Linux Fast Boot on i.MX6Q Board: Building Steps
This document provides the steps to patch and build a fastboot Linux System. This document assumes the BSP 3.0.35_1.1.0 and a  i.MX6Q platform. For more information about what the patches do, please check this link.
  • Install LTIB and move to the ltib folder
  • Download the ltib patch from this document and patch it (patch -p1 < 0001-set-imx6_ssd_lite_defconfig-as-default-kernel-config.patch)
  • Go to the LTIB configuration menu (./ltib -m config), select mx6q platform and min profile
  • Select mx6q_sabresd as u-boot board
  • Fetch and Patch:
u-boot:
Prepare u-boot source code (./ltib -m prep -p u-boot)
Move to u-boot folder (cd rpm/BUILD/u-boot-2009.08)
Download u-boot attached patches
Patch code (for p in *.patch; do patch -p1 < $p;done)
kernel:
Prepare kernel source code (./ltib -m prep -p kernel)
Move to kernel folder (cd rpm/BUILD/linux)
Download attached kernel patches
  • Build  (./ltib)
  • Add  an application to run first after boot in rootfs/etc/inittab (see example inittab file, it captures data from the MIPI Camera)
  • Create necessary devices nodes under rootfs/dev. For example
    • terminal: sudo mknod ttymxc0 c 207 16
    • video capture nodes: sudo mknod video0 c 81 5; sudo mknod video1 c 81 6
    • video display nodes: sudo mknod video16 c 81 0; sudo mknod video17 c 81 1
    • frame-buffers: for i in 0 1 2 3 4; do sudo mknod fb$i c 29 $i; done
  • Package rootfs (cd rootfs; sudo tar --numeric-owner -cvfj ../rootfs.tar.bz2 *; cd ..)
  • On a windows machine, download latest Manufacturing tool and uncompress it.
  • Move rootfs.tar.bz2, rootfs/boot/uImage and rootfs/boot/u-boot.bin into the corresponding Manufacturing folder (Profiles\MX6Q Linux Update\OS Firmware\files)
  • Choose a sabresd-eMMC profile and flash the board
  • Boot the board using the eMMC
ラベル(2)
タグ(1)
添付
コメント
Could you please attach patches for SabreAI board??
Unfortunately I do not have them. You may need to patch manually. In case you do this, please share your sabre AI patches.
Leo
Hi,Why i can't find "imx6_ssd_lite_defconfig" in "arch/arm/configs" ? my device is imx6q.
Have you got these files for MarS Board (embest-tech)?
And Have you got full image (not just patch)?
which version of u-boot is used? uboot-2009.08?? There is no file/folder named mx6qsabresd in this version of u-boot!
How much time u_boot takes to finish in milisecs?
%3CLINGO-SUB%20id%3D%22lingo-sub-1106989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E6%A7%8B%E7%AF%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81fastboot%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81BSP%203.0.35_1.1.0%20%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99i.MX6Q%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93619%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FA%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3ELTIB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81ltib%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%20ltib%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20(%3CEM%3Epatch%20-p1%20%26lt%3B%200001-set-imx6_ssd_lite_defconfig-as-default-kernel-config.patch%3C%2FEM%3E)%E3%80%82%3C%2FLI%3E%3CLI%3ELTIB%20%E8%A8%AD%E5%AE%9A%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%20(%3CEM%3E.%2Fltib%20-m%20confi%3C%2FEM%3Eg)%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81mx6q%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%20min%20profile%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3Emx6q_sabresd%E3%82%92u-boot%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%A8%E3%83%91%E3%83%83%E3%83%81%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3EU%E3%83%96%E3%83%BC%E3%83%88%3A%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3Eu-boot%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%BA%96%E5%82%99(%3CEM%3E.%2Fltib%20-m%20prep%20-p%20u-boot%3C%2FEM%3E)%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3EU%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%3CEM%3ECD%20RPM%2F%E3%83%93%E3%83%AB%E3%83%89%2FU-%E3%83%96%E3%83%BC%E3%83%88-2009.08%3C%2FEM%3E%EF%BC%89%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3Eu-boot%E6%B7%BB%E4%BB%98%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%B3%E3%83%BC%E3%83%89%20(*%3CEM%3E.patch%20%E3%81%AE%20p%20%E3%81%AE%E5%A0%B4%E5%90%88%3B%20do%20patch%20-p1%20%26lt%3B%20%24p%3B%E5%AE%8C%E4%BA%86%3C%2FEM%3E)%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3Ekernel%3A%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%20(%3CEM%3E.%2Fltib%20-m%20prep%20-p%20kernel%3C%2FEM%3E)%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%20(%3CEM%3Ecd%20rpm%2FBUILD%2Flinux%3C%2FEM%3E)%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%B3%E3%83%BC%E3%83%89%20(*%3CEM%3E.patch%20%E3%81%AE%20p%20%E3%81%AE%E5%A0%B4%E5%90%88%3B%20do%20patch%20-p1%20%26lt%3B%20%24p%3B%E5%AE%8C%E4%BA%86%3C%2FEM%3E)%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%93%E3%83%AB%E3%83%89%20(%3CEM%3E.%2Fltib%3C%2FEM%3E)%3C%2FLI%3E%3CLI%3E%E3%83%96%E3%83%BC%E3%83%88%E5%BE%8C%E3%81%AB%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%20rootfs%2Fetc%2Finittab%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%20(inittab%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%80%81MIPI%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%20rootfs%2Fdev%20%E3%81%AE%E4%B8%8B%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%3CUL%3E%3CLI%3Eterminal%3A%20%3CEM%3Esudo%20mknod%20ttymxc0%20c%20207%2016%3C%2FEM%3E%3C%2FLI%3E%3CLI%3Evideo%20capture%20nodes%3A%20%3CEM%3Esudo%20mknod%20video0%20c%2081%205%3B%20sudo%20mknod%20video1%20c%2081%206%3C%2FEM%3E%3C%2FLI%3E%3CLI%3Evideo%20display%20nodes%3A%20%3CEM%3Esudo%20mknod%20video16%20c%2081%200%3B%20sudo%20mknod%20video17%20c%2081%201%3C%2FEM%3E%3C%2FLI%3E%3CLI%3Eframe-buffers%3A%20%3CEM%3Efor%20i%20in%200%201%202%203%204%3B%20do%20sudo%20mknod%20fb%24i%20c%2029%20%24i%3B%20done%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20rootfs%20(%3CEM%3Ecd%20rootfs%3B%20sudo%20tar%20--numeric-owner%20-cvfj%20..%2Frootfs.tar.bz2%20*%3Bcd%20..%3C%2FEM%3E)%3C%2FLI%3E%3CLI%3EWindows%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AE%E8%A3%BD%E9%80%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3E%3CEM%3E%20rootfs.tar.bz2%3C%2FEM%3E%20%E3%82%92%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81rootfs%2Fboot%2FuImage%20%E3%81%A8%20rootfs%2Fboot%2Fu-boot.bin%20%E3%82%92%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%20Manufacturing%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%20(Profiles%5CMX6Q%20Linux%20Update%5COS%20Firmware%5Cfiles)%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3Esabresd-eMMC%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3EeMMC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9F%E3%83%AA%E3%82%BB%E3%83%83%E3%82%AF%E3%81%A7%E4%BB%95%E4%B8%8A%E3%81%92%E3%82%8B%E3%81%AEu_boot%E3%81%A9%E3%81%AE%E3%81%8F%E3%82%89%E3%81%84%E3%81%AE%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEu-boot%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3Fuboot-2009.08%20%3F%3F%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEyou-boot%E3%81%AB%E3%81%AF%E3%80%81mx6qsabresd%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMarS%20Board%20(embest-tech)%E7%94%A8%E3%81%AE%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%80%8Carch%20%2F%20arm%20%2F%20configs%E3%80%8D%E3%81%AB%E3%80%8Cimx6_ssd_lite_defconfig%E3%80%8D%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFIMX6Q%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E7%A7%81%E3%81%AF%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BCAI%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%20Linux%20%E9%AB%98%E9%80%9F%E3%83%96%E3%83%BC%E3%83%88%3A%20%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESabreAI%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%E3%83%AF%E3%83%83%E3%83%9A%E3%83%B3%E3%82%92%E4%BB%98%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-07-2013 08:42 AM
更新者:
