%3CP%3Ei2c%20reset%20-%20I2C%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EI2C%E3%83%AB%E3%83%BC%E3%83%97%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B.0%E3%80%81.1%2C.2%5D%5B%23%20of%20objects%5D%20-%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%97%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A00%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A00%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%81%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A00%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3Esetenv%20-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3A%3C%2FP%3E%3CP%3Esetenv%20%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AE%E5%80%A4%20...%3C%2FP%3E%3CP%3E-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%20'name'%20%E3%82%92%20'value%20...'%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20%E5%90%8D%3C%2FP%3E%3CP%3E-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%20'name'%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3Esetenv%20-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3A%3C%2FP%3E%3CP%3Esetenv%20%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AE%E5%80%A4%20...%3C%2FP%3E%3CP%3E-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%20'name'%20%E3%82%92%20'value%20...'%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20%E5%90%8D%3C%2FP%3E%3CP%3E-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%20'name'%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20'setexpr'%20-%20'help'%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3Esetenv%20-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E...%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99...%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81CTRL-C%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EuImage%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3887912%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%23%23%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%2010800000%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%90%8D%3A%20linux-3.0.35-1.1.0%2Bg2dc5560%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%82%BF%E3%82%A4%E3%83%97%3A%20ARM%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%E9%9D%9E%E5%9C%A7%E7%B8%AE)%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%3A3887848%E3%83%90%E3%82%A4%E3%83%88%3D%203.7%20MB%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10008000%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A10008000%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EOK%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E8%A7%A3%E5%87%8D...%E5%AE%8C%E4%BA%86%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35-1.1.0%20%2B%20g2dc5560(dev%40dev%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%B7%E3%83%B3)(gcc%20version%204.7.2%20(GCC)%20)%20%231%20SMP%20PREEMPT%20Thu%20Jun%2027%2014%3A58%3A30%20EDT%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B7%E3%83%B3%3AFreescale%20i.MX%206Quad%20Sabre-Lite%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3ECPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A227328%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20enable_wait_mode%3Doff%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dlcd%2CCLAA-WVGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Aoff%20vi%3C%2FP%3E%3CP%3Edeo%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb0%3Aoff%3C%2FP%3E%3CP%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A640MB%20256MB%20%3D%20%E5%90%88%E8%A8%88896MB%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A900528k%20%2F%20900528k%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%81148048k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E.init%3A%200x80008000%20-%200x8003a000%20(%20200%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003a000%20-%200x806fe7b4%26nbsp%3B%26nbsp%3B%20(6930%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80700000%20-%200x8075a2c0%20(%20361%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x8075a2e4%20-%200x807a6584%26nbsp%3B%26nbsp%3B%20(%20305%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Earm_max_freq%3D2%3C%2FP%3E%3CP%3EMMIO%200x21e8000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Btty0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Enitrogen6x%3C%2FSPAN%3E%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%82%92%E4%BD%9C%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Efsl-image-gui-nitrogen6x.sdcard%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E5%8F%82%E7%85%A7)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E5%90%8D%E3%81%AF%E3%80%8C%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EBoot%20nitrog%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%816x_bootscript%E3%80%81%20%3C%2FSPAN%3EuImage%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUBoot%E3%81%8C%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%83%AD%E3%82%B0%E3%81%A7%E3%80%816x_bootscript%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20%3CSTRONG%3E6q_bootscript%3C%2FSTRONG%3E%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%20%3CSTRONG%3E%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(%E5%90%8D%E5%89%8D%E3%81%AEQ%20verus%20x)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A8%E9%96%A2%E4%BF%82%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3Fx%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92q%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E5%88%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELOG1%20%E3%81%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08%20(2012%E5%B9%B48%E6%9C%8816%E6%97%A5%20-%2010%3A06%3A42)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX%206%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%200.0V%E3%80%81792MHz%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A49%C2%B0C%E3%80%81%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF0x5774ed7d%3C%2FP%3E%3CP%3Emx6q%20pll1%3A792MHz%3C%2FP%3E%3CP%3Emx6q%20pll2%3A528MHz%E3%81%AE%3C%2FP%3E%3CP%3Emx6q%20pll3%3A480MHz%3C%2FP%3E%3CP%3Emx6q%20pll8%3A50MHz%E3%81%AE%3C%2FP%3E%3CP%3Eipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A66000000Hz%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FP%3E%3CP%3Euart%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A80000000Hz%3C%2FP%3E%3CP%3Ecspi%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A60000000Hz%3C%2FP%3E%3CP%3Eahb%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%3C%2FP%3E%3CP%3E%E8%BB%B8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A264000000Hz%3C%2FP%3E%3CP%3Eemi_slow%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A29333333Hz%3C%2FP%3E%3CP%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A528000000Hz%3C%2FP%3E%3CP%3Eusdhc1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3ENFC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A24000000Hz%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX6Q-SABRELITE%3A%5BPOR%5D%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AI2C%3C%2FP%3E%3CP%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EDRAM%3A1%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200xc0000%20%5B0x2000%20%E3%83%90%E3%82%A4%E3%83%88%5D%20-%26gt%3B%20RAM%200x276009b8%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%3AIIM%E3%81%8B%E3%82%89MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%3A00%3A00%3A00%3A00%3A00%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A3%202%201%200%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E9%9B%BB%E5%9C%A7%E9%81%B8%E6%8A%9E%E3%81%AB%E5%8F%8D%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmc0(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMMC%3A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B70x1%E3%81%8C%E6%9C%80%E5%A4%A7(0x0)%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200%20%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20%E8%84%82%E8%82%AA%E8%B2%A0%E8%8D%B7%E3%81%AB%20mmc%200%3A1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20%E4%B8%8D%E6%AD%A3%E3%81%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2F6q_bootscript%20%E3%82%92%E8%AA%AD%E3%82%80%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20mmc%201%3A1%20%E3%81%8B%E3%82%89%20%22%2F6q_bootscript%22%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmc%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%201%3A1%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F6q_bootscript%22%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%20(xxb1)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eext2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20Bad%20ext2%20partition%20or%20disk%20-%20mmc%201%3A1%20**%20(Bad%20ext2%20partition%20or%20disk%20-%20mmc%201%3A1%20)%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U-Boot%20%26gt%3B%20%3CSTRONG%3EPPRRIINNTTEENVV%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%3D3%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%3D115200%3C%2FP%3E%3CP%3Eipaddr%3D192.168.1.103%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BCIP%20%3D%20192.168.1.101%3C%2FP%3E%3CP%3Enetmask%3D255.255.255.0%3C%2FP%3E%3CP%3Eloadaddr%3D0x10800000%3C%2FP%3E%3CP%3Erd_loadaddr%3D0x11000000%3C%2FP%3E%3CP%3Enetdev%3Deth0%3C%2FP%3E%3CP%3Eethprime%3DFEC0%3C%2FP%3E%3CP%3Euboot%3Du-boot.bin%3C%2FP%3E%3CP%3Ekernel%3DuImage%3C%2FP%3E%3CP%3Enfsroot%3D%2Fopt%2Feldk%2Farm%3C%2FP%3E%3CP%3Ebootargs_nfs%3Dsetenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%24%7Bserverip%7D%3A%24%7Bnfsroot%7D%2Cv3%2Ctcp%3C%2FP%3E%3CP%3Ebootcmd_net%3D%E5%AE%9F%E8%A1%8Cbootargs_nfs%3Btftpboot%20%24%7Bloadaddr%7D%20%24%7Bkernel%7D%3Bbootm%E3%81%AE%3C%2FP%3E%3CP%3Ebootcmd_mmc%3D%200%201%20%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%AE%E5%A0%B4%E5%90%88%20%3BMMC%E9%96%8B%E7%99%BA%20%24%7Bdisk%7D%20%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%84%82%E8%82%AAExt2%E3%81%AEFS%E3%81%AE%E5%A0%B4%E5%90%88%3B%20%24%7Bfs%7D%E8%B2%A0%E8%8D%B7MMC%20%24%7Bdisk%7D%3A1%2010008000%20%2F6q_bootscript%20%26amp%3B%20Source%2010008000%3B%E5%AE%8C%E6%88%90%E3%81%A7%E3%81%99%3B%E5%AE%8C%E6%88%90%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Ebootcmd%3D%E5%AE%9F%E8%A1%8Cbootcmd_mmc%3C%2FP%3E%3CP%3Eclearenv%3Dsf%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%201%20%26amp%3B%26amp%3B%20sf%20%E6%B6%88%E5%8E%BB%200xc0000%200x2000%20%26amp%3B%20%E3%82%A8%E3%82%B3%E3%83%BC%20%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AB%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%81%9F%E7%92%B0%E5%A2%83%3C%2FP%3E%3CP%3Eupgradeu%3D0%201%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E7%94%A8%3BMMC%E9%96%8B%E7%99%BA%20%24%7Bdisk%7D%20%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%84%82%E8%82%AAExt2%E3%81%AEFS%E3%81%AE%E5%A0%B4%E5%90%88%3B%20%24%7Bfs%7D%E8%B2%A0%E8%8D%B7MMC%20%24%7Bdisk%7D%3A1%2010008000%20%2F6q_upgrade%20%26amp%3B%20Source%2010008000%3B%E5%AE%8C%E6%88%90%E3%81%A7%E3%81%99%3B%E5%AE%8C%E6%88%90%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eethact%3DFEC0%3C%2FP%3E%3CP%3Ebootargs%3Dconsole%3Dttymxc1%2C115200%20root%3D%2Fdev%2Fmmcblk0p2%20rootwait%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1280x800M%4060%2Cif%3DRGB24%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB666%3C%2FP%3E%3CP%3Emmcargs%3Dsetenv%20bootargs%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p2%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%3C%2FP%3E%3CP%3Estdin%3Dserial%3C%2FP%3E%3CP%3Estdout%3D%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3Estderr%3Dserial%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%92%B0%E5%A2%83%E3%82%B5%E3%82%A4%E3%82%BA%3A%201129%2F8188%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3Asmileysilly%3A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E3%81%BB%E3%81%A9%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%881%E3%81%A0%E3%81%91%E3%81%8C%E7%A7%81%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%99!%3A-P)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81LVDS0%201024x600%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEmmcargs%E5%A4%89%E6%95%B0%E3%81%AE%E5%88%A5%E3%81%AE%E5%8F%AF%E8%83%BD%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Esetenv%20mmcargs%20'setenv%20bootargs%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p2%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E'%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EBye.%3C%2FSPAN%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%BB%E3%82%A4%E3%83%96%E3%83%A9%E3%82%A4%E3%83%88%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F335684%23335684%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F335684%23335684%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESabrelite%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%2F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AA%E3%81%A9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%A4%9A%E3%81%8F%E3%81%AE%E8%89%AF%E3%81%84%E6%83%85%E5%A0%B1%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81meta-fsl-arm%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81Nitrogen%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Enitrogen6x%E3%83%9E%E3%82%B7%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%80%81%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BB%8A%E6%97%A5%E9%81%85%E3%81%8F%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENitrogen6x%E3%81%A8SabreLITE%E3%81%AF%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81qsabrelite%E3%81%A7qsabresd%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EBye!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%BC%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%E3%81%AF%E3%81%84%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99!%E3%80%8C%3D%E3%80%8D%E3%81%AF%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%A2%E3%83%B3%E3%83%89%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99!%E3%81%94%E3%82%81%E3%82%93%E3%81%AA%E3%81%95%E3%81%84%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%8Cfsl-image-gui-imx6qsabresd.sdcard%3C%2FSPAN%3E%E3%80%8D%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E7%A7%81%E3%81%AESabrelite%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E5%83%8D%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Esudo%20dd%20if%3Dfsl-image-gui-imx6qsabresd.sdcard%20of%3D%2Fdev%2Fsdb%20bs%3D1M%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3ESabrelite%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08%20(2012%E5%B9%B48%E6%9C%8816%E6%97%A5%20-%2010%3A06%3A42)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX%206%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%200.0V%E3%80%81792MHz%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A39%C2%B0C%E3%80%81%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF0x5774ed7d%3C%2FP%3E%3CP%3Emx6q%20pll1%3A792MHz%3C%2FP%3E%3CP%3Emx6q%20pll2%3A528MHz%E3%81%AE%3C%2FP%3E%3CP%3Emx6q%20pll3%3A480MHz%3C%2FP%3E%3CP%3Emx6q%20pll8%3A50MHz%E3%81%AE%3C%2FP%3E%3CP%3Eipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A66000000Hz%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FP%3E%3CP%3Euart%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A80000000Hz%3C%2FP%3E%3CP%3Ecspi%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A60000000Hz%3C%2FP%3E%3CP%3Eahb%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%3C%2FP%3E%3CP%3E%E8%BB%B8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A264000000Hz%3C%2FP%3E%3CP%3Eemi_slow%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A29333333Hz%3C%2FP%3E%3CP%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A528000000Hz%3C%2FP%3E%3CP%3Eusdhc1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3Eusdhc4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A200000000Hz%3C%2FP%3E%3CP%3ENFC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A24000000Hz%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX6Q-SABRELITE%3A%5BPOR%5D%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AI2C%3C%2FP%3E%3CP%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EDRAM%3A1%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%3C%2FP%3E%3CP%3EJEDEC%20ID%3A%200xbf%3A0x25%3A0x41%3C%2FP%3E%3CP%3ESPI%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%200xc0000%20%5B0x2000%20%E3%83%90%E3%82%A4%E3%83%88%5D%20-%26gt%3B%20RAM%200x276009b8%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%20-%20%E4%B8%8D%E6%AD%A3%E3%81%AACRC%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%3AIIM%E3%81%8B%E3%82%89MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%3A00%3A00%3A00%3A00%3A00%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A3%202%201%200%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E9%9B%BB%E5%9C%A7%E9%81%B8%E6%8A%9E%E3%81%AB%E5%8F%8D%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmc0(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMMC%3A%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B70x1%E3%81%8C%E6%9C%80%E5%A4%A7(0x0)%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200%20%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20%E8%84%82%E8%82%AA%E8%B2%A0%E8%8D%B7%E3%81%AB%20mmc%200%3A1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20%E4%B8%8D%E6%AD%A3%E3%81%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2F6q_bootscript%20%E3%82%92%E8%AA%AD%E3%82%80%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20mmc%201%3A1%20%E3%81%8B%E3%82%89%20%22%2F6q_bootscript%22%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmc%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%201%3A1%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2F6q_bootscript%22%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%20(xxb1)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eext2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E**%20Bad%20ext2%20partition%20or%20disk%20-%20mmc%201%3A1%20**%20(Bad%20ext2%20partition%20or%20disk%20-%20mmc%201%3A1%20)%20**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EMX6Q%20%E3%82%B5%E3%83%96%E3%83%AC%E3%83%A9%E3%82%A4%E3%83%88%20U%E3%83%96%E3%83%BC%E3%83%84%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%80%83%E3%81%88%E3%80%81%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Essinfod%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81element14%E3%81%AESabrelite%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7setenv%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%20%3CSTRONG%3EU-Boot%202009.08%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20(2012%20%E5%B9%B4%208%20%E6%9C%88%2016%20%E6%97%A5%20-%2010%3A06%3A42)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E5%BD%A2%E5%BC%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Esetenv%20mmcargs%20'setenv%20bootargs%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p2%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%3CSTRONG%3E'%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Esaveenv%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3E%E3%83%96%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E6%96%87%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E4%B8%8E%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECAN%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E8%AD%B0%E8%AB%96%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3FCAN%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF%E7%A7%81%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(%E5%AE%9F%E9%9A%9B%E3%80%81%E7%A7%81%E3%81%AF%E6%9C%80%E9%AB%98%E3%81%AE%E4%BA%BA%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E7%A7%81%E3%81%A8%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eu-boot%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1-%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89(git%20clone)%E3%82%92%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-imx%2Fcommits%2Fpatches-2013.07%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-imx%2Fcommits%2Fpatches-2013.07%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%C2%B7%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2Fu-boot-imx%20%C2%B7GitHub%E3%81%AE%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2-%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-imx%2Fcommit%2F08bb52dd977dc571c9808047670a66310848e80f%22%20title%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-imx%2Fcommit%2F08bb52dd977dc571c9808047670a66310848e80f%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emx6qsabrelite%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3AOE%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%20%C2%B7%2008bb52d%20%C2%B7%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2Fu-boot-imx%20%C2%B7GitHub%E3%81%AE%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7HDMI%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABmmcarg%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3-%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FOtavioSalvador%22%20target%3D%22_blank%22%3EOtavioSalvador%3C%2FA%3E%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92you-boot%E3%81%AB%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%80%81github%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4-%20%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%20%3CA%20href%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fmeta-fsl-arm%2Ftree%2Frecipes-bsp%2Fu-boot%2Fu-boot-fslc_2013.07.bb%22%20title%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fmeta-fsl-arm%2Ftree%2Frecipes-bsp%2Fu-boot%2Fu-boot-fslc_2013.07.bb%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-fsl-arm%20-%20Freescale%20ARM%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A1%E3%82%BF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%90%AB%E3%82%80%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%20ID%20%E3%82%92%E6%8C%87%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7CAN%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E5%83%8D%E3%81%8F%E4%BA%BA%E3%81%8C%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%A8%E3%81%A6%E3%82%82%E3%81%86%E3%82%8C%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1%E3%81%A4%E3%81%A0%E3%81%91%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82HDMI%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Daiane%2C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E5%88%86%E9%87%8E%E3%81%A7%E3%81%AF%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AE%E4%BD%9C%E3%82%8A%E6%96%B9%E3%82%92%E5%AD%A6%E3%81%B9%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AA%E3%82%89%E4%BF%AE%E6%AD%A3!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%82%E3%81%97%E7%A7%81%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%9F%A5%E8%AD%98%E3%82%92%E6%B4%BB%E3%81%8B%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8C%E3%81%B0%E3%80%81SABRE%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%90%E3%82%B9EIM%E4%B8%8A%E3%81%AECAN%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20SJA1000%E3%80%81%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EHW%E3%81%A8SW%E3%81%AE%E8%A6%96%E7%82%B9%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EFrancesco%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%83%A9%E3%83%B3%E3%83%81%E3%82%A7%E3%82%B9%E3%82%B3%E3%81%95%E3%82%93%E3%80%81%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B4%A0%E6%95%B5%E3%81%AA%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E7%9B%B4%E6%8E%A5%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E3%81%84%E3%80%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E6%A9%9F%E8%83%BD%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%AE%9F%E8%A3%85%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97%E3%82%88%E3%82%8D%E3%81%97%E3%81%91%E3%82%8C%E3%81%B0%E3%81%94%E6%A1%88%E5%86%85%E3%81%95%E3%81%9B%E3%81%A6%E9%A0%82%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20%234%20-%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A8%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3EHDMI%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20imx6qsabresd%20%E3%82%92%E5%88%9D%E3%82%81%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%20uboot%20envvar%20%3CSTRONG%3Emmcargs%3C%2FSTRONG%3E%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%A1%E3%83%A2%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3Esetenv%20mmcargs%3Dsetenv%20bootargs%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p2%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Esaveenv%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%96%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%88%E3%81%86%E3%81%AA%E3%82%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎06-17-2013 07:22 AM
更新者:
