Setup QT Creator with Yocto Build
bitbaked meta-toolchain-qt
Install it  with
~/yocto/build/tmp/deploy/sdk$ poky-eglibc-x86_64-arm-toolchain-qt-1.4.1.sh
Download Qtcreator from here http://qt-project.org/downloads
and Install it to Your home directory
edit the bin/qtcreator.sh
source /opt/poky/1.4.1/environment-setup-armv7a-vfp-neon-poky-linux-gnueabi
#! /bin/sh
makeAbsolute() {
    case $1 in
            # already absolute, return it
            echo "$1"
            # relative, prepend $2 made absolute
            echo `makeAbsolute "$2" "$PWD"`/"$1" | sed 's,/\.$,,'
    esac
To do it before "#! /bin/sh" is IMPORTANT!!!!
In QtCreator i set
Compiler as
               /opt/poky/1.4.1/sysroots/x86_64-pokysdk-linux/usr/bin/armv7a-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++
Qt version as
                     /opt/poky/1.4.1/sysroots/x86_64-pokysdk-linux/usr/bin/qmake
sysroot as
                    /opt/poky/1.4.1/sysroots/armv7a-vfp-neon-poky-linux-gnueabi
Put them in a Kit
For connection to Your Board click on  Device  --->    Manage
Build a new project
and add some to the .pro file
Building the image for Your Board:
add
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh" to Your localconfig
bitbake core-image-sato-sdk
set a password to root  via
ssh root@[boardip]
passwd
test connection via
sftp  root@[boardip]
start qtcreator
./qtcreator.sh
Message was edited by: Joerg Boge
Good Video to get more Information about Programming are this
Beaglebone: LCD Touchscreen GUI Applications for Embedded Linux - YouTube
Beaglebone: Qt Creator for C++ ARM Embedded Linux Development - YouTube
Beaglebone: Example Qt Embedded Linux Application - YouTube
It is for Beagelbone but for programming Qt it is a good start.
Dieses Dokument wurde aus folgender Diskussion erzeugt: Setup QT Creator with Yocto Build
评论
Hi there!
Starting the ./qtcreator.sh from the Terminal works fine for me but isn't very convenient I think.
Why isn't it possible to set all the env-Variables directly in the build settings of Qt Creator?
Setting the environment variables (which is everyhing what the environment-setup-... does at the moment) directly in Qt Creator (Projects->Build Settings->Build Environment) doesn't work - does anyone know why?
The other way around for me would be to create a .desktop for a quick execution of the .sh from the Desktop/Starter Menu.
But there is another problem with creating a .desktop file on Ubuntu: It doesn't find the environment-setup-... (1: /mypath/qtcreator.sh: source: not found) on starting with the .desktop-file - is there something wrong? As already set: Executing it directly from the terminal works flawlessly.
qtcreator.desktop (in same directory as qtcreator.sh)
[Desktop Entry]
Version=2.8.1
Name=Qt Creator
Exec=/mypath/qtcreator.sh
Icon=QtProject-qtcreator
Terminal=true
Type=Application
Categories=Development;IDE;Qt;
MimeType=text/x-c++src;text/x-c++hdr;text/x-xsrc;application/x-designer;application/vnd.nokia.qt.qmakeprofile;application/vnd.nokia.xml.qt.resource;text/x-qml;
Any other ideas in improving this step and working around the "problem" of starting the qtcreator from the terminal?
Me again :smileywink:
Maybe we should also mention to use bitbaked meta-toolchain-qte to use e.g. the QWS Qt Window Server without the need for X11.
What do you think?
Florian
Hello Florin,
You should give it a try. I build fsl-image-gui with that local.conf features:
MACHINE ??= 'YOURBAORD'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
CORE_IMAGE_EXTRA_INSTALL_append = "openssh-sftp-server "
TOOLCHAIN_HOST_TASK_append = " nativesdk-python-subprocess"
works fine. debugging i did'nt test till now
So with this setup you were able use QWS without X11? Because I also tried successfully the fsl-image-gui. But then it uses X11 instead of directfb for rendering the Qt-Application.
For performance and faster boot I wanted to get rid of X11.
And what I thought is, that I have to use the meta-toolchain-qte instead of meta-toolchain-qt to compile my Qt-App the right way - if that is the case we should mention it in this DOC.
I am following all the steps mentioned above, however after I  boot the Nitrogen 6x  board, I am unable to connect through sftp.
It has the following error, can someone please help me out
sftp [email protected]
[email protected]'s password:
sh: /usr/lib/openssh/sftp-server: No such file or directory
Connection closed
When I run "bitbaked meta-toolchain-qt", I meet a problem.
Missing or unbuildable dependency chain was ["meta-toolchain-qt","packagegroup-qt-toolchain-target","qt4-mkspecs","virtual/libx11"]
Why it is?
%3CLINGO-SUB%20id%3D%22lingo-sub-1104138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3Ebitbaked%20meta-toolchain-qt%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E5%AE%89%E8%A3%85%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%80%9C%2F%20yocto%20%2F%20build%20%2F%20tmp%20%2F%E9%83%A8%E7%BD%B2%2F%20sdk%20%24%20poky-eglibc-x86_64-arm-toolchain-qt-1.4.1.sh%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%E8%BF%99%E9%87%8C%E4%B8%8B%E8%BD%BD%20Qtcreator%20%3CA%20href%3D%22http%3A%2F%2Fqt-project.org%2Fdownloads%22%20title%3D%22http%3A%2F%2Fqt-project.org%2Fdownloads%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fqt-project.org%2Fdownloads%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E5%B0%86%E5%85%B6%E5%AE%89%E8%A3%85%E5%88%B0%E6%82%A8%E7%9A%84%E4%B8%BB%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%BC%96%E8%BE%91%20bin%2Fqtcreator.sh%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%BA%90%2Fopt%2Fpoky%2F1.4.1%2Fenvironment-setup-armv7a-vfp-neon-poky-linux-gnueabi%3CBR%20%2F%3E%20%2Fbin%2Fsh%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3EmakeAbsolute()%7B%3CBR%20%2F%3E%E6%A1%88%E4%BE%8B%20%241%3CBR%20%2F%3E%20%2F*)%3CBR%20%2F%3E%20%23%20%E5%B7%B2%E7%BB%8F%E6%98%AF%E7%BB%9D%E5%AF%B9%E7%9A%84%EF%BC%8C%E8%BF%94%E5%9B%9E%E5%AE%83%3CBR%20%2F%3E%E5%9B%9E%E6%98%BE%E2%80%9C%241%E2%80%9D%3CBR%20%2F%3E%20%EF%BC%9B%EF%BC%9B%3CBR%20%2F%3E%20*%EF%BC%89%3CBR%20%2F%3E%20%23%20%E7%9B%B8%E5%AF%B9%EF%BC%8C%E5%9C%A8%E5%89%8D%E9%9D%A2%E5%8A%A0%E4%B8%8A%20%242%20%E4%BD%BF%E4%B9%8B%E6%88%90%E4%B8%BA%E7%BB%9D%E5%AF%B9%3CBR%20%2F%3E%E5%9B%9E%E6%98%BE%60makeAbsolute%E2%80%9C%242%E2%80%9D%E2%80%9C%24PWD%E2%80%9D%60%2F%E2%80%9C%241%E2%80%9D%7C%20sed's%EF%BC%8C%2F%5C.%24%EF%BC%8C%EF%BC%8C'%3CBR%20%2F%3E%EF%BC%9B%EF%BC%9B%3CBR%20%2F%3E%E5%9F%83%E8%90%A8%E5%85%8B%3CBR%20%2F%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E....%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%9C%A8%E2%80%9C%23!%2Fbin%2Fsh%E2%80%9D%20%E5%BE%88%E9%87%8D%E8%A6%81%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20QtCreator%20%E4%B8%AD%E6%88%91%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E7%BC%96%E8%AF%91%E5%99%A8%E4%B8%BA%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fopt%2Fpoky%2F1.4.1%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-g%2B%2B%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3EQt%20%E7%89%88%E6%9C%AC%E4%B8%BA%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%0A%3CP%3E%2Fopt%2Fpoky%2F1.4.1%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Fqmake%3C%2FP%3E%0A%3CP%3Esysroot%20%E4%BD%9C%E4%B8%BA%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fopt%2Fpoky%2F1.4.1%2Fsysroots%2Farmv7a-vfp-neon-poky-linux-gnueabi%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%8A%8A%E5%AE%83%E4%BB%AC%E6%94%BE%E5%9C%A8%E5%B7%A5%E5%85%B7%E5%8C%85%E9%87%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FEBE925D45324E40498AFFA875EAA732B%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%EF%BC%8C%E8%AF%B7%E5%8D%95%E5%87%BB%E8%AE%BE%E5%A4%87---%26gt%3B%E7%AE%A1%E7%90%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BB%BA%E7%AB%8B%E6%96%B0%E9%A1%B9%E7%9B%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%BA%9B%E5%88%B0%20.pro%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fskins%2Fimages%2FEBE925D45324E40498AFFA875EAA732B%2Fresponsive_peak%2Fimages%2Fimage_not_found.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1081669779%22%20id%3D%22toc-hId-2005252246%22%3E%E4%B8%BA%E6%82%A8%E7%9A%84%E8%91%A3%E4%BA%8B%E4%BC%9A%E6%A0%91%E7%AB%8B%E5%BD%A2%E8%B1%A1%EF%BC%9A%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eadd%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9Cdebug-tweaks%20ssh-server-openssh%E2%80%9D%E5%88%B0%E6%82%A8%E7%9A%84%E6%9C%AC%E5%9C%B0%E9%85%8D%E7%BD%AE%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Ebitbake%20core-image-sato-sdk%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E8%AE%BE%E7%BD%AE%20root%20%E5%AF%86%E7%A0%81%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Essh%20root%40%5Bboardip%5D%3C%2FP%3E%0A%3CP%3E%E5%AF%86%E7%A0%81%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E6%B5%8B%E8%AF%95%E8%BF%9E%E6%8E%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Esftp%20root%40%5Bboardip%5D%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20qtcreator%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E.%2Fqtcreator.sh%3C%2FP%3E%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B6%88%E6%81%AF%E7%94%B1%20Joerg%20Boge%20%E7%BC%96%E8%BE%91%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E6%9C%89%E5%85%B3%E7%BC%96%E7%A8%8B%E4%BF%A1%E6%81%AF%E7%9A%84%E4%BC%98%E7%A7%80%E8%A7%86%E9%A2%91%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyXTJC-_rlMY%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyXTJC-_rlMY%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBeaglebone%EF%BC%9A%E9%80%82%E7%94%A8%E4%BA%8E%E5%B5%8C%E5%85%A5%E5%BC%8F%20Linux%20%E7%9A%84%20LCD%20%E8%A7%A6%E6%91%B8%E5%B1%8F%20GUI%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20-%20YouTube%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DkP7uvOu9hoQ%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DkP7uvOu9hoQ%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBeaglebone%EF%BC%9A%E7%94%A8%E4%BA%8E%20C%2B%2B%20ARM%20%E5%B5%8C%E5%85%A5%E5%BC%8F%20Linux%20%E5%BC%80%E5%8F%91%E7%9A%84%20Qt%20Creator%20-%20YouTube%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyNvOyY9zK1o%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20title%3D%22http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DyNvOyY9zK1o%26amp%3Bfeature%3Dc4-overview-vl%26amp%3Blist%3DPLF4A1A7E09E5E260A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBeaglebone%EF%BC%9AQt%20%E5%B5%8C%E5%85%A5%E5%BC%8F%20Linux%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%A4%BA%E4%BE%8B%20-%20YouTube%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E9%80%82%E7%94%A8%E4%BA%8E%20Beagelbone%EF%BC%8C%E4%BD%86%E5%AF%B9%E4%BA%8E%20Qt%20%E7%BC%96%E7%A8%8B%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E5%BC%80%E5%A7%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDieses%20Dokument%20wurde%20aus%20folgender%20Diskussion%20erzeugt%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F309578%22%20target%3D%22_blank%22%3ESetup%20QT%20Creator%20with%20Yocto%20Build%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E2%80%9C%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ebitbaked%20meta-toolchain-qt%E2%80%9D%E6%97%B6%EF%BC%8C%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E7%BC%BA%E5%B0%91%E6%88%96%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%E7%9A%84%E4%BE%9D%E8%B5%96%E9%93%BE%E6%98%AF%20%5B%E2%80%9Cmeta-toolchain-qt%E2%80%9D%EF%BC%8C%E2%80%9Cpackagegroup-qt-toolchain-target%E2%80%9D%EF%BC%8C%E2%80%9Cqt4-mkspecs%E2%80%9D%EF%BC%8C%E2%80%9Cvirtual%2Flibx11%E2%80%9D%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E5%91%A2%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E9%81%B5%E5%BE%AA%E4%BA%86%E4%B8%8A%E8%BF%B0%E6%89%80%E6%9C%89%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E5%90%AF%E5%8A%A8%20Nitrogen%206x%20%E6%9D%BF%E5%90%8E%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20sftp%20%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%83%E6%9C%89%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8C%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E5%90%97%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Esftp%20root%40192.168.2.26%3C%2FP%3E%3CP%3Eroot%40192.168.2.26%20%E7%9A%84%E5%AF%86%E7%A0%81%EF%BC%9A%20%3C%2FP%3E%3CP%3Esh%EF%BC%9A%2Fusr%2Flib%2Fopenssh%2Fsftp-server%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%E5%B7%B2%E5%85%B3%E9%97%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%82%A3%E4%B9%88%E9%80%9A%E8%BF%87%E6%AD%A4%E8%AE%BE%E7%BD%AE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%B2%A1%E6%9C%89%20X11%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%BF%E7%94%A8%20QWS%20%E5%90%97%EF%BC%9F%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B9%9F%E6%88%90%E5%8A%9F%E5%B0%9D%E8%AF%95%E4%BA%86fsl-image-gui%E3%80%82%E4%BD%86%E6%98%AF%E5%AE%83%E4%BD%BF%E7%94%A8%20X11%20%E8%80%8C%E4%B8%8D%E6%98%AF%20directfb%20%E6%9D%A5%E6%B8%B2%E6%9F%93%20Qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E6%8F%90%E9%AB%98%E6%80%A7%E8%83%BD%E5%92%8C%E5%8A%A0%E5%BF%AB%E5%90%AF%E5%8A%A8%E9%80%9F%E5%BA%A6%EF%BC%8C%E6%88%91%E6%83%B3%E6%91%86%E8%84%B1%20X11%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%83%B3%E6%B3%95%E6%98%AF%EF%BC%8C%E6%88%91%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20meta-toolchain-%20%3CSTRONG%3Eqte%3C%2FSTRONG%3E%E8%80%8C%E4%B8%8D%E6%98%AF%20meta-toolchain-%20%3CSTRONG%3Eqt%3C%2FSTRONG%3E%E6%9D%A5%E4%BB%A5%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%96%B9%E5%BC%8F%E7%BC%96%E8%AF%91%E6%88%91%E7%9A%84%20Qt-App%20-%20%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%9C%A8%E8%BF%99%E4%B8%AA%20DOC%20%E4%B8%AD%E6%8F%90%E5%8F%8A%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Florin%2C%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%BA%94%E8%AF%A5%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%20local.conf%20%E5%8A%9F%E8%83%BD%E6%9E%84%E5%BB%BA%E4%BA%86%20fsl-image-gui%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9C%BA%E5%99%A8%3F%3F%3D'%E4%BD%A0%E7%9A%84%E4%B8%BB%E6%9D%BF'%3C%2FP%3E%0A%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%0A%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22%E8%BD%AF%E4%BB%B6%E5%8C%85_rpm%22%3C%2FP%3E%0A%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9C%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4ssh%E6%9C%8D%E5%8A%A1%E5%99%A8openssh%E2%80%9D%3C%2FP%3E%0A%3CP%3ECORE_IMAGE_EXTRA_INSTALL_append%20%3D%E2%80%9Copenssh-sftp%E6%9C%8D%E5%8A%A1%E5%99%A8%E2%80%9D%3C%2FP%3E%0A%3CP%3ETOOLCHAIN_HOST_TASK_append%20%3D%20%22%20nativesdk-python-%E5%AD%90%E8%BF%9B%E7%A8%8B%22%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%E8%B0%83%E8%AF%95%E6%88%91%E5%88%B0%E7%8E%B0%E5%9C%A8%E8%BF%98%E6%B2%A1%E6%9C%89%E6%B5%8B%E8%AF%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8F%88%E6%98%AF%E6%88%91%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E4%BB%AC%E8%BF%98%E5%BA%94%E8%AF%A5%E6%8F%90%E5%88%B0%E4%BD%BF%E7%94%A8%20bitbaked%20meta-toolchain-qte%20%E6%9D%A5%E4%BD%BF%E7%94%A8%E4%BE%8B%E5%A6%82%3CA%20href%3D%22http%3A%2F%2Fqt-project.org%2Fdoc%2Fqt-4.8%2Fembeddedlinux-support.html%23compact-and-efficient-windowing-system-qws%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EQWS%3C%2FA%3E%20Qt%20Window%20Server%EF%BC%8C%E8%80%8C%E4%B8%8D%E9%9C%80%E8%A6%81%20X11%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%80%8E%E4%B9%88%E8%AE%A4%E4%B8%BA%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E5%BC%97%E6%B4%9B%E9%87%8C%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Yocto%20Build%20%E8%AE%BE%E7%BD%AE%20QT%20Creator%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%E5%91%80%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%E7%BB%88%E7%AB%AF%E5%90%AF%E5%8A%A8%20.%2Fqtcreator.sh%20%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E5%BE%88%E5%A5%BD%EF%BC%8C%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E4%B8%8D%E6%98%AF%E5%BE%88%E6%96%B9%E4%BE%BF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%8D%E8%83%BD%E5%9C%A8%20Qt%20Creator%20%E7%9A%84%E6%9E%84%E5%BB%BA%E8%AE%BE%E7%BD%AE%E4%B8%AD%E7%9B%B4%E6%8E%A5%E8%AE%BE%E7%BD%AE%E6%89%80%E6%9C%89%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%9B%B4%E6%8E%A5%E5%9C%A8%20Qt%20Creator%EF%BC%88%E9%A1%B9%E7%9B%AE-%26gt%3B%E6%9E%84%E5%BB%BA%E8%AE%BE%E7%BD%AE-%26gt%3B%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%EF%BC%89%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%88%E5%8D%B3%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E5%BD%93%E5%89%8D%E6%89%80%E5%81%9A%E7%9A%84%E4%B8%80%E5%88%87%EF%BC%89%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%20-%20%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%E6%98%AF%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20.desktop%E5%BF%AB%E9%80%9F%E6%89%A7%E8%A1%8C.sh%E4%BB%8E%E6%A1%8C%E9%9D%A2%2F%E5%BC%80%E5%A7%8B%E8%8F%9C%E5%8D%95%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%88%9B%E5%BB%BA%20.desktop%20%E8%BF%98%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98Ubuntu%20%E4%B8%8A%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9A%E5%AE%83%E6%89%BE%E4%B8%8D%E5%88%B0%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE...%EF%BC%881%EF%BC%9A%2Fmypath%2Fqtcreator.sh%EF%BC%9A%E6%9D%A5%E6%BA%90%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%89%E4%BB%8E%20.desktop%20%E6%96%87%E4%BB%B6%E5%BC%80%E5%A7%8B-%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%AD%A3%E5%A6%82%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E7%9A%84%EF%BC%9A%E7%9B%B4%E6%8E%A5%E4%BB%8E%E7%BB%88%E7%AB%AF%E6%89%A7%E8%A1%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%AE%8C%E7%BE%8E%E5%9C%B0%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eqtcreator.desktop%EF%BC%88%E4%B8%8E%20qtcreator.sh%20%E4%BD%8D%E4%BA%8E%E5%90%8C%E4%B8%80%E7%9B%AE%E5%BD%95%E4%B8%AD%EF%BC%89%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%5B%E6%A1%8C%E9%9D%A2%E6%9D%A1%E7%9B%AE%5D%3C%2FP%3E%0A%3CP%3E%E7%89%88%E6%9C%AC%3D2.8.1%3C%2FP%3E%0A%3CP%3E%E5%90%8D%E7%A7%B0%3DQt%20Creator%3C%2FP%3E%0A%3CP%3E%E6%89%A7%E8%A1%8C%3D%2Fmypath%2Fqtcreator.sh%3C%2FP%3E%0A%3CP%3E%E5%9B%BE%E6%A0%87%3DQtProject-qtcreator%3C%2FP%3E%0A%3CP%3E%E7%BB%88%E7%AB%AF%3D%E7%9C%9F%3C%2FP%3E%0A%3CP%3E%E7%B1%BB%E5%9E%8B%3D%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%0A%3CP%3E%E7%B1%BB%E5%88%AB%3D%E5%BC%80%E5%8F%91%EF%BC%9BIDE%EF%BC%9BQt%EF%BC%9B%3C%2FP%3E%0A%3CP%3EMimeType%3Dtext%2Fx-c%2B%2Bsrc%3Btext%2Fx-c%2B%2Bhdr%3Btext%2Fx-xsrc%3Bapplication%2Fx-designer%3Bapplication%2Fvnd.nokia.qt.qmakeprofile%3Bapplication%2Fvnd.nokia.xml.qt.resource%3Btext%2Fx-qml%3B%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%83%B3%E6%B3%95%E5%8F%AF%E4%BB%A5%E6%94%B9%E8%BF%9B%E8%BF%99%E4%B8%80%E6%AD%A5%E5%B9%B6%E8%A7%A3%E5%86%B3%E4%BB%8E%E7%BB%88%E7%AB%AF%E5%90%AF%E5%8A%A8%20qtcreator%20%E7%9A%84%E2%80%9C%E9%97%AE%E9%A2%98%E2%80%9D%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-30-2013 07:33 AM
更新人:
