Setup QT Creator with Yocto Build
bitbaked meta-toolchain-qt
Install it  with
~/yocto/build/tmp/deploy/sdk$ poky-eglibc-x86_64-arm-toolchain-qt-1.4.1.sh
Download Qtcreator from here http://qt-project.org/downloads
and Install it to Your home directory
edit the bin/qtcreator.sh
source /opt/poky/1.4.1/environment-setup-armv7a-vfp-neon-poky-linux-gnueabi
#! /bin/sh
makeAbsolute() {
    case $1 in
            # already absolute, return it
            echo "$1"
            # relative, prepend $2 made absolute
            echo `makeAbsolute "$2" "$PWD"`/"$1" | sed 's,/\.$,,'
    esac
To do it before "#! /bin/sh" is IMPORTANT!!!!
In QtCreator i set
Compiler as
               /opt/poky/1.4.1/sysroots/x86_64-pokysdk-linux/usr/bin/armv7a-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++
Qt version as
                     /opt/poky/1.4.1/sysroots/x86_64-pokysdk-linux/usr/bin/qmake
sysroot as
                    /opt/poky/1.4.1/sysroots/armv7a-vfp-neon-poky-linux-gnueabi
Put them in a Kit
For connection to Your Board click on  Device  --->    Manage
Build a new project
and add some to the .pro file
Building the image for Your Board:
add
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh" to Your localconfig
bitbake core-image-sato-sdk
set a password to root  via
ssh root@[boardip]
passwd
test connection via
sftp  root@[boardip]
start qtcreator
./qtcreator.sh
Message was edited by: Joerg Boge
Good Video to get more Information about Programming are this
Beaglebone: LCD Touchscreen GUI Applications for Embedded Linux - YouTube
Beaglebone: Qt Creator for C++ ARM Embedded Linux Development - YouTube
Beaglebone: Example Qt Embedded Linux Application - YouTube
It is for Beagelbone but for programming Qt it is a good start.
Dieses Dokument wurde aus folgender Diskussion erzeugt: Setup QT Creator with Yocto Build
コメント
Hi there!
Starting the ./qtcreator.sh from the Terminal works fine for me but isn't very convenient I think.
Why isn't it possible to set all the env-Variables directly in the build settings of Qt Creator?
Setting the environment variables (which is everyhing what the environment-setup-... does at the moment) directly in Qt Creator (Projects->Build Settings->Build Environment) doesn't work - does anyone know why?
The other way around for me would be to create a .desktop for a quick execution of the .sh from the Desktop/Starter Menu.
But there is another problem with creating a .desktop file on Ubuntu: It doesn't find the environment-setup-... (1: /mypath/qtcreator.sh: source: not found) on starting with the .desktop-file - is there something wrong? As already set: Executing it directly from the terminal works flawlessly.
qtcreator.desktop (in same directory as qtcreator.sh)
[Desktop Entry]
Version=2.8.1
Name=Qt Creator
Exec=/mypath/qtcreator.sh
Icon=QtProject-qtcreator
Terminal=true
Type=Application
Categories=Development;IDE;Qt;
MimeType=text/x-c++src;text/x-c++hdr;text/x-xsrc;application/x-designer;application/vnd.nokia.qt.qmakeprofile;application/vnd.nokia.xml.qt.resource;text/x-qml;
Any other ideas in improving this step and working around the "problem" of starting the qtcreator from the terminal?
Me again :smileywink:
Maybe we should also mention to use bitbaked meta-toolchain-qte to use e.g. the QWS Qt Window Server without the need for X11.
What do you think?
Florian
Hello Florin,
You should give it a try. I build fsl-image-gui with that local.conf features:
MACHINE ??= 'YOURBAORD'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
CORE_IMAGE_EXTRA_INSTALL_append = "openssh-sftp-server "
TOOLCHAIN_HOST_TASK_append = " nativesdk-python-subprocess"
works fine. debugging i did'nt test till now
So with this setup you were able use QWS without X11? Because I also tried successfully the fsl-image-gui. But then it uses X11 instead of directfb for rendering the Qt-Application.
For performance and faster boot I wanted to get rid of X11.
And what I thought is, that I have to use the meta-toolchain-qte instead of meta-toolchain-qt to compile my Qt-App the right way - if that is the case we should mention it in this DOC.
I am following all the steps mentioned above, however after I  boot the Nitrogen 6x  board, I am unable to connect through sftp.
It has the following error, can someone please help me out
sftp root@192.168.2.26
root@192.168.2.26's password:
sh: /usr/lib/openssh/sftp-server: No such file or directory
Connection closed
When I run "bitbaked meta-toolchain-qt", I meet a problem.
Missing or unbuildable dependency chain was ["meta-toolchain-qt","packagegroup-qt-toolchain-target","qt4-mkspecs","virtual/libx11"]
Why it is?
%3CLINGO-SUB%20id%3D%22lingo-sub-1104138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYocto%20Build%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%83%89%E3%83%BB%E3%83%A1%E3%82%BF-%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3-qt%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E~%2Fyocto%2Fbuild%2Ftmp%2Fdeploy%2Fsdk%24%20poky-eglibc-x86_64-arm-toolchain-qt-1.4.1.sh%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fqt-project.org%2Fdownloads%22%20title%3D%22http%3A%2F%2Fqt-project.org%2Fdownloads%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EQtcreator%E3%82%92%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20http%3A%2F%2Fqt-project.org%2Fdownloads%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%9B%E3%83%BC%E3%83%A0%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%B3%2Fqtcreator.sh%20%E3%81%AE%E7%B7%A8%E9%9B%86%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%3A%20%2Fopt%2Fpoky%2F1.4.1%2Fenvironment-setup-armv7a-vfp-neon-poky-linux-gnueabi%3CBR%20%2F%3E%23!%2Fbin%2Fsh%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3EmakeAbsolute()%20%7B%3CBR%20%2F%3E%E3%82%B1%E3%83%BC%E3%82%B9%24%201%3CBR%20%2F%3E%2F*)%3CBR%20%2F%3E%23%E3%81%99%E3%81%A7%E3%81%AB%E7%B5%B6%E5%AF%BE%E7%9A%84%E3%81%AA%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%BF%94%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%82%B3%E3%83%BC%20%22%241%22%3CBR%20%2F%3E%3B%3B%3CBR%20%2F%3E*)%3CBR%20%2F%3E%23%20relative%2C%20%E5%85%88%E9%A0%AD%E3%81%AB%20%242%20%E3%82%92%E7%B5%B6%E5%AF%BE%E5%80%A4%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%82%A8%E3%82%B3%E3%83%BC%20'makeAbsolute%20%22%242%22%2C%20%22%24PWD%22'%2F%22%241%22%20%7Csed%20's%2C%2F%5C.%24%2C%2C'%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3B%3B%3CBR%20%2F%3EESAC%E3%81%AE%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E....%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%80%8C%23!%E3%80%8C%2Fbin%2Fsh%E3%80%8D%E3%81%AF%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99!!!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQtCreator%E3%81%A7%E7%A7%81%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fopt%2Fpoky%2F1.4.1%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-g%2B%2B%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3EQt%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%0A%3CP%3E%2Fopt%2Fpoky%2F1.4.1%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Fqmake%3C%2FP%3E%0A%3CP%3Esysroot%20%E3%82%92%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fopt%2Fpoky%2F1.4.1%2Fsysroots%2Farmv7a-vfp-neon-poky-linux-gnueabi%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FEBE925D45324E40498AFFA875EAA732B%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84---%26gt%3B%20%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6.pro%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FEBE925D45324E40498AFFA875EAA732B%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1081669779%22%20id%3D%22toc-hId-2005252245%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A7%8B%E7%AF%89%3A%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eadd%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0-%E5%BE%AE%E8%AA%BF%E6%95%B4%20ssh-server-openssh%20%22%20%E3%82%92%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Ebitbake%20core-image-sato-sdk%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92root%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3ESSH%E3%81%AEroot%40%5BboardIP%5D%3C%2FP%3E%0A%3CP%3Epasswd%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3ESFTP%20root%40%5B%E3%83%9C%E3%83%BC%E3%83%89IP%5D%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3EQtCreator%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E.%2Fqtcreator.sh%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E7%B7%A8%E9%9B%86%E8%80%85%3A%20Joerg%20Boge%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%89%AF%E3%81%84%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyXTJC-_rlMY%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyXTJC-_rlMY%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBeaglebone%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%20Linux%20%E7%94%A8%20LCD%20%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20GUI%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20-%20YouTube%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DkP7uvOu9hoQ%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DkP7uvOu9hoQ%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBeaglebone%3A%20C%2B%2B%20ARM%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%20Linux%20%E9%96%8B%E7%99%BA%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%20Qt%20%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%20-%20YouTube%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyNvOyY9zK1o%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyNvOyY9zK1o%26amp%3B%20feature%3Dc4-overview-vl%20%26amp%3B%20list%3DPLF4A1A7E09E5E260A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%93%E3%83%BC%E3%82%B0%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%B3%EF%BC%9AQt%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BFLinux%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%8B-YouTube%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBeagelbone%E7%94%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Qt%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AF%E8%89%AF%E3%81%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDieses%20Dokument%20wurde%20aus%20folgender%20Diskussion%20erzeugt%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F309578%22%20target%3D%22_blank%22%3ESetup%20QT%20Creator%20with%20Yocto%20Build%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%22%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ebitbaked%E3%83%A1%E3%82%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3-qt%20%22%3C%2FSPAN%3E%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%8C%E3%81%AA%E3%81%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%20%5B%22%20meta-toolchain-qt%20%22%2C%20%22%20packagegroup-qt-toolchain-target%20%22%2C%20%22%20qt4-mkspecs%20%22%2C%20%22%20virtual%2Flibx11%20%22%5D%20%E3%81%A7%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%AA%E3%81%9C%E3%81%9D%E3%81%86%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Nitrogen%206x%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81sftp%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%AA%B0%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESFTP%20root%40192.168.2.26%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%88%20%40192%20.168.2.26%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%3A%20%3C%2FP%3E%3CP%3Esh%3A%20%2Fusr%2Flib%2Fopenssh%2Fsftp-server%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%8C%E9%96%89%E3%81%98%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%80%81X11%E3%81%AA%E3%81%97%E3%81%A7QWS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E7%A7%81%E3%82%82fs-image-gui%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Qt%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AFdirectfb%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABX11%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%A8%E8%B5%B7%E5%8B%95%E3%82%92%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81X11%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%8C%E6%80%9D%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%3CSTRONG%3EQt-App%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3Emeta-toolchain-qte%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABmeta-toolchain-qte%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%E3%80%82%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%81%93%E3%81%AEDOC%E3%81%A7%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Florin%2C%3C%2FP%3E%3CP%3E%E3%81%9C%E3%81%B2%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AElocal.conf%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6fsl-image-gui%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%A9%9F%E6%A2%B0%E3%80%82%E3%80%82%3D%20'%E3%83%A6%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89'%3C%2FP%3E%0A%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%0A%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3C%2FP%3E%0A%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0-%E5%BE%AE%E8%AA%BF%E6%95%B4%20ssh-server-openssh%20%22%3C%2FP%3E%0A%3CP%3ECORE_IMAGE_EXTRA_INSTALL_append%20%3D%20%22openssh-sftp-server%20%22%3C%2FP%3E%0A%3CP%3ETOOLCHAIN_HOST_TASK_append%20%3D%20%22nativesdk-python-subprocess%22%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E4%BB%8A%E3%81%BE%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%82%92%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fqt-project.org%2Fdoc%2Fqt-4.8%2Fembeddedlinux-support.html%23compact-and-efficient-windowing-system-qws%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EX11%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%9B%E3%81%9A%E3%81%ABQWS%3C%2FA%3E%20Qt%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AA%E3%81%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%82%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3-qte%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8F%E3%81%B9%E3%81%8D%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AD%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7QT%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%8B%E3%82%89.%2Fqtcreator.sh%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%82%E3%81%BE%E3%82%8A%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQt%20Creator%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E7%9B%B4%E6%8E%A5%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EQt%20Creator%EF%BC%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88-%26gt%3B%20%E3%83%93%E3%83%AB%E3%83%89%E8%A8%AD%E5%AE%9A-%26gt%3B%20%E3%83%93%E3%83%AB%E3%83%89%E7%92%B0%E5%A2%83%EF%BC%89%E3%81%A7%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%EF%BC%88%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A-...%20%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%EF%BC%89%E3%82%92%E7%9B%B4%E6%8E%A5%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%9D%E3%81%AE%E7%90%86%E7%94%B1%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AE%E3%81%9D%E3%81%AE%E9%80%86%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81.desktop%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99.sh%E3%82%92%E3%81%99%E3%81%B0%E3%82%84%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%2F%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%8B%E3%82%89%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81.desktop%20%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E3%81%AF%E5%88%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99Ubuntu%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3Aenvironment-setup%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93-...(1%3A%20%2Fmypath%2Fqtcreator.sh%3Asource%3A%20not%20found)%20.desktop-file%20%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99-%20%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%99%E3%81%A7%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%3A%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eqtcreator.desktop%20(qtcreator.sh%20%E3%81%A8%E5%90%8C%E3%81%98%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85)%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%5B%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%5D%3C%2FP%3E%0A%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D2.8.1%3C%2FP%3E%0A%3CP%3E%E5%90%8D%E5%89%8D%3DQt%E3%82%AF%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CP%3Eexec%3D%2Fmypath%2Fqtcreator.sh%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%82%A4%E3%82%B3%E3%83%B3%3DQtProject-qtcreator%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%3D%E6%9C%AC%E5%BD%93%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%97%3D%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%3D%E9%96%8B%E7%99%BA%3B%E4%BA%95%E6%89%8B%3BQt%3B%3C%2FP%3E%0A%3CP%3EMimeType%3Dtext%2Fx-c%2B%2Bsrc%3Btext%2Fx-c%2B%2Bhdr%3Btext%2Fx-xsrc%3Bapplication%2Fx-designer%3Bapplication%2Fvnd.nokia.qt.qmakeprofile%3Bapplication%2Fvnd.nokia.xml.qt.resource%3Btext%2Fx-qml%3B%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E6%94%B9%E5%96%84%E3%81%97%E3%80%81%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%8B%E3%82%89qtcreator%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%80%8C%E5%95%8F%E9%A1%8C%E3%80%8D%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-30-2013 07:33 AM
更新者:
