Installing Ubuntu Rootfs on NXP i.MX6 boards
This post describes the setup detail for installing Ubuntu based distro in any i.Mx6x NXP Boards. Details are described on:
1. Select your board, Setting the host, Download and compile uboot , dtb and and the Kernel version on your board.
2. Installing the Ubuntu core, Lubuntu graphics desktop version and/or Build your own Ubuntu rootfs with debootstrap.
3. Modify rootfs and Installing needed packages
4. Setting with SD image.
5. Setting Ubuntu on target
6. Adding GPU acceleration
1: Select your board, Setting the host, Download and compile uboot , dtb and and the Kernel version on your board.
Supported NXP HW boards:
  • i.MX 6QuadPlus SABRE-SD Board and Platform
  • i.MX 6Quad SABRE-SD Board and Platform
  • i.MX 6DualLite SABRE-SD Board
  • i.MX 6Quad SABRE-AI Board
  • i.MX 6DualLite SABRE-AI Board
  • i.MX 6SoloX SABRE-SD Board
  • i.MX 6SoloX SABRE-AI Board
Install host dependences (version tested 14.04):
$ sudo apt-get install gparted git build-essential libncurses5 wget u-boot-tools zlib1g-dev ncurses-dev \
cmake libc-dev-armhf-cross pkg-config-arm-linux-gnueabihf build-essential checkinstall cmake \
pkg-config lzop libc6 libstdc++6 debootstrap qemu-user-static binfmt-support
Download the compiler toolchain and extract it:
$ cd ~/
$ wget -c https://releases.linaro.org/14.09/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.9-2...
$ tar xf gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz
Create general variable environments:
$ export target=mx6q (e.g. processor: mx6sx, mx6d, mx6dl,etc)
$ export board=sabresd (e.g. sabresd, sabreauto)
$ export ARCH=arm
$ export CROSS_COMPILE=../gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf-
$ unset LDFLAGS
Download u-boot
At the release of this document, latest uboot version was imx_3.14.52, it should work with other version as well, so please check the proper version for your board:
$ cd ~/
$ wget –c http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/snapshot/uboot-imx-rel_imx_3.14.52_1.1.0_ga....
$ tar -xf uboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz
$ cd uboot-imx-rel_imx_3.14.52_1.1.0_ga
$ make $targetboard_config    # e.g. mx6qsabresd_config
$ make
Linux Kernel, Firmware, headers, modules and DTS files
$ cd ~/
$ wget –c http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/snapshot/linux-2.6-imx-rel_imx_3.14.52_1...
$ tar xf linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz
$ cd linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga
$ make imx_v7_defconfig
$ make menuconfig
$ make -j4 zImage modules dtbs
$ cd ~/
move your image to binary folder:
$ sudo cp –v uboot-imx-rel_imx_3.14.52_1.1.0_ga/u-boot.imx binary/
$ sudo cp –v linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/boot/zImage binary/
$ sudo cp –v linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/boot/dts/i$target-$board.dtb binary/
Now you have the bootloader, device tree and kernel image of your board ready, let’s create the rootfs.
2: Installing the Ubuntu core, Lubuntu graphics desktop version and/or Build your own Ubuntu rootfs with debootstrap.
Installing ubuntu core:
$ cd ~/
$ sudo mkdir –p core /media/rootfs /media/kernel
$ wget –c http://cdimage.ubuntu.com/ubuntu-core/releases/14.04/release/ubuntu-core-14.04.4-core-armhf.tar.gz
$ sudo tar –xf ubuntu-core-14.04.4-core-armhf.tar.gz –C core
$ sudo cp -vr core/* /media/rootfs
$ sudo make modules_install firmware_install INSTALL_MOD_PATH=/media/rootfs/ ARCH=arm CROSS_COMPILE=../../gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf-
$ sudo make ARCH=arm CROSS_COMPILE=../../gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf- headers_install INSTALL_HDR_PATH=/media/rootfs/usr
Now you should have your ubuntu rootfs on /media/rootfs folder. and you can pass to part 3 of this post.
Installing ubuntu Linaro LXDE:
$ cd ~/
$ wget https://releases.linaro.org/14.10/ubuntu/trusty-images/alip/linaro-trusty-alip-20141024-684.tar.gz
$ sudo tar -xf linaro-trusty-alip-20141024-684.tar.gz –C core
$ sudo mv core/binary/* core/
$ sudo rm –rf core/binary
Installing with debootstrap
$ cd ~/
$ target=rootfs
$ distro=trusty
$ sudo debootstrap --arch=armhf --foreign --include=ubuntu-keyring,apt-transport-https,ca-certificates,openssl $distro "$target" http://ports.ubuntu.com
$ sudo cp /usr/bin/qemu-arm-static $target/usr/bin
$ sudo cp /etc/resolv.conf $target/etc
Now have a minimal Ubuntu rootfs - chroot to it and perform the 2nd stage install:
$ sudo chroot $target  //Now we are in chroot
# distro=trusty
# export LC_ALL=C LANGUAGE=C LANG=C
# /debootstrap/debootstrap --second-stage
Edit the sources.list repositories
# cat <<EOT > /etc/apt/sources.list
deb http://ports.ubuntu.com/ubuntu-ports/ $distro main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ $distro-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ $distro-security main restricted universe multiverse
EOT
# apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 40976EAF437D05B5
# apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 3B4FE6ACC0B21F32
# apt-get update
# apt -y -f install
# apt-get upgrade
# apt-get install nano
Now you should be able to login without password, then use passwd command to set one. If you like to add custom users:
# passwd root
# adduser <myuser>
# usermod -a -G tty myuser
# usermod -a -G dialout, adm, sudo, dip, plugdev myuser
# visudo
Under the line that looks like:
root ALL=(ALL:ALL) ALL
add the following (change user with your actual username)
<myuser> ALL=(ALL) ALL
your rootfs is ready, exit chroot
# exit
$ sudo rm $target/etc/resolv.conf
$ sudo rm $target/usr/bin/qemu-arm-static
$ sudo mv rootfs/* /media/rootfs
Now you should have your ubuntu rootfs on /media/root.
3: Modify Rootfs and Install needed packages
Edit and verify the sources.list repositories
$ cd /media/rootfs
$ sudo cat <<EOT > etc/apt/sources.list
deb http://ports.ubuntu.com/ubuntu-ports/ trusty main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security main restricted universe multiverse
EOT
Edit networks interfaces and append in the existing file:
$ sudo nano etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
If you require Serial Console, remove and include an additional line at the end of the file for  ttymxc0 output as below,
$ sudo nano etc/init/tty1.conf
exec /sbin/getty -8 38400 tty1
exec /sbin/getty -L 115200 ttymxc0
If you like to change the localhostname:
$ sudo nano etc/hostname
and change to “your name” e.g. imx6Q.
Set the date and time clock and update
$ sudo nano /etc/rc.local
Add this:
if [ `date +"%Y"` -eq "1970" ]; then
                    date --set="2016-04-01"
fi
exit 0
(optional for Linaro rootfs)
Edit passwd and remove the x in root and linaro lines
$ sudo nano etc/passwd
root:x:0:0:root:/root:/bin/bash
linaro:x:0:0..
and change like this:
root::0:0:root:/root:/bin/bash
linaro:::0:..
Now you are ready to program your sd image.
4: Setup microSD/SD card
For these instructions, we are assuming: DISK=/dev/sdg on your HOST, cat /proc/partitions is very useful for determining the device id.
$ cd ~/
$ export DISK=/dev/sdg
Erase microSD/SD card:
$ sudo dd if=/dev/zero of=${DISK} bs=1M count=10
Install Bootloader
$ cd binary/
$ sudo dd if=u-boot.imx of=${DISK} bs=512 seek=2
$ sync
Create Partition layout:
$ cd ~/
$ sudo fdisk ${DISK}
steps:
  • d ///delete all partitions currently on sd
  • n // create new partition
  • p // Primary partition
  • 1 // partition number 1
  • 2048 //default
  • +1G //
  • n // created 2d parition
  • p
  • 2
  • default
  • default
  • 1 // firts
  • B // to be fat32
  • W // write partiotions
$ sudo mkfs.vfat ${DISK}1
$ sudo mkfs.ext3  ${DISK}2
Mount ext3 SD partition to /media/rootfs:
$ sudo mount ${DISK1} /media/kernel_target
$ sudo mount ${DISK}2 /media/rootfs_target
Copy Files on the SD.
$ cd ~/
$ sudo cp –v binary/ i$target-$board.dtb /media/kernel_target
$ sudo cp –v binary/zImage /media/kernel_target
$ sudo mv /media/rootfs/* /media/rootfs_target
Remove SD:
$ sync
$ sudo umount /media/kernel_target
$ sudo umount /media/rootfs_target
Boot the target, in console you should be login as root.
root@imx6QSabreSD:~#
5: Setting Ubuntu on target
Note: If you have issues with sudo on user UID, need to logout and log as root:
imx6Q login: root
Welcome to Ubuntu 14.04.4 LTS (GNU/Linux 3.14.52 armv7l)
root@imx6Q:~# chown root:root /usr/bin/sudo
root@imx6Q:~# chmod 4755 /usr/bin/sudo
root@imx6Q:~# exit
Login with <user $> or root #
# apt-get update
# apt-get –f install
# apt-get install locales dialog wget
# dpkg-reconfigure locales
# apt-get upgrade
Optional – install some useful packages:
# apt-get install openssh-server can-utils usbutils build-essential automake autoconf libtool
Get and Install the BSP packages (EULA required)
# cd /home/user
# mkdir –p vpu_pack
# cd vpu_pack
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//firmware-imx-5.3.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-5.4.32.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//libfslcodec-4.0.8.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-lib-5.1.tar.gz
# chmod +x *
# ./firmware-imx-5.3.bin --auto-accept --force
# mkdir –p /lib/firmware/vpu
# cp -ravf firmware-imx-5.3/firmware/* /lib/firmware/
# ./imx-vpu-5.4.32.bin --auto-accept --force
# cd imx-vpu-*
# make PLATFORM=IMX6Q all
# make install
# tar -xf imx-lib-5.1.tar.gz
# cd  imx-lib-5.1/
# make -j1 PLATFORM="IMX6Q"
# make PLATFORM="IMX6Q" install
# cd ..
# ./libfslcodec-4.0.8 --auto-accept –force
# cd libfslcodec-*
# ./autogent.sh --prefix=/usr --enable-fhw --enable-vpu
# make
# make install
# mv /usr/lib/imx-mm/video-codec/* /usr/lib
# mv /usr/lib/imx-mm/audio-codec/* /usr/lib
# rm –rf /usr/lib/imx-mm/
# cd ..
# mkdir –p gpu_pack
# cd gpu_pack
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-gpu-viv-5.0.11.p7.4-hfp.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//xserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz
# chmod +x *
# ./imx-gpu-viv-5.0.11.p7.4-hfp –-auto-accept -–force
# cd imx-gpu*
# cp g2d/usr/include/* /usr/include/
# cp -d g2d/usr/lib/* /usr/lib/
# cp -Pr gpu-core/usr/* /usr
# optional: install demos
# cp -r gpu-demos/opt /
# optional: install gpu tools
# cp -axr gpu-tools/gmem-info/usr/bin/* /usr/bin/
# cd ..
Installing gstreamer-imx, IPU, VPU and GPU support:
Install build deps, gstreamer1.x, this step could take some time (~350MB):
# apt-get install python pkg-config git gstreamer1.0-x gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-alsa libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-good1.0-dev g++-multilib
# git clone git://github.com/Freescale/gstreamer-imx.git
# cd gstreamer-imx
# ln –s /usr/lib/arm-linux-gnueabihf/gstreamer-1.0/ /usr/lib/gstreamer-1.0
# ./waf configure --prefix=/usr --kernel-headers=/include
# ./waf
# ./waf install
# cd ../../
(optional) Install libimxvpuapi library: This library provides a community based open-source API to the NXP imx-vpu library (the low-level IMX6 VPU interface).
# git clone git://github.com/Freescale/libimxvpuapi.git
# cd libimxvpu*
# ./waf configure –-prefix=/usr
# ./waf
# ./waf install
# cd ..
  • note './waf install' installs artifacts to its prefix + /lib/gstreamer-1.0 but they need to be installed to /usr/lib/arm-linux-gnueabihf/gstreamer-1.0 which is why we created a symlink above before installing
  • note g2d lib required to build G2D
  • note that x11 library is required to build EGL sink with Vivante direct textures (only needed for X11 support)
  • note that libfslaudiocodec is required to build audio plugins
Now you are ready to test gstreamer
6: Add GPU HW Acceleration for X11
NOTE: The original version of these build instructions can be found in the Gateworks wiki . Many thanks to them for writing this!
IMX6 IPU, VPU, and GPU support via GStreamer and Gstreamer-imx plugins. Many of the pieces needed (firmware and source-code) are from NXP and not freely redistributable thus must be downloaded from their mirror and extracted from a shell script that forces you to read and agree to their End User License Agreement (EULA).
The following instructions can be used on top of the debootstrap and should work on other sources of Ubuntu or other Linux distributions root filesystems as well
You can easily add X11 support to a base image created with the debootstrap instructions above by adding a few package groups. You will need the following:
  • X11 server - ie Xorg
  • Display Manager - this controls the login to the X session
  • Window Manager - manages window position, re-sizing, decorations, etc for X clients
If in any case you have installed the Linaro LXDE rootfs, it includes the Xorg X11 server, the lxdm Display Manager, the openbox Window Manager, and others useful user applications including the Chromium browser, if you do not install linaro lxde and want to install it please do:
this step could take some time (~650MB)
  # apt-get install xinit lxde lxterminal lxappearance lxrandr lxshortcut lxinput xinit  xserver-xorg-dev mesa-utils mesa-utils-extra
Notes:
  • you will need to add a non-root user with adduser for Chromium browser to work. You may choose to set up auto-login for that user by editing /etc/lxdm/default.conf and setting the autologin property in the base section at the beginning of the config file. /etc/xdg/lubuntu/lxdm/lxdm.conf
  • This document takes as based kernel version 3.14.52v, vivante 5.0.11p7.4 correspond to the kernel version used. you should check the BSP release notes in order to know which xserver and Vivante GPU files need to be downloaded from the NXP repos.
$ sudo nano /etc/lxdm/default.conf
   [base]
   autologin=user
To add hardware GPU acceleration to X11 you need to add some libraries and drivers provided by Freescale from the imx-gpu-viv package. This requires signing Freescales End User License Agreement (EULA). This package provides the following:
  • libg2d - a documented low-level API to the GPU (used by things like libimxvpuapi for gstreamer-imx and the gpu-core drivers)
  • gpu-core - provides all the various OpenGL libs (libGL, libGLESv1_CM, libGLESv1_CL, libGLESv2, libGLSLC, libCLC, libEGL, libGAL, libOpenCL, ls
  • libOpenVG) typically provided by the mesa project. Note that several versions of libEGL/libGAL/libGLESv2/libVIVANTE are provided for different backend rendering systems: dfb, fb, wl, x11.
# cd gpu_pack
#cd imx-gpu-*
# cp gpu-core/usr/lib/dri/vivante_dri.so /usr/lib/xorg/modules/drivers/
# chmod 644 /usr/lib/xorg/modules/drivers/vivante_dri.so
# rm /usr/lib/arm-linux-gnueabihf/mesa/libGL.so*
# rm /usr/lib/arm-linux-gnueabihf/mesa-egl/libEGL.so*
# rm /usr/lib/arm-linux-gnueabihf/mesa-egl/libGLESv2.so*
# rm /usr/lib/arm-linux-gnueabihf/mesa-egl/libOpenVG.so*
# cd ../../
# cd gpu-pack
# tar –xf xserver*
# cd xserver-org-video-imx*
#looks lik have to made #git init
# ./fastbuild.sh  BUILD_HARD_VFP=1 XSERVER_GREATER_THAN_13=1
# cd..
# cd kernel-modu*
# make
Switch to gpu-core x11 backend:
# backend=x11
# ln -sf libEGL-${backend}.so /usr/lib/libEGL.so
# ln -sf libEGL-${backend}.so /usr/lib/libEGL.so.1
# ln -sf libEGL-${backend}.so /usr/lib/libEGL.so.1.0
# ln -sf libGAL-${backend}.so /usr/lib/libGAL.so
# ln -sf libGLESv2-${backend}.so /usr/lib/libGLESv2.so
# ln -sf libGLESv2-${backend}.so /usr/lib/libGLESv2.so.2
# ln -sf libGLESv2-${backend}.so /usr/lib/libGLESv2.so.2.0.0
# ln -sf libVIVANTE-${backend}.so /usr/lib/libVIVANTE.so
# ln -sf libGAL_egl.dri.so /usr/lib/libGAL_egl.so
# for i in egl glesv1_cm glesv2 vg; do
        cp /usr/lib/pkgconfig/${i}_${backend}.pc/usr/lib/pkgconfig/${i}.pc
    done
#rm /usr/lib/*-dfb.so /usr/lib/*-fb.so /usr/lib/*-wl.so
(Optional in case you deploy your kernel version with GPU as module) make vivante kernel module (GPU kernel driver) load on boot:
# echo vivante >> /etc/modules
# nano /etc/udev/rules.d/10-imx.rules
KERNEL=="galcore",  MODE="0660", GROUP="video"
KERNEL=="mxc_asrc",  MODE="0666"
Create an xorg.conf configured for the Vivante fbdev driver:
# nano /etc/X11/xorg.conf
Section "Device"
    Identifier "i.MX Accelerated Framebuffer Device"
    Driver "vivante"
    Option "fbdev" "/dev/fb0"
    Option "vivante_fbdev" "/dev/fb0"
    Option "HWcursor" "false"
EndSection
Section "ServerFlags"
    Option "BlankTime"  "0"
    Option "StandbyTime"  "0"
    Option "SuspendTime"  "0"
    Option "OffTime"  "0"
EndSection
# cd ..
Make sure the files copied into the correct places.
If all compiled and copied, you should now see a bunch of new libraries in /usr/lib! Congratulations! After you finish you can reboot your system and start playing.
Testing Gstreamer examples:
  • show gstreamer-imx plugins:
# gst-inspect-1.0 | grep imx
imxvpu:  imxvpuenc_mjpeg: Freescale VPU motion JPEG video encoder
imxvpu:  imxvpuenc_mpeg4: Freescale VPU MPEG-4 video encoder
imxvpu:  imxvpuenc_h264: Freescale VPU h.264 video encoder
imxvpu:  imxvpuenc_h263: Freescale VPU h.263 video encoder
imxvpu:  imxvpudec: Freescale VPU video decoder
imxv4l2videosrc:  imxv4l2videosrc: V4L2 CSI Video Source
imxg2d:  imxg2dcompositor: Freescale G2D video compositor
imxg2d:  imxg2dvideotransform: Freescale G2D video transform
imxg2d:  imxg2dvideosink: Freescale G2D video sink
imxipu:  imxipucompositor: Freescale IPU video compositor
imxipu:  imxipuvideosink: Freescale IPU video sink
imxipu:  imxipuvideotransform: Freescale IPU video transform
imxpxp:  imxpxpvideotransform: Freescale PxP video transform
imxpxp:  imxpxpvideosink: Freescale PxP video sink
  • imxipuvideosink:
# gst-launch-1.0 videotestsrc ! imxipuvideosink
imxg2dvideosink:
# gst-launch-1.0 videotestsrc ! imxg2dvideosink
The imxeglvivsink allows hardware accelerated display to a window on the X11 host
# export DISPLAY=:0.0
# gst-launch-1.0 videotestsrc ! imxeglvivsink
To test if you have graphics support you can run any glmark2 and/or mesa-utils or can run example of the next route:
# cd /opt/viv_samples/vdk/
# ./tutorial1        //any example
root@imx6Q:~# glxgears -info
GL_RENDERER   = Vivante GC2000
GL_VERSION    = 2.1 2.0.1
GL_VENDOR     = Vivante Corporation
GL_EXTENSIONS = WGL_ARB_extensions_string WGL_EXT_extensions_string WGL_EXT_swap_control GL_EXT_texture_env_add GL_ARB_multitexture GL_ARB_multisample GL_ARB_texture_env_add GL_ARB_texture_compression GL_ARB_texture_env_combine GL_ARB_depth_texture GL_ARB_window_pos ….
1606 frames in 5.0 seconds = 321.130 FPS
1650 frames in 5.0 seconds = 329.834 FPS
GL_VENDOR     = Vivante Corporation1629 frames in 5.0 seconds = 325.644 FPS
1621 frames in 5.0 seconds = 324.072 FPS
1650 frames in 5.0 seconds = 329.806 FPS
1651 frames in 5.0 seconds = 330.079 FPS
评论
How to connect it to HDMI Display?
Is there any additional changes or If I connect to HDMI it will show desktop??
HI,
Does somebody encounter /bin/sh 1: arm-linux-gnueabihf-gcc not found issue? this is a symlink to arm-linux-gnueabihf-gcc-4.9.4.
any fix to it is highly appreciated.
Thanks aheard.
wenming
Hi all,
I find the gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz compiler not working on ubuntu14.04, I tried with gcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx works.
Regards!
Wenming
Hi, thanks for this excellent doc, and I have a question on rootfs system. I am using imx6 sabrelite board and have exactly followed the guidelines in this doc. I cross compiled all the files on an Ubuntu platform, and after the unmount and inserted the SD card to my board. The kernel boot process requests 6x_bootscript file and it seems like the older uBoot is operating fron Nand Flash. How should I solve this issue by setting my own uBoot to prompt and load rootfs and zImage ?
Hi Anuradha, please refer to https://community.nxp.com/message/836641?commentID=836641&et=watches.email.thread#comment-836641  this doc, about old uboot with new kernel.
Hi Anuradha,
Actually for SabreLite you don't need to follow the above instructions, we already provide an Ubuntu image ready to go:
https://boundarydevices.com/ubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15/
Or if you'd rather use Debian:
https://boundarydevices.com/debian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28/
Note that in our case all the NXP components like the graphics library, VPU support, Chrome hw acceleration are packaged. That means that when a new graphics library version is out, you just need to do "apt update && apt upgrade" and you are up-to-date.
Hope this helps.
Gary
Hi Gary, thanks for your reply. Now the situation is like this :
I want to interface an analog TV encoder (adv7343) to the RGB port of the imx6 (in BDSL). According to what I have researched, I need adding few modifications to the mxc_lcd.if of the linux kernel (3.14.52_1.1.0_ga) to use lcd driver in V_SYNC | H_SYNC mode to support this encoder. So I have no option (or do I?) rather than building a new kernel (as these drivers are builtin modules), and that's why I thought of building a bootable SD card myself.
I think the steps I followed in preparing SD should be okay, but to note what I've done in brief :
cd binary/
sync
//------------create partition table
sudo fdisk ${DISK}
d       //delete all partitions currently on sd
2048 //default
+1G    //
p
2
default
default
w
sudo cp –v binary/ i$target-$board.dtb /media/kernel_target    //dtb file
sudo cp –v binary/uImage /media/kernel_target                        //uImage
sudo mv /media/rootfs/* /media/rootfs_target                             //root file sys
As you said the NAND flashed uboot already has required environment variables, and the uboot 'print' is attached to this comment. Now after the uboot prompt, I get the following message in console terminal :
switch to partitions #0, OK
mmc1 is current device
MMC read: dev # 1, block # 2048, count 16384 ... 16384 blocks read: OK
MMC read: dev # 1, block # 20480, count 2048 ... 2048 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
So from this point, how should I proceed ? do these environment variables cause the issue or is SD card preparation wrong?
Thanks in advance !
My uboot print (couldn't find the document attachment option)
baudrate=115200
board=sabrelite
bootargs=console=ttymxc0,115200 root=/dev/mmcblk2p1 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk2p1 rootwait rw
bootcmd=run bootcmd_mmc
bootcmd_mmc=run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x4000;mmc read ${fdt_addr} 0x5000 0x800;bootm ${loadaddr} - ${fdt_addr}
bootdelay=3
bootdevs=sata mmc usb
clearenv=if sf probe || sf probe || sf probe 1 ; then sf erase 0xc0000 0x2000 && echo restored environment to factory default ; fi
cmd_hdmi=fdt set fb_hdmi status okay;fdt set fb_hdmi mode_str 1280x720M@60;
cmd_lcd=fdt set fb_lcd status disabled
cmd_lvds=fdt set fb_lvds status disabled
console=ttymxc1
cpu=6Q
dfu_alt_info=u-boot raw 0x0 0xc0000
ethact=FEC
ethaddr=00:19:b8:02:79:6c
ethprime=FEC
fdt_addr=0x18000000
fdt_high=0xffffffff
filesize=70c00
initrd_high=0xffffffff
kernel=uImage
loadaddr=0x80800000
loadsplash=if sf probe ; then sf read ${splashimage} c2000 ${splashsize} ; fi
reset_cause=1
rundfu=dfu 0 sf 0:0:25000000:0
stdout=serial,vga
uboot_defconfig=nitrogen6q
umsdevs=sata mmc
upgradeu=for dtype in ${bootdevs}; do for disk in 0 1 ; do ${dtype} dev ${disk};load ${dtype} ${disk}:1 10008000 /6x_upgrade && source 10008000 ; done ; done
usbnet_devaddr=00:19:b8:00:00:02
usbnet_hostaddr=00:19:b8:00:00:01
usbrecover=setenv ethact usb_ether; setenv ipaddr 10.0.0.2; setenv netmask 255.255.255.0; setenv serverip 10.0.0.1;
setenv bootargs console=ttymxc1,115200; tftp boot 10800000 10.0.0.1:uImage-${board}-recovery&& tftpboot 12800000 10.0.0.1:uramdisk-${board}-recovery.img && bootm 10800000 12800000
Environment size: 1701/8188 bytes
=> boot
Please use the flashing procedure from our Ubuntu release blog post.
Gary
Hi ,
I build one following the guidance for my im53qsb reference board. But I got kernel panic at imx5_pm_init, I am using the imx_v7_defconfig, is anybody else has this issue or has fix for this issue or can I remove the pm configuration.
U-Boot 2015.04 (Oct 04 2016 - 12:17:39)
Board: MX53 LOCO
I2C: ready
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: FEC
Hit any key to stop autoboot: 0
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
5997120 bytes read in 346 ms (16.5 MiB/s)
Booting from mmc ...
reading imx53-qsrb.dtb
24491 bytes read in 19 ms (1.2 MiB/s)
Kernel image @ 0x72000000 [ 0x000000 - 0x5b8240 ]
## Flattened Device Tree blob at 71000000
Booting using the fdt blob at 0x71000000
Loading Device Tree to 8f552000, end 8f55afaa ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.14.38 (lucid@ubuntu) (gcc version 4.8.5 (Linaro GCC 4.8-2015.06) ) #1 SMP PREEMPT Wed Oct 5 06:56:31 PDT 2016
CPU: ARMv7 Processor [412fc085] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX53 Quick Start Board
cma: CMA: reserved 320 MiB at bc000000
Memory policy: Data cache writeback
CPU: All CPU(s) started in SVC mode.
PERCPU: Embedded 8 pages/cpu @cb33f000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259072
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 699820K/1048576K available (7423K kernel code, 456K rwdata, 2584K rodata, 384K init, 432K bss, 348756K reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0x80000000 - 0xe0000000 (1536 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x809ce000 (10008 kB)
.init : 0x809ce000 - 0x80a2e080 ( 385 kB)
.data : 0x80a30000 - 0x80aa20c0 ( 457 kB)
.bss : 0x80aa20cc - 0x80b0e25c ( 433 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
NR_IRQS:16 nr_irqs:16 16
TrustZone Interrupt Controller (TZIC) initialized
CPU identified as i.MX53, silicon rev 2.1
Switching to timer-based delay loop
sched_clock: 32 bits at 33MHz, resolution 30ns, wraps every 128849019873ns
clocksource_of_init: no matching clocksources found
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket -1, mpidr 0
Setting up static identity map for 0x70710420 - 0x70710478
Brought up 1 CPUs
SMP: Total of 1 processors activated (66.66 BogoMIPS).
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
Use WDOG1 as reset source
syscon 53fa8000.iomuxc-gpr: regmap [mem 0x53fa8000-0x53fa800b] registered
hw-breakpoint: debug architecture 0x4 unsupported.
imx53-pinctrl 53fa8000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
3P2V: 3200 mV
usb_vbus: 5000 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbphy.1 supply vcc not found, using dummy regulator
usbphy.2 supply vcc not found, using dummy regulator
i2c i2c-1: IMX I2C adapter registered
da9052: probe of 0-0048 failed with error -5
i2c i2c-0: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
imx-ipuv3: probe of 18000000.ipu failed with error -22
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switched to clocksource mxc_timer1
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 2006
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
imx-sdma 63fb0000.sdma: no iram assigned, using external mem
imx-sdma 63fb0000.sdma: no event needs to be remapped
imx-sdma 63fb0000.sdma: Direct firmware load failed with error -2
imx-sdma 63fb0000.sdma: Falling back to user helper
imx-sdma 63fb0000.sdma: initialized
Serial: IMX driver
53fbc000.serial: ttymxc0 at MMIO 0x53fbc000 (irq = 47, base_baud = 4166666) is a IMX
console [ttymxc0] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
CAN device driver interface
63fec000.ethernet supply phy not found, using dummy regulator
libphy: fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usb_ehset_test
53f80800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
input: mma8450 as /devices/virtual/input/input0
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
coda 63ff4000.vpu: Direct firmware load failed with error -2
coda 63ff4000.vpu: Falling back to user helper
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt 53f98000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 50004000.esdhc [50004000.esdhc] using ADMA
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc1: SDHCI controller on 50020000.esdhc [50020000.esdhc] using ADMA
mmc0: new high speed SDHC card at address 0007
Job Ring Device allocation for transform failed
mmcblk0: mmc0:0007 SD16G 14.5 GiB
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmcblk0: p1 p2
sgtl5000 1-000a: sgtl5000 revision 0x11
imx-sgtl5000 sound.8: phandle missing or invalid
imx-sgtl5000: probe of sound.8 failed with error -22
NET: Registered protocol family 26
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
Unable to handle kernel paging request at virtual address f51a000c
pgd = 80004000
[f51a000c] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.38 #1
task: c8068000 ti: c806c000 task.ti: c806c000
PC is at mx5_cpu_lp_set+0x10/0xfc
LR is at imx5_pm_init+0x64/0x80
pc : [<8001d804>] lr : [<809da58c>] psr: 60000113
sp : c806dedc ip : 00000072 fp : 00000000
r10: c806c038 r9 : 80a1ee7c r8 : 809d1190
r7 : 80aa2100 r6 : 80aa2100 r5 : 00000007 r4 : c801b600
r3 : f51a0000 r2 : 8001d8f0 r1 : 00000002 r0 : 00000002
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 70004019 DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xc806c238)
Stack: (0xc806dedc to 0xc806e000)
dec0: c801b600
dee0: 00000007 809da58c 80a2b80c 809d11b0 00000000 800088bc c800ccc0 808c7d28
df00: c8096200 80714144 00000000 00000000 00000000 8012a57c 00000000 80a446b0
df20: 60000113 00000001 cbfffc2e 8073b938 0000010b 800498e0 80996644 00000007
df40: cbfffc36 00000007 80a446a0 80a2b80c 00000007 80aa2100 80aa2100 809ce50c
df60: 80a1ee7c 0000010b 80a1ee74 809cec38 00000007 00000007 809ce50c 8070fbd8
df80: 00000000 00002100 80706164 00000000 00000000 00000000 00000000 00000000
dfa0: 00000000 80706170 00000000 8000e278 00000000 00000000 00000000 00000000
dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 80000220 08040010
[<8001d804>] (mx5_cpu_lp_set) from [<809da58c>] (imx5_pm_init+0x64/0x80)
[<809da58c>] (imx5_pm_init) from [<809d11b0>] (init_machine_late+0x20/0x28)
[<809d11b0>] (init_machine_late) from [<800088bc>] (do_one_initcall+0xf8/0x144)
[<800088bc>] (do_one_initcall) from [<809cec38>] (kernel_init_freeable+0x13c/0x1dc)
[<809cec38>] (kernel_init_freeable) from [<80706170>] (kernel_init+0xc/0xe8)
[<80706170>] (kernel_init) from [<8000e278>] (ret_from_fork+0x14/0x3c)
Code: e3a03000 e92d4030 e1a01000 e34f351a (e593c00c)
---[ end trace 65acb852349b9d5b ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
T
Have you chance to test it for i.MX 6QuadPlus SABRE-AI Board?
Can be used a newer BSP rel_imx_4.1.15_1.1.0_ga?
HI Erik,
I do not have a i.mx 6 QuadPlus board to try.
If you tried and share me the results.
Thanks!
Wenming
How can I redirect output to HDMI monitor?
I am trying to start the system but I got stuck at
* Stopping save kernel messages                                         [ OK ]
U-Boot 2015.04 (Nov 02 2016 - 23:46:14)
CPU: Freescale i.MX6QP rev1.0 at 792 MHz
CPU: Temperature 33 C
Reset cause: POR
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
PMIC: PFUZE100 ID=0x10
NAND: 0 MiB
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
reading boot.scr
reading zImage
6022776 bytes read in 309 ms (18.6 MiB/s)
reading imx6qp-sabreauto.dtb
46893 bytes read in 20 ms (2.2 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5be678 ]
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800e72c
Starting kernel ...
Linux version 3.14.52 (r59400@Latitude) (gcc version 4.8.5 (Linaro GCC 4.8-2015.06) ) #3 SMP PREEMPT Wed Nov 2 23:55:53 CET 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
Machine model: Freescale i.MX6 Quad Plus SABRE Automotive Board
cma: CMA: reserved 320 MiB at 6a000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @ee71d000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520720
Kernel command line: console=ttymxc3,115200 root=/dev/mmcblk2p2 rootwait rw
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1739228K/2097152K available (7452K kernel code, 460K rwdata, 2596K rodata, 392K init, 433K bss, 357924K reserved, 270336K highmem)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0x80000000 - 0xef800000 (1784 MB)
.text : 0x80008000 - 0x809d82d4 (10049 kB)
.init : 0x809d9000 - 0x80a3b080 ( 393 kB)
.data : 0x80a3c000 - 0x80aaf340 ( 461 kB)
.bss : 0x80aaf34c - 0x80b1b99c ( 434 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32070000, Cache size: 1024 kB
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10718008 - 0x10718060
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: Booted secondary processor
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: Booted secondary processor
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
CPU identified as i.MX6QP, silicon rev 1.0
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
vddarm: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV at 1150 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
mxs-dma 110000.dma-apbh: initialized
cs42888_supply: 3300 mV
3P3V: 3300 mV
vio1: 3300 mV
vio2: 3300 mV
vd: 3300 mV
va: 5000 mV
platform usb_h1_vbus.30: Driver reg-fixed-voltage requests probe deferral
platform usb_otg_vbus.31: Driver reg-fixed-voltage requests probe deferral
P3V3_SDa_SWITCHED: 3300 mV
usbphy_nop1.12 supply vcc not found, using dummy regulator
usbphy_nop2.13 supply vcc not found, using dummy regulator
i2c i2c-2: IMX I2C adapter registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-prg 21cc000.prg: driver probed
imx-prg 21cd000.prg: driver probed
imx-pre 21c8000.pre: driver probed
imx-pre 21c9000.pre: driver probed
imx-pre 21ca000.pre: driver probed
imx-pre 21cb000.pre: driver probed
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
imx_busfreq busfreq.16: DDR medium rate not supported.
futex hash table entries: 1024 (order: 4, 65536 bytes)
bounce pool size: 64 pages
msgmni has been set to 3508
backlight.17 supply power not found, using dummy regulator
mxc_sdc_fb fb.23: registered mxc display driver ldb
imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
mxc_sdc_fb fb.24: registered mxc display driver hdmi
mxc_sdc_fb fb.25: NO mxc display driver found!
mxc_sdc_fb fb.26: registered mxc display driver ldb
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.2
mxc_hdmi 20e0000.hdmi_video: Read EDID again
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1375 mV
SW1C: 300 <--> 1875 mV at 1375 mV
SW2: 800 <--> 1975 mV at 1375 mV
SW3A: 400 <--> 1975 mV at 1350 mV
SW3B: 400 <--> 1975 mV at 1350 mV
SW4: 800 <--> 1975 mV at 1825 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 800 <--> 1550 mV at 1200 mV
VGEN2: 800 <--> 1550 mV at 1500 mV
VGEN3: 1800 <--> 3300 mV at 1800 mV
VGEN4: 1800 <--> 3300 mV at 3000 mV
VGEN5: 1800 <--> 3300 mV at 2500 mV
VGEN6: 1800 <--> 3300 mV at 2800 mV
Serial: IMX driver
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61, base_baud = 5000000) is a IMX
mxc_hdmi 20e0000.hdmi_video: create default modelist
console [ttymxc3] enabled
brd: module loaded
loop: module loaded
si476x-core 1-0063: Using default platform data.
si476x-core 1-0063: No IRQ number specified, will use polling
si476x-core 1-0063: Error while sending command 0x11
si476x-core 1-0063: The device in inconsistent power state
ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
2094000.can supply xceiver not found, using dummy regulator
flexcan 2094000.can: device registered (reg_base=f0238000, irq=143)
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet eth0: registered PHC device 0
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
platform 2184000.usb: Driver imx_usb requests probe deferral
imx_usb 2184200.usb: Can't register ci_hdrc platform device, err=-517
platform 2184200.usb: Driver imx_usb requests probe deferral
egalax_ts 1-0004: Failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
2-0044 supply vdd not found, using dummy regulator
input: isl29023 light sensor as /devices/virtual/input/input1
isl29023 2-0044: driver version 1.0 enabled
snvs_rtc 20cc034.snvs-rtc-lp: can't get snvs-rtc clock
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video17
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video18
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video19
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video20
2-000e supply vdd not found, using dummy regulator
2-000e supply vddio not found, using dummy regulator
mag3110 2-000e: check mag3110 chip ID
input: mag3110 as /devices/virtual/input/input2
mag3110 2-000e: mag3110 is probed
2-001c supply vdd not found, using dummy regulator
2-001c supply vddio not found, using dummy regulator
ata1: SATA link down (SStatus 0 SControl 300)
ahci-imx 2200000.sata: no device found, disabling link.
ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
input: mma845x as /devices/virtual/input/input3
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Warning: No contiguous memory is reserverd for gpu.!
Warning: Will use default value(134217728) for the reserved memory!
Galcore version 5.0.11.41671
mmc2: Problem setting current limit!
mmc2: new ultra high speed DDR50 SDHC card at address aaaa
mmcblk2: mmc2:aaaa SU08G 7.40 GiB
mmcblk2: p1 p2
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_vpu 2040000.vpu: VPU initialized
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a160100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] e5 67 1a 32 44 12 3e 71
platform caam_sm: [0008] 35 de 20 2e 43 ce ec 82
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] d4 b2 d2 cd de 16 e3 b1
platform caam_sm: [0008] 13 7c 1e af 4c a4 40 14
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 3d 4f 1d c9 83 84 b5 8a
platform caam_sm: [0008] 50 8e de 15 8e 02 00 8d
platform caam_sm: [0016] 67 cd 31 2d c6 9c 13 60
platform caam_sm: [0024] 35 2d b7 c2 10 76 36 e9
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] c4 4e d7 b6 3e 43 2f 66
platform caam_sm: [0008] 36 df f3 c9 1c b4 d5 28
platform caam_sm: [0016] 4b 48 f0 e6 04 2e 87 2c
platform caam_sm: [0024] 30 f4 10 8d c6 91 bd 77
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 9c 5f c6 a9 06 33 a5 a5
platform caam_sm: [0008] de 27 35 d8 15 e5 a1 4f
platform caam_sm: [0016] f7 e1 e8 d0 74 23 fd a8
platform caam_sm: [0024] 68 81 69 46 49 13 17 3e
platform caam_sm: [0032] 9c fc 15 f5 39 0a c6 3d
platform caam_sm: [0040] d7 00 d0 49 9a bb 3f c3
platform caam_sm: [0048] e4 ef 05 f9 e5 38 da f8
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 84 6e 68 1d 03 6b f8 3b
platform caam_sm: [0008] 09 da 7c 60 70 f4 df 65
platform caam_sm: [0016] 95 b5 48 9d 70 e4 47 ca
platform caam_sm: [0024] e9 1f 5a e5 f0 43 26 a7
platform caam_sm: [0032] a9 90 65 92 42 ab fd 46
platform caam_sm: [0040] fb 3d e9 13 5c 24 f1 e9
platform caam_sm: [0048] 8b ca b4 c1 10 23 9d 66
platform caam_sm: [0056] 85 68 14 30 47 ce 43 c0
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 57 a6 97 3f 43 96 cf 87
platform caam_sm: [0008] 1f 72 89 a6 a0 ad 0e 48
platform caam_sm: [0016] 7a ad 5c e4 6e 37 04 3d
platform caam_sm: [0024] e4 95 c9 09 aa c7 12 bb
platform caam_sm: [0032] 56 3c d7 dc 03 6b 2f e1
platform caam_sm: [0040] 16 a8 c2 c3 78 7a 95 ce
platform caam_sm: [0048] 05 75 fc d4 a6 84 be d3
platform caam_sm: [0056] c7 df 01 4f bc 17 fd 9d
platform caam_sm: [0064] 98 25 68 26 f6 9b 5c 99
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] fe a8 22 dd 34 d2 00 3e
platform caam_sm: [0008] 7e e8 32 93 59 a4 96 72
platform caam_sm: [0016] 47 9a dd 3e fe 2a 83 27
platform caam_sm: [0024] 92 05 b2 c8 cc 3e fe 64
platform caam_sm: [0032] 9b 6b 2d 47 bc 58 ca 1c
platform caam_sm: [0040] 8d c2 b4 94 81 b1 80 bf
platform caam_sm: [0048] 0e 59 38 50 47 61 09 f4
platform caam_sm: [0056] 22 c2 fa 92 56 92 df 2e
platform caam_sm: [0064] 62 84 43 56 69 3a 85 f1
platform caam_sm: [0072] c4 f4 f7 54 46 4c 0b ca
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] c8 bd 51 12 0f 8c 3c 9b
platform caam_sm: [0008] 94 ac 86 67 55 65 75 24
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 47 6b e3 e8 62 6f 89 8f
platform caam_sm: [0024] 7c dc 6f eb cc 73 30 1c
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
cs42xx8 1-0048: found device, revision 4
fsl-asrc 2034000.asrc: driver registered
snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
imx-cs42888 sound-cs42888.27: cs42888 <-> 2024000.esai mapping ok
imx-cs42888 sound-cs42888.27: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
imx-spdif sound-spdif.20: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
imx-audio-hdmi sound-hdmi.21: hdmi-hifi <-> hdmi_audio.3 mapping ok
imx-tuner-si476x sound-fm.33: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm.33 failed with error -22
VGEN2: disabling
SWBST: disabling
SW4: disabling
regulator-dummy: disabling
imx mcc test is registered.
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys.18 as /devices/soc0/gpio-keys.18/input/input4
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
ALSA device list:
#0: cs42888-audio
#1: imx-spdif
#2: imx-hdmi-soc
usb 1-1: new high-speed USB device number 2 using ci_hdrc
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk2p2): using internal journal
EXT3-fs (mmcblk2p2): recovery complete
EXT3-fs (mmcblk2p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 392K (809d9000 - 80a3b000)
usb 1-1.2: new low-speed USB device number 3 using ci_hdrc
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
random: init urandom read with 68 bits of entropy available
input: DELL DELL USB Laser Mouse as /devices/soc0/soc.0/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C063.0001/input/input5
hid-generic 0003:046D:C063.0001: input: USB HID v1.10 Mouse [DELL DELL USB Laser Mouse] on usb-ci_hdrc.0-1.2/input0
usb 1-1.3: new low-speed USB device number 4 using ci_hdrc
init: plymouth-upstart-bridge main process (177) terminated with status 1
init: plymouth-upstart-bridge main process ended, respawning
init: plymouth-upstart-bridge main process (187) terminated with status 1
init: plymouth-upstart-bridge main process (190) terminated with status 1
input: Dell Dell QuietKey Keyboard as /devices/soc0/soc.0/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2106.0002/input/input6
hid-generic 0003:413C:2106.0002: input: USB HID v1.10 Keyboard [Dell Dell QuietKey Keyboard] on usb-ci_hdrc.0-1.3/input0
init: ureadahead main process (180) terminated with status 5
init: mounted-proc main process (204) terminated with status 1
DBG sensor data is at 7f010190
* Starting Mount filesystems on boot [ OK ]
* Stopping Send an event to indicate plymouth is up [ OK ]
* Starting Signal sysvinit that the rootfs is mounted [ OK ]
* Starting Clean /tmp directory [ OK ]
* Starting Populate and link to /run filesystem [ OK ]
* Stopping Populate and link to /run filesystem [ OK ]
* Stopping Clean /tmp directory [ OK ]
* Stopping Track if upstart is running in a container [ OK ]
* Starting Initialize or finalize resolvconf [ OK ]
* Starting Signal sysvinit that virtual filesystems are mounted [ OK ]
* ERROR: v4l2 capture: slave not found!
* Starting Bridge udev events into upstart [ OK ]
* Starting Signal sysvinit that local filesystems are mounted [ OK ]
* Starting Signal sysvinit that remote filesystems are mounted [ OK ]
* Stopping Mount filesystems on boot [ OK ]
* Starting device node and kernel event manager [ OK ]
* Starting flush early job output to logs [ OK ]
* Starting load modules from /etc/modules [ OK ]
* Starting cold plug devices [ OK ]
* Starting log initial device creation [ OK ]
* Stopping flush early job output to logs [ OK ]
* Stopping load modules from /etc/modules [ OK ]
* Starting set console font [ OK ]
* Starting system logging daemon [ OK ]
* Stopping set console font [ OK ]
* Starting userspace bootsplash [ OK ]
* Stopping userspace bootsplash [ OK ]
* Starting Send an event to indicate plymouth is up [ OK ]
* Starting configure network device security [ OK ]
* Starting configure network device [ OK ]
* Starting Mount network filesystems [ OK ]
* Starting Failsafe Boot Delay [ OK ]
* Stopping Mount network filesystems [ OK ]
* Starting Bridge socket events into upstart [ OK ]
* Starting Bridge file events into upstart [ OK ]
* Stopping Failsafe Boot Delay [ OK ]
* Starting System V initialisation compatibility [ OK ]
* Stopping System V initialisation compatibility [ OK ]
* Starting System V runlevel compatibility [ OK ]
* Starting save kernel messages [ OK ]
* Starting regular background program processing daemon [ OK ]
* Stopping System V runlevel compatibility [ OK ]
I did compile for 4.1.15 kernel but I need to set (configure) proper board instead of Board: MX6Q-Sabreauto revA
I need to have: MX6QP-Sabreauto
Where and how to configure it?
How can I redirect display to HDMI?
U-Boot 2016.03 (Nov 03 2016 - 11:28:37 +0100)
CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 28C
Reset cause: POR
I2C: ready
DRAM: 2 GiB
NAND: 0 MiB
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
Now I got Linaro, 14.10 image booting.. but still get into HDMI display and it's Serial console from PC.
How can I enable and run it form within HDMI monitor?
Secondly I followed  section 3: Modify Rootfs and Install needed packages  even though network, sources.list, hostname are not configured accordingly.. I change it on host PC and those setting are not reflected...
U-Boot 2016.03 (Nov 04 2016 - 11:24:24 +0100)
CPU: Automotive temperature grade (-40C to 125C) at 31C
Reset cause: POR
I2C: ready
DRAM: 2 GiB
NAND: 0 MiB
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
reading boot.scr
reading zImage
6637656 bytes read in 328 ms (19.3 MiB/s)
48853 bytes read in 20 ms (2.3 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x654858 ]
Using Device Tree in place at 18000000, end 1800eed4
Starting kernel ...
Linux version 4.1.15 (r59400@Latitude) (gcc version 4.8.5 (Linaro GCC 4.8-2015.06) ) #1 SMP PREEMPT Fri Nov 4 11:53:43 CET 2016
Reserved memory: created CMA memory pool at 0x6a000000, size 320 MiB
Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
PERCPU: Embedded 12 pages/cpu @ee6fe000 s16960 r8192 d24000 u49152
Memory: 1737928K/2097152K available (8295K kernel code, 435K rwdata, 2892K rodata, 432K init, 450K bss, 31544K reserved, 327680K cma-reserved, 270336K highmem)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
.text : 0x80008000 - 0x80af51c8 (11189 kB)
.init : 0x80af6000 - 0x80b62000 ( 432 kB)
.data : 0x80b62000 - 0x80bcec40 ( 436 kB)
.bss : 0x80bd1000 - 0x80c41a5c ( 451 kB)
Additional per-CPU info printed with stalls.
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76470001
mxc_clocksource_init 3000000
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Setting up static identity map for 0x10008280 - 0x100082d8
Brought up 4 CPUs
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
imx6q-pinctrl 20e0000.iomuxc: no groups defined in /soc/aips-bus@02000000/iomuxc@020e0000/hdmicecgrp
imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-1: can't use DMA
i2c i2c-2: can't use DMA
Bluetooth: Core ver 2.20
CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.23)
bounce: pool size: 64 pages
backlight supply power not found, using dummy regulator
mxc_sdc_fb fb@0: registered mxc display driver ldb
mxc_sdc_fb fb@1: registered mxc display driver hdmi
mxc_sdc_fb fb@2: NO mxc display driver found!
mxc_sdc_fb fb@3: registered mxc display driver ldb
imx-sdma 20ec000.sdma: loaded firmware 3.3
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 298, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 299, base_baud = 5000000) is a IMX
brd: module loaded
loop: module loaded
scsi host0: ahci-imx
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 313
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
IR RC5(x/sz) protocol handler initialized
IR Sharp protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
mxc_v4l2_output v4l2_out: V4L2 device registered as video18
mxc_v4l2_output v4l2_out: V4L2 device registered as video19
mxc_v4l2_output v4l2_out: V4L2 device registered as video20
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
/soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
218c000.mlb supply reg_nvcc not found, using dummy regulator
mxc_mlb150 218c000.mlb: enalbe regulator
mxc_vpu 2040000.vpu_fsl: VPU initialized
imx6q-pinctrl 20e0000.iomuxc: unable to find group for node hdmicecgrp
mxc_hdmi_cec soc:hdmi_cec@00120000: can't get/select CEC pinctrl
mmc2: new ultra high speed SDR104 SDHC card at address 0007
mmcblk2: mmc2:0007 SD32G 28.9 GiB
mmcblk2: p1 p2
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
platform caam_sm: [0000] b1 20 7c 0a 8a 86 61 07
platform caam_sm: [0008] f0 19 01 46 38 76 bd 49
platform caam_sm: [0000] 2f 06 82 1f cc b0 35 1f
platform caam_sm: [0008] 72 03 b1 f3 aa e0 3e b0
platform caam_sm: [0000] 1b b3 ad 95 d0 24 81 9a
platform caam_sm: [0008] fd b9 b8 4c 55 17 92 c4
platform caam_sm: [0016] ae af b5 6a ea 59 01 4f
platform caam_sm: [0024] 1b be de e8 dd 5c 8b 10
platform caam_sm: [0000] cf f7 16 54 2e 7b 19 e0
platform caam_sm: [0008] fe 96 8c 8b 3e 1b b3 f0
platform caam_sm: [0016] 38 35 bc 80 67 35 ed 58
platform caam_sm: [0024] e1 dd 73 11 85 8b 10 1f
platform caam_sm: [0000] 7c 66 1b 86 2d 1c b7 2d
platform caam_sm: [0008] 20 1f bb eb b4 00 1c 56
platform caam_sm: [0016] 8f b7 46 a6 40 58 28 49
platform caam_sm: [0024] 55 a0 50 1c 58 1d 43 a9
platform caam_sm: [0032] 06 3c 86 13 da 7d c1 6a
platform caam_sm: [0040] 3b 09 77 ee 3a ee 3f e6
platform caam_sm: [0048] 7e be 58 92 f4 b9 1d 4a
platform caam_sm: [0000] 61 a7 fd 69 ac 06 3c 35
platform caam_sm: [0008] 55 aa 49 66 c1 d2 ee 49
platform caam_sm: [0016] 04 af 80 4a fe 33 92 ab
platform caam_sm: [0024] 9c a7 c3 82 25 53 80 63
platform caam_sm: [0032] 22 3e 89 9a e6 d8 a6 54
platform caam_sm: [0040] c6 e6 f7 34 b6 1f 2c 9e
platform caam_sm: [0048] 5e 96 89 5e a6 fc 7f 87
platform caam_sm: [0056] 20 5f 7a 16 11 3b e7 ce
platform caam_sm: [0000] 23 2c cb 1b 73 ab 7d 23
platform caam_sm: [0008] f4 b0 f7 92 b2 78 0d 4c
platform caam_sm: [0016] b7 ba 1e 4d 05 6d 31 f5
platform caam_sm: [0024] ce c9 fd 0a ce 39 eb 94
platform caam_sm: [0032] cb b1 33 41 b7 f7 6b 26
platform caam_sm: [0040] 44 80 d7 26 36 25 ad 73
platform caam_sm: [0048] 87 a0 51 29 82 7f 9c d8
platform caam_sm: [0056] 2f 75 98 5f b7 50 f3 db
platform caam_sm: [0064] b3 39 17 c7 c9 90 c8 26
platform caam_sm: [0000] 49 ff 5a d8 79 44 e7 67
platform caam_sm: [0008] 96 87 75 f6 5c 8a 2e df
platform caam_sm: [0016] ae cc a1 b6 4a 31 f6 e8
platform caam_sm: [0024] 8d fd ad 8b 07 f3 e8 b0
platform caam_sm: [0032] c0 58 18 9b ae 02 bb ce
platform caam_sm: [0040] 38 fb 44 db 04 67 1b c7
platform caam_sm: [0048] 2c 15 75 41 8d c1 77 cf
platform caam_sm: [0056] a1 68 de 68 2d cd 24 e7
platform caam_sm: [0064] d5 7e e3 22 eb 7a 21 9d
platform caam_sm: [0072] 63 67 cf 3b 32 19 e0 03
platform caam_sm: [0000] 95 c8 a2 bc ac 2e 8e d7
platform caam_sm: [0008] f7 cc fa 5b b6 a5 5b 4b
platform caam_sm: [0016] 5f 82 48 34 d8 cb 15 a9
platform caam_sm: [0024] b0 6c fe c8 ee 8e cd 21
imx-cs42888 sound-cs42888: cs42888 <-> 2024000.esai mapping ok
imx-cs42888 sound-cs42888: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
imx-tuner-si476x sound-fm: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm failed with error -22
imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
can-stby: supplied by can-en
flexcan 2094000.flexcan: device registered (reg_base=f0648000, irq=31)
dhd_module_init in
input: gpio-keys as /devices/soc0/gpio-keys/input/input4
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
can-stby: disabling
can-en: disabling
VGEN2: disabling
SWBST: disabling
SW4: disabling
ALSA device list:
#0: cs42888-audio
#1: imx-spdif
#2: imx-hdmi-soc
input: DELL DELL USB Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C063.0001/input/input5
input: Dell Dell QuietKey Keyboard as /devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2106.0002/input/input6
devtmpfs: mounted
Freeing unused kernel memory: 432K (80af6000 - 80b62000)
random: init urandom read with 34 bits of entropy available
init: plymouth-upstart-bridge main process (175) terminated with status 1
init: plymouth-upstart-bridge main process (185) terminated with status 1
init: plymouth-upstart-bridge main process (189) terminated with status 1
init: ureadahead main process (178) terminated with status 5
DBG sensor data is at 7f010188
* Starting Populate /dev filesystem [ OK ]
* Stopping Populate /dev filesystem [ OK ]
* Starting set console keymap [ OK ]
* Stopping set console keymap [ OK ]
* Starting D-Bus system message bus [ OK ]
* Starting SystemD login management service [ OK ]
* Starting bluetooth daemon [ OK ]
* Starting mDNS/DNS-SD daemon [ OK ]
* Starting Reload cups, upon starting avahi-daemon to make sure remote q[ OK ]are populated
* Starting Reload cups, upon starting avahi-daemon to make sure remote q[fail]are populated
* Setting up X socket directories... [ OK ]
Last login: Thu Jan 1 00:00:23 UTC 1970 on tty1
Welcome to Linaro 14.04 (GNU/Linux 4.1.15 armv7l)
* Documentation: https://wiki.linaro.org/
root@linaro-alip:~#
First of all, thanks for this amazing post. Helped a lot. I have used the Linaro LXDE rootfs(partly because the ubuntu core link didnt work). Now apart from few hiccups I faced here and there in the process, I am able to boot the hardware and login from the serial console to the shell. But on the HDMI display I am shown a login window. I tried typing username 'root' and 'linaro' without any password(since I had removed the password from the root and linaro user as per the process above) and I am still stuck on the same window. I am unable to move past the login window and enter the GUI. Did anyone else face this. Please advise if I have missed something. Or I could just remove this login window manager and install another.
What imx board/chip do you use?
Hi Erik,
I am using iMX6 QP Sabre Board. Everything is working fine just that I am unable to login through the gui login manager.
Also I am facing another issue today. I installed gstreamer-imx and its plugins but I am getting an error with the audio codec plugin which is not working. When I run 'gst-inspect-1.0 -b' I get.
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
Blacklisted files:
libgstimxaudio.so
Total count: 1 blacklisted file
I dont understand why only audio plugin got blacklisted when I installed both fsl video and audio codec together. I have followed the links from this post. Also the error that it shows that it cannot open shared file, I checked the directory and the file is inside it.
Hi Erik
Any idea how to boot into desktop rather than to the login window I am getting. When I execute startx from serial console, it starts desktop environment on the screen. But by default, startlxde is getting executed and that takes me to the login page from where I cant login with any user. By default I want startx to load. (later I would like to just boot into just one gui application)
Hi Jaffin,
I'm in  pretty much the same situation: have you chance to resolve it?
Thank you.
Hi Erik,
   If you have also used Linaro LXDE then the default display manager is lxdm which is upstarted from /etc/init.d/. Lxdm uses /etc/lxdm/lxdm.conf for its configuration. I changed the default session to 'startx' to avoid the login page. Just a workaround for now.
More info here : LXDM - ArchWiki
Understand but on my side after install I can't run 'startx' command (command not found). I have my console on PC host side where I'm connected to the target via UART. On target itself I got Login screen which I can't go thru. I did changes as you suggested but no success.
Erik,
Maybe you have not installed xorg and xinit. Try that.
Finally I got login: After I got LXDE login screen which I needed to switch off the GUI and start in console mode via CTRL+ALT+F1 then I set passwd for root again and then switch back via CTRL+ALT+F7 and I did login as root.
Have you fixed gstreamer-imx somehow?
Nice. Do let me know if you figure out how to remove the login page completely from 'startlxde'.
I can login as root with no login screen automatically. this works for me
/etc/lxdm$ lxdm.conf
[base]
## uncomment and set autologin username to enable autologin
autologin=root
## uncomment and set timeout to enable timeout autologin,
## the value should >=5
# timeout=10
## default session or desktop used when no systemwide config
session=/usr/bin/startlxde
## uncomment and set to set numlock on your keyboard
# numlock=0
## set this if you don't want to put xauth file at ~/.Xauthority
# xauth_path=/tmp
## greeter used to welcome the user
greeter=/usr/lib/lxdm/lxdm-greeter-gtk
[server]
## arg used to start xserver, not fully function
# arg=/usr/bin/X -background vt1
[display]
## gtk theme used by greeter
gtk_theme=Clearlooks
## background of the greeter
bg=/usr/share/backgrounds/default.png
## if show bottom pane
bottom_pane=1
## if show language select control
lang=1
## if show keyboard layout select control
keyboard=0
## the theme of greeter
theme=Industrial
[input]
[userlist]
## if disable the user list control at greeter
disable=0
## whitelist user
white=
## blacklist user
black=
Cool. I had changed it to 'linaro' user which also doesnt have a password but still showed me login page. Anyways will try 'root.' But I was getting launched into desktop directly already so dont know if I should bother. Anyways thank for the info.
What error are you getting. I am still having the error messages I posted but my audio is working nonetheless so I stopped troubleshooting further on it until someone gives me an idea what should be done.
I connected USB disk and USB mouse to the USB Host port, but the devices were not able to be detected.
I can see following message during kernel booting up:
usb_otg_vbus: disabling
What could be the possible reasons?
Thanks!
Is there anyway to rotate LCD from landscape mode to portrait mode with ubuntu Linaro LXDE rootfs? Thanks!
Dears,
I'd like to continue with adding GPU HW Acceleration for X11 per instruction with that section and working within gpu_pack directory instructions say:
  1. # cd kernel-modu*
  2. # make
  3. Switch to gpu-core x11 backend:
  4. # backend=x11
Where kernel-modu* is coming from?
How kernel-modu* to create from?
I encounter a uboot compiler issue, when I try to build the wandboard_dl_defconfig.
Anybody else encounter this? share your fix.
LD examples/standalone/hello_world
OBJCOPY examples/standalone/hello_world.srec
OBJCOPY examples/standalone/hello_world.bin
LDS u-boot.lds
LD u-boot
arch/arm/imx-common/built-in.o: In function `print_cpuinfo':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/imx-common/cpu.c:199: undefined reference to `uclass_get_device'
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/imx-common/cpu.c:201: undefined reference to `thermal_get_temp'
arch/arm/imx-common/built-in.o: In function `arch_preboot_os':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/imx-common/cpu.c:270: undefined reference to `ldo_mode_set'
drivers/built-in.o: In function `read_cpu_temperature':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:43: undefined reference to `dev_get_platdata'
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:45: undefined reference to `dev_get_priv'
drivers/built-in.o: In function `imx_thermal_probe':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:226: undefined reference to `dev_get_platdata'
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:227: undefined reference to `dev_get_priv'
/home/lucid/toolchain/gcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: BFD (GNU Binutils) Linaro 2014.11-3-git 2.24.0.20141017 assertion fail /home/tcwg-buildslave/workspace/tcwg-make-release/label/tcwg-x86_64/target/arm-linux-gnueabihf/snapshots/binutils-gdb.git~linaro_binutils-2_24-branch@a93e252ee5250dba831e54f98336b40c7210dac7/bfd/elf32-arm.c:7710
/home/lucid/toolchain/gcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: error: required section '.rel.plt' not found in the linker script
/home/lucid/toolchain/gcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: final link failed: Invalid operation
make: *** [u-boot] Error 1
lucid@ubuntu:~/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga$
Thanks!
WF
I installed ubuntu Linaro LXDE desktop but the touch panel doesn't work. I confirmed the touch panel driver is ok. It generates input events when I cat /dev/input/event0 and touch the panel. But the ubuntu desktop does not have response. Anyone has advice on it? Thanks!
It seems now no way to build by this thread. I changed the gcc toolchain, still not compilable. But I can build one month ago, there should be some commits blocked the build.
Does someone else encounter the same issue as me currently?
I am using above steps to get ubuntu rootfs running on imx6q-sabrsd board. I am not able to build xserver-xorg-video-imx-viv-5.0.11.p7.4.
I am getting below error with linaro rootfs:
gcc -DCOMMIT="`git log -n 1 --format=%H``git diff-index --quiet HEAD || echo '-dirty'`" -DFIX_NO_MI_BACKINGSTORE -fvisibility=hidden -fPIC -DPIc
fatal: Not a git repository (or any of the parent directories): .git
gcc -shared -fPIC -o vivante_drv.so vivante_gal/vivante_gal_blit.o vivante_gal/vivante_gal_gpu.o vivante_gal/vivante_gal_surface.o vivante_fbde
make: Leaving directory `/root/gpu/xserver-xorg-video-imx-viv-5.0.11.p7.4/EXA/src'
make: *** DRI_1.10.4/src/: No such file or directory. Stop.
has anybody able to solve this issue?? Also has anybody tried brnigup with ubuntu-core rootfs? Link for ubuntu-core rootfs seems dead.
Prathamesh
Hi Pratham,
Do you used any patches?  I can not boot into rootfs on my mx6dl customer board, I only can start uboot and kernel. Kenerl will stop at waiting "Waiting for root device /dev/mmcblk0p2...
which version of toolchain are you used?
Thanks!
Wenming
Hi feng,
the issue "Waiting for root device /dev/mmcblk0p2.." , seems to be related to sd card initialization failure, once kernel comes up.
Try to boot from eMMc and see if you still get same issue.
I am using toolchain mentioned above in this post.
Prathamesh
Hi erikraynolds‌ ,
I have the same question as yours. There seems no folder named kernel-modu*.
Have you solved the problem now?
Thanks!
Kane
Hi Pratham,
I got the same issue with you. Do you get it worked?
Thanks!
Wenming
Hi, Prathamesh
You can run the command: git init as the the doc said to have a try.
You can open the ubuntu-core link in the Explorer and use another.
E.g in the link: Index of /ubuntu-core/vivid/daily-preinstalled/current
You may select vivid-preinstalled-core-armhf.tar.gz .
Kane
Hi Kane,
I export the BUILD_HARD_VFP=1 and XSERVER_GREATER_THAN_13=1 it will not make for the DRI_1.10.4/src/,
but I still got
fatal: bad default revision 'HEAD'
fatal: ambiguous argument 'HEAD': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
fsl_pixmap_ext.c:31:33: fatal error: X11/extensions/Xext.h: No such file or directory
#include <X11/extensions/Xext.h>
Does me missed some installed package?
BTW, as your mentioned vivid-preinstalled-core-armhf.tar.gz  are you tried and success to bring up the desktop for your imx6 board?
thanks!
Wenming
Hi Wenming,
Which rootfs did you choose? I think you may not choose the Linaro LXDE rootfs(E.g. linaro-trusty-alip-20141024-684.tar.gz) as mentioned in the doc above.
The  vivid-preinstalled-core-armhf.tar.gz I mentioned didn't have a GUI desktop, it just have a console terminal. And it seems that did not support the commands like apt-get.
But I also tried the rootfs linaro-trusty-alip-20141024-684.tar.gz as same as the doc. And I can succeed to bring up the desktop in i.MX6Q SABRE SD, but there's some issues about how to find the GPU Vivante and play tutorials.
Besides, I did not find the folder named kernel-modu* as the doc said, have you?
  1. # ./fastbuild.sh  BUILD_HARD_VFP=1 XSERVER_GREATER_THAN_13=1
  2. # cd..
  3.
  4. # cd kernel-modu*
  5. # make
  6. Switch to gpu-core x11 backend:
  7. # backend=x11
All the Best
Kane
Hi Wenming,
You may try command: apt-get install libxtst-dev to overcome the fatal error: X11/extensions/Xext.h: No such file or directory.
All the Best
Kane
Hi @Bio_TICFSL,
Thanks for your excellent doc!!
There's two questions I have get now.
1. I did not find the folder named kernel-modu* as the doc said, where is it?
  2. # cd..
  3.
  5. # make
  7. # backend=x11
2. And when I use the rootfs named linaro-jessie-alip-20160428-22.tar.gz(debian based ubuntu 16.04), I can not successfully login to the console:
[FAILED] Failed to start Login Service.
See 'systemctl status systemd-logind.service' for details.
[ OK ] Started Permit User Sessions.
[FAILED] Failed to start LSB: Load kernel mo...eeded to enable cpufreq scaling.
See 'systemctl status loadcpufreq.service' for details.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started LSB: network benchmark.
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started Initialize hardware monitoring sensors.
[ TIME ] Timed out waiting for device dev-ttymxc0.device.
[DEPEND] Dependency failed for Serial Getty on ttymxc0.
[FAILED] Failed to start Network Manager.
See 'systemctl status NetworkManager.service' for details.
So how to login to the console, any ideas?
All the Best
Kane
Hi Kane,
I am used the linaro-trusty-alip-20141024-684.tar.gz , I can not start the desktop for my imx6dl customer board, I used an OSD-WVGA lcd to connect with ipu.di0/fb0. for the ubuntu core version I can not boot into console.
about the kernel-modu* there is a link in the note:ventana/ubuntu – Gateworks  section 2, what I do just ignore the cd kernel-modu* make, I just cd /usr/lib to do the ln -sf . the fastbuild.sh only build the vivante_drv.so, the vivante_dri.so is copy from gpu_core. I can not find any folder name kernel-modu* maybe a mistake.
BTW,
what is you video= line,
Thanks!
Wenming
Hi Wenming,
I ignore the cd kernel-modu* too.
My board is i.mx6q sabre sd and I use a LVDS display. Have you try the toolchain gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz as the doc discribed?
You can search "Kane Jiang" in the Skype for Business.
All the Best
Kane Jiang
I am using imx6q-sabresd board. I am following steps from Installing Ubuntu Rootfs on NXP i.MX6 boards
My kernel version is 3.14.52 and i am using ubuntu Rootfs 14.04.
My Xorg xserver version is 1.15.1.
I am observing that if i enable PCI bus support in the kernel, then i am not able to use x11 gpu hardware acceleration(glxgears and es2gears give segmentation faults).
But if i disable PCI support , i could use x11 gpu hardware acceleration with above mentioned versions of xserver.
What role is PCI drivers playing in x11 hardware acceleration? How to get x11 acceleration working with PCI bus support enabled.
Has anyone faced similar issue? Is there any fix for this or patches for pci or drm drivers??
Thanks for this great post ! My goal is to run an Ubuntu 14.04 or higher on my IMX6Q SABRE SD board from the mmc card. I am following the post.
The following link is not valid any more:
https://releases.linaro.org/14.09/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.9-2...
I replace it by the following one:
https://releases.linaro.org/archive/14.09/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz
But it does not work, I get the following strange error: (same error described by wenming feng)
/bin/sh: 1: /home/guillaume/gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf-gcc: not found
If I select this toolchain, I can compile:
gcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx
But I am generating an Image file and NOT a zImage file. And u-boot does not take it (bad linux arm zimage magic error at u boot runtime). It seems that it exists uImage, Image and zImage. Image would correspond to a 64bit image if I understand correctly.
Question 1: Which toolchain or option I have to use/set to generate a zImage ? (and not an Image)
Question 2: Would it be possible to update this post with up to date links ?
Question 3: Is there somewhere an already builded .sdcard for SABRE SD with everything on it (u-boot, kernel, dtb, ubuntu 14.04 or higher ..) ?
Guillaume HUGUES
Basically, I found the solution. To generate a zImage instead of Image, you have to enter make menuconfig and select this option
Gzip is not the defaut choice.
Now I have a ubuntu 14.04 running on my I.MX6Q SABRESD board. Thanks for this essential post !
%3CLINGO-SUB%20id%3D%22lingo-sub-1108497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E6%9C%AC%E6%96%87%E8%AF%A6%E7%BB%86%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%9C%A8%E4%BB%BB%E6%84%8Fi.Mx6x%20NXP%E6%9D%BF%E4%B8%AD%E5%AE%89%E8%A3%85%E5%9F%BA%E4%BA%8EUbuntu%E5%8F%91%E8%A1%8C%E7%89%88%E7%9A%84%E8%AE%BE%E7%BD%AE%E7%BB%86%E8%8A%82%E3%80%82%E5%85%B7%E4%BD%93%E8%AF%B4%E6%98%8E%E8%AF%A6%E8%A7%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E1.%20%E9%80%89%E6%8B%A9%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%EF%BC%8C%E8%AE%BE%E7%BD%AE%E4%B8%BB%E6%9C%BA%EF%BC%8C%E4%B8%8B%E8%BD%BD%E5%B9%B6%E7%BC%96%E8%AF%91%20uboot%E3%80%81dtb%20%E4%BB%A5%E5%8F%8A%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E5%88%B0%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E2.%20%E5%AE%89%E8%A3%85%20Ubuntu%20%E6%A0%B8%E5%BF%83%E3%80%81Lubuntu%20%E5%9B%BE%E5%BD%A2%E6%A1%8C%E9%9D%A2%E7%89%88%E6%9C%AC%EF%BC%8C%E6%88%96%E4%BD%BF%E7%94%A8%20debootstrap%20%E6%9E%84%E5%BB%BA%E6%82%A8%E8%87%AA%E5%B7%B1%E7%9A%84%20Ubuntu%20%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E3.%20%E4%BF%AE%E6%94%B9%20rootfs%20%E5%B9%B6%E5%AE%89%E8%A3%85%E6%89%80%E9%9C%80%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E4.%20%E4%BD%BF%E7%94%A8%20SD%20%E5%9B%BE%E5%83%8F%E8%BF%9B%E8%A1%8C%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E5.%20%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%E8%AE%BE%E7%BD%AEUbuntu%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E6.%20%E6%B7%BB%E5%8A%A0GPU%E5%8A%A0%E9%80%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22Subtitulo%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2014pt%3B%20color%3A%20%23e23d39%3B%22%3E1%3A%20%E9%80%89%E6%8B%A9%E6%82%A8%E7%9A%84%E6%9D%BF%EF%BC%8C%E8%AE%BE%E7%BD%AE%E4%B8%BB%E6%9C%BA%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%9D%BF%E4%B8%8A%E4%B8%8B%E8%BD%BD%E5%92%8C%E7%BC%96%E8%AF%91uboot%E3%80%81dtb%E4%BB%A5%E5%8F%8A%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E6%94%AF%E6%8C%81%E7%9A%84%20NXP%20%E7%A1%AC%E4%BB%B6%E6%9D%BF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206QuadPlus%20SABRE-SD%20%E5%BC%80%E5%8F%91%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206Quad%20SABRE-SD%20%E4%B8%BB%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206DualLite%20SABRE-SD%20%E4%B8%BB%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206Quad%20SABRE-AI%E7%94%B5%E8%B7%AF%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206DualLite%20SABRE-AI%20%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206SoloX%20SABRE-SD%E7%94%B5%E8%B7%AF%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206SoloX%20SABRE-AI%E7%94%B5%E8%B7%AF%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E5%AE%89%E8%A3%85%E4%B8%BB%E6%9C%BA%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%88%E6%B5%8B%E8%AF%95%E7%89%88%E6%9C%AC%E4%B8%BA14.04%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22python%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594434795498978%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22565_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594434795498978%22%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20sudo%20apt-get%20install%20gparted%20git%20build-essential%20libncurses5%20wget%20u-boot-tools%20zlib1g-dev%20ncurses-dev%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ecmake%20libc-dev-armhf-cross%20pkg-config-arm-linux-gnueabihf%20build-essential%20checkinstall%20cmake%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Epkg-config%20lzop%20libc6%20libstdc%2B%2B6%20debootstrap%20qemu-user-static%20binfmt-support%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23606060%3B%20line-height%3A%2026px%3B%22%3E%E4%B8%8B%E8%BD%BD%E7%BC%96%E8%AF%91%E5%99%A8%E5%B7%A5%E5%85%B7%E9%93%BE%E5%B9%B6%E8%A7%A3%E5%8E%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594434795251957%22%20data-renderedposition%3D%22662.77783203125_50.000003814697266_1158_156%22%20jivemacro_uid%3D%22_14594434795251957%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20wget%20-c%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20tar%20xf%20gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%88%9B%E5%BB%BA%E9%80%9A%E7%94%A8%E5%8F%98%E9%87%8F%E7%8E%AF%E5%A2%83%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20target%3Dmx6q%20(e.g.%20processor%3A%20mx6sx%2C%20mx6d%2C%20mx6dl%2Cetc)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20board%3Dsabresd%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CSabresd%E3%80%81SabreAuto)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20ARCH%3Darm%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20CROSS_COMPILE%3D..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20unset%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%20LDFLAGS%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E4%B8%8B%E8%BD%BDu-boot%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E5%9C%A8%E5%8F%91%E5%B8%83%E6%AD%A4%E6%96%87%E6%A1%A3%E6%97%B6%EF%BC%8Cuboot%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BAimx_3.14.52%EF%BC%8C%E5%AE%83%E4%B9%9F%E9%80%82%E7%94%A8%E4%BA%8E%E5%85%B6%E4%BB%96%E7%89%88%E6%9C%AC%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%AF%B7%E6%A3%80%E6%9F%A5%E9%80%82%E5%90%88%E6%82%A8%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594434795058554%20jive_text_macro%22%20data-renderedposition%3D%22895.0000610351562_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_14594434795058554%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20wget%20%E2%80%93c%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%2Fsnapshot%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%2Fsnapshot%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20tar%20-xf%20uboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20uboot-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20%24targetboard_config%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20e.g.%20mx6qsabresd_config%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3ELinux%20%E5%86%85%E6%A0%B8%E3%80%81%E5%9B%BA%E4%BB%B6%E3%80%81%E5%A4%B4%E6%96%87%E4%BB%B6%E3%80%81%E6%A8%A1%E5%9D%97%E5%92%8C%20DTS%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594434794835555%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221029.4444580078125_50.000003814697266_1158_141%22%20jivemacro_uid%3D%22_14594434794835555%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20wget%20%E2%80%93c%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fsnapshot%2Flinux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fsnapshot%2Flinux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20tar%20xf%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20imx_v7_defconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20menuconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20-j4%20zImage%20modules%20dtbs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E5%B0%86%E6%82%A8%E7%9A%84%E5%9B%BE%E5%83%8F%E7%A7%BB%E5%8A%A8%E5%88%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594434794499495%20jive_text_macro%22%20data-renderedposition%3D%221196.1112060546875_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14594434794499495%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20uboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fu-boot.imx%20binary%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fboot%2FzImage%20binary%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fboot%2Fdts%2Fi%24target-%24board.dtb%20binary%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%B7%B2%E7%BB%8F%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E3%80%81%E8%AE%BE%E5%A4%87%E6%A0%91%E5%92%8C%E5%86%85%E6%A0%B8%E9%95%9C%E5%83%8F%EF%BC%8C%E6%8E%A5%E4%B8%8B%E6%9D%A5%E8%AE%A9%E6%88%91%E4%BB%AC%E5%88%9B%E5%BB%BA%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20color%3A%20%23e23d39%3B%22%3E2%EF%BC%9A%E5%AE%89%E8%A3%85%20Ubuntu%20%E6%A0%B8%E5%BF%83%E3%80%81Lubuntu%20%E5%9B%BE%E5%BD%A2%E6%A1%8C%E9%9D%A2%E7%89%88%E6%9C%AC%EF%BC%8C%E6%88%96%E4%BD%BF%E7%94%A8%20debootstrap%20%E6%9E%84%E5%BB%BA%E6%82%A8%E8%87%AA%E5%B7%B1%E7%9A%84%20Ubuntu%20%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EInstalling%20ubuntu%20core%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435070879416%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221363.1944580078125_50.000003814697266_1158_234%22%20jivemacro_uid%3D%22_14594435070879416%22%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3Ecd%20~%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20mkdir%20%E2%80%93p%20core%20%2Fmedia%2Frootfs%20%2Fmedia%2Fkernel%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20wget%20%E2%80%93c%20%3CA%20href%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Freleases%2F14.04%2Frelease%2Fubuntu-core-14.04.4-core-armhf.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Freleases%2F14.04%2Frelease%2Fubuntu-core-14.04.4-core-armhf.tar.gz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20tar%20%E2%80%93xf%20ubuntu-core-14.04.4-core-armhf.tar.gz%20%E2%80%93C%20core%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20-vr%20core%2F*%20%2Fmedia%2Frootfs%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20modules_install%20firmware_install%20INSTALL_MOD_PATH%3D%2Fmedia%2Frootfs%2F%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%20headers_install%20INSTALL_HDR_PATH%3D%2Fmedia%2Frootfs%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E5%B0%86ubuntu%20rootfs%E6%94%BE%E5%9C%A8%2Fmedia%2Frootfs%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%8C%E5%B9%B6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E7%BB%A7%E7%BB%AD%E9%98%85%E8%AF%BB%E6%9C%AC%E5%B8%96%E6%96%87%E7%9A%84%E7%AC%AC3%E9%83%A8%E5%88%86%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EInstalling%20ubuntu%20Linaro%20LXDE%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435070643311%20jive_text_macro%22%20data-renderedposition%3D%221675.6251220703125_50.000003814697266_1158_218%22%20jivemacro_uid%3D%22_14594435070643311%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mkdir%20%E2%80%93p%20core%20%2Fmedia%2Frootfs%20%2Fmedia%2Fkernel%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.10%2Fubuntu%2Ftrusty-images%2Falip%2Flinaro-trusty-alip-20141024-684.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.10%2Fubuntu%2Ftrusty-images%2Falip%2Flinaro-trusty-alip-20141024-684.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2F14.10%2Fubuntu%2Ftrusty-images%2Falip%2Flinaro-trusty-alip-20141024-684.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20tar%20-xf%20linaro-trusty-alip-20141024-684.tar.gz%20%E2%80%93C%20core%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mv%20core%2Fbinary%2F*%20core%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20rm%20%E2%80%93rf%20core%2Fbinary%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20cp%20-vr%20core%2F*%20%2Fmedia%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20make%20modules_install%20firmware_install%20INSTALL_MOD_PATH%3D%2Fmedia%2Frootfs%2F%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20make%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%20headers_install%20INSTALL_HDR_PATH%3D%2Fmedia%2Frootfs%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22white-space%3A%20pre%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E5%B0%86ubuntu%20rootfs%E6%94%BE%E5%9C%A8%2Fmedia%2Frootfs%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%8C%E5%B9%B6%3C%2FSPAN%3E%3CSPAN%20style%3D%22white-space%3A%20pre%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E7%BB%A7%E7%BB%AD%E9%98%85%E8%AF%BB%E6%9C%AC%E5%B8%96%E6%96%87%E7%9A%84%E7%AC%AC3%E9%83%A8%E5%88%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%20debootstrap%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435070387076%22%20data-renderedposition%3D%221971.3890380859375_50.000003814697266_1158_124%22%20jivemacro_uid%3D%22_14594435070387076%22%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20target%3Drootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20distro%3Dtrusty%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20sudo%20debootstrap%20--arch%3Darmhf%20--foreign%20--include%3Dubuntu-keyring%2Capt-transport-https%2Cca-certificates%2Copenssl%20%24distro%20%22%24target%22%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fports.ubuntu.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%2Fusr%2Fbin%2Fqemu-arm-static%20%24target%2Fusr%2Fbin%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%2Fetc%2Fresolv.conf%20%24target%2Fetc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E7%8E%B0%E6%9C%89%E6%9C%80%E5%B0%8F%E5%8C%96Ubuntu%20rootfs%EF%BC%8C%E9%9C%80%E9%80%9A%E8%BF%87chroot%E5%90%AF%E5%8A%A8%E5%B9%B6%E6%89%A7%E8%A1%8C%E7%AC%AC%E4%BA%8C%E9%98%B6%E6%AE%B5%E7%9A%84%E5%AE%89%E8%A3%85%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435069697394%20jive_text_macro%22%20data-renderedposition%3D%222121.388916015625_50.000003814697266_1158_707%22%20jivemacro_uid%3D%22_14594435069697394%22%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20chroot%20%24target%26nbsp%3B%20%2F%2F%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%AC%E5%B7%B2%E8%BF%9B%E5%85%A5chroot%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20distro%3Dtrusty%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20export%20LC_ALL%3DC%20LANGUAGE%3DC%20LANG%3DC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20%2Fdebootstrap%2Fdebootstrap%20--second-stage%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E7%BC%96%E8%BE%91sources.list%E5%AD%98%E5%82%A8%E5%BA%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20cat%20%26lt%3B%3CEOT%3E%20%2Fetc%2Fapt%2Fsources.list%3C%2FEOT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20%24distro%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20%24distro-updates%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20%24distro-security%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3EEOT%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-key%20adv%20--recv-keys%20--keyserver%20keyserver.ubuntu.com%2040976EAF437D05B5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-key%20adv%20--recv-keys%20--keyserver%20keyserver.ubuntu.com%203B4FE6ACC0B21F32%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-get%20update%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt%20-y%20-f%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-get%20upgrade%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-get%20install%20nano%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E6%97%A0%E9%9C%80%E5%AF%86%E7%A0%81%E7%99%BB%E5%BD%95%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20passwd%20%E5%91%BD%E4%BB%A4%E8%AE%BE%E7%BD%AE%E4%B8%80%E4%B8%AA%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E6%B7%BB%E5%8A%A0%E8%87%AA%E5%AE%9A%E4%B9%89%E7%94%A8%E6%88%B7%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20passwd%20root%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20adduser%20%3CMYUSER%3E%3C%2FMYUSER%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%20usermod%20-a%20-G%20tty%20myuser%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20usermod%20-a%20-G%20dialout%2C%20adm%2C%20sudo%2C%20dip%2C%20plugdev%20myuser%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20visudo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%9C%A8%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E7%9A%84%E8%A1%8C%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eroot%20ALL%3D(ALL%3AALL)%20ALL%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%88%E5%B0%86%E5%BD%93%E5%89%8D%E7%94%A8%E6%88%B7%E5%90%8D%E6%9B%BF%E6%8D%A2%E4%B8%BA%E6%82%A8%E7%9A%84%E5%AE%9E%E9%99%85%E7%94%A8%E6%88%B7%E5%90%8D%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CMYUSER%3E%20ALL%3D(ALL)%20ALL%3C%2FMYUSER%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%82%A8%E7%9A%84rootfs%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%EF%BC%8C%E8%AF%B7%E9%80%80%E5%87%BAchroot%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20%E9%80%80%E5%87%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20rm%20%24target%2Fetc%2Fresolv.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20rm%20%24target%2Fusr%2Fbin%2Fqemu-arm-static%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20mv%20rootfs%2F*%20%2Fmedia%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20modules_install%20firmware_install%20INSTALL_MOD_PATH%3D%2Fmedia%2Frootfs%2F%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%20headers_install%20INSTALL_HDR_PATH%3D%2Fmedia%2Frootfs%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%8E%B0%E5%9C%A8ubuntu%20rootfs%E5%B7%B2%E6%94%BE%E5%85%A5%2Fmedia%2Froot%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E3%EF%BC%9A%E4%BF%AE%E6%94%B9%20Rootfs%20%E5%B9%B6%E5%AE%89%E8%A3%85%E6%89%80%E9%9C%80%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%BC%96%E8%BE%91%E5%B9%B6%E9%AA%8C%E8%AF%81%20sources.list%20%E4%BB%93%E5%BA%93%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435642761323%22%20data-renderedposition%3D%222931.388916015625_50.000003814697266_1158_98%22%20jivemacro_uid%3D%22_14594435642761323%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20%2Fmedia%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cat%20%26lt%3B%3CEOT%3E%20etc%2Fapt%2Fsources.list%3C%2FEOT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%22%3Edeb%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%22%3E%20trusty%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20trusty-updates%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20trusty-security%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3EEOT%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%BC%96%E8%BE%91%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%E5%B9%B6%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%8E%B0%E6%9C%89%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435642499160%22%20data-renderedposition%3D%223054.722412109375_50.000003814697266_1158_78%22%20jivemacro_uid%3D%22_14594435642499160%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Fnetwork%2Finterfaces%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eauto%20lo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eiface%20lo%20inet%20loopback%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eauto%20eth0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eiface%20eth0%20inet%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20%23303030%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%8C%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22background%3A%20white%3B%22%3E%E8%AF%B7%E5%9C%A8%E6%96%87%E4%BB%B6%E6%9C%AB%E5%B0%BE%E7%A7%BB%E9%99%A4%E5%B9%B6%E6%B7%BB%E5%8A%A0ttymxc0%E8%BE%93%E5%87%BA%E8%A1%8C%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_1459443564220284%20jive_text_macro%22%20data-renderedposition%3D%223158.0556640625_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_1459443564220284%22%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435641951566%20jive_text_macro%22%20data-renderedposition%3D%223173.611328125_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594435641951566%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Finit%2Ftty1.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20line-through%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eexec%20%2Fsbin%2Fgetty%20-8%2038400%20tty1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eexec%20%2Fsbin%2Fgetty%20-L%20115200%20ttymxc0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E6%9B%B4%E6%94%B9%E6%9C%AC%E5%9C%B0%E4%B8%BB%E6%9C%BA%E5%90%8D%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435641679774%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223245.83349609375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594435641679774%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Fhostname%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%B9%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%E2%80%9C%E6%82%A8%E7%9A%84%E5%90%8D%E7%A7%B0%E2%80%9D%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9Aimx6Q%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E8%AE%BE%E7%BD%AE%E6%97%A5%E6%9C%9F%E5%92%8C%E6%97%B6%E9%97%B4%E6%97%B6%E9%92%9F%E5%B9%B6%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_1459443564136564%22%20data-renderedposition%3D%223302.500244140625_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_1459443564136564%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20%2Fetc%2Frc.local%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eif%20%5B%20%60date%20%2B%22%25Y%22%60%20-eq%20%221970%22%20%5D%3B%20then%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20date%20--set%3D%222016-04-01%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Efi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eexit%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435641048700%20jive_text_macro%22%20data-renderedposition%3D%223411.38916015625_50.000003814697266_1158_124%22%20jivemacro_uid%3D%22_14594435641048700%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%EF%BC%88%E5%8F%AF%E9%80%89%E7%94%A8%E4%BA%8E%20Linaro%20rootfs%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E7%BC%96%E8%BE%91%E5%AF%86%E7%A0%81%E5%B9%B6%E7%A7%BB%E9%99%A4root%E5%92%8Clinaro%E8%A1%8C%E4%B8%AD%E7%9A%84x%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Fpasswd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%3Ax%3A0%3A0%3Aroot%3A%2Froot%3A%2Fbin%2Fbash%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Elinaro%3Ax%3A0%3A0..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%AE%8C%E6%88%90%E4%BB%A5%E4%B8%8B%E6%9B%B4%E6%94%B9%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%3A%3A0%3A0%3Aroot%3A%2Froot%3A%2Fbin%2Fbash%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Elinaro%3A%3A%3A0%3A..%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20%23303030%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22background%3A%20white%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%AF%B9sd%E5%9B%BE%E5%83%8F%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background%3A%20white%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E4%EF%BC%9A%E5%AE%89%E8%A3%85microSD%2FSD%E5%8D%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%A0%B9%E6%8D%AE%E4%B8%8A%E8%BF%B0%E8%AF%B4%E6%98%8E%EF%BC%8C%E5%81%87%E8%AE%BE%EF%BC%9ADISK%3D%2Fdev%2Fsdg%E4%BD%8D%E4%BA%8E%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%EF%BC%8C%E5%9B%A0%E6%AD%A4cat%20%2Fproc%2Fpartitions%E9%80%82%E7%94%A8%E4%BA%8E%E7%A1%AE%E5%AE%9A%E8%AE%BE%E5%A4%87id%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435807757639%22%20data-renderedposition%3D%223638.0556640625_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594435807757639%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20export%20DISK%3D%2Fdev%2Fsdg%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E6%93%A6%E9%99%A4microSD%2FSD%E5%8D%A1%3C%2FSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435807475109%20jive_text_macro%22%20data-renderedposition%3D%223695.83349609375_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594435807475109%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20dd%20if%3D%2Fdev%2Fzero%20of%3D%24%7BDISK%7D%20bs%3D1M%20count%3D10%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%AE%89%E8%A3%85%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435807202965%22%20data-renderedposition%3D%223736.944580078125_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594435807202965%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20binary%2F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20dd%20if%3Du-boot.imx%20of%3D%24%7BDISK%7D%20bs%3D512%20seek%3D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20%E5%90%8C%E6%AD%A5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%88%9B%E5%BB%BA%E5%88%86%E5%8C%BA%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435806876462%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223809.166748046875_50.000003814697266_1158_379%22%20jivemacro_uid%3D%22_14594435806876462%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20fdisk%20%24%7BDISK%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%E6%AD%A5%E9%AA%A4%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ed%20%2F%2F%2F%E5%88%A0%E9%99%A4%E5%BD%93%E5%89%8D%E5%9C%A8SD%E5%8D%A1%E4%B8%8A%E7%9A%84%E6%89%80%E6%9C%89%E5%88%86%E5%8C%BA%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3En%20%2F%2F%20%E5%88%9B%E5%BB%BA%E6%96%B0%E5%88%86%E5%8C%BA%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ep%20%2F%2F%20%E4%B8%BB%E5%88%86%E5%8C%BA%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E1%20%2F%2F%20%E5%88%86%E5%8C%BA%E5%8F%B7%201%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E2048%20%2F%2Fdefault%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%2B1G%20%2F%2F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3En%20%2F%2F%20%E5%B7%B2%E5%88%9B%E5%BB%BA2d%E5%88%86%E5%8C%BA%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ep%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E2%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E9%BB%98%E8%AE%A4%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E9%BB%98%E8%AE%A4%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E1%20%2F%2F%20firts%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EB%20%2F%2F%20%E4%B8%BAfat32%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EW%20%2F%2F%20%E5%86%99%E5%85%A5%E5%88%86%E5%8C%BA%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20mkfs.vfat%20%24%7BDISK%7D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20mkfs.ext3%24%7BDISK%7D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%B0%86%20ext3%20SD%20%E5%88%86%E5%8C%BA%E6%8C%82%E8%BD%BD%E5%88%B0%20%2Fmedia%2Frootfs%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435806522942%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224238.4375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594435806522942%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mount%20%24%7BDISK1%7D%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mount%20%24%7BDISK%7D2%20%2Fmedia%2Frootfs_target%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%B0%86%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20SD%20%E5%8D%A1%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435806243344%20jive_text_macro%22%20data-renderedposition%3D%224295.1044921875_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14594435806243344%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20binary%2F%20i%24target-%24board.dtb%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20binary%2FzImage%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mv%20%2Fmedia%2Frootfs%2F*%20%2Fmedia%2Frootfs_target%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E7%A7%BB%E9%99%A4%20SD%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435805956657%20jive_text_macro%22%20data-renderedposition%3D%224382.88232421875_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594435805956657%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20%E5%90%8C%E6%AD%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20umount%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20umount%20%2Fmedia%2Frootfs_target%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%90%AF%E5%8A%A8%E7%9B%AE%E6%A0%87%EF%BC%8C%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BB%A5root%E8%BA%AB%E4%BB%BD%E7%99%BB%E5%BD%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435805666148%20jive_text_macro%22%20data-renderedposition%3D%224455.1044921875_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594435805666148%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eroot%40imx6QSabreSD%3A~%23%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20font-size%3A%2018.6667px%3B%22%3E5%EF%BC%9A%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%E8%AE%BE%E7%BD%AEUbuntu%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E7%94%A8%E6%88%B7%20UID%20%E4%B8%8B%E4%BD%BF%E7%94%A8%20sudo%20%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%B3%A8%E9%94%80%E5%B9%B6%E4%BB%A5%20root%20%E7%94%A8%E6%88%B7%E7%99%BB%E5%BD%95%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594437023562434%22%20data-renderedposition%3D%224547.32666015625_50.000003814697266_1158_78%22%20jivemacro_uid%3D%22_14594437023562434%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eimx6Q%20%E7%99%BB%E5%BD%95%EF%BC%9Aroot%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E6%AC%A2%E8%BF%8E%E4%BD%BF%E7%94%A8Ubuntu%2014.04.4LTS%20(GNU%2FLinux%203.14.52%20armv7l)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20chown%20root%3Aroot%20%2Fusr%2Fbin%2Fsudo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20chmod%204755%20%2Fusr%2Fbin%2Fsudo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20exit%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%22%3E%E4%BD%BF%E7%94%A8%20%3CUSER%3E%20%E6%88%96%20root%20%23%20%E7%99%BB%E5%BD%95%3C%2FUSER%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1459443738624799%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224650.66015625_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_1459443738624799%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20update%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20%E2%80%93f%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20locales%20dialog%20wget%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20dpkg-reconfigure%20locales%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20upgrade%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%8F%AF%E9%80%89%E2%80%94%E2%80%94%E5%AE%89%E8%A3%85%E4%B8%80%E4%BA%9B%E6%9C%89%E7%94%A8%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20%E5%AE%89%E8%A3%85%20openssh-server%20can-utils%20usbutils%20build-essential%20automake%20autoconf%20libtool%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E8%8E%B7%E5%8F%96%E5%B9%B6%E5%AE%89%E8%A3%85%20BSP%20%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%88%E9%9C%80%E8%A6%81%20EULA%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594437778399621%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224785.1044921875_50.000003814697266_1158_809%22%20jivemacro_uid%3D%22_14594437778399621%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20%2Fhome%2Fuser%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mkdir%20%E2%80%93p%20vpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20vpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-5.3.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Ffirmware-imx-5.3.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Ffirmware-imx-5.3.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-vpu-5.4.32.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-vpu-5.4.32.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-vpu-5.4.32.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Flibfslcodec-4.0.8.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Flibfslcodec-4.0.8.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Flibfslcodec-4.0.8.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-lib-5.1.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-lib-5.1.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-lib-5.1.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20chmod%20%2Bx%20*%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20.%2Ffirmware-imx-5.3.bin--auto-accept%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20mkdir%20%E2%80%93p%20%2Flib%2Ffirmware%2Fvpu%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cp%20-ravf%20firmware-imx-5.3%2Ffirmware%2F*%20%2Flib%2Ffirmware%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20.%2Fimx-vpu-5.4.32.bin%20--auto-accept%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cd%20imx-vpu-*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20make%20PLATFORM%3DIMX6Q%20all%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20%E6%89%A7%E8%A1%8C%E5%AE%89%E8%A3%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20tar%20-xf%20imx-lib-5.1.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cd%26nbsp%3B%20imx-lib-5.1%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20make%20-j1%20PLATFORM%3D%22IMX6Q%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20%E6%89%A7%E8%A1%8CPLATFORM%3D%22IMX6Q%22%E5%AE%89%E8%A3%85%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Flibfslcodec-4.0.8%20--auto-accept%20%E2%80%93force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20libfslcodec-*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fautogent.sh%20--prefix%3D%2Fusr%20--enable-fhw%20--enable-vpu%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%88%B6%E4%BD%9C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20%E6%89%A7%E8%A1%8C%E5%AE%89%E8%A3%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mv%20%2Fusr%2Flib%2Fimx-mm%2Fvideo-codec%2F*%20%2Fusr%2Flib%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mv%20%2Fusr%2Flib%2Fimx-mm%2Faudio-codec%2F*%20%2Fusr%2Flib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%E2%80%93rf%20%2Fusr%2Flib%2Fimx-mm%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mkdir%20%E2%80%93p%20gpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-gpu-viv-5.0.11.p7.4-hfp.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-gpu-viv-5.0.11.p7.4-hfp.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-gpu-viv-5.0.11.p7.4-hfp.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20chmod%20%2Bx%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fimx-gpu-viv-5.0.11.p7.4-hfp%20%E2%80%93-auto-accept%20-%E2%80%93force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20imx-gpu*%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20g2d%2Fusr%2Finclude%2F*%20%2Fusr%2Finclude%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-d%20g2d%2Fusr%2Flib%2F*%20%2Fusr%2Flib%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-Pr%20gpu-core%2Fusr%2F*%20%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20class%3D%22c%22%20style%3D%22color%3A%20%23999988%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CEM%3E%23%20%E5%8F%AF%E9%80%89%EF%BC%9A%E5%AE%89%E8%A3%85%E6%BC%94%E7%A4%BA%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-r%20gpu-demos%2Fopt%20%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20class%3D%22c%22%20style%3D%22color%3A%20%23999988%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CEM%3E%23%20%E5%8F%AF%E9%80%89%EF%BC%9A%E5%AE%89%E8%A3%85%20GPU%20%E5%B7%A5%E5%85%B7%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-axr%20gpu-tools%2Fgmem-info%2Fusr%2Fbin%2F*%20%2Fusr%2Fbin%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%AE%89%E8%A3%85%20gstreamer-imx%E3%80%81IPU%E3%80%81VPU%20%E5%92%8C%20GPU%20%E6%94%AF%E6%8C%81%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594438185374207%20jive_text_macro%22%20data-renderedposition%3D%225619.548828125_50.000003814697266_1158_140%22%20jivemacro_uid%3D%22_14594438185374207%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%AE%89%E8%A3%85%E6%9E%84%E5%BB%BA%E4%BE%9D%E8%B5%96%E9%A1%B9%E3%80%81gstreamer1.x%EF%BC%8C%E6%AD%A4%E6%AD%A5%E9%AA%A4%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4%EF%BC%88~350MB%EF%BC%89%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20python%20pkg-config%20git%20gstreamer1.0-x%20gstreamer1.0-tools%20gstreamer1.0-plugins-good%20gstreamer1.0-plugins-bad%20gstreamer1.0-alsa%20libgstreamer1.0-dev%20libgstreamer-plugins-base1.0-dev%20libgstreamer-plugins-good1.0-dev%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eg%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%2B%2B-%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Emultilib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20git%20clone%20git%3A%2F%2Fgithub.com%2FFreescale%2Fgstreamer-imx.git%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gstreamer-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20%E2%80%93s%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2F%20%2Fusr%2Flib%2Fgstreamer-1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%20configure%20--prefix%3D%2Fusr%20--kernel-headers%3D%2Finclude%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%2F..%2F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%EF%BC%88%E5%8F%AF%E9%80%89%EF%BC%89%E5%AE%89%E8%A3%85libimxvpuapi%E5%BA%93%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E8%AF%A5%E5%BA%93%E5%8F%AF%E6%8F%90%E4%BE%9B%E5%9F%BA%E4%BA%8E%E7%A4%BE%E5%8C%BA%E7%9A%84%E5%BC%80%E6%BA%90API%EF%BC%8C%E7%94%A8%E4%BA%8E%E8%AE%BF%E9%97%AE%E6%81%A9%E6%99%BA%E6%B5%A6imx-vpu%E5%BA%93%EF%BC%88IMX6%20VPU%E7%9A%84%E4%BD%8E%E7%BA%A7%E6%8E%A5%E5%8F%A3%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594438636081123%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%225785.1044921875_50.000003814697266_1158_93%22%20jivemacro_uid%3D%22_14594438636081123%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20git%20clone%20git%3A%2F%2Fgithub.com%2FFreescale%2Flibimxvpuapi.git%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20libimxvpu*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%20configure%20%E2%80%93-prefix%3D%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A'.%2Fwaf%20install'%20%E4%BC%9A%E5%B0%86%E6%9E%84%E5%BB%BA%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%E5%AE%89%E8%A3%85%E5%88%B0%E5%85%B6%E5%89%8D%E7%BC%80%E7%9B%AE%E5%BD%95%20%2B%20%2Flib%2Fgstreamer-1.0%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BA%9B%E6%96%87%E4%BB%B6%E5%AE%9E%E9%99%85%E4%B8%8A%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E5%88%B0%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%E5%AE%89%E8%A3%85%E5%89%8D%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%8A%E8%BF%B0%E7%AC%A6%E5%8F%B7%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%9E%84%E5%BB%BA%20G2D%20%E9%9C%80%E8%A6%81%20g2d%20lib%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%9E%84%E5%BB%BA%E6%94%AF%E6%8C%81Vivante%E7%9B%B4%E6%8E%A5%E7%BA%B9%E7%90%86%E7%9A%84EGL%20sink%E9%9C%80x11%E5%BA%93%EF%BC%88%E4%BB%85X11%E6%94%AF%E6%8C%81%E9%9C%80%E8%A6%81%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%9E%84%E5%BB%BA%E9%9F%B3%E9%A2%91%E6%8F%92%E4%BB%B6%E9%9C%80%E8%A6%81libfslaudiocodec%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%22%3E%E6%82%A8%E5%B7%B2%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%EF%BC%8C%E5%8F%AF%E6%B5%8B%E8%AF%95gstreamer%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background%3A%20white%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E6%EF%BC%9A%E4%B8%BA%20X11%20%E6%B7%BB%E5%8A%A0%20GPU%20%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A4%E7%B1%BB%E6%9E%84%E5%BB%BA%E8%AF%B4%E6%98%8E%E7%9A%84%E5%8E%9F%E5%A7%8B%E7%89%88%E6%9C%AC%E8%AF%A6%E8%A7%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%3CA%20href%3D%22http%3A%2F%2Ftrac.gateworks.com%2Fwiki%2Fventana%2Fubuntu%23HardwareGPUAccelerationforX11%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGateworks%20wiki%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E8%AF%A5%E5%9B%A2%E9%98%9F%E6%92%B0%E5%86%99%E8%AF%B4%E6%98%8E%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EIMX6%20IPU%E3%80%81VPU%E5%92%8CGPU%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87GStreamer%E5%92%8CGstreamer-imx%E6%8F%92%E4%BB%B6%E5%AE%9E%E7%8E%B0%E3%80%82%E6%89%80%E9%9C%80%E7%9A%84%E8%AE%B8%E5%A4%9A%E7%BB%84%E4%BB%B6%EF%BC%88%E5%9B%BA%E4%BB%B6%E5%92%8C%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%89%E5%9D%87%E6%9D%A5%E8%87%AA%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%8C%E4%B8%94%E4%B8%8D%E5%8F%AF%E8%87%AA%E7%94%B1%E5%88%86%E5%8F%91%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BF%85%E9%A1%BB%E4%BB%8E%E5%85%B6%E9%95%9C%E5%83%8F%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B8%8B%E8%BD%BD%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%E5%BC%BA%E5%88%B6%E7%94%A8%E6%88%B7%E9%98%85%E8%AF%BB%E5%B9%B6%E5%90%8C%E6%84%8F%E5%85%B6%E6%9C%80%E7%BB%88%E7%94%A8%E6%88%B7%E8%AE%B8%E5%8F%AF%E5%8D%8F%E8%AE%AE(EULA)%E7%9A%84shell%E8%84%9A%E6%9C%AC%E8%BF%9B%E8%A1%8C%E6%8F%90%E5%8F%96%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E4%BB%A5%E4%B8%8B%E6%8C%87%E4%BB%A4%E5%8F%AF%E4%BB%A5%E5%9C%A8debootstrap%E5%9F%BA%E7%A1%80%E4%B8%8A%E4%BD%BF%E7%94%A8%EF%BC%8C%3CSPAN%20class%3D%22apple-converted-space%22%3E%E4%B8%94%3C%2FSPAN%3E%E9%80%82%E7%94%A8%E4%BA%8E%E5%85%B6%E4%BB%96Ubuntu%E6%BA%90%E6%88%96Linux%E5%8F%91%E8%A1%8C%E7%89%88%E7%9A%84%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E6%B7%BB%E5%8A%A0%E5%87%A0%E4%B8%AA%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84%EF%BC%8C%E4%B8%BA%E5%9F%BA%E4%BA%8E%E4%B8%8A%E8%BF%B0debootstrap%E6%8C%87%E4%BB%A4%E5%88%9B%E5%BB%BA%E7%9A%84%E5%9F%BA%E7%A1%80%E6%98%A0%E5%83%8F%E8%BD%BB%E6%9D%BE%E6%B7%BB%E5%8A%A0X11%E6%94%AF%E6%8C%81%E3%80%82%E9%9C%80%E8%A6%81%E4%BB%A5%E4%B8%8B%E7%BB%84%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EX11%20server%20-%20ie%20Xorg%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E6%98%BE%E7%A4%BA%E7%AE%A1%E7%90%86%E5%99%A8%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%8E%A7%E5%88%B6X%E4%BC%9A%E8%AF%9D%E7%9A%84%E7%99%BB%E5%BD%95%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%AA%97%E5%8F%A3%E7%AE%A1%E7%90%86%E5%99%A8%EF%BC%8C%E7%94%A8%E4%BA%8E%E7%AE%A1%E7%90%86X%E5%AE%A2%E6%88%B7%E7%AB%AF%E7%9A%84%E7%AA%97%E5%8F%A3%E4%BD%8D%E7%BD%AE%E3%80%81%E5%A4%A7%E5%B0%8F%E8%B0%83%E6%95%B4%E3%80%81%E8%A3%85%E9%A5%B0%E7%AD%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B7%B2%E5%AE%89%E8%A3%85Linaro%20LXDE%20rootfs%EF%BC%8C%E5%AE%83%E5%8C%85%E6%8B%ACXorg%20X11%E6%9C%8D%E5%8A%A1%E5%99%A8%E3%80%81lxdm%E6%98%BE%E7%A4%BA%E7%AE%A1%E7%90%86%E5%99%A8%E3%80%81openbox%E7%AA%97%E5%8F%A3%E7%AE%A1%E7%90%86%E5%99%A8%E5%92%8C%E5%85%B6%E4%BB%96%E5%AE%9E%E7%94%A8%E7%94%A8%E6%88%B7%E5%BA%94%E7%94%A8%EF%BC%88%E5%8C%85%E6%8B%ACChromium%E6%B5%8F%E8%A7%88%E5%99%A8%EF%BC%89%EF%BC%8C%E6%9C%AA%E5%AE%89%E8%A3%85%E4%BD%86%E4%BB%8D%E9%9C%80%E5%AE%89%E8%A3%85linaro%20lxde%EF%BC%8C%E8%AF%B7%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_1459444118777927%20jive_text_macro%22%20data-renderedposition%3D%226365.31298828125_50.000003814697266_1158_32%22%20jivemacro_uid%3D%22_1459444118777927%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E6%AD%A4%E6%AD%A5%E9%AA%A4%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4%EF%BC%88~650MB%EF%BC%89%20%3C%2FSPAN%3E%3C%2FP%3E%26nbsp%3B%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20xinit%20lxde%20lxterminal%20lxappearance%20lxrandr%20lxshortcut%20lxinput%20xinit%26nbsp%3B%20xserver-xorg-dev%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Emesa-utils%20mesa-utils-extra%20%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23660000%3B%20background%3A%20%23fafafa%3B%22%3Eadduser%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%E5%91%BD%E4%BB%A4%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%B8%AA%E9%9D%9Eroot%E7%94%A8%E6%88%B7%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9DChromium%E6%B5%8F%E8%A7%88%E5%99%A8%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E7%BC%96%E8%BE%91%2Fetc%2Flxdm%2Fdefault.conf%EF%BC%8C%E5%9C%A8%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23660000%3B%20background%3A%20%23fafafa%3B%22%3E%E5%9F%BA%E7%A1%80%3C%2FSPAN%3E%3C%2FTT%3E%20%3CSPAN%20lang%3D%22ES-MX%22%3E%E9%83%A8%E5%88%86%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23660000%3B%20background%3A%20%23fafafa%3B%22%3E%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%E5%B1%9E%E6%80%A7%E4%BB%A5%E9%92%88%E5%AF%B9%E8%AF%A5%E7%94%A8%E6%88%B7%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%E3%80%82%2Fetc%2Fxdg%2Flubuntu%2Flxdm%2Flxdm.conf%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E4%BB%A5%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC3.14.52v%E4%B8%BA%E5%9F%BA%E7%A1%80%EF%BC%8Cvivante%205.0.11p7.4%E4%B8%8E%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E5%AF%B9%E5%BA%94%E3%80%82%E6%82%A8%E5%BA%94%E6%9F%A5%E9%98%85BSP%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%EF%BC%8C%E4%BB%A5%E7%A1%AE%E5%AE%9A%E9%9C%80%E8%A6%81%E4%BB%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E4%BB%93%E5%BA%93%E4%B8%8B%E8%BD%BD%E7%9A%84x%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%92%8CVivante%20GPU%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594441892347696%20jive_text_macro%22%20data-renderedposition%3D%226534.27099609375_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594441892347696%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20%2Fetc%2Flxdm%2Fdefault.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%5B%E5%9F%BA%E7%A1%80%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%3D%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20background-color%3A%20white%3B%22%3E%E8%A6%81%E5%9C%A8X11%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%A1%AC%E4%BB%B6GPU%E5%8A%A0%E9%80%9F%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BB%8E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%8F%90%E4%BE%9B%E7%9A%84imx-gpu-viv%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%BA%9B%E5%BA%93%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E8%BF%99%E9%9C%80%E8%A6%81%E7%AD%BE%E7%BD%B2%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%9C%80%E7%BB%88%E7%94%A8%E6%88%B7%E8%AE%B8%E5%8F%AF%E5%8D%8F%E8%AE%AE(EULA)%E3%80%82%E6%AD%A4%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%8F%AF%E6%8F%90%E4%BE%9B%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Elibg2d%20-%20%E4%B8%80%E4%B8%AA%E5%8F%97%E6%96%87%E6%A1%A3%E6%94%AF%E6%8C%81%E7%9A%84%E4%BD%8E%E7%BA%A7API%EF%BC%8C%E7%94%A8%E4%BA%8EGPU%EF%BC%88%E7%94%B1gstreamer-imx%E4%B8%AD%E7%9A%84libimxvpuapi%E5%92%8Cgpu-core%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%AD%89%E4%BD%BF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Egpu-core%20-%20provides%20all%20the%20various%20OpenGL%20libs%20(libGL%2C%20libGLESv1_CM%2C%20libGLESv1_CL%2C%20libGLESv2%2C%20libGLSLC%2C%20libCLC%2C%20libEGL%2C%20libGAL%2C%20libOpenCL%2C%20ls%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3ElibOpenVG)%20%E9%80%9A%E5%B8%B8%E7%94%B1%20mesa%20%E9%A1%B9%E7%9B%AE%E6%8F%90%E4%BE%9B%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E9%92%88%E5%AF%B9%E4%B8%8D%E5%90%8C%E7%9A%84%E5%90%8E%E7%AB%AF%E6%B8%B2%E6%9F%93%E7%B3%BB%E7%BB%9F%EF%BC%8C%E6%8F%90%E4%BE%9B%E4%BA%86%E5%A4%9A%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20libEGL%2FlibGAL%2FlibGLESv2%2FlibVIVANTE%EF%BC%9Adfb%E3%80%81fb%E3%80%81wl%E3%80%81x11%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594442717887539%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%226746.2158203125_50.000003814697266_1158_576%22%20jivemacro_uid%3D%22_14594442717887539%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23cd%20imx-gpu-*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20gpu-core%2Fusr%2Flib%2Fdri%2Fvivante_dri.so%20%2Fusr%2Flib%2Fxorg%2Fmodules%2Fdrivers%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20chmod%20644%20%2Fusr%2Flib%2Fxorg%2Fmodules%2Fdrivers%2Fvivante_dri.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa%2FlibGL.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa-egl%2FlibEGL.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa-egl%2FlibGLESv2.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22color%3A%20%23999988%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Erm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa-egl%2FlibOpenVG.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%2F..%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gpu-pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20tar%20%E2%80%93xf%20xserver*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20xserver-org-video-imx*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%E7%9C%8B%E8%B5%B7%E6%9D%A5%E9%9C%80%E8%A6%81%E6%89%A7%E8%A1%8Clik%20%23git%20init%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Ffastbuild.sh%26nbsp%3B%20BUILD_HARD_VFP%3D1%20XSERVER_GREATER_THAN_13%3D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20kernel-modu*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%88%B6%E4%BD%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%E5%88%87%E6%8D%A2%E5%88%B0%20gpu-core%20x11%20%E5%90%8E%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20backend%3Dx11%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libEGL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibEGL.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libEGL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibEGL.so.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libEGL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibEGL.so.1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGAL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGAL.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGLESv2-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGLESv2.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGLESv2-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGLESv2.so.2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGLESv2-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGLESv2.so.2.0.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libVIVANTE-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibVIVANTE.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGAL_egl.dri.so%20%2Fusr%2Flib%2FlibGAL_egl.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20for%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Ei%20in%20egl%20glesv1_cm%20glesv2%20vg%3B%20do%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cp%20%2Fusr%2Flib%2Fpkgconfig%2F%24%7Bi%7D_%24%7Bbackend%7D.pc%2Fusr%2Flib%2Fpkgconfig%2F%24%7Bi%7D.pc%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23rm%20%2Fusr%2Flib%2F*-dfb.so%20%2Fusr%2Flib%2F*-fb.so%20%2Fusr%2Flib%2F*-wl.so%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%EF%BC%88%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8GPU%E4%BD%9C%E4%B8%BA%E6%A8%A1%E5%9D%97%E9%83%A8%E7%BD%B2%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%EF%BC%8C%E5%88%99%E5%8F%AF%E9%80%89%EF%BC%89%E7%A1%AE%E4%BF%9Dvivante%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%EF%BC%88GPU%E5%86%85%E6%A0%B8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E5%8F%AF%E5%8A%A0%E8%BD%BD%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594443264249544%20jive_text_macro%22%20data-renderedposition%3D%227347.32666015625_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14594443264249544%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20echo%20vivante%20%26gt%3B%26gt%3B%20%2Fetc%2Fmodules%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20nano%20%2Fetc%2Fudev%2Frules.d%2F10-imx.rules%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3EKERNEL%3D%3D%22galcore%22%2C%20MODE%3D%220660%22%2C%20GROUP%3D%22video%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3EKERNEL%3D%3D%22mxc_asrc%22%2C%20MODE%3D%220666%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E4%B8%BAVivante%20fbdev%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9B%E5%BB%BA%E9%85%8D%E7%BD%AE%E7%9A%84xorg.conf%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594443585909304%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%227435.1044921875_50.000003814697266_1158_249%22%20jivemacro_uid%3D%22_14594443585909304%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20nano%20%2Fetc%2FX11%2Fxorg.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E2%80%9C%E8%AE%BE%E5%A4%87%E2%80%9D%E4%B8%80%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E6%A0%87%E8%AF%86%E7%AC%A6%E2%80%9Ci.MX%E5%8A%A0%E9%80%9F%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AE%BE%E5%A4%87%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E2%80%9Cvivante%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%E2%80%9Cfbdev%E2%80%9D%E2%80%9C%2Fdev%2Ffb0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%E2%80%9Cvivante_fbdev%E2%80%9D%E2%80%9C%2Fdev%2Ffb0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%20%E2%80%9CHWcursor%E2%80%9D%E2%80%9Cfalse%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E7%BB%93%E6%9D%9F%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E2%80%9CServerFlags%E2%80%9D%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%20%E2%80%9CBlankTime%E2%80%9D%E2%80%9C0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%E2%80%9CStandbyTime%E2%80%9D%E2%80%9C0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%E2%80%9CSuspendTime%E2%80%9D%E2%80%9C0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E9%80%89%E9%A1%B9%E2%80%9COffTime%E2%80%9D%E2%80%9C0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E7%BB%93%E6%9D%9F%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E7%A1%AE%E4%BF%9D%E6%96%87%E4%BB%B6%E5%B7%B2%E5%A4%8D%E5%88%B6%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E5%A6%82%E6%9E%9C%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%E9%83%BD%E5%B7%B2%E5%AE%8C%E6%88%90%E7%BC%96%E8%AF%91%E5%92%8C%E5%A4%8D%E5%88%B6%EF%BC%8C%E6%82%A8%E5%B0%B1%E8%83%BD%E5%9C%A8%2Fusr%2Flib%E4%B8%8B%E6%9F%A5%E7%9C%8B%E6%96%B0%E7%9A%84%E5%BA%93%EF%BC%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%81%AD%E5%96%9C%EF%BC%81%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%8D%B3%E5%8F%AF%E9%87%8D%E5%90%AF%E7%B3%BB%E7%BB%9F%E5%B9%B6%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%B5%8B%E8%AF%95%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3EGStreamer%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%98%BE%E7%A4%BA%20gstreamer-imx%20%E6%8F%92%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594443991277636%22%20data-renderedposition%3D%227792.18798828125_50.000003814697266_1158_383%22%20jivemacro_uid%3D%22_14594443991277636%22%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20gst-inspect-1.0%20%7C%20grep%20imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%EF%BC%9Aimxvpuenc_mjpeg%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20VPU%20%E5%8A%A8%E6%80%81%20JPEG%20%E8%A7%86%E9%A2%91%E7%BC%96%E7%A0%81%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%3A%26nbsp%3B%20imxvpuenc_mpeg4%3A%20Freescale%20VPU%20MPEG-4%20video%20encoder%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%EF%BC%9Aimxvpuenc_h264%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20VPU%20h.264%20%E8%A7%86%E9%A2%91%E7%BC%96%E7%A0%81%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%EF%BC%9Aimxvpuenc_h263%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20VPU%20h.263%20%E8%A7%86%E9%A2%91%E7%BC%96%E7%A0%81%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%EF%BC%9Aimxvpudec%EF%BC%9AFreescale%20VPU%20%E8%A7%86%E9%A2%91%E8%A7%A3%E7%A0%81%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxv4l2videosrc%3A%26nbsp%3B%20imxv4l2videosrc%3A%20V4L2%20CSI%20Video%20Source%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2d%3A%26nbsp%3B%20imxg2dcompositor%3A%20Freescale%20G2D%20video%20compositor%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2d%EF%BC%9Aimxg2dvideotransform%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94G2D%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2d%EF%BC%9Aimxg2dvideosink%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94G2D%E8%A7%86%E9%A2%91%E6%B1%87%E7%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipu%3A%26nbsp%3B%20imxipucompositor%3A%20Freescale%20IPU%20video%20compositor%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipu%EF%BC%9Aimxipuvideosink%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94IPU%E8%A7%86%E9%A2%91%E6%B1%87%E7%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipu%EF%BC%9Aimxipuvideotransform%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94IPU%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxpxp%EF%BC%9Aimxpxpvideotransform%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20PxP%20%E8%A7%86%E9%A2%91%E8%BD%AC%E6%8D%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxpxp%EF%BC%9Aimxpxpvideosink%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94PxP%E8%A7%86%E9%A2%91%E6%B1%87%E7%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipuvideosink%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594444707294011%20jive_text_macro%22%20data-renderedposition%3D%228232.6044921875_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594444707294011%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20line-height%3A%2012pt%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Egst-launch-1.0%20videotestsrc%20!%20imxipuvideosink%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2dvideosink%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594445554421995%22%20data-renderedposition%3D%228273.7158203125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594445554421995%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20gst-launch-1.0%20videotestsrc%20!%20imxg2dvideosink%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20background%3A%20%23fafafa%3B%22%3Eimxeglvivsink%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87X11%E4%B8%BB%E6%9C%BA%E5%AE%9E%E7%8E%B0%E7%AA%97%E5%8F%A3%E7%BA%A7%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E6%98%BE%E7%A4%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594445991565696%20jive_text_macro%22%20data-renderedposition%3D%228315.9375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594445991565696%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20%E5%AF%BC%E5%87%BA%E6%98%BE%E7%A4%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22o%22%20style%3D%22color%3A%20windowtext%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%3A0.0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20gst-launch-1.0%20videotestsrc%20!%20imxeglvivsink%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E8%A6%81%E6%B5%8B%E8%AF%95%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E5%9B%BE%E5%BD%A2%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%E4%BB%BB%E4%BD%95%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20%23222222%3B%20background%3A%20white%3B%22%3Eglmark2%E5%92%8C%2F%E6%88%96mesa-utils%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%EF%BC%8C%E6%88%96%E8%80%85%E6%89%A7%E8%A1%8C%E5%90%8E%E7%BB%AD%E8%B7%AF%E5%BE%84%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594446314181983%20jive_text_macro%22%20data-renderedposition%3D%228372.6044921875_50.000003814697266_1158_294%22%20jivemacro_uid%3D%22_14594446314181983%22%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20cd%20%2Fopt%2Fviv_samples%2Fvdk%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20.%2Ftutorial1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2Fany%20example%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20glxgears%20-info%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_RENDERER%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20GC2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VERSION%20%3D%202.1%202.0.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VENDOR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20Corporation%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_EXTENSIONS%20%3D%20WGL_ARB_extensions_string%20WGL_EXT_extensions_string%20WGL_EXT_swap_control%20GL_EXT_texture_env_add%20GL_ARB_multitexture%20GL_ARB_multisample%20GL_ARB_texture_env_add%20GL_ARB_texture_compression%20GL_ARB_texture_env_combine%20GL_ARB_depth_texture%20GL_ARB_window_pos%20%E2%80%A6.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%E7%A7%92%E5%86%851606%E5%B8%A7%20%3D%20321.130%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%20%E7%A7%92%E5%86%85%201650%20%E5%B8%A7%20%3D%20329.834%20%E5%B8%A7%E6%AF%8F%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EL_RENDERER%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20GC2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VERSION%20%3D%202.1%202.0.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VENDOR%20%3D%20Vivante%20Corporation%201629%20%E5%B8%A7%E5%9C%A8%205.0%20%E7%A7%92%E5%86%85%20%3D%20325.644%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E1621%20%E5%B8%A7%E5%9C%A8%205.0%20%E7%A7%92%E5%86%85%20%3D%20324.072%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%20%E7%A7%92%E5%86%85%201650%20%E5%B8%A7%20%3D%20329.806%20%E5%B8%A7%E6%AF%8F%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%E7%A7%92%E5%86%851651%E5%B8%A7%20%3D%20330.079%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FBio_TICFSL%22%20target%3D%22_blank%22%3EBio_TICFSL%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BC%98%E7%A7%80%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BB%8E%E4%BA%8B%20imx6q%20sabreauto%20%E7%9A%84%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%E5%B0%86u-boot%E3%80%81zimage%E3%80%81*dtb%E5%92%8Crootfs%E5%88%B7%E5%86%99%E5%88%B0SD%E5%8D%A1%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%BC%80%E5%8F%91%E6%9D%BF%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E5%9B%A0%E6%95%85%E5%81%9C%E6%AD%A2%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%E3%80%82%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202015.04-gb8837c4-dirty%20(2019%E5%B9%B48%E6%9C%8813%E6%97%A5%20-%2017%3A05%3A21)%3C%2FP%3E%3CP%3ECPU%EF%BC%9AFreescale%20i.MX6Q%E4%BF%AE%E8%AE%A2%E7%89%881.2%E8%BF%90%E8%A1%8C%E9%A2%91%E7%8E%87792%20MHz%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B8%A9%E5%BA%A641%C2%B0C%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%8E%9F%E5%9B%A0%EF%BC%9APOR%3CBR%20%2F%3E%E6%9D%BF%EF%BC%9AMX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%EF%BC%9A%E5%B0%B1%E7%BB%AA%3CBR%20%2F%3EDRAM%EF%BC%9A2GiB%3CBR%20%2F%3EPMIC%EF%BC%9APFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%EF%BC%9A0%20MiB%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%EF%BC%8CFSL_SDHC%EF%BC%9A1%3CBR%20%2F%3E%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E9%9D%A2%E6%9D%BF%EF%BC%9A%E9%BB%98%E8%AE%A4%E8%BF%9E%E6%8E%A5HDMI%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%EF%BC%9AHDMI%20(640x480)%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%EF%BC%9AFEC%20%5BPRIME%5D%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9AFEC%20%E5%9C%B0%E5%9D%80%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%20%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96boot.scr%3CBR%20%2F%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E6%96%87%E4%BB%B6boot.scr%20**%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96zImage%3CBR%20%2F%3E6022032%E5%AD%97%E8%8A%82%E5%9C%A8293%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96%E5%AE%8C%E6%AF%95(19.6%20MiB%2Fs)%3CBR%20%2F%3E%E4%BB%8Emmc%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96imx6q-sabreauto.dtb%3CBR%20%2F%3E19%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%9641594%E5%AD%97%E8%8A%82(2.1%20MiB%2Fs)%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%20%40%200x12000000%20%5B%200x000000%20-%200x5be390%20%5D%3CBR%20%2F%3E%23%23%20%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91blob%E4%BD%8D%E4%BA%8E%2018000000%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E0x18000000%E7%9A%84fdt%20blob%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E18000000%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E1800d279%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%89%A9%E7%90%86CPU%200x0%E4%B8%8A%E5%90%AF%E5%8A%A8Linux%3CBR%20%2F%3ELinux%E7%89%88%E6%9C%AC3.14.52-g0e08af9-dirty(BspDeveloper2%40BspDeveloper2)%20(gcc%E7%89%88%E6%9C%AC4.8.5%20(Linaro%20GCC%204.8-2015.06)%20)%20%239%20SMP%E9%A2%84%E6%8A%A2%E5%8D%A02019%E5%B9%B48%E6%9C%8813%E6%97%A516%3A58%3A40%20IST%3CBR%20%2F%3ECPU%3A%20ARMv7%E5%A4%84%E7%90%86%E5%99%A8%5B412fc09a%5D%E4%BF%AE%E8%AE%A2%E7%89%8810%20(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%E9%9D%9E%E5%88%AB%E5%90%8D%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%2C%20VIPT%E5%88%AB%E5%90%8D%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%3A%20Freescale%20i.MX6%20Quad%20SABRE%E6%B1%BD%E8%BD%A6%E5%BC%80%E5%8F%91%E6%9D%BF%3CBR%20%2F%3Ecma%3A%20CMA%3A%20%E5%9C%A86a000000%E9%A2%84%E7%95%99320%20MiB%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%3A%20%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E5%86%99%E5%85%A5%E5%88%86%E9%85%8D%3CBR%20%2F%3EPERCPU%3A%20%E5%B7%B2%E5%B5%8C%E5%85%A58%E9%A1%B5%2FCPU%20%40ee71e000%20s8320%20r8192%20d16256%20u32768%3CBR%20%2F%3E%E5%B7%B2%E6%9E%84%E5%BB%BA1%E4%B8%AA%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%8E%92%E5%88%97%E7%9A%84%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E5%90%AF%E7%94%A8%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E9%9D%A2%E6%95%B0%EF%BC%9A520720%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk2p2%20rootwait%20rw%3CBR%20%2F%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E7%9B%AE%E5%BD%95%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A262144%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048%2C576%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%E8%8A%82%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A1739236K%2F2097152K%20%E5%8F%AF%E7%94%A8%EF%BC%887452K%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%EF%BC%8C460K%E5%8F%AF%E8%AF%BB%E5%86%99%E6%95%B0%E6%8D%AE%EF%BC%8C2596K%E5%8F%AA%E8%AF%BB%E6%95%B0%E6%8D%AE%EF%BC%8C392K%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C433K%20BSS%EF%BC%8C357916K%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%8C270336K%E9%AB%98%E5%86%85%E5%AD%98%EF%BC%89%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3CBR%20%2F%3E%20%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000%20-%200xffff1000%20(4%20KB)%3CBR%20%2F%3E%20%E5%9B%BA%E5%AE%9A%E6%98%A0%E5%B0%84%EF%BC%9A0xfff00000%20-%200xfffe0000%20(896%20KB)%3CBR%20%2F%3E%20%E8%99%9A%E6%8B%9F%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%EF%BC%9A0xf0000000%20-%200xff000000%20(240MB)%3CBR%20%2F%3E%20%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xef800000%20(1784MB)%3CBR%20%2F%3E%20%E6%8C%81%E4%B9%85%E5%86%85%E6%A0%B8%E6%98%A0%E5%B0%84%EF%BC%9A0x7fe00000%20-%200x80000000%20(2MB)%3CBR%20%2F%3E%20%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%20(14MB)%3CBR%20%2F%3E.text%3A%200x80008000%20-%200x809d828c%20(10049%20kB)%3CBR%20%2F%3E%20.init%20%3A%200x809d9000%20-%200x80a3b080%20(%20393%20kB)%3CBR%20%2F%3E%20.data%20%3A%200x80a3c000%20-%200x80aaf340%20(%20461%20kB)%3CBR%20%2F%3E%20.bss%20%EF%BC%9A0x80aaf34c%EF%BC%8D0x80b1b99c%EF%BC%88434%20kB%EF%BC%89%3CBR%20%2F%3ESLUB%EF%BC%9A%E7%A1%AC%E4%BB%B6%E5%AF%B9%E9%BD%90%3D64%EF%BC%8C%E5%86%85%E5%AD%98%E5%9D%97%E9%98%B6%E6%95%B0%3D0%EF%BC%8D3%EF%BC%8C%E6%9C%80%E5%B0%8F%E5%AF%B9%E8%B1%A1%E6%95%B0%3D0%EF%BC%8CCPU%3D4%EF%BC%8C%E8%8A%82%E7%82%B9%3D1%3CBR%20%2F%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E5%BC%8F%E5%88%86%E5%B1%82RCU%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3EL310%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3El2x0%3A%2016%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c7%EF%BC%8CAUX_CTRL%200x32070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1024kB%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%9F%BA%E4%BA%8E%E5%AE%9A%E6%97%B6%E5%99%A8%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3Esched_clock%3A%2032%E4%BD%8D%EF%BC%8C%E9%A2%91%E7%8E%873000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87333ns%EF%BC%8C%E6%AF%8F1431655765682ns%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%8780x30%3CBR%20%2F%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%88%E5%B7%B2%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E6%A0%B9%E6%8D%AE%E5%AE%9A%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E5%80%BC%E2%80%A66.00%20BogoMIPS%20(lpj%3D30000)%3CBR%20%2F%3Epid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%EF%BC%9A32768%EF%BC%8C%E6%9C%80%E5%B0%8F%EF%BC%9A301%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E9%80%9A%E8%BF%87%3CBR%20%2F%3ECPU0%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%200%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8CMPIDR%2080000000%3CBR%20%2F%3E%E4%B8%BA0x10717d60%20-%200x10717db8%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E8%BA%AB%E4%BB%BD%E6%98%A0%E5%B0%84%3CBR%20%2F%3ECPU1%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%AC%A1%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU1%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%201%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000001%3CBR%20%2F%3ECPU2%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%AC%A1%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU2%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%202%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000002%3CBR%20%2F%3ECPU3%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%AC%A1%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU3%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%203%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000003%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E5%8A%A84%E4%B8%AACPU%3CBR%20%2F%3ESMP%EF%BC%9A%E6%80%BB%E8%AE%A14%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%E5%B7%B2%E6%BF%80%E6%B4%BB%20(24.00%20BogoMIPS)%E3%80%82%3CBR%20%2F%3ECPU%EF%BC%9A%E6%89%80%E6%9C%89CPU%E5%9D%87%E4%BB%A5SVC%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3Edevtmpfs%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EVFP%E6%94%AF%E6%8C%81%E7%89%88%E6%9C%AC0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E4%BB%B6%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3CBR%20%2F%3E%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%EF%BC%9A%E6%97%A0%E5%8F%82%E6%95%B0%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F16%3CBR%20%2F%3EDMA%EF%BC%9A%E5%B7%B2%E4%B8%BA%E5%8E%9F%E5%AD%90%E4%B8%80%E8%87%B4%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D256%20KiB%E6%B1%A0%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%98%B6%E6%A2%AF%E5%9E%8B%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%98%B6%E6%A2%AF%E5%9E%8B%E8%8F%9C%E5%8D%95%3CBR%20%2F%3ECPU%E5%B7%B2%E8%AF%86%E5%88%AB%E4%B8%BAi.MX6Q%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC1.2%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8WDOG1%E4%BD%9C%E4%B8%BA%E9%87%8D%E7%BD%AE%E6%BA%90%3CBR%20%2F%3Esyscon%2020c8000.anatop%EF%BC%9Aregmap%20%5Bmem%200x020c8000-0x020c8fff%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Evdd1p1%EF%BC%9A800%20%26lt%3B--%26gt%3B%201375%20mV%EF%BC%8C%E5%BD%93%E5%89%8D%E4%B8%BA1100%20mV%20%3CBR%20%2F%3Evdd3p0%EF%BC%9A2625%20%26lt%3B--%26gt%3B%203400%20mV%EF%BC%8C%E5%BD%93%E5%89%8D%E4%B8%BA3000%20mV%20%3CBR%20%2F%3Evdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202750%20mV%EF%BC%8C%E5%BD%93%E5%89%8D%E4%B8%BA2400%20mV%20%3CBR%20%2F%3Evddarm%EF%BC%9A725%20%26lt%3B--%26gt%3B%201450%20mV%EF%BC%8C%E5%BD%93%E5%89%8D%E4%B8%BA1150mV%20%3CBR%20%2F%3Evddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201450%20mV%20%3CBR%20%2F%3Evddsoc%EF%BC%9A725%20%26lt%3B--%26gt%3B%201450%20mV%EF%BC%8C%E5%BD%93%E5%89%8D%E4%B8%BA1175%20mV%20%3CBR%20%2F%3Esyscon%2020e0000.iomuxc-gpr%EF%BC%9Aregmap%20%5B%E5%86%85%E5%AD%980x020e0000-0x020e0037%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Esyscon%2021bc000.ocotp-ctrl%EF%BC%9Aregmap%20%5B%E5%86%85%E5%AD%980x021bc000-0x021bffff%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B05%E4%B8%AA%E6%96%AD%E7%82%B9%EF%BC%88%2B1%E4%B8%AA%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%89%E5%92%8C1%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA4%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20IMX%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%3CBR%20%2F%3Ebio%3A%20%E5%9C%A80%E5%A4%84%E5%88%9B%E5%BB%BAslab%20%3CBIO-0%3E%3CBR%20%2F%3Emxs-dma%20110000.dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecs42888_supply%EF%BC%9A3300%20mV%20%3CBR%20%2F%3E3P3V%EF%BC%9A3300%20mV%20%3CBR%20%2F%3Evio1%EF%BC%9A3300%20mV%20%3CBR%20%2F%3Evio2%EF%BC%9A3300%20mV%20%3CBR%20%2F%3Evd%EF%BC%9A3300%20mV%20%3CBR%20%2F%3Eva%EF%BC%9A5000%20mV%20%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0usb_h1_vbus.29%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0usb_otg_vbus.30%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3ESCSI%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb%3CBR%20%2F%3Eusbphy_nop1.12%E7%94%B5%E6%BA%90vcc%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eusbphy_nop2.13%20%E7%94%B5%E6%BA%90vcc%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Ei2c%20i2c-1%3A%20IMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Epca953x%202-0032%3A%20%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Epca953x%3A%202-0032%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA-5%3CBR%20%2F%3Ei2c%20i2c-2%3A%20IMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ELinux%20%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%E6%8E%A5%E5%8F%A3%3A%20v2.00%3CBR%20%2F%3Epps_core%3A%20LinuxPPS%20API%E7%89%88%E6%9C%AC1%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%3CSPAN%3Epps_core%3A%20%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC5.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%E6%97%B6%E9%92%9F%E6%94%AF%E6%8C%81%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eimx-ipuv3%202400000.ipu%EF%BC%9AIPU%20DMFC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%EF%BC%8C5B(4%2C5)%EF%BC%8C5F(6%2C7)%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%EF%BC%9AIPU%20DMFC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3CBR%20%2F%3EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E9%AB%98%E7%BA%A7Linux%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC2.18%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F31%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecfg80211%EF%BC%9A%E8%B0%83%E7%94%A8CRDA%E6%9B%B4%E6%96%B0%E5%85%A8%E7%90%83%E7%9B%91%E7%AE%A1%E5%9F%9F%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90mxc_timer1%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F2%3CBR%20%2F%3ETCP%E5%B7%B2%E5%BB%BA%E7%AB%8B%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B16384%EF%BC%8C%E7%BB%91%E5%AE%9A16384%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9Areno%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EUDP-Lite%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F1%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BAUNIX%E7%9A%84%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Cudp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%20NFSv4.1%E5%90%8E%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%80%A7%E8%83%BD%E7%9B%91%E6%8E%A7%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E4%BD%BF%E7%94%A8ARMv7%20Cortex-A9%20PMU%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C7%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%E5%8F%AF%E7%94%A8%3CBR%20%2F%3Eimx%20rpmsg%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3Eimx_busfreq%20busfreq.16%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81DDR%E4%B8%AD%E7%AD%89%E9%80%9F%E7%8E%87%E3%80%82%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Efutex%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%BC%B9%E6%80%A7%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A64%E9%A1%B5%3CBR%20%2F%3EVFS%EF%BC%9A%E7%A3%81%E7%9B%98%E9%85%8D%E9%A2%9Ddquot_6.5.2%3CBR%20%2F%3EDquot-cache%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%200%EF%BC%8C4096%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENFS%EF%BC%9A%E6%B3%A8%E5%86%8Cid_resolver%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_legacy%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ejffs2%EF%BC%9A%E7%89%88%E6%9C%AC2.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3E%E7%86%94%E4%B8%9D%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88API%E7%89%88%E6%9C%AC7.22%EF%BC%89%3CBR%20%2F%3Emsgmni%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA3508%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fnoop%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fdeadline%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fcfq%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3Eimx-weim%2021b8000.weim%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3Ebacklight.17%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Emxc_sdc_fb%20fb.22%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%20mxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%EF%BC%9AIPU%20DMFC%20DP%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%9A1(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AE%BE%E5%A4%87128x48%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%E6%A3%80%E6%B5%8B%E5%88%B0HDMI%E6%8E%A7%E5%88%B6%E5%99%A80x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%E5%90%8D%E7%A7%B0%20-%202.073M9%3CBR%20%2F%3Emxc_sdc_fb%20fb.23%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fhdmi%3CBR%20%2F%3Emxc_sdc_fb%20fb.24%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0mxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3CBR%20%2F%3Emxc_sdc_fb%20fb.25%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E6%9C%AA%E5%88%86%E9%85%8Diram%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E5%86%85%E5%AD%98%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E6%98%A0%E5%B0%84%E4%BB%BB%E4%BD%95%E4%BA%8B%E4%BB%B6%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B63.2%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9A%E5%85%A8%E5%B1%82%EF%BC%9A2%EF%BC%8C%E9%87%91%E5%B1%9E%E5%B1%82%EF%BC%9A1%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9AFAB%EF%BC%9A0%EF%BC%8CFIN%EF%BC%9A0%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0pfuze100%E3%80%82%3CBR%20%2F%3ESW1AB%3A%20300%26lt%3B--%26gt%3B%201875%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1375%20mV%3CBR%20%2F%3ESW1C%3A%20300%26lt%3B--%26gt%3B%201875%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1375%20mV%3CBR%20%2F%3ESW2%3A%20800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA3000%20mV%3CBR%20%2F%3ESW3A%3A400%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1500%20mV%3CBR%20%2F%3ESW3B%3A%20400%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1500%20mV%3CBR%20%2F%3ESW4%3A%20800%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1800%20mV%3CBR%20%2F%3ESWBST%3A%205000%26lt%3B--%26gt%3B%205150%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA5000%20mV%3CBR%20%2F%3EVSNVS%3A%201000%26lt%3B--%26gt%3B%203000%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA3000%20mV%3CBR%20%2F%3EVREFDDR%3A750%20mV%3CBR%20%2F%3EVGEN1%3A%20800%26lt%3B--%26gt%3B%201550%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA800%20mV%3CBR%20%2F%3EVGEN2%3A%20800%26lt%3B--%26gt%3B%201550%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1500%20mV%3CBR%20%2F%3EVGEN3%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1800%20mV%3CBR%20%2F%3EVGEN4%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1800%20mV%3CBR%20%2F%3EVGEN5%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA2500%20mV%3CBR%20%2F%3EVGEN6%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA2800%20mV%3CBR%20%2F%3E%E4%B8%B2%E8%A1%8C%EF%BC%9AIMX%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E21ec000.serial%3Attymxc2%E4%BD%8D%E4%BA%8EMMIO%200x21ec000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2060%EF%BC%8C%E5%9F%BA%E7%A1%80%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%205%2C000%2C000%EF%BC%89%E6%98%AFIMX%3CBR%20%2F%3E21f0000.serial%EF%BC%9Attymxc3%E4%BD%8D%E4%BA%8EMMIO%200x21f0000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2061%EF%BC%8C%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2060%EF%BC%8C%E5%9F%BA%E7%A1%80%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%205000000%EF%BC%89%E6%98%AFIMX%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc3%5D%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%E4%B8%B2%E8%A1%8C%EF%BC%9AFreescale%20lpuart%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eimx%20sema4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%9620060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E5%B7%B2%E5%9C%A8%E6%AC%A1%E8%A6%81%E7%89%88%E6%9C%AC0%E4%B8%8A%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ebrd%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%B9%B3%E5%8F%B0%E6%95%B0%E6%8D%AE%E3%80%82%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E6%9C%AA%E6%8C%87%E5%AE%9AIRQ%E7%BC%96%E5%8F%B7%EF%BC%8C%E5%B0%86%E4%BD%BF%E7%94%A8%E8%BD%AE%E8%AF%A2%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E5%8F%91%E9%80%81%E5%91%BD%E4%BB%A40x11%E6%97%B6%E5%87%BA%E9%94%99%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E8%AE%BE%E5%A4%87%E7%94%B5%E6%BA%90%E7%8A%B6%E6%80%81%E4%B8%8D%E4%B8%80%E8%87%B4%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-level-mV%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800000024%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-boost-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800000480%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-atten-16ths%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800002000%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Creceive-eq-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A8%2005000000%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9A%E9%87%8D%E7%BD%AEphy%E5%A4%B1%E8%B4%A5%EF%BC%9A-110%3CBR%20%2F%3Eahci-imx%EF%BC%9A%E6%8E%A2%E6%B5%8B2200000.sata%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA-110%3CBR%20%2F%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E2094000.can%E6%9C%AA%E6%89%BE%E5%88%B0xceiver%E7%94%B5%E6%BA%90%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eflexcan%202094000.can%EF%BC%9A%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%20(reg_base%3Df01f0000%2C%20irq%3D143)%3CBR%20%2F%3Eehci_hcd%EF%BC%9AUSB%202.0%E2%80%9C%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%9D%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8(EHCI)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eehci-mxc%EF%BC%9AFreescale%E7%89%87%E4%B8%8AEHCI%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb-storage%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb_ehset_test%3CBR%20%2F%3E2184800.usbmisc%20%E7%94%B5%E6%BA%90vbus-wakeup%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eimx_usb%202184000.usb%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B02184000.usb%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fimx_usb%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Eimx_usb%202184200.usb%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B02184200.usb%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fimx_usb%E8%AF%B7%E6%B1%82%E6%8E%A2%E6%B5%8B%E5%BB%B6%E8%BF%9F%3CBR%20%2F%3Emousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84PS%2F2%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3CBR%20%2F%3Eegalax_ts%201-0004%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3CBR%20%2F%3Eegalax_ts%EF%BC%9A%E6%8E%A2%E6%B5%8B1-0004%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA-5%3CBR%20%2F%3E2-0044%20%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90vdd%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bisl29023%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bisl29023%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96snvs-rtc%E6%97%B6%E9%92%9F%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%EF%BC%9Artc%20core%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C20cc034.snvs-rtc-lp%E4%BD%9C%E4%B8%BArtc0%3CBR%20%2F%3Ei2c%20%2Fdev%20entries%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EIR%20NEC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5(x)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC6%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20JVC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20Sony%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5(streamzap)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20SANYO%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20MCE%E9%94%AE%E7%9B%98%2F%E9%BC%A0%E6%A0%87%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo16%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo17%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E6%B3%A8%E5%86%8C%E4%B8%BAvideo18%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%EF%BC%9AV4L2%20%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo19%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%EF%BC%9AV4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo20%3CBR%20%2F%3E2-000e%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2-000e%20%E7%94%B5%E6%BA%90vddio%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emag3110%202-000e%3A%20%E6%A3%80%E6%9F%A5mag3110%E8%8A%AF%E7%89%87ID%3CBR%20%2F%3Emag3110%202-000e%3A%20%E8%AF%BB%E5%8F%96%E8%8A%AF%E7%89%87ID%200xfffffffb%E4%B8%8D%E7%AD%89%E4%BA%8E%200xc4%EF%BC%81%3CBR%20%2F%3Emag3110%3A%202-000e%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-22%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmag3110%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmag3110%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3E2-001c%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2-001c%20%E7%94%B5%E6%BA%90vddio%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emma8451%202-001c%3A%20%E8%AF%BB%E5%8F%96%E8%8A%AF%E7%89%87ID%200x1%20%E4%B8%8D%E7%AD%89%E4%BA%8E0x1a%E6%88%960x2a%EF%BC%81%3CBR%20%2F%3Emma8451%3A%202-001c%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-22%3CBR%20%2F%3Eimx2-wdt%2020bc000.wdog%3AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92(nowayout%3D0)%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20H4%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20BCSP%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbcm203x%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fath3k%3CBR%20%2F%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Esdhci%EF%BC%9ACopyright(c)%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%EF%BC%9ASDHCI%E5%B9%B3%E5%8F%B0%E5%92%8COF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A9%E6%89%8B%3CBR%20%2F%3Emmc1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc1%EF%BC%9ASDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E2194000.usdhc%20%5B2194000.usdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3Emmc2%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc2%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc2%EF%BC%9ASDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E2198000.usdhc%20%5B2198000.usdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3EGalcore%E7%89%88%E6%9C%AC5.0.11.33433%3CBR%20%2F%3Emmc1%EF%BC%9A%E6%96%B0%E5%9E%8B%E9%AB%98%E9%80%9FDDR%20MMC%E5%8D%A1%E4%BD%8D%E4%BA%8E%E5%9C%B0%E5%9D%800001%3CBR%20%2F%3Emmcblk1%EF%BC%9Ammc1%EF%BC%9A0001%20VM010B%2014.5GiB%3CBR%20%2F%3Emmcblk1boot0%EF%BC%9Ammc1%EF%BC%9A0001%20VM010B%20%E5%88%86%E5%8C%BA1%20512KiB%3CBR%20%2F%3Emmcblk1boot1%EF%BC%9Ammc1%EF%BC%9A0001%20VM010B%20%E5%88%86%E5%8C%BA2%20512KiB%3CBR%20%2F%3Emmcblk1rpmb%EF%BC%9Ammc1%EF%BC%9A0001%20VM010B%20%E5%88%86%E5%8C%BA3%20512KiB%3CBR%20%2F%3E%E5%A4%87%E7%94%A8GPT%E6%97%A0%E6%95%88%EF%BC%8C%E4%BD%BF%E7%94%A8%E4%B8%BBGPT%E3%80%82%3CBR%20%2F%3Emmcblk1%EF%BC%9Ap1%20p2%20p3%20p4%20p5%20p6%20p7%3CBR%20%2F%3Emmcblk1boot1%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3CBR%20%2F%3Emmcblk1boot0%EF%BC%9A%E6%9C%AA%E7%9F%A5%E5%88%86%E5%8C%BA%E8%A1%A8%3CBR%20%2F%3Emmc2%EF%BC%9A%E4%B8%BB%E6%9C%BA%E4%B8%8D%E6%94%AF%E6%8C%81%E8%AF%BB%E5%8F%96%E5%8F%AA%E8%AF%BB%E5%BC%80%E5%85%B3%E3%80%82%E5%81%87%E8%AE%BE%E5%8F%AF%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3Emmc2%EF%BC%9A%E6%96%B0%E5%9E%8B%E9%AB%98%E9%80%9FSDHC%E5%8D%A1%E4%BD%8D%E4%BA%8E%E5%9C%B0%E5%9D%80e624%3CBR%20%2F%3Emmcblk2%EF%BC%9Ammc2%EF%BC%9Ae624%20SS16G%2014.8GiB%3CBR%20%2F%3E%20mmcblk2%EF%BC%9Ap1%20p2%3CBR%20%2F%3E%20mxc_vdoa%2021e4000.vdoa%EF%BC%9Ai.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8(VDOA)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Emxc_vpu%202040000.vpu%EF%BC%9AVPU%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E5%B7%B2%E5%AE%9E%E4%BE%8B%E5%8C%96RNG4%20SH0%3CBR%20%2F%3Ecaam%202%2C100%2C000.caam%EF%BC%9A%E5%B7%B2%E5%AE%9E%E4%BE%8B%E5%8C%96RNG4%20SH1%3CBR%20%2F%3Ecaam%202%2C100%2C000.caam%EF%BC%9A%E8%AE%BE%E5%A4%87ID%20%3D%200x0a160100%20(Era%204)%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E4%BD%9C%E4%B8%9A%E7%8E%AF%20%3D%202%EF%BC%8Cqi%20%3D%200%3CBR%20%2F%3Ecaam%E7%AE%97%E6%B3%95%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%9C%A8%2Fproc%2Fcrypto%3CBR%20%2F%3Ecaam_jr%202101000.jr0%EF%BC%9A%E6%B3%A8%E5%86%8Cng-caam%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20blkkey_ex%3A%204%E4%B8%AA%E5%AF%86%E9%92%A5%E5%BA%93%E5%8D%95%E5%85%83%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064-bit%20black%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2017%20d4%2014%20e3%20cd%2014%2099%203c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2028%20ac%2013%20da%204f%2013%2086%20b9%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128-bit%20clear%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2047%2020%20d5%208a%2008%202e%20c9%2076%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2021%20a3%20ab%2086%2072%20eb%20e0%20d7%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20a0%20ab%2018%20b1%20c0%2086%2052%20c3%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2026%2002%2062%2070%20a8%2078%204c%20f2%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%204e%206c%20e5%2031%207e%206c%20d1%2025%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2048%2062%2078%2086%2093%2070%2062%20ff%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2061%2042%20d7%20cf%2079%20ad%2081%205c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20cc%201b%209e%205c%20a0%2020%200e%2054%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%20ed%20fa%2074%2003%2008%20e1%2096%20e2%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%205c%2085%20e0%20cc%20ab%20f4%209e%203b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20196%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E9%BB%91%E9%92%A5%E5%9C%A8blob%E4%B8%AD%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20fc%20e1%202d%202c%2081%2075%205e%2099%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%202d%2093%209b%20b0%20a6%205a%203d%2049%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2098%2096%209d%200c%2039%2036%20da%2072%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20f9%201d%2066%200c%2078%2024%2020%209a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2085%203c%2092%201e%20a4%2055%20d2%204b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20e4%207a%20ed%2019%20af%2070%202e%20f6%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%20cf%20c9%2007%200e%2082%2019%2047%207f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E9%BB%91%E9%92%A5%E4%BD%8D%E4%BA%8Eblob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20c6%20ae%2004%2056%20f6%205e%20c2%201b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20d9%206c%2007%2089%209d%201e%2020%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2072%204c%2063%20e1%20ed%20d2%20fd%2068%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2099%2081%2017%2032%2033%2039%202a%201c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%20fb%20e4%20bb%20db%200c%2007%20c0%20f2%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20eb%2023%20cf%2079%2064%202a%20ca%20f3%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%20d9%2084%20ac%2022%200b%2049%2079%20e9%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%207d%208b%2097%2009%206a%20d4%2072%200b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E9%BB%91%E9%92%A5%E4%BD%8D%E4%BA%8Eblob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%209c%20ec%2058%2009%2050%2020%2080%201d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2021%20b6%20e3%2064%2041%20ed%2014%2012%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2016%20e1%20c7%20d3%20fe%2054%2040%20ed%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20bc%2092%20e0%200c%206b%200a%20ec%2002%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%203b%2060%206f%2018%2020%2026%20e4%2004%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20c2%2094%205e%202f%201e%20e4%2099%20b1%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%209c%2005%2065%2095%209b%208d%20db%2072%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%20a8%2050%20b0%2050%209d%20f8%2067%2066%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2033%20ae%2046%20e9%2042%206c%20fb%20ab%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E9%BB%91%E9%92%A5%E4%BD%8D%E4%BA%8Eblob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%209b%2050%206d%2078%2093%20a8%2008%2084%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20e5%203b%2026%2018%201d%206a%2042%2080%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%203f%20c9%207f%204d%20dd%201a%20b6%20a3%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2002%206a%204d%2064%20a6%20cc%20c3%2061%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2015%209e%20c8%201f%2075%2072%2001%20af%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20f5%2087%20b3%2078%20b0%2078%203f%2034%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%20bf%2019%2080%2005%2072%2032%20c2%2082%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%20d1%20fd%204c%20f7%20c6%20c9%2098%2085%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%209d%2002%2055%2075%2035%20d5%20ef%20ca%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2080%20f5%2021%2087%20ef%206c%20cd%2096%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D64%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2047%209d%20fa%2049%20f0%20cf%20c5%201c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2090%204d%200a%20e3%20a1%20ee%2072%205c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D128%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2047%2020%20d5%208a%2008%202e%20c9%2076%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2021%20a3%20ab%2086%2072%20eb%20e0%20d7%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D192%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20a0%20ab%2018%20b1%20c0%2086%2052%20c3%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2026%2002%2062%2070%20a8%2078%204c%20f2%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%208d%200d%20bc%202d%202c%2090%2067%200c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2093%2091%20ea%2059%2081%20df%2052%20df%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D256%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2061%2042%20d7%20cf%2079%20ad%2081%205c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20cc%201b%209e%205c%20a0%2020%200e%2054%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%20ed%20fa%2074%2003%2008%20e1%2096%20e2%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%205c%2085%20e0%20cc%20ab%20f4%209e%203b%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3A%20%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96snvs%E6%97%B6%E9%92%9F%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%EF%BC%9A%E8%BF%9D%E8%A7%84%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%BF%80%E6%B4%BB%20-%20%E9%9D%9E%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3CBR%20%2F%3Eusbhid%EF%BC%9AUSB%20HID%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Ecs42xx8%201-0048%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%884%3CBR%20%2F%3Efsl-asrc%202034000.asrc%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Esnd-soc-dummy%20snd-soc-dummy%3A%20ASoC%3A%20%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%E5%B9%B3%E5%8F%B0debugfs%E7%9B%AE%E5%BD%95%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.26%3Acs42888%26lt%3B-%26gt%3B%202024000.esai%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.26%EF%BC%9Asnd-soc-dummy-dai%26lt%3B-%26gt%3B%202034000.asrc%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.26%EF%BC%9Acs42888%26lt%3B-%26gt%3B%202024000.esai%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-spdif%20sound-spdif.19%EF%BC%9Asnd-soc-dummy-dai%26lt%3B-%26gt%3B%202004000.spdif%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-audio-hdmi%20sound-hdmi.20%EF%BC%9Ahdmi-hifi%26lt%3B-%26gt%3B%20hdmi_audio.3%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-tuner-si476x%20sound-fm.31%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0FM%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%3CBR%20%2F%3Eimx-tuner-si476x%3A%20sound-fm.31%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-22%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F26%3CBR%20%2F%3ETCP%3A%20cubic%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F10%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%E9%9A%A7%E9%81%93%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F17%3CBR%20%2F%3Ecan%3A%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%8C%BA%E5%9F%9F%E7%BD%91%E7%BB%9C%E6%A0%B8%E5%BF%83(%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20abi%209)%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F29%3CBR%20%2F%3Ecan%3A%20%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE(%E4%BF%AE%E8%AE%A2%E7%89%8820120528)%3CBR%20%2F%3Ecan%3A%20%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE(%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20t)%3CBR%20%2F%3Ecan%3A%20netlink%E7%BD%91%E5%85%B3(%E4%BF%AE%E8%AE%A2%E7%89%8820130117)%20max_hops%3D1%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%20TTY%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%E7%89%88%E6%9C%AC1.11%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP(%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F)%20%E7%89%88%E6%9C%AC1.3%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP%E8%BF%87%E6%BB%A4%E5%99%A8%3A%20%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP(%E4%BA%BA%E6%9C%BA%E6%8E%A5%E5%8F%A3%E4%BB%BF%E7%9C%9F)%20%E7%89%88%E6%9C%AC1.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%E6%94%AF%E6%8C%81%E7%89%88%E6%9C%AC1.8%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bdns_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EVGEN2%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3ESWBST%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3ESW4%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3Eimx%20mcc%E6%B5%8B%E8%AF%95%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0usb_h1_vbus.29%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Eusb_otg_vbus%EF%BC%9A5000%20mV%3CBR%20%2F%3Eimx_usb%202184200.usb%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B02184200.usb%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fimx_usb%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0usb_h1_vbus.29%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA1970-01-01%2000%3A00%3A02%20UTC%20(2)%3CBR%20%2F%3Eimx_usb%202184200.usb%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3CBR%20%2F%3E%20%230%EF%BC%9Acs42888-%E9%9F%B3%E9%A2%91%3CBR%20%2F%3E%20%231%EF%BC%9Aimx-spdif%3CBR%20%2F%3E%20%232%EF%BC%9Aimx-hdmi-soc%3CBR%20%2F%3Ep%E5%B9%B3%E5%8F%B0usb_h1_vbus.29%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Ekjournald%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%945%E7%A7%92%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E5%B7%B2%E6%8C%82%E8%BD%BD%E6%9C%89%E5%BA%8F%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3EVFS%3A%20%E5%B7%B2%E5%9C%A8%E8%AE%BE%E5%A4%87179%3A34%E4%B8%8A%E6%8C%82%E8%BD%BDroot(ext3%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F)%E3%80%82%3CBR%20%2F%3Edevtmpfs%3A%20%E6%8C%82%E8%BD%BD%E9%94%99%E8%AF%AF-2%3CBR%20%2F%3E%E9%87%8A%E6%94%BE%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%EF%BC%9A392K%20(809d9000%20-%2080a3b000)%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%20-%20%E6%9C%AA%E5%90%8C%E6%AD%A5%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%8F%AF%E7%94%A8%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%9B%E7%A8%8B%E3%80%82%E5%B0%9D%E8%AF%95%E5%B0%86init%3D%E9%80%89%E9%A1%B9%E4%BC%A0%E9%80%92%E7%BB%99%E5%86%85%E6%A0%B8%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85Linux%E6%96%87%E6%A1%A3%2Finit.txt%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%8C%87%E5%AF%BC%E3%80%82%3CBR%20%2F%3ECPU2%EF%BC%9A%E5%81%9C%E6%AD%A2%3CBR%20%2F%3ECPU%EF%BC%9A2%20PID%EF%BC%9A0%20%E8%BF%9B%E7%A8%8B%EF%BC%9Aswapper%2F2%E6%9C%AA%E8%A2%AB%E6%B1%A1%E6%9F%933.14.52-g0e08af9-dirty%239%3CBR%20%2F%3E%5B%26lt%3B80014764%26gt%3B%5D%20(unwind_backtrace)%E6%9D%A5%E8%87%AA%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack)%E6%9D%A5%E8%87%AA%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3CBR%20%2F%3E%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack)%E6%9D%A5%E8%87%AA%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI%2B0x144%2F0x158)%3CBR%20%2F%3E%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI)%E6%9D%A5%E8%87%AA%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq%2B0x58%2F0x5c)%3CBR%20%2F%3E%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq)%E6%9D%A5%E8%87%AA%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc%2B0x40%2F0x70)%3CBR%20%2F%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88(0xd80adf50%20to%200xd80adf98)%3CBR%20%2F%3Edf40%3A%20d80adf98%203b9aca00%20e9b5de9d%2000000000%3CBR%20%2F%3Edf60%3A%20e882c038%2000000000%20ee72f0d0%2080a4a814%2000000001%20ee72f0d4%20d80ac000%20d80ac000%3CBR%20%2F%3Edf80%3A%20a6aaaaab%20d80adf98%2000000009%20804b64bc%2060000113%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc)%20from%20%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%E6%9D%A5%E8%87%AA%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call%2B0xfc%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call)%E6%9D%A5%E8%87%AA%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle%2B0x8%2F0x44)%3CBR%20%2F%3E%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle)%E6%9D%A5%E8%87%AA%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry%2B0x104%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry)%E6%9D%A5%E8%87%AA%5B%26lt%3B10008644%26gt%3B%5D%20(0x10008644)%3CBR%20%2F%3ECPU0%3A%20%E5%81%9C%E6%AD%A2%3CBR%20%2F%3ECPU%3A%200%20PID%3A%200%20%E8%BF%9B%E7%A8%8B%3A%20swapper%2F0%E6%9C%AA%E8%A2%AB%E6%B1%A1%E6%9F%933.14.52-g0e08af9-dirty%20%239%3CBR%20%2F%3E%5B%26lt%3B80014764%26gt%3B%5D%20(unwind_backtrace)%E6%9D%A5%E8%87%AA%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack)%E6%9D%A5%E8%87%AA%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3CBR%20%2F%3E%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack)%E6%9D%A5%E8%87%AA%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI%2B0x144%2F0x158)%3CBR%20%2F%3E%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI)%E6%9D%A5%E8%87%AA%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq%2B0x58%2F0x5c)%3CBR%20%2F%3E%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq)%E6%9D%A5%E8%87%AA%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc%2B0x40%2F0x70)%3CBR%20%2F%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88(0x80a3df18%20to%200x80a3df60)%3CBR%20%2F%3Edf00%3A%2080a3df60%203b9aca00%3CBR%20%2F%3Edf20%3A%20e9b5de9d%2000000000%20e883714d%2000000000%20ee71f0d0%2080a4a814%2000000001%20ee71f0d4%3CBR%20%2F%3Edf40%3A%2080a3c000%2080a3c000%20a6aaaaab%2080a3df60%2000000009%20804b64bc%2060000113%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc)%E6%9D%A5%E8%87%AA%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%E6%9D%A5%E8%87%AA%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call%2B0xfc%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call)%E6%9D%A5%E8%87%AA%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle%2B0x8%2F0x44)%3CBR%20%2F%3E%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle)%E6%9D%A5%E8%87%AA%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry%2B0x104%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry)%E6%9D%A5%E8%87%AA%5B%26lt%3B809d9af0%26gt%3B%5D%20(start_kernel%2B0x350%2F0x35c)%3CBR%20%2F%3ECPU3%3A%20%E5%81%9C%E6%AD%A2%3CBR%20%2F%3ECPU%3A%203%20PID%3A%200%20Comm%3A%20swapper%2F3%E6%9C%AA%E8%A2%AB%E6%B1%A1%E6%9F%933.14.52-g0e08af9-dirty%20%239%3CBR%20%2F%3E%5B%26lt%3B80014764%26gt%3B%5D%20(unwind_backtrace)%E6%9D%A5%E8%87%AA%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack)%E6%9D%A5%E8%87%AA%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3CBR%20%2F%3E%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack)%E6%9D%A5%E8%87%AA%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI%2B0x144%2F0x158)%3CBR%20%2F%3E%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI)%E6%9D%A5%E8%87%AA%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq%2B0x58%2F0x5c)%3CBR%20%2F%3E%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq)%E6%9D%A5%E8%87%AA%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc%2B0x40%2F0x70)%3CBR%20%2F%3E%E5%BC%82%E5%B8%B8%E5%A0%86%E6%A0%88(0xd80aff50%20to%200xd80aff98)%3CBR%20%2F%3Eff40%3A%20d80aff98%203b9aca00%20e9b5de9d%2000000000%3CBR%20%2F%3Eff60%3A%20e882c2d3%2000000000%20ee7370d0%2080a4a814%2000000001%20ee7370d4%20d80ae000%20d80ae000%3CBR%20%2F%3Eff80%3A%20a6aaaaab%20d80aff98%2000000009%20804b64bc%2060000113%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc)%E6%9D%A5%E8%87%AA%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%E6%9D%A5%E8%87%AA%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call%2B0xfc%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call)%E6%9D%A5%E8%87%AA%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle%2B0x8%2F0x44)%3CBR%20%2F%3E%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle)%E6%9D%A5%E8%87%AA%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry%2B0x104%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry)%E6%9D%A5%E8%87%AA%5B%26lt%3B10008644%26gt%3B%5D%20(0x10008644)%3C%2FBIO-0%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9B%B8%E5%90%8C%E7%9A%84%E6%8C%87%E4%BB%A4%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BA%8Eimx.8%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E6%82%A8%E5%A5%BD%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20400%3B%20font-size%3A%2016px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E5%9C%A8%E2%80%9C%E4%B8%8B%E8%BD%BDu-boot%E2%80%9D%E4%B8%80%E8%8A%82%E4%B8%AD%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20400%3B%20font-size%3A%2016px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E6%88%91%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E5%B7%B2%E6%89%A7%E8%A1%8C%E2%80%9Cmake%E2%80%9D%E6%8C%87%E4%BB%A4%EF%BC%8C%E4%BD%86%E4%BC%BC%E4%B9%8E%E5%B9%B6%E6%9C%AA%E7%94%9F%E6%95%88%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%E6%88%91%E5%BA%94%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%202rem%3B%20margin%3A%200px%200px%2030px%3B%20padding%3A%200px%20300px%200px%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%201%3A%20..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9C(%E2%80%9D%E6%84%8F%E5%A4%96%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%201%3A%20..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9C(%E2%80%9D%E6%84%8F%E5%A4%96%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Edirname%3A%20%E7%BC%BA%E5%B0%91%E6%93%8D%E4%BD%9C%E6%95%B0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E8%AF%B7%E5%B0%9D%E8%AF%95'dirname%20--help'%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Escripts%2Fkconfig%2Fconf%20--silentoldconfig%20Kconfig%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20CHK%20include%2Fconfig.h%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20GEN%20include%2Fautoconf.mk%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%201%3A%20..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%EF%BC%9A%22(%22%E6%84%8F%E5%A4%96%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Escripts%2FMakefile.autoconf%3A71%3A%20%E7%9B%AE%E6%A0%87'include%2Fautoconf.mk'%E7%9A%84%E8%A7%84%E5%88%99%E5%A4%B1%E6%95%88%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Emake%5B1%5D%3A%20***%20%5Binclude%2Fautoconf.mk%5D%E9%94%99%E8%AF%AF1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Emake%3A%20***%20%E5%B9%B6%E6%9C%AA%E9%85%8D%E7%BD%AE%E8%A7%84%E5%88%99%E4%BB%A5%E7%94%9F%E6%88%90%E7%9B%AE%E6%A0%87'include%2Fconfig%2Fauto.conf'%EF%BC%8C'include%2Fconfig%2Fuboot.release'%20%E9%9C%80%E8%A6%81%E8%AF%A5%E7%9B%AE%E6%A0%87%E3%80%82%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9F%BA%E6%9C%AC%E4%B8%8A%EF%BC%8C%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E8%A6%81%E7%94%9F%E6%88%90%20zImage%20%E8%80%8C%E4%B8%8D%E6%98%AF%20Image%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E8%BE%93%E5%85%A5%20make%20menuconfig%20%E5%B9%B6%E9%80%89%E6%8B%A9%E6%AD%A4%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20492px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27702iD8C61D7B243F870F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGzip%E4%B8%8D%E6%98%AF%E9%BB%98%E8%AE%A4%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E5%B7%B2%E5%9C%A8I.MX6Q%20SABRESD%E6%9D%BF%E4%B8%8A%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8Cubuntu%2014.04%E3%80%82%E6%84%9F%E8%B0%A2%E8%BF%99%E7%AF%87%E5%AE%9E%E7%94%A8%E5%B8%96%E6%96%87%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%BF%99%E7%AF%87%E7%B2%BE%E5%BD%A9%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%81%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E5%9C%A8%E6%88%91%E7%9A%84%20IMX6Q%20SABRE%20SD%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E9%80%9A%E8%BF%87%20mmc%20%E5%8D%A1%E8%BF%90%E8%A1%8C%20Ubuntu%2014.04%20%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%85%B3%E6%B3%A8%E8%AF%A5%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E4%B8%8D%E5%86%8D%E6%9C%89%E6%95%88%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20title%3D%22https%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E5%85%B6%E6%9B%BF%E6%8D%A2%E4%B8%BA%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jivelink12%22%20href%3D%22https%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2F%22%20title%3D%22https%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2F%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20style%3D%22color%3A%20%23444444%20!important%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%20!important%3B%20font-size%3A%2013px%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%AE%83%E4%BE%9D%E7%84%B6%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E5%BC%82%E5%B8%B8%E9%94%99%E8%AF%AF%EF%BC%9A%EF%BC%88%E4%B8%8E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20500%3B%20font-size%3A%2010.9998px%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22287259%22%20data-username%3D%22wenmingfeng%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fwenmingfeng%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20text-decoration%3A%20none%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3Ewenming%20feng%3C%2FA%3E%3C%2FSPAN%3E%E6%8F%8F%E8%BF%B0%E7%9A%84%E9%94%99%E8%AF%AF%E7%9B%B8%E5%90%8C%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Fbin%2Fsh%3A%201%3A%20%2Fhome%2Fguillaume%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%88%91%E9%80%89%E6%8B%A9%E8%BF%99%E4%B8%AA%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%BC%96%E8%AF%91%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%23008000%3B%22%3Egcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%BD%86%E6%88%91%E6%AD%A3%E5%9C%A8%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%E6%96%87%E4%BB%B6%EF%BC%8C%3CSTRONG%3E%E8%80%8C%E9%9D%9EzImage%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%E3%80%82u-boot%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E8%AF%A5%E6%96%87%E4%BB%B6%EF%BC%88%E5%9C%A8u%20boot%E8%BF%90%E8%A1%8C%E6%97%B6%E5%87%BA%E7%8E%B0linux%20arm%20zimage%E9%AD%94%E6%9C%AF%E5%80%BC%E9%94%99%E8%AF%AF%EF%BC%89%E3%80%82%E4%BC%BC%E4%B9%8E%E5%AD%98%E5%9C%A8uImage%E3%80%81Image%E5%92%8CzImage%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%9B%BE%E5%83%8F%E5%B0%86%E5%AF%B9%E5%BA%94%E4%BA%8E64%E4%BD%8D%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E9%97%AE%E9%A2%981%EF%BC%9A%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%2F%E8%AE%BE%E7%BD%AE%E5%93%AA%E4%B8%AA%E5%B7%A5%E5%85%B7%E9%93%BE%E6%88%96%E9%80%89%E9%A1%B9%E6%9D%A5%E7%94%9F%E6%88%90zImage%EF%BC%9F%EF%BC%88%E8%80%8C%E9%9D%9E%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E9%97%AE%E9%A2%982%EF%BC%9A%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%96%B0%E6%AD%A4%E5%B8%96%E6%96%87%E5%B9%B6%E9%99%84%E4%B8%8A%E6%9C%80%E6%96%B0%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E9%97%AE%E9%A2%983%EF%BC%9A%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%B7%B2%E6%9E%84%E5%BB%BA%E7%9A%84SABRE%20SD%E4%B8%93%E7%94%A8.sdcard%E9%95%9C%E5%83%8F%E6%96%87%E4%BB%B6%EF%BC%88%E5%8C%85%E5%90%ABu-boot%E3%80%81%E5%86%85%E6%A0%B8%E3%80%81dtb%E3%80%81ubuntu%2014.04%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E2%80%A6%E2%80%A6%EF%BC%89%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3EGuillaume%20HUGUES%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22border%3A%200px%3B%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8imx6q-sabresd%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%E6%88%91%E4%B8%A5%E6%A0%BC%E9%81%B5%E5%BE%AA%E2%80%9C%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22330147%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330147%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FA%3E%E2%80%9D%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E6%88%91%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E6%98%AF%203.14.52%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Ubuntu%20Rootfs%2014.04%E3%80%82%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E6%88%91%E7%9A%84%20Xorg%20xserver%20%E7%89%88%E6%9C%AC%E6%98%AF%201.15.1%E3%80%82%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%9C%A8%E5%86%85%E6%A0%B8%E4%B8%AD%E5%90%AF%E7%94%A8PCI%E6%80%BB%E7%BA%BF%E6%94%AF%E6%8C%81%EF%BC%8C%E5%B0%B1%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8x11%20gpu%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%EF%BC%88glxgears%E5%92%8Ces2gears%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%88%86%E6%AE%B5%E9%94%99%E8%AF%AF%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E7%A6%81%E7%94%A8PCI%E6%94%AF%E6%8C%81%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%B8%8A%E8%BF%B0%E7%89%88%E6%9C%AC%E7%9A%84x%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%9D%A5%E5%90%AF%E7%94%A8x11%20gpu%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EPCI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8x11%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E4%B8%AD%E8%B5%B7%E4%BB%80%E4%B9%88%E4%BD%9C%E7%94%A8%EF%BC%9F%E5%A6%82%E4%BD%95%E5%9C%A8%E5%90%AF%E7%94%A8PCI%E6%80%BB%E7%BA%BF%E6%94%AF%E6%8C%81%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%A1%AE%E4%BF%9Dx11%E5%8A%A0%E9%80%9F%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%9C%89%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%E6%88%96%E9%80%82%E7%94%A8%E4%BA%8Epci%2Fdrm%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CWenming%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%E6%88%91%E4%B9%9F%E5%BF%BD%E7%95%A5%E4%BA%86%20cd%20kernel-modu*%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AF%20i.mx6q%20sabre%20sd%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20LVDS%20%E6%98%BE%E7%A4%BA%E5%99%A8%E3%80%82%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E5%B7%A5%E5%85%B7%E9%93%BE%3CEM%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3Egcc-linaro-arm-linux-gnueabihf-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23c00000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E4.9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23c00000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E2014%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E.09_linux.tar.xz%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FSPAN%3E%3C%2FEM%3E%EF%BC%8C%E5%A6%82%E6%96%87%E6%A1%A3%E6%89%80%E8%BF%B0%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8Skype%20for%20Business%E4%B8%AD%E6%90%9C%E7%B4%A2%E2%80%9CKane%20Jiang%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A5%9D%E6%82%A8%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%3C%2FP%3E%3CP%3EKane%20Jiang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Kane%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%3CEM%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Elinaro-trusty-alip-20141024-684.tar.gz%3C%2FSTRONG%3E%3C%2FEM%3E%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8imx6dl%E5%AE%A2%E6%88%B7%E6%9D%BF%E6%A1%8C%E9%9D%A2%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8OSD-WVGA%20lcd%E8%BF%9E%E6%8E%A5ipu.di0%2Ffb0%E3%80%82%E5%AF%B9%E4%BA%8Eubuntu%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E8%BF%9B%E5%85%A5%E6%8E%A7%E5%88%B6%E5%8F%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8Ekernel-modu*%EF%BC%8C%E6%B3%A8%E9%87%8A%E4%B8%AD%E5%8C%85%E5%90%AB%E9%93%BE%E6%8E%A5%EF%BC%9A%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Ftrac.gateworks.com%2Fwiki%2Fventana%2Fubuntu%23HardwareGPUAccelerationforX11%22%20title%3D%22http%3A%2F%2Ftrac.gateworks.com%2Fwiki%2Fventana%2Fubuntu%23HardwareGPUAccelerationforX11%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eventana%2Fubuntu%20%E2%80%93%20Gateworks%3C%2FA%3E%E7%AC%AC2%E8%8A%82%EF%BC%8C%E6%88%91%E6%89%80%E5%81%9A%E7%9A%84%E5%8F%AA%E6%98%AF%E5%BF%BD%E7%95%A5cd%20kernel-modu*%20make%EF%BC%8C%E5%90%8C%E6%97%B6%E5%80%9F%E5%8A%A9cd%20%2Fusr%2Flib%E6%9D%A5%E6%89%A7%E8%A1%8Cln%20-sf%E3%80%82fastbuild.sh%E4%BB%85%E6%9E%84%E5%BB%BAvivante_drv.so%EF%BC%8Cvivante_dri.so%E5%88%99%E5%9F%BA%E4%BA%8Egpu_core%E5%A4%8D%E5%88%B6%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E5%90%8D%E4%B8%BAkernel-modu*%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E8%A7%86%E9%A2%91%3D%E8%A1%8C%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%96%87%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHi%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%3E%40Bio_TICFSL%3C%2Fa%3E%2C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BC%98%E8%B4%A8%E6%96%87%E6%A1%A3%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%9C%89%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E1.%E6%88%91%E6%9C%AA%E8%83%BD%E6%89%BE%E5%88%B0%E6%96%87%E6%A1%A3%E6%89%80%E6%8F%8F%E8%BF%B0%E7%9A%84%E5%90%8D%E4%B8%BA%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Ekernel-modu*%3C%2FSTRONG%3E%3C%2FEM%3E%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E8%AF%B7%E9%97%AE%E5%AE%83%E7%9A%84%E5%85%B7%E4%BD%93%E4%BD%8D%E7%BD%AE%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3B.%2Ffastbuild.sh%26nbsp%3B%26nbsp%3BBUILD_HARD_VFP%3D1%26nbsp%3BXSERVER_GREATER_THAN_13%3D1%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd..%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd%26nbsp%3Bkernel-modu*%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bmake%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%E5%88%87%E6%8D%A2%E5%88%B0%20gpu-core%20x11%20%E5%90%8E%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%20backend%3Dx11%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E2.%20%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%90%8D%E4%B8%BA%3CSTRONG%20style%3D%22background-color%3A%20%23cbe68f%3B%20%3A%20%3B%20color%3A%20%23444444%3B%20text-decoration%3A%20none%20!important%3B%20font-size%3A%2013px%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Freleases.linaro.org%2Fdebian%2Fimages%2Falip-armhf%2F16.04%2Flinaro-jessie-alip-20160428-22.tar.gz%22%20style%3D%22color%3A%20%23444444%20!important%3B%20background-color%3A%20%23cbe68f%3B%20text-decoration%3A%20none%20!important%3B%20font-size%3A%2013px%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinaro-jessie-alip-20160428-22.tar.gz%3C%2FA%3E%3C%2FSTRONG%3E%EF%BC%88%E5%9F%BA%E4%BA%8Edebian%E7%9A%84ubuntu%2016.04%EF%BC%89%E7%9A%84rootfs%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%E7%99%BB%E5%BD%95%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CEM%3E%3CSTRONG%3E%5B%E5%A4%B1%E8%B4%A5%5D%20%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E7%99%BB%E5%BD%95%E6%9C%8D%E5%8A%A1%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CEM%3E%3CSTRONG%3E%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E2%80%9Csystemctl%20status%20systemd-logind.service%E2%80%9D%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%8F%91%E8%B5%B7%E6%8E%88%E6%9D%83%E7%94%A8%E6%88%B7%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%5B%E5%A4%B1%E8%B4%A5%5D%20%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8LSB%EF%BC%9A%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E2%80%A6%E9%9C%80%E8%A6%81%E5%90%AF%E7%94%A8cpufreq%E9%A2%91%E7%8E%87%E8%B0%83%E8%8A%82%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E2%80%9Csystemctl%20status%20loadcpufreq.service%E2%80%9D%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%2Fetc%2Frc.local%20Compatibility%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8LSB%EF%BC%9A%E7%BD%91%E7%BB%9C%E5%9F%BA%E5%87%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8LSB%EF%BC%9A%E9%AB%98%E7%BA%A7IEEE%20802.11%E7%AE%A1%E7%90%86%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%BC%80%E5%A7%8B%E5%88%9D%E5%A7%8B%E5%8C%96%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%8E%A7%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E6%97%B6%E9%97%B4%5D%20%E7%AD%89%E5%BE%85%E8%AE%BE%E5%A4%87dev-ttymxc0.device%E8%B6%85%E6%97%B6%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E4%BE%9D%E8%B5%96%5D%20ttymxc0%E4%B8%8A%E4%B8%B2%E8%A1%8CGetty%E6%9C%8D%E5%8A%A1%E7%9A%84%E4%BE%9D%E8%B5%96%E9%A1%B9%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%5B%E5%A4%B1%E8%B4%A5%5D%20%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E7%AE%A1%E7%90%86%E5%99%A8%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E2%80%9Csystemctl%20status%20NetworkManager.service%E2%80%9D%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E9%82%A3%E4%B9%88%E5%A6%82%E4%BD%95%E7%99%BB%E5%BD%95%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%8C%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E7%A5%9D%E6%82%A8%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CWenming%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%91%BD%E4%BB%A4%EF%BC%9A%3CEM%3E%3CSTRONG%3Eapt-get%20install%20libxtst-dev%3C%2FSTRONG%3E%3C%2FEM%3E%E6%9D%A5%E5%85%8B%E6%9C%8D%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9AX11%2Fextensions%2FXext.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%A5%9D%E6%82%A8%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CWenming%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E9%80%89%E6%8B%A9%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AARootFS%EF%BC%9F%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%8F%AF%E8%83%BD%E5%B9%B6%E6%9C%AA%E9%80%89%E6%8B%A9%E6%96%87%E6%A1%A3%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ELinaro%20LXDE%20rootfs%EF%BC%88%E4%BE%8B%E5%A6%82%3CSTRONG%3E%3CEM%20style%3D%22color%3A%20%23008000%3B%22%3Elinaro-trusty-alip-20141024-684.tar.gz%3C%2FEM%3E%3C%2FSTRONG%3E%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%3CSPAN%20style%3D%22border%3A%200px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcdimage.ubuntu.com%252Fubuntu-core%252Fvivid%252Fdaily-preinstalled%252Fcurrent%252Fvivid-preinstalled-core-armhf.tar.gz%22%20style%3D%22color%3A%20%23772953%3B%20background-color%3A%20%23f7f6f5%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%20medium%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Evivid-preinstalled-core-armhf.tar.gz%3C%2FA%3E%3C%2FEM%3E%3C%2FSTRONG%3E%E4%B8%8D%E5%8C%85%E5%90%ABGUI%E6%A1%8C%E9%9D%A2%EF%BC%8C%E5%8F%AA%E6%8F%90%E4%BE%9B%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%BB%88%E7%AB%AF%EF%BC%8C%E8%80%8C%E4%B8%94%E4%BC%BC%E4%B9%8E%E4%B8%8D%E6%94%AF%E6%8C%81%3CSTRONG%3E%3CEM%3Eapt-get%3C%2FEM%3E%3C%2FSTRONG%3E%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20inherit%3B%22%3E%E4%BD%86%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E4%B8%8E%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9B%B8%E5%90%8C%E7%9A%84rootfs%20%3CEM%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23008000%3B%22%3Elinaro-trusty-alip-20141024-684.tar.gz%3C%2FSTRONG%3E%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E3%80%82%E6%88%91%E6%88%90%E5%8A%9F%E5%9C%A8i.MX6Q%20SABRE%20SD%E4%B8%8A%E5%90%AF%E5%8A%A8%E4%BA%86%E6%A1%8C%E9%9D%A2%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%9F%A5%E6%89%BEGPU%20Vivante%E5%92%8C%E8%BF%90%E8%A1%8C%E6%95%99%E7%A8%8B%E6%96%B9%E9%9D%A2%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20inherit%3B%22%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E6%96%87%E6%A1%A3%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E5%90%8D%E4%B8%BA%20%3CEM%3E%3CSTRONG%3Ekernel-modu*%20%3C%2FSTRONG%3E%3C%2FEM%3E%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E6%82%A8%E6%89%BE%E5%88%B0%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3B.%2Ffastbuild.sh%26nbsp%3B%26nbsp%3BBUILD_HARD_VFP%3D1%26nbsp%3BXSERVER_GREATER_THAN_13%3D1%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd..%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSTRONG%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20color%3A%20black%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd%26nbsp%3Bkernel-modu*%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bmake%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%E5%88%87%E6%8D%A2%E5%88%B0%20gpu-core%20x11%20%E5%90%8E%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%20backend%3Dx11%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E7%A5%9D%E6%82%A8%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Kane%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%BC%E5%87%BA%E4%BA%86BUILD_HARD_VFP%3D1%E5%92%8CXSERVER_GREATER_THAN_13%3D1%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%E5%AF%BC%E5%87%BA%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDRI_1.10.4%2Fsrc%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E5%BE%97%E5%88%B0%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E9%BB%98%E8%AE%A4%E4%BF%AE%E8%AE%A2%E7%89%88%E6%9C%AC'HEAD'%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E5%8F%82%E6%95%B0'HEAD'%E5%90%AB%E4%B9%89%E4%B8%8D%E6%98%8E%E7%A1%AE%EF%BC%9A%E6%9C%AA%E7%9F%A5%E4%BF%AE%E8%AE%A2%E7%89%88%E6%9C%AC%E6%88%96%E8%B7%AF%E5%BE%84%E4%B8%8D%E5%9C%A8%E5%B7%A5%E4%BD%9C%E6%A0%91%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8'--'%E5%88%86%E9%9A%94%E8%B7%AF%E5%BE%84%E5%92%8C%E4%BF%AE%E8%AE%A2%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3CBR%20%2F%3E'git%20%3CCOMMAND%3E%20%5B%3CREVISION%3E...%5D%20--%20%5B%3CFILE%3E...%5D'%3CBR%20%2F%3Efsl_pixmap_ext.c%3A31%3A33%3A%20%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9AX11%2Fextensions%2FXext.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%20%23include%20%3CX11%3E%3C%2FX11%3E%3C%2FFILE%3E%3C%2FREVISION%3E%3C%2FCOMMAND%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%94%99%E8%BF%87%E4%BA%86%E4%B8%80%E4%BA%9B%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%82%A8%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CA%20class%3D%22%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcdimage.ubuntu.com%252Fubuntu-core%252Fvivid%252Fdaily-preinstalled%252Fcurrent%252Fvivid-preinstalled-core-armhf.tar.gz%22%20style%3D%22color%3A%20%23772953%3B%20background-color%3A%20%23f7f6f5%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%20medium%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Evivid-preinstalled-core-armhf.tar.gz%3C%2FA%3E%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E5%B9%B6%E6%88%90%E5%8A%9F%E5%9C%A8imx6%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E5%90%AF%E5%8A%A8%E6%A1%8C%E9%9D%A2%EF%BC%9F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E6%96%87%E6%98%8E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8CPrathamesh%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E6%89%80%E8%BF%B0%EF%BC%8C%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E5%91%BD%E4%BB%A4%EF%BC%9A%3CSTRONG%3Egit%20init%3C%2FSTRONG%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8Explorer%E4%B8%AD%E6%89%93%E5%BC%80ubuntu-core%E9%93%BE%E6%8E%A5%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BE%8B%E5%A6%82%E5%9C%A8%E9%93%BE%E6%8E%A5%E4%B8%AD%EF%BC%9A%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%2F%22%20title%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EIndex%20of%20%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%3CSTRONG%3E%3CEM%3E%3CA%20href%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%2Fvivid-preinstalled-core-armhf.tar.gz%22%20style%3D%22color%3A%20%23772953%3B%20background-color%3A%20%23f7f6f5%3B%20font-size%3A%20medium%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evivid-preinstalled-core-armhf.tar.gz%3C%2FA%3E%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CPratham%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%96%87%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Ferikraynolds%22%20target%3D%22_blank%22%3Eerikraynolds%3C%2FA%3E%E2%80%8C%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E5%92%8C%E6%82%A8%E4%B8%80%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%3CEM%3Ekernel-modu*%3C%2FEM%3E%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E7%8E%B0%E5%9C%A8%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EKane%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20feng%2C%3C%2FP%3E%3CP%3E%E2%80%9C%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%AD%89%E5%BE%85%E6%A0%B9%E8%AE%BE%E5%A4%87%2Fdev%2Fmmcblk0p2...%3C%2FSPAN%3E%E2%80%9D%E8%BF%99%E4%B8%80%E9%97%AE%E9%A2%98%E4%BC%BC%E4%B9%8E%E4%B8%8E%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E5%90%8Esd%E5%8D%A1%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BB%8E%20eMMc%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E7%9C%8B%E7%9C%8B%E6%82%A8%E6%98%AF%E5%90%A6%E4%BB%8D%E7%84%B6%E9%81%87%E5%88%B0%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%8A%E6%96%87%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EPrathamesh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CPratham%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E8%BF%87%E4%BB%BB%E4%BD%95%E8%A1%A5%E4%B8%81%EF%BC%9F%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8mx6dl%E5%AE%A2%E6%88%B7%E6%9D%BF%E4%B8%8A%E5%90%AF%E5%8A%A8%E8%BF%9B%E5%85%A5rootfs%EF%BC%8C%E5%8F%AA%E8%83%BD%E5%90%AF%E5%8A%A8uboot%E5%92%8C%E5%86%85%E6%A0%B8%E3%80%82%E5%86%85%E6%A0%B8%E5%B0%86%E5%81%9C%E6%AD%A2%E5%9C%A8%E2%80%9C%E7%AD%89%E5%BE%85%E6%A0%B9%E8%AE%BE%E5%A4%87%2Fdev%2Fmmcblk0p2...%E2%80%9D%E7%9A%84%E7%8A%B6%E6%80%81%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%96%87%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E6%8C%89%E7%85%A7%E4%B8%8A%E8%BF%B0%E6%AD%A5%E9%AA%A4%E5%9C%A8imx6q-sabrsd%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8Cubuntu%20rootfs%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BAxserver-xorg-video-imx-viv-5.0.11.p7.4%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20linaro%20rootfs%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egcc%20-DCOMMIT%3D%22%60git%20log%20-n%201%20--format%3D%25H%60%60git%20diff-index%20--quiet%20HEAD%20%7C%7C%20echo%20'-dirty'%60%22%20-DFIX_NO_MI_BACKINGSTORE%20-fvisibility%3Dhidden%20-fPIC%20-DPIc%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E9%9D%9Egit%E5%AD%98%E5%82%A8%E5%BA%93%EF%BC%88%E6%88%96%E4%BB%BB%E4%BD%95%E7%88%B6%E7%9B%AE%E5%BD%95%EF%BC%89%EF%BC%9A.git%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E9%9D%9Egit%E5%AD%98%E5%82%A8%E5%BA%93%EF%BC%88%E6%88%96%E4%BB%BB%E4%BD%95%E7%88%B6%E7%9B%AE%E5%BD%95%EF%BC%89%EF%BC%9A.git%3CBR%20%2F%3Egcc%20-shared%20-fPIC%20-o%20vivante_drv.so%20vivante_gal%2Fvivante_gal_blit.o%20vivante_gal%2Fvivante_gal_gpu.o%20vivante_gal%2Fvivante_gal_surface.o%20vivante_fbde%3CBR%20%2F%3Emake%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%60%2Froot%2Fgpu%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4%2FEXA%2Fsrc'%3CBR%20%2F%3Emake%3A%20***%20DRI_1.10.4%2Fsrc%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E3%80%82%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8ubuntu-core%20rootfs%E6%9D%A5%E8%BF%90%E8%A1%8Cbrnigup%EF%BC%9Fubuntu-core%20rootfs%E7%9A%84%E9%93%BE%E6%8E%A5%E4%BC%BC%E4%B9%8E%E5%B7%B2%E5%A4%B1%E6%95%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EPrathamesh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8E%B0%E5%9C%A8%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E8%AF%A5%E7%BA%BF%E7%A8%8B%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%E3%80%82%E6%88%91%E6%9B%B4%E6%8D%A2%E4%BA%86gcc%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E7%BC%96%E8%AF%91%E3%80%82%E4%BD%86%E6%98%AF%E6%88%91%E4%B8%80%E4%B8%AA%E6%9C%88%E5%89%8D%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%98%AF%E6%9F%90%E4%BA%9B%E6%8F%90%E4%BA%A4%E9%98%BB%E6%96%AD%E4%BA%86%E6%9E%84%E5%BB%BA%E6%B5%81%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B6%E4%BB%96%E4%BA%BA%E9%81%87%E5%88%B0%E4%B8%8E%E6%88%91%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%AE%89%E8%A3%85ubuntu%20Linaro%20LXDE%E6%A1%8C%E9%9D%A2%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E4%BD%BF%E7%94%A8%E8%A7%A6%E6%91%B8%E9%9D%A2%E6%9D%BF%E3%80%82%E6%88%91%E7%A1%AE%E8%AE%A4%E8%A7%A6%E6%91%B8%E9%9D%A2%E6%9D%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%8A%B6%E6%80%81%E6%AD%A3%E5%B8%B8%E3%80%82%E5%BD%93%E6%88%91%E6%89%A7%E8%A1%8C%2Fdev%2Finput%2Fevent0%E5%B9%B6%E8%A7%A6%E6%91%B8%E9%9D%A2%E6%9D%BF%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E7%94%9F%E6%88%90%E8%BE%93%E5%85%A5%E4%BA%8B%E4%BB%B6%E3%80%82%E4%BD%86%E6%98%AFubuntu%E6%A1%8C%E9%9D%A2%E5%B9%B6%E6%9C%AA%E5%93%8D%E5%BA%94%E3%80%82%E6%9C%89%E4%BA%BA%E8%83%BD%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BAwandboard_dl_defconfig%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86u-boot%E7%BC%96%E8%AF%91%E5%99%A8%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%E8%AF%B7%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELD%20examples%2Fstandalone%2Fhello_world%3CBR%20%2F%3E%20OBJCOPY%20examples%2Fstandalone%2Fhello_world.srec%3CBR%20%2F%3E%20OBJCOPY%20examples%2Fstandalone%2Fhello_world.bin%3CBR%20%2F%3ELDS%20u-boot.lds%3CBR%20%2F%3ELD%20u-boot%3CBR%20%2F%3Earch%2Farm%2Fimx-common%2Fbuilt-in.o%3A%20%E5%9C%A8%E5%87%BD%E6%95%B0%60print_cpuinfo'%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fimx-common%2Fcpu.c%3A199%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60uclass_get_device'%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fimx-common%2Fcpu.c%3A201%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60thermal_get_temp'%3CBR%20%2F%3Earch%2Farm%2Fimx-common%2Fbuilt-in.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%60arch_preboot_os'%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fimx-common%2Fcpu.c%3A270%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60ldo_mode_set'%3CBR%20%2F%3Edrivers%2Fbuilt-in.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%60read_cpu_temperature'%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A43%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60dev_get_platdata'%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A45%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60dev_get_priv'%3CBR%20%2F%3Edrivers%2Fbuilt-in.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%60imx_thermal_probe'%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A226%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60dev_get_platdata'%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A227%EF%BC%9A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%60dev_get_priv'%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%EF%BC%9ABFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git2.24.0.20141017%E6%96%AD%E8%A8%80%E5%A4%B1%E8%B4%A5%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%20BFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git%202.24.0.20141017%E6%96%AD%E8%A8%80%E5%A4%B1%E8%B4%A5%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%20BFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git%202.24.0.20141017%E6%96%AD%E8%A8%80%E5%A4%B1%E8%B4%A5%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%20BFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git%202.24.0.20141017%E6%96%AD%E8%A8%80%E5%A4%B1%E8%B4%A5%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%20BFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git%202.24.0.20141017%E6%96%AD%E8%A8%80%E5%A4%B1%E8%B4%A5%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%BF%85%E9%9C%80%E9%83%A8%E5%88%86'.rel.plt'%20%E6%9C%AA%E5%9C%A8%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%E4%B8%AD%E6%89%BE%E5%88%B0%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%EF%BC%9A%E6%9C%80%E7%BB%88%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%95%88%E6%93%8D%E4%BD%9C%3CBR%20%2F%3Emake%3A%20***%20%5Bu-boot%5D%20%E9%94%99%E8%AF%AF1%3CBR%20%2F%3Elucid%40ubuntu%3A~%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%24%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EWF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%8A%E6%95%AC%E7%9A%84%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E7%BB%A7%E7%BB%AD%E6%A0%B9%E6%8D%AE%E8%AF%A5%E9%83%A8%E5%88%86%E7%9A%84%E6%8C%87%E4%BB%A4%E4%B8%BAX11%E6%B7%BB%E5%8A%A0GPU%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7gpu_pack%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%E6%8C%87%E4%BB%A4%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E8%AF%B4%E6%98%8E%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd%26nbsp%3Bkernel-modu*%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bmake%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%E5%88%87%E6%8D%A2%E5%88%B0%20gpu-core%20x11%20%E5%90%8E%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%20backend%3Dx11%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%3CEM%3Ekernel-modu*%3C%2FEM%3E%E4%BB%8E%E4%BD%95%E8%80%8C%E6%9D%A5%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BAkernel-modu*%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E5%9C%A8ubuntu%20Linaro%20LXDE%20rootfs%E4%B8%AD%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%B0%86LCD%E4%BB%8E%E6%A8%AA%E5%90%91%E6%A8%A1%E5%BC%8F%E6%97%8B%E8%BD%AC%E4%B8%BA%E7%BA%B5%E5%90%91%E6%A8%A1%E5%BC%8F%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86USB%E7%A3%81%E7%9B%98%E5%92%8CUSB%E9%BC%A0%E6%A0%87%E8%BF%9E%E6%8E%A5%E5%88%B0USB%E4%B8%BB%E6%9C%BA%E7%AB%AF%E5%8F%A3%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E6%A3%80%E6%B5%8B%E5%88%B0%E8%BF%99%E4%BA%9B%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E8%83%BD%E7%9C%8B%E5%88%B0%E5%A6%82%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Eusb_otg_vbus%EF%BC%9A%E6%AD%A3%E5%9C%A8%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%80%E4%B9%88%E9%94%99%E8%AF%AF%EF%BC%9F%E6%88%91%E4%BB%8D%E4%BC%9A%E6%94%B6%E5%88%B0%E5%B7%B2%E5%8F%91%E5%B8%83%E7%9A%84%E9%94%99%E8%AF%AF%E6%8F%90%E7%A4%BA%EF%BC%8C%E4%BD%86%E9%9F%B3%E9%A2%91%E5%8A%9F%E8%83%BD%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E5%B7%B2%E6%9A%82%E5%81%9C%E6%8E%92%E6%9F%A5%E6%95%85%E9%9A%9C%EF%BC%8C%E5%BE%85%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E5%90%8E%E5%B0%86%E7%BB%A7%E7%BB%AD%E8%BF%9B%E8%A1%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%E9%94%99%E3%80%82%E6%88%91%E5%B7%B2%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA'linaro'%E7%94%A8%E6%88%B7%EF%BC%8C%E8%AF%A5%E7%94%A8%E6%88%B7%E5%90%8C%E6%A0%B7%E6%9C%AA%E8%AE%BE%E7%BD%AE%E5%AF%86%E7%A0%81%EF%BC%8C%E4%BD%86%E7%B3%BB%E7%BB%9F%E4%BB%8D%E6%98%BE%E7%A4%BA%E7%99%BB%E5%BD%95%E9%A1%B5%E9%9D%A2%E3%80%82%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E5%85%88%E8%AF%95%E8%AF%95'root'%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8%E8%BF%9B%E5%85%A5%E6%A1%8C%E9%9D%A2%EF%BC%8C%E6%89%80%E4%BB%A5%E4%B8%8D%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E7%BB%A7%E7%BB%AD%E5%A4%84%E7%90%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%80%BB%E4%B9%8B%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BB%A5root%E8%BA%AB%E4%BB%BD%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E7%99%BB%E5%BD%95%E7%95%8C%E9%9D%A2%E3%80%82%E8%BF%99%E5%AF%B9%E6%88%91%E6%9C%89%E6%95%88%3C%2FP%3E%3CP%3E%2Fetc%2Flxdm%24%20lxdm.conf%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%5Bbase%5D%3CBR%20%2F%3E%23%23%20%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A%E5%B9%B6%E8%AE%BE%E7%BD%AE%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%E7%94%A8%E6%88%B7%E5%90%8D%E4%BB%A5%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E7%99%BB%E5%BD%95%3CBR%20%2F%3E%3CSTRONG%3Eautologin%3Droot%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20uncomment%20and%20set%20timeout%20to%20enable%20timeout%20autologin%2C%3CBR%20%2F%3E%23%23%20%E8%AF%A5%E5%80%BC%E5%BA%94%26gt%3B%3D5%23%20%E8%B6%85%E6%97%B6%3D10%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E5%BD%93%E6%B2%A1%E6%9C%89%E7%B3%BB%E7%BB%9F%E8%8C%83%E5%9B%B4%E9%85%8D%E7%BD%AE%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E9%BB%98%E8%AE%A4%E4%BC%9A%E8%AF%9D%E6%88%96%E6%A1%8C%E9%9D%A2%3CBR%20%2F%3Esession%3D%2Fusr%2Fbin%2Fstartlxde%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A%E5%B9%B6%E8%AE%BE%E7%BD%AE%E9%94%AE%E7%9B%98%E4%B8%8A%E7%9A%84%E6%95%B0%E5%AD%97%E9%94%81%E5%AE%9A%E9%94%AE%3CBR%20%2F%3E%23%20%E6%95%B0%E5%AD%97%E9%94%81%E5%AE%9A%3D0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E6%83%B3%E5%B0%86%20xauth%20%E6%96%87%E4%BB%B6%E6%94%BE%E5%9C%A8%20~%2F.Xauthority%EF%BC%8C%E8%AF%B7%E8%AE%BE%E7%BD%AE%E6%AD%A4%E9%80%89%E9%A1%B9%3CBR%20%2F%3E%23%20xauth_path%3D%2Ftmp%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E7%94%A8%E4%BA%8E%E6%AC%A2%E8%BF%8E%E7%94%A8%E6%88%B7%E7%9A%84%20greeter%3CBR%20%2F%3Egreeter%3D%2Fusr%2Flib%2Flxdm%2Flxdm-greeter-gtk%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%E6%9C%8D%E5%8A%A1%E5%99%A8%5D%3CBR%20%2F%3E%23%23%20%E7%94%A8%E4%BA%8E%E5%90%AF%E5%8A%A8x%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E5%8F%82%E6%95%B0%EF%BC%8C%E5%8A%9F%E8%83%BD%E4%B8%8D%E5%AE%8C%E6%95%B4%3CBR%20%2F%3E%23%20%E5%8F%82%E6%95%B0%3D%2Fusr%2Fbin%2FX%20-background%20vt1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%E6%98%BE%E7%A4%BA%5D%3CBR%20%2F%3E%23%23%20greeter%20%E4%BD%BF%E7%94%A8%E7%9A%84%20gtk%20%E4%B8%BB%E9%A2%98%3CBR%20%2F%3Egtk_theme%3DClearlooks%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E6%AC%A2%E8%BF%8E%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%83%8C%E6%99%AF%3CBR%20%2F%3Ebg%3D%2Fusr%2Fshare%2Fbackgrounds%2Fdefault.png%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E5%A6%82%E6%9E%9C%E6%98%BE%E7%A4%BA%E5%BA%95%E9%83%A8%E7%AA%97%E6%A0%BC%3CBR%20%2F%3Ebottom_pane%3D1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E5%A6%82%E6%9E%9C%E6%98%BE%E7%A4%BA%E8%AF%AD%E8%A8%80%E9%80%89%E6%8B%A9%E6%8E%A7%E4%BB%B6%3CBR%20%2F%3Elang%3D1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E5%A6%82%E6%9E%9C%E6%98%BE%E7%A4%BA%E9%94%AE%E7%9B%98%E5%B8%83%E5%B1%80%E9%80%89%E6%8B%A9%E6%8E%A7%E4%BB%B6%3CBR%20%2F%3Ekeyboard%3D0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E8%BF%8E%E5%AE%BE%E7%9A%84%E4%B8%BB%E9%A2%98%3CBR%20%2F%3E%E4%B8%BB%E9%A2%98%3D%E5%B7%A5%E4%B8%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5Binput%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%E7%94%A8%E6%88%B7%E5%88%97%E8%A1%A8%5D%3CBR%20%2F%3E%23%23%20%E5%A6%82%E6%9E%9C%E5%9C%A8%E6%AC%A2%E8%BF%8E%E7%95%8C%E9%9D%A2%E7%A6%81%E7%94%A8%E7%94%A8%E6%88%B7%E5%88%97%E8%A1%A8%E6%8E%A7%E5%88%B6%3CBR%20%2F%3Edisable%3D0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E7%99%BD%E5%90%8D%E5%8D%95%E7%94%A8%E6%88%B7%3CBR%20%2F%3Ewhite%3D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E9%BB%91%E5%90%8D%E5%8D%95%E7%94%A8%E6%88%B7%3CBR%20%2F%3Eblack%3D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%E9%94%99%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%88%90%E5%8A%9F%E7%A7%BB%E9%99%A4'startlxde'%E4%B8%AD%E7%9A%84%E7%99%BB%E5%BD%95%E9%A1%B5%E9%9D%A2%EF%BC%8C%E8%AF%B7%E5%8A%A1%E5%BF%85%E5%91%8A%E7%9F%A5%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E4%BB%A5%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E4%BF%AE%E5%A4%8D%E4%BA%86gstreamer-imx%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%BB%88%E4%BA%8E%E6%88%90%E5%8A%9F%E7%99%BB%E5%BD%95%EF%BC%9A%E5%9C%A8%E7%9C%8B%E5%88%B0LXDE%E7%99%BB%E5%BD%95%E7%95%8C%E9%9D%A2%E5%90%8E%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%85%B3%E9%97%ADGUI%E5%B9%B6%E9%80%9A%E8%BF%87CTRL%2BALT%2BF1%E5%90%AF%E5%8A%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%A8%A1%E5%BC%8F%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E9%87%8D%E6%96%B0%E8%AE%BE%E7%BD%AE%E4%BA%86root%E7%9A%84%E5%AF%86%E7%A0%81%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87CTRL%2BALT%2BF7%E5%88%87%E5%9B%9EGUI%EF%BC%8C%E6%9C%80%E7%BB%88%E4%BB%A5root%E8%BA%AB%E4%BB%BD%E7%99%BB%E5%BD%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EErik%2C%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E6%82%A8%E5%B0%9A%E6%9C%AA%E5%AE%89%E8%A3%85%20xorg%20%E5%92%8C%20xinit%E3%80%82%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%8E%E7%99%BD%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E5%AE%8C%E6%88%90%E5%AE%89%E8%A3%85%E5%90%8E%EF%BC%8C%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E2%80%9Cstartx%E2%80%9D%E5%91%BD%E4%BB%A4%EF%BC%88%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%EF%BC%89%E3%80%82%E6%88%91%E7%9A%84%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%BD%8D%E4%BA%8EPC%E4%B8%BB%E6%9C%BA%E7%AB%AF%EF%BC%8C%E9%80%9A%E8%BF%87UART%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%E3%80%82%E7%9B%AE%E6%A0%87%E6%98%BE%E7%A4%BA%E4%BA%86%E7%99%BB%E5%BD%95%E7%95%8C%E9%9D%A2%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E8%B7%B3%E8%BF%87%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%BF%AE%E6%94%B9%EF%BC%8C%E4%BD%86%E4%BB%8D%E6%9C%AA%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erik%2C%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B9%9F%E4%BD%BF%E7%94%A8%E8%BF%87Linaro%20LXDE%EF%BC%8C%E9%82%A3%E4%B9%88%E9%BB%98%E8%AE%A4%E6%98%BE%E7%A4%BA%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%BAlxdm%EF%BC%8C%E5%AE%83%E9%80%9A%E8%BF%87%2Fetc%2Finit.d%2F%E5%90%AF%E5%8A%A8%E3%80%82Lxdm%E4%BD%BF%E7%94%A8%2Fetc%2Flxdm%2Flxdm.conf%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E3%80%82%E6%88%91%E5%B7%B2%E5%B0%86%E9%BB%98%E8%AE%A4%E4%BC%9A%E8%AF%9D%E6%9B%B4%E6%94%B9%E4%B8%BA'startx'%E4%BB%A5%E8%B7%B3%E8%BF%87%E7%99%BB%E5%BD%95%E9%A1%B5%E9%9D%A2%E3%80%82%E4%BD%86%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E6%9D%83%E5%AE%9C%E4%B9%8B%E8%AE%A1%E3%80%82%3CBR%20%2F%3E%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E8%AF%A6%E8%A7%81%EF%BC%9A%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwiki.archlinux.org%2Findex.php%2FLXDM%22%20title%3D%22https%3A%2F%2Fwiki.archlinux.org%2Findex.php%2FLXDM%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELXDM%20-%20ArchWiki%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CJaffin%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E4%B9%9F%E9%81%87%E5%88%B0%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%9A%E6%82%A8%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erik%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E7%BB%95%E8%BF%87%E7%99%BB%E5%BD%95%E7%AA%97%E5%8F%A3%E7%9B%B4%E6%8E%A5%E5%90%AF%E5%8A%A8%E8%BF%9B%E5%85%A5%E6%A1%8C%E9%9D%A2%EF%BC%9F%E5%BD%93%E6%88%91%E4%BB%8E%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%89%A7%E8%A1%8Cstartx%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%9C%A8%E5%B1%8F%E5%B9%95%E4%B8%8A%E5%90%AF%E5%8A%A8%E6%A1%8C%E9%9D%A2%E7%8E%AF%E5%A2%83%E3%80%82%E4%BD%86%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Cstartlxde%E7%A8%8B%E5%BA%8F%E4%BC%9A%E6%89%A7%E8%A1%8C%EF%BC%8C%E5%B0%86%E6%88%91%E5%BC%95%E5%90%91%E7%99%BB%E5%BD%95%E9%A1%B5%E9%9D%A2%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%AD%A4%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%E7%94%A8%E6%88%B7%E5%90%8D%E7%99%BB%E5%BD%95%E3%80%82%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E5%8A%A0%E8%BD%BDstartx%E3%80%82%EF%BC%88%E5%90%8E%E7%BB%AD%E5%B8%8C%E6%9C%9B%E7%9B%B4%E6%8E%A5%E5%90%AF%E5%8A%A8%E8%BF%9B%E5%85%A5%E5%8D%95%E4%B8%80gui%E5%BA%94%E7%94%A8%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erik%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20iMX6%20QP%20Sabre%20Board%E3%80%82%E4%B8%80%E5%88%87%E9%83%BD%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20GUI%20%E7%99%BB%E5%BD%95%E7%AE%A1%E7%90%86%E5%99%A8%E7%99%BB%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E4%BB%8A%E5%A4%A9%E8%BF%98%E9%81%87%E5%88%B0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%B7%B2%E5%AE%89%E8%A3%85gstreamer-imx%E5%8F%8A%E5%85%B6%E6%8F%92%E4%BB%B6%EF%BC%8C%E4%BD%86%E9%9F%B3%E9%A2%91%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%8F%92%E4%BB%B6%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E4%B8%94%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C'gst-inspect-1.0-b'%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%8F%90%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%3A%20lib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%EF%BC%88gst-plugin-scanner%3A8983%EF%BC%89%EF%BC%9AGStreamer-WARNING%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%EF%BC%9AGStreamer-%E8%AD%A6%E5%91%8A%20**%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E6%8F%92%E4%BB%B6'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E5%88%97%E5%85%A5%E9%BB%91%E5%90%8D%E5%8D%95%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%20libgstimxaudio.so%3C%2FP%3E%3CP%3E%E6%80%BB%E8%AE%A1%EF%BC%9A1%20%E4%B8%AA%E8%A2%AB%E5%88%97%E5%85%A5%E9%BB%91%E5%90%8D%E5%8D%95%E7%9A%84%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E5%90%8C%E6%97%B6%E5%AE%89%E8%A3%85fsl%E8%A7%86%E9%A2%91%E5%92%8C%E9%9F%B3%E9%A2%91%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E5%90%8E%EF%BC%8C%E5%8F%AA%E6%9C%89%E9%9F%B3%E9%A2%91%E6%8F%92%E4%BB%B6%E8%A2%AB%E5%88%97%E5%85%A5%E9%BB%91%E5%90%8D%E5%8D%95%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9F%A5%E9%98%85%E4%BA%86%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E7%9A%84%E9%93%BE%E6%8E%A5%E3%80%82%E5%AE%83%E8%BF%98%E6%98%BE%E7%A4%BA%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E6%96%87%E4%BB%B6%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E7%9B%AE%E5%BD%95%EF%BC%8C%E6%96%87%E4%BB%B6%E7%A1%AE%E5%AE%9E%E5%AD%98%E5%9C%A8%E4%BA%8E%E7%9B%AE%E5%BD%95%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E4%BB%80%E4%B9%88%20imx%20%E6%9D%BF%2F%E8%8A%AF%E7%89%87%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E8%BF%99%E7%AF%87%E7%B2%BE%E5%BD%A9%E7%9A%84%E5%B8%96%E6%96%87%E3%80%82%E5%AE%83%E5%AF%B9%E6%88%91%E5%B8%AE%E5%8A%A9%E5%BE%88%E5%A4%A7%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86Linaro%20LXDE%20rootfs%EF%BC%88%E9%83%A8%E5%88%86%E5%8E%9F%E5%9B%A0%E6%98%AFubuntu%E6%A0%B8%E5%BF%83%E9%93%BE%E6%8E%A5%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%89%E3%80%82%E9%99%A4%E4%BA%86%E5%9C%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E7%9A%84%E4%B8%80%E4%BA%9B%E5%B0%8F%E9%97%AE%E9%A2%98%E5%A4%96%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8%E7%A1%AC%E4%BB%B6%E5%B9%B6%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%99%BB%E5%BD%95%E5%88%B0shell%E3%80%82%E4%BD%86HDMI%E6%98%BE%E7%A4%BA%E5%B1%8F%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E7%99%BB%E5%BD%95%E7%95%8C%E9%9D%A2%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E8%BE%93%E5%85%A5%E7%94%A8%E6%88%B7%E5%90%8D%E2%80%9Croot%E2%80%9D%E5%92%8C%E2%80%9Clinaro%E2%80%9D%E5%B9%B6%E7%9C%81%E7%95%A5%E5%AF%86%E7%A0%81%EF%BC%88%E5%9B%A0%E4%B8%BA%E6%88%91%E5%B7%B2%E6%8C%89%E7%85%A7%E4%B8%8A%E8%BF%B0%E6%B5%81%E7%A8%8B%E7%A7%BB%E9%99%A4root%E5%92%8Clinaro%E7%94%A8%E6%88%B7%E7%9A%84%E5%AF%86%E7%A0%81%EF%BC%89%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E5%8D%A1%E5%9C%A8%E5%90%8C%E4%B8%80%E7%95%8C%E9%9D%A2%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E8%B7%B3%E8%BF%87%E7%99%BB%E5%BD%95%E7%95%8C%E9%9D%A2%E8%BF%9B%E5%85%A5GUI%E3%80%82%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%88%91%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%E5%86%85%E5%AE%B9%E3%80%82%E6%88%96%E8%80%85%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A7%BB%E9%99%A4%E8%AF%A5%E7%99%BB%E5%BD%95%E7%95%8C%E9%9D%A2%E7%AE%A1%E7%90%86%E5%99%A8%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8F%A6%E8%A1%8C%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%E7%AE%A1%E7%90%86%E5%99%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%B7%B2%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8Linaro%2014.10%E9%95%9C%E5%83%8F%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E5%8F%AA%E8%83%BD%E9%80%9A%E8%BF%87HDMI%E6%98%BE%E7%A4%BA%E5%99%A8%E6%9F%A5%E7%9C%8B%E5%B1%8F%E5%B9%95%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%AE%83%E6%9D%A5%E8%87%AAPC%E7%9A%84%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%A6%82%E4%BD%95%E5%9C%A8HDMI%E6%98%BE%E7%A4%BA%E5%99%A8%E4%B8%8A%E5%90%AF%E7%94%A8%E5%B9%B6%E8%BF%90%E8%A1%8C%E8%AF%A5%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E6%88%91%E6%8C%89%E7%85%A7%E7%AC%AC%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background-color%3A%20%23ffffff%3B%22%3E3%E8%8A%82%EF%BC%9A%E4%BF%AE%E6%94%B9Rootfs%E5%B9%B6%E5%AE%89%E8%A3%85%E6%89%80%E9%9C%80%E4%BB%A3%E7%A0%81%E5%8C%85%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E7%9A%84%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8D%B3%E4%BD%BF%E7%BD%91%E7%BB%9C%E3%80%81sources.list%E3%80%81%E4%B8%BB%E6%9C%BA%E5%90%8D%E5%B9%B6%E6%9C%AA%E6%89%A7%E8%A1%8C%E7%9B%B8%E5%BA%94%E9%85%8D%E7%BD%AE%E3%80%82%E6%88%91%E5%B7%B2%E5%9C%A8%E4%B8%BB%E6%9C%BAPC%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BA%9B%E8%AE%BE%E7%BD%AE%E5%B9%B6%E6%9C%AA%E6%88%90%E5%8A%9F%E5%90%8C%E6%AD%A5%E2%80%A6%E2%80%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EU-Boot%202016.03%EF%BC%882016%E5%B9%B411%E6%9C%884%20%E6%97%A5%20-%2011%3A24%3A24%20%2B0100%EF%BC%89%3C%2FP%3E%3CP%3ECPU%EF%BC%9AFreescale%20i.MX6QP%20rev1.0%20996%20MHz%EF%BC%88%E8%BF%90%E8%A1%8C%E9%A2%91%E7%8E%87%E4%B8%BA%20792%20MHz%EF%BC%89%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B1%BD%E8%BD%A6%E7%BA%A7%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%EF%BC%88-40%C2%B0C%20%E8%87%B3%20125%C2%B0C%EF%BC%89%EF%BC%8C%E5%BD%93%E5%89%8D%E6%B8%A9%E5%BA%A6%E4%B8%BA%2031%C2%B0C%3CBR%20%2F%3E%E5%A4%8D%E4%BD%8D%E5%8E%9F%E5%9B%A0%EF%BC%9APOR%3CBR%20%2F%3E%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%9AMX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%EF%BC%9A%E5%B7%B2%E5%B0%B1%E7%BB%AA%3CBR%20%2F%3EDRAM%EF%BC%9A2%20GiB%3CBR%20%2F%3EPMIC%EF%BC%9APFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%EF%BC%9A0%20MiB%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%EF%BC%8CFSL_SDHC%EF%BC%9A1%3CBR%20%2F%3E%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E9%9D%A2%E6%9D%BF%EF%BC%9A%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%20Hannstar-XGA%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%EF%BC%9AHannstar-XGA%20(1024x768)%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%E4%B8%B2%E5%8F%A3%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E5%8F%A3%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E5%8F%A3%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%20%230%EF%BC%8C%E6%88%90%E5%8A%9F%3CBR%20%2F%3Emmc1%20%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%EF%BC%9AFEC%20%5BPRIME%5D%3CBR%20%2F%3E%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%20%230%EF%BC%8C%E6%88%90%E5%8A%9F%3CBR%20%2F%3Emmc1%20%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%20boot.scr%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E6%96%87%E4%BB%B6%20boot.scr%20**%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%20zImage%3CBR%20%2F%3E6637656%20%E5%AD%97%E8%8A%82%E5%9C%A8%20328%20%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96%E5%AE%8C%E6%AF%95%EF%BC%8819.3%20MiB%2Fs%EF%BC%89%3CBR%20%2F%3E%E4%BB%8E%20mmc%20%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%20imx6qp-sabreauto.dtb%3CBR%20%2F%3E20%20%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96%2048853%20%E5%AD%97%E8%8A%82%20(2.3%20MiB%2Fs)%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%20%40%200x12000000%20%5B%200x000000%20-%200x654858%20%5D%3CBR%20%2F%3E%23%23%20%E4%BD%8D%E4%BA%8E%2018000000%20%E7%9A%84%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%200x18000000%20%E7%9A%84%20fdt%20blob%20%E5%BC%95%E5%AF%BC%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E%2018000000%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E%201800eed4%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%89%A9%E7%90%86CPU%200x0%E4%B8%8A%E5%90%AF%E5%8A%A8%20Linux%3CBR%20%2F%3ELinux%E7%89%88%E6%9C%AC4.1.15(r59400%40Latitude)%EF%BC%88gcc%E7%89%88%E6%9C%AC4.8.5%20(Linaro%20GCC%204.8-2015.06)%EF%BC%89%231%20SMP%20PREEMPT%202016%E5%B9%B411%E6%9C%884%E6%97%A5%2011%3A53%3A43%20CET%3CBR%20%2F%3ECPU%EF%BC%9AARMv7%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%8810%20(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%20%E9%9D%9E%E5%88%AB%E5%90%8D%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%EF%BC%8CVIPT%E5%88%AB%E5%90%8D%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%EF%BC%9AFreescale%20i.MX6%20Quad%20Plus%20SABRE%E6%B1%BD%E8%BD%A6%E5%BC%80%E5%8F%91%E6%9D%BF%3CBR%20%2F%3E%E9%A2%84%E7%95%99%E5%86%85%E5%AD%98%EF%BC%9A%E5%9C%A80x6a000000%E5%A4%84%E5%88%9B%E5%BB%BACMA%E5%86%85%E5%AD%98%E6%B1%A0%EF%BC%8C%E5%A4%A7%E5%B0%8F%E4%B8%BA320MiB%3CBR%20%2F%3E%E9%A2%84%E7%95%99%E5%86%85%E5%AD%98%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E8%8A%82%E7%82%B9linux%2Ccma%EF%BC%8C%E5%85%BC%E5%AE%B9ID%20shared-dma-pool%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9A%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E5%86%99%E5%85%A5%E5%88%86%E9%85%8D%3CBR%20%2F%3EPERCPU%EF%BC%9A%E5%B7%B2%E5%B5%8C%E5%85%A512%E9%A1%B5%2Fcpu%20%40ee6fe000%20s16960%20r8192%20d24000%20u49152%3CBR%20%2F%3E%E5%B7%B2%E6%9E%84%E5%BB%BA1%E4%B8%AA%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%8E%92%E5%88%97%E7%9A%84%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E5%90%AF%E7%94%A8%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A520720%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk2p2%20rootwait%20rw%3CBR%20%2F%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E7%9B%AE%E5%BD%95%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A262144%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E7%B4%A2%E5%BC%95%E8%8A%82%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A1737928K%2F2097152K%E5%8F%AF%E7%94%A8%EF%BC%888295K%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%EF%BC%8C435K%E5%8F%AF%E8%AF%BB%E5%86%99%E6%95%B0%E6%8D%AE%EF%BC%8C2892K%E5%8F%AA%E8%AF%BB%E6%95%B0%E6%8D%AE%EF%BC%8C432K%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C450K%20bss%EF%BC%8C31544K%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%8C327680K%20cma%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%8C270336K%E9%AB%98%E5%86%85%E5%AD%98%EF%BC%89%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3CBR%20%2F%3E%20%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000%20-%200xffff1000%20(4KB)%3CBR%20%2F%3E%20%E5%9B%BA%E5%AE%9A%E6%98%A0%E5%B0%84%EF%BC%9A0xffc00000%20-%200xfff00000%20(3%2C072%20kB)%3CBR%20%2F%3E%20%E8%99%9A%E6%8B%9F%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%EF%BC%9A0xf0000000%20-%200xff000000%20(240%20MB)%3CBR%20%2F%3E%20%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xef800000%20(1784MB)%3CBR%20%2F%3E%20%E6%8C%81%E4%B9%85%E5%86%85%E6%A0%B8%E6%98%A0%E5%B0%84%EF%BC%9A0x7fe00000%20-%200x80000000%20(2MB)%3CBR%20%2F%3E%20%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%20(14MB)%3CBR%20%2F%3E%20.text%3A%200x80008000%EF%BC%8D0x80af51c8%20(11%2C189%20kB)%3CBR%20%2F%3E%20.init%3A%200x80af6000%20-%200x80b62000%20(432%20kB)%3CBR%20%2F%3E.data%EF%BC%9A0x80b62000%EF%BC%8D0x80bcec40%EF%BC%88436%20kB%EF%BC%89%3CBR%20%2F%3E.bss%EF%BC%9A0x80bd1000%EF%BC%8D0x80c41a5c%EF%BC%88451%20kB%EF%BC%89%3CBR%20%2F%3ESLUB%EF%BC%9A%E7%A1%AC%E4%BB%B6%E5%AF%B9%E9%BD%90%3D64%EF%BC%8C%E5%86%85%E5%AD%98%E5%9D%97%E9%98%B6%E6%95%B0%3D0-3%EF%BC%8C%E6%9C%80%E5%B0%8F%E5%AF%B9%E8%B1%A1%E6%95%B0%3D0%EF%BC%8CCPU%3D4%EF%BC%8C%E8%8A%82%E7%82%B9%3D1%3CBR%20%2F%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E5%BC%8F%E5%88%86%E5%B1%82RCU%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E5%87%BA%E7%8E%B0%E5%81%9C%E9%A1%BF%E6%97%B6%EF%BC%8C%E6%89%93%E5%8D%B0%E6%AF%8F%E4%B8%AACPU%E7%9A%84%E9%99%84%E5%8A%A0%E4%BF%A1%E6%81%AF%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3EL2C-310%E8%AF%AF%E5%B7%AE769419%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3EL2C-310%E5%90%AF%E7%94%A8Cortex-A9%E7%9A%84%E6%97%A9%E6%9C%9FBRESP%3CBR%20%2F%3EL2C-310%E5%B7%B2%E5%90%AF%E7%94%A8Cortex-A9%E7%9A%84%E5%85%A8%E9%9B%B6%E8%A1%8C%3CBR%20%2F%3EL2C-310%20ID%E9%A2%84%E5%8F%96%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%81%8F%E7%A7%BB%E9%87%8F16%E8%A1%8C%3CBR%20%2F%3EL2C-310%E5%8A%A8%E6%80%81%E6%97%B6%E9%92%9F%E9%97%A8%E6%8E%A7%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3EL2C-310%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C16%E8%B7%AF%EF%BC%8C1024kB%3CBR%20%2F%3EL2C-310%3A%20CACHE_ID%200x410000c8%EF%BC%8CAUX_CTRL%200x76470001%3CBR%20%2F%3Emxc_clocksource_init%203000000%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%9F%BA%E4%BA%8E%E5%AE%9A%E6%97%B6%E5%99%A8%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87333ns%3CBR%20%2F%3Esched_clock%3A%2032%E4%BD%8D%EF%BC%8C3000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87333ns%EF%BC%8C%E6%AF%8F715827882841%20ns%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3CBR%20%2F%3E%E6%97%B6%E9%92%9F%E6%BA%90mxc_timer1%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xffffffff%20%E6%9C%80%E5%A4%A7%E5%91%A8%E6%9C%9F%EF%BC%9A0xffffffff%EF%BC%8C%E6%9C%80%E5%A4%A7%E7%A9%BA%E9%97%B2%E6%97%B6%E9%97%B4%EF%BC%9A637086815595ns%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%8780x30%3CBR%20%2F%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%88%E5%B7%B2%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E6%A0%B9%E6%8D%AE%E5%AE%9A%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E5%80%BC..%206.00%20BogoMIPS%20(lpj%3D30000)%3CBR%20%2F%3E%E8%BF%9B%E7%A8%8BID%E6%9C%80%E5%A4%A7%E5%80%BC%EF%BC%9A%E9%BB%98%E8%AE%A4%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%EF%BC%9A301%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%3A%202%2C%2016384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%3A%204096%EF%BC%88%E9%A1%BA%E5%BA%8F%3A%202%2C%2016384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ECPU%3A%20%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%88%90%E5%8A%9F%3CBR%20%2F%3ECPU0%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%2C%20CPU%200%2C%20%E6%8F%92%E6%A7%BD0%2C%20mpidr%2080000000%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E6%A0%87%E8%AF%86%E6%98%A0%E5%B0%84%E8%A1%A8%EF%BC%9A0x10008280%20-%200x100082d8%3CBR%20%2F%3ECPU1%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%2C%20CPU%201%2C%20%E6%8F%92%E6%A7%BD0%2C%20mpidr%2080000001%3CBR%20%2F%3ECPU2%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%2C%20CPU%202%2C%20%E6%8F%92%E6%A7%BD0%2C%20mpidr%2080000002%3CBR%20%2F%3ECPU3%3A%20%E7%BA%BF%E7%A8%8B-1%2C%20CPU%203%2C%20%E6%8F%92%E6%A7%BD0%2C%20mpidr%2080000003%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E5%8A%A84%E4%B8%AACPU%3CBR%20%2F%3ESMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB4%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8(24.00%20BogoMIPS)%E3%80%82%3CBR%20%2F%3ECPU%EF%BC%9A%E6%89%80%E6%9C%89CPU%E5%9D%87%E4%BB%A5SVC%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3Edevtmpfs%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EVFP%E6%94%AF%E6%8C%81%E7%89%88%E6%9C%AC0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E4%BB%B6%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3CBR%20%2F%3E%E6%97%B6%E9%92%9F%E6%BA%90jiffies%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xffffffff%20%E6%9C%80%E5%A4%A7%E5%91%A8%E6%9C%9F%EF%BC%9A0xffffffff%EF%BC%8C%E6%9C%80%E5%A4%A7%E7%A9%BA%E9%97%B2%E6%97%B6%E9%97%B4%EF%BC%9A19112604462750000ns%3CBR%20%2F%3E%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F16%3CBR%20%2F%3EDMA%EF%BC%9A%E9%A2%84%E5%88%86%E9%85%8D256KiB%E6%B1%A0%E7%94%A8%E4%BA%8E%E5%8E%9F%E5%AD%90%E4%B8%80%E8%87%B4%E6%80%A7%E5%88%86%E9%85%8D%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%98%B6%E6%A2%AF%E5%BD%A2%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%8F%9C%E5%8D%95%E5%9E%8B%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3ECPU%E8%AF%86%E5%88%AB%E4%B8%BAi.MX6QP%EF%BC%8C%E8%8A%AF%E7%89%87%E4%BF%AE%E8%AE%A2%E7%89%881.0%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E5%8F%91%E7%8E%B05%E4%B8%AA%EF%BC%88%2B1%E4%B8%AA%E9%A2%84%E7%95%99%EF%BC%89%E6%96%AD%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E5%92%8C1%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA4%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20%E6%9C%AA%E5%9C%A8%2Fsoc%2Faips-bus%4002000000%2Fiomuxc%40020e0000%2Fhdmicecgrp%E4%B8%AD%E5%AE%9A%E4%B9%89%E4%BB%BB%E4%BD%95%E7%BB%84%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%EF%BC%9AIMX%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eimx-gpc%2020dc000.gpc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0fsl%E6%88%96ldo%E6%97%81%E9%80%9A%EF%BC%81%3CBR%20%2F%3Emxs-dma%20110000.dma-apbh%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3ESCSI%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E7%9A%84%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb%3CBR%20%2F%3E2000000.aips-bus%3Ausbphy_nop1%E6%9C%AA%E6%89%BE%E5%88%B0%E5%88%B0%E7%94%B5%E6%BA%90vcc%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2000000.aips-bus%3Ausbphy_nop2%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90vcc%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Ei2c%20i2c-1%EF%BC%9AIMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ei2c%20i2c-1%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8DMA%3CBR%20%2F%3Ei2c%20i2c-2%EF%BC%9AIMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ei2c%20i2c-2%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8DMA%3CBR%20%2F%3ELinux%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%E6%8E%A5%E5%8F%A3%EF%BC%9A%E7%89%88%E6%9C%AC2.00%3CBR%20%2F%3Epps_core%EF%BC%9ALinuxPPS%20API%20%E7%89%88%E6%9C%AC1%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%3CSPAN%3Epps_core%EF%BC%9A%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC5.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%E6%97%B6%E9%92%9F%E6%94%AF%E6%8C%81%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eimx-ipuv3%202400000.ipu%EF%BC%9AIPU%20DMFC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%EF%BC%8C5B(4%2C5)%EF%BC%8C5F(6%2C7)%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%EF%BC%9AIPU%20DMFC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%EF%BC%8C5B(4%2C5)%EF%BC%8C5F(6%2C7)%3CBR%20%2F%3Eimx-prg%2021cc000.prg%3A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-prg%2021cd000.prg%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021c8000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021c9000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021ca000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021cb000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E9%AB%98%E7%BA%A7Linux%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC2.20%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F31%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90mxc_timer1%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F2%3CBR%20%2F%3ETCP%E5%B7%B2%E5%BB%BA%E7%AB%8B%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B16384%EF%BC%8C%E5%B7%B2%E7%BB%91%E5%AE%9A16384%EF%BC%89%3CBR%20%2F%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EUDP-Lite%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F1%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BAUNIX%E7%9A%84%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Cudp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%20NFSv4.1%E5%90%8E%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ECPU%20PMU%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%2Fsoc%2Fpmu%2Finterrupt-affinity%5B0%5D%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%80%A7%E8%83%BD%E7%9B%91%E6%8E%A7%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8armv7_cortex_a9%20PMU%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C7%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%E5%8F%AF%E7%94%A8%3CBR%20%2F%3Eimx%20rpmsg%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Efutex%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EVFS%EF%BC%9A%E7%A3%81%E7%9B%98%E9%85%8D%E9%A2%9Ddquot_6.6.0%3CBR%20%2F%3EVFS%EF%BC%9ADquot-cache%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%200%EF%BC%8C4096%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENFS%EF%BC%9A%E6%B3%A8%E5%86%8Cid_resolver%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_legacy%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ejffs2%EF%BC%9A%E7%89%88%E6%9C%AC2.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3E%E7%86%94%E4%B8%9D%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88API%E7%89%88%E6%9C%AC7.23%EF%BC%89%3CBR%20%2F%3E%E5%BC%B9%E6%80%A7%E7%BC%93%E5%86%B2%E6%B1%A0%EF%BC%9A%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A64%E9%A1%B5%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8Bnoop%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fdeadline%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fcfq%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E8%83%8C%E5%85%89%E7%94%B5%E6%BA%90%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Emxc_sdc_fb%20fb%400%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%EF%BC%9AIPU%20DMFC%20DP%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%9A1(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AE%BE%E5%A4%87128x48%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%E6%A3%80%E6%B5%8B%E5%88%B0HDMI%E6%8E%A7%E5%88%B6%E5%99%A80x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%E5%90%8D%E7%A7%B0%20-%202.073M9%3CBR%20%2F%3Emxc_sdc_fb%20fb%401%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fhdmi%3CBR%20%2F%3Emxc_sdc_fb%20fb%402%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0mxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3CBR%20%2F%3Emxc_sdc_fb%20fb%403%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%20%E5%86%8D%E6%AC%A1%E8%AF%BB%E5%8F%96EDID%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E6%9C%AA%E5%88%86%E9%85%8Diram%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E5%86%85%E5%AD%98%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E6%98%A0%E5%B0%84%E4%BB%BB%E4%BD%95%E4%BA%8B%E4%BB%B6%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B63.3%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9A%E5%85%A8%E5%B1%82%EF%BC%9A2%EF%BC%8C%E9%87%91%E5%B1%9E%E5%B1%82%EF%BC%9A1%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9AFAB%EF%BC%9A0%EF%BC%8CFIN%EF%BC%9A0%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0pfuze100%E3%80%82%3CBR%20%2F%3E21ec000.serial%EF%BC%9Attymxc2%E4%BD%8D%E4%BA%8EMMIO%200x21ec000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%3D298%EF%BC%8C%E5%9F%BA%E7%A1%80%E6%B3%A2%E7%89%B9%E7%8E%87%3D5%2C000%2C000%EF%BC%89%E6%98%AFIMX%3CBR%20%2F%3E21f0000.serial%EF%BC%9Attymxc3%E5%9C%A8MMIO%200x21f0000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%20299%EF%BC%8C%E5%9F%BA%E7%A1%80%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%205000000%EF%BC%89%E6%98%AFIMX%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%EF%BC%9A%E5%88%9B%E5%BB%BA%E9%BB%98%E8%AE%A4%E6%A8%A1%E5%BC%8F%E5%88%97%E8%A1%A8%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc3%5D%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3Eimx%20sema4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%9620060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E5%B7%B2%E5%9C%A8%E6%AC%A1%E8%A6%81%E7%89%88%E6%9C%AC0%E4%B8%8A%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ebrd%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%B9%B3%E5%8F%B0%E6%95%B0%E6%8D%AE%E3%80%82%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E6%9C%AA%E6%8C%87%E5%AE%9AIRQ%E7%BC%96%E5%8F%B7%EF%BC%8C%E5%B0%86%E4%BD%BF%E7%94%A8%E8%BD%AE%E8%AF%A2%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E5%8F%91%E9%80%81%E5%91%BD%E4%BB%A40x11%E6%97%B6%E5%87%BA%E9%94%99%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E8%AE%BE%E5%A4%87%E7%94%B5%E6%BA%90%E7%8A%B6%E6%80%81%E4%B8%8D%E4%B8%80%E8%87%B4%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-level-mV%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800000024%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-boost-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800000480%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-atten-16ths%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800002000%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Creceive-eq-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A8%2005000000%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9ASSS%E6%A0%87%E5%BF%97%E5%B7%B2%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B9%B6%E8%A1%8C%E6%80%BB%E7%BA%BF%E6%89%AB%E6%8F%8F%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9AAHCI%200001.0300%2032%E4%B8%AA%E6%8F%92%E6%A7%BD%201%E4%B8%AA%E7%AB%AF%E5%8F%A3%203%20Gbps%200x1%E5%AE%9E%E7%8E%B0%E5%B9%B3%E5%8F%B0%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9A%E6%A0%87%E5%BF%97%EF%BC%9Ancq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%3CBR%20%2F%3Escsi%20host0%3A%20ahci-imx%3CBR%20%2F%3Eata1%3A%20SATA%20%E6%9C%80%E5%A4%A7%20UDMA%2F133%20mmio%20%5B%E5%86%85%E5%AD%98%200x02200000-0x02203fff%5D%20%E7%AB%AF%E5%8F%A3%200x100%20%E4%B8%AD%E6%96%AD%20313%3CBR%20%2F%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E2188000.ethernet%20%E7%94%B5%E6%BA%90PHY%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Epps%20pps0%3A%20%E6%96%B0%E7%9A%84PPS%E6%BA%90%20ptp0%3CBR%20%2F%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E5%B7%B2%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Efec%202188000.ethernet%20eth0%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8CPHC%E8%AE%BE%E5%A4%870%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%20%E2%80%9C%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%9D%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8(EHCI)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eehci-mxc%3A%20Freescale%E7%89%87%E4%B8%8AEHCI%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb-storage%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb_ehset_test%3CBR%20%2F%3E2184800.usbmisc%20%E7%94%B5%E6%BA%90vbus-wakeup%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eimx_usb%202184000.usb%3A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3Eimx_usb%202184200.usb%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3Emousedev%EF%BC%9A%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%E9%80%9A%E7%94%A8%E7%9A%84PS%2F2%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%3CBR%20%2F%3Eegalax_ts%201-0004%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3CBR%20%2F%3Eegalax_ts%EF%BC%9A%E6%8E%A2%E6%B5%8B1-0004%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA-5%3CBR%20%2F%3E2-0044%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90vdd%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Aisl29023%E5%85%89%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput1%3CBR%20%2F%3Eisl29023%202-0044%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC1.0%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3Esnvs_rtc%2020cc000.snvs%EF%BC%9Asnvs-rtc-lp%EF%BC%9ARTC%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C20cc000.snvs%3Asnvs-r%E4%BD%9C%E4%B8%BArtc0%E7%9A%84%3CBR%20%2F%3Ei2c%2Fdev%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EIR%20NEC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5(x%2Fsz)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC6%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20JVC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20Sony%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20SANYO%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20Sharp%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20MCE%E9%94%AE%E7%9B%98%2F%E9%BC%A0%E6%A0%87%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20XMP%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo16%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo17%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo18%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo19%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E8%AE%BE%E5%A4%877%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo20%3CBR%20%2F%3E2-000e%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2-000e%20%E7%94%B5%E6%BA%90vddio%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emag3110%202-000e%3A%20%E6%A3%80%E6%9F%A5mag3110%E8%8A%AF%E7%89%87ID%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%3A%20mag3110%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput2%3CBR%20%2F%3Emag3110%202-000e%3A%20mag3110%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3E2-001c%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2-001c%20%E7%94%B5%E6%BA%90vddio%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Amma845x%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput3%3CBR%20%2F%3Eimx2-wdt%2020bc000.wdog%3A%E8%B6%85%E6%97%B660%E7%A7%92%20(nowayout%3D0)%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.3%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AEH4%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEBCSP%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEATH3K%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eata1%EF%BC%9ASATA%E9%93%BE%E8%B7%AF%E6%96%AD%E5%BC%80%20(SStatus%200%20SControl%20300)%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E7%A6%81%E7%94%A8%E9%93%BE%E6%8E%A5%E3%80%82%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8FBCM203x%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fath3k%3CBR%20%2F%3EAHCI-IMX%202200000.sata%EF%BC%9A%E9%80%9A%E8%BF%87ahci_imx..hotplug%3D1%E5%90%AF%E7%94%A8%E7%83%AD%E6%8F%92%E6%8B%94%3CBR%20%2F%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Esdhci%EF%BC%9ACopyright(c)%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%EF%BC%9ASDHCI%E5%B9%B3%E5%8F%B0%E5%92%8COF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A9%E6%89%8B%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%4002190000%EF%BC%9A%E6%9C%AA%E6%8C%87%E5%AE%9A%E7%94%B5%E5%8E%8B%E8%8C%83%E5%9B%B4%3CBR%20%2F%3Esdhci-esdhc-imx%202190000.usdhc%EF%BC%9A%E8%8E%B7%E5%8F%96CD%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202190000.usdhc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Esdhci-esdhc-imx%202190000.usdhc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc0%3A%20SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E2190000.usdhc%20%5B2190000.usdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%4002198000%EF%BC%9A%E7%94%B5%E5%8E%8B%E8%8C%83%E5%9B%B4%E6%9C%AA%E6%8C%87%E5%AE%9A%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%EF%BC%9A%E8%8E%B7%E5%8F%96CD%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%EF%BC%9A%E8%8E%B7%E5%8F%96WP%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc2%EF%BC%9ASDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E2198000.usdhc%20%5B2198000.usdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3E218c000.mlb%E6%97%B6%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90reg_nvcc%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emxc_mlb150%20218c000.mlb%EF%BC%9A%E5%90%AF%E7%94%A8%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emxc_vpu%202040000.vpu_fsl%EF%BC%9AVPU%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Emxc_vdoa%2021e4000.vdoa%3A%20i.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8(VDOA)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E8%8A%82%E7%82%B9hdmicecgrp%E7%9A%84%E7%BB%84%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E8%8A%82%E7%82%B9hdmicecgrp%E7%9A%84%E7%BB%84%3CBR%20%2F%3Emxc_hdmi_cec%20soc%3Ahdmi_cec%4000120000%3A%20%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%2F%E9%80%89%E6%8B%A9CEC%20pinctrl%3CBR%20%2F%3EGalcore%E7%89%88%E6%9C%AC5.0.11.41671%3CBR%20%2F%3Emmc2%EF%BC%9A%E4%BD%8D%E4%BA%8E%E5%9C%B0%E5%9D%800007%E7%9A%84%E6%96%B0%E8%B6%85%E9%AB%98%E9%80%9FSDR104%20SDHC%E5%8D%A1%3CBR%20%2F%3Emmcblk2%EF%BC%9Ammc2%EF%BC%9A0007%20SD32G%2028.9%20GiB%3CBR%20%2F%3Emmcblk2%EF%BC%9Ap1%20p2%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E7%86%B5%E5%BB%B6%E8%BF%9F%20%3D%203200%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E5%B7%B2%E5%AE%9E%E4%BE%8B%E5%8C%96RNG4%20SH0%3CBR%20%2F%3Ecaam%202%2C100%2C000.caam%EF%BC%9A%E5%B7%B2%E5%AE%9E%E4%BE%8B%E5%8C%96RNG4%20SH1%3CBR%20%2F%3Ecaam%202%2C100%2C000.caam%EF%BC%9A%E8%AE%BE%E5%A4%87%20ID%20%3D%200x0a16010000000000%20(Era%20-524)%3CBR%20%2F%3Ecaam%202100000.caam%3A%E4%BD%9C%E4%B8%9A%E7%8E%AF%20%3D%202%EF%BC%8Cqi%20%3D%200%3CBR%20%2F%3Ecaam%E7%AE%97%E6%B3%95%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%9C%A8%2Fproc%2Fcrypto%3CBR%20%2F%3Ecaam_jr%202101000.jr0%EF%BC%9A%E6%B3%A8%E5%86%8Crng-caam%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20blkkey_ex%3A%204%E4%B8%AA%E5%AF%86%E9%92%A5%E5%BA%93%E5%8D%95%E5%85%83%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064-bit%20clear%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20b1%2020%207c%200a%208a%2086%2061%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20f0%2019%2001%2046%2038%2076%20bd%2049%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128-bit%20black%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%202f%2006%2082%201f%20cc%20b0%2035%201f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2072%2003%20b1%20f3%20aa%20e0%203e%20b0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192-bit%20black%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%201b%20b3%20ad%2095%20d0%2024%2081%209a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20fd%20b9%20b8%204c%2055%2017%2092%20c4%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%20ae%20af%20b5%206a%20ea%2059%2001%204f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%201b%20be%20de%20e8%20dd%205c%208b%2010%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256-bit%20clear%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20cf%20f7%2016%2054%202e%207b%2019%20e0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20fe%2096%208c%208b%203e%201b%20b3%20f0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2038%2035%20bc%2080%2067%2035%20ed%2058%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20e1%20dd%2073%2011%2085%208b%2010%201f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20196%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E9%BB%91%E9%92%A5%E4%BD%8D%E4%BA%8Eblob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%207c%2066%201b%2086%202d%201c%20b7%202d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2020%201f%20bb%20eb%20b4%2000%201c%2056%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%208f%20b7%2046%20a6%2040%2058%2028%2049%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2055%20a0%2050%201c%2058%201d%2043%20a9%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2006%203c%2086%2013%20da%207d%20c1%206a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%203b%2009%2077%20ee%203a%20ee%203f%20e6%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%207e%20be%2058%2092%20f4%20b9%201d%204a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E9%BB%91%E9%92%A5%E4%BD%8D%E4%BA%8Eblob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2061%20a7%20fd%2069%20ac%2006%203c%2035%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2055%20aa%2049%2066%20c1%20d2%20ee%2049%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2004%20af%2080%204a%20fe%2033%2092%20ab%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%209c%20a7%20c3%2082%2025%2053%2080%2063%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2022%203e%2089%209a%20e6%20d8%20a6%2054%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20c6%20e6%20f7%2034%20b6%201f%202c%209e%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%205e%2096%2089%205e%20a6%20fc%207f%2087%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2020%205f%207a%2016%2011%203b%20e7%20ce%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E9%BB%91%E9%92%A5%E4%BD%8D%E4%BA%8Eblob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2023%202c%20cb%201b%2073%20ab%207d%2023%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20f4%20b0%20f7%2092%20b2%2078%200d%204c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%20b7%20ba%201e%204d%2005%206d%2031%20f5%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20ce%20c9%20fd%200a%20ce%2039%20eb%2094%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%20cb%20b1%2033%2041%20b7%20f7%206b%2026%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2044%2080%20d7%2026%2036%2025%20ad%2073%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2087%20a0%2051%2029%2082%207f%209c%20d8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%202f%2075%2098%205f%20b7%2050%20f3%20db%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%20b3%2039%2017%20c7%20c9%2090%20c8%2026%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256-bit%20black%20key%20in%20blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2049%20ff%205a%20d8%2079%2044%20e7%2067%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2096%2087%2075%20f6%205c%208a%202e%20df%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%20ae%20cc%20a1%20b6%204a%2031%20f6%20e8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%208d%20fd%20ad%208b%2007%20f3%20e8%20b0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%20c0%2058%2018%209b%20ae%2002%20bb%20ce%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2038%20fb%2044%20db%2004%2067%201b%20c7%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%202c%2015%2075%2041%208d%20c1%2077%20cf%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%20a1%2068%20de%2068%202d%20cd%2024%20e7%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%20d5%207e%20e3%2022%20eb%207a%2021%209d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2063%2067%20cf%203b%2032%2019%20e0%2003%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20restored%2064-bit%20black%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2095%20c8%20a2%20bc%20ac%202e%208e%20d7%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20f7%20cc%20fa%205b%20b6%20a5%205b%204b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20restored%20128-bit%20black%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%202f%2006%2082%201f%20cc%20b0%2035%201f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2072%2003%20b1%20f3%20aa%20e0%203e%20b0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D192%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%201b%20b3%20ad%2095%20d0%2024%2081%209a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20fd%20b9%20b8%204c%2055%2017%2092%20c4%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%205f%2082%2048%2034%20d8%20cb%2015%20a9%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20b0%206c%20fe%20c8%20ee%208e%20cd%2021%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D256%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20cf%20f7%2016%2054%202e%207b%2019%20e0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20fe%2096%208c%208b%203e%201b%20b3%20f0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2038%2035%20bc%2080%2067%2035%20ed%2058%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20e1%20dd%2073%2011%2085%208b%2010%201f%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3A%20%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96snvs%E6%97%B6%E9%92%9F%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%EF%BC%9A%E8%BF%9D%E8%A7%84%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%BF%80%E6%B4%BB%20-%20%E9%9D%9E%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3CBR%20%2F%3Eusbhid%EF%BC%9AUSB%20HID%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Ecs42xx8%201-0048%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%884%3CBR%20%2F%3Efsl-asrc%202034000.asrc%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888%3A%20cs42888%26lt%3B-%26gt%3B%202024000.esai%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888%3A%20snd-soc-dummy-dai%26lt%3B-%26gt%3B%202034000.asrc%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888%3A%20cs42888%26lt%3B-%26gt%3B%202024000.esai%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-spdif%20sound-spdif%3A%20snd-soc-dummy-dai%26lt%3B-%26gt%3B%202004000.spdif%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-tuner-si476x%20sound-fm%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0FM%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%3CBR%20%2F%3Eimx-tuner-si476x%3A%20sound-fm%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-22%3CBR%20%2F%3Eimx-audio-hdmi%20sound-hdmi%3A%20hdmi-hifi%26lt%3B-%26gt%3B%20soc%3Ahdmi_audio%4000120000%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F26%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F10%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%E9%9A%A7%E9%81%93%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F17%3CBR%20%2F%3Ecan%3A%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%8C%BA%E5%9F%9F%E7%BD%91%E7%BB%9C%E6%A0%B8%E5%BF%83%20(%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20ABI%209)%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F29%3CBR%20%2F%3Ecan%3A%20%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%20(%E4%BF%AE%E8%AE%A2%E7%89%8820120528)%3CBR%20%2F%3Ecan%3A%20%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%20(%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20t)%3CBR%20%2F%3Ecan%3A%20netlink%E7%BD%91%E5%85%B3%20(%E4%BF%AE%E8%AE%A2%E7%89%8820130117)%20max_hops%3D1%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%20TTY%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%E7%89%88%E6%9C%AC1.11%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP(%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F)%E7%89%88%E6%9C%AC1.3%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP%E8%BF%87%E6%BB%A4%E5%99%A8%3A%20%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP(%E4%BA%BA%E6%9C%BA%E6%8E%A5%E5%8F%A3%E4%BB%BF%E7%9C%9F)%E7%89%88%E6%9C%AC1.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%E6%94%AF%E6%8C%81%E7%89%88%E6%9C%AC1.8%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bdns_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ecan-stby%3A%20%E7%94%B1can-en%E6%8F%90%E4%BE%9B%3CBR%20%2F%3Eflexcan%202094000.flexcan%3A%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C(reg_base%3Df0648000%2C%20irq%3D31)%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%EF%BC%9AEHCI%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%EF%BC%9A%E6%96%B0%E7%9A%84USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA1%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%EF%BC%9AUSB%202.0%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0USB%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B01%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3AEHCI%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9A%E6%96%B0%E7%9A%84USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA2%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9AUSB%202.0%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A82-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0USB%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A82-0%3A1.0%3A%20%E5%B7%B2%E6%A3%80%E6%B5%8B%E5%88%B01%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Edhd_module_init%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys%E4%BD%9C%E4%B8%BA%2Fdevices%2Fsoc0%2Fgpio-keys%2Finput%2Finput4%3CBR%20%2F%3Esnvs_rtc%2020cc000.snvs%3Asnvs-rtc-lp%3A%20%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA1970-01-01%2000%3A00%3A02%20UTC%20(2)%3CBR%20%2F%3Ecan-stby%EF%BC%9A%E7%A6%81%E7%94%A8%3CBR%20%2F%3Ecan-en%EF%BC%9A%E7%A6%81%E7%94%A8%3CBR%20%2F%3EVGEN2%EF%BC%9A%E7%A6%81%E7%94%A8%3CBR%20%2F%3ESWBST%EF%BC%9A%E7%A6%81%E7%94%A8%3CBR%20%2F%3ESW4%EF%BC%9A%E7%A6%81%E7%94%A8%3CBR%20%2F%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3CBR%20%2F%3E%230%3A%20cs42888-audio%3CBR%20%2F%3E%231%3A%20imx-spdif%3CBR%20%2F%3E%232%3A%20imx-hdmi-soc%3CBR%20%2F%3Eusb%201-1%EF%BC%9A%E6%96%B0%E5%9E%8B%E9%AB%98%E9%80%9FUSB%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B72%E4%BD%BF%E7%94%A8ci_hdrc%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-1%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0USB%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-1%3A1.0%3A%20%E5%B7%B2%E6%A3%80%E6%B5%8B%E5%88%B04%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Eusb%201-1.2%3A%20%E6%96%B0%E5%9E%8B%E4%BD%8E%E9%80%9FUSB%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B73%E4%BD%BF%E7%94%A8%20ci_hdrc%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%3A%20DELL%20DELL%20USB%E6%BF%80%E5%85%89%E9%BC%A0%E6%A0%87%E4%BD%9C%E4%B8%BA%2Fdevices%2Fsoc0%2Fsoc%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.2%2F1-1.2%3A1.0%2F0003%3A046D%3AC063.0001%2Finput%2Finput5%3CBR%20%2F%3Ehid-generic%200003%3A046D%3AC063.0001%3A%20%E8%BE%93%E5%85%A5%EF%BC%9AUSB%20HID%20v1.10%E9%BC%A0%E6%A0%87%5BDELL%20DELL%20USB%E6%BF%80%E5%85%89%E9%BC%A0%E6%A0%87%5D%E4%BD%8D%E4%BA%8Eusb-ci_hdrc.0-1.2%2Finput0%3CBR%20%2F%3Eusb%201-1.3%EF%BC%9A%E6%96%B0%E5%9E%8B%E4%BD%8E%E9%80%9FUSB%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B74%E4%BD%BF%E7%94%A8ci_hdrc%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9ADell%20Dell%20QuietKey%E9%94%AE%E7%9B%98%EF%BC%8C%E8%AE%BE%E5%A4%87%E8%B7%AF%E5%BE%84%E4%B8%BA%2Fdevices%2Fsoc0%2Fsoc%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.3%2F1-1.3%3A1.0%2F0003%3A413C%3A2106.0002%2Finput%2Finput6%3CBR%20%2F%3Ehid-generic%200003%3A413C%3A2106.0002%EF%BC%9A%E8%BE%93%E5%85%A5%EF%BC%9AUSB%20HID%20v1.10%E9%94%AE%E7%9B%98%5BDell%20QuietKey%E9%94%AE%E7%9B%98%5D%E4%BD%8D%E4%BA%8Eusb-ci_hdrc.0-1.3%2Finput0%3CBR%20%2F%3Ekjournald%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%945%E7%A7%92%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E5%B7%B2%E6%8C%82%E8%BD%BD%E6%9C%89%E5%BA%8F%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3EVFS%3A%20%E5%B7%B2%E5%9C%A8%E8%AE%BE%E5%A4%87179%3A2%E4%B8%8A%E6%8C%82%E8%BD%BDroot(ext3%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F)%E3%80%82%3CBR%20%2F%3Edevtmpfs%EF%BC%9A%E5%B7%B2%E6%8C%82%E8%BD%BD%3CBR%20%2F%3E%E9%87%8A%E6%94%BE%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%EF%BC%9A432K(80af6000%20-%2080b62000)%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%9C%A8%2Fsys%2Ffs%2Fselinux%E4%B8%8A%E6%8C%82%E8%BD%BDselinuxfs%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E9%9A%8F%E6%9C%BA%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96urandom%E8%AF%BB%E5%8F%96%EF%BC%8C34%E4%BD%8D%E7%86%B5%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B(175)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B%E5%B7%B2%E7%BB%93%E6%9D%9F%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%87%8D%E5%90%AF%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B(185)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B%E5%B7%B2%E7%BB%93%E6%9D%9F%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%87%8D%E5%90%AF%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B(189)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B%E5%B7%B2%E7%BB%93%E6%9D%9F%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%87%8D%E5%90%AF%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aureadahead%E4%B8%BB%E8%BF%9B%E7%A8%8B(178)%E4%BB%A5%E7%8A%B6%E6%80%815%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Amounted-proc%E4%B8%BB%E8%BF%9B%E7%A8%8B(204)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3EDBG%E4%BC%A0%E6%84%9F%E5%99%A8%E6%95%B0%E6%8D%AE%E4%BD%8D%E4%BA%8E7f010188%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%8F%91%E9%80%81%E4%BA%8B%E4%BB%B6%E8%A1%A8%E6%98%8Eplymouth%E5%B7%B2%E5%90%AF%E5%8A%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7sysvinit%E8%A1%A8%E7%A4%BArootfs%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%A1%AB%E5%85%85%2Fdev%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%A1%AB%E5%85%85%2Fdev%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%B8%85%E7%90%86%2Ftmp%E7%9B%AE%E5%BD%95%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%A1%AB%E5%85%85%E5%B9%B6%E9%93%BE%E6%8E%A5%E5%88%B0%2Frun%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%B8%85%E7%90%86%2Ftmp%E7%9B%AE%E5%BD%95%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%A1%AB%E5%85%85%E5%B9%B6%E9%93%BE%E6%8E%A5%E5%88%B0%2Frun%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E8%B7%9F%E8%B8%AAupstart%E6%98%AF%E5%90%A6%E5%9C%A8%E5%AE%B9%E5%99%A8%E4%B8%AD%E8%BF%90%E8%A1%8C%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%96%E5%AE%8C%E6%88%90resolvconf%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E9%94%AE%E6%98%A0%E5%B0%84%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7sysvinit%E8%A1%A8%E7%A4%BA%E8%99%9A%E6%8B%9F%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%A1%A5%E6%8E%A5udev%E4%BA%8B%E4%BB%B6%E5%88%B0upstart%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E9%94%AE%E6%98%A0%E5%B0%84%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9%E5%92%8C%E5%86%85%E6%A0%B8%E4%BA%8B%E4%BB%B6%E7%AE%A1%E7%90%86%E5%99%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7sysvinit%E8%A1%A8%E7%A4%BA%E6%9C%AC%E5%9C%B0%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7%20sysvinit%20%E8%A1%A8%E7%A4%BA%E8%BF%9C%E7%A8%8B%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%9D%A5%E8%87%AA%2Fetc%2Fmodules%E7%9A%84%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%86%B7%E6%8F%92%E6%8B%94%E8%AE%BE%E5%A4%87%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E5%88%9D%E5%A7%8B%E8%AE%BE%E5%A4%87%E5%88%9B%E5%BB%BA%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E4%BB%8E%2Fetc%2Fmodules%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%B0%86%E6%97%A9%E6%9C%9F%E4%BD%9C%E4%B8%9A%E8%BE%93%E5%87%BA%E5%88%B7%E6%96%B0%E5%88%B0%E6%97%A5%E5%BF%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%B0%86%E6%97%A9%E6%9C%9F%E4%BD%9C%E4%B8%9A%E8%BE%93%E5%87%BA%E5%88%B7%E6%96%B0%E5%88%B0%E6%97%A5%E5%BF%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8D-Bus%E7%B3%BB%E7%BB%9F%E6%B6%88%E6%81%AF%E6%80%BB%E7%BA%BF%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%AD%97%E4%BD%93%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8SystemD%E7%99%BB%E5%BD%95%E7%AE%A1%E7%90%86%E6%9C%8D%E5%8A%A1%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%AD%97%E4%BD%93%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4bootsplash%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4bootsplash%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%8F%91%E9%80%81%E4%BA%8B%E4%BB%B6%E8%A1%A8%E6%98%8Eplymouth%E5%B7%B2%E5%90%AF%E5%8A%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E8%93%9D%E7%89%99%E5%AE%88%E6%8A%A4%E7%A8%8B%E5%BA%8F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%8F%91%E9%80%81%E4%BA%8B%E4%BB%B6%E8%A1%A8%E6%98%8Eplymouth%E5%B7%B2%E5%90%AF%E5%8A%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E6%97%A5%E5%BF%97%E5%AE%88%E6%8A%A4%E7%A8%8B%E5%BA%8F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8mDNS%2FDNS-SD%E5%AE%88%E6%8A%A4%E7%A8%8B%E5%BA%8F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8avahi-daemon%E6%97%B6%E9%87%8D%E8%A3%85cups%EF%BC%8C%E7%A1%AE%E4%BF%9D%E8%BF%9C%E7%A8%8B%E9%98%9F%E5%88%97%E5%B7%B2%E5%A1%AB%E5%85%85%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%87%8D%E8%A3%85cups%EF%BC%8C%E5%90%AF%E5%8A%A8avahi-daemon%E5%90%8E%E7%A1%AE%E4%BF%9D%E8%BF%9C%E7%A8%8B%E9%98%9F%E5%88%97%E5%B7%B2%E5%A1%AB%E5%85%85%20%5B%E5%A4%B1%E8%B4%A5%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%8C%82%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%95%85%E9%9A%9C%E4%BF%9D%E6%8A%A4%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%8C%82%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%95%85%E9%9A%9C%E4%BF%9D%E6%8A%A4%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8System%20V%E5%88%9D%E5%A7%8B%E5%8C%96%E5%85%BC%E5%AE%B9%E6%80%A7%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E8%AE%BE%E7%BD%AEX%E5%A5%97%E6%8E%A5%E5%AD%97%E7%9B%AE%E5%BD%95...%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2System%20V%E5%88%9D%E5%A7%8B%E5%8C%96%E5%85%BC%E5%AE%B9%E6%80%A7%20%5B%E7%A1%AE%E5%AE%9A%5D%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E7%99%BB%E5%BD%95%EF%BC%9A1970%E5%B9%B41%E6%9C%881%E6%97%A500%3A00%3A23%20UTC%E4%BA%8Etty1%3CBR%20%2F%3E%E6%AC%A2%E8%BF%8E%E4%BD%BF%E7%94%A8Linaro%2014.04%EF%BC%88GNU%2FLinux%204.1.15%EF%BC%89armv7l)%3C%2FP%3E%3CP%3E%3CSPAN%3E*%20%E6%96%87%E6%A1%A3%EF%BC%9A%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwiki.linaro.org%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwiki.linaro.org%2F%3C%2FA%3E%3CBR%20%2F%3Eroot%40linaro-alip%3A~%23%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%A1%AE%E5%AE%9E%E7%BC%96%E8%AF%91%E4%BA%864.1.15%E5%86%85%E6%A0%B8%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%EF%BC%88%E9%85%8D%E7%BD%AE%EF%BC%89%E5%90%88%E9%80%82%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E8%80%8C%E9%9D%9E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3E%E6%9D%BF%EF%BC%9AMX6Q-Sabreauto%20revA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%EF%BC%9A%3CSTRONG%3EMX6QP-Sabreauto%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%93%AA%E9%87%8C%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E5%AE%83%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%B0%86%E6%98%BE%E7%A4%BA%E9%87%8D%E5%AE%9A%E5%90%91%E5%88%B0HDMI%EF%BC%9F%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202016.03%EF%BC%882016%E5%B9%B411%E6%9C%883%E6%97%A5%20-%2011%3A28%3A37%20%2B0100%EF%BC%89%3C%2FP%3E%3CP%3ECPU%EF%BC%9AFreescale%20i.MX6QP%20rev1.0%20996%20MHz%EF%BC%88%E8%BF%90%E8%A1%8C%E9%A2%91%E7%8E%87%E4%B8%BA%20792%20MHz%EF%BC%89%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B1%BD%E8%BD%A6%E6%B8%A9%E5%BA%A6%E7%AD%89%E7%BA%A7%EF%BC%88-40%C2%B0C%20%E8%87%B3%20125%C2%B0C%EF%BC%89%E5%9C%A8%2028%C2%B0C%3CBR%20%2F%3E%E5%A4%8D%E4%BD%8D%E5%8E%9F%E5%9B%A0%EF%BC%9APOR%3CBR%20%2F%3E%E6%9D%BF%E5%8D%A1%EF%BC%9AMX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%EF%BC%9A%E5%B0%B1%E7%BB%AA%3CBR%20%2F%3EDRAM%EF%BC%9A2%20GiB%3CBR%20%2F%3EPMIC%EF%BC%9APFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%EF%BC%9A0%20MiB%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%EF%BC%8CFSL_SDHC%EF%BC%9A1%3CBR%20%2F%3E***%20%E8%AD%A6%E5%91%8A%20-%20%E9%94%99%E8%AF%AF%E7%9A%84%20CRC%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E9%9D%A2%E6%9D%BF%EF%BC%9A%E9%BB%98%E8%AE%A4%E4%B8%BA%20Hannstar-XGA%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%EF%BC%9AHannstar-XGA%20(1024x768)%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%20%230%EF%BC%8COK%3CBR%20%2F%3Emmc1%20%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%EF%BC%9AFEC%20%5BPRIME%5D%3CBR%20%2F%3E%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%B0%86%E8%BE%93%E5%87%BA%E9%87%8D%E5%AE%9A%E5%90%91%E5%88%B0%20HDMI%20%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%BB%A5%E4%B8%8B%E7%8E%AF%E8%8A%82%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E5%81%9C%E6%AD%A2%E4%BF%9D%E5%AD%98%E5%86%85%E6%A0%B8%E6%97%A5%E5%BF%97%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EU-Boot%202015.04%20(2016%E5%B9%B411%E6%9C%882%E6%97%A5%20-%2023%3A46%3A14)%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94i.MX6QP%E4%BF%AE%E8%AE%A2%E7%89%881.0%EF%BC%8C792MHz%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B8%A9%E5%BA%A633%C2%B0C%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%8E%9F%E5%9B%A0%EF%BC%9APOR%3CBR%20%2F%3E%E6%9D%BF%EF%BC%9AMX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%EF%BC%9A%E5%B0%B1%E7%BB%AA%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A2GiB%3CBR%20%2F%3EPMIC%EF%BC%9APFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%EF%BC%9A0MiB%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%EF%BC%8CFSL_SDHC%EF%BC%9A1%3CBR%20%2F%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%E6%A0%A1%E9%AA%8C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E9%9D%A2%E6%9D%BF%EF%BC%9A%E9%BB%98%E8%AE%A4%E4%B8%BAHannstar-XGA%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%EF%BC%9AHannstar-XGA%20(1024x768)%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3ENet%3A%20FEC%20%5BPRIME%5D%3CBR%20%2F%3E%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96boot.scr%3CBR%20%2F%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E6%96%87%E4%BB%B6boot.scr%20**%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96zImage%3CBR%20%2F%3E6022776%E5%AD%97%E8%8A%82%E5%9C%A8309%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96(18.6%20MiB%2Fs)%3CBR%20%2F%3E%E4%BB%8Emmc%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96imx6qp-sabreauto.dtb%3CBR%20%2F%3E20%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%9646893%E5%AD%97%E8%8A%82(2.2%20MiB%2Fs)%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%40%200x12000000%20%5B%200x000000%20-%200x5be678%20%5D%3CBR%20%2F%3E%23%23%20%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91blob%E4%BD%8D%E4%BA%8E18000000%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E0x18000000%E7%9A%84fdt%20blob%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%E4%BD%8D%E4%BA%8E18000000%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%BB%93%E6%9D%9F%E4%BA%8E1800e72c%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%89%A9%E7%90%86CPU%200x0%E4%B8%8A%E5%90%AF%E5%8A%A8Linux%3CBR%20%2F%3ELinux%E7%89%88%E6%9C%AC3.14.52%20(r59400%40Latitude)%20(gcc%E7%89%88%E6%9C%AC4.8.5(Linaro%20GCC%204.8-2015.06))%20%233%20SMP%20PREEMPT%202016%E5%B9%B411%E6%9C%882%E6%97%A523%3A55%3A53%20CET%3CBR%20%2F%3ECPU%3A%20ARMv7%E5%A4%84%E7%90%86%E5%99%A8%5B412fc09a%5D%20%E4%BF%AE%E8%AE%A2%E7%89%8810%20(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%E9%9D%9E%E5%88%AB%E5%90%8D%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%EF%BC%8CVIPT%E5%88%AB%E5%90%8D%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94i.MX6%20Quad%20Plus%20SABRE%E6%B1%BD%E8%BD%A6%E5%BC%80%E5%8F%91%E6%9D%BF%3CBR%20%2F%3Ecma%3A%20CMA%3A%20%E5%B7%B2%E5%9C%A86a000000%E9%A2%84%E7%95%99320MiB%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9A%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E5%86%99%E5%85%A5%E5%88%86%E9%85%8D%3CBR%20%2F%3EPERCPU%3A%20%E5%B7%B2%E5%B5%8C%E5%85%A58%E9%A1%B5%2FCPU%20%40ee71d000%20s8320%20r8192%20d16256%20u32768%3CBR%20%2F%3E%E5%B7%B2%E6%9E%84%E5%BB%BA1%E4%B8%AA%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%8E%92%E5%88%97%E7%9A%84%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E5%90%AF%E7%94%A8%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A520720%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk2p2%20rootwait%20rw%3CBR%20%2F%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E7%9B%AE%E5%BD%95%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A262144%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A8%EF%BC%8C1048576%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EInode%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A1739%2C228K%2F2097152K%E5%8F%AF%E7%94%A8%EF%BC%887452K%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%EF%BC%8C460K%E5%8F%AF%E8%AF%BB%E5%86%99%E6%95%B0%E6%8D%AE%EF%BC%8C2596K%E5%8F%AA%E8%AF%BB%E6%95%B0%E6%8D%AE%EF%BC%8C392K%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C433K%20bss%EF%BC%8C357924K%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%8C270336K%E9%AB%98%E5%86%85%E5%AD%98%EF%BC%89%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3CBR%20%2F%3E%20%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000%20-%200xffff1000%20(4%20kB)%3CBR%20%2F%3E%20%E5%9B%BA%E5%AE%9A%E6%98%A0%E5%B0%84%EF%BC%9A0xfff00000%20-%200xfffe0000%20(896%20kB)%3CBR%20%2F%3E%20%E8%99%9A%E6%8B%9F%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%EF%BC%9A0xf0000000%20-%200xff000000%20(240%20MB)%3CBR%20%2F%3E%20%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xef800000%20(1%2C784%20MB)%3CBR%20%2F%3E%20%E6%8C%81%E4%B9%85%E5%86%85%E6%A0%B8%E6%98%A0%E5%B0%84%EF%BC%9A0x7fe00000%20-%200x80000000%20(2%20MB)%3CBR%20%2F%3E%20%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%20(14%20MB)%3CBR%20%2F%3E.text%3A%200x80008000%20-%200x809d82d4%20(10049%20kB)%3CBR%20%2F%3E%20.init%20%3A%200x809d9000%20-%200x80a3b080%20(%20393%20kB)%3CBR%20%2F%3E%20.data%20%3A%200x80a3c000%20-%200x80aaf340%20(%20461%20kB)%3CBR%20%2F%3E%20.bss%20%EF%BC%9A0x80aaf34c%EF%BC%8D0x80b1b99c%EF%BC%88434%20kB%EF%BC%89%3CBR%20%2F%3ESLUB%EF%BC%9A%E7%A1%AC%E4%BB%B6%E5%AF%B9%E9%BD%90%3D64%EF%BC%8C%E5%86%85%E5%AD%98%E5%9D%97%E9%98%B6%E6%95%B0%3D0%EF%BC%8D3%EF%BC%8C%E6%9C%80%E5%B0%8F%E5%AF%B9%E8%B1%A1%E6%95%B0%3D0%EF%BC%8CCPU%3D4%EF%BC%8C%E8%8A%82%E7%82%B9%3D1%3CBR%20%2F%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E5%BC%8F%E5%88%86%E5%B1%82RCU%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3EL310%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3El2x0%3A%2016%E8%B7%AF%EF%BC%8CCACHE_ID%200x410000c8%EF%BC%8CAUX_CTRL%200x32070000%EF%BC%8C%E7%BC%93%E5%AD%98%E5%A4%A7%E5%B0%8F%EF%BC%9A1024%20kB%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%9F%BA%E4%BA%8E%E5%AE%9A%E6%97%B6%E5%99%A8%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3Esched_clock%3A%2032%E4%BD%8D%EF%BC%8C%E9%A2%91%E7%8E%873000kHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87333ns%EF%BC%8C%E6%AF%8F1431655765682ns%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%8780x30%3CBR%20%2F%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%88%E5%B7%B2%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E6%A0%B9%E6%8D%AE%E5%AE%9A%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E5%80%BC%E2%80%A66.00%20BogoMIPS%20(lpj%3D30000)%3CBR%20%2F%3Epid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%EF%BC%9A32768%EF%BC%8C%E6%9C%80%E5%B0%8F%EF%BC%9A301%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E9%80%9A%E8%BF%87%3CBR%20%2F%3ECPU0%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%200%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000000%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E8%BA%AB%E4%BB%BD%E6%98%A0%E5%B0%84%E8%A1%A8%EF%BC%9A0x10718008%20-%200x10718060%3CBR%20%2F%3ECPU1%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%AC%A1%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU1%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%201%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000001%3CBR%20%2F%3ECPU2%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%AC%A1%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU2%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%202%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000002%3CBR%20%2F%3ECPU3%EF%BC%9A%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%AC%A1%E7%BA%A7%E5%A4%84%E7%90%86%E5%99%A8%3CBR%20%2F%3ECPU3%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8CCPU%203%EF%BC%8C%E6%8F%92%E6%A7%BD0%EF%BC%8Cmpidr%2080000003%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E5%8A%A84%E4%B8%AACPU%3CBR%20%2F%3ESMP%EF%BC%9A%E6%80%BB%E5%85%B1%E6%BF%80%E6%B4%BB4%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%8824.00%20BogoMIPS%EF%BC%89%E3%80%82%3CBR%20%2F%3ECPU%EF%BC%9A%E6%89%80%E6%9C%89CPU%E5%9D%87%E4%BB%A5SVC%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3Edevtmpfs%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EVFP%E6%94%AF%E6%8C%81%E7%89%88%E6%9C%AC0.3%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E4%BB%B6%2030%20%E5%8F%98%E4%BD%93%209%20%E4%BF%AE%E8%AE%A2%E7%89%88%204%3CBR%20%2F%3Epinctrl%20core%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E5%AD%90%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%EF%BC%9A%E6%97%A0%E5%8F%82%E6%95%B0%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F16%3CBR%20%2F%3EDMA%EF%BC%9A%E5%B7%B2%E4%B8%BA%E5%8E%9F%E5%AD%90%E4%B8%80%E8%87%B4%E6%80%A7%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D256KiB%E6%B1%A0%3CBR%20%2F%3Ecpuidle%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%98%B6%E6%A2%AF%E5%9E%8B%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%8F%9C%E5%8D%95%E5%9E%8B%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3ECPU%E5%B7%B2%E8%AF%86%E5%88%AB%E4%B8%BAi.MX6QP%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC1.0%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8WDOG1%E4%BD%9C%E4%B8%BA%E9%87%8D%E7%BD%AE%E6%BA%90%3CBR%20%2F%3Esyscon%2020c8000.anatop%EF%BC%9Aregmap%20%5Bmem%200x020c8000-0x020c8fff%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Evdd1p1%EF%BC%9A800%20%26lt%3B--%26gt%3B%201375%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1100%20mV%3CBR%20%2F%3Evdd3p0%EF%BC%9A2625%20%26lt%3B--%26gt%3B%203400%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA3000%20mV%3CBR%20%2F%3Evdd2p5%EF%BC%9A2000%20%26lt%3B--%26gt%3B%202750%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA2400%20mV%3CBR%20%2F%3Evddarm%EF%BC%9A725%20%26lt%3B--%26gt%3B%201450%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1150%20mV%3CBR%20%2F%3Evddpu%EF%BC%9A725%20%26lt%3B--%26gt%3B%201450%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1150%20mV%3CBR%20%2F%3Evddsoc%EF%BC%9A725%20%26lt%3B--%26gt%3B%201450%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1175%20mV%3CBR%20%2F%3Esyscon%2020e0000.iomuxc-gpr%EF%BC%9Aregmap%20%5B%E5%86%85%E5%AD%980x020e0000-0x020e0037%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Esyscon%2021bc000.ocotp-ctrl%EF%BC%9Aregmap%20%5B%E5%86%85%E5%AD%980x021bc000-0x021bffff%5D%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B05%E4%B8%AA%E6%96%AD%E7%82%B9%EF%BC%88%2B1%E4%B8%AA%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%89%E5%92%8C1%E4%B8%AA%E8%A7%82%E5%AF%9F%E7%82%B9%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E6%9C%80%E5%A4%A7%E8%A7%82%E5%AF%9F%E7%82%B9%E5%A4%A7%E5%B0%8F%E4%B8%BA4%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20IMX%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%3CBR%20%2F%3Ebio%3A%20%E5%9C%A80%E5%A4%84%E5%88%9B%E5%BB%BAslab%20%3CBIO-0%3E%3CBR%20%2F%3Emxs-dma%20110000.dma-apbh%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecs42888_supply%EF%BC%9A3300%20mV%3CBR%20%2F%3E3P3V%EF%BC%9A3300%20mV%3CBR%20%2F%3Evio1%EF%BC%9A3300%20mV%3CBR%20%2F%3Evio2%EF%BC%9A3300%20mV%3CBR%20%2F%3Evd%EF%BC%9A3300%20mV%3CBR%20%2F%3Eva%EF%BC%9A5000%20mV%3CBR%20%2F%3Eplatform%20usb_h1_vbus.30%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0%20usb_otg_vbus.31%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Freg-fixed-voltage%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3EP3V3_SDa_SWITCHED%EF%BC%9A3300%20mV%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3ESCSI%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbfs%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb%3CBR%20%2F%3Eusbphy_nop1.12%20%E7%94%B5%E6%BA%90vcc%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eusbphy_nop2.13%20%E7%94%B5%E6%BA%90vcc%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Ei2c%20i2c-1%EF%BC%9AIMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ei2c%20i2c-2%EF%BC%9AIMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ELinux%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%E6%8E%A5%E5%8F%A3%EF%BC%9Av2.00%3CBR%20%2F%3Epps_core%EF%BC%9ALinuxPPS%20API%E7%89%88%E6%9C%AC1%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%3CSPAN%3Epps_core%EF%BC%9A%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%E6%97%B6%E9%92%9F%E6%94%AF%E6%8C%81%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eimx-ipuv3%202400000.ipu%EF%BC%9AIPU%20DMFC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%EF%BC%8C5B(4%2C5)%EF%BC%8C5F(6%2C7)%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%EF%BC%9AIPU%20DMFC%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%9A1(0~1)%EF%BC%8C5B(4%2C5)%EF%BC%8C5F(6%2C7)%3CBR%20%2F%3Eimx-prg%2021cc000.prg%3A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-prg%2021cd000.prg%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021c8000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021c9000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021ca000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eimx-pre%2021cb000.pre%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3EMIPI%20CSI2%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E9%AB%98%E7%BA%A7Linux%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC2.18%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F31%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecfg80211%EF%BC%9A%E8%B0%83%E7%94%A8CRDA%E6%9B%B4%E6%96%B0%E5%85%A8%E7%90%83%E7%9B%91%E7%AE%A1%E5%9F%9F%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90mxc_timer1%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F2%3CBR%20%2F%3ETCP%E5%B7%B2%E5%BB%BA%E7%AB%8B%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A5%EF%BC%8C131072%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B16384%EF%BC%8C%E7%BB%91%E5%AE%9A16384%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9Areno%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EUDP-Lite%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F1%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BAUNIX%E7%9A%84%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Cudp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%20NFSv4.1%E5%90%8E%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%80%A7%E8%83%BD%E7%9B%91%E6%8E%A7%EF%BC%9A%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E4%BD%BF%E7%94%A8ARMv7%20Cortex-A9%20PMU%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C7%E4%B8%AA%E8%AE%A1%E6%95%B0%E5%99%A8%E5%8F%AF%E7%94%A8%3CBR%20%2F%3Eimx%20rpmsg%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3Eimx_busfreq%20busfreq.16%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81DDR%E4%B8%AD%E7%AD%89%E9%80%9F%E7%8E%87%E3%80%82%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Efutex%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%BC%B9%E6%80%A7%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A64%E9%A1%B5%3CBR%20%2F%3EVFS%EF%BC%9A%E7%A3%81%E7%9B%98%E9%85%8D%E9%A2%9Ddquot_6.5.2%3CBR%20%2F%3EDquot-cache%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%200%EF%BC%8C4096%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENFS%EF%BC%9A%E6%B3%A8%E5%86%8Cid_resolver%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_legacy%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ejffs2%EF%BC%9A%E7%89%88%E6%9C%AC2.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3E%E7%86%94%E4%B8%9D%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88API%E7%89%88%E6%9C%AC7.22%EF%BC%89%3CBR%20%2F%3Emsgmni%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA3508%3CBR%20%2F%3E%E5%B7%B2%E6%B3%A8%E5%86%8Cio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fnoop%3CBR%20%2F%3E%E5%B7%B2%E6%B3%A8%E5%86%8Cio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fdeadline%3CBR%20%2F%3E%E5%B7%B2%E6%B3%A8%E5%86%8Cio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fcfq%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3Ebacklight.17%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Emxc_sdc_fb%20fb.23%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%EF%BC%9AIPU%20DMFC%20DP%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%9A1(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E5%BD%A9%E8%89%B2%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AE%BE%E5%A4%87128x48%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%E5%B7%B2%E6%A3%80%E6%B5%8B%E5%88%B0HDMI%E6%8E%A7%E5%88%B6%E5%99%A8%200x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%E5%90%8D%E7%A7%B0%20-%202.073M9%3CBR%20%2F%3Emxc_sdc_fb%20fb.24%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fhdmi%3CBR%20%2F%3Emxc_sdc_fb%20fb.25%3A%20%E6%9C%AA%E6%89%BE%E5%88%B0mxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%81%3CBR%20%2F%3Emxc_sdc_fb%20fb.26%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8Cmxc%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fldb%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%20%E6%9C%AA%E5%88%86%E9%85%8Diram%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E5%86%85%E5%AD%98%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E6%98%A0%E5%B0%84%E4%BB%BB%E4%BD%95%E4%BA%8B%E4%BB%B6%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B63.2%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%EF%BC%9A%E5%86%8D%E6%AC%A1%E8%AF%BB%E5%8F%96EDID%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9A%E5%85%A8%E5%B1%82%EF%BC%9A2%EF%BC%8C%E9%87%91%E5%B1%9E%E5%B1%82%EF%BC%9A1%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9AFAB%EF%BC%9A0%EF%BC%8CFIN%EF%BC%9A0%3CBR%20%2F%3Epfuze100-%E7%A8%B3%E5%8E%8B%E5%99%A8%201-0008%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0pfuze100%E3%80%82%3CBR%20%2F%3ESW1AB%3A%20300%26lt%3B--%26gt%3B%201875%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1375%20mV%3CBR%20%2F%3ESW1C%3A%20300%26lt%3B--%26gt%3B%201875%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1375%20mV%3CBR%20%2F%3ESW2%3A%20800%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1375%20mV%3CBR%20%2F%3ESW3A%3A%20400%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1350%20mV%3CBR%20%2F%3ESW3B%3A%20400%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1350%20mV%3CBR%20%2F%3ESW4%3A%20800%26lt%3B--%26gt%3B%201975%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1825%20mV%3CBR%20%2F%3ESWBST%3A%205000%26lt%3B--%26gt%3B%205150%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA5000%20mV%3CBR%20%2F%3EVSNVS%3A%201000%26lt%3B--%26gt%3B%203000%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA3000%20mV%3CBR%20%2F%3EVREFDDR%3A%20750%20mV%3CBR%20%2F%3EVGEN1%3A%20800%26lt%3B--%26gt%3B%201550%20mV%20%E5%9C%A8%201200%20mV%3CBR%20%2F%3EVGEN2%3A%20800%26lt%3B--%26gt%3B%201550%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1500%20mV%3CBR%20%2F%3EVGEN3%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA1800%20mV%3CBR%20%2F%3EVGEN4%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA3000%20mV%3CBR%20%2F%3EVGEN5%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA2500%20mV%3CBR%20%2F%3EVGEN6%3A%201800%26lt%3B--%26gt%3B%203300%20mV%20%E5%BD%93%E5%89%8D%E4%B8%BA2800%20mV%3CBR%20%2F%3ESerial%3A%20IMX%20driver%3CBR%20%2F%3E21ec000.serial%3Attymxc2%E4%BD%8D%E4%BA%8EMMIO%200x21ec000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2060%EF%BC%8C%E5%9F%BA%E7%A1%80%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%205%2C000%2C000%EF%BC%89%E6%98%AFIMX%3CBR%20%2F%3E21f0000.serial%EF%BC%9Attymxc3%E4%BD%8D%E4%BA%8EMMIO%200x21f0000%EF%BC%88%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2061%EF%BC%8C%E4%B8%AD%E6%96%AD%E5%8F%B7%20%3D%2060%EF%BC%8C%E5%9F%BA%E7%A1%80%E6%B3%A2%E7%89%B9%E7%8E%87%20%3D%205000000%EF%BC%89%E6%98%AFIMX%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%EF%BC%9A%E5%88%9B%E5%BB%BA%E9%BB%98%E8%AE%A4%E6%A8%A1%E5%BC%8F%E5%88%97%E8%A1%A8%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc3%5D%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%E4%B8%B2%E8%A1%8C%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94lpuart%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eimx%20sema4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%9620060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E5%B7%B2%E5%9C%A8%E6%AC%A1%E8%A6%81%E7%89%88%E6%9C%AC0%E4%B8%8A%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ebrd%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%B9%B3%E5%8F%B0%E6%95%B0%E6%8D%AE%E3%80%82%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E6%9C%AA%E6%8C%87%E5%AE%9AIRQ%E7%BC%96%E5%8F%B7%EF%BC%8C%E5%B0%86%E4%BD%BF%E7%94%A8%E8%BD%AE%E8%AF%A2%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E5%8F%91%E9%80%81%E5%91%BD%E4%BB%A40x11%E6%97%B6%E5%87%BA%E9%94%99%3CBR%20%2F%3Esi476x-core%201-0063%EF%BC%9A%E8%AE%BE%E5%A4%87%E7%94%B5%E6%BA%90%E7%8A%B6%E6%80%81%E4%B8%8D%E4%B8%80%E8%87%B4%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-level-mV%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800000024%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-boost-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800000480%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Ctransmit-atten-16ths%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A800002000%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9Afsl%EF%BC%8Creceive-eq-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%EF%BC%8C%E4%BD%BF%E7%94%A8%2005000000%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9ASSS%E6%A0%87%E5%BF%97%E5%B7%B2%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B9%B6%E8%A1%8C%E6%80%BB%E7%BA%BF%E6%89%AB%E6%8F%8F%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9AAHCI%200001.0300%2032%E4%B8%AA%E6%8F%92%E6%A7%BD%201%E4%B8%AA%E7%AB%AF%E5%8F%A3%203%20Gbps%200x1%E5%AE%9E%E7%8E%B0%E5%B9%B3%E5%8F%B0%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9A%E6%A0%87%E5%BF%97%EF%BC%9Ancq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%3CBR%20%2F%3Escsi0%EF%BC%9Aahci_platform%3CBR%20%2F%3Eata1%EF%BC%9ASATA%20%E6%9C%80%E5%A4%A7%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02203fff%5D%20%E7%AB%AF%E5%8F%A30x100%20irq%2071%3CBR%20%2F%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E2094000.can%20%E7%94%B5%E6%BA%90xceiver%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eflexcan%202094000.can%EF%BC%9A%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C(reg_base%3Df0238000%2C%20irq%3D143)%3CBR%20%2F%3E2188000.ethernet%20%E7%94%B5%E6%BA%90phy%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Epps%20pps0%3A%20%E6%96%B0%E7%9A%84PPS%E6%BA%90ptp0%3CBR%20%2F%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E5%B7%B2%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Efec%202188000.ethernet%20eth0%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8CPHC%E8%AE%BE%E5%A4%870%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%20%E2%80%9C%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%9D%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8(EHCI)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eehci-mxc%3A%20%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8AEHCI%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb-storage%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb_ehset_test%3CBR%20%2F%3E2184800.usbmisc%20%E7%94%B5%E6%BA%90vbus-wakeup%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eimx_usb%202184000.usb%3A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B02184000.usb%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fimx_usb%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Eimx_usb%202184200.usb%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B3%A8%E5%86%8Cci_hdrc%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3D-517%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B02184200.usb%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fimx_usb%E8%AF%B7%E6%B1%82%E6%8E%A8%E8%BF%9F%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Emousedev%3A%20PS%2F2%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8E%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%EF%BC%89%3CBR%20%2F%3Eegalax_ts%201-0004%3A%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%3CBR%20%2F%3Eegalax_ts%3A%20%E6%8E%A2%E6%B5%8B1-0004%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-5%3CBR%20%2F%3E2-0044%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Aisl29023%E5%85%89%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput1%3CBR%20%2F%3Eisl29023%202-0044%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC1.0%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bisl29023%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bisl29023%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%3A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96snvs-rtc%E6%97%B6%E9%92%9F%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%EF%BC%9Artc%20core%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C20cc034.snvs-rtc-lp%E4%BD%9C%E4%B8%BARTC0%3CBR%20%2F%3Ei2c%20%2Fdev%20entries%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EIR%20NEC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5(x)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC6%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20JVC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20Sony%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5%20(streamzap)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20SANYO%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20MCE%E9%94%AE%E7%9B%98%2F%E9%BC%A0%E6%A0%87%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.35%EF%BC%9AV4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo16%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.35%EF%BC%9AV4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo17%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.35%EF%BC%9AV4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo18%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.35%EF%BC%9AV4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo19%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.35%3AV4L2%E8%AE%BE%E5%A4%87%E5%B7%B2%E6%B3%A8%E5%86%8C%E4%B8%BAvideo20%3CBR%20%2F%3E2-000e%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2-000e%20%E7%94%B5%E6%BA%90vddio%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emag3110%202-000e%EF%BC%9A%E6%A3%80%E6%9F%A5mag3110%E8%8A%AF%E7%89%87ID%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Amag3110%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput2%3CBR%20%2F%3Emag3110%202-000e%EF%BC%9Amag3110%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmag3110%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmag3110%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3E2-001c%20%E7%94%B5%E6%BA%90vdd%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3E2-001c%20%E7%94%B5%E6%BA%90vddio%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eata1%EF%BC%9ASATA%E9%93%BE%E8%B7%AF%E6%96%AD%E5%BC%80(SStatus%200%20SControl%20300)%3CBR%20%2F%3Eahci-imx%202200000.sata%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E7%A6%81%E7%94%A8%E9%93%BE%E6%8E%A5%E3%80%82%3CBR%20%2F%3Eahci-imx%202200000.sata%3A%20%E4%BC%A0%E9%80%92ahci_imx..hotplug%3D1%E4%BB%A5%E5%90%AF%E7%94%A8%E7%83%AD%E6%8F%92%E6%8B%94%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Amma845x%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput3%3CBR%20%2F%3Eimx2-wdt%2020bc000.wdog%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92(nowayout%3D0)%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20H4%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20BCSP%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbcm203x%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fath3k%3CBR%20%2F%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Esdhci%EF%BC%9ACopyright(c)%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%EF%BC%9ASDHCI%E5%B9%B3%E5%8F%B0%E5%92%8COF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A9%E6%89%8B%3CBR%20%2F%3Emmc0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc0%EF%BC%9ASDHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E2190000.usdhc%20%5B2190000.usdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3Emmc2%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc2%EF%BC%9ASDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E2198000.usdhc%20%5B2198000.usdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9C%AA%E9%92%88%E5%AF%B9gpu.%E9%A2%84%E7%95%99%E8%BF%9E%E7%BB%AD%E5%86%85%E5%AD%98%EF%BC%81%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%B0%86%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%80%BC(134217728)%E4%BD%9C%E4%B8%BA%E9%A2%84%E7%95%99%E5%86%85%E5%AD%98%EF%BC%81%3C%2FP%3E%3CP%3EGalcore%E7%89%88%E6%9C%AC5.0.11.41671%3CBR%20%2F%3Emmc2%EF%BC%9A%E8%AE%BE%E7%BD%AE%E9%99%90%E6%B5%81%E6%97%B6%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%EF%BC%81%3CBR%20%2F%3Emmc2%EF%BC%9A%E6%96%B0%E5%9E%8B%E8%B6%85%E9%AB%98%E9%80%9FDDR50%20SDHC%20%E5%8D%A1%EF%BC%8C%E5%9C%B0%E5%9D%80%E4%B8%BAaaaa%3CBR%20%2F%3Emmcblk2%EF%BC%9Ammc2%EF%BC%9Aaaaa%20SU08G%207.40%20GiB%3CBR%20%2F%3Emmcblk2%EF%BC%9Ap1%20p2%3CBR%20%2F%3Emxc_vdoa%2021e4000.vdoa%EF%BC%9Ai.MX%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E9%A1%BA%E5%BA%8F%E9%80%82%E9%85%8D%E5%99%A8(VDOA)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8E%A2%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Emxc_vpu%202040000.vpu%EF%BC%9AVPU%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E5%B7%B2%E5%AE%9E%E4%BE%8B%E5%8C%96RNG4%20SH0%3CBR%20%2F%3Ecaam%202%2C100%2C000.caam%EF%BC%9A%E5%B7%B2%E5%AE%9E%E4%BE%8B%E5%8C%96RNG4%20SH1%3CBR%20%2F%3Ecaam%202%2C100%2C000.caam%EF%BC%9A%E8%AE%BE%E5%A4%87ID%20%3D%200x0a160100%20(Era%204)%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E4%BD%9C%E4%B8%9A%E7%8E%AF%20%3D%202%EF%BC%8Cqi%20%3D%200%3CBR%20%2F%3Ecaam%E7%AE%97%E6%B3%95%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%9C%A8%2Fproc%2Fcrypto%3CBR%20%2F%3Ecaam_jr%202101000.jr0%EF%BC%9A%E6%B3%A8%E5%86%8Crng-caam%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20blkkey_ex%3A%204%E4%B8%AA%E5%AF%86%E9%92%A5%E5%BA%93%E5%8D%95%E5%85%83%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064-bit%20clear%20key%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20e5%2067%201a%2032%2044%2012%203e%2071%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2035%20de%2020%202e%2043%20ce%20ec%2082%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E6%B8%85%E9%99%A4%E5%AF%86%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20d4%20b2%20d2%20cd%20de%2016%20e3%20b1%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2013%207c%201e%20af%204c%20a4%2040%2014%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%203d%204f%201d%20c9%2083%2084%20b5%208a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2050%208e%20de%2015%208e%2002%2000%208d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2067%20cd%2031%202d%20c6%209c%2013%2060%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2035%202d%20b7%20c2%2010%2076%2036%20e9%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20c4%204e%20d7%20b6%203e%2043%202f%2066%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2036%20df%20f3%20c9%201c%20b4%20d5%2028%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%204b%2048%20f0%20e6%2004%202e%2087%202c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2030%20f4%2010%208d%20c6%2091%20bd%2077%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20196%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E6%9C%AA%E5%86%99%E5%85%A5%E7%9A%84blob%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%2064%E4%BD%8D%E9%BB%91%E9%92%A5%E5%9C%A8blob%E4%B8%AD%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%209c%205f%20c6%20a9%2006%2033%20a5%20a5%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%20de%2027%2035%20d8%2015%20e5%20a1%204f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%20f7%20e1%20e8%20d0%2074%2023%20fd%20a8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2068%2081%2069%2046%2049%2013%2017%203e%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%209c%20fc%2015%20f5%2039%200a%20c6%203d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20d7%2000%20d0%2049%209a%20bb%203f%20c3%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%20e4%20ef%2005%20f9%20e5%2038%20da%20f8%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20128%E4%BD%8D%E9%BB%91%E9%92%A5%E5%9C%A8blob%E4%B8%AD%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2084%206e%2068%201d%2003%206b%20f8%203b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2009%20da%207c%2060%2070%20f4%20df%2065%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2095%20b5%2048%209d%2070%20e4%2047%20ca%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20e9%201f%205a%20e5%20f0%2043%2026%20a7%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%20a9%2090%2065%2092%2042%20ab%20fd%2046%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%20fb%203d%20e9%2013%205c%2024%20f1%20e9%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%208b%20ca%20b4%20c1%2010%2023%209d%2066%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2085%2068%2014%2030%2047%20ce%2043%20c0%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20192%E4%BD%8D%E9%BB%91%E9%92%A5%E5%9C%A8blob%E4%B8%AD%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%2057%20a6%2097%203f%2043%2096%20cf%2087%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%201f%2072%2089%20a6%20a0%20ad%200e%2048%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%207a%20ad%205c%20e4%206e%2037%2004%203d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%20e4%2095%20c9%2009%20aa%20c7%2012%20bb%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%2056%203c%20d7%20dc%2003%206b%202f%20e1%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%2016%20a8%20c2%20c3%2078%207a%2095%20ce%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%2005%2075%20fc%20d4%20a6%2084%20be%20d3%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%20c7%20df%2001%204f%20bc%2017%20fd%209d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2098%2025%2068%2026%20f6%209b%205c%2099%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20256%E4%BD%8D%E9%BB%91%E9%92%A5%E5%9C%A8blob%E4%B8%AD%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20fe%20a8%2022%20dd%2034%20d2%2000%203e%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%207e%20e8%2032%2093%2059%20a4%2096%2072%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2047%209a%20dd%203e%20fe%202a%2083%2027%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2092%2005%20b2%20c8%20cc%203e%20fe%2064%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0032%5D%209b%206b%202d%2047%20bc%2058%20ca%201c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0040%5D%208d%20c2%20b4%2094%2081%20b1%2080%20bf%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0048%5D%200e%2059%2038%2050%2047%2061%2009%20f4%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0056%5D%2022%20c2%20fa%2092%2056%2092%20df%202e%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0064%5D%2062%2084%2043%2056%2069%203a%2085%20f1%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0072%5D%20c4%20f4%20f7%2054%2046%204c%200b%20ca%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D64%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20c8%20bd%2051%2012%200f%208c%203c%209b%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2094%20ac%2086%2067%2055%2065%2075%2024%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D128%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20d4%20b2%20d2%20cd%20de%2016%20e3%20b1%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2013%207c%201e%20af%204c%20a4%2040%2014%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D192%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%203d%204f%201d%20c9%2083%2084%20b5%208a%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2050%208e%20de%2015%208e%2002%2000%208d%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%2047%206b%20e3%20e8%2062%206f%2089%208f%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%207c%20dc%206f%20eb%20cc%2073%2030%201c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%E5%B7%B2%E6%81%A2%E5%A4%8D256%E4%BD%8D%E9%BB%91%E9%92%A5%3A%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0000%5D%20c4%204e%20d7%20b6%203e%2043%202f%2066%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0008%5D%2036%20df%20f3%20c9%201c%20b4%20d5%2028%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0016%5D%204b%2048%20f0%20e6%2004%202e%2087%202c%3CBR%20%2F%3E%E5%B9%B3%E5%8F%B0caam_sm%3A%20%5B0024%5D%2030%20f4%2010%208d%20c6%2091%20bd%2077%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3A%20%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96snvs%E6%97%B6%E9%92%9F%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%EF%BC%9A%E8%BF%9D%E8%A7%84%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%BF%80%E6%B4%BB%20-%20%E9%9D%9E%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3CBR%20%2F%3Eusbhid%EF%BC%9AUSB%20HID%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Ecs42xx8%201-0048%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%884%3CBR%20%2F%3Efsl-asrc%202034000.asrc%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Esnd-soc-dummy%20snd-soc-dummy%3A%20ASoC%3A%20%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%E5%B9%B3%E5%8F%B0debugfs%E7%9B%AE%E5%BD%95%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.27%3Acs42888%26lt%3B-%26gt%3B%202024000.esai%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.27%EF%BC%9Asnd-soc-dummy-dai%26lt%3B-%26gt%3B%202034000.asrc%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.27%EF%BC%9Acs42888%26lt%3B-%26gt%3B%202024000.esai%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-spdif%20sound-spdif.20%EF%BC%9Asnd-soc-dummy-dai%26lt%3B-%26gt%3B%202004000.spdif%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-audio-hdmi%20sound-hdmi.21%EF%BC%9Ahdmi-hifi%26lt%3B-%26gt%3B%20hdmi_audio.3%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3Eimx-tuner-si476x%20sound-fm.33%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0FM%E5%B9%B3%E5%8F%B0%E8%AE%BE%E5%A4%87%3CBR%20%2F%3Eimx-tuner-si476x%3A%20sound-fm.33%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-22%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F26%3CBR%20%2F%3ETCP%3A%20cubic%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F10%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%E9%9A%A7%E9%81%93%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F17%3CBR%20%2F%3Ecan%3A%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%8C%BA%E5%9F%9F%E7%BD%91%E7%BB%9C%E6%A0%B8%E5%BF%83(%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20ABI%209)%3CBR%20%2F%3ENET%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F29%3CBR%20%2F%3Ecan%3A%20%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE(%E4%BF%AE%E8%AE%A2%E7%89%8820120528)%3CBR%20%2F%3Ecan%3A%20%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE(%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20t)%3CBR%20%2F%3Ecan%3A%20netlink%E7%BD%91%E5%85%B3(%E4%BF%AE%E8%AE%A2%E7%89%8820130117)%20max_hops%3D1%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%20TTY%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20RFCOMM%E7%89%88%E6%9C%AC1.11%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP(%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F)%20%E7%89%88%E6%9C%AC1.3%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP%E8%BF%87%E6%BB%A4%E5%99%A8%3A%20%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20BNEP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP(%E4%BA%BA%E6%9C%BA%E6%8E%A5%E5%8F%A3%E4%BB%BF%E7%9C%9F)%E7%89%88%E6%9C%AC1.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%E6%94%AF%E6%8C%81%E7%89%88%E6%9C%AC1.8%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bdns_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EVGEN2%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3ESWBST%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3ESW4%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3A%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3Eimx%20mcc%E6%B5%8B%E8%AF%95%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3Eusb_h1_vbus%EF%BC%9A5000%20mV%3CBR%20%2F%3Eusb_otg_vbus%EF%BC%9A5000%20mV%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%EF%BC%9AEHCI%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%EF%BC%9A%E6%96%B0%E7%9A%84USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA1%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%EF%BC%9AUSB%202.0%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0USB%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B01%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%E4%B8%8D%E6%94%AF%E6%8C%81gadget%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9AEHCI%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9A%E6%96%B0%E7%9A%84USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA2%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9AUSB%202.0%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A82-0%3A1.0%EF%BC%9A%E5%B7%B2%E6%89%BE%E5%88%B0USB%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A82-0%3A1.0%3A%20%E5%B7%B2%E6%A3%80%E6%B5%8B%E5%88%B01%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9Agpio-keys.18%E4%BD%9C%E4%B8%BA%2Fdevices%2Fsoc0%2Fgpio-keys.18%2Finput%2Finput4%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%3A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA1970-01-01%2000%3A00%3A02%20UTC%20(2)%3CBR%20%2F%3EALSA%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%3CBR%20%2F%3E%20%230%3A%20cs42888-audio%3CBR%20%2F%3E%20%231%3A%20imx-spdif%3CBR%20%2F%3E%20%232%3A%20imx-hdmi-soc%3CBR%20%2F%3Eusb%201-1%3A%20%E6%96%B0%E5%9E%8B%E9%AB%98%E9%80%9FUSB%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B72%EF%BC%8C%E4%BD%BF%E7%94%A8ci_hdrc%3CBR%20%2F%3Ehub%201-1%3A1.0%3A%20%E5%B7%B2%E6%89%BE%E5%88%B0USB%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-1%3A1.0%3A%20%E5%B7%B2%E6%A3%80%E6%B5%8B%E5%88%B04%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Ekjournald%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E3%80%82%E6%8F%90%E4%BA%A4%E9%97%B4%E9%9A%945%E7%A7%92%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E6%97%A5%E5%BF%97%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E6%81%A2%E5%A4%8D%E5%AE%8C%E6%88%90%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E5%B7%B2%E6%8C%82%E8%BD%BD%E6%9C%89%E5%BA%8F%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3EVFS%3A%20%E5%B7%B2%E5%9C%A8%E8%AE%BE%E5%A4%87179%3A2%E4%B8%8A%E6%8C%82%E8%BD%BDroot(ext3%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F)%E3%80%82%3CBR%20%2F%3Edevtmpfs%EF%BC%9A%E5%B7%B2%E6%8C%82%E8%BD%BD%3CBR%20%2F%3E%E9%87%8A%E6%94%BE%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%EF%BC%9A392K%20(809d9000%20-%2080a3b000)%3CBR%20%2F%3Eusb%201-1.2%EF%BC%9A%E6%96%B0%E5%9E%8B%E4%BD%8E%E9%80%9FUSB%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B73%EF%BC%8C%E4%BD%BF%E7%94%A8ci_hdrc%3CBR%20%2F%3E%E5%9C%A8%2Fsys%2Ffs%2Fselinux%E4%B8%8A%E6%8C%82%E8%BD%BDselinuxfs%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3Erandom%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96urandom%E8%AF%BB%E5%8F%96%EF%BC%8C%E5%85%B7%E6%9C%8968%E4%BD%8D%E5%8F%AF%E7%94%A8%E7%86%B5%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9ADELL%20DELL%20USB%E6%BF%80%E5%85%89%E9%BC%A0%E6%A0%87%E4%BD%9C%E4%B8%BA%2Fdevices%2Fsoc0%2Fsoc.0%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.2%2F1-1.2%3A1.0%2F0003%3A046D%3AC063.0001%2Finput%2Finput5%3CBR%20%2F%3Ehid-generic%200003%3A046D%3AC063.0001%3A%20%E8%BE%93%E5%85%A5%EF%BC%9AUSB%20HID%20v1.10%E9%BC%A0%E6%A0%87%5BDELL%20DELL%20USB%E6%BF%80%E5%85%89%E9%BC%A0%E6%A0%87%5D%E4%BD%8D%E4%BA%8Eusb-ci_hdrc.0-1.2%2Finput0%3CBR%20%2F%3EUSB%201-1.3%EF%BC%9A%E6%96%B0%E5%9E%8B%E4%BD%8E%E9%80%9FUSB%E8%AE%BE%E5%A4%87%E7%BC%96%E5%8F%B74%EF%BC%8C%E4%BD%BF%E7%94%A8ci_hdrc%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B(177)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B%E7%BB%93%E6%9D%9F%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B(187)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B%E7%BB%93%E6%9D%9F%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B(190)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aplymouth-upstart-bridge%E4%B8%BB%E8%BF%9B%E7%A8%8B%E7%BB%93%E6%9D%9F%EF%BC%8C%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%EF%BC%9ADell%20Dell%20QuietKey%E9%94%AE%E7%9B%98%E4%BD%9C%E4%B8%BA%2Fdevices%2Fsoc0%2Fsoc.0%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.3%2F1-1.3%3A1.0%2F0003%3A413C%3A2106.0002%2Finput%2Finput6%3CBR%20%2F%3Ehid-generic%200003%3A413C%3A2106.0002%EF%BC%9A%E8%BE%93%E5%85%A5%EF%BC%9AUSB%20HID%20v1.10%E9%94%AE%E7%9B%98%5BDell%20QuietKey%E9%94%AE%E7%9B%98%5D%E4%BD%8D%E4%BA%8Eusb-ci_hdrc.0-1.3%2Finput0%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Aureadahead%E4%B8%BB%E8%BF%9B%E7%A8%8B(180)%E4%BB%A5%E7%8A%B6%E6%80%815%E7%BB%88%E6%AD%A2%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9Amounted-proc%E4%B8%BB%E8%BF%9B%E7%A8%8B(204)%E4%BB%A5%E7%8A%B6%E6%80%811%E7%BB%88%E6%AD%A2%3CBR%20%2F%3EDBG%E4%BC%A0%E6%84%9F%E5%99%A8%E6%95%B0%E6%8D%AE%E4%BD%8D%E4%BA%8E7f010190%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%8F%91%E9%80%81%E4%BA%8B%E4%BB%B6%E8%A1%A8%E6%98%8Eplymouth%E5%B7%B2%E5%90%AF%E5%8A%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%90%91sysvinit%E5%8F%91%E9%80%81%E4%BF%A1%E5%8F%B7%EF%BC%8C%E6%8C%87%E7%A4%BA%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%B8%85%E7%90%86%2Ftmp%E7%9B%AE%E5%BD%95%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%A1%AB%E5%85%85%E5%B9%B6%E9%93%BE%E6%8E%A5%2Frun%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%A1%AB%E5%85%85%E5%B9%B6%E9%93%BE%E6%8E%A5%2Frun%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%B8%85%E7%90%86%2Ftmp%E7%9B%AE%E5%BD%95%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E8%B7%9F%E8%B8%AAupstart%E6%98%AF%E5%90%A6%E5%9C%A8%E5%AE%B9%E5%99%A8%E4%B8%AD%E8%BF%90%E8%A1%8C%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%96%E5%AE%8C%E6%88%90resolvconf%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%90%91sysvinit%E5%8F%91%E9%80%81%E4%BF%A1%E5%8F%B7%EF%BC%8C%E8%A1%A8%E6%98%8E%E8%99%9A%E6%8B%9F%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E4%BB%8E%E7%AB%99%EF%BC%81%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7sysvinit%E8%A1%A8%E6%98%8E%E8%99%9A%E6%8B%9F%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%B0%86udev%E4%BA%8B%E4%BB%B6%E6%A1%A5%E6%8E%A5%E5%88%B0upstart%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7sysvinit%E8%A1%A8%E6%98%8E%E6%9C%AC%E5%9C%B0%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%A1%E5%8F%B7sysvinit%E8%A1%A8%E6%98%8E%E8%BF%9C%E7%A8%8B%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%B7%B2%E6%8C%82%E8%BD%BD%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E6%8C%82%E8%BD%BD%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9%E5%92%8C%E5%86%85%E6%A0%B8%E4%BA%8B%E4%BB%B6%E7%AE%A1%E7%90%86%E5%99%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%B0%86%E6%97%A9%E6%9C%9F%E4%BB%BB%E5%8A%A1%E8%BE%93%E5%87%BA%E5%88%B7%E6%96%B0%E5%88%B0%E6%97%A5%E5%BF%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BB%8E%2Fetc%2Fmodules%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%86%B7%E6%8F%92%E6%8B%94%E8%AE%BE%E5%A4%87%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E5%88%9D%E5%A7%8B%E8%AE%BE%E5%A4%87%E5%88%9B%E5%BB%BA%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%B0%86%E6%97%A9%E6%9C%9F%E4%BB%BB%E5%8A%A1%E8%BE%93%E5%87%BA%E5%88%B7%E6%96%B0%E5%88%B0%E6%97%A5%E5%BF%97%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E4%BB%8E%2Fetc%2Fmodules%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%AD%97%E4%BD%93%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E6%97%A5%E5%BF%97%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%AD%97%E4%BD%93%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%8F%91%E9%80%81%E4%BA%8B%E4%BB%B6%E8%A1%A8%E6%98%8Eplymouth%E5%B7%B2%E5%90%AF%E5%8A%A8%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E5%8F%91%E9%80%81%E4%BA%8B%E4%BB%B6%E8%A1%A8%E6%98%8Eplymouth%E5%B7%B2%E5%90%AF%E5%8A%A8%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%8C%82%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%20%E7%A1%AE%E5%AE%9A%20%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%95%85%E9%9A%9C%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%8C%82%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%B0%86%E6%A1%A5%E6%8E%A5%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BA%8B%E4%BB%B6%E4%BC%A0%E9%80%92%E5%88%B0upstart%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%B0%86%E6%A1%A5%E6%8E%A5%E6%96%87%E4%BB%B6%E4%BA%8B%E4%BB%B6%E4%BC%A0%E9%80%92%E5%88%B0upstart%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E6%8C%82%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%95%85%E9%9A%9C%E5%AE%89%E5%85%A8%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8System%20V%E5%88%9D%E5%A7%8B%E5%8C%96%E5%85%BC%E5%AE%B9%E6%80%A7%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2System%20V%E5%88%9D%E5%A7%8B%E5%8C%96%E5%85%BC%E5%AE%B9%E6%80%A7%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8System%20V%E8%BF%90%E8%A1%8C%E7%BA%A7%E5%88%AB%E5%85%BC%E5%AE%B9%E6%80%A7%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E4%BF%9D%E5%AD%98%E5%86%85%E6%A0%B8%E6%B6%88%E6%81%AF%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E5%AE%89%E5%85%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%90%AF%E5%8A%A8%E5%B8%B8%E8%A7%84%E5%90%8E%E5%8F%B0%E7%A8%8B%E5%BA%8F%E5%A4%84%E7%90%86%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2System%20V%E8%BF%90%E8%A1%8C%E7%BA%A7%E5%88%AB%E5%85%BC%E5%AE%B9%E6%80%A7%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E6%8C%82%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%20*%20%E5%81%9C%E6%AD%A2%E4%BF%9D%E5%AD%98%E5%86%85%E6%A0%B8%E6%B6%88%E6%81%AF%20%5B%E7%A1%AE%E5%AE%9A%5D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Erik%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%9A%82%E6%97%A0i.mx%206%20QuadPlus%E5%BC%80%E5%8F%91%E6%9D%BF%E5%8F%AF%E4%BE%9B%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B7%B2%E5%AE%8C%E6%88%90%E6%B5%8B%E8%AF%95%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%96%87%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%92%88%E5%AF%B9i.MX%206QuadPlus%20SABRE-AI%E5%BC%80%E5%8F%91%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BE%83%E6%96%B0%E7%9A%84%20BSP%20rel_imx_4.1.15_1.1.0_ga%3CSPAN%3E%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%B5%E5%BE%AAim53qsb%E5%8F%82%E8%80%83%E6%9D%BF%E6%8C%87%E5%8D%97%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%E3%80%82%E4%BD%86%E5%9C%A8imx5_pm_init%E4%B8%AD%E5%87%BA%E7%8E%B0%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8imx_v7_defconfig%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B6%E4%BB%96%E4%BA%BA%E9%81%87%E5%88%B0%E6%AD%A4%E9%97%AE%E9%A2%98%E6%88%96%E5%B7%B2%E4%BF%AE%E5%A4%8D%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%96%E8%80%85%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E7%A7%BB%E9%99%A4pm%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202015.04%EF%BC%882016%E5%B9%B410%E6%9C%884%E6%97%A5%20-%2012%3A17%3A39%EF%BC%89%3C%2FP%3E%3CP%3E%E6%9D%BF%EF%BC%9AMX53%20LOCO%3CBR%20%2F%3EI2C%EF%BC%9A%E5%B0%B1%E7%BB%AA%3CBR%20%2F%3EDRAM%EF%BC%9A1%20GiB%3CBR%20%2F%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%EF%BC%8CFSL_SDHC%EF%BC%9A1%3CBR%20%2F%3E***%20%E8%AD%A6%E5%91%8A%20-%20%E9%94%99%E8%AF%AF%E7%9A%84%20CRC%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%E8%BE%93%E5%85%A5%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%EF%BC%9AFEC%3CBR%20%2F%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc0%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96boot.scr%3CBR%20%2F%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E6%96%87%E4%BB%B6boot.scr%20**%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96zImage%3CBR%20%2F%3E5997120%E5%AD%97%E8%8A%82%E5%9C%A8346%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%96%E5%AE%8C%E6%AF%95(16.5MiB%2Fs)%3CBR%20%2F%3E%E4%BB%8Emmc%E5%90%AF%E5%8A%A8...%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96imx53-qsrb.dtb%3CBR%20%2F%3E19%E6%AF%AB%E7%A7%92%E5%86%85%E8%AF%BB%E5%8F%9624491%E5%AD%97%E8%8A%82(1.2MiB%2Fs)%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%20%40%200x72000000%20%5B%200x000000%20-%200x5b8240%20%5D%3CBR%20%2F%3E%23%23%20%E6%89%81%E5%B9%B3%E5%8C%96%E8%AE%BE%E5%A4%87%E6%A0%91blob%E4%BD%8D%E4%BA%8E71000000%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8fdt%20blob%E5%9C%A80x71000000%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%20%E5%B0%86%E8%AE%BE%E5%A4%87%E6%A0%91%E5%8A%A0%E8%BD%BD%E5%88%B08f552000%EF%BC%8C%E5%B9%B6%E4%BA%8E8f55afaa%E7%BB%93%E6%9D%9F...%E7%A1%AE%E5%AE%9A%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%89%A9%E7%90%86CPU%200x0%E4%B8%8A%E5%90%AF%E5%8A%A8Linux%3CBR%20%2F%3ELinux%E7%89%88%E6%9C%AC3.14.38(lucid%40ubuntu)%EF%BC%88gcc%E7%89%88%E6%9C%AC%204.8.5%EF%BC%89(Linaro%20GCC%204.8-2015.06)%20)%20%231%20SMP%20PREEMPT%202016%E5%B9%B410%E6%9C%885%E6%97%A5%EF%BC%88%E6%98%9F%E6%9C%9F%E4%B8%89%EF%BC%8C06%3A56%3A31%EF%BC%8C%E5%A4%AA%E5%B9%B3%E6%B4%8B%E5%A4%8F%E4%BB%A4%E6%97%B6%E9%97%B4%EF%BC%89%3CBR%20%2F%3ECPU%EF%BC%9AARMv7%E5%A4%84%E7%90%86%E5%99%A8%20%5B412fc085%5D%20%E4%BF%AE%E8%AE%A2%E7%89%885(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3ECPU%EF%BC%9APIPT%20%2F%20VIPT%E9%9D%9E%E5%88%AB%E5%90%8D%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%EF%BC%8CVIPT%E5%88%AB%E5%90%8D%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94i.MX53%E5%BF%AB%E9%80%9F%E5%90%AF%E5%8A%A8%E6%9D%BF%3CBR%20%2F%3Ecma%3A%20CMA%3A%20%E5%9C%A8bc000000%E9%A2%84%E7%95%99320MiB%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E7%AD%96%E7%95%A5%EF%BC%9A%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E5%9B%9E%E5%86%99%3CBR%20%2F%3ECPU%EF%BC%9A%E6%89%80%E6%9C%89CPU%E5%9D%87%E4%BB%A5SVC%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3EPERCPU%EF%BC%9A%E5%B7%B2%E5%B5%8C%E5%85%A58%E9%A1%B5%2Fcpu%20%40cb33f000%20s8320%20r8192%20d16256%20u32768%3CBR%20%2F%3E%E5%B7%B2%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA1%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E5%B9%B6%E5%90%AF%E7%94%A8%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A259%2C072%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p2%20rw%20rootwait%3CBR%20%2F%3EPID%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A4%2C096%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E7%9B%AE%E5%BD%95%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A131%2C072%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A7%EF%BC%8C524288%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EInode%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A65%2C536%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A6%EF%BC%8C262144%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A699820K%2F1%2C048576K%E5%8F%AF%E7%94%A8%EF%BC%887423K%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%EF%BC%8C456K%E8%AF%BB%E5%86%99%E6%95%B0%E6%8D%AE%EF%BC%8C2584K%E5%8F%AA%E8%AF%BB%E6%95%B0%E6%8D%AE%EF%BC%8C384K%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C432K%20bss%EF%BC%8C348756K%E5%B7%B2%E9%A2%84%E7%95%99%EF%BC%8C0K%E9%AB%98%E5%86%85%E5%AD%98%EF%BC%89%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3CBR%20%2F%3E%20%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000%20-%200xffff1000%20(4kB)%3CBR%20%2F%3E%20%E5%9B%BA%E5%AE%9A%E6%98%A0%E5%B0%84%EF%BC%9A0xfff00000%20-%200xfffe0000%20(896kB)%3CBR%20%2F%3E%20%E8%99%9A%E6%8B%9F%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%EF%BC%9A0xe0800000%20-%200xff000000%20(488MB)%3CBR%20%2F%3E%20%E4%BD%8E%E5%86%85%E5%AD%98%EF%BC%9A0x80000000%20-%200xe0000000%20(1%2C536MB)%3CBR%20%2F%3E%20%E6%8C%81%E4%B9%85%E5%86%85%E6%A0%B8%E6%98%A0%E5%B0%84%EF%BC%9A0x7fe00000%20-%200x80000000%20(2MB)%3CBR%20%2F%3E%20%E6%A8%A1%E5%9D%97%EF%BC%9A0x7f000000%20-%200x7fe00000%20(14MB)%3CBR%20%2F%3E.text%3A%200x80008000%20-%200x809ce000%20(10008kB)%3CBR%20%2F%3E%20.init%20%3A%200x809ce000%20-%200x80a2e080%20(385kB)%3CBR%20%2F%3E%20.data%20%3A%200x80a30000%20-%200x80aa20c0%20(457kB)%3CBR%20%2F%3E%20.bss%20%3A%200x80aa20cc%20-%200x80b0e25c%20(433kB)%3CBR%20%2F%3ESLUB%EF%BC%9A%E7%A1%AC%E4%BB%B6%E5%AF%B9%E9%BD%90%3D64%EF%BC%8C%E5%86%85%E5%AD%98%E5%9D%97%E9%98%B6%E6%95%B0%3D0-3%EF%BC%8C%E6%9C%80%E5%B0%8F%E5%AF%B9%E8%B1%A1%E6%95%B0%3D0%EF%BC%8CCPU%3D1%EF%BC%8C%E8%8A%82%E7%82%B9%3D1%3CBR%20%2F%3E%E5%8F%AF%E6%8A%A2%E5%8D%A0%E5%BC%8F%E5%88%86%E5%B1%82RCU%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%20RCU%E5%B0%86CPU%E6%95%B0%E9%87%8F%E4%BB%8ENR_CPUS%3D4%E9%99%90%E5%88%B6%E4%B8%BAnr_cpu_ids%3D1%E3%80%82%3CBR%20%2F%3ERCU%EF%BC%9A%E8%B0%83%E6%95%B4rcu_fanout_leaf%3D16%E5%92%8Cnr_cpu_ids%3D1%E7%9A%84%E5%87%A0%E4%BD%95%E5%8F%82%E6%95%B0%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3ETrustZone%E4%B8%AD%E6%96%AD%E6%8E%A7%E5%88%B6%E5%99%A8(TZIC)%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3ECPU%E5%B7%B2%E8%AF%86%E5%88%AB%E4%B8%BAi.MX53%EF%BC%8C%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC2.1%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%9F%BA%E4%BA%8E%E5%AE%9A%E6%97%B6%E5%99%A8%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3Esched_clock%EF%BC%9A32%E4%BD%8D%EF%BC%8C33MHz%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%8730ns%EF%BC%8C%E6%AF%8F128849019873ns%E5%BE%AA%E7%8E%AF%E4%B8%80%E6%AC%A1%3CBR%20%2F%3Eclocksource_of_init%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%8C%B9%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%E6%BA%90%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%8780x30%3CBR%20%2F%3E%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%88%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E6%A0%B9%E6%8D%AE%E5%AE%9A%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E5%80%BC%E2%80%A666.66%20BogoMIPS%20(lpj%3D333333)%3CBR%20%2F%3Epid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%EF%BC%9A301%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A2048%20(%E9%A1%BA%E5%BA%8F%EF%BC%9A1%EF%BC%8C8192%E5%AD%97%E8%8A%82)%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A2048%20(%E9%A1%BA%E5%BA%8F%EF%BC%9A1%EF%BC%8C8192%E5%AD%97%E8%8A%82)%3CBR%20%2F%3ECPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9A%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3ECPU0%EF%BC%9A%E7%BA%BF%E7%A8%8B-1%EF%BC%8Ccpu0%EF%BC%8C%E6%8F%92%E6%A7%BD-1%EF%BC%8Cmpidr0%3CBR%20%2F%3E%E4%B8%BA0x70710420%20-%200x70710478%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E6%A0%87%E8%AF%86%E6%98%A0%E5%B0%84%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E5%8A%A81%E4%B8%AACPU%3CBR%20%2F%3ESMP%EF%BC%9A%E5%85%B1%E6%BF%80%E6%B4%BB1%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8(66.66%20BogoMIPS)%E3%80%82%3CBR%20%2F%3ECPU%EF%BC%9A%E6%89%80%E6%9C%89CPU%E5%9D%87%E4%BB%A5SVC%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3Edevtmpfs%EF%BC%9A%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EVFP%E6%94%AF%E6%8C%81v0.3%EF%BC%9A%E5%AE%9E%E6%96%BD%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%203%20%E9%83%A8%E4%BB%B6%2030%20%E5%8F%98%E4%BD%93%20c%20%E4%BF%AE%E8%AE%A2%E7%89%882%3CBR%20%2F%3E%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%EF%BC%9A%E6%97%A0%E5%8F%82%E6%95%B0%3CBR%20%2F%3ENET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F16%3CBR%20%2F%3EDMA%EF%BC%9A%E4%B8%BA%E5%8E%9F%E5%AD%90%E4%B8%80%E8%87%B4%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D256KiB%E6%B1%A0%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E9%98%B6%E6%A2%AF%E5%BD%A2%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3ECPU%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%E7%AE%A1%E7%90%86%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%8F%9C%E5%8D%95%E5%9E%8B%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8WDOG1%E4%BD%9C%E4%B8%BA%E9%87%8D%E7%BD%AE%E6%BA%90%3CBR%20%2F%3Esyscon%2053fa8000.iomuxc-gpr%EF%BC%9Aregmap%20%5Bmem%200x53fa8000-0x53fa800b%5D%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E8%B0%83%E8%AF%95%E6%9E%B6%E6%9E%840x4%E3%80%82%3CBR%20%2F%3Eimx53-pinctrl%2053fa8000.iomuxc%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96IMX%E5%BC%95%E8%84%9A%E6%8E%A7%E5%88%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Ebio%3A%20%E5%9C%A80%E5%88%9B%E5%BB%BAslab%3CBIO-0%3E%3CBR%20%2F%3E3P2V%3A%203200mV%3CBR%20%2F%3Eusb_vbus%3A%205000mV%3CBR%20%2F%3Ei2c%E6%A0%B8%E5%BF%83%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c%E6%A0%B8%E5%BF%83%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmax17135%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3ESCSI%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusb%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usbfs%3CBR%20%2F%3Eusb%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fhub%3CBR%20%2F%3Eusb%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb%3CBR%20%2F%3Eusbphy.1%E7%94%B5%E6%BA%90VCC%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eusbphy.2%E7%94%B5%E6%BA%90VCC%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3EI2C%20I2C-1%EF%BC%9AIMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EDA9052%EF%BC%9A0-0048%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-5%3CBR%20%2F%3EI2C%20I2C-0%EF%BC%9AIMX%20I2C%E9%80%82%E9%85%8D%E5%99%A8%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ELinux%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%E6%8E%A5%E5%8F%A3%EF%BC%9A%E7%89%88%E6%9C%AC2.00%3CBR%20%2F%3EPPS%E6%A0%B8%E5%BF%83%EF%BC%9ALinuxPPS%20API%E7%89%88%E6%9C%AC1%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%3CSPAN%3EPPS%E6%A0%B8%E5%BF%83%EF%BC%9A%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC5.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%E6%97%B6%E9%92%9F%E6%94%AF%E6%8C%81%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eimx-ipuv3%EF%BC%9A%E6%8E%A2%E6%B5%8B18000000.ipu%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-22%3CBR%20%2F%3EMIPI%20CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%E9%AB%98%E7%BA%A7Linux%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC2.18%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F31%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ASCO%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E5%B7%B2%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90mxc_timer1%3CBR%20%2F%3Ecfg80211%EF%BC%9A%E8%B0%83%E7%94%A8CRDA%E6%9B%B4%E6%96%B0%E5%85%A8%E7%90%83%E7%9B%91%E7%AE%A1%E5%9F%9F%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F2%3CBR%20%2F%3ETCP%E5%B7%B2%E5%BB%BA%E7%AB%8B%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A8192%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A8192%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B8192%EF%BC%8C%E7%BB%91%E5%AE%9A8192%EF%BC%89%3CBR%20%2F%3ETCP%EF%BC%9Areno%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3EUDP%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EUDP-Lite%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F1%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%90%8D%E4%B8%BAUNIX%E7%9A%84%E5%A5%97%E6%8E%A5%E5%AD%97%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Cudp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8Ctcp%20NFSv4.1%E5%90%8E%E9%80%9A%E9%81%93%E4%BC%A0%E8%BE%93%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3Eimx%20rpmsg%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Efutex%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A2%EF%BC%8C16384%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EVFS%EF%BC%9A%E7%A3%81%E7%9B%98%E9%85%8D%E9%A2%9Ddquot_6.5.2%3CBR%20%2F%3EDquot-cache%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%200%EF%BC%8C4096%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3ENFS%EF%BC%9A%E6%B3%A8%E5%86%8Cid_resolver%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8Bid_legacy%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Ejffs2%EF%BC%9A%E7%89%88%E6%9C%AC2.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3Efuse%20init%EF%BC%88API%E7%89%88%E6%9C%AC7.22%EF%BC%89%3CBR%20%2F%3Emsgmni%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%B8%BA2006%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fnoop%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fdeadline%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3Eio%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8Fcfq%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3EMIPI%20DSI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%EF%BC%9A%E6%9C%AA%E5%88%86%E9%85%8Diram%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8mem%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%EF%BC%9A%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E6%98%A0%E5%B0%84%E4%BB%BB%E4%BD%95%E4%BA%8B%E4%BB%B6%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%EF%BC%9A%E7%9B%B4%E6%8E%A5%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81-2%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%EF%BC%9A%E5%9B%9E%E9%80%80%E5%88%B0%E7%94%A8%E6%88%B7%E5%8A%A9%E6%89%8B%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E4%B8%B2%E5%8F%A3%EF%BC%9AIMX%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E53fbc000.serial%EF%BC%9Attymxc0%E5%9C%A8MMIO%200x53fbc000%EF%BC%88irq%20%3D%2047%EF%BC%8Cbase_baud%20%3D%204166666%EF%BC%89%E6%98%AF%E4%B8%80%E4%B8%AAIMX%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc0%5D%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%E4%B8%B2%E8%A1%8C%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94lpuart%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eimx%20sema4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B3%A8%E5%86%8C%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%9620060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E5%B7%B2%E5%9C%A8%E6%AC%A1%E8%A6%81%E7%89%88%E6%9C%AC0%E4%B8%8A%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ebrd%3A%20%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3Eloop%3A%20%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3ECAN%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E63fec000.ethernet%E7%94%B5%E6%BA%90phy%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E5%B7%B2%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3Eehci_hcd%3A%20USB2.0%20%E2%80%9C%E5%A2%9E%E5%BC%BA%E5%9E%8B%E2%80%9D%20%E4%B8%BB%E6%8E%A7%E5%88%B6%E5%99%A8(EHCI)%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eehci-mxc%3A%20%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%89%87%E4%B8%8AEHCI%E4%B8%BB%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb-storage%3CBR%20%2F%3Eusbcore%3A%20%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusb_ehset_test%3CBR%20%2F%3E53f80800.usbmisc%E7%94%B5%E6%BA%90vbus-wakeup%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%E4%B8%8D%E6%94%AF%E6%8C%81gadget%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9AEHCI%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9A%E6%96%B0%E7%9A%84USB%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA1%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9AUSB%202.0%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CEHCI%201.00%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-0%3A1.0%EF%BC%9AUSB%E9%9B%86%E7%BA%BF%E5%99%A8%E5%B7%B2%E6%89%BE%E5%88%B0%3CBR%20%2F%3E%E9%9B%86%E7%BA%BF%E5%99%A81-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B01%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3Emousedev%3A%20PS%2F2%E9%BC%A0%E6%A0%87%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%E6%89%80%E6%9C%89%E9%BC%A0%E6%A0%87%3CBR%20%2F%3E%E8%BE%93%E5%85%A5%3A%20mma8450%E4%BD%9C%E4%B8%BA%2Fdevices%2Fvirtual%2Finput%2Finput0%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bisl29023%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%3A%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bisl29023%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c%20%2Fdev%E6%9D%A1%E7%9B%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3EIR%20NEC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5(x)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC6%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20JVC%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%8C%96%E6%A7%BD%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20Sony%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20RC5(streamzap)%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20SANYO%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3EIR%20MCE%E9%94%AE%E7%9B%98%2F%E9%BC%A0%E6%A0%87%E5%8D%8F%E8%AE%AE%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Ecoda%2063ff4000.vpu%3A%E5%9B%BA%E4%BB%B6%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA-2%3CBR%20%2F%3Ecoda%2063ff4000.vpu%EF%BC%9A%E5%9B%9E%E9%80%80%E5%88%B0%E7%94%A8%E6%88%B7%E5%8A%A9%E6%89%8B%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmag3110%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%8C%82%E8%B5%B7%E6%96%B9%E6%B3%95%3CBR%20%2F%3Ei2c-core%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5Bmag3110%5D%E4%BD%BF%E7%94%A8%E4%BC%A0%E7%BB%9F%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%3CBR%20%2F%3Eimx2-wdt%2053f98000.wdog%EF%BC%9AIMX2%2B%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E8%B6%85%E6%97%B6%3D60%E7%A7%92(nowayout%3D0)%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20H4%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCI%20BCSP%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHCIATH3K%E5%8D%8F%E8%AE%AE%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbcm203x%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fbtusb%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fath3k%3CBR%20%2F%3Esdhci%EF%BC%9A%E5%AE%89%E5%85%A8%E6%95%B0%E5%AD%97%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3Esdhci%EF%BC%9ACopyright(c)%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%EF%BC%9ASDHCI%E5%B9%B3%E5%8F%B0%E5%92%8COF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A9%E6%89%8B%3CBR%20%2F%3Emmc0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc0%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc0%EF%BC%9ASDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BD%8D%E4%BA%8E50004000.esdhc%20%5B50004000.esdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3Emmc1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vqmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc1%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0vmmc%E7%A8%B3%E5%8E%8B%E5%99%A8%3CBR%20%2F%3Emmc0%3A%EF%BC%9A%E4%B8%BB%E6%9C%BA%E4%B8%8D%E6%94%AF%E6%8C%81%E8%AF%BB%E5%8F%96%E5%8F%AA%E8%AF%BB%E5%BC%80%E5%85%B3%E3%80%82%E5%81%87%E8%AE%BE%E5%8F%AF%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3Emmc1%EF%BC%9A50020000.esdhc%E4%B8%8A%E7%9A%84SDHCI%E6%8E%A7%E5%88%B6%E5%99%A8%5B50020000.esdhc%5D%E4%BD%BF%E7%94%A8ADMA%3CBR%20%2F%3Emmc0%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA0007%E7%9A%84%E6%96%B0%E5%9E%8B%E9%AB%98%E9%80%9FSDHC%E5%8D%A1%3CBR%20%2F%3E%E4%BD%9C%E4%B8%9A%E7%8E%AF%E8%AE%BE%E5%A4%87%E5%88%86%E9%85%8D%E8%BD%AC%E6%8D%A2%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Emmcblk0%3A%20mmc0%3A0007%20SD16G%2014.5GiB%3CBR%20%2F%3Eusbcore%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fusbhid%3CBR%20%2F%3Eusbhid%EF%BC%9AUSB%20HID%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%20mmcblk0%EF%BC%9Ap1%20p2%3CBR%20%2F%3Esgtl5000%201-000a%EF%BC%9Asgtl5000%E4%BF%AE%E8%AE%A2%E7%89%880x11%3CBR%20%2F%3Eimx-sgtl5000%20sound.8%3A%20phandle%E7%BC%BA%E5%A4%B1%E6%88%96%E6%97%A0%E6%95%88%3CBR%20%2F%3Eimx-sgtl5000%EF%BC%9A%E6%8E%A2%E6%B5%8Bsound.8%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA-22%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F26%3CBR%20%2F%3ETCP%EF%BC%9Acubic%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F10%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%E9%9A%A7%E9%81%93%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F17%3CBR%20%2F%3Ecan%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%99%A8%E5%8C%BA%E5%9F%9F%E7%BD%91%E7%BB%9C%E6%A0%B8%E5%BF%83%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20abi%209%EF%BC%89%3CBR%20%2F%3ENET%EF%BC%9A%E5%B7%B2%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E6%97%8F29%3CBR%20%2F%3Ecan%EF%BC%9A%E5%8E%9F%E5%A7%8B%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%8820120528%EF%BC%89%3CBR%20%2F%3Ecan%EF%BC%9A%E5%B9%BF%E6%92%AD%E7%AE%A1%E7%90%86%E5%99%A8%E5%8D%8F%E8%AE%AE%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%8820120528%20t%EF%BC%89%3CBR%20%2F%3Ecan%EF%BC%9Anetlink%E7%BD%91%E5%85%B3%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%8820130117%EF%BC%89max_hops%3D1%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%E7%89%88%E6%9C%AC1.11%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC1.3%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9ABNEP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E6%8E%A5%E5%8F%A3%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC1.2%3CBR%20%2F%3E%E8%93%9D%E7%89%99%3A%20HIDP%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%E6%94%AF%E6%8C%81v1.8%3CBR%20%2F%3E%E9%94%AE%E7%B1%BB%E5%9E%8Bdns_resolver%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80f51a000c%E7%9A%84%E5%86%85%E6%A0%B8%E5%88%86%E9%A1%B5%E8%AF%B7%E6%B1%82%3CBR%20%2F%3Epgd%20%3D%2080004000%3CBR%20%2F%3E%5Bf51a000c%5D%20*pgd%3D00000000%3CBR%20%2F%3E%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%EF%BC%9AOops%3A%205%20%5B%231%5D%20PREEMPT%20SMP%20ARM%3CBR%20%2F%3E%E5%B7%B2%E9%93%BE%E6%8E%A5%E6%A8%A1%E5%9D%97%EF%BC%9A%3CBR%20%2F%3ECPU%3A%200%20PID%3A%201%20Comm%3A%20swapper%2F0%20%E6%9C%AA%E6%B1%A1%E6%9F%933.14.38%20%231%3CBR%20%2F%3E%E4%BB%BB%E5%8A%A1%EF%BC%9Ac8068000%20ti%3A%20c806c000%20task.ti%3Ac806c000%3CBR%20%2F%3EPC%E4%BD%8D%E4%BA%8Emx5_cpu_lp_set%2B0x10%2F0xfc%3CBR%20%2F%3ELR%E4%BD%8D%E4%BA%8Eimx5_pm_init%2B0x64%2F0x80%3CBR%20%2F%3Epc%20%3A%20%5B%26lt%3B8001d804%26gt%3B%5D%20lr%20%3A%20%5B%26lt%3B809da58c%26gt%3B%5D%20psr%3A%2060000113%3CBR%20%2F%3E%E5%A0%86%E6%A0%88%E6%8C%87%E9%92%88%EF%BC%9Ac806dedc%20ip%20%3A%2000000072%20fp%20%3A%2000000000%3CBR%20%2F%3Er10%3Ac806c038%20r9%20%3A%2080a1ee7c%20r8%20%3A%20809d1190%3CBR%20%2F%3Er7%20%3A%2080aa2100%20r6%20%3A%2080aa2100%20r5%20%3A%2000000007%20r4%20%3Ac801b600%3CBR%20%2F%3Er3%20%3A%20f51a0000%20r2%20%3A%208001d8f0%20r1%20%3A%2000000002%20r0%20%3A%2000000002%3CBR%20%2F%3E%E6%A0%87%E5%BF%97%EF%BC%9AnZCv%20IRQs%20on%20FIQs%20on%20Mode%20SVC_32%20ISA%20ARM%20%E6%AE%B5%E5%86%85%E6%A0%B8%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%EF%BC%9A10c5387d%20%E8%A1%A8%EF%BC%9A70004019%20DAC%3A%2000000015%3CBR%20%2F%3E%E8%BF%9B%E7%A8%8B%E4%BA%A4%E6%8D%A2%E5%99%A8%2F0%EF%BC%88pid%3A%201%EF%BC%8C%E6%A0%88%E9%99%90%E5%88%B6%20%3D%200xc806c238%EF%BC%89%3CBR%20%2F%3E%E6%A0%88%EF%BC%9A%EF%BC%880xc806dedc%E5%88%B00xc806e000%EF%BC%89%3CBR%20%2F%3Edec0%3Ac801b600%3CBR%20%2F%3Edee0%3A%2000000007%20809da58c%2080a2b80c%20809d11b0%2000000000%20800088bc%20c800ccc0%20808c7d28%3CBR%20%2F%3Edf00%3Ac8096200%2080714144%2000000000%2000000000%2000000000%208012a57c%2000000000%2080a446b0%3CBR%20%2F%3Edf20%3A60000113%2000000001%20cbfffc2e%208073b938%200000010b%20800498e0%2080996644%2000000007%3CBR%20%2F%3Edf40%3Acbfffc36%2000000007%2080a446a0%2080a2b80c%2000000007%2080aa2100%2080aa2100%20809ce50c%3CBR%20%2F%3Edf60%3A80a1ee7c%200000010b%2080a1ee74%20809cec38%2000000007%2000000007%20809ce50c%208070fbd8%3CBR%20%2F%3Edf80%3A00000000%2000002100%2080706164%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3Edfa0%3A00000000%2080706170%2000000000%208000e278%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3Edfc0%3A00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3Edfe0%3A00000000%2000000000%2000000000%2000000000%2000000013%2000000000%2080000220%2008040010%3CBR%20%2F%3E%5B%26lt%3B8001d804%26gt%3B%5D%20(mx5_cpu_lp_set)%E6%9D%A5%E8%87%AA%5B%26lt%3B809da58c%26gt%3B%5D%20(imx5_pm_init%2B0x64%2F0x80)%3CBR%20%2F%3E%5B%26lt%3B809da58c%26gt%3B%5D%20(imx5_pm_init)%E6%9D%A5%E8%87%AA%5B%26lt%3B809d11b0%26gt%3B%5D%20(init_machine_late%2B0x20%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B809d11b0%26gt%3B%5D%20(init_machine_late)%E6%9D%A5%E8%87%AA%5B%26lt%3B800088bc%26gt%3B%5D%20(do_one_initcall%2B0xf8%2F0x144)%3CBR%20%2F%3E%5B%26lt%3B800088bc%26gt%3B%5D%20(do_one_initcall)%E6%9D%A5%E8%87%AA%5B%26lt%3B809cec38%26gt%3B%5D%20(kernel_init_freeable%2B0x13c%2F0x1dc)%3CBR%20%2F%3E%5B%26lt%3B809cec38%26gt%3B%5D%20(kernel_init_freeable)%E6%9D%A5%E8%87%AA%5B%26lt%3B80706170%26gt%3B%5D%20(kernel_init%2B0xc%2F0xe8)%3CBR%20%2F%3E%5B%26lt%3B80706170%26gt%3B%5D%20(kernel_init)%E6%9D%A5%E8%87%AA%5B%26lt%3B8000e278%26gt%3B%5D%20(ret_from_fork%2B0x14%2F0x3c)%3CBR%20%2F%3E%E4%BB%A3%E7%A0%81%EF%BC%9Ae3a03000%20e92d4030%20e1a01000%20e34f351a%20(e593c00c)%3CBR%20%2F%3E---%5B%20%E8%B7%9F%E8%B8%AA%E7%BB%93%E6%9D%9F65acb852349b9d5b%20%5D---%3CBR%20%2F%3E%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%20-%20%E6%97%A0%E6%B3%95%E5%90%8C%E6%AD%A5%EF%BC%9A%E5%B0%9D%E8%AF%95%E6%9D%80%E6%AD%BB%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%9B%E7%A8%8B%EF%BC%81%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%3D0x0000000b%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ET%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%88%91%E4%BB%ACUbuntu%E5%8F%91%E5%B8%83%E5%8D%9A%E5%AE%A2%E6%96%87%E7%AB%A0%E4%B8%AD%E7%9A%84%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EGary%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9A%84uboot%E6%89%93%E5%8D%B0%EF%BC%88%E6%89%BE%E4%B8%8D%E5%88%B0%E6%96%87%E6%A1%A3%E9%99%84%E4%BB%B6%E9%80%89%E9%A1%B9%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%E6%B3%A2%E7%89%B9%E7%8E%87%3D115200%3CBR%20%2F%3E%E6%9D%BF%3Dsabrelite%3CBR%20%2F%3Ebootargs%3Dconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk2p1%20rootwait%20rw%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3CBR%20%2F%3Ebootargs_base%3Dsetenv%20bootargs%20console%3Dttymxc0%2C115200%3CBR%20%2F%3Ebootargs_mmc%3Dsetenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk2p1%20rootwait%20rw%3CBR%20%2F%3Ebootcmd%3Drun%20bootcmd_mmc%3CBR%20%2F%3Ebootcmd_mmc%3Drun%20bootargs_base%20bootargs_mmc%3Bmmc%20dev%201%3Bmmc%20read%20%24%7Bloadaddr%7D%200x800%200x4000%3Bmmc%20read%20%24%7Bfdt_addr%7D%200x5000%200x800%3Bbootm%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3CBR%20%2F%3Ebootdelay%3D3%3CBR%20%2F%3Ebootdevs%3Dsata%20mmc%20usb%3CBR%20%2F%3Eclearenv%3Dif%20sf%20probe%20%7C%7C%20sf%20probe%20%7C%7C%20sf%20probe%201%20%3B%20then%20sf%20erase%200xc0000%200x2000%20%26amp%3B%26amp%3B%20echo%20%E5%B7%B2%E6%81%A2%E5%A4%8D%E7%8E%AF%E5%A2%83%E8%87%B3%E5%B7%A5%E5%8E%82%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%3B%20fi%3CBR%20%2F%3Ecmd_hdmi%3Dfdt%20set%20fb_hdmi%20status%20okay%3Bfdt%20set%20fb_hdmi%20mode_str%201280x720M%4060%3B%3CBR%20%2F%3Ecmd_lcd%3Dfdt%20set%20fb_lcd%20status%20disabled%3CBR%20%2F%3Ecmd_lvds%3Dfdt%20set%20fb_lvds%20status%20disabled%3CBR%20%2F%3Econsole%3Dttymxc1%3CBR%20%2F%3Ecpu%3D6Q%3CBR%20%2F%3Edfu_alt_info%3Du-boot%20raw%200x0%200xc0000%3CBR%20%2F%3Eethact%3DFEC%3CBR%20%2F%3Eethaddr%3D00%3A19%3Ab8%3A02%3A79%3A6c%3CBR%20%2F%3Eethprime%3DFEC%3CBR%20%2F%3Efdt_addr%3D0x18000000%3CBR%20%2F%3Efdt_high%3D0xffffffff%3CBR%20%2F%3Efilesize%3D70c00%3CBR%20%2F%3Einitrd_high%3D0xffffffff%3CBR%20%2F%3Ekernel%3DuImage%3CBR%20%2F%3Eloadaddr%3D0x80800000%3CBR%20%2F%3Eloadsplash%3Dif%20sf%20probe%20%3B%20then%20sf%20read%20%24%7Bsplashimage%7D%20c2000%20%24%7Bsplashsize%7D%20%3B%20fi%3CBR%20%2F%3Ereset_cause%3D1%3CBR%20%2F%3Erundfu%3Ddfu%200%20sf%200%3A0%3A25000000%3A0%3CBR%20%2F%3Estdout%3Dserial%2Cvga%3CBR%20%2F%3Euboot_defconfig%3Dnitrogen6q%3CBR%20%2F%3Eumsdevs%3Dsata%20mmc%3CBR%20%2F%3Eupgradeu%3Dfor%20dtype%20in%20%24%7Bbootdevs%7D%3B%20do%20for%20disk%20in%200%201%20%3B%20do%20%24%7Bdtype%7D%20dev%20%24%7Bdisk%7D%3Bload%20%24%7Bdtype%7D%20%24%7Bdisk%7D%3A1%2010008000%20%2F6x_upgrade%20%26amp%3B%26amp%3B%20source%2010008000%20%3B%20done%20%3B%20done%3CBR%20%2F%3Eusbnet_devaddr%3D00%3A19%3Ab8%3A00%3A00%3A02%3CBR%20%2F%3Eusbnet_hostaddr%3D00%3A19%3Ab8%3A00%3A00%3A01%3CBR%20%2F%3Eusbrecover%3Dsetenv%20ethact%20usb_ether%3B%20setenv%20ipaddr%2010.0.0.2%3B%20setenv%20netmask%20255.255.255.0%3Bsetenv%20serverip%2010.0.0.1%3B%20%3CBR%20%2F%3Esetenv%20bootargs%20console%3Dttymxc1%2C115200%3B%20tftp%20boot%2010800000%2010.0.0.1%3AuImage-%24%7Bboard%7D-recovery%26amp%3B%26amp%3B%20tftpboot%2012800000%2010.0.0.1%3Auramdisk-%24%7Bboard%7D-recovery.img%20%26amp%3B%26amp%3B%20bootm%2010800000%2012800000%3C%2FP%3E%3CP%3E%E7%8E%AF%E5%A2%83%E5%A4%A7%E5%B0%8F%EF%BC%9A1701%2F8188%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%3D%26gt%3B%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3EMMC%E8%AF%BB%E5%8F%96%EF%BC%9A%E8%AE%BE%E5%A4%87%23%201%EF%BC%8C%E5%9D%97%23%202048%EF%BC%8C%E8%AE%A1%E6%95%B016384%E2%80%A616384%E4%B8%AA%E5%9D%97%E8%AF%BB%E5%8F%96%EF%BC%9A%E7%A1%AE%E5%AE%9A%3C%2FP%3E%3CP%3EMMC%20%E8%AF%BB%E5%8F%96%EF%BC%9A%E8%AE%BE%E5%A4%87%20%231%EF%BC%8C%E5%9D%97%20%2320480%EF%BC%8C%E8%AE%A1%E6%95%B0%202048%E2%80%A6%E2%80%A62048%20%E4%B8%AA%E5%9D%97%E8%AF%BB%E5%8F%96%EF%BC%9A%E6%88%90%E5%8A%9F%3CBR%20%2F%3Ebootm%20%E5%91%BD%E4%BB%A4%E7%9A%84%E5%9B%BE%E5%83%8F%E6%A0%BC%E5%BC%8F%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%EF%BC%81%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%20Gary%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E7%8E%B0%E5%9C%A8%E7%9A%84%E6%83%85%E5%86%B5%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%B0%86%E6%A8%A1%E6%8B%9F%E7%94%B5%E8%A7%86%E7%BC%96%E7%A0%81%E5%99%A8(adv7343)%E8%BF%9E%E6%8E%A5%E5%88%B0imx6%E7%9A%84RGB%E7%AB%AF%E5%8F%A3%EF%BC%88%E5%9C%A8BDSL%E4%B8%AD%EF%BC%89%E3%80%82%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E7%A0%94%E7%A9%B6%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%AF%B9linux%E5%86%85%E6%A0%B8(3.14.52_1.1.0_ga)%E7%9A%84mxc_lcd.if%E6%96%87%E4%BB%B6%E8%BF%9B%E8%A1%8C%E5%B0%91%E9%87%8F%E4%BF%AE%E6%94%B9%E4%BD%BF%E7%94%A8V_SYNC%20%7C%20H_SYNC%E6%A8%A1%E5%BC%8F%E4%B8%8B%E7%9A%84lcd%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9D%A5%E6%94%AF%E6%8C%81%E6%AD%A4%E7%BC%96%E7%A0%81%E5%99%A8%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E9%99%A4%E4%BA%86%E6%9E%84%E5%BB%BA%E6%96%B0%E5%86%85%E6%A0%B8%E5%A4%96%E6%88%91%E5%88%AB%E6%97%A0%E9%80%89%E6%8B%A9%EF%BC%88%E6%88%96%E5%8F%A6%E6%9C%89%E6%96%B9%E6%A1%88%EF%BC%9F%EF%BC%89%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%BA%9B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9D%87%E4%B8%BA%E5%86%85%E7%BD%AE%E6%A8%A1%E5%9D%97%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%80%83%E8%99%91%E8%87%AA%E5%88%B6%E4%B8%80%E5%BC%A0%E5%8F%AF%E5%90%AF%E5%8A%A8SD%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E5%9C%A8%E5%87%86%E5%A4%87%20SD%20%E6%97%B6%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E7%AE%80%E8%A6%81%E8%AF%B4%E6%98%8E%E6%88%91%E6%89%80%E5%81%9A%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3Eexport%20DISK%3D%2Fdev%2Fsdg%20%3CBR%20%2F%3Esudo%20dd%20if%3D%2Fdev%2Fzero%20of%3D%24%7BDISK%7D%20bs%3D1M%20count%3D10%20%3CBR%20%2F%3Ecd%20binary%2F%20%3CBR%20%2F%3Esudo%20dd%20if%3Du-boot.imx%20of%3D%24%7BDISK%7D%20bs%3D512%20seek%3D2%20%3CBR%20%2F%3Esync%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F------------%E5%88%9B%E5%BB%BA%E5%88%86%E5%8C%BA%E8%A1%A8%3C%2FP%3E%3CP%3Esudo%20fdisk%20%24%7BDISK%7D%20%3CBR%20%2F%3Ed%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E5%88%A0%E9%99%A4%E5%BD%93%E5%89%8DSD%E5%8D%A1%E4%B8%8A%E7%9A%84%E6%89%80%E6%9C%89%E5%88%86%E5%8C%BA%3CBR%20%2F%3En%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E5%88%9B%E5%BB%BA%E6%96%B0%E5%88%86%E5%8C%BA%3CBR%20%2F%3Ep%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E4%B8%BB%E5%88%86%E5%8C%BA%3CBR%20%2F%3E1%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E5%88%86%E5%8C%BA%E5%8F%B71%3CBR%20%2F%3E2048%20%2F%2F%E9%BB%98%E8%AE%A4%3CBR%20%2F%3E%2B1G%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%20%3CBR%20%2F%3En%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E5%88%9B%E5%BB%BA%E7%AC%AC%E4%BA%8C%E4%B8%AA%E5%88%86%E5%8C%BA%3CBR%20%2F%3Ep%20%3CBR%20%2F%3E2%20%3CBR%20%2F%3E%E9%BB%98%E8%AE%A4%20%3CBR%20%2F%3E%E9%BB%98%E8%AE%A4%20%3CBR%20%2F%3Ew%3CBR%20%2F%3Esudo%20mkfs.vfat%20%24%7BDISK%7D1%20%3CBR%20%2F%3Esudo%20mkfs.ext3%20%24%7BDISK%7D2%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%86ext3%20SD%E5%88%86%E5%8C%BA%E6%8C%82%E8%BD%BD%E5%88%B0%2Fmedia%2Frootfs%3A%3CBR%20%2F%3Esudo%20mount%20%24%7BDISK1%7D%20%2Fmedia%2Fkernel_target%20%3CBR%20%2F%3Esudo%20mount%20%24%7BDISK%7D2%20%2Fmedia%2Frootfs_target%20%3CBR%20%2F%3Esudo%20cp%20%E2%80%93v%20binary%2F%20i%24target-%24board.dtb%20%2Fmedia%2Fkernel_target%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2Fdtb%E6%96%87%E4%BB%B6%3CBR%20%2F%3Esudo%20cp%20%E2%80%93v%20binary%2FuImage%20%2Fmedia%2Fkernel_target%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2FuImage%26nbsp%3B%3CBR%20%2F%3Esudo%20mv%20%2Fmedia%2Frootfs%2F*%20%2Fmedia%2Frootfs_target%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3E----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%E5%A6%82%E6%82%A8%E6%89%80%E8%AF%B4%EF%BC%8CNAND%E5%B7%B2%E5%88%B7%E5%86%99%E5%8C%85%E5%90%AB%E5%BF%85%E8%A6%81%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E7%9A%84uboot%EF%BC%8C%E4%B8%94uboot%E7%9A%84%E2%80%9C%E6%89%93%E5%8D%B0%E2%80%9D%E8%BE%93%E5%87%BA%E5%B7%B2%E9%99%84%E5%9C%A8%E6%AD%A4%E8%AF%84%E8%AE%BA%E4%B8%AD%E3%80%82%E7%9B%AE%E5%89%8D%E5%9C%A8uboot%E6%8F%90%E7%A4%BA%E7%AC%A6%E5%90%8E%EF%BC%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%BB%88%E7%AB%AF%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%87%E6%8D%A2%E5%88%B0%E5%88%86%E5%8C%BA%230%EF%BC%8C%E7%A1%AE%E5%AE%9A%3CBR%20%2F%3Emmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3C%2FP%3E%3CP%3EMMC%E8%AF%BB%E5%8F%96%EF%BC%9A%E8%AE%BE%E5%A4%87%23%201%EF%BC%8C%E5%9D%97%23%202048%EF%BC%8C%E8%AE%A1%E6%95%B016384%E2%80%A616384%E4%B8%AA%E5%9D%97%E8%AF%BB%E5%8F%96%EF%BC%9A%E7%A1%AE%E5%AE%9A%3C%2FP%3E%3CP%3EMMC%20%E8%AF%BB%E5%8F%96%EF%BC%9A%E8%AE%BE%E5%A4%87%20%231%EF%BC%8C%E5%9D%97%20%2320480%EF%BC%8C%E8%AE%A1%E6%95%B0%202048%E2%80%A6%E2%80%A62048%20%E4%B8%AA%E5%9D%97%E8%AF%BB%E5%8F%96%EF%BC%9A%E6%88%90%E5%8A%9F%3CBR%20%2F%3Ebootm%20%E5%91%BD%E4%BB%A4%E7%9A%84%E5%9B%BE%E5%83%8F%E6%A0%BC%E5%BC%8F%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E4%BB%8E%E7%8E%B0%E9%98%B6%E6%AE%B5%E8%B5%B7%E6%88%91%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E7%BB%A7%E7%BB%AD%E6%93%8D%E4%BD%9C%EF%BC%9F%E6%98%AF%E8%BF%99%E4%BA%9B%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E5%AF%BC%E8%87%B4%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%98%E6%98%AFSD%E5%8D%A1%E5%87%86%E5%A4%87%E6%9C%89%E8%AF%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CAnuradha%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E5%AF%B9%E4%BA%8ESabreLite%EF%BC%8C%E6%82%A8%E6%97%A0%E9%9C%80%E9%81%B5%E5%BE%AA%E4%B8%8A%E8%BF%B0%E6%8C%87%E7%A4%BA%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E6%8F%90%E4%BE%9B%E5%8F%AF%E7%9B%B4%E6%8E%A5%E8%B0%83%E7%94%A8%E7%9A%84Ubuntu%E9%95%9C%E5%83%8F%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%E5%A6%82%E6%9E%9C%E6%82%A8%E5%80%BE%E5%90%91%E4%BA%8E%E4%BD%BF%E7%94%A8Debian%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fdebian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fdebian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fdebian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E6%A1%88%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%89%80%E6%9C%89%E6%81%A9%E6%99%BA%E6%B5%A6%E7%BB%84%E4%BB%B6%EF%BC%88%E5%A6%82%E5%9B%BE%E5%BD%A2%E5%BA%93%E3%80%81VPU%E6%94%AF%E6%8C%81%E3%80%81Chrome%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E7%AD%89%EF%BC%89%E5%9D%87%E5%B7%B2%E6%89%93%E5%8C%85%E3%80%82%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%EF%BC%8C%E5%BD%93%E6%96%B0%E7%9A%84%E5%9B%BE%E5%BD%A2%E5%BA%93%E7%89%88%E6%9C%AC%E5%8F%91%E5%B8%83%E6%97%B6%EF%BC%8C%E6%82%A8%E5%8F%AA%E9%9C%80%E6%89%A7%E8%A1%8C%E2%80%9Capt%20update%20%26amp%3B%26amp%3B%20apt%20upgrade%E2%80%9D%E5%8D%B3%E5%8F%AF%E8%8E%B7%E5%8F%96%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EGary%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CAnuradha%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F836641%3FcommentID%3D836641%26amp%3Bet%3Dwatches.email.thread%23comment-836641%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F836641%3FcommentID%3D836641%26amp%3Bet%3Dwatches.email.thread%23comment-836641%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F836641%3FcommentID%3D836641%26amp%3Bet%3Dwatches.email.thread%23comment-836641%3C%2FA%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E5%8C%85%E5%90%AB%E4%B8%8E%E6%97%A7%E7%89%88uboot%E5%92%8C%E6%96%B0%E7%89%88%E5%86%85%E6%A0%B8%E7%9B%B8%E5%85%B3%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%BF%99%E4%BB%BD%E4%BC%98%E7%A7%80%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%85%B3%E4%BA%8Erootfs%E7%B3%BB%E7%BB%9F%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8imx6%20sabrelite%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E5%B9%B6%E4%B8%A5%E6%A0%BC%E6%8C%89%E7%85%A7%E6%AD%A4%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%E6%8C%87%E5%8D%97%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E5%9C%A8Ubuntu%E5%B9%B3%E5%8F%B0%E4%B8%8A%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E4%BA%86%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%B8%E8%BD%BD%E5%B9%B6%E5%B0%86SD%E5%8D%A1%E6%8F%92%E5%85%A5%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E8%AF%B7%E6%B1%826x_bootscript%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E9%80%9A%E8%BF%87NAND%E9%97%AA%E5%AD%98%E8%BF%90%E8%A1%8C%E7%9A%84%E4%BC%BC%E4%B9%8E%E6%98%AF%E6%97%A7%E7%89%88uBoot%E3%80%82%E6%88%91%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AEuBoot%E6%9D%A5%E6%8F%90%E7%A4%BA%E5%B9%B6%E5%8A%A0%E8%BD%BDrootfs%E5%92%8CzImage%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23f6f6f6%3B%22%3Egcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%E7%BC%96%E8%AF%91%E5%99%A8%E6%97%A0%E6%B3%95%E5%9C%A8ubuntu14.04%E4%B8%8A%E8%BF%90%E8%A1%8C%EF%BC%8C%E6%94%B9%E7%94%A8gcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx%E5%88%99%E6%81%A2%E5%A4%8D%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E6%96%87%E6%98%8E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%2C%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%2Fbin%2Fsh%201%3A%20arm-linux-gnueabihf-gcc%20not%20found%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E7%AC%A6%E5%8F%B7%E9%93%BE%E6%8E%A5%EF%BC%8C%E6%8C%87%E5%90%91arm-linux-gnueabihf-gcc-4.9.4%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%83%BD%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%A1%88%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%87%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6i.MX6%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85Ubuntu%20Rootfs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%B0%86%E5%85%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%20HDMI%20%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B6%E4%BB%96%E6%9B%B4%E6%94%B9%EF%BC%9F%E6%88%96%E8%80%85%E5%A6%82%E6%9E%9C%E6%88%91%E8%BF%9E%E6%8E%A5%E5%88%B0HDMI%EF%BC%8C%E6%98%AF%E5%90%A6%E4%BC%9A%E6%98%BE%E7%A4%BA%E6%A1%8C%E9%9D%A2%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:07 AM
更新人:
