Installing Ubuntu Rootfs on NXP i.MX6 boards
This post describes the setup detail for installing Ubuntu based distro in any i.Mx6x NXP Boards. Details are described on:
1. Select your board, Setting the host, Download and compile uboot , dtb and and the Kernel version on your board.
2. Installing the Ubuntu core, Lubuntu graphics desktop version and/or Build your own Ubuntu rootfs with debootstrap.
3. Modify rootfs and Installing needed packages
4. Setting with SD image.
5. Setting Ubuntu on target
6. Adding GPU acceleration
1: Select your board, Setting the host, Download and compile uboot , dtb and and the Kernel version on your board.
Supported NXP HW boards:
  • i.MX 6QuadPlus SABRE-SD Board and Platform
  • i.MX 6Quad SABRE-SD Board and Platform
  • i.MX 6DualLite SABRE-SD Board
  • i.MX 6Quad SABRE-AI Board
  • i.MX 6DualLite SABRE-AI Board
  • i.MX 6SoloX SABRE-SD Board
  • i.MX 6SoloX SABRE-AI Board
Install host dependences (version tested 14.04):
$ sudo apt-get install gparted git build-essential libncurses5 wget u-boot-tools zlib1g-dev ncurses-dev \
cmake libc-dev-armhf-cross pkg-config-arm-linux-gnueabihf build-essential checkinstall cmake \
pkg-config lzop libc6 libstdc++6 debootstrap qemu-user-static binfmt-support
Download the compiler toolchain and extract it:
$ cd ~/
$ wget -c https://releases.linaro.org/14.09/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.9-2...
$ tar xf gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz
Create general variable environments:
$ export target=mx6q (e.g. processor: mx6sx, mx6d, mx6dl,etc)
$ export board=sabresd (e.g. sabresd, sabreauto)
$ export ARCH=arm
$ export CROSS_COMPILE=../gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf-
$ unset LDFLAGS
Download u-boot
At the release of this document, latest uboot version was imx_3.14.52, it should work with other version as well, so please check the proper version for your board:
$ cd ~/
$ wget –c http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/snapshot/uboot-imx-rel_imx_3.14.52_1.1.0_ga....
$ tar -xf uboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz
$ cd uboot-imx-rel_imx_3.14.52_1.1.0_ga
$ make $targetboard_config    # e.g. mx6qsabresd_config
$ make
Linux Kernel, Firmware, headers, modules and DTS files
$ cd ~/
$ wget –c http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/snapshot/linux-2.6-imx-rel_imx_3.14.52_1...
$ tar xf linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz
$ cd linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga
$ make imx_v7_defconfig
$ make menuconfig
$ make -j4 zImage modules dtbs
$ cd ~/
move your image to binary folder:
$ sudo cp –v uboot-imx-rel_imx_3.14.52_1.1.0_ga/u-boot.imx binary/
$ sudo cp –v linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/boot/zImage binary/
$ sudo cp –v linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/boot/dts/i$target-$board.dtb binary/
Now you have the bootloader, device tree and kernel image of your board ready, let’s create the rootfs.
2: Installing the Ubuntu core, Lubuntu graphics desktop version and/or Build your own Ubuntu rootfs with debootstrap.
Installing ubuntu core:
$ cd ~/
$ sudo mkdir –p core /media/rootfs /media/kernel
$ wget –c http://cdimage.ubuntu.com/ubuntu-core/releases/14.04/release/ubuntu-core-14.04.4-core-armhf.tar.gz
$ sudo tar –xf ubuntu-core-14.04.4-core-armhf.tar.gz –C core
$ sudo cp -vr core/* /media/rootfs
$ sudo make modules_install firmware_install INSTALL_MOD_PATH=/media/rootfs/ ARCH=arm CROSS_COMPILE=../../gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf-
$ sudo make ARCH=arm CROSS_COMPILE=../../gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf- headers_install INSTALL_HDR_PATH=/media/rootfs/usr
Now you should have your ubuntu rootfs on /media/rootfs folder. and you can pass to part 3 of this post.
Installing ubuntu Linaro LXDE:
$ cd ~/
$ wget https://releases.linaro.org/14.10/ubuntu/trusty-images/alip/linaro-trusty-alip-20141024-684.tar.gz
$ sudo tar -xf linaro-trusty-alip-20141024-684.tar.gz –C core
$ sudo mv core/binary/* core/
$ sudo rm –rf core/binary
Installing with debootstrap
$ cd ~/
$ target=rootfs
$ distro=trusty
$ sudo debootstrap --arch=armhf --foreign --include=ubuntu-keyring,apt-transport-https,ca-certificates,openssl $distro "$target" http://ports.ubuntu.com
$ sudo cp /usr/bin/qemu-arm-static $target/usr/bin
$ sudo cp /etc/resolv.conf $target/etc
Now have a minimal Ubuntu rootfs - chroot to it and perform the 2nd stage install:
$ sudo chroot $target  //Now we are in chroot
# distro=trusty
# export LC_ALL=C LANGUAGE=C LANG=C
# /debootstrap/debootstrap --second-stage
Edit the sources.list repositories
# cat <<EOT > /etc/apt/sources.list
deb http://ports.ubuntu.com/ubuntu-ports/ $distro main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ $distro-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ $distro-security main restricted universe multiverse
EOT
# apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 40976EAF437D05B5
# apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 3B4FE6ACC0B21F32
# apt-get update
# apt -y -f install
# apt-get upgrade
# apt-get install nano
Now you should be able to login without password, then use passwd command to set one. If you like to add custom users:
# passwd root
# adduser <myuser>
# usermod -a -G tty myuser
# usermod -a -G dialout, adm, sudo, dip, plugdev myuser
# visudo
Under the line that looks like:
root ALL=(ALL:ALL) ALL
add the following (change user with your actual username)
<myuser> ALL=(ALL) ALL
your rootfs is ready, exit chroot
# exit
$ sudo rm $target/etc/resolv.conf
$ sudo rm $target/usr/bin/qemu-arm-static
$ sudo mv rootfs/* /media/rootfs
Now you should have your ubuntu rootfs on /media/root.
3: Modify Rootfs and Install needed packages
Edit and verify the sources.list repositories
$ cd /media/rootfs
$ sudo cat <<EOT > etc/apt/sources.list
deb http://ports.ubuntu.com/ubuntu-ports/ trusty main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ trusty-security main restricted universe multiverse
EOT
Edit networks interfaces and append in the existing file:
$ sudo nano etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
If you require Serial Console, remove and include an additional line at the end of the file for  ttymxc0 output as below,
$ sudo nano etc/init/tty1.conf
exec /sbin/getty -8 38400 tty1
exec /sbin/getty -L 115200 ttymxc0
If you like to change the localhostname:
$ sudo nano etc/hostname
and change to “your name” e.g. imx6Q.
Set the date and time clock and update
$ sudo nano /etc/rc.local
Add this:
if [ `date +"%Y"` -eq "1970" ]; then
                    date --set="2016-04-01"
fi
exit 0
(optional for Linaro rootfs)
Edit passwd and remove the x in root and linaro lines
$ sudo nano etc/passwd
root:x:0:0:root:/root:/bin/bash
linaro:x:0:0..
and change like this:
root::0:0:root:/root:/bin/bash
linaro:::0:..
Now you are ready to program your sd image.
4: Setup microSD/SD card
For these instructions, we are assuming: DISK=/dev/sdg on your HOST, cat /proc/partitions is very useful for determining the device id.
$ cd ~/
$ export DISK=/dev/sdg
Erase microSD/SD card:
$ sudo dd if=/dev/zero of=${DISK} bs=1M count=10
Install Bootloader
$ cd binary/
$ sudo dd if=u-boot.imx of=${DISK} bs=512 seek=2
$ sync
Create Partition layout:
$ cd ~/
$ sudo fdisk ${DISK}
steps:
  • d ///delete all partitions currently on sd
  • n // create new partition
  • p // Primary partition
  • 1 // partition number 1
  • 2048 //default
  • +1G //
  • n // created 2d parition
  • p
  • 2
  • default
  • default
  • 1 // firts
  • B // to be fat32
  • W // write partiotions
$ sudo mkfs.vfat ${DISK}1
$ sudo mkfs.ext3  ${DISK}2
Mount ext3 SD partition to /media/rootfs:
$ sudo mount ${DISK1} /media/kernel_target
$ sudo mount ${DISK}2 /media/rootfs_target
Copy Files on the SD.
$ cd ~/
$ sudo cp –v binary/ i$target-$board.dtb /media/kernel_target
$ sudo cp –v binary/zImage /media/kernel_target
$ sudo mv /media/rootfs/* /media/rootfs_target
Remove SD:
$ sync
$ sudo umount /media/kernel_target
$ sudo umount /media/rootfs_target
Boot the target, in console you should be login as root.
root@imx6QSabreSD:~#
5: Setting Ubuntu on target
Note: If you have issues with sudo on user UID, need to logout and log as root:
imx6Q login: root
Welcome to Ubuntu 14.04.4 LTS (GNU/Linux 3.14.52 armv7l)
root@imx6Q:~# chown root:root /usr/bin/sudo
root@imx6Q:~# chmod 4755 /usr/bin/sudo
root@imx6Q:~# exit
Login with <user $> or root #
# apt-get update
# apt-get –f install
# apt-get install locales dialog wget
# dpkg-reconfigure locales
# apt-get upgrade
Optional – install some useful packages:
# apt-get install openssh-server can-utils usbutils build-essential automake autoconf libtool
Get and Install the BSP packages (EULA required)
# cd /home/user
# mkdir –p vpu_pack
# cd vpu_pack
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//firmware-imx-5.3.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-5.4.32.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//libfslcodec-4.0.8.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-lib-5.1.tar.gz
# chmod +x *
# ./firmware-imx-5.3.bin --auto-accept --force
# mkdir –p /lib/firmware/vpu
# cp -ravf firmware-imx-5.3/firmware/* /lib/firmware/
# ./imx-vpu-5.4.32.bin --auto-accept --force
# cd imx-vpu-*
# make PLATFORM=IMX6Q all
# make install
# tar -xf imx-lib-5.1.tar.gz
# cd  imx-lib-5.1/
# make -j1 PLATFORM="IMX6Q"
# make PLATFORM="IMX6Q" install
# cd ..
# ./libfslcodec-4.0.8 --auto-accept –force
# cd libfslcodec-*
# ./autogent.sh --prefix=/usr --enable-fhw --enable-vpu
# make
# make install
# mv /usr/lib/imx-mm/video-codec/* /usr/lib
# mv /usr/lib/imx-mm/audio-codec/* /usr/lib
# rm –rf /usr/lib/imx-mm/
# cd ..
# mkdir –p gpu_pack
# cd gpu_pack
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-gpu-viv-5.0.11.p7.4-hfp.bin
# wget http://www.nxp.com/lgfiles/NMG/MAD/YOCTO//xserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz
# chmod +x *
# ./imx-gpu-viv-5.0.11.p7.4-hfp –-auto-accept -–force
# cd imx-gpu*
# cp g2d/usr/include/* /usr/include/
# cp -d g2d/usr/lib/* /usr/lib/
# cp -Pr gpu-core/usr/* /usr
# optional: install demos
# cp -r gpu-demos/opt /
# optional: install gpu tools
# cp -axr gpu-tools/gmem-info/usr/bin/* /usr/bin/
# cd ..
Installing gstreamer-imx, IPU, VPU and GPU support:
Install build deps, gstreamer1.x, this step could take some time (~350MB):
# apt-get install python pkg-config git gstreamer1.0-x gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-alsa libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-good1.0-dev g++-multilib
# git clone git://github.com/Freescale/gstreamer-imx.git
# cd gstreamer-imx
# ln –s /usr/lib/arm-linux-gnueabihf/gstreamer-1.0/ /usr/lib/gstreamer-1.0
# ./waf configure --prefix=/usr --kernel-headers=/include
# ./waf
# ./waf install
# cd ../../
(optional) Install libimxvpuapi library: This library provides a community based open-source API to the NXP imx-vpu library (the low-level IMX6 VPU interface).
# git clone git://github.com/Freescale/libimxvpuapi.git
# cd libimxvpu*
# ./waf configure –-prefix=/usr
# ./waf
# ./waf install
# cd ..
  • note './waf install' installs artifacts to its prefix + /lib/gstreamer-1.0 but they need to be installed to /usr/lib/arm-linux-gnueabihf/gstreamer-1.0 which is why we created a symlink above before installing
  • note g2d lib required to build G2D
  • note that x11 library is required to build EGL sink with Vivante direct textures (only needed for X11 support)
  • note that libfslaudiocodec is required to build audio plugins
Now you are ready to test gstreamer
6: Add GPU HW Acceleration for X11
NOTE: The original version of these build instructions can be found in the Gateworks wiki . Many thanks to them for writing this!
IMX6 IPU, VPU, and GPU support via GStreamer and Gstreamer-imx plugins. Many of the pieces needed (firmware and source-code) are from NXP and not freely redistributable thus must be downloaded from their mirror and extracted from a shell script that forces you to read and agree to their End User License Agreement (EULA).
The following instructions can be used on top of the debootstrap and should work on other sources of Ubuntu or other Linux distributions root filesystems as well
You can easily add X11 support to a base image created with the debootstrap instructions above by adding a few package groups. You will need the following:
  • X11 server - ie Xorg
  • Display Manager - this controls the login to the X session
  • Window Manager - manages window position, re-sizing, decorations, etc for X clients
If in any case you have installed the Linaro LXDE rootfs, it includes the Xorg X11 server, the lxdm Display Manager, the openbox Window Manager, and others useful user applications including the Chromium browser, if you do not install linaro lxde and want to install it please do:
this step could take some time (~650MB)
  # apt-get install xinit lxde lxterminal lxappearance lxrandr lxshortcut lxinput xinit  xserver-xorg-dev mesa-utils mesa-utils-extra
Notes:
  • you will need to add a non-root user with adduser for Chromium browser to work. You may choose to set up auto-login for that user by editing /etc/lxdm/default.conf and setting the autologin property in the base section at the beginning of the config file. /etc/xdg/lubuntu/lxdm/lxdm.conf
  • This document takes as based kernel version 3.14.52v, vivante 5.0.11p7.4 correspond to the kernel version used. you should check the BSP release notes in order to know which xserver and Vivante GPU files need to be downloaded from the NXP repos.
$ sudo nano /etc/lxdm/default.conf
   [base]
   autologin=user
To add hardware GPU acceleration to X11 you need to add some libraries and drivers provided by Freescale from the imx-gpu-viv package. This requires signing Freescales End User License Agreement (EULA). This package provides the following:
  • libg2d - a documented low-level API to the GPU (used by things like libimxvpuapi for gstreamer-imx and the gpu-core drivers)
  • gpu-core - provides all the various OpenGL libs (libGL, libGLESv1_CM, libGLESv1_CL, libGLESv2, libGLSLC, libCLC, libEGL, libGAL, libOpenCL, ls
  • libOpenVG) typically provided by the mesa project. Note that several versions of libEGL/libGAL/libGLESv2/libVIVANTE are provided for different backend rendering systems: dfb, fb, wl, x11.
# cd gpu_pack
#cd imx-gpu-*
# cp gpu-core/usr/lib/dri/vivante_dri.so /usr/lib/xorg/modules/drivers/
# chmod 644 /usr/lib/xorg/modules/drivers/vivante_dri.so
# rm /usr/lib/arm-linux-gnueabihf/mesa/libGL.so*
# rm /usr/lib/arm-linux-gnueabihf/mesa-egl/libEGL.so*
# rm /usr/lib/arm-linux-gnueabihf/mesa-egl/libGLESv2.so*
# rm /usr/lib/arm-linux-gnueabihf/mesa-egl/libOpenVG.so*
# cd ../../
# cd gpu-pack
# tar –xf xserver*
# cd xserver-org-video-imx*
#looks lik have to made #git init
# ./fastbuild.sh  BUILD_HARD_VFP=1 XSERVER_GREATER_THAN_13=1
# cd..
# cd kernel-modu*
# make
Switch to gpu-core x11 backend:
# backend=x11
# ln -sf libEGL-${backend}.so /usr/lib/libEGL.so
# ln -sf libEGL-${backend}.so /usr/lib/libEGL.so.1
# ln -sf libEGL-${backend}.so /usr/lib/libEGL.so.1.0
# ln -sf libGAL-${backend}.so /usr/lib/libGAL.so
# ln -sf libGLESv2-${backend}.so /usr/lib/libGLESv2.so
# ln -sf libGLESv2-${backend}.so /usr/lib/libGLESv2.so.2
# ln -sf libGLESv2-${backend}.so /usr/lib/libGLESv2.so.2.0.0
# ln -sf libVIVANTE-${backend}.so /usr/lib/libVIVANTE.so
# ln -sf libGAL_egl.dri.so /usr/lib/libGAL_egl.so
# for i in egl glesv1_cm glesv2 vg; do
        cp /usr/lib/pkgconfig/${i}_${backend}.pc/usr/lib/pkgconfig/${i}.pc
    done
#rm /usr/lib/*-dfb.so /usr/lib/*-fb.so /usr/lib/*-wl.so
(Optional in case you deploy your kernel version with GPU as module) make vivante kernel module (GPU kernel driver) load on boot:
# echo vivante >> /etc/modules
# nano /etc/udev/rules.d/10-imx.rules
KERNEL=="galcore",  MODE="0660", GROUP="video"
KERNEL=="mxc_asrc",  MODE="0666"
Create an xorg.conf configured for the Vivante fbdev driver:
# nano /etc/X11/xorg.conf
Section "Device"
    Identifier "i.MX Accelerated Framebuffer Device"
    Driver "vivante"
    Option "fbdev" "/dev/fb0"
    Option "vivante_fbdev" "/dev/fb0"
    Option "HWcursor" "false"
EndSection
Section "ServerFlags"
    Option "BlankTime"  "0"
    Option "StandbyTime"  "0"
    Option "SuspendTime"  "0"
    Option "OffTime"  "0"
EndSection
# cd ..
Make sure the files copied into the correct places.
If all compiled and copied, you should now see a bunch of new libraries in /usr/lib! Congratulations! After you finish you can reboot your system and start playing.
Testing Gstreamer examples:
  • show gstreamer-imx plugins:
# gst-inspect-1.0 | grep imx
imxvpu:  imxvpuenc_mjpeg: Freescale VPU motion JPEG video encoder
imxvpu:  imxvpuenc_mpeg4: Freescale VPU MPEG-4 video encoder
imxvpu:  imxvpuenc_h264: Freescale VPU h.264 video encoder
imxvpu:  imxvpuenc_h263: Freescale VPU h.263 video encoder
imxvpu:  imxvpudec: Freescale VPU video decoder
imxv4l2videosrc:  imxv4l2videosrc: V4L2 CSI Video Source
imxg2d:  imxg2dcompositor: Freescale G2D video compositor
imxg2d:  imxg2dvideotransform: Freescale G2D video transform
imxg2d:  imxg2dvideosink: Freescale G2D video sink
imxipu:  imxipucompositor: Freescale IPU video compositor
imxipu:  imxipuvideosink: Freescale IPU video sink
imxipu:  imxipuvideotransform: Freescale IPU video transform
imxpxp:  imxpxpvideotransform: Freescale PxP video transform
imxpxp:  imxpxpvideosink: Freescale PxP video sink
  • imxipuvideosink:
# gst-launch-1.0 videotestsrc ! imxipuvideosink
imxg2dvideosink:
# gst-launch-1.0 videotestsrc ! imxg2dvideosink
The imxeglvivsink allows hardware accelerated display to a window on the X11 host
# export DISPLAY=:0.0
# gst-launch-1.0 videotestsrc ! imxeglvivsink
To test if you have graphics support you can run any glmark2 and/or mesa-utils or can run example of the next route:
# cd /opt/viv_samples/vdk/
# ./tutorial1        //any example
root@imx6Q:~# glxgears -info
GL_RENDERER   = Vivante GC2000
GL_VERSION    = 2.1 2.0.1
GL_VENDOR     = Vivante Corporation
GL_EXTENSIONS = WGL_ARB_extensions_string WGL_EXT_extensions_string WGL_EXT_swap_control GL_EXT_texture_env_add GL_ARB_multitexture GL_ARB_multisample GL_ARB_texture_env_add GL_ARB_texture_compression GL_ARB_texture_env_combine GL_ARB_depth_texture GL_ARB_window_pos ….
1606 frames in 5.0 seconds = 321.130 FPS
1650 frames in 5.0 seconds = 329.834 FPS
GL_VENDOR     = Vivante Corporation1629 frames in 5.0 seconds = 325.644 FPS
1621 frames in 5.0 seconds = 324.072 FPS
1650 frames in 5.0 seconds = 329.806 FPS
1651 frames in 5.0 seconds = 330.079 FPS
コメント
How to connect it to HDMI Display?
Is there any additional changes or If I connect to HDMI it will show desktop??
HI,
Does somebody encounter /bin/sh 1: arm-linux-gnueabihf-gcc not found issue? this is a symlink to arm-linux-gnueabihf-gcc-4.9.4.
any fix to it is highly appreciated.
Thanks aheard.
wenming
Hi all,
I find the gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz compiler not working on ubuntu14.04, I tried with gcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx works.
Regards!
Wenming
Hi, thanks for this excellent doc, and I have a question on rootfs system. I am using imx6 sabrelite board and have exactly followed the guidelines in this doc. I cross compiled all the files on an Ubuntu platform, and after the unmount and inserted the SD card to my board. The kernel boot process requests 6x_bootscript file and it seems like the older uBoot is operating fron Nand Flash. How should I solve this issue by setting my own uBoot to prompt and load rootfs and zImage ?
Hi Anuradha, please refer to https://community.nxp.com/message/836641?commentID=836641&et=watches.email.thread#comment-836641  this doc, about old uboot with new kernel.
Hi Anuradha,
Actually for SabreLite you don't need to follow the above instructions, we already provide an Ubuntu image ready to go:
https://boundarydevices.com/ubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15/
Or if you'd rather use Debian:
https://boundarydevices.com/debian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28/
Note that in our case all the NXP components like the graphics library, VPU support, Chrome hw acceleration are packaged. That means that when a new graphics library version is out, you just need to do "apt update && apt upgrade" and you are up-to-date.
Hope this helps.
Gary
Hi Gary, thanks for your reply. Now the situation is like this :
I want to interface an analog TV encoder (adv7343) to the RGB port of the imx6 (in BDSL). According to what I have researched, I need adding few modifications to the mxc_lcd.if of the linux kernel (3.14.52_1.1.0_ga) to use lcd driver in V_SYNC | H_SYNC mode to support this encoder. So I have no option (or do I?) rather than building a new kernel (as these drivers are builtin modules), and that's why I thought of building a bootable SD card myself.
I think the steps I followed in preparing SD should be okay, but to note what I've done in brief :
cd binary/
sync
//------------create partition table
sudo fdisk ${DISK}
d       //delete all partitions currently on sd
2048 //default
+1G    //
p
2
default
default
w
sudo cp –v binary/ i$target-$board.dtb /media/kernel_target    //dtb file
sudo cp –v binary/uImage /media/kernel_target                        //uImage
sudo mv /media/rootfs/* /media/rootfs_target                             //root file sys
As you said the NAND flashed uboot already has required environment variables, and the uboot 'print' is attached to this comment. Now after the uboot prompt, I get the following message in console terminal :
switch to partitions #0, OK
mmc1 is current device
MMC read: dev # 1, block # 2048, count 16384 ... 16384 blocks read: OK
MMC read: dev # 1, block # 20480, count 2048 ... 2048 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
So from this point, how should I proceed ? do these environment variables cause the issue or is SD card preparation wrong?
Thanks in advance !
My uboot print (couldn't find the document attachment option)
baudrate=115200
board=sabrelite
bootargs=console=ttymxc0,115200 root=/dev/mmcblk2p1 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk2p1 rootwait rw
bootcmd=run bootcmd_mmc
bootcmd_mmc=run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x4000;mmc read ${fdt_addr} 0x5000 0x800;bootm ${loadaddr} - ${fdt_addr}
bootdelay=3
bootdevs=sata mmc usb
clearenv=if sf probe || sf probe || sf probe 1 ; then sf erase 0xc0000 0x2000 && echo restored environment to factory default ; fi
cmd_hdmi=fdt set fb_hdmi status okay;fdt set fb_hdmi mode_str 1280x720M@60;
cmd_lcd=fdt set fb_lcd status disabled
cmd_lvds=fdt set fb_lvds status disabled
console=ttymxc1
cpu=6Q
dfu_alt_info=u-boot raw 0x0 0xc0000
ethact=FEC
ethaddr=00:19:b8:02:79:6c
ethprime=FEC
fdt_addr=0x18000000
fdt_high=0xffffffff
filesize=70c00
initrd_high=0xffffffff
kernel=uImage
loadaddr=0x80800000
loadsplash=if sf probe ; then sf read ${splashimage} c2000 ${splashsize} ; fi
reset_cause=1
rundfu=dfu 0 sf 0:0:25000000:0
stdout=serial,vga
uboot_defconfig=nitrogen6q
umsdevs=sata mmc
upgradeu=for dtype in ${bootdevs}; do for disk in 0 1 ; do ${dtype} dev ${disk};load ${dtype} ${disk}:1 10008000 /6x_upgrade && source 10008000 ; done ; done
usbnet_devaddr=00:19:b8:00:00:02
usbnet_hostaddr=00:19:b8:00:00:01
usbrecover=setenv ethact usb_ether; setenv ipaddr 10.0.0.2; setenv netmask 255.255.255.0; setenv serverip 10.0.0.1;
setenv bootargs console=ttymxc1,115200; tftp boot 10800000 10.0.0.1:uImage-${board}-recovery&& tftpboot 12800000 10.0.0.1:uramdisk-${board}-recovery.img && bootm 10800000 12800000
Environment size: 1701/8188 bytes
=> boot
Please use the flashing procedure from our Ubuntu release blog post.
Gary
Hi ,
I build one following the guidance for my im53qsb reference board. But I got kernel panic at imx5_pm_init, I am using the imx_v7_defconfig, is anybody else has this issue or has fix for this issue or can I remove the pm configuration.
U-Boot 2015.04 (Oct 04 2016 - 12:17:39)
Board: MX53 LOCO
I2C: ready
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: FEC
Hit any key to stop autoboot: 0
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
5997120 bytes read in 346 ms (16.5 MiB/s)
Booting from mmc ...
reading imx53-qsrb.dtb
24491 bytes read in 19 ms (1.2 MiB/s)
Kernel image @ 0x72000000 [ 0x000000 - 0x5b8240 ]
## Flattened Device Tree blob at 71000000
Booting using the fdt blob at 0x71000000
Loading Device Tree to 8f552000, end 8f55afaa ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.14.38 (lucid@ubuntu) (gcc version 4.8.5 (Linaro GCC 4.8-2015.06) ) #1 SMP PREEMPT Wed Oct 5 06:56:31 PDT 2016
CPU: ARMv7 Processor [412fc085] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX53 Quick Start Board
cma: CMA: reserved 320 MiB at bc000000
Memory policy: Data cache writeback
CPU: All CPU(s) started in SVC mode.
PERCPU: Embedded 8 pages/cpu @cb33f000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259072
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 699820K/1048576K available (7423K kernel code, 456K rwdata, 2584K rodata, 384K init, 432K bss, 348756K reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0x80000000 - 0xe0000000 (1536 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x809ce000 (10008 kB)
.init : 0x809ce000 - 0x80a2e080 ( 385 kB)
.data : 0x80a30000 - 0x80aa20c0 ( 457 kB)
.bss : 0x80aa20cc - 0x80b0e25c ( 433 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
NR_IRQS:16 nr_irqs:16 16
TrustZone Interrupt Controller (TZIC) initialized
CPU identified as i.MX53, silicon rev 2.1
Switching to timer-based delay loop
sched_clock: 32 bits at 33MHz, resolution 30ns, wraps every 128849019873ns
clocksource_of_init: no matching clocksources found
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket -1, mpidr 0
Setting up static identity map for 0x70710420 - 0x70710478
Brought up 1 CPUs
SMP: Total of 1 processors activated (66.66 BogoMIPS).
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
Use WDOG1 as reset source
syscon 53fa8000.iomuxc-gpr: regmap [mem 0x53fa8000-0x53fa800b] registered
hw-breakpoint: debug architecture 0x4 unsupported.
imx53-pinctrl 53fa8000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
3P2V: 3200 mV
usb_vbus: 5000 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbphy.1 supply vcc not found, using dummy regulator
usbphy.2 supply vcc not found, using dummy regulator
i2c i2c-1: IMX I2C adapter registered
da9052: probe of 0-0048 failed with error -5
i2c i2c-0: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
imx-ipuv3: probe of 18000000.ipu failed with error -22
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switched to clocksource mxc_timer1
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 2006
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
imx-sdma 63fb0000.sdma: no iram assigned, using external mem
imx-sdma 63fb0000.sdma: no event needs to be remapped
imx-sdma 63fb0000.sdma: Direct firmware load failed with error -2
imx-sdma 63fb0000.sdma: Falling back to user helper
imx-sdma 63fb0000.sdma: initialized
Serial: IMX driver
53fbc000.serial: ttymxc0 at MMIO 0x53fbc000 (irq = 47, base_baud = 4166666) is a IMX
console [ttymxc0] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
CAN device driver interface
63fec000.ethernet supply phy not found, using dummy regulator
libphy: fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usb_ehset_test
53f80800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
input: mma8450 as /devices/virtual/input/input0
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
coda 63ff4000.vpu: Direct firmware load failed with error -2
coda 63ff4000.vpu: Falling back to user helper
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt 53f98000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 50004000.esdhc [50004000.esdhc] using ADMA
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc1: SDHCI controller on 50020000.esdhc [50020000.esdhc] using ADMA
mmc0: new high speed SDHC card at address 0007
Job Ring Device allocation for transform failed
mmcblk0: mmc0:0007 SD16G 14.5 GiB
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmcblk0: p1 p2
sgtl5000 1-000a: sgtl5000 revision 0x11
imx-sgtl5000 sound.8: phandle missing or invalid
imx-sgtl5000: probe of sound.8 failed with error -22
NET: Registered protocol family 26
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
Unable to handle kernel paging request at virtual address f51a000c
pgd = 80004000
[f51a000c] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.38 #1
task: c8068000 ti: c806c000 task.ti: c806c000
PC is at mx5_cpu_lp_set+0x10/0xfc
LR is at imx5_pm_init+0x64/0x80
pc : [<8001d804>] lr : [<809da58c>] psr: 60000113
sp : c806dedc ip : 00000072 fp : 00000000
r10: c806c038 r9 : 80a1ee7c r8 : 809d1190
r7 : 80aa2100 r6 : 80aa2100 r5 : 00000007 r4 : c801b600
r3 : f51a0000 r2 : 8001d8f0 r1 : 00000002 r0 : 00000002
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 70004019 DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xc806c238)
Stack: (0xc806dedc to 0xc806e000)
dec0: c801b600
dee0: 00000007 809da58c 80a2b80c 809d11b0 00000000 800088bc c800ccc0 808c7d28
df00: c8096200 80714144 00000000 00000000 00000000 8012a57c 00000000 80a446b0
df20: 60000113 00000001 cbfffc2e 8073b938 0000010b 800498e0 80996644 00000007
df40: cbfffc36 00000007 80a446a0 80a2b80c 00000007 80aa2100 80aa2100 809ce50c
df60: 80a1ee7c 0000010b 80a1ee74 809cec38 00000007 00000007 809ce50c 8070fbd8
df80: 00000000 00002100 80706164 00000000 00000000 00000000 00000000 00000000
dfa0: 00000000 80706170 00000000 8000e278 00000000 00000000 00000000 00000000
dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 80000220 08040010
[<8001d804>] (mx5_cpu_lp_set) from [<809da58c>] (imx5_pm_init+0x64/0x80)
[<809da58c>] (imx5_pm_init) from [<809d11b0>] (init_machine_late+0x20/0x28)
[<809d11b0>] (init_machine_late) from [<800088bc>] (do_one_initcall+0xf8/0x144)
[<800088bc>] (do_one_initcall) from [<809cec38>] (kernel_init_freeable+0x13c/0x1dc)
[<809cec38>] (kernel_init_freeable) from [<80706170>] (kernel_init+0xc/0xe8)
[<80706170>] (kernel_init) from [<8000e278>] (ret_from_fork+0x14/0x3c)
Code: e3a03000 e92d4030 e1a01000 e34f351a (e593c00c)
---[ end trace 65acb852349b9d5b ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
T
Have you chance to test it for i.MX 6QuadPlus SABRE-AI Board?
Can be used a newer BSP rel_imx_4.1.15_1.1.0_ga?
HI Erik,
I do not have a i.mx 6 QuadPlus board to try.
If you tried and share me the results.
Thanks!
Wenming
How can I redirect output to HDMI monitor?
I am trying to start the system but I got stuck at
* Stopping save kernel messages                                         [ OK ]
U-Boot 2015.04 (Nov 02 2016 - 23:46:14)
CPU: Freescale i.MX6QP rev1.0 at 792 MHz
CPU: Temperature 33 C
Reset cause: POR
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
PMIC: PFUZE100 ID=0x10
NAND: 0 MiB
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
reading boot.scr
reading zImage
6022776 bytes read in 309 ms (18.6 MiB/s)
reading imx6qp-sabreauto.dtb
46893 bytes read in 20 ms (2.2 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5be678 ]
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800e72c
Starting kernel ...
Linux version 3.14.52 (r59400@Latitude) (gcc version 4.8.5 (Linaro GCC 4.8-2015.06) ) #3 SMP PREEMPT Wed Nov 2 23:55:53 CET 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
Machine model: Freescale i.MX6 Quad Plus SABRE Automotive Board
cma: CMA: reserved 320 MiB at 6a000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @ee71d000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520720
Kernel command line: console=ttymxc3,115200 root=/dev/mmcblk2p2 rootwait rw
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1739228K/2097152K available (7452K kernel code, 460K rwdata, 2596K rodata, 392K init, 433K bss, 357924K reserved, 270336K highmem)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0x80000000 - 0xef800000 (1784 MB)
.text : 0x80008000 - 0x809d82d4 (10049 kB)
.init : 0x809d9000 - 0x80a3b080 ( 393 kB)
.data : 0x80a3c000 - 0x80aaf340 ( 461 kB)
.bss : 0x80aaf34c - 0x80b1b99c ( 434 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32070000, Cache size: 1024 kB
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10718008 - 0x10718060
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: Booted secondary processor
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: Booted secondary processor
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
CPU identified as i.MX6QP, silicon rev 1.0
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
vddarm: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV at 1150 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
mxs-dma 110000.dma-apbh: initialized
cs42888_supply: 3300 mV
3P3V: 3300 mV
vio1: 3300 mV
vio2: 3300 mV
vd: 3300 mV
va: 5000 mV
platform usb_h1_vbus.30: Driver reg-fixed-voltage requests probe deferral
platform usb_otg_vbus.31: Driver reg-fixed-voltage requests probe deferral
P3V3_SDa_SWITCHED: 3300 mV
usbphy_nop1.12 supply vcc not found, using dummy regulator
usbphy_nop2.13 supply vcc not found, using dummy regulator
i2c i2c-2: IMX I2C adapter registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-prg 21cc000.prg: driver probed
imx-prg 21cd000.prg: driver probed
imx-pre 21c8000.pre: driver probed
imx-pre 21c9000.pre: driver probed
imx-pre 21ca000.pre: driver probed
imx-pre 21cb000.pre: driver probed
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
imx_busfreq busfreq.16: DDR medium rate not supported.
futex hash table entries: 1024 (order: 4, 65536 bytes)
bounce pool size: 64 pages
msgmni has been set to 3508
backlight.17 supply power not found, using dummy regulator
mxc_sdc_fb fb.23: registered mxc display driver ldb
imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
mxc_sdc_fb fb.24: registered mxc display driver hdmi
mxc_sdc_fb fb.25: NO mxc display driver found!
mxc_sdc_fb fb.26: registered mxc display driver ldb
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.2
mxc_hdmi 20e0000.hdmi_video: Read EDID again
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1375 mV
SW1C: 300 <--> 1875 mV at 1375 mV
SW2: 800 <--> 1975 mV at 1375 mV
SW3A: 400 <--> 1975 mV at 1350 mV
SW3B: 400 <--> 1975 mV at 1350 mV
SW4: 800 <--> 1975 mV at 1825 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 800 <--> 1550 mV at 1200 mV
VGEN2: 800 <--> 1550 mV at 1500 mV
VGEN3: 1800 <--> 3300 mV at 1800 mV
VGEN4: 1800 <--> 3300 mV at 3000 mV
VGEN5: 1800 <--> 3300 mV at 2500 mV
VGEN6: 1800 <--> 3300 mV at 2800 mV
Serial: IMX driver
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61, base_baud = 5000000) is a IMX
mxc_hdmi 20e0000.hdmi_video: create default modelist
console [ttymxc3] enabled
brd: module loaded
loop: module loaded
si476x-core 1-0063: Using default platform data.
si476x-core 1-0063: No IRQ number specified, will use polling
si476x-core 1-0063: Error while sending command 0x11
si476x-core 1-0063: The device in inconsistent power state
ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
2094000.can supply xceiver not found, using dummy regulator
flexcan 2094000.can: device registered (reg_base=f0238000, irq=143)
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet eth0: registered PHC device 0
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
platform 2184000.usb: Driver imx_usb requests probe deferral
imx_usb 2184200.usb: Can't register ci_hdrc platform device, err=-517
platform 2184200.usb: Driver imx_usb requests probe deferral
egalax_ts 1-0004: Failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
2-0044 supply vdd not found, using dummy regulator
input: isl29023 light sensor as /devices/virtual/input/input1
isl29023 2-0044: driver version 1.0 enabled
snvs_rtc 20cc034.snvs-rtc-lp: can't get snvs-rtc clock
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video17
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video18
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video19
mxc_v4l2_output v4l2_out.35: V4L2 device registered as video20
2-000e supply vdd not found, using dummy regulator
2-000e supply vddio not found, using dummy regulator
mag3110 2-000e: check mag3110 chip ID
input: mag3110 as /devices/virtual/input/input2
mag3110 2-000e: mag3110 is probed
2-001c supply vdd not found, using dummy regulator
2-001c supply vddio not found, using dummy regulator
ata1: SATA link down (SStatus 0 SControl 300)
ahci-imx 2200000.sata: no device found, disabling link.
ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
input: mma845x as /devices/virtual/input/input3
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Warning: No contiguous memory is reserverd for gpu.!
Warning: Will use default value(134217728) for the reserved memory!
Galcore version 5.0.11.41671
mmc2: Problem setting current limit!
mmc2: new ultra high speed DDR50 SDHC card at address aaaa
mmcblk2: mmc2:aaaa SU08G 7.40 GiB
mmcblk2: p1 p2
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_vpu 2040000.vpu: VPU initialized
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a160100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] e5 67 1a 32 44 12 3e 71
platform caam_sm: [0008] 35 de 20 2e 43 ce ec 82
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] d4 b2 d2 cd de 16 e3 b1
platform caam_sm: [0008] 13 7c 1e af 4c a4 40 14
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 3d 4f 1d c9 83 84 b5 8a
platform caam_sm: [0008] 50 8e de 15 8e 02 00 8d
platform caam_sm: [0016] 67 cd 31 2d c6 9c 13 60
platform caam_sm: [0024] 35 2d b7 c2 10 76 36 e9
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] c4 4e d7 b6 3e 43 2f 66
platform caam_sm: [0008] 36 df f3 c9 1c b4 d5 28
platform caam_sm: [0016] 4b 48 f0 e6 04 2e 87 2c
platform caam_sm: [0024] 30 f4 10 8d c6 91 bd 77
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 9c 5f c6 a9 06 33 a5 a5
platform caam_sm: [0008] de 27 35 d8 15 e5 a1 4f
platform caam_sm: [0016] f7 e1 e8 d0 74 23 fd a8
platform caam_sm: [0024] 68 81 69 46 49 13 17 3e
platform caam_sm: [0032] 9c fc 15 f5 39 0a c6 3d
platform caam_sm: [0040] d7 00 d0 49 9a bb 3f c3
platform caam_sm: [0048] e4 ef 05 f9 e5 38 da f8
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 84 6e 68 1d 03 6b f8 3b
platform caam_sm: [0008] 09 da 7c 60 70 f4 df 65
platform caam_sm: [0016] 95 b5 48 9d 70 e4 47 ca
platform caam_sm: [0024] e9 1f 5a e5 f0 43 26 a7
platform caam_sm: [0032] a9 90 65 92 42 ab fd 46
platform caam_sm: [0040] fb 3d e9 13 5c 24 f1 e9
platform caam_sm: [0048] 8b ca b4 c1 10 23 9d 66
platform caam_sm: [0056] 85 68 14 30 47 ce 43 c0
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 57 a6 97 3f 43 96 cf 87
platform caam_sm: [0008] 1f 72 89 a6 a0 ad 0e 48
platform caam_sm: [0016] 7a ad 5c e4 6e 37 04 3d
platform caam_sm: [0024] e4 95 c9 09 aa c7 12 bb
platform caam_sm: [0032] 56 3c d7 dc 03 6b 2f e1
platform caam_sm: [0040] 16 a8 c2 c3 78 7a 95 ce
platform caam_sm: [0048] 05 75 fc d4 a6 84 be d3
platform caam_sm: [0056] c7 df 01 4f bc 17 fd 9d
platform caam_sm: [0064] 98 25 68 26 f6 9b 5c 99
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] fe a8 22 dd 34 d2 00 3e
platform caam_sm: [0008] 7e e8 32 93 59 a4 96 72
platform caam_sm: [0016] 47 9a dd 3e fe 2a 83 27
platform caam_sm: [0024] 92 05 b2 c8 cc 3e fe 64
platform caam_sm: [0032] 9b 6b 2d 47 bc 58 ca 1c
platform caam_sm: [0040] 8d c2 b4 94 81 b1 80 bf
platform caam_sm: [0048] 0e 59 38 50 47 61 09 f4
platform caam_sm: [0056] 22 c2 fa 92 56 92 df 2e
platform caam_sm: [0064] 62 84 43 56 69 3a 85 f1
platform caam_sm: [0072] c4 f4 f7 54 46 4c 0b ca
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] c8 bd 51 12 0f 8c 3c 9b
platform caam_sm: [0008] 94 ac 86 67 55 65 75 24
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 47 6b e3 e8 62 6f 89 8f
platform caam_sm: [0024] 7c dc 6f eb cc 73 30 1c
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
cs42xx8 1-0048: found device, revision 4
fsl-asrc 2034000.asrc: driver registered
snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
imx-cs42888 sound-cs42888.27: cs42888 <-> 2024000.esai mapping ok
imx-cs42888 sound-cs42888.27: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
imx-spdif sound-spdif.20: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
imx-audio-hdmi sound-hdmi.21: hdmi-hifi <-> hdmi_audio.3 mapping ok
imx-tuner-si476x sound-fm.33: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm.33 failed with error -22
VGEN2: disabling
SWBST: disabling
SW4: disabling
regulator-dummy: disabling
imx mcc test is registered.
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys.18 as /devices/soc0/gpio-keys.18/input/input4
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
ALSA device list:
#0: cs42888-audio
#1: imx-spdif
#2: imx-hdmi-soc
usb 1-1: new high-speed USB device number 2 using ci_hdrc
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk2p2): using internal journal
EXT3-fs (mmcblk2p2): recovery complete
EXT3-fs (mmcblk2p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 392K (809d9000 - 80a3b000)
usb 1-1.2: new low-speed USB device number 3 using ci_hdrc
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
random: init urandom read with 68 bits of entropy available
input: DELL DELL USB Laser Mouse as /devices/soc0/soc.0/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C063.0001/input/input5
hid-generic 0003:046D:C063.0001: input: USB HID v1.10 Mouse [DELL DELL USB Laser Mouse] on usb-ci_hdrc.0-1.2/input0
usb 1-1.3: new low-speed USB device number 4 using ci_hdrc
init: plymouth-upstart-bridge main process (177) terminated with status 1
init: plymouth-upstart-bridge main process ended, respawning
init: plymouth-upstart-bridge main process (187) terminated with status 1
init: plymouth-upstart-bridge main process (190) terminated with status 1
input: Dell Dell QuietKey Keyboard as /devices/soc0/soc.0/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2106.0002/input/input6
hid-generic 0003:413C:2106.0002: input: USB HID v1.10 Keyboard [Dell Dell QuietKey Keyboard] on usb-ci_hdrc.0-1.3/input0
init: ureadahead main process (180) terminated with status 5
init: mounted-proc main process (204) terminated with status 1
DBG sensor data is at 7f010190
* Starting Mount filesystems on boot [ OK ]
* Stopping Send an event to indicate plymouth is up [ OK ]
* Starting Signal sysvinit that the rootfs is mounted [ OK ]
* Starting Clean /tmp directory [ OK ]
* Starting Populate and link to /run filesystem [ OK ]
* Stopping Populate and link to /run filesystem [ OK ]
* Stopping Clean /tmp directory [ OK ]
* Stopping Track if upstart is running in a container [ OK ]
* Starting Initialize or finalize resolvconf [ OK ]
* Starting Signal sysvinit that virtual filesystems are mounted [ OK ]
* ERROR: v4l2 capture: slave not found!
* Starting Bridge udev events into upstart [ OK ]
* Starting Signal sysvinit that local filesystems are mounted [ OK ]
* Starting Signal sysvinit that remote filesystems are mounted [ OK ]
* Stopping Mount filesystems on boot [ OK ]
* Starting device node and kernel event manager [ OK ]
* Starting flush early job output to logs [ OK ]
* Starting load modules from /etc/modules [ OK ]
* Starting cold plug devices [ OK ]
* Starting log initial device creation [ OK ]
* Stopping flush early job output to logs [ OK ]
* Stopping load modules from /etc/modules [ OK ]
* Starting set console font [ OK ]
* Starting system logging daemon [ OK ]
* Stopping set console font [ OK ]
* Starting userspace bootsplash [ OK ]
* Stopping userspace bootsplash [ OK ]
* Starting Send an event to indicate plymouth is up [ OK ]
* Starting configure network device security [ OK ]
* Starting configure network device [ OK ]
* Starting Mount network filesystems [ OK ]
* Starting Failsafe Boot Delay [ OK ]
* Stopping Mount network filesystems [ OK ]
* Starting Bridge socket events into upstart [ OK ]
* Starting Bridge file events into upstart [ OK ]
* Stopping Failsafe Boot Delay [ OK ]
* Starting System V initialisation compatibility [ OK ]
* Stopping System V initialisation compatibility [ OK ]
* Starting System V runlevel compatibility [ OK ]
* Starting save kernel messages [ OK ]
* Starting regular background program processing daemon [ OK ]
* Stopping System V runlevel compatibility [ OK ]
I did compile for 4.1.15 kernel but I need to set (configure) proper board instead of Board: MX6Q-Sabreauto revA
I need to have: MX6QP-Sabreauto
Where and how to configure it?
How can I redirect display to HDMI?
U-Boot 2016.03 (Nov 03 2016 - 11:28:37 +0100)
CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 28C
Reset cause: POR
I2C: ready
DRAM: 2 GiB
NAND: 0 MiB
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
Now I got Linaro, 14.10 image booting.. but still get into HDMI display and it's Serial console from PC.
How can I enable and run it form within HDMI monitor?
Secondly I followed  section 3: Modify Rootfs and Install needed packages  even though network, sources.list, hostname are not configured accordingly.. I change it on host PC and those setting are not reflected...
U-Boot 2016.03 (Nov 04 2016 - 11:24:24 +0100)
CPU: Automotive temperature grade (-40C to 125C) at 31C
Reset cause: POR
I2C: ready
DRAM: 2 GiB
NAND: 0 MiB
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Normal Boot
reading boot.scr
reading zImage
6637656 bytes read in 328 ms (19.3 MiB/s)
48853 bytes read in 20 ms (2.3 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x654858 ]
Using Device Tree in place at 18000000, end 1800eed4
Starting kernel ...
Linux version 4.1.15 (r59400@Latitude) (gcc version 4.8.5 (Linaro GCC 4.8-2015.06) ) #1 SMP PREEMPT Fri Nov 4 11:53:43 CET 2016
Reserved memory: created CMA memory pool at 0x6a000000, size 320 MiB
Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
PERCPU: Embedded 12 pages/cpu @ee6fe000 s16960 r8192 d24000 u49152
Memory: 1737928K/2097152K available (8295K kernel code, 435K rwdata, 2892K rodata, 432K init, 450K bss, 31544K reserved, 327680K cma-reserved, 270336K highmem)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
.text : 0x80008000 - 0x80af51c8 (11189 kB)
.init : 0x80af6000 - 0x80b62000 ( 432 kB)
.data : 0x80b62000 - 0x80bcec40 ( 436 kB)
.bss : 0x80bd1000 - 0x80c41a5c ( 451 kB)
Additional per-CPU info printed with stalls.
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76470001
mxc_clocksource_init 3000000
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Setting up static identity map for 0x10008280 - 0x100082d8
Brought up 4 CPUs
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
imx6q-pinctrl 20e0000.iomuxc: no groups defined in /soc/aips-bus@02000000/iomuxc@020e0000/hdmicecgrp
imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-1: can't use DMA
i2c i2c-2: can't use DMA
Bluetooth: Core ver 2.20
CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.23)
bounce: pool size: 64 pages
backlight supply power not found, using dummy regulator
mxc_sdc_fb fb@0: registered mxc display driver ldb
mxc_sdc_fb fb@1: registered mxc display driver hdmi
mxc_sdc_fb fb@2: NO mxc display driver found!
mxc_sdc_fb fb@3: registered mxc display driver ldb
imx-sdma 20ec000.sdma: loaded firmware 3.3
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 298, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 299, base_baud = 5000000) is a IMX
brd: module loaded
loop: module loaded
scsi host0: ahci-imx
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 313
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
IR RC5(x/sz) protocol handler initialized
IR Sharp protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
mxc_v4l2_output v4l2_out: V4L2 device registered as video18
mxc_v4l2_output v4l2_out: V4L2 device registered as video19
mxc_v4l2_output v4l2_out: V4L2 device registered as video20
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
/soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
218c000.mlb supply reg_nvcc not found, using dummy regulator
mxc_mlb150 218c000.mlb: enalbe regulator
mxc_vpu 2040000.vpu_fsl: VPU initialized
imx6q-pinctrl 20e0000.iomuxc: unable to find group for node hdmicecgrp
mxc_hdmi_cec soc:hdmi_cec@00120000: can't get/select CEC pinctrl
mmc2: new ultra high speed SDR104 SDHC card at address 0007
mmcblk2: mmc2:0007 SD32G 28.9 GiB
mmcblk2: p1 p2
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
platform caam_sm: [0000] b1 20 7c 0a 8a 86 61 07
platform caam_sm: [0008] f0 19 01 46 38 76 bd 49
platform caam_sm: [0000] 2f 06 82 1f cc b0 35 1f
platform caam_sm: [0008] 72 03 b1 f3 aa e0 3e b0
platform caam_sm: [0000] 1b b3 ad 95 d0 24 81 9a
platform caam_sm: [0008] fd b9 b8 4c 55 17 92 c4
platform caam_sm: [0016] ae af b5 6a ea 59 01 4f
platform caam_sm: [0024] 1b be de e8 dd 5c 8b 10
platform caam_sm: [0000] cf f7 16 54 2e 7b 19 e0
platform caam_sm: [0008] fe 96 8c 8b 3e 1b b3 f0
platform caam_sm: [0016] 38 35 bc 80 67 35 ed 58
platform caam_sm: [0024] e1 dd 73 11 85 8b 10 1f
platform caam_sm: [0000] 7c 66 1b 86 2d 1c b7 2d
platform caam_sm: [0008] 20 1f bb eb b4 00 1c 56
platform caam_sm: [0016] 8f b7 46 a6 40 58 28 49
platform caam_sm: [0024] 55 a0 50 1c 58 1d 43 a9
platform caam_sm: [0032] 06 3c 86 13 da 7d c1 6a
platform caam_sm: [0040] 3b 09 77 ee 3a ee 3f e6
platform caam_sm: [0048] 7e be 58 92 f4 b9 1d 4a
platform caam_sm: [0000] 61 a7 fd 69 ac 06 3c 35
platform caam_sm: [0008] 55 aa 49 66 c1 d2 ee 49
platform caam_sm: [0016] 04 af 80 4a fe 33 92 ab
platform caam_sm: [0024] 9c a7 c3 82 25 53 80 63
platform caam_sm: [0032] 22 3e 89 9a e6 d8 a6 54
platform caam_sm: [0040] c6 e6 f7 34 b6 1f 2c 9e
platform caam_sm: [0048] 5e 96 89 5e a6 fc 7f 87
platform caam_sm: [0056] 20 5f 7a 16 11 3b e7 ce
platform caam_sm: [0000] 23 2c cb 1b 73 ab 7d 23
platform caam_sm: [0008] f4 b0 f7 92 b2 78 0d 4c
platform caam_sm: [0016] b7 ba 1e 4d 05 6d 31 f5
platform caam_sm: [0024] ce c9 fd 0a ce 39 eb 94
platform caam_sm: [0032] cb b1 33 41 b7 f7 6b 26
platform caam_sm: [0040] 44 80 d7 26 36 25 ad 73
platform caam_sm: [0048] 87 a0 51 29 82 7f 9c d8
platform caam_sm: [0056] 2f 75 98 5f b7 50 f3 db
platform caam_sm: [0064] b3 39 17 c7 c9 90 c8 26
platform caam_sm: [0000] 49 ff 5a d8 79 44 e7 67
platform caam_sm: [0008] 96 87 75 f6 5c 8a 2e df
platform caam_sm: [0016] ae cc a1 b6 4a 31 f6 e8
platform caam_sm: [0024] 8d fd ad 8b 07 f3 e8 b0
platform caam_sm: [0032] c0 58 18 9b ae 02 bb ce
platform caam_sm: [0040] 38 fb 44 db 04 67 1b c7
platform caam_sm: [0048] 2c 15 75 41 8d c1 77 cf
platform caam_sm: [0056] a1 68 de 68 2d cd 24 e7
platform caam_sm: [0064] d5 7e e3 22 eb 7a 21 9d
platform caam_sm: [0072] 63 67 cf 3b 32 19 e0 03
platform caam_sm: [0000] 95 c8 a2 bc ac 2e 8e d7
platform caam_sm: [0008] f7 cc fa 5b b6 a5 5b 4b
platform caam_sm: [0016] 5f 82 48 34 d8 cb 15 a9
platform caam_sm: [0024] b0 6c fe c8 ee 8e cd 21
imx-cs42888 sound-cs42888: cs42888 <-> 2024000.esai mapping ok
imx-cs42888 sound-cs42888: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
imx-tuner-si476x sound-fm: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm failed with error -22
imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
can-stby: supplied by can-en
flexcan 2094000.flexcan: device registered (reg_base=f0648000, irq=31)
dhd_module_init in
input: gpio-keys as /devices/soc0/gpio-keys/input/input4
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
can-stby: disabling
can-en: disabling
VGEN2: disabling
SWBST: disabling
SW4: disabling
ALSA device list:
#0: cs42888-audio
#1: imx-spdif
#2: imx-hdmi-soc
input: DELL DELL USB Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C063.0001/input/input5
input: Dell Dell QuietKey Keyboard as /devices/soc0/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2106.0002/input/input6
devtmpfs: mounted
Freeing unused kernel memory: 432K (80af6000 - 80b62000)
random: init urandom read with 34 bits of entropy available
init: plymouth-upstart-bridge main process (175) terminated with status 1
init: plymouth-upstart-bridge main process (185) terminated with status 1
init: plymouth-upstart-bridge main process (189) terminated with status 1
init: ureadahead main process (178) terminated with status 5
DBG sensor data is at 7f010188
* Starting Populate /dev filesystem [ OK ]
* Stopping Populate /dev filesystem [ OK ]
* Starting set console keymap [ OK ]
* Stopping set console keymap [ OK ]
* Starting D-Bus system message bus [ OK ]
* Starting SystemD login management service [ OK ]
* Starting bluetooth daemon [ OK ]
* Starting mDNS/DNS-SD daemon [ OK ]
* Starting Reload cups, upon starting avahi-daemon to make sure remote q[ OK ]are populated
* Starting Reload cups, upon starting avahi-daemon to make sure remote q[fail]are populated
* Setting up X socket directories... [ OK ]
Last login: Thu Jan 1 00:00:23 UTC 1970 on tty1
Welcome to Linaro 14.04 (GNU/Linux 4.1.15 armv7l)
* Documentation: https://wiki.linaro.org/
root@linaro-alip:~#
First of all, thanks for this amazing post. Helped a lot. I have used the Linaro LXDE rootfs(partly because the ubuntu core link didnt work). Now apart from few hiccups I faced here and there in the process, I am able to boot the hardware and login from the serial console to the shell. But on the HDMI display I am shown a login window. I tried typing username 'root' and 'linaro' without any password(since I had removed the password from the root and linaro user as per the process above) and I am still stuck on the same window. I am unable to move past the login window and enter the GUI. Did anyone else face this. Please advise if I have missed something. Or I could just remove this login window manager and install another.
What imx board/chip do you use?
Hi Erik,
I am using iMX6 QP Sabre Board. Everything is working fine just that I am unable to login through the gui login manager.
Also I am facing another issue today. I installed gstreamer-imx and its plugins but I am getting an error with the audio codec plugin which is not working. When I run 'gst-inspect-1.0 -b' I get.
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8983): GStreamer-WARNING **: Failed to load plugin '/usr/lib/arm-linux-gnueabihf/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/gstreamer-1.0/libgstimxaudio.so': lib_mp3_enc_arm12_elinux.so.2: cannot open shared object file: No such file or directory
Blacklisted files:
libgstimxaudio.so
Total count: 1 blacklisted file
I dont understand why only audio plugin got blacklisted when I installed both fsl video and audio codec together. I have followed the links from this post. Also the error that it shows that it cannot open shared file, I checked the directory and the file is inside it.
Hi Erik
Any idea how to boot into desktop rather than to the login window I am getting. When I execute startx from serial console, it starts desktop environment on the screen. But by default, startlxde is getting executed and that takes me to the login page from where I cant login with any user. By default I want startx to load. (later I would like to just boot into just one gui application)
Hi Jaffin,
I'm in  pretty much the same situation: have you chance to resolve it?
Thank you.
Hi Erik,
   If you have also used Linaro LXDE then the default display manager is lxdm which is upstarted from /etc/init.d/. Lxdm uses /etc/lxdm/lxdm.conf for its configuration. I changed the default session to 'startx' to avoid the login page. Just a workaround for now.
More info here : LXDM - ArchWiki
Understand but on my side after install I can't run 'startx' command (command not found). I have my console on PC host side where I'm connected to the target via UART. On target itself I got Login screen which I can't go thru. I did changes as you suggested but no success.
Erik,
Maybe you have not installed xorg and xinit. Try that.
Finally I got login: After I got LXDE login screen which I needed to switch off the GUI and start in console mode via CTRL+ALT+F1 then I set passwd for root again and then switch back via CTRL+ALT+F7 and I did login as root.
Have you fixed gstreamer-imx somehow?
Nice. Do let me know if you figure out how to remove the login page completely from 'startlxde'.
I can login as root with no login screen automatically. this works for me
/etc/lxdm$ lxdm.conf
[base]
## uncomment and set autologin username to enable autologin
autologin=root
## uncomment and set timeout to enable timeout autologin,
## the value should >=5
# timeout=10
## default session or desktop used when no systemwide config
session=/usr/bin/startlxde
## uncomment and set to set numlock on your keyboard
# numlock=0
## set this if you don't want to put xauth file at ~/.Xauthority
# xauth_path=/tmp
## greeter used to welcome the user
greeter=/usr/lib/lxdm/lxdm-greeter-gtk
[server]
## arg used to start xserver, not fully function
# arg=/usr/bin/X -background vt1
[display]
## gtk theme used by greeter
gtk_theme=Clearlooks
## background of the greeter
bg=/usr/share/backgrounds/default.png
## if show bottom pane
bottom_pane=1
## if show language select control
lang=1
## if show keyboard layout select control
keyboard=0
## the theme of greeter
theme=Industrial
[input]
[userlist]
## if disable the user list control at greeter
disable=0
## whitelist user
white=
## blacklist user
black=
Cool. I had changed it to 'linaro' user which also doesnt have a password but still showed me login page. Anyways will try 'root.' But I was getting launched into desktop directly already so dont know if I should bother. Anyways thank for the info.
What error are you getting. I am still having the error messages I posted but my audio is working nonetheless so I stopped troubleshooting further on it until someone gives me an idea what should be done.
I connected USB disk and USB mouse to the USB Host port, but the devices were not able to be detected.
I can see following message during kernel booting up:
usb_otg_vbus: disabling
What could be the possible reasons?
Thanks!
Is there anyway to rotate LCD from landscape mode to portrait mode with ubuntu Linaro LXDE rootfs? Thanks!
Dears,
I'd like to continue with adding GPU HW Acceleration for X11 per instruction with that section and working within gpu_pack directory instructions say:
  1. # cd kernel-modu*
  2. # make
  3. Switch to gpu-core x11 backend:
  4. # backend=x11
Where kernel-modu* is coming from?
How kernel-modu* to create from?
I encounter a uboot compiler issue, when I try to build the wandboard_dl_defconfig.
Anybody else encounter this? share your fix.
LD examples/standalone/hello_world
OBJCOPY examples/standalone/hello_world.srec
OBJCOPY examples/standalone/hello_world.bin
LDS u-boot.lds
LD u-boot
arch/arm/imx-common/built-in.o: In function `print_cpuinfo':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/imx-common/cpu.c:199: undefined reference to `uclass_get_device'
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/imx-common/cpu.c:201: undefined reference to `thermal_get_temp'
arch/arm/imx-common/built-in.o: In function `arch_preboot_os':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/arch/arm/imx-common/cpu.c:270: undefined reference to `ldo_mode_set'
drivers/built-in.o: In function `read_cpu_temperature':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:43: undefined reference to `dev_get_platdata'
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:45: undefined reference to `dev_get_priv'
drivers/built-in.o: In function `imx_thermal_probe':
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:226: undefined reference to `dev_get_platdata'
/home/lucid/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga/drivers/thermal/imx_thermal.c:227: undefined reference to `dev_get_priv'
/home/lucid/toolchain/gcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: BFD (GNU Binutils) Linaro 2014.11-3-git 2.24.0.20141017 assertion fail /home/tcwg-buildslave/workspace/tcwg-make-release/label/tcwg-x86_64/target/arm-linux-gnueabihf/snapshots/binutils-gdb.git~linaro_binutils-2_24-branch@a93e252ee5250dba831e54f98336b40c7210dac7/bfd/elf32-arm.c:7710
/home/lucid/toolchain/gcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: error: required section '.rel.plt' not found in the linker script
/home/lucid/toolchain/gcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: final link failed: Invalid operation
make: *** [u-boot] Error 1
lucid@ubuntu:~/imx6dl/uboot-imx-rel_imx_3.14.52_1.1.0_ga$
Thanks!
WF
I installed ubuntu Linaro LXDE desktop but the touch panel doesn't work. I confirmed the touch panel driver is ok. It generates input events when I cat /dev/input/event0 and touch the panel. But the ubuntu desktop does not have response. Anyone has advice on it? Thanks!
It seems now no way to build by this thread. I changed the gcc toolchain, still not compilable. But I can build one month ago, there should be some commits blocked the build.
Does someone else encounter the same issue as me currently?
I am using above steps to get ubuntu rootfs running on imx6q-sabrsd board. I am not able to build xserver-xorg-video-imx-viv-5.0.11.p7.4.
I am getting below error with linaro rootfs:
gcc -DCOMMIT="`git log -n 1 --format=%H``git diff-index --quiet HEAD || echo '-dirty'`" -DFIX_NO_MI_BACKINGSTORE -fvisibility=hidden -fPIC -DPIc
fatal: Not a git repository (or any of the parent directories): .git
gcc -shared -fPIC -o vivante_drv.so vivante_gal/vivante_gal_blit.o vivante_gal/vivante_gal_gpu.o vivante_gal/vivante_gal_surface.o vivante_fbde
make: Leaving directory `/root/gpu/xserver-xorg-video-imx-viv-5.0.11.p7.4/EXA/src'
make: *** DRI_1.10.4/src/: No such file or directory. Stop.
has anybody able to solve this issue?? Also has anybody tried brnigup with ubuntu-core rootfs? Link for ubuntu-core rootfs seems dead.
Prathamesh
Hi Pratham,
Do you used any patches?  I can not boot into rootfs on my mx6dl customer board, I only can start uboot and kernel. Kenerl will stop at waiting "Waiting for root device /dev/mmcblk0p2...
which version of toolchain are you used?
Thanks!
Wenming
Hi feng,
the issue "Waiting for root device /dev/mmcblk0p2.." , seems to be related to sd card initialization failure, once kernel comes up.
Try to boot from eMMc and see if you still get same issue.
I am using toolchain mentioned above in this post.
Prathamesh
Hi erikraynolds‌ ,
I have the same question as yours. There seems no folder named kernel-modu*.
Have you solved the problem now?
Thanks!
Kane
Hi Pratham,
I got the same issue with you. Do you get it worked?
Thanks!
Wenming
Hi, Prathamesh
You can run the command: git init as the the doc said to have a try.
You can open the ubuntu-core link in the Explorer and use another.
E.g in the link: Index of /ubuntu-core/vivid/daily-preinstalled/current
You may select vivid-preinstalled-core-armhf.tar.gz .
Kane
Hi Kane,
I export the BUILD_HARD_VFP=1 and XSERVER_GREATER_THAN_13=1 it will not make for the DRI_1.10.4/src/,
but I still got
fatal: bad default revision 'HEAD'
fatal: ambiguous argument 'HEAD': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
fsl_pixmap_ext.c:31:33: fatal error: X11/extensions/Xext.h: No such file or directory
#include <X11/extensions/Xext.h>
Does me missed some installed package?
BTW, as your mentioned vivid-preinstalled-core-armhf.tar.gz  are you tried and success to bring up the desktop for your imx6 board?
thanks!
Wenming
Hi Wenming,
Which rootfs did you choose? I think you may not choose the Linaro LXDE rootfs(E.g. linaro-trusty-alip-20141024-684.tar.gz) as mentioned in the doc above.
The  vivid-preinstalled-core-armhf.tar.gz I mentioned didn't have a GUI desktop, it just have a console terminal. And it seems that did not support the commands like apt-get.
But I also tried the rootfs linaro-trusty-alip-20141024-684.tar.gz as same as the doc. And I can succeed to bring up the desktop in i.MX6Q SABRE SD, but there's some issues about how to find the GPU Vivante and play tutorials.
Besides, I did not find the folder named kernel-modu* as the doc said, have you?
  1. # ./fastbuild.sh  BUILD_HARD_VFP=1 XSERVER_GREATER_THAN_13=1
  2. # cd..
  3.
  4. # cd kernel-modu*
  5. # make
  6. Switch to gpu-core x11 backend:
  7. # backend=x11
All the Best
Kane
Hi Wenming,
You may try command: apt-get install libxtst-dev to overcome the fatal error: X11/extensions/Xext.h: No such file or directory.
All the Best
Kane
Hi @Bio_TICFSL,
Thanks for your excellent doc!!
There's two questions I have get now.
1. I did not find the folder named kernel-modu* as the doc said, where is it?
  2. # cd..
  3.
  5. # make
  7. # backend=x11
2. And when I use the rootfs named linaro-jessie-alip-20160428-22.tar.gz(debian based ubuntu 16.04), I can not successfully login to the console:
[FAILED] Failed to start Login Service.
See 'systemctl status systemd-logind.service' for details.
[ OK ] Started Permit User Sessions.
[FAILED] Failed to start LSB: Load kernel mo...eeded to enable cpufreq scaling.
See 'systemctl status loadcpufreq.service' for details.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started LSB: network benchmark.
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started Initialize hardware monitoring sensors.
[ TIME ] Timed out waiting for device dev-ttymxc0.device.
[DEPEND] Dependency failed for Serial Getty on ttymxc0.
[FAILED] Failed to start Network Manager.
See 'systemctl status NetworkManager.service' for details.
So how to login to the console, any ideas?
All the Best
Kane
Hi Kane,
I am used the linaro-trusty-alip-20141024-684.tar.gz , I can not start the desktop for my imx6dl customer board, I used an OSD-WVGA lcd to connect with ipu.di0/fb0. for the ubuntu core version I can not boot into console.
about the kernel-modu* there is a link in the note:ventana/ubuntu – Gateworks  section 2, what I do just ignore the cd kernel-modu* make, I just cd /usr/lib to do the ln -sf . the fastbuild.sh only build the vivante_drv.so, the vivante_dri.so is copy from gpu_core. I can not find any folder name kernel-modu* maybe a mistake.
BTW,
what is you video= line,
Thanks!
Wenming
Hi Wenming,
I ignore the cd kernel-modu* too.
My board is i.mx6q sabre sd and I use a LVDS display. Have you try the toolchain gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz as the doc discribed?
You can search "Kane Jiang" in the Skype for Business.
All the Best
Kane Jiang
I am using imx6q-sabresd board. I am following steps from Installing Ubuntu Rootfs on NXP i.MX6 boards
My kernel version is 3.14.52 and i am using ubuntu Rootfs 14.04.
My Xorg xserver version is 1.15.1.
I am observing that if i enable PCI bus support in the kernel, then i am not able to use x11 gpu hardware acceleration(glxgears and es2gears give segmentation faults).
But if i disable PCI support , i could use x11 gpu hardware acceleration with above mentioned versions of xserver.
What role is PCI drivers playing in x11 hardware acceleration? How to get x11 acceleration working with PCI bus support enabled.
Has anyone faced similar issue? Is there any fix for this or patches for pci or drm drivers??
Thanks for this great post ! My goal is to run an Ubuntu 14.04 or higher on my IMX6Q SABRE SD board from the mmc card. I am following the post.
The following link is not valid any more:
https://releases.linaro.org/14.09/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.9-2...
I replace it by the following one:
https://releases.linaro.org/archive/14.09/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz
But it does not work, I get the following strange error: (same error described by wenming feng)
/bin/sh: 1: /home/guillaume/gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux/bin/arm-linux-gnueabihf-gcc: not found
If I select this toolchain, I can compile:
gcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx
But I am generating an Image file and NOT a zImage file. And u-boot does not take it (bad linux arm zimage magic error at u boot runtime). It seems that it exists uImage, Image and zImage. Image would correspond to a 64bit image if I understand correctly.
Question 1: Which toolchain or option I have to use/set to generate a zImage ? (and not an Image)
Question 2: Would it be possible to update this post with up to date links ?
Question 3: Is there somewhere an already builded .sdcard for SABRE SD with everything on it (u-boot, kernel, dtb, ubuntu 14.04 or higher ..) ?
Guillaume HUGUES
Basically, I found the solution. To generate a zImage instead of Image, you have to enter make menuconfig and select this option
Gzip is not the defaut choice.
Now I have a ubuntu 14.04 running on my I.MX6Q SABRESD board. Thanks for this essential post !
%3CLINGO-SUB%20id%3D%22lingo-sub-1108497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%81%AF%E3%80%81i.Mx6x%20NXP%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%20Ubuntu%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E1.%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81uboot%E3%80%81dtb%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E2.%20Ubuntu%20%E3%82%B3%E3%82%A2%E3%80%81Lubuntu%20%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%20debootstrap%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%8B%AC%E8%87%AA%E3%81%AE%20Ubuntu%20rootfs%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E3.%20rootfs%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E4.%20SD%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E5.%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%ABUbuntu%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E6.%20GPU%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22Subtitulo%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2014pt%3B%20color%3A%20%23e23d39%3B%22%3E1%3A%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81uboot%E3%80%81dtb%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BNXP%20HW%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206QuadPlus%20SABRE-SD%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8A%E3%82%88%E3%81%B3%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206Quad%20SABRE-SD%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8A%E3%82%88%E3%81%B3%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206DualLite%20SABRE-SD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206Quad%20SABRE-AI%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206DualLite%20SABRE-AI%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206SoloX%20SABRE-SD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ei.MX%206SoloX%20SABRE-AI%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%83%9B%E3%82%B9%E3%83%88%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2014.04%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22python%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594434795498978%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22565_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594434795498978%22%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20sudo%20apt-get%20install%20gparted%20git%20build-essential%20libncurses5%20wget%20u-boot-tools%20zlib1g-dev%20ncurses-dev%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Ecmake%20libc-dev-armhf-cross%20pkg-config-arm-linux-gnueabihf%20build-essential%20checkinstall%20cmake%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Epkg-config%20lzop%20libc6%20libstdc%2B%2B6%20debootstrap%20qemu-user-static%20binfmt-support%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23606060%3B%20line-height%3A%2026px%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594434795251957%22%20data-renderedposition%3D%22662.77783203125_50.000003814697266_1158_156%22%20jivemacro_uid%3D%22_14594434795251957%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20wget%20-c%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20tar%20xf%20gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%A4%89%E6%95%B0%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20target%3Dmx6q%20(e.g.%20processor%3A%20mx6sx%2C%20mx6d%2C%20mx6dl%2Cetc)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20board%3Dsabresd%EF%BC%88%E4%BE%8B%EF%BC%9Asabresd%E3%80%81sabreauto%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20ARCH%3Darm%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20export%20CROSS_COMPILE%3D..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20unset%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%20LDFLAGS%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Eu-boot%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%20uboot%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%20imx_3.14.52%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594434795058554%20jive_text_macro%22%20data-renderedposition%3D%22895.0000610351562_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_14594434795058554%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20wget%20%E2%80%93c%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%2Fsnapshot%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Fuboot-imx.git%2Fsnapshot%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20tar%20-xf%20uboot-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20uboot-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20%24targetboard_config%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20e.g.%20mx6qsabresd_config%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%81DTS%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594434794835555%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221029.4444580078125_50.000003814697266_1158_141%22%20jivemacro_uid%3D%22_14594434794835555%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20wget%20%E2%80%93c%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fsnapshot%2Flinux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fsnapshot%2Flinux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20tar%20xf%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20imx_v7_defconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20menuconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20make%20-j4%20zImage%20modules%20dtbs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%94%BB%E5%83%8F%E3%82%92%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594434794499495%20jive_text_macro%22%20data-renderedposition%3D%221196.1112060546875_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14594434794499495%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20uboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fu-boot.imx%20binary%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20-v%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fboot%2FzImagebinary%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20-v%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fboot%2Fdts%2Fi%24target-%24board.dtb%20binary%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E6%BA%96%E5%82%99%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81rootfs%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20color%3A%20%23e23d39%3B%22%3E2%EF%BC%9AUbuntu%E3%82%B3%E3%82%A2%E3%80%81Lubuntu%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AFdebootstrap%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%8B%AC%E8%87%AA%E3%81%AEUbuntu%20rootfs%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EInstalling%20ubuntu%20core%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435070879416%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221363.1944580078125_50.000003814697266_1158_234%22%20jivemacro_uid%3D%22_14594435070879416%22%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3Ecd%20~%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20mkdir%20%E2%80%93p%20core%20%2Fmedia%2Frootfs%20%2Fmedia%2Fkernel%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20wget%20%E2%80%93c%20%3CA%20href%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Freleases%2F14.04%2Frelease%2Fubuntu-core-14.04.4-core-armhf.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Freleases%2F14.04%2Frelease%2Fubuntu-core-14.04.4-core-armhf.tar.gz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20tar%20%E2%80%93xf%20ubuntu-core-14.04.4-core-armhf.tar.gz%20%E2%80%93C%20core%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20-vr%20core%2F*%20%2Fmedia%2Frootfs%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20modules_install%20firmware_install%20INSTALL_MOD_PATH%3D%2Fmedia%2Frootfs%2F%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%20headers_install%20INSTALL_HDR_PATH%3D%2Fmedia%2Frootfs%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22margin-left%3A%2045pt%3B%20text-indent%3A%20-45pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81ubuntu%20rootfs%E3%81%8C%2Fmedia%2Frootfs%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E3%83%91%E3%83%BC%E3%83%883%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EInstalling%20ubuntu%20Linaro%20LXDE%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435070643311%20jive_text_macro%22%20data-renderedposition%3D%221675.6251220703125_50.000003814697266_1158_218%22%20jivemacro_uid%3D%22_14594435070643311%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mkdir%20%E2%80%93p%20core%20%2Fmedia%2Frootfs%20%2Fmedia%2Fkernel%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.10%2Fubuntu%2Ftrusty-images%2Falip%2Flinaro-trusty-alip-20141024-684.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.10%2Fubuntu%2Ftrusty-images%2Falip%2Flinaro-trusty-alip-20141024-684.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2F14.10%2Fubuntu%2Ftrusty-images%2Falip%2Flinaro-trusty-alip-20141024-684.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20tar%20-xf%20linaro-trusty-alip-20141024-684.tar.gz%20%E2%80%93C%20core%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mv%20core%2Fbinary%2F*%20core%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20rm%20%E2%80%93rf%20core%2Fbinary%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20cp%20-vr%20core%2F*%20%2Fmedia%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20make%20modules_install%20firmware_install%20INSTALL_MOD_PATH%3D%2Fmedia%2Frootfs%2F%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20make%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%20headers_install%20INSTALL_HDR_PATH%3D%2Fmedia%2Frootfs%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22white-space%3A%20pre%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81ubuntu%20rootfs%E3%81%8C%2Fmedia%2Frootfs%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22white-space%3A%20pre%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E3%83%91%E3%83%BC%E3%83%883%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200%200%201.0pt%200%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3Edebootstrap%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435070387076%22%20data-renderedposition%3D%221971.3890380859375_50.000003814697266_1158_124%22%20jivemacro_uid%3D%22_14594435070387076%22%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20target%3Drootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20distro%3Dtrusty%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%24%20sudo%20debootstrap%20--arch%3Darmhf%20--foreign%20--include%3Dubuntu-keyring%2Capt-transport-https%2Cca-certificates%2Copenssl%20%24distro%20%22%24target%22%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fports.ubuntu.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%2Fusr%2Fbin%2Fqemu-arm-static%20%24target%2Fusr%2Fbin%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2026pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cp%20%2Fetc%2Fresolv.conf%20%24target%2Fetc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AEUbuntu%20rootfs%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81chroot%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E7%AC%AC2%E6%AE%B5%E9%9A%8E%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22java%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435069697394%20jive_text_macro%22%20data-renderedposition%3D%222121.388916015625_50.000003814697266_1158_707%22%20jivemacro_uid%3D%22_14594435069697394%22%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20chroot%20%24target%20%2F%2F%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7chroot%E7%92%B0%E5%A2%83%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20distro%3Dtrusty%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20export%20LC_ALL%3DC%20LANGUAGE%3DC%20LANG%3DC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20%2Fdebootstrap%2Fdebootstrap%20--second-stage%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Esources.list%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E7%B7%A8%E9%9B%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20cat%20%26lt%3B%3CEOT%3E%20%2Fetc%2Fapt%2Fsources.list%3C%2FEOT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20%24distro%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20%24distro-updates%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20%24distro-security%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3EEOT%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-key%20adv%20--recv-keys%20--keyserver%20keyserver.ubuntu.com%2040976EAF437D05B5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-key%20adv%20--recv-keys%20--keyserver%20keyserver.ubuntu.com%203B4FE6ACC0B21F32%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-get%20update%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt%20-y%20-f%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-get%20upgrade%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20apt-get%20install%20nano%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AA%E3%81%97%E3%81%A7%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81passwd%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20passwd%20root%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20adduser%20%3CMYUSER%3E%3C%2FMYUSER%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eusermod%20-a%20-G%20tty%20myuser%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20usermod%20-a%20-G%20dialout%2C%20adm%2C%20sudo%2C%20dip%2C%20plugdev%20myuser%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20visudo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A1%8C%E3%81%AE%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eroot%20ALL%3D(ALL%3AALL)%20ALL%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%E3%81%AB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%3CMYUSER%3E%20ALL%3D(ALL)%20ALL%3C%2FMYUSER%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Erootfs%E3%81%8C%E6%BA%96%E5%82%99%E3%81%A7%E3%81%8D%E3%81%9F%E3%82%89%E3%80%81chroot%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20exit%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20rm%20%24target%2Fetc%2Fresolv.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20rm%20%24target%2Fusr%2Fbin%2Fqemu-arm-static%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20mv%20rootfs%2F*%20%2Fmedia%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20cd%20linux-2.6-imx-rel_imx_3.14.52_1.1.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20modules_install%20firmware_install%20INSTALL_MOD_PATH%3D%2Fmedia%2Frootfs%2F%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%24%20sudo%20make%20ARCH%3Darm%20CROSS_COMPILE%3D..%2F..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-%20headers_install%20INSTALL_HDR_PATH%3D%2Fmedia%2Frootfs%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding-left%3A%2011pt%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7Ubuntu%E3%81%AErootfs%E3%81%8C%2Fmedia%2Froot%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E3%EF%BC%9ARootfs%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Esources.list%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435642761323%22%20data-renderedposition%3D%222931.388916015625_50.000003814697266_1158_98%22%20jivemacro_uid%3D%22_14594435642761323%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20%2Fmedia%2Frootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20cat%20%26lt%3B%3CEOT%3E%20etc%2Fapt%2Fsources.list%3C%2FEOT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%22%3Edeb%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%22%3E%20trusty%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20trusty-updates%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%3Edeb%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fports.ubuntu.com%252Fubuntu-ports%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2F%3C%2FA%3E%3CSPAN%3E%20trusty-security%20main%20restricted%20universe%20multiverse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3EEOT%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81%E6%97%A2%E5%AD%98%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435642499160%22%20data-renderedposition%3D%223054.722412109375_50.000003814697266_1158_78%22%20jivemacro_uid%3D%22_14594435642499160%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Fnetwork%2Finterfaces%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eauto%20lo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eiface%20lo%20inet%20loopback%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eauto%20eth0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eiface%20eth0%20inet%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20%23303030%3B%22%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22background%3A%20white%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABttymxc0%E5%87%BA%E5%8A%9B%E7%94%A8%E3%81%AB%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9C%AB%E5%B0%BE%E3%81%8B%E3%82%89%E8%A1%8C%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%A1%8C%E3%82%92%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_1459443564220284%20jive_text_macro%22%20data-renderedposition%3D%223158.0556640625_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_1459443564220284%22%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435641951566%20jive_text_macro%22%20data-renderedposition%3D%223173.611328125_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594435641951566%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Finit%2Ftty1.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20line-through%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eexec%20%2Fsbin%2Fgetty%20-8%2038400%20tty1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eexec%20%2Fsbin%2Fgetty%20-L%20115200%20ttymxc0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435641679774%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223245.83349609375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594435641679774%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Fhostname%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%90%8D%E5%89%8D%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%EF%BC%9Aimx6Q%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_1459443564136564%22%20data-renderedposition%3D%223302.500244140625_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_1459443564136564%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20%2Fetc%2Frc.local%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%81%93%E3%82%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eif%20%5B%20%60date%20%2B%22%25Y%22%60%20-eq%20%221970%22%20%5D%3B%20then%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Edate%20--set%3D%222016-04-01%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Efi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eexit%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435641048700%20jive_text_macro%22%20data-renderedposition%3D%223411.38916015625_50.000003814697266_1158_124%22%20jivemacro_uid%3D%22_14594435641048700%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%EF%BC%88Linaro%20rootfs%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81root%E3%81%A8linaro%E3%81%AE%E8%A1%8C%E3%81%8B%E3%82%89x%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20etc%2Fpasswd%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%3Ax%3A0%3A0%3Aroot%3A%2Froot%3A%2Fbin%2Fbash%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Elinaro%3Ax%3A0%3A0..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%81%9D%E3%82%8C%E3%81%8B%E3%82%89%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%3A%3A0%3A0%3Aroot%3A%2Froot%3A%2Fbin%2Fbash%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Elinaro%3A%3A%3A0%3A..%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20%23303030%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22background%3A%20white%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81SD%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background%3A%20white%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E4%EF%BC%9AmicroSD%2FSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%AF%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%E3%81%A7DISK%3D%2Fdev%2Fsdg%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%81%AB%E3%81%AFcat%20%2Fproc%2Fpartitions%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435807757639%22%20data-renderedposition%3D%223638.0556640625_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594435807757639%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20export%20DISK%3D%2Fdev%2Fsdg%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3EmicroSD%2FSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%B6%88%E5%8E%BB%3C%2FSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435807475109%20jive_text_macro%22%20data-renderedposition%3D%223695.83349609375_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594435807475109%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20dd%20if%3D%2Fdev%2Fzero%20of%3D%24%7BDISK%7D%20bs%3D1M%20count%3D10%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594435807202965%22%20data-renderedposition%3D%223736.944580078125_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594435807202965%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20binary%2F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20dd%20if%3Du-boot.imx%20of%3D%24%7BDISK%7D%20bs%3D512%20seek%3D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sync%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435806876462%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223809.166748046875_50.000003814697266_1158_379%22%20jivemacro_uid%3D%22_14594435806876462%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20fdisk%20%24%7BDISK%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%EF%BC%9A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ed%20%2F%2F%2F%20%E7%8F%BE%E5%9C%A8SD%E4%B8%8A%E3%81%AB%E3%81%82%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3En%20%2F%2F%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3Ep%20%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E1%20%2F%2F%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E7%95%AA%E5%8F%B7%201%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E2048%20%2F%2Fdefault%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%2B1G%20%2F%2F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3En%20%2F%2F%202D%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EP%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E2%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E1%20%2F%2F%20firts%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EB%20%2F%2F%20FAT32%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EW%20%2F%2F%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20mkfs.vfat%20%24%7BDISK%7D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%24%20sudo%20mkfs.ext3%26nbsp%3B%24%7BDISK%7D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eext3%20SD%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%2Fmedia%2Frootfs%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594435806522942%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224238.4375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594435806522942%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mount%20%24%7BDISK1%7D%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mount%20%24%7BDISK%7D2%20%2Fmedia%2Frootfs_target%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3ESD%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435806243344%20jive_text_macro%22%20data-renderedposition%3D%224295.1044921875_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14594435806243344%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20binary%2F%20i%24target-%24board.dtb%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20cp%20%E2%80%93v%20binary%2FzImage%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20mv%20%2Fmedia%2Frootfs%2F*%20%2Fmedia%2Frootfs_target%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3ESD%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435805956657%20jive_text_macro%22%20data-renderedposition%3D%224382.88232421875_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594435805956657%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sync%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20umount%20%2Fmedia%2Fkernel_target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20umount%20%2Fmedia%2Frootfs_target%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22padding%3A%200%200%200%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%20root%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594435805666148%20jive_text_macro%22%20data-renderedposition%3D%224455.1044921875_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594435805666148%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eroot%40imx6QSabreSD%3A~%23%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20font-size%3A%2018.6667px%3B%22%3E5%EF%BC%9AUbuntu%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20UID%E3%81%A7sudo%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%AD%E3%82%B0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%A6root%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594437023562434%22%20data-renderedposition%3D%224547.32666015625_50.000003814697266_1158_78%22%20jivemacro_uid%3D%22_14594437023562434%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eimx6Q%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%20root%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EUbuntu%2014.04.4%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9DLTS%EF%BC%88GNU%2FLinux%203.14.52%20armv7l%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20chown%20root%3Aroot%20%2Fusr%2Fbin%2Fsudo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20chmod%204755%20%2Fusr%2Fbin%2Fsudo%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20exit%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CUSER%3E%20%E3%81%BE%E3%81%9F%E3%81%AF%20root%20%23%20%E3%81%A7%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E3%80%82%3C%2FUSER%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1459443738624799%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224650.66015625_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_1459443738624799%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20update%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20%E2%80%93f%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20locales%20dialog%20wget%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20dpkg-reconfigure%20locales%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20upgrade%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%E2%80%93%20%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BE%BF%E5%88%A9%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20openssh-server%20can-utils%20usbutils%20build-essential%20automake%20autoconf%20libtool%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EBSP%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%EF%BC%88EULA%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594437778399621%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224785.1044921875_50.000003814697266_1158_809%22%20jivemacro_uid%3D%22_14594437778399621%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20%2Fhome%2Fuser%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mkdir%20%E2%80%93p%20vpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20vpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-5.3.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Ffirmware-imx-5.3.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Ffirmware-imx-5.3.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-vpu-5.4.32.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-vpu-5.4.32.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-vpu-5.4.32.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Flibfslcodec-4.0.8.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Flibfslcodec-4.0.8.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Flibfslcodec-4.0.8.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-lib-5.1.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-lib-5.1.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-lib-5.1.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20chmod%20%2Bx%20*%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20.%2Ffirmware-imx-5.3.bin--auto-accept%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20mkdir%20%E2%80%93p%20%2Flib%2Ffirmware%2Fvpu%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cp%20-ravf%20firmware-imx-5.3%2Ffirmware%2F*%20%2Flib%2Ffirmware%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20.%2Fimx-vpu-5.4.32.bin%20--auto-accept%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cd%20imx-vpu-*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20make%20PLATFORM%3DIMX6Q%20all%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20make%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20tar%20-xf%20imx-lib-5.1.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cd%26nbsp%3B%20imx-lib-5.1%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20make%20-j1%20PLATFORM%3D%22IMX6Q%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20make%20PLATFORM%3D%22IMX6Q%22%20install%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Flibfslcodec-4.0.8%20--auto-accept%20%E2%80%93force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20libfslcodec-*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fautogent.sh%20--prefix%3D%2Fusr%20--enable-fhw%20--enable-vpu%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20make%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20make%20install%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mv%20%2Fusr%2Flib%2Fimx-mm%2Fvideo-codec%2F*%20%2Fusr%2Flib%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mv%20%2Fusr%2Flib%2Fimx-mm%2Faudio-codec%2F*%20%2Fusr%2Flib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%E2%80%93rf%20%2Fusr%2Flib%2Fimx-mm%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20mkdir%20%E2%80%93p%20gpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fimx-gpu-viv-5.0.11.p7.4-hfp.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-gpu-viv-5.0.11.p7.4-hfp.bin%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fimx-gpu-viv-5.0.11.p7.4-hfp.bin%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20chmod%20%2Bx%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fimx-gpu-viv-5.0.11.p7.4-hfp%20%E2%80%93-auto-accept%20-%E2%80%93force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20imx-gpu*%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20g2d%2Fusr%2Finclude%2F*%20%2Fusr%2Finclude%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-d%20g2d%2Fusr%2Flib%2F*%20%2Fusr%2Flib%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-Pr%20gpu-core%2Fusr%2F*%20%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20class%3D%22c%22%20style%3D%22color%3A%20%23999988%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CEM%3E%23%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%9A%E3%83%87%E3%83%A2%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-r%20gpu-demos%2Fopt%20%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20class%3D%22c%22%20style%3D%22color%3A%20%23999988%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CEM%3E%23%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%9AGPU%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20-axr%20gpu-tools%2Fgmem-info%2Fusr%2Fbin%2F*%20%2Fusr%2Fbin%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Egstreamer-imx%E3%80%81IPU%E3%80%81VPU%E3%80%81GPU%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594438185374207%20jive_text_macro%22%20data-renderedposition%3D%225619.548828125_50.000003814697266_1158_140%22%20jivemacro_uid%3D%22_14594438185374207%22%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%83%93%E3%83%AB%E3%83%89%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%A8gstreamer1.x%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E3%81%AF%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E7%B4%84350MB%E3%81%BE%E3%81%A7%EF%BC%89%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20python%20pkg-config%20git%20gstreamer1.0-x%20gstreamer1.0-tools%20gstreamer1.0-plugins-good%20gstreamer1.0-plugins-bad%20gstreamer1.0-alsa%20libgstreamer1.0-dev%20libgstreamer-plugins-base1.0-dev%20libgstreamer-plugins-good1.0-dev%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eg%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%2B%2B-%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Emultilib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20git%20clone%20git%3A%2F%2Fgithub.com%2FFreescale%2Fgstreamer-imx.git%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gstreamer-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-s%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2F%2Fusr%2Flib%2Fgstreamer-1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwafconfigure%20--prefix%3D%2Fusr%20--kernel-headers%3D%2Finclude%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%2F..%2F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20class%3D%22Code%22%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89libimxvpuapi%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E3%81%93%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%80%81NXP%20imx-vpu%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%EF%BC%88%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%ABIMX6%20VPU%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%89%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%20API%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594438636081123%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%225785.1044921875_50.000003814697266_1158_93%22%20jivemacro_uid%3D%22_14594438636081123%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20git%20clone%20git%3A%2F%2Fgithub.com%2FFreescale%2Flibimxvpuapi.git%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20libimxvpu*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwafconfigure%20%E2%80%93-prefix%3D%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Fwaf%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%80%8C.%2Fwaf%20install%E3%80%8D%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%2B%20%2Flib%2Fgstreamer-1.0%E3%81%AB%E3%82%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%95%E3%82%A1%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E5%89%8D%E3%81%AB%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EG2D%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AFg2d%20lib%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EVivante%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%83%86%E3%82%AF%E3%82%B9%E3%83%81%E3%83%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6EGL%E3%82%B7%E3%83%B3%E3%82%AF%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81X11%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88X11%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AE%E3%81%BF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AFlibfslaudiocodec%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81Gstreamer%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background%3A%20white%3B%20font-size%3A%2018.6667px%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E6%3A%20X11%E3%81%ABGPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E6%B3%A8%EF%BC%9A%E3%81%93%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%E3%81%AE%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E7%89%88%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%3CA%20href%3D%22http%3A%2F%2Ftrac.gateworks.com%2Fwiki%2Fventana%2Fubuntu%23HardwareGPUAccelerationforX11%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGateworks%20wiki%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E3%81%A7%E3%81%94%E8%A6%A7%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%E5%9F%B7%E7%AD%86%E8%80%85%E3%81%AE%E7%9A%86%E6%A7%98%E3%81%AB%E6%84%9F%E8%AC%9D%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EGStreamer%20%E3%81%8A%E3%82%88%E3%81%B3%20Gstreamer-imx%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20IMX6%20IPU%E3%80%81VPU%E3%80%81GPU%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E9%83%A8%E5%93%81%EF%BC%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%89%E3%81%AE%E5%A4%9A%E3%81%8F%E3%81%AFNXP%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E8%87%AA%E7%94%B1%E3%81%AB%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81NXP%E3%81%AE%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%8A%BD%E5%87%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%A8%E3%83%B3%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%EF%BC%88EULA%EF%BC%89%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E6%B1%82%E3%82%81%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CSPAN%20class%3D%22apple-converted-space%22%3E%3C%2FSPAN%3E%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AFdebootstrap%E3%81%AE%E4%B8%8A%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%80%81Ubuntu%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%84%E4%BB%96%E3%81%AELinux%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AEdebootstrap%E6%89%8B%E9%A0%86%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%ABX11%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3EX11%20server%20-%20ie%20Xorg%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%20-%20X%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E5%88%B6%E5%BE%A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%20-%20X%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E3%80%81%E8%A3%85%E9%A3%BE%E3%81%AA%E3%81%A9%E3%82%92%E7%AE%A1%E7%90%86%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%E3%82%82%E3%81%97Linaro%20LXDE%20rootfs%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%AFXorg%20X11%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%80%81lxdm%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%80%81openbox%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%80%81Chromium%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%E3%83%BC%E3%81%AA%E3%81%A9%E3%81%AE%E4%BE%BF%E5%88%A9%E3%81%AA%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linaro%20LXDE%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_1459444118777927%20jive_text_macro%22%20data-renderedposition%3D%226365.31298828125_50.000003814697266_1158_32%22%20jivemacro_uid%3D%22_1459444118777927%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E3%81%AF%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88650MB%E3%81%BE%E3%81%A7%EF%BC%89%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%26nbsp%3B%20%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20apt-get%20install%20xinit%20lxde%20lxterminal%20lxappearance%20lxrandr%20lxshortcut%20lxinput%20xinit%26nbsp%3B%20xserver-xorg-dev%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Emesa-utils%20mesa-utils-extra%20%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E3%83%A1%E3%83%A2%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3EChromium%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23660000%3B%20background%3A%20%23fafafa%3B%22%3Eadduser%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E9%9D%9Eroot%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%2Fetc%2Flxdm%2Fdefault.conf%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%85%88%E9%A0%AD%E3%81%AB%E3%81%82%E3%82%8Bbase%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23660000%3B%20background%3A%20%23fafafa%3B%22%3E%E8%87%AA%E5%8B%95%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22color%3A%20%23660000%3B%20background%3A%20%23fafafa%3B%22%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E8%87%AA%E5%8B%95%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%2Fetc%2Fxdg%2Flubuntu%2Flxdm%2Flxdm.conf%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20windowtext%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.14.52v%E3%80%81vivante%205.0.11p7.4%E3%82%92%E5%9F%BA%E6%9C%AC%E3%81%AB%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NXP%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8Bxserver%E3%81%8A%E3%82%88%E3%81%B3Vivante%20GPU%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81BSP%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594441892347696%20jive_text_macro%22%20data-renderedposition%3D%226534.27099609375_50.000003814697266_1158_47%22%20jivemacro_uid%3D%22_14594441892347696%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%24%20sudo%20nano%20%2Fetc%2Flxdm%2Fdefault.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%EF%BC%BB%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eautologin%3D%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20background-color%3A%20white%3B%22%3EX11%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20GPU%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81imx-gpu-viv%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AEFreescale%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81Freescales%E3%82%A8%E3%83%B3%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E4%BD%BF%E7%94%A8%E8%A8%B1%E8%AB%BE%E5%A5%91%E7%B4%84%EF%BC%88EULA%EF%BC%89%E3%81%B8%E3%81%AE%E7%BD%B2%E5%90%8D%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Elibg2d%20-%20GPU%E5%90%91%E3%81%91%E3%81%AE%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%ABAPI%EF%BC%88gstreamer-imx%E7%94%A8%E3%81%AElibimxvpuapi%E3%82%84gpu-core%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E4%BD%BF%E7%94%A8%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Egpu-core%20-%20provides%20all%20the%20various%20OpenGL%20libs%20(libGL%2C%20libGLESv1_CM%2C%20libGLESv1_CL%2C%20libGLESv2%2C%20libGLSLC%2C%20libCLC%2C%20libEGL%2C%20libGAL%2C%20libOpenCL%2C%20ls%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3ElibOpenVG%20-%20%E9%80%9A%E5%B8%B8%E3%80%81mesa%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%80%82libEGL%2FlibGAL%2FlibGLESv2%2FlibVIVANTE%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%EF%BC%88dfb%E3%80%81fb%E3%80%81wl%E3%80%81x11%EF%BC%89%E7%94%A8%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594442717887539%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%226746.2158203125_50.000003814697266_1158_576%22%20jivemacro_uid%3D%22_14594442717887539%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gpu_pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23cd%20imx-gpu-*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cp%20gpu-core%2Fusr%2Flib%2Fdri%2Fvivante_dri.so%20%2Fusr%2Flib%2Fxorg%2Fmodules%2Fdrivers%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20chmod%20644%20%2Fusr%2Flib%2Fxorg%2Fmodules%2Fdrivers%2Fvivante_dri.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa%2FlibGL.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa-egl%2FlibEGL.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20rm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa-egl%2FlibGLESv2.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22color%3A%20%23999988%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Erm%20%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fmesa-egl%2FlibOpenVG.so*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%2F..%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20gpu-pack%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20wget%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2F%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4.tar.gz%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20tar%20%E2%80%93xf%20xserver*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20xserver-org-video-imx*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23git%20init%E5%AE%9F%E8%A1%8C%E3%81%AE%E5%BF%85%E8%A6%81%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E6%A8%A1%E6%A7%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20.%2Ffastbuild.sh%26nbsp%3B%20BUILD_HARD_VFP%3D1%20XSERVER_GREATER_THAN_13%3D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd..%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20kernel-modu*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20make%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3Egpu-core%20x11%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20backend%3Dx11%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libEGL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibEGL.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libEGL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibEGL.so.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libEGL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibEGL.so.1.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGAL-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGAL.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGLESv2-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGLESv2.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGLESv2-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGLESv2.so.2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGLESv2-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibGLESv2.so.2.0.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libVIVANTE-%24%7Bbackend%7D.so%20%2Fusr%2Flib%2FlibVIVANTE.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20ln%20-sf%20libGAL_egl.dri.so%20%2Fusr%2Flib%2FlibGAL_egl.so%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20for%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Ei%20in%20egl%20glesv1_cm%20glesv2%20vg%3B%20do%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Ecp%20%2Fusr%2Flib%2Fpkgconfig%2F%24%7Bi%7D_%24%7Bbackend%7D.pc%2Fusr%2Flib%2Fpkgconfig%2F%24%7Bi%7D.pc%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E5%AE%8C%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23rm%20%2Fusr%2Flib%2F*-dfb.so%20%2Fusr%2Flib%2F*-fb.so%20%2Fusr%2Flib%2F*-wl.so%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%EF%BC%88GPU%E3%82%92%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89vivante%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%EF%BC%88GPU%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%EF%BC%89%E3%82%92%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594443264249544%20jive_text_macro%22%20data-renderedposition%3D%227347.32666015625_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14594443264249544%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20echo%20vivante%20%26gt%3B%26gt%3B%20%2Fetc%2Fmodules%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20nano%20%2Fetc%2Fudev%2Frules.d%2F10-imx.rules%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3EKERNEL%3D%3D%22galcore%22%2C%20MODE%3D%220660%22%2C%20GROUP%3D%22video%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3EKERNEL%3D%3D%22mxc_asrc%22%2C%26nbsp%3B%20MODE%3D%220666%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3EVivante%20fbdev%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%94%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%20xorg.conf%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14594443585909304%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%227435.1044921875_50.000003814697266_1158_249%22%20jivemacro_uid%3D%22_14594443585909304%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20nano%20%2Fetc%2FX11%2Fxorg.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%80%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E8%AD%98%E5%88%A5%E5%AD%90%E3%80%8Ci.MX%20Accelerated%20Framebuffer%20Device%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%80%8Cvivante%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%22fbdev%22%20%22%2Fdev%2Ffb0%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%22vivante_fbdev%22%20%22%20%2Fdev%2Ffb0%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%22HWcursor%22%20%22%20false%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%80%8CServerFlags%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%22BlankTime%22%26nbsp%3B%220%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5BStandbyTime%5D%26nbsp%3B%5B0%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5BSuspendTime%5D%26nbsp%3B%5B0%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%22OffTime%22%26nbsp%3B%20%220%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20cd%20..%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E6%89%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B3%E3%83%94%E3%83%BC%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%2Fusr%2Flib%20%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%81%8A%E3%82%81%E3%81%A7%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%83%86%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3EGStreamer%E3%81%AE%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Egstreamer-imx%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E8%A1%A8%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594443991277636%22%20data-renderedposition%3D%227792.18798828125_50.000003814697266_1158_383%22%20jivemacro_uid%3D%22_14594443991277636%22%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20gst-inspect-1.0%20%7C%20grep%20imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%3A%20imxvpuenc_mjpeg%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20VPU%20%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20JPEG%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%3A%26nbsp%3B%20imxvpuenc_mpeg4%3A%20Freescale%20VPU%20MPEG-4%20video%20encoder%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%3A%20imxvpuenc_h264%3A%20Freescale%20VPU%20h.264%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%3A%20imxvpuenc_h263%3A%20Freescale%20VPU%20h.263%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxvpu%3A%26nbsp%3Bimxvpudec%3A%20Freescale%20VPU%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxv4l2videosrc%3A%26nbsp%3B%20imxv4l2videosrc%3A%20V4L2%20CSI%20Video%20Source%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2d%3A%26nbsp%3B%20imxg2dcompositor%3A%20Freescale%20G2D%20video%20compositor%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2d%3A%20imxg2dvideotransform%3A%20Freescale%20G2D%20%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2d%3A%20imxg2dvideosink%3A%20Freescale%20G2D%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipu%3A%26nbsp%3B%20imxipucompositor%3A%20Freescale%20IPU%20video%20compositor%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipu%3A%20imxipuvideosink%3A%20Freescale%20IPU%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipu%3A%20imxipuvideotransform%3A%20Freescale%20IPU%20%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxpxp%3A%20imxpxpvideotransform%3A%20Freescale%20PxP%20%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxpxp%3A%20imxpxpvideosink%3A%20Freescale%20PxP%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxipuvideosink%3A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594444707294011%20jive_text_macro%22%20data-renderedposition%3D%228232.6044921875_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594444707294011%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209pt%3B%20line-height%3A%2012pt%3B%22%3E%23%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Egst-launch-1.0%20videotestsrc%20!%20imxipuvideosink%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3Eimxg2dvideosink%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14594445554421995%22%20data-renderedposition%3D%228273.7158203125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14594445554421995%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20gst-launch-1.0videotestsrc%20!%20imxg2dvideosink%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3Eimxeglvivsink%3C%2FSPAN%3E%3CTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%20background%3A%20%23fafafa%3B%22%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%3C%2FSPAN%3E%3C%2FTT%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-size%3A%2010pt%3B%22%3E%E3%80%81X11%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%E3%81%AE%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%E8%A1%A8%E7%A4%BA%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594445991565696%20jive_text_macro%22%20data-renderedposition%3D%228315.9375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14594445991565696%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%23%20export%20DISPLAY%3C%2FSPAN%3E%3CSPAN%20class%3D%22o%22%20style%3D%22color%3A%20windowtext%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%3A0.0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%20color%3A%20windowtext%3B%22%3E%23%20gst-launch-1.0videotestsrc%20!%20imxeglvivsink%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20color%3A%20black%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22ES-MX%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ES-MX%22%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%20color%3A%20%23222222%3B%20background%3A%20white%3B%22%3Eglmark2%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AFmesa-utils%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14594446314181983%20jive_text_macro%22%20data-renderedposition%3D%228372.6044921875_50.000003814697266_1158_294%22%20jivemacro_uid%3D%22_14594446314181983%22%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20cd%20%2Fopt%2Fviv_samples%2Fvdk%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri%20Light'%2C%20sans-serif%3B%22%3E%23%20.%2Ftutorial1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2Fany%20example%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%20style%3D%22color%3A%20%23606060%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2015px%3B%20line-height%3A%2026px%3B%20white-space%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3Eroot%40imx6Q%3A~%23%20glxgears%20-info%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_RENDERER%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20GC2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VERSION%20%3D%202.1%202.0.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VENDOR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20Corporation%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_EXTENSIONS%20%3D%20WGL_ARB_extensions_string%20WGL_EXT_extensions_string%20WGL_EXT_swap_control%20GL_EXT_texture_env_add%20GL_ARB_multitexture%20GL_ARB_multisample%20GL_ARB_texture_env_add%20GL_ARB_texture_compression%20GL_ARB_texture_env_combine%20GL_ARB_depth_texture%20GL_ARB_window_pos%20%E2%80%A6.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%E7%A7%92%E3%81%A71606%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%3D%20321.130%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%E7%A7%92%E3%81%A71650%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%3D329.834%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EL_RENDERER%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20GC2000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VERSION%20%3D%202.1%202.0.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3EGL_VENDOR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20Vivante%20Corporation%201629%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%2F5.0%E7%A7%92%20%3D%20325.644%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%E7%A7%92%E3%81%A71621%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%3D324.072%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%E7%A7%92%E3%81%A71650%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%3D%20329.806%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Calibri%20Light'%2C'sans-serif'%3B%22%3E5.0%20%E7%A7%92%E3%81%A7%201651%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%3D%20330.079%20FPS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3C%2FP%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FBio_TICFSL%22%20target%3D%22_blank%22%3EBio_TICFSL%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%E5%84%AA%E3%82%8C%E3%81%9F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eimx6q%20sabreauto%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Euboot%E3%80%81zimage%E3%80%81*dtb%E3%80%81rootfs%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%82%E3%82%8B%E6%99%82%E7%82%B9%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E7%9B%B4%E3%81%9B%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202015.04-gb8837c4-dirty(Aug%2013%202019%20-%2017%3A05%3A21)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6Q%20rev1.2%E3%80%81792%20MHz%3CBR%20%2F%3ECPU%3A%20%E6%B8%A9%E5%BA%A641%20%C2%B0C%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%8E%9F%E5%9B%A0%3A%20POR%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%20MX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3EPMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%3A%200%20MiB%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%2C%20FSL_SDHC%3A%201%3CBR%20%2F%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7HDMI%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3A%20HDMI%20(640x480)%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3A%20FEC%20%5BPRIME%5D%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20FEC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%3A%200%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Eboot.scr%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E**%20boot.scr%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93**%3CBR%20%2F%3EzImage%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E6022032%E3%83%90%E3%82%A4%E3%83%88%E3%82%92293%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%8819.6%20MiB%2F%E7%A7%92%EF%BC%89mmc%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3Eimx6q-sabreauto.dtb%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E41594%E3%83%90%E3%82%A4%E3%83%88%E3%82%9219%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%882.1%20MiB%2F%E7%A7%92%EF%BC%89%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%40%200x12000000%20%5B%200x000000%20-%200x5be390%20%5D%3CBR%20%2F%3E%23%23%2018000000%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%3CBR%20%2F%3E0x18000000%E3%81%AEfdt%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3E18000000%E3%81%AE%E6%89%80%E5%AE%9A%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%811800d279%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%E7%89%A9%E7%90%86%20CPU%200x0%E3%81%A7Linux%20%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%3CBR%20%2F%3ELinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.14.52-g0e08af9-dirty(BspDeveloper2%40BspDeveloper2)%20(gcc%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.8.5%20(Linaro%20GCC%204.8-2015.06)%20)%20%239%20SMP%20PREEMPT%202019%E5%B9%B48%E6%9C%8813%E6%97%A5%2016%3A58%3A40%20IST%3CBR%20%2F%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B310%20(ARMv7)%E3%80%81cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%A2%E3%83%87%E3%83%AB%3A%20Freescale%20i.MX6%20Quad%20SABRE%20Automotive%20Board%3CBR%20%2F%3Ecma%3A%20CMA%3A%206a000000%20%E3%81%AB320%20MiB%E3%82%92%E4%BA%88%E7%B4%84%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3CBR%20%2F%3EPERCPU%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF8%E3%83%9A%E3%83%BC%E3%82%B8%2FCPU%20%40ee71e000%20s8320%20r8192%20d16256%20u32768%3CBR%20%2F%3E1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB%E6%A7%8B%E7%AF%89%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E6%9C%89%E5%8A%B9%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A%20520720%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk2p2%20rootwait%20rw%3CBR%20%2F%3EPID%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EDentry%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20262144%20(%E9%A0%86%E5%BA%8F%3A%208%2C%201048576%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EInode%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%2C%20524288%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A%201739236K%2F2097152K%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%20(7452K%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81460K%20rwdata%E3%80%812596K%20rodata%E3%80%81392K%20init%E3%80%81433K%20bss%E3%80%81357916K%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%81270336K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA)%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%20%3CBR%20%2F%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(4%20kB)%3CBR%20%2F%3E%20%E5%9B%BA%E5%AE%9A%E3%83%9E%E3%83%83%E3%83%97%20%3A%200xfff00000%20-%200xfffe0000%20(896%20kB)%3CBR%20%2F%3E%20vmalloc%3A%200xf0000000%20-%200xff000000%20(240%20MB)%3CBR%20%2F%3E%20lowmem%20%3A%200x80000000%20-%200xef800000%20(1784%20MB)%3CBR%20%2F%3E%20pkmap%20%3A%200x7fe00000%20-%200x80000000%20(2%20MB)%3CBR%20%2F%3E%20modules%20%3A%200x7f000000%20-%200x7fe00000%20(14%20MB)%3CBR%20%2F%3E.text%3A%200x80008000%20-%200x809d828c%20(10049%20kB)%3CBR%20%2F%3E%20.init%20%3A%200x809d9000%20-%200x80a3b080%20(%20393%20kB)%3CBR%20%2F%3E%20.data%20%3A%200x80a3c000%20-%200x80aaf340%20(%20461%20kB)%3CBR%20%2F%3E%20.bss%20%3A%200x80aaf34c%20-%200x80b1b99c%20(%20434%20kB)%3CBR%20%2F%3ESLUB%3A%20HWalign%3D64%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3CBR%20%2F%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E9%9A%8E%E5%B1%A4%E5%9E%8BRCU%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%3CBR%20%2F%3E16L310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3El2x0%3A%2016%E3%82%A6%E3%82%A7%E3%82%A4%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x32070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B5%E3%82%A4%E3%82%BA%3A%201024%20kB%3CBR%20%2F%3E%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Esched_clock%3A%2032%20%E3%83%93%E3%83%83%E3%83%88%E3%80%813000kHz%E3%80%81%E5%88%86%E8%A7%A3%E8%83%BD%20333ns%E3%80%811431655765682ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2080x30%3CBR%20%2F%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%EF%BC%89%E3%80%81%E5%80%A4%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97..%206.00%20BogoMIPS%20(lpj%3D30000)%3CBR%20%2F%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ECPU%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%83%86%E3%82%B9%E3%83%88%3A%20OK%3CBR%20%2F%3ECPU0%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%2C%20CPU%200%2C%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%2C%20mpidr%2080000000%3CBR%20%2F%3E0x10717d60%20-%200x10717db8%E7%94%A8%E3%81%AE%E9%9D%99%E7%9A%84%E3%82%A2%E3%82%A4%E3%83%87%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E8%A8%AD%E5%AE%9A%E4%B8%AD%3CBR%20%2F%3ECPU1%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E8%B5%B7%E5%8B%95CPU1%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%201%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81MPIDR%2080000001%3CBR%20%2F%3ECPU2%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E8%B5%B7%E5%8B%95CPU2%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%202%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81MPIDR%2080000002%3CBR%20%2F%3ECPU3%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E8%B5%B7%E5%8B%95%3CBR%20%2F%3ECPU3%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%203%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81MPIDR%2080000003%3CBR%20%2F%3E4%E3%81%A4%E3%81%AECPU%E3%81%8C%E8%B5%B7%E5%8B%95%3CBR%20%2F%3ESMP%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E7%B7%8F%E6%95%B0%3A%204%20(24.00%20BogoMIPS)%E3%80%82%3CBR%20%2F%3ECPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECPU%E3%81%8CSVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%80%82%3CBR%20%2F%3Edevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20%E5%AE%9F%E8%A3%85%E8%80%85%2041%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%203%20%E3%83%91%E3%83%BC%E3%83%88%2030%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%889%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B34%3CBR%20%2F%3Epinctrl%20%E3%82%B3%E3%82%A2%3A%20pinctrl%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AA%E3%81%97%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2016%3CBR%20%2F%3EDMA%3A%20%E5%8E%9F%E5%AD%90%E7%9A%84%E3%81%AA%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB256%20KiB%E3%81%AE%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3ECPU%E3%81%AFi.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B31.2%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%9F%3CBR%20%2F%3EWDOG1%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Esyscon%2020c8000.anatop%3Aregmap%20%5Bmem%200x020c8000-0x020c8fff%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%20vdd1p1%3A%20800%EF%BD%9E1375%26lt%3B--%26gt%3B%20mV%20at%201100%20mV%3CBR%20%2F%3Evdd3p0%3A%202625%EF%BD%9E3400%26lt%3B--%26gt%3B%20mV%20at%203000%20mV%3CBR%20%2F%3Evdd2p5%3A%202000%EF%BD%9E2750%26lt%3B--%26gt%3B%20mV%20at%202400%20mV%3CBR%20%2F%3Evddarm%3A%20725%EF%BD%9E1450%26lt%3B--%26gt%3B%20mV%20at%201150%20mV%3CBR%20%2F%3Evddpu%3A%20725%EF%BD%9E1450%26lt%3B--%26gt%3B%20mV%20%3CBR%20%2F%3Evddsoc%3A%20725%EF%BD%9E1450%26lt%3B--%26gt%3B%20mV%20at%201175%20mV%3CBR%20%2F%3E%20syscon%2020e0000.iomuxc-gpr%3Aregmap%20%5Bmem%200x020e0000-0x020e0037%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Eyscon%2021bc000.ocotp-ctrl%3A%20regmap%20%5Bmem%200x021bc000-0x021bffff%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ehw-breakpoint%3A%205%E5%80%8B%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%EF%BC%88%2B1%E5%80%8B%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%EF%BC%89%E3%81%A81%E5%80%8B%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%3A%20%E6%9C%80%E5%A4%A7%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20IMX%E3%83%94%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%E7%95%A5%E6%AD%B4%3A%E3%82%B9%E3%83%A9%E3%83%96%20%3CBIO-0%3E%20%E3%82%920%20mxs-dma%20110000.dma-apbh%E3%81%AB%3CBR%20%2F%3E%E4%BD%9C%E6%88%90%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3Ecs42888_supply%3A%203300%20mV%20%3CBR%20%2F%3E3P3V%3A%203300%20mV%20%3CBR%20%2F%3Evio1%3A%203300%20mV%20%3CBR%20%2F%3Evio2%3A%203300%20mV%20%3CBR%20%2F%3Evd%3A%203300%20mV%20%3CBR%20%2F%3Eva%3A%205000%20mV%20%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0usb_h1_vbus.29%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E5%9B%BA%E5%AE%9A%E9%9B%BB%E5%9C%A7%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20usb_otg_vbus.30%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90reg-fixed-voltage%E3%81%AF%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmax17135%5D%20%E3%81%AF%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmax17135%5D%20%E3%81%AF%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3ESCSI%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eusbfs%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20usbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%8F%E3%83%96%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%8F%E3%83%96usb%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbphy_nop1.12%20%E4%BE%9B%E7%B5%A6VCC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eusbphy_nop2.13%20%E4%BE%9B%E7%B5%A6VCC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ei2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Epca953x%202-0032%3A%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Epca953x%3A%202-0032%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ei2c%20i2c-2%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20v2.00%3CBR%20%2F%3Epps_core%3A%20LinuxPPS%20API%20ver.%201%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CSPAN%3Epps_core%3A%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-ipuv3%202400000.ipu%EF%BC%9AIPU%20DMFC%20%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3A%201%EF%BC%880%EF%BD%9E1%EF%BC%89%E3%80%815B%EF%BC%884%2C5%EF%BC%89%E3%80%815F%EF%BC%886%2C7%EF%BC%89%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3A%20IPU%20DMFC%20NORMAL%20%E3%83%A2%E3%83%BC%E3%83%89%3A%201(0%EF%BD%9E1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3CBR%20%2F%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAdvanced%20Linux%20Sound%20Architecture%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EBluetooth%3A%20%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.18%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC31%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20L2CAP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20SCO%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecfg80211%3A%20CRDA%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92mxc_timer1%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC2%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ETCP%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2016384%20(%E9%A0%86%E5%BA%8F%3A%204%2C%2065536%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2016384%20(%E9%A0%86%E5%BA%8F%3A%205%2C%20131072%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(%E7%A2%BA%E7%AB%8B%2016384%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%2016384)%3CBR%20%2F%3ETCP%3A%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EUDP-Lite%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC1%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ERPC%3A%20%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%EF%BC%9AARMv7%20Cortex-A9%20PMU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%80%817%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3Eimx%20rpmsg%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eimx_busfreq%20busfreq.16%3ADDR%20%E3%81%AE%E4%B8%AD%E9%80%9F%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Efutex%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%204%E3%80%8165536%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%83%97%E3%83%BC%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%20%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3EVFS%3A%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%20dquot_6.5.2%3CBR%20%2F%3EDquot-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A1024%EF%BC%88%E9%A0%86%E5%BA%8F%200%E3%80%814096%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3ENFS%3A%20id_resolver%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_resolver%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_legacy%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ejffs2%EF%BC%9A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3CBR%20%2F%3Efuse%20init%20(API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.22)%3CBR%20%2F%3Emsgmni%E3%81%8C3508%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9noop%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9deadline%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9cfq%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%89%3CBR%20%2F%3Eimx-weim%2021b8000.weim%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88.17%E3%81%AE%E4%BE%9B%E7%B5%A6%E9%9B%BB%E6%BA%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3EMIPI%20DSI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EMIPI%20DSI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_sdc_fb%20fb.22%3A%20MXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ldb%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3AIPU%20DMFC%20DP%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%201(0%2C1)%E3%80%815B(2%EF%BD%9E5)%E3%80%815F(6%2C7)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9128x48%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%20%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FHDMI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%200x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%20%E5%90%8D%20-%202.073M9%3CBR%20%2F%3Emxc_sdc_fb%20fb.23%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9Fmxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90hdmi%3CBR%20%2F%3Emxc_sdc_fb%20fb.24%3A%20mxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3Emxc_sdc_fb%20fb.25%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9Fmxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ldb%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3AIRAM%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%A4%96%E9%83%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%86%8D%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%203.2%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%EF%BC%9A%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A%202%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A%201%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20FAB%3A%200%E3%80%81FIN%3A%200%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20pfuze100%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESW1AB%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201375%20mV%20%3CBR%20%2F%3ESW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20at%201375%20mV%20%3CBR%20%2F%3ESW2%3A%20800%20%26lt%3B--%26gt%3B%203300%20mV%20at%203000%20mV%20%3CBR%20%2F%3ESW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3CBR%20%2F%3ESW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20at%201500%20mV%20%3CBR%20%2F%3ESW4%3A%20800%20%26lt%3B--%26gt%3B%201975%20mV%20at%201800%20mV%20%3CBR%20%2F%3ESWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20at%205000%20mV%20%3CBR%20%2F%3EVSNVS%3A%201000%20%26lt%3B--%26gt%3B%203000%20mV%20at%203000%20mV%20%3CBR%20%2F%3EVREFDDR%3A%20750%20mV%20%3CBR%20%2F%3EVGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%20800%20mV%20%3CBR%20%2F%3EVGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20at%201500%20mV%20%3CBR%20%2F%3EVGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%201800%20mV%20%3CBR%20%2F%3EVGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%201800%20mV%20%3CBR%20%2F%3EVGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%202500%20mV%20%3CBR%20%2F%3EVGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20at%202800%20mV%20%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20IMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E21ec000.serial%3A%20ttymxc2%20%E3%81%AF%20MMIO%200x21ec000%20(irq%20%3D%2060%E3%80%81base_baud%20%3D%205000000)%20%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81IMX%3CBR%20%2F%3E21f0000.serial%20%E3%81%A7%E3%81%99%E3%80%82ttymxc3%20%E3%81%AF%20MMIO%200x21f0000%20(irq%20%3D%2061%2C%20base_baud%20%3D%205000000)%20%E3%81%AB%E3%81%82%E3%82%8B%20IMX%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc3%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20Freescale%20lpuart%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eimx%20sema4%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F20060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E3%82%92minor%200%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ebrd%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Esi476x-core%201-0063%3A%20IRQ%20%E7%95%AA%E5%8F%B7%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%890x11%E3%81%AE%E9%80%81%E4%BF%A1%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E9%9B%BB%E6%BA%90%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Ctransmit-level-mV%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8100000024%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Ctransmit-boost-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8100000480%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%E3%80%81transmit-atten-16ths%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%8100002000%20%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Creceive-eq-mdB%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%8105000000%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%3APHY%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20-110%3CBR%20%2F%3Eahci-imx%3A%202200000.sata%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-110%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E2094000.can%E3%81%AE%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%9A%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eflexcan%202094000.can%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(reg_base%3Df01f0000%2C%20irq%3D143)%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eehci-mxc%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usb-storage%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usb_ehset_test%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2184800.usbmisc%20%E4%BE%9B%E7%B5%A6vbus-wakeup%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eimx_usb%202184000.usb%3Aci_hdrc%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%202184000.usb%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20imx_usb%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eimx_usb%202184200.usb%3Aci_hdrc%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%202184200.usb%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20imx_usb%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%3CBR%20%2F%3Emousedev%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AB%E5%85%B1%E9%80%9A%E3%81%AE%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Eegalax_ts%201-0004%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%3CBR%20%2F%3Eegalax_ts%3A%201-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%3CBR%20%2F%3E2-0044%20%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%9A%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bisl29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bisl29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%3A%20snvs-rtc%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%3Artc%E3%82%B3%E3%82%A2%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF20cc034.snvs-rtc-lprtc0%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3Ei2c%20%2Fdev%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3EIR%20NEC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC5(x)%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC6%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20JVC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20Sony%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC5%20(streamzap)%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20SANYO%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20MCE%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%3AV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8Cvideo16%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%3AV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8Cvideo17%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%EF%BC%9AV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8Cvideo18%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%3AV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8Cvideo19%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out.33%3AV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8Cvideo20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E2-000e%E3%81%AE%E9%9B%BB%E6%BA%90vdd%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2-000e%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vddio%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Emag3110%202-000e%3A%20mag3110%20%E3%83%81%E3%83%83%E3%83%97ID%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3Emag3110%202-000e%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%E3%83%81%E3%83%83%E3%83%97%20ID%200xfffffffb%20%E3%81%AF%200xc4%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%3CBR%20%2F%3Emag3110%3A%202-000e%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmag3110%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmag3110%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E5%86%8D%E9%96%8B%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2-001c%E3%81%AE%E9%9B%BB%E6%BA%90vdd%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2-001c%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vddio%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Emma8451%202-001c%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%E3%83%81%E3%83%83%E3%83%97%20ID%200x1%20%E3%81%AF%200x1a%20%E3%81%BE%E3%81%9F%E3%81%AF%200x2a%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%3CBR%20%2F%3Emma8451%3A%202-001c%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eimx2-wdt%2020bc000.wdog%3AIMX2%2B%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%EF%BC%88nowayout%3D0%EF%BC%89%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ver%202.2%3CBR%20%2F%3EBluetooth%3A%20HCI%20H4%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3EBluetooth%3A%20HCI%20BCSP%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20bcm203x%20%E3%81%8C%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90btusb%E3%81%8C%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ath3k%E3%81%8C%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Esdhci%3A%20%C2%A9%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%3A%20SDHCI%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%8A%E3%82%88%E3%81%B3OF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%3CBR%20%2F%3Emmc1%3A%20vqmmc%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3CBR%20%2F%3Emmc1%3A%20vmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3CBR%20%2F%3Emmc1%3A%20SDHCI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C2194000.usdhc%20%5B2194000.usdhc%5D%20%E3%81%AB%E3%81%82%E3%82%8BADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emmc2%3A%20VQMMC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc2%3A%20VMMC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc2%3A%202198000.usdhc%E3%81%AESDHCI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%5B2198000.usdhc%5DADMA%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EGalcore%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.0.11.33433%3CBR%20%2F%3Emmc1%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001%20%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3Emmcblk1%3A%20mmc1%3A0001%20VM010B%2014.5%20GiB%3CBR%20%2F%3Emmcblk1boot0%3A%20mmc1%3A0001%20VM010B%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B31%20512%20Ki%3CBR%20%2F%3Emmcblk1boot1%3A%20mmc1%3A0001%20VM010B%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%202%20512%20KiB%3CBR%20%2F%3Emmcblk1rpmb%3A%20mmc1%3A0001%20VM010B%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%203%20512%20KiB%3CBR%20%2F%3E%E4%BB%A3%E6%9B%BF%20GPT%20%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AAGPT%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emmcblk1%3A%20p1%20p2%20p3%20p4%20p5%20p6%20p7%3CBR%20%2F%3Emmcblk1boot1%3A%20%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3CBR%20%2F%3E%20mmcblk1boot0%3A%20%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3CBR%20%2F%3Emmc2%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82mmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9e624%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9FSDHC%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3Emmcblk2%3A%20mmc2%3Ae624%20SS16G%2014.8%20GiB%3CBR%20%2F%3Emmcblk2%3A%20p1%20p2%3CBR%20%2F%3Emxc_vdoa%2021e4000.vdoa%3Ai.MX%20%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_vpu%202040000.vpu%3AVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecaam%202100000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH0%3CBR%20%2F%3Ecaam%202100000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH1%3CBR%20%2F%3Ecaam%202100000.caam%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%20%3D%200x0a160100%EF%BC%88Era%204%EF%BC%89%3CBR%20%2F%3Ecaam%202100000.caam%3A%20%E3%82%B8%E3%83%A7%E3%83%96%E3%83%AA%E3%83%B3%E3%82%B0%20%3D%202%E3%80%81qi%20%3D%200%3CBR%20%2F%3Ecaam%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%20%2Fproc%2Fcrypto%20%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ecaam_jr%202101000.jr0%3Arng-caam%20%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20blkkey_ex%3A%204%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2017%20d4%2014%20e3%20cd%2014%2099%203c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2028%20ac%2013%20da%204f%2013%2086%20b9%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2047%2020%20d5%208a%2008%202e%20c9%2076%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2021%20a3%20ab%2086%2072%20eb%20e0%20d7%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20a0%20ab%2018%20b1%20c0%2086%2052%20c3%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2026%2002%2062%2070%20a8%2078%204c%20f2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%204e%206c%20e5%2031%207e%206c%20d1%2025%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2048%2062%2078%2086%2093%2070%2062%20ff%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2061%2042%20d7%20cf%2079%20ad%2081%205c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20cc%201b%209e%205c%20a0%2020%200e%2054%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%20ed%20fa%2074%2003%2008%20e1%2096%20e2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%205c%2085%20e0%20cc%20ab%20f4%209e%203b%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D00%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20196%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D00%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%EF%BC%88%E3%83%96%E3%83%AD%E3%83%96%E5%BD%A2%E5%BC%8F%EF%BC%89%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20fc%20e1%202d%202c%2081%2075%205e%2099%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D2d%2093%209b%20b0%20a6%205a%203d%2049%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2098%2096%209d%200c%2039%2036%20da%2072%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20f9%201d%2066%200c%2078%2024%2020%209a%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2085%203c%2092%201e%20a4%2055%20d2%204b%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20e4%207a%20ed%2019%20af%2070%202e%20f6%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%20cf%20c9%2007%200e%2082%2019%2047%207f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%E3%83%96%E3%83%AD%E3%83%96%E5%86%85%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%20c6%20ae%2004%2056%20f6%205e%20c2%201b%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20d9%206c%2007%2089%209d%201e%2020%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2072%204c%2063%20e1%20ed%20d2%20fd%2068%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2099%2081%2017%2032%2033%2039%202a%201c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0032%5D%20fb%20e4%20bb%20db%200c%2007%20c0%20f2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20eb%2023%20cf%2079%2064%202a%20ca%20f3%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0048%5D%20d9%2084%20ac%2022%200b%2049%2079%20e9%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0056%5D%207d%208b%2097%2009%206a%20d4%2072%200b%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D00%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%20blob%20%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%209c%20ec%2058%2009%2050%2020%2080%201d%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2021%20b6%20e3%2064%2041%20ed%2014%2012%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2016%20e1%20c7%20d3%20fe%2054%2040%20ed%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20bc%2092%20e0%200c%206b%200a%20ec%2002%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%203b%2060%206f%2018%2020%2026%20e4%2004%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20c2%2094%205e%202f%201e%20e4%2099%20b1%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%209c%2005%2065%2095%209b%208d%20db%2072%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3A%20%5B0056%5D%20a8%2050%20b0%2050%209d%20f8%2067%2066%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%2033%20ae%2046%20e9%2042%206c%20fb%20ab%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%20blob%20%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%209b%2050%206d%2078%2093%20a8%2008%2084%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20e5%203b%2026%2018%201d%206a%2042%2080%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%203f%20c9%207f%204d%20dd%201a%20b6%20a3%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2002%206a%204d%2064%20a6%20cc%20c3%2061%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D15%209e%20c8%201f%2075%2072%2001%20af%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20f5%2087%20b3%2078%20b0%2078%203f%2034%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0048%5D%20bf%2019%2080%2005%2072%2032%20c2%2082%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0056%5D%20d1%20fd%204c%20f7%20c6%20c9%2098%2085%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%209d%2002%2055%2075%2035%20d5%20ef%20ca%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2080%20f5%2021%2087%20ef%206c%20cd%2096%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2047%209d%20fa%2049%20f0%20cf%20c5%201c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2090%204d%200a%20e3%20a1%20ee%2072%205c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2047%2020%20d5%208a%2008%202e%20c9%2076%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BCcaam_sm%3A%20%5B0008%5D%2021%20a3%20ab%2086%2072%20eb%20e0%20d7%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%20a0%20ab%2018%20b1%20c0%2086%2052%20c3%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2026%2002%2062%2070%20a8%2078%204c%20f2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%208d%200d%20bc%202d%202c%2090%2067%200c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2093%2091%20ea%2059%2081%20df%2052%20df%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2061%2042%20d7%20cf%2079%20ad%2081%205c%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%20cc%201b%209e%205c%20a0%2020%200e%2054%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0016%5D%20ed%20fa%2074%2003%2008%20e1%2096%20e2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0024%5D%205c%2085%20e0%20cc%20ab%20f4%209e%203b%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3Asnvs%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3A%E9%81%95%E5%8F%8D%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E8%B5%B7%E5%8B%95%20-%20%E9%9D%9E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E7%8A%B6%E6%85%8B%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usbhid%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbhid%3A%20USB%20HID%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Ecs42xx8%201-0048%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BA%E8%A6%8B%E3%80%81%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B34%3CBR%20%2F%3Efsl-asrc%202034000.asrc%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esnd-soc-dummy%20snd-soc-dummy%3A%20ASoC%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20debugfs%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.26%3Acs42888%26lt%3B-%26gt%3B%202024000.esai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0ok%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.26%3Asnd-soc-dummy-dai%20%26lt%3B-%26gt%3B%202034000.asrc%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20ok%3CBR%20%2F%3Eimx-cs42888%20sound-cs42888.26%3A%20cs42888%20%26lt%3B-%26gt%3B%202024000.esai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E5%AE%8C%E4%BA%86%3CBR%20%2F%3Eimx-spdif%20sound-spdif.19%3A%20snd-soc-dummy-dai%20%26lt%3B-%26gt%3B%202004000.spdif%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OK%3CBR%20%2F%3Eimx-audio-hdmi%20sound-hdmi.20%3A%20hdmi-hifi%26lt%3B-%26gt%3B%20hdmi_audio.3%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OK%3CBR%20%2F%3Eimx-tuner-si476x%20sound-fm.31%EF%BC%9AFM%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-tuner-si476x%3A%20sound-fm.31%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2026%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ETCP%3A%20cubic%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2010%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2017%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecan%3A%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2%20(rev%2020120528%20abi%209)NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2029%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecan%3A%20raw%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528)can%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528%20t)%3CBR%20%2F%3Ecan%3A%20netlink%20%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%20(rev%2020130117)%20max_hops%3D1Bluetooth%3A%20RFCOMM%20TTY%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.11%3CBR%20%2F%3EBluetooth%3A%20BNEP%20(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.3%3CBR%20%2F%3EBluetooth%3A%20BNEP%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3CBR%20%2F%3EBluetooth%3A%20BNEP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HIDP%20(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.2%3CBR%20%2F%3EBluetooth%3A%20HIDP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20dns_resolver%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EVGEN2%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3ESWBST%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3ESW4%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3Eimx%20mcc%20%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20usb_h1_vbus.29%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%9B%BA%E5%AE%9A%E9%9B%BB%E5%9C%A7%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eusb_otg_vbus%3A%205000%20mV%3CBR%20%2F%3Eimx_usb%202184200.usb%3Aci_hdrc%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%202184200.usb%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90imx_usb%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20usb_h1_vbus.29%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20reg-fixed-voltage%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A02%20UTC%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(2)%3CBR%20%2F%3Eimx_usb%202184200.usb%3Aci_hdrc%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3EALSA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%B9%E3%83%88%3A%3CBR%20%2F%3E%230%3A%20cs42888-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3CBR%20%2F%3E%20%231%3A%20imx-spdif%3CBR%20%2F%3E%232%3A%20imx-hdmi-soc%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20usb_h1_vbus.29%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%9B%BA%E5%AE%9A%E9%9B%BB%E5%9C%A7%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ekjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%945%E7%A7%92%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E5%BE%A9%E6%97%A7%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EEXT3-fs%20(mmcblk2p2)%3A%20%E9%A0%86%E5%BA%8F%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A34%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Edevtmpfs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%20-2%3CBR%20%2F%3E%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A7%A3%E6%94%BE%E4%B8%AD%3A%20392K%20(809d9000%20-%2080a3b000)%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%20-%20%E5%90%8C%E6%9C%9F%E3%81%9B%E3%81%9A%3A%20%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8Binit%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82init%3D%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E6%B8%A1%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Linux%20Documentation%2Finit.txt%20%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82CPU2%3A%20%E5%81%9C%E6%AD%A2%E4%B8%AD%3CBR%20%2F%3ECPU%3A%202%20PID%3A%200%20Comm%3A%20swapper%2F2%20%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%203.14.52-g0e08af9-dirty%239%3CBR%20%2F%3E%5B%26lt%3B80014764%26gt%3B%5D%20(unwind_backtrace)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3CBR%20%2F%3E%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI%2B0x144%2F0x158)%3CBR%20%2F%3E%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq%2B0x58%2F0x5c)%3CBR%20%2F%3E%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc%2B0x40%2F0x70)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xd80adf50%20%E3%81%8B%E3%82%89%200xd80adf98)%3CBR%20%2F%3Edf40%3A%20d80adf98%203b9aca00%20e9b5de9d%2000000000%3CBR%20%2F%3Edf60%3A%20e882c038%2000000000%20ee72f0d0%2080a4a814%2000000001%20ee72f0d4%20d80ac000%20d80ac000%3CBR%20%2F%3Edf80%3A%20a6aaaaab%20d80adf98%2000000009%20804b64bc%2060000113%20ffffffff%5B%26lt%3B80011f80%26gt%3B%5D%20%3CBR%20%2F%3E(__irq_svc)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call%2B0xfc%2F0x150)%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call)%20%E3%81%8B%E3%82%89%3CBR%20%2F%3E%20%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle%2B0x8%2F0x44)%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle)%20%E3%81%8B%E3%82%89%3CBR%20%2F%3E%20%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry%2B0x104%2F0x150)%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry)%20%E3%81%8B%E3%82%89%3CBR%20%2F%3E%20%5B%26lt%3B10008644%26gt%3B%5D%20(0x10008644)CPU0%3A%20%E5%81%9C%E6%AD%A2%E4%B8%AD%3CBR%20%2F%3ECPU%3A%200%20PID%3A%200%20%E9%80%9A%E4%BF%A1%3A%20swapper%2F0%20%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%203.14.52-g0e08af9-dirty%239%3CBR%20%2F%3E%5B%26lt%3B80014764%26gt%3B%5D%20(unwind_backtrace)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3CBR%20%2F%3E%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI%2B0x144%2F0x158)%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq%2B0x58%2F0x5c)%3CBR%20%2F%3E%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc%2B0x40%2F0x70)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0x80a3df18%20%E3%81%8B%E3%82%89%200x80a3df60%3CBR%20%2F%3E)df00%3A%2080a3df60%203b9aca00%3CBR%20%2F%3Edf20%3A%20e9b5de9d%2000000000%20e883714d%2000000000%20ee71f0d0%2080a4a814%2000000001%20ee71f0d4%3CBR%20%2F%3Edf40%3A%2080a3c000%2080a3c000%20a6aaaaab%2080a3df60%2000000009%20804b64bc%2060000113%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc)%20from%20%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%E3%81%8B%E3%82%89%20%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call%2B0xfc%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle%2B0x8%2F0x44)%3CBR%20%2F%3E%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry%2B0x104%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B809d9af0%26gt%3B%5D%20(start_kernel%2B0x350%2F0x35c)%3CBR%20%2F%3ECPU3%3A%20%E5%81%9C%E6%AD%A2%E4%B8%AD%3CBR%20%2F%3ECPU%3A%203%20PID%3A%200%20Comm%3A%20swapper%2F3%20Not%20tainted%203.14.52-g0e08af9-dirty%239%3CBR%20%2F%3E%5B%26lt%3B80014764%26gt%3B%5D%20(unwind_backtrace)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%5B%26lt%3B80011488%26gt%3B%5D%20(show_stack)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3CBR%20%2F%3E%5B%26lt%3B807119b4%26gt%3B%5D%20(dump_stack)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI%2B0x144%2F0x158)%3CBR%20%2F%3E%5B%26lt%3B80013718%26gt%3B%5D%20(handle_IPI)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq%2B0x58%2F0x5c)%3CBR%20%2F%3E%5B%26lt%3B800085b0%26gt%3B%5D%20(gic_handle_irq)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc%2B0x40%2F0x70)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xd80aff50%20%E3%81%8B%E3%82%89%200xd80aff98)%3CBR%20%2F%3Eff40%3A%20d80aff98%203b9aca00%20e9b5de9d%2000000000%3CBR%20%2F%3Eff60%3A%20e882c2d3%2000000000%20ee7370d0%2080a4a814%2000000001%20ee7370d4%20d80ae000%20d80ae000%3CBR%20%2F%3Eff80%3A%20a6aaaaab%20d80aff98%2000000009%20804b64bc%2060000113%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80011f80%26gt%3B%5D%20(__irq_svc)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state%2B0x50%2F0xe0)%3CBR%20%2F%3E%5B%26lt%3B804b64bc%26gt%3B%5D%20(cpuidle_enter_state)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call%2B0xfc%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B804b6648%26gt%3B%5D%20(cpuidle_idle_call)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle%2B0x8%2F0x44)%3CBR%20%2F%3E%5B%26lt%3B8000edf0%26gt%3B%5D%20(arch_cpu_idle)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry%2B0x104%2F0x150)%3CBR%20%2F%3E%5B%26lt%3B8006b140%26gt%3B%5D%20(cpu_startup_entry)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B10008644%26gt%3B%5D%20(0x10008644)%3C%2FBIO-0%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx.8%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%26nbsp%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20400%3B%20font-size%3A%2016px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20%E3%80%8Cu-boot%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20400%3B%20font-size%3A%2016px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%E3%80%8Cmake%E3%80%8D%E5%91%BD%E4%BB%A4%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%202rem%3B%20margin%3A%200px%200px%2030px%3B%20padding%3A%200px%20300px%200px%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%201%3A%20..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20Syntax%20error%3A%20%22(%22%20unexpected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%201%3A%20..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20Syntax%20error%3A%20%22(%22%20unexpected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Edirname%3A%20missing%20operand%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3ETry%20'dirname%20--help'%20for%20more%20information.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Escripts%2Fkconfig%2Fconf%20--silentoldconfig%20Kconfig%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20CHK%20include%2Fconfig.h%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E%20GEN%20include%2Fautoconf.mk%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3E..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%201%3A%20..%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20Syntax%20error%3A%20%22(%22%20unexpected%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Escripts%2FMakefile.autoconf%3A71%3A%20recipe%20for%20target%20'include%2Fautoconf.mk'%20failed%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Emake%5B1%5D%3A%20***%20%5Binclude%2Fautoconf.mk%5D%20Error%201%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20'times%20new%20roman'%2C%20times%2C%20serif%3B%22%3Emake%3A%20***%20No%20rule%20to%20make%20target%20'include%2Fconfig%2Fauto.conf'%2C%20needed%20by%20'include%2Fconfig%2Fuboot.release'.%20Stop.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Image%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABzImage%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81make%20menuconfig%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20492px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27702iD8C61D7B243F870F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGzip%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E9%81%B8%E6%8A%9E%E8%82%A2%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%AEI.MX6Q%20SABRESD%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7Ubuntu%2014.04%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E7%A7%81%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81MMC%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89IMX6Q%20SABRE%20SD%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7Ubuntu%2014.04%E4%BB%A5%E4%B8%8A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%82%82%E3%81%86%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20title%3D%22https%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jivelink12%22%20href%3D%22https%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2F%22%20title%3D%22https%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2F%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2Farchive%2F14.09%2Fcomponents%2Ftoolchain%2Fbinaries%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%22%20style%3D%22color%3A%20%23444444%20!important%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20none%20!important%3B%20font-size%3A%2013px%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A5%87%E5%A6%99%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20500%3B%20font-size%3A%2010.9998px%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22287259%22%20data-username%3D%22wenmingfeng%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fwenmingfeng%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20text-decoration%3A%20none%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3Ewenming%20feng%3C%2FA%3E%3C%2FSPAN%3E%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Fbin%2Fsh%3A%201%3A%20%2Fhome%2Fguillaume%2Fgcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux%2Fbin%2Farm-linux-gnueabihf-gcc%3A%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%23008000%3B%22%3Egcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%3CSTRONG%3EzImage%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%3C%2FSTRONG%3E%E3%80%81Image%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81u-boot%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88u-boot%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E3%81%AE%E4%B8%8D%E6%AD%A3%E3%81%AALinux%20arm%20zimage%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%89%E3%80%82uImage%E3%80%81Image%E3%80%81zImage%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81Image%E3%81%AF64%E3%83%93%E3%83%83%E3%83%88%E7%94%BB%E5%83%8F%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%B3%AA%E5%95%8F1%EF%BC%9AzImage%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%2F%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F(%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%B3%AA%E5%95%8F2%EF%BC%9A%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%B3%AA%E5%95%8F%203%EF%BC%9A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%9FSABRE%20SD%E7%94%A8%EF%BC%88U-Boot%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%81DTB%E3%80%81Ubuntu%2014.04%E4%BB%A5%E9%99%8D...%EF%BC%89%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%81%AE.sdcard%E3%81%8C%E3%81%A9%E3%81%93%E3%81%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%82%AE%E3%83%A8%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%A6%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22border%3A%200px%3B%22%3E%E7%A7%81%E3%81%AFimx6q-sabresd%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22330147%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330147%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3ENXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABUbuntu%20Rootfs%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FA%3E%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%203.14.52%20%E3%81%A7%E3%80%81Ubuntu%20Rootfs%2014.04%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E7%A7%81%E3%81%AE%20Xorg%20xserver%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%201.15.1%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7PCI%E3%83%90%E3%82%B9%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81x11%E3%81%AEGPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88glxgears%E3%81%A8es2gears%E3%81%A7%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PCI%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AExserver%E3%81%A7x11%20GPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EPCI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFx11%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%BD%B9%E5%89%B2%E3%82%92%E6%9E%9C%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82PCI%E3%83%90%E3%82%B9%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6x11%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E4%BF%AE%E6%AD%A3%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%84%E3%80%81PCI%E3%81%BE%E3%81%9F%E3%81%AFDRM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A7%E3%83%B3%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%20cd%20kernel-modu*%E3%82%82%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFi.mx6q%20sabre%20sd%E3%81%A7%E3%80%81LVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3CEM%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3Egcc-linaro-arm-linux-gnueabihf-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23c00000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E4.9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23c00000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E2014%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E.09_linux.tar.xz%3C%2FSPAN%3E%3C%2FSTRONG%3E%E3%82%92%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FSPAN%3E%3C%2FEM%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%80%9A%E3%82%8A%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3ESkype%20for%20Business%20%E3%81%A7%E3%80%8CKane%20Jiang%E3%80%8D%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKane%20Jiang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Kane%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%3CEM%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Elinaro-trusty-alip-20141024-684.tar.gz%3C%2FSTRONG%3E%3C%2FEM%3E%E3%82%92%E4%BD%BF%E3%81%84%E6%85%A3%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81imx6dl%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82ipu.di0%2Ffb0%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABOSD-WVGA%20lcd%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Ubuntu%20Core%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Ekernel-modu*%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B3%A8%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%9A%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Ftrac.gateworks.com%2Fwiki%2Fventana%2Fubuntu%23HardwareGPUAccelerationforX11%22%20title%3D%22http%3A%2F%2Ftrac.gateworks.com%2Fwiki%2Fventana%2Fubuntu%23HardwareGPUAccelerationforX11%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eventana%2Fubuntu%20%E2%80%93%20Gateworks%3C%2FA%3E%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B32%E3%81%A7%E3%80%81cd%20kernel-modu*%20make%E3%82%92%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%80%81cd%20%2Fusr%2Flib%E3%81%A7ln%20-sf%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82fastbuild.sh%E3%81%AFvivante_drv.so%E3%81%AE%E3%81%BF%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81vivante_dri.so%E3%81%AFgpu_core%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E5%90%8Dkernel-modu*%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEvideo%3D%20line%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EWenming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHi%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%3E%40Bio_TICFSL%3C%2Fa%3E%2C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%84%AA%E3%82%8C%E3%81%9F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%93%E3%81%93%E3%81%A72%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E1.%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Ekernel-modu*%3C%2FSTRONG%3E%3C%2FEM%3E%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3B.%2Ffastbuild.sh%26nbsp%3B%26nbsp%3BBUILD_HARD_VFP%3D1%26nbsp%3BXSERVER_GREATER_THAN_13%3D1%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd..%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd%26nbsp%3Bkernel-modu*%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bmake%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3Bgpu-core%26nbsp%3Bx11%26nbsp%3B%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%EF%BC%9A%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bbackend%3Dx11%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E2.%20%E3%81%9D%E3%82%8C%E3%81%8B%E3%82%89%3CSTRONG%20style%3D%22background-color%3A%20%23cbe68f%3B%20%3A%20%3B%20color%3A%20%23444444%3B%20text-decoration%3A%20none%20!important%3B%20font-size%3A%2013px%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Freleases.linaro.org%2Fdebian%2Fimages%2Falip-armhf%2F16.04%2Flinaro-jessie-alip-20160428-22.tar.gz%22%20style%3D%22color%3A%20%23444444%20!important%3B%20background-color%3A%20%23cbe68f%3B%20text-decoration%3A%20none%20!important%3B%20font-size%3A%2013px%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinaro-jessie-alip-20160428-22.tar.gz%3C%2FA%3E%3C%2FSTRONG%3E%E3%81%A8%E3%81%84%E3%81%86rootfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%EF%BC%88debian%E3%80%81Ubuntu%2016.04%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%89%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CEM%3E%3CSTRONG%3E%5B%E5%A4%B1%E6%95%97%5D%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E9%96%8B%E5%A7%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CEM%3E%3CSTRONG%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8Csystemctl%20status%20systemd-logind.service%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5BOK%5D%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A8%B1%E5%8F%AF%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%5B%E5%A4%B1%E6%95%97%5D%20LSB%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99...eeded%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6cpufreq%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8Csystemctl%20status%20loadcpufreq.service%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5BOK%5D%20%2Fetc%2Frc.local%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5BOK%5D%20LSB%EF%BC%9A%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5BOK%5D%20LSB%EF%BC%9A%E9%AB%98%E5%BA%A6%E3%81%AAIEEE%20802.11%E7%AE%A1%E7%90%86%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5BOK%5D%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E7%9B%A3%E8%A6%96%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E6%99%82%E9%96%93%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9dev-ttymxc0.device%E3%81%AE%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%5B%E4%BE%9D%E5%AD%98%5D%20ttymxc0%20%E4%B8%8A%E3%81%AESerial%20Getty%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%5B%E5%A4%B1%E6%95%97%5D%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%3CEM%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8Csystemctl%20status%20NetworkManager.service%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%89%AF%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A7%E3%83%B3%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%9A%3CEM%3E%3CSTRONG%3Eapt-get%20install%20libxtst-dev%3C%2FSTRONG%3E%3C%2FEM%3E%E3%82%92%E8%A9%A6%E3%81%99%E3%81%A8%E3%80%81%3CEM%3E%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8CX11%2Fextensions%2FXext.h%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%20%E3%80%8D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A7%E3%83%B3%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AErootfs%E3%82%92%E9%81%B8%E3%81%B3%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E8%BF%B0%E3%81%B9%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Linaro%20LXDE%20rootfs%EF%BC%88%E4%BE%8B%EF%BC%9A%3CSTRONG%3E%3CEM%20style%3D%22color%3A%20%23008000%3B%22%3Elinaro-trusty-alip-20141024-684.tar.gz%3C%2FEM%3E%3C%2FSTRONG%3E%EF%BC%89%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%85%88%E3%81%BB%E3%81%A9%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcdimage.ubuntu.com%252Fubuntu-core%252Fvivid%252Fdaily-preinstalled%252Fcurrent%252Fvivid-preinstalled-core-armhf.tar.gz%22%20style%3D%22color%3A%20%23772953%3B%20background-color%3A%20%23f7f6f5%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%20medium%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Evivid-preinstalled-core-armhf.tar.gz%3C%2FA%3E%3C%2FEM%3E%3C%2FSTRONG%3E%E3%81%AB%E3%81%AFGUI%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E7%AB%AF%E6%9C%AB%E3%81%AE%E3%81%BF%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%3CSTRONG%3E%3CEM%3Eapt-get%3C%2FEM%3E%3C%2FSTRONG%3E%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20inherit%3B%22%3E%E7%A7%81%E3%82%82rootfs%26nbsp%3B%3CEM%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23008000%3B%22%3Elinaro-trusty-alip-20141024-684.tar.gz%3C%2FSTRONG%3E%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82i.MX6Q%20SABRE%20SD%E3%81%A7%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81GPU%20Vivante%E3%81%AE%E6%A4%9C%E5%87%BA%E6%96%B9%E6%B3%95%E3%82%84%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20color%3A%20%2351626f%3B%20font-weight%3A%20inherit%3B%22%3E%E3%81%95%E3%82%89%E3%81%AB%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%80%81%3CEM%3E%3CSTRONG%3Ekernel-modu*%3C%2FSTRONG%3E%3C%2FEM%3E%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3B.%2Ffastbuild.sh%26nbsp%3B%26nbsp%3BBUILD_HARD_VFP%3D1%26nbsp%3BXSERVER_GREATER_THAN_13%3D1%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd..%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSTRONG%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20color%3A%20black%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd%26nbsp%3Bkernel-modu*%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bmake%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3Bgpu-core%26nbsp%3Bx11%26nbsp%3B%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%EF%BC%9A%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bbackend%3Dx11%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Kane%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBUILD_HARD_VFP%3D1%E3%81%A8XSERVER_GREATER_THAN_13%3D1%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDRI_1.10.4%2Fsrc%2F%3C%2FSPAN%3E%E3%81%AB%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%BE%E3%81%A0%E4%BB%A5%E4%B8%8B%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%8CHEAD%E3%80%8D%E3%81%8C%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9A%E5%BC%95%E6%95%B0%E3%80%8CHEAD%E3%80%8D%E3%81%8C%E3%81%82%E3%81%84%E3%81%BE%E3%81%84%EF%BC%9A%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%91%E3%82%B9%E3%81%8C%E4%BD%9C%E6%A5%AD%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%91%E3%82%B9%E3%81%A8%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%88%86%E3%81%91%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB'--'%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%3CBR%20%2F%3E'git%20%3CCOMMAND%3E%20%5B%3CREVISION%3E...%5D%20--%20%3CBR%20%2F%3E%5B%3CFILE%3E...%5D'fsl_pixmap_ext.c%3A31%3A33%3A%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9AX11%2Fextensions%2FXext.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%20%23include%20%3CX11%3E%3C%2FX11%3E%3C%2FFILE%3E%3C%2FREVISION%3E%3C%2FCOMMAND%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%9F%E9%80%9A%E3%82%8A%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CA%20class%3D%22%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcdimage.ubuntu.com%252Fubuntu-core%252Fvivid%252Fdaily-preinstalled%252Fcurrent%252Fvivid-preinstalled-core-armhf.tar.gz%22%20style%3D%22color%3A%20%23772953%3B%20background-color%3A%20%23f7f6f5%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%20medium%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Evivid-preinstalled-core-armhf.tar.gz%3C%2FA%3E%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%80%81imx6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EWenming%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%97%E3%83%A9%E3%82%BF%E3%83%A1%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%3CSTRONG%3Egit%20init%3C%2FSTRONG%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%97%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%A7ubuntu-core%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%80%81%E5%88%A5%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BE%8B%EF%BC%9A%E3%83%AA%E3%83%B3%E3%82%AF%26nbsp%3B%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%2F%22%20title%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Index%20of%20%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E%3CEM%3E%3CA%20href%3D%22http%3A%2F%2Fcdimage.ubuntu.com%2Fubuntu-core%2Fvivid%2Fdaily-preinstalled%2Fcurrent%2Fvivid-preinstalled-core-armhf.tar.gz%22%20style%3D%22color%3A%20%23772953%3B%20background-color%3A%20%23f7f6f5%3B%20font-size%3A%20medium%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evivid-preinstalled-core-armhf.tar.gz%3C%2FA%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EKane%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPratham%E6%A7%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EWenming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Ferikraynolds%22%20target%3D%22_blank%22%3Eerikraynolds%3C%2FA%3E%E2%80%8C%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CEM%3Ekernel-modu*%3C%2FEM%3E%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EKane%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20feng%2C%3C%2FP%3E%3CP%3E%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2Fdev%2Fmmcblk0p2%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99..%3C%2FSPAN%3E%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E5%A4%B1%E6%95%97%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EeMMc%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%BF%E3%83%A1%E3%83%83%E3%82%B7%E3%83%A5%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPratham%E6%A7%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E7%A7%81%E3%81%AE%20mx6dl%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%20rootfs%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82uboot%20%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%97%E3%81%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%8C%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%2Fdev%2Fmmcblk0p2%20%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99...%E3%80%8D%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EWenming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81imx6q-sabrsd%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7Ubuntu%20rootfs%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82xserver-xorg-video-imx-viv-5.0.11.p7.4%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Elinaro%20rootfs%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egcc%20-DCOMMIT%3D%22%60git%20log%20-n%201%20--format%3D%25H%60%60git%20diff-index%20--quiet%20HEAD%20%7C%7C%20echo%20'-dirty'%60%22%20-DFIX_NO_MI_BACKINGSTORE%20-fvisibility%3Dhidden%20-fPIC%20-DPIc%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E7%9A%84%3A%20Git%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%E8%A6%AA%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%EF%BC%89%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%20.git%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E7%9A%84%3A%20Git%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%E8%A6%AA%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%EF%BC%89%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%20.git%3CBR%20%2F%3Egcc%20-shared%20-fPIC%20-o%20vivante_drv.so%20vivante_gal%2Fvivante_gal_blit.o%20vivante_gal%2Fvivante_gal_gpu.ovivante_gal%2Fvivante_gal_surface.ovivante_fbde%20%3CBR%20%2F%3Emake%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%60%2Froot%2Fgpu%2Fxserver-xorg-video-imx-viv-5.0.11.p7.4%2FEXA%2Fsrc%60%20%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3Emake%3A%20***%20DRI_1.10.4%2Fsrc%2F%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%9F%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%8CUbuntu%20Core%E3%81%AErootfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9Fubuntu-core%20rootfs%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%BF%E3%83%A1%E3%82%B7%E3%83%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82gcc%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%821%E3%81%8B%E6%9C%88%E5%89%8D%E3%81%AB%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E5%A6%A8%E3%81%92%E3%82%8B%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ewandboard_dl_defconfig%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81uboot%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B9%E3%81%8C%E3%81%8A%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELD%20examples%2Fstandalone%2Fhello_world%3CBR%20%2F%3E%20OBJCOPY%20examples%2Fstandalone%2Fhello_world.srec%3CBR%20%2F%3E%20OBJCOPY%20examples%2Fstandalone%2Fhello_world.bin%3CBR%20%2F%3E%20LDS%20u-boot.lds%3CBR%20%2F%3E%20LD%20u-boot%3CBR%20%2F%3Earch%2Farm%2Fimx-common%2Fbuilt-in.o%3A%20%E9%96%A2%E6%95%B0%60print_cpuinfo'%E5%86%85%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fimx-common%2Fcpu.c%3A199%3A%20%60uclass_get_device'%3CBR%20%2F%3E%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fimx-common%2Fcpu.c%3A201%3A%20%60thermal_get_temp'%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Earch%2Farm%2Fimx-common%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%60arch_preboot_os'%E5%86%85%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Farch%2Farm%2Fimx-common%2Fcpu.c%3A270%3A%20%60ldo_mode_set'%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%60read_cpu_temperature'%E5%86%85%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A43%3A%20%60dev_get_platdata'%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A45%3A%20%60dev_get_priv'%3CBR%20%2F%3E%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%60imx_thermal_probe'%E5%86%85%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A226%3A%20%60dev_get_platdata'%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%2Fhome%2Flucid%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%2Fdrivers%2Fthermal%2Fimx_thermal.c%3A227%3A%20%60dev_get_priv'%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3ABFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git2.24.0.20141017%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%A4%B1%E6%95%97%20%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3ABFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git2.24.0.20141017%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%A4%B1%E6%95%97%20%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3ABFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git2.24.0.20141017%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%A4%B1%E6%95%97%20%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3ABFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git2.24.0.20141017%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%A4%B1%E6%95%97%20%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3ABFD%20(GNU%20Binutils)%20Linaro%202014.11-3-git2.24.0.20141017%20%E3%82%A2%E3%82%B5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%A4%B1%E6%95%97%20%2Fhome%2Ftcwg-buildslave%2Fworkspace%2Ftcwg-make-release%2Flabel%2Ftcwg-x86_64%2Ftarget%2Farm-linux-gnueabihf%2Fsnapshots%2Fbinutils-gdb.git~linaro_binutils-2_24-branch%40a93e252ee5250dba831e54f98336b40c7210dac7%2Fbfd%2Felf32-arm.c%3A7710%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E5%BF%85%E9%A0%88%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8C.rel.plt%E3%80%8D%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%2Fhome%2Flucid%2Ftoolchain%2Fgcc-linaro-4.8-2015.06-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-ld.bfd%3A%E6%9C%80%E7%B5%82%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E7%84%A1%E5%8A%B9%E3%81%AA%E6%93%8D%E4%BD%9C%3CBR%20%2F%3Emake%3A%20***%20%5Bu-boot%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3CBR%20%2F%3Elucid%40ubuntu%3A~%2Fimx6dl%2Fuboot-imx-rel_imx_3.14.52_1.1.0_ga%24%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EWF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6X11%E3%81%AEGPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81gpu_pack%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E4%BD%9C%E6%A5%AD%E3%82%92%E7%B6%9A%E3%81%91%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20class%3D%22%22%20start%3D%221%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23ffffff%3B%20border%3A%20none%3B%20font-size%3A%2012px%3B%20margin%3A%200px%200px%201px%2045px%20!important%3B%22%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bcd%26nbsp%3Bkernel-modu*%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bmake%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%26nbsp%3Bgpu-core%26nbsp%3Bx11%26nbsp%3B%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%EF%BC%9A%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22%22%20style%3D%22color%3A%20%235c5c5c%3B%20background-color%3A%20%23f6f6f6%3B%20border-top%3A%20none%3B%20border-bottom%3A%20none%3B%20border-left%3A%203px%20solid%20%236ce26c%3B%20border-right%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%20margin%3A%200px%20!important%3B%20padding%3A%200px%203px%200px%2010px%20!important%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%23%26nbsp%3Bbackend%3Dx11%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%3CEM%3Ekernel-modu*%3C%2FEM%3E%E3%81%AF%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E6%9D%A5%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3EUbuntu%20Linaro%20LXDE%20rootfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6LCD%E3%82%92%E6%A8%AA%E5%90%91%E3%81%8D%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E7%B8%A6%E5%90%91%E3%81%8D%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%9B%9E%E8%BB%A2%E3%81%95%E3%81%9B%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3EUSB%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%A8USB%E3%83%9E%E3%82%A6%E3%82%B9%E3%82%92USB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eusb_otg_vbus%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E7%A7%81%E3%81%8C%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%BE%E3%81%A0%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%9F%B3%E5%A3%B0%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%95%E3%82%92%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%BE%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%81%AE%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E3%82%84%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%82%E3%80%8Clinaro%E3%80%8D%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A8%E3%82%8A%E3%81%82%E3%81%88%E3%81%9A%E3%80%8Croot%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%82%8F%E3%81%96%E3%82%8F%E3%81%96%E8%A9%A6%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E7%94%BB%E9%9D%A2%E3%81%8C%E3%81%AA%E3%81%84%E3%81%BE%E3%81%BE%E3%81%A7%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%ABroot%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%2Fetc%2Flxdm%24%20lxdm.conf%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%5Bbase%5D%3CBR%20%2F%3E%23%23%20%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%80%81autologin%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E8%87%AA%E5%8B%95%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CSTRONG%3Eautologin%3Droot%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20uncomment%20and%20set%20timeout%20to%20enable%20timeout%20autologin%2C%3CBR%20%2F%3E%23%23%E3%81%AE%E5%80%A4%E3%81%AF%20%26gt%3B%3D5%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%23%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D10%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%85%A8%E4%BD%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%3CBR%20%2F%3Esession%3D%2Fusr%2Fbin%2Fstartlxde%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%A6%E3%80%81%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%20Num%20Lock%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%23%20numlock%3D0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20~%2F.Xauthority%20%E3%81%AB%20xauth%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%BD%AE%E3%81%8D%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%23%20xauth_path%3D%2Ftmp%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E6%AD%93%E8%BF%8E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8Bgreeter%3CBR%20%2F%3Egreeter%3D%2Fusr%2Flib%2Flxdm%2Flxdm-greeter-gtk%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5Bserver%5D%3CBR%20%2F%3E%23%23%20xserver%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%BC%95%E6%95%B0%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AB%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%23%20arg%3D%2Fusr%2Fbin%2FX%20-background%20vt1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%E8%A1%A8%E7%A4%BA%5D%3CBR%20%2F%3E%23%23%20%E3%82%B0%E3%83%AA%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20gtk%20%E3%83%86%E3%83%BC%E3%83%9E%3CBR%20%2F%3Egtk_theme%3DClearlooks%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%82%B0%E3%83%AA%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E8%83%8C%E6%99%AF%3CBR%20%2F%3Ebg%3D%2Fusr%2Fshare%2Fbackgrounds%2Fdefault.png%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E4%B8%8B%E9%83%A8%E3%83%9A%E3%82%A4%E3%83%B3%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3CBR%20%2F%3Ebottom_pane%3D1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E8%A8%80%E8%AA%9E%E9%81%B8%E6%8A%9E%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3CBR%20%2F%3Elang%3D1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Ekeyboard%3D0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%82%B0%E3%83%AA%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%86%E3%83%BC%E3%83%9E%3CBR%20%2F%3E%E3%83%86%E3%83%BC%E3%83%9E%3D%E3%82%A4%E3%83%B3%E3%83%80%E3%82%B9%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5Binput%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5Buserlist%5D%3CBR%20%2F%3E%23%23%E3%82%B0%E3%83%AA%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E7%94%BB%E9%9D%A2%E3%81%A7%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AE%E5%88%B6%E5%BE%A1%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3CBR%20%2F%3Edisable%3D0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3Ewhite%3D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%3D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%E3%80%8Cstartlxde%E3%80%8D%E3%81%8B%E3%82%89%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%89%E3%80%81%E3%81%9C%E3%81%B2%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Egstreamer-imx%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82LXDE%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E7%94%BB%E9%9D%A2%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81GUI%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%97%E3%81%A6CTRL%2BALT%2BF1%E3%81%A7%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E5%86%8D%E5%BA%A6root%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81TRL%2BALT%2BF7%E3%81%A7%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%80%81root%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EErik%2C%3C%2FP%3E%3CP%3Exorg%E3%81%A8xinit%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E5%BE%8C%E3%81%AB%E3%80%8Cstartx%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%80%82%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AFPC%E3%83%9B%E3%82%B9%E3%83%88%E5%81%B4%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81UART%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E8%87%AA%E4%BD%93%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E7%94%BB%E9%9D%A2%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E9%80%9A%E9%81%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%9F%E9%80%9A%E3%82%8A%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erik%2C%3C%2FP%3E%3CP%3ELinaro%20LXDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%AF%2Fetc%2Finit.d%2F%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%82%8Blxdm%E3%81%A7%E3%81%99%E3%80%82Lxdm%E3%81%AF%E3%81%9D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%2Fetc%2Flxdm%2Flxdm.conf%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%80%8Cstartx%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%20%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwiki.archlinux.org%2Findex.php%2FLXDM%22%20title%3D%22https%3A%2F%2Fwiki.archlinux.org%2Findex.php%2FLXDM%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELXDM%20-%20ArchWiki%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJaffin%E6%A7%98%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%99%E3%80%82%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%A9%9F%E4%BC%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erik%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%20startx%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E9%9D%A2%E4%B8%8A%E3%81%AB%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E7%92%B0%E5%A2%83%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AFstartlxde%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%80%81%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AF%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81startx%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E6%9C%9B%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E5%BE%8C%E3%81%A71%E3%81%A4%E3%81%AEGUI%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A0%E3%81%91%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E6%9C%9B%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erik%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6%20QP%20Sabre%20Board%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81GUI%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%8B%E3%82%89%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BB%8A%E6%97%A5%E3%81%AF%E5%88%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82gstreamer-imx%E3%81%A8%E3%81%9D%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82'gst-inspect-1.0%20-b'%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Flibgstimxaudio.so'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%20lib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%20lib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%20lib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%20lib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%80%8C%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so%E3%80%8D%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82lib_mp3_enc_arm12_elinux.so.2%EF%BC%9A%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%80%8C%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so%E3%80%8D%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82lib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A8983)%3A%20GStreamer-WARNING%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%80%8C%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so%E3%80%8D%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82lib_mp3_enc_arm12_elinux.so.2%EF%BC%9A%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A%208983)%3A%20GStreamer-Warning%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%3A%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E(gst-plugin-scanner%3A%208983)%3A%20GStreamer-Warning%20**%3A%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20'%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Fgstreamer-1.0%2Flibgstimxaudio.so'%3A%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Alib_mp3_enc_arm12_elinux.so.2%EF%BC%9A%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%9A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9A%3CBR%20%2F%3Elibgstimxaudio.so%3C%2FP%3E%3CP%3E%E5%90%88%E8%A8%88%E6%95%B0%EF%BC%9A%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB1%E4%BB%B6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Efsl%E3%83%93%E3%83%87%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%A8%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AB%E3%80%81%E3%81%AA%E3%81%9C%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A0%E3%81%91%E3%81%8C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%9F%E3%81%A9%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%85%B1%E6%9C%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%91%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%AEimx%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%81%93%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A8%E3%81%A6%E3%82%82%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AFLinaro%20LXDE%E3%81%AErootfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88Ubuntu%E3%81%AE%E3%82%B3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%82%E4%B8%80%E5%9B%A0%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E3%81%82%E3%81%A1%E3%81%93%E3%81%A1%E3%81%A7%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%9F%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E9%99%A4%E3%81%91%E3%81%B0%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%82%B7%E3%82%A7%E3%83%AB%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AF%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%E3%80%8Croot%E3%80%8D%E3%81%A8%E3%80%8Clinaro%E3%80%8D%E3%82%92%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AA%E3%81%97%E3%81%A7%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%EF%BC%88%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81root%E3%81%8A%E3%82%88%E3%81%B3linaro%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8B%E3%82%89%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%EF%BC%89%E3%80%81%E3%81%BE%E3%81%A0%E5%90%8C%E3%81%98%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E7%95%99%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%80%9A%E9%81%8E%E3%81%97%E3%81%A6GUI%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%96%E3%81%AE%E6%96%B9%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E4%BD%95%E3%81%8B%E8%A6%8B%E9%80%83%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%80%81%E5%88%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELinaro%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%A6%E3%80%8114.10%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%80%81PC%E3%81%8B%E3%82%89%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EHDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background-color%3A%20%23ffffff%3B%22%3E3%EF%BC%9ARootfs%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%80%81sources.list%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AB%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9B%E3%82%B9%E3%83%88PC%E3%81%A7%E5%A4%89%E6%9B%B4%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%81%9D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E5%8F%8D%E6%98%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E2%80%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EU-Boot%202016.03%20(2016%E5%B9%B411%E6%9C%884%E6%97%A5%20-%2011%3A24%3A24%20%2B0100)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6QP%20rev1.0%20996%20MHz%EF%BC%88792%20MHz%20%E3%81%A7%E5%8B%95%E4%BD%9C%E4%B8%AD%EF%BC%89%3CBR%20%2F%3ECPU%EF%BC%9A31C%E3%81%AE%E8%87%AA%E5%8B%95%E8%BB%8A%E7%94%A8%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%EF%BC%88-40C%20%EF%BD%9E%20125C%EF%BC%89%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%8E%9F%E5%9B%A0%EF%BC%9APOR%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%9AMX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%EF%BC%9A%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3EPMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%3A%200%20MiB%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%2C%20FSL_SDHC%3A%201%3CBR%20%2F%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7Hannstar-XGA%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%EF%BC%9AHannstar-XGA%20(1024x768)%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3A%20FEC%20%5BPRIME%5D%3CBR%20%2F%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%820%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3Eboot.scr%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E**%20boot.scr%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93**%3CBR%20%2F%3EzImage%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E6637656%E3%83%90%E3%82%A4%E3%83%88%E3%82%92328%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%8819.3%20MiB%2F%E7%A7%92%EF%BC%89%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emmc%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3Eimx6qp-sabreauto.dtb%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E48853%E3%83%90%E3%82%A4%E3%83%88%E3%82%9220%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%882.3%20MiB%2F%E7%A7%92%EF%BC%89%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%40%200x12000000%20%5B%200x000000%20-%200x654858%20%5D%3CBR%20%2F%3E%23%23%2018000000%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%BB%E3%83%84%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%96%E3%83%AD%E3%83%96%3CBR%20%2F%3E0x18000000%E3%81%AEfdt%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E18000000%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%BB%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%811800eed4%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%E7%89%A9%E7%90%86%20CPU%200x0%20%E3%81%A7%20Linux%20%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%A7%E3%81%99%3CBR%20%2F%3ELinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.1.15(r59400%40Latitude)%20(gcc%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.8.5%20(Linaro%20GCC%204.8-2015.06)%20)%20%231%20SMP%20PREEMPT%202016%E5%B9%B411%E6%9C%884%E6%97%A5%2011%3A53%3A43%20CET%3CBR%20%2F%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%A2%E3%83%87%E3%83%AB%3A%20Freescale%20i.MX6%20Quad%20Plus%20SABRE%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%3A%200x6a000000%20%E3%81%AB%20CMA%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%20320%20MiB%3CBR%20%2F%3E%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%E3%83%8E%E3%83%BC%E3%83%89%20linux%2Ccma%E3%80%81%E4%BA%92%E6%8F%9B%20ID%20shared-dma-pool%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3CBR%20%2F%3EPERCPU%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%2012%20%E3%83%9A%E3%83%BC%E3%82%B8%2FCPU%20%40ee6fe000%20s16960%20r8192%20d24000%20u49152%3CBR%20%2F%3E1%20%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB%E6%A7%8B%E7%AF%89%E3%80%81%E7%A7%BB%E5%8B%95%E6%80%A7%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E6%9C%89%E5%8A%B9%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A%20520%2C720%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk2p2%20rootwait%20rw%3CBR%20%2F%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016%2C384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20262%2C144%20(%E9%A0%86%E5%BA%8F%3A%208%2C%201%2C048%2C576%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EInode%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131%2C072%20(%E9%A0%86%E5%BA%8F%3A%207%2C%20524%2C288%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A%201%2C737%2C928K%2F2%2C097%2C152K%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%20(8%2C295K%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81435K%20rwdata%E3%80%812%2C892K%20rodata%E3%80%81432K%20init%E3%80%81450K%20bss%E3%80%8131%2C544K%20%E4%BA%88%E7%B4%84%E3%80%81327%2C680K%20cma-%E4%BA%88%E7%B4%84%E3%80%81270%2C336K%20%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA)%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%EF%BC%9A0xffff0000%20-%200xffff1000%20(%204%20kB)%3CBR%20%2F%3E%E5%9B%BA%E5%AE%9A%E3%83%9E%E3%83%83%E3%83%97%EF%BC%9A0xffc00000%20-%200xfff00000%20(3%2C072%20kB)%3CBR%20%2F%3Evmalloc%20%3A%200xf0000000%20-%200xff000000%20(%20240%20MB)%3CBR%20%2F%3Elowmem%20%3A%200x80000000%20-%200xef800000%20(1%2C784%20MB)%3CBR%20%2F%3Epkmap%20%3A%200x7fe00000%20-%200x80000000%20(%202%20MB)%3CBR%20%2F%3Emodules%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3CBR%20%2F%3E.text%3A%200x80008000%20-%200x80af51c8%20(11189%20kB)%3CBR%20%2F%3E%20.init%3A%200x80af6000%20-%200x80b62000%20(%20432%20kB)%3CBR%20%2F%3E%20.data%3A%200x80b62000%20-%200x80bcec40%20(%20436%20KB)%3CBR%20%2F%3E%20.bss%3A%200x80bd1000%20-%200x80c41a5c%20(%20451%20kB)%3CBR%20%2F%3ESLUB%3A%20HWalign%3D64%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D4%E3%80%81Nodes%3D1%3CBR%20%2F%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3E%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%AE%20CPU%20%E6%83%85%E5%A0%B1%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3EL2C-310%20erratum%20769419%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3CBR%20%2F%3EL2C-310%20Cortex-A9%20%E7%94%A8%E3%81%AE%E6%97%A9%E6%9C%9F%20BRESP%20%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3CBR%20%2F%3EL2C-310%20Cortex-A9%E7%94%A8%E3%81%AE%E3%83%95%E3%83%AB%E3%82%BC%E3%83%AD%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3CBR%20%2F%3EL2C-310%20ID%E3%83%97%E3%83%AA%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%8816%E8%A1%8C%3CBR%20%2F%3EL2C-310%E3%83%80%E3%82%A4%E3%83%8A%E3%83%9F%E3%83%83%E3%82%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3CBR%20%2F%3EL2C-310%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%E3%80%8116%E3%82%A6%E3%82%A7%E3%82%A4%E3%80%811024%20kB%3CBR%20%2F%3EL2C-310%3A%20CACHE_ID%200x410000c8%2C%20AUX_CTRL%200x76470001%3CBR%20%2F%3Emxc_clocksource_init%203000000%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333nss%3CBR%20%2F%3Eched_clock%3A%2032%E3%83%93%E3%83%83%E3%83%88%E3%80%813000kHz%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%81715827882841ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3CBR%20%2F%3Eclocksource%20mxc_timer1%3A%20%E3%83%9E%E3%82%B9%E3%82%AF%3A%200xffffffff%20%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E6%95%B0%3A%200xffffffff%E3%80%81%E6%9C%80%E5%A4%A7%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E6%99%82%E9%96%93%3A%20637086815595%20ns%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2080x30%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97)%E3%80%81%E5%80%A4%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F...6.00%20BogoMIPS%20(lpj%3D30000)%3CBR%20%2F%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ECPU%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%83%86%E3%82%B9%E3%83%88%3A%20OK%3CBR%20%2F%3ECPU0%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%2C%20CPU%200%2C%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%2C%20mpidr%2080000000%3CBR%20%2F%3E0x10008280%20-%200x100082d8%20%E7%94%A8%E3%81%AE%E9%9D%99%E7%9A%84%E3%82%A2%E3%82%A4%E3%83%87%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E8%A8%AD%E5%AE%9A%E4%B8%AD%3CBR%20%2F%3ECPU1%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%2C%20CPU%201%2C%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%2C%20mpidr%2080000001%3CBR%20%2F%3ECPU2%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%2C%20CPU%202%2C%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%2C%20mpidr%2080000002%3CBR%20%2F%3ECPU3%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%2C%20CPU%203%2C%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%2C%20mpidr%2080000003%3CBR%20%2F%3E4%E3%81%A4%E3%81%AEPU%20%E3%82%92%E8%B5%B7%E5%8B%95%3CBR%20%2F%3ESMP%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E7%B7%8F%E6%95%B0%3A%204%20(24.00%20BogoMIPS)%E3%80%82%3CBR%20%2F%3ECPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECPU%E3%81%8CSVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%80%82%3CBR%20%2F%3Edevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20%E5%AE%9F%E8%A3%85%E8%80%85%2041%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%203%20%E3%83%91%E3%83%BC%E3%83%88%2030%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%209%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%204%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%20jiffies%3A%20%E3%83%9E%E3%82%B9%E3%82%AF%3A%200xffffffff%20%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3A%200xffffffff%E3%80%81%E6%9C%80%E5%A4%A7%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%20ns%3A%2019112604462750000%20nspinctrl%20%3CBR%20%2F%3E%E3%82%B3%E3%82%A2%3A%20pinctrl%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2016%20%E3%82%92%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3EDMA%3A%20%E5%8E%9F%E5%AD%90%E7%9A%84%E3%81%AA%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB%20256%20KiB%20%E3%81%AE%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%AD%3CBR%20%2F%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%AD%3CBR%20%2F%3ECPU%20%E3%81%AF%20i.MX6QP%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%201.0%20%E3%81%A8%E3%81%97%E3%81%A6%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ehw-breakpoint%3A%205%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(%2B1%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF)%20%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%3A%20%E6%9C%80%E5%A4%A7%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%2Fsoc%2Faips-bus%4002000000%2Fiomuxc%40020e0000%2Fhdmicecgrp%20%E3%81%AB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3AIMX%E3%83%94%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-gpc%2020dc000.gpc%EF%BC%9Afsl%E3%80%81ldo-bypass%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%3CBR%20%2F%3Emxs-dma%20110000.dma-apbh%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20hub%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E2000000.aips-bus%3Ausbphy_nop1VCC%E3%81%AE%E4%BE%9B%E7%B5%A6%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2000000.aips-bus%3Ausbphy_nop2%E4%BE%9B%E7%B5%A6VCC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97i2c%20i2c-1%3A%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ei2c%20i2c-2%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ei2c%20i2c-2%3A%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20v2.00pps_core%3A%20LinuxPPS%20API%20ver.%201%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CSPAN%3Epps_core%3A%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-ipuv3%202400000.ipu%EF%BC%9AIPU%20DMFC%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3A%201%EF%BC%880%EF%BD%9E1%EF%BC%89%E3%80%815B%EF%BC%884%2C5%EF%BC%89%E3%80%815F%EF%BC%886%2C7%EF%BC%89%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3A%20IPU%20DMFC%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A1%EF%BC%880%EF%BD%9E1%EF%BC%89%E3%80%815B%EF%BC%884%2C5%EF%BC%89%E3%80%815F%EF%BC%886%2C7%EF%BC%89%3CBR%20%2F%3Eimx-prg%2021cc000.prg%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%3CBR%20%2F%3Eimx-prg%2021cd000.prg%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%3CBR%20%2F%3Eimx-pre%2021c8000.pre%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%3CBR%20%2F%3Eimx-pre%2021c9000.pre%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%3CBR%20%2F%3Eimx-pre%2021ca000.pre%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%3CBR%20%2F%3Eimx-pre%2021cb000.pre%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAdvanced%20Linux%20Sound%20Architecture%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EBluetooth%3A%20%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.20%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2031%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20L2CAP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20SCO%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%20mxc_timer1%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%202%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2016384%20(%E9%A0%86%E5%BA%8F%3A%204%2C%2065536%20%E3%83%90%E3%82%A4%E3%83%88)TCP%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2016384%20(%E9%A0%86%E5%BA%8F%3A%205%2C%20131072%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(%E7%A2%BA%E7%AB%8B%2016384%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%2016384)%3CBR%20%2F%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%201%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ERPC%3A%20%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ECPU%20PMU%3A%20%2Fsoc%2Fpmu%2Finterrupt-affinity%5B0%5D%E3%81%AE%E8%A7%A3%E6%9E%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ehw%20perfevents%3A%20armv7_cortex_a9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%80%817%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3Eimx%20rpmsg%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Efutex%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E3%82%AA%E3%83%BC%E3%83%80%E3%83%BC%3A%204%2C%2065536%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EVFS%3A%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%20dquot_6.6.0%3CBR%20%2F%3EVFS%3A%20Dquot-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A1024%EF%BC%88%E9%A0%86%E5%BA%8F%200%E3%80%814096%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3ENFS%3A%20id_resolver%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_resolver%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_legacy%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ejffs2%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3Efuse%20init%20(API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.23)%3CBR%20%2F%3Ebounce%3A%20%E3%83%97%E3%83%BC%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%20%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3Eio%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%20noop%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eio%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%20deadline%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eio%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%20cfq%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_sdc_fb%20fb%400%3A%20mxc%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ldb%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3AIPU%20DMFC%20DP%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%201(0%2C1)%E3%80%815B(2%EF%BD%9E5)%E3%80%815F(6%2C7)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9128x48%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%20%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FHDMI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%200x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%20%E5%90%8D%20-%202.073M9%3CBR%20%2F%3Emxc_sdc_fb%20fb%401%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AEmxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90hdmi%3CBR%20%2F%3Emxc_sdc_fb%20fb%402%3A%20mxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%81%3CBR%20%2F%3Emxc_sdc_fb%20fb%403%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AEmxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ldb%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3AEDID%20%E3%82%92%E5%86%8D%E5%BA%A6%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80imx-sdma%2020ec000.sdma%EF%BC%9AIRAM%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%A4%96%E9%83%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%86%8D%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%203.3%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A%202%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A%201%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20FAB%3A%200%E3%80%81FIN%3A%200%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20pfuze100%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E21ec000.serial%3AMMIO%200x21ec000%20(irq%20%3D%20298%2C%20base_baud%20%3D%205000000)%20%E3%81%AE%20ttymxc2%20%E3%81%AF%20IMX%3CBR%20%2F%3E21f0000.serial%20%E3%81%A7%E3%81%99%E3%80%82ttymxc3%20%E3%81%AF%20MMIO%200x21f0000%20(irq%20%3D%20299%2C%20base_baud%20%3D%205000000)%20%E3%81%AB%E3%81%82%E3%82%8B%20IMX%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3Econsole%20%5Bttymxc3%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3Eimx%20sema4%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F20060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E3%82%92minor%200%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ebrd%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Esi476x-core%201-0063%3A%20IRQ%20%E7%95%AA%E5%8F%B7%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%890x11%E3%81%AE%E9%80%81%E4%BF%A1%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E9%9B%BB%E6%BA%90%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Ctransmit-level-mV%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8100000024%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Ctransmit-boost-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8100000480%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%E3%80%81transmit-atten-16ths%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%8100002000%20%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Creceive-eq-mdB%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%8105000000%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%3ASSS%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%83%90%E3%82%B9%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ahci-imx%202200000.sata%EF%BC%9AAHCI%200001.0300%2032%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%201%20%E3%83%9D%E3%83%BC%E3%83%88%203%20Gbps%200x1%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89ahci-imx%202200000.sata%3A%20%E3%83%95%E3%83%A9%E3%82%B0%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%3CBR%20%2F%3Escsi%20host0%3A%20ahci-imx%3CBR%20%2F%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02203fff%5D%20port%200x100%20irq%20313%3CBR%20%2F%3ECAN%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E2188000.ethernet%20%E4%BE%9B%E7%B5%A6%20PHY%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Epps%20pps0%3A%20%E6%96%B0%E3%81%97%E3%81%84%20PPS%20%E3%82%BD%E3%83%BC%E3%82%B9%20ptp0%3CBR%20%2F%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3Efec%202188000.ethernet%20eth0%3A%20PHC%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9Fehci_hcd%3A%20USB%202.0%E3%80%8CEnhanced%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eehci-mxc%3A%20Freescale%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%20EHCI%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb-storage%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb_ehset_test%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2184800.usbmisc%20%E4%BE%9B%E7%B5%A6%20vbus-wakeup%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eimx_usb%202184000.usb%3Aci_hdrc%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3Eimx_usb%202184200.usb%3Aci_hdrc%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3Emousedev%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AB%E5%85%B1%E9%80%9A%E3%81%AE%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Eegalax_ts%201-0004%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eegalax_ts%3A%201-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2-0044%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%9A%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20isl29023%20%E5%85%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%20%2Fdevices%2Fvirtual%2Finput%2Finput1%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eisl29023%202-0044%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.0%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3Esnvs_rtc%2020cc000.snvs%3Asnvs-rtc-lp%3Artc%20%E3%82%B3%E3%82%A2%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%2020cc000.snvs%3Asnvs-rrtc0%20%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3Ei2c%20%2Fdev%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3EIR%20NEC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC5(x%2Fsz)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC6%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20JVC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20Sony%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20SANYO%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20Sharp%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20MCE%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ER%20XMP%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%20video16%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%20video17%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%20video18%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%20video19%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%20video20%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2-000e%20%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E2-000e%20%E9%9B%BB%E6%BA%90%20vddio%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Emag3110%202-000e%3A%20mag3110%20%E3%83%81%E3%83%83%E3%83%97%20ID%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20mag3110%20%E3%81%8C%20%2Fdevices%2Fvirtual%2Finput%2Finput2%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emag3110%202-000e%3A%20mag3110%20%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2-001c%20%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E2-001c%20%E9%9B%BB%E6%BA%90%20vddio%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20mma845x%20%E3%81%8C%20%2Fdevices%2Fvirtual%2Finput%2Finput3%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx2-wdt%2020bc000.wdog%3A%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%2060%20%E7%A7%92%20(nowayout%3D0)%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ver%202.3%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20H4%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20BCSP%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20ATH3K%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Eata1%3A%20SATA%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%80%E3%82%A6%E3%83%B3%20(SStatus%200%20SControl%20300)%3CBR%20%2F%3Eahci-imx%202200000.sata%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20bcm203x%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ath3k%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eahci-imx%202200000.sata%3Aahci_imx..hotplug%3D1%20%E3%82%92%E6%B8%A1%E3%81%97%E3%81%A6%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Esdhci%3A%20Copyright%20(c)%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%3A%20SDHCI%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8OF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%4002190000%3A%20%E9%9B%BB%E5%9C%A7%E7%AF%84%E5%9B%B2%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Esdhci-esdhc-imx%202190000.usdhc%3A%20CD%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202190000.usdhc%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Avmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Esdhci-esdhc-imx%202190000.usdhc%3Avqmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc0%3A%202190000.usdhc%20%5B2190000.usdhc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%4002198000%20%E3%82%92%E4%BD%BF%E7%94%A8%3A%20%E9%9B%BB%E5%9C%A7%E7%AF%84%E5%9B%B2%E6%9C%AA%E6%8C%87%E5%AE%9A%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3A%20CD%20GPIO%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3AGot%20WP%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3A%20vqmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc2%3A%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%202198000.usdhc%20%5B2198000.usdhc%5D%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99ADMA%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%AD%3CBR%20%2F%3E218c000.mlb%E3%81%AE%E4%BE%9B%E7%B5%A6reg_nvcc%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%AD%3CBR%20%2F%3Emxc_mlb150%20218c000.mlb%EF%BC%9Aenalbe%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%3CBR%20%2F%3Emxc_vpu%202040000.vpu_fsl%EF%BC%9AVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_vdoa%2021e4000.vdoa%EF%BC%9Ai.MX%20%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%E3%83%8E%E3%83%BC%E3%83%89%20hdmicecgrp%20%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%EF%BC%9A%E3%83%8E%E3%83%BC%E3%83%89%20hdmicecgrp%20%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emxc_hdmi_cec%20soc%3Ahdmi_cec%4000120000%3A%20CEC%20pinctrl%20%E3%82%92%E5%8F%96%E5%BE%97%2F%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3EGalcore%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%205.0.11.41671%3CBR%20%2F%3Emmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200007%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E8%B6%85%E9%AB%98%E9%80%9F%20SDR104%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3Emmcblk2%3A%20mmc2%3A0007%20SD32G%2028.9%20GiB%3CBR%20%2F%3Emmcblk2%3A%20p1%20p2%3CBR%20%2F%3Ecaam%202100000.caam%3A%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E9%81%85%E5%BB%B6%20%3D%203200%3CBR%20%2F%3Ecaam%202100000.caam%EF%BC%9A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH0caam%202100000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH1caam%202100000.caam%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%20%3D%200x0a16010000000000%EF%BC%88Era%20-524%EF%BC%89%3CBR%20%2F%3Ecaam%202100000.caam%3A%20%E3%82%B8%E3%83%A7%E3%83%96%E3%83%AA%E3%83%B3%E3%82%B0%20%3D%202%E3%80%81qi%20%3D%200caam%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%20%2Fproc%2Fcrypto%20%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99caam_jr%202101000.jr0%3Arng-caam%20%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20blkkey_ex%3A%204%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%20b1%2020%207c%200a%208a%2086%2061%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20f0%2019%2001%2046%2038%2076%20bd%2049%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%202f%2006%2082%201f%20cc%20b0%2035%201f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2072%2003%20b1%20f3%20aa%20e0%203e%20b0%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%201b%20b3%20ad%2095%20d0%2024%2081%209a%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20fd%20b9%20b8%204c%2055%2017%2092%20c4%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%20ae%20af%20b5%206a%20ea%2059%2001%204f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%201b%20be%20de%20e8%20dd%205c%208b%2010%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20cf%20f7%2016%2054%202e%207b%2019%20e0%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20fe%2096%208c%208b%203e%201b%20b3%20f0%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2038%2035%20bc%2080%2067%2035%20ed%2058%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20e1%20dd%2073%2011%2085%208b%2010%201f%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%E3%83%93%E3%83%83%E3%83%88%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20196%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D00%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%20blob%20%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%207c%2066%201b%2086%202d%201c%20b7%202d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2020%201f%20bb%20eb%20b4%2000%201c%2056%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D8f%20b7%2046%20a6%2040%2058%2028%2049%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2055%20a0%2050%201c%2058%201d%2043%20a9%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%2006%203c%2086%2013%20da%207d%20c1%206a%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0040%5D%203b%2009%2077%20ee%203a%20ee%203f%20e6%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%207e%20be%2058%2092%20f4%20b9%201d%204a%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%E3%83%96%E3%83%AD%E3%83%96%E5%86%85%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D61%20a7%20fd%2069%20ac%2006%203c%2035%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2055%20aa%2049%2066%20c1%20d2%20ee%2049%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2004%20af%2080%204a%20fe%2033%2092%20ab%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D9c%20a7%20c3%2082%2025%2053%2080%2063%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%2022%203e%2089%209a%20e6%20d8%20a6%2054%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20c6%20e6%20f7%2034%20b6%201f%202c%209e%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%205e%2096%2089%205e%20a6%20fc%207f%2087%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2020%205f%207a%2016%2011%203b%20e7%20ce%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%E3%83%96%E3%83%AD%E3%83%96%E5%86%85%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2023%202c%20cb%201b%2073%20ab%207d%2023%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20f4%20b0%20f7%2092%20b2%2078%200d%204c%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%20b7%20ba%201e%204d%2005%206d%2031%20f5%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20ce%20c9%20fd%200a%20ce%2039%20eb%2094%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%20cb%20b1%2033%2041%20b7%20f7%206b%2026%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0040%5D%2044%2080%20d7%2026%2036%2025%20ad%2073%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0048%5D%2087%20a0%2051%2029%2082%207f%209c%20d8%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D2f%2075%2098%205f%20b7%2050%20f3%20db%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%20b3%2039%2017%20c7%20c9%2090%20c8%2026%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%E3%83%96%E3%83%AD%E3%83%96%E5%86%85%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2049%20ff%205a%20d8%2079%2044%20e7%2067%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2096%2087%2075%20f6%205c%208a%202e%20df%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%20ae%20cc%20a1%20b6%204a%2031%20f6%20e8%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%208d%20fd%20ad%208b%2007%20f3%20e8%20b0%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%20c0%2058%2018%209b%20ae%2002%20bb%20ce%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2038%20fb%2044%20db%2004%2067%201b%20c7%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%202c%2015%2075%2041%208d%20c1%2077%20cf%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%20a1%2068%20de%2068%202d%20cd%2024%20e7%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%20d5%207e%20e3%2022%20eb%207a%2021%209d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0072%5D%2063%2067%20cf%203b%2032%2019%20e0%2003%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2095%20c8%20a2%20bc%20ac%202e%208e%20d7%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20f7%20cc%20fa%205b%20b6%20a5%205b%204b%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%202f%2006%2082%201f%20cc%20b0%2035%201f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2072%2003%20b1%20f3%20aa%20e0%203e%20b0%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%201b%20b3%20ad%2095%20d0%2024%2081%209a%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20fd%20b9%20b8%204c%2055%2017%2092%20c4%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%205f%2082%2048%2034%20d8%20cb%2015%20a9%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20b0%206c%20fe%20c8%20ee%208e%20cd%2021%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%20cf%20f7%2016%2054%202e%207b%2019%20e0%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20fe%2096%208c%208b%203e%201b%20b3%20f0%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2038%2035%20bc%2080%2067%2035%20ed%2058%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20e1%20dd%2073%2011%2085%208b%2010%201fsnvs-secvio%2020cc000.caam-snvs%3Asnvs%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93snvs-secvio%2020cc000.caam-snvs%3A%E9%81%95%E5%8F%8D%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E8%B5%B7%E5%8B%95%20-%20%E9%9D%9E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E7%8A%B6%E6%85%8Busbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2usbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90cs42xx8%201-0048%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BA%E8%A6%8B%E3%80%81%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%204fsl-asrc%202034000.asrc%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fimx-cs42888%20sound-cs42888%3A%20cs42888%26lt%3B-%26gt%3B%202024000.esai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OKimx-cs42888%20sound-cs42888%3A%20snd-soc-dummy-dai%26lt%3B-%26gt%3B%202034000.asrc%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OKimx-cs42888%20sound-cs42888%3A%20cs42888%26lt%3B-%26gt%3B%202024000.esai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OKimx-spdif%20sound-spdif%3A%20snd-soc-dummy-dai%26lt%3B-%26gt%3B%202004000.spdif%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OKimx-tuner-si476x%20sound-fm%3A%20FM%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9Fimx-tuner-si476x%3A%20sound-fm%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9Fimx-audio-hdmi%20sound-hdmi%3A%20hdmi-hifi%26lt%3B-%26gt%3B%20soc%3Ahdmi_audio%4000120000%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OKNET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC26%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FNET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC10%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fsit%3A%20IPv6%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC17%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fcan%3A%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2%20(rev%2020120528%20abi%209)NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC29%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fcan%3A%20raw%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528)can%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528%20t)can%3A%20netlink%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%20(rev%2020130117)%20max_hops%3D1Bluetooth%3A%20RFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20RFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20RFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11Bluetooth%3A%20BNEP%20(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.3Bluetooth%3A%20BNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88Bluetooth%3A%20BNEP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.2Bluetooth%3A%20HIDP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F8021q%3A%20802.1Q%20VLAN%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97dns_resolver%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fcan-stby%3A%20can-en%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99flexcan%202094000.flexcan%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(reg_base%3Df0648000%E3%80%81irq%3D31)%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.0%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9ci_hdrc%20ci_hdrc.0%3A%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B7%201%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ci_hdrc%20ci_hdrc.0%3AUSB%202.0%20%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81EHCI%201.00%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fci_hdrc%20ci_hdrc.1%3AEHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9ci_hdrc%20ci_hdrc.1%3A%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B7%202%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fci_hdrc%20ci_hdrc.1%3AUSB%202.0%20%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81EHCI%201.00%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Edhd_module_init%20in%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20gpio-keys%20as%20%2Fdevices%2Fsoc0%2Fgpio-keys%2Finput%2Finput4%3CBR%20%2F%3Esnvs_rtc%2020cc000.snvs%3Asnvs-rtc-lp%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A02%20UTC%20%E3%81%AB%E8%A8%AD%E5%AE%9A%20(2)%3CBR%20%2F%3Ecan-stby%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3Ecan-en%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3EVGEN2%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3ESWBST%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3ESW4%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3CBR%20%2F%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%B9%E3%83%88%3A%3CBR%20%2F%3E%20%230%3A%20cs42888-audio%3CBR%20%2F%3E%20%231%3A%20imx-spdif%3CBR%20%2F%3E%20%232%3A%20imx-hdmi-soc%3CBR%20%2F%3Eusb%201-1%3A%20ci_hdrc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%202%3CBR%20%2F%3E%E3%83%8F%E3%83%96%201-1%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%8F%E3%83%96%201-1%3A1.0%3A%204%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusb%201-1.2%3A%20ci_hdrc%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B73%E5%85%A5%E5%8A%9B%3A%20DELL%20DELL%20USB%E3%83%AC%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%82%A6%E3%82%B9%E3%82%92%20%2Fdevices%2Fsoc0%2Fsoc%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.2%2F1-1.2%3A1.0%2F0003%3A046D%3AC063.0001%2Finput%2Finput5%20%E3%81%A8%E3%81%97%E3%81%A6hid-generic%200003%3A046D%3AC063.0001%3A%E5%85%A5%E5%8A%9B%3A%20USB%20HID%20v1.10%20%E3%83%9E%E3%82%A6%E3%82%B9%20%5BDELL%20DELL%20USB%20%E3%83%AC%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%82%A6%E3%82%B9%5D%20on%20usb-ci_hdrc.0-1.2%2Finput0usb%201-1.3%3A%20ci_hdrc%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B74%E5%85%A5%E5%8A%9B%3A%20Dell%20QuietKey%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%20%2Fdevices%2Fsoc0%2Fsoc%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.3%2F1-1.3%3A1.0%2F0003%3A413C%3A2106.0002%2Finput%2Finput6hid-generic%200003%3A413C%3A2106.0002%3A%E5%85%A5%E5%8A%9B%EF%BC%9AUSB%20HID%20v1.10%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20%5BDell%20Dell%20QuietKey%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%5D%20on%20usb-ci_hdrc.0-1.3%2F%E5%85%A5%E5%8A%9B0kjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92EXT3-fs%20(mmcblk2p2)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8EXT3-fs%20(mmcblk2p2)%3A%20%E5%BE%A9%E6%97%A7%E5%AE%8C%E4%BA%86EXT3-fs%20(mmcblk2p2)%3A%20%E9%A0%86%E5%BA%8F%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0VFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A2%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82devtmpfs%3A%3CBR%20%2F%3E%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20432K%20(80af6000%20-%2080b62000)%3CBR%20%2F%3E%2Fsys%2Ffs%2Fselinux%20%E4%B8%8A%E3%81%AE%20selinuxfs%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%20init%20urandom%20%E3%81%AF%2034%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Einit%3Aplymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(175)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Einit%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Einit%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(185)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Einit%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Einit%3Aplymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(189)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Einit%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Einit%3A%20ureadahead%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(178)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%205%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Einit%3A%20mounted-proc%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(204)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EDBG%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%207f010188%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%E5%81%9C%E6%AD%A2%20plymouth%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%20sysvinit%20%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Fdev%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Fdev%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Ftmp%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Frun%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Ftmp%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Frun%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20upstart%20%E3%81%8C%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E8%BF%BD%E8%B7%A1%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20resolvconf%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%80%E7%B5%82%E5%8C%96%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E*%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E4%BB%AE%E6%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%20sysvinit%20%E3%81%AB%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E4%BB%AE%E6%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%20sysvinit%20%E3%81%AB%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20udev%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%20upstart%20%E3%81%AB%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%97%E3%81%BE%E3%81%99%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%A7sysvinit%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%A7sysvinit%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Fetc%2Fmodules%E3%81%8B%E3%82%89%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%89%E3%83%97%E3%83%A9%E3%82%B0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E5%88%9D%E6%9C%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%BD%9C%E6%88%90%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%2Fetc%2Fmodules%20%E3%81%8B%E3%82%89%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E6%97%A9%E6%9C%9F%E3%82%B8%E3%83%A7%E3%83%96%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%AD%E3%82%B0%E3%81%B8%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E6%97%A9%E6%9C%9F%E3%82%B8%E3%83%A7%E3%83%96%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%AD%E3%82%B0%E3%81%B8%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20D-Bus%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20SystemD%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E7%AE%A1%E7%90%86%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%B3%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20plymouth%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20Bluetooth%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20plymouth%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20mDNS%2FDNS-SD%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20daemon%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20avahi-daemon%20%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%20q%5B%20OK%20%5D%20%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81cups%20%E3%82%92%E5%86%8D%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20avahi-daemon%20%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%20q%5Bfail%5D%20%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81cups%20%E3%82%92%E5%86%8D%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20System%20V%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20X%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%5B%20OK%20%5D%3CBR%20%2F%3E%20*%20System%20V%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%5B%20OK%20%5D%3C%2FP%3E%3CP%3E%E6%9C%80%E7%B5%82%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%201970%E5%B9%B41%E6%9C%881%E6%97%A5%2000%3A00%3A23%20UTC%20tty1%3CBR%20%2F%3ELinaro%2014.04%20(GNU%2FLinux%204.1.15%20armv7l)%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9D%3C%2FP%3E%3CP%3E%3CSPAN%3E*%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3A%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwiki.linaro.org%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwiki.linaro.org%2F%3C%2FA%3Eroot%40linaro-alip%3A~%23%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E4.1.15%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3EBoard%3A%20MX6Q-Sabreauto%20revA%3C%2FSPAN%3E%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%A9%E5%88%87%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%EF%BC%88%E6%A7%8B%E6%88%90%EF%BC%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EMX6QP-Sabreauto%3C%2FSTRONG%3E%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%93%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92HDMI%E3%81%AB%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202016.03%20(2016%E5%B9%B411%E6%9C%883%E6%97%A5%20-%2011%3A28%3A37%20%2B0100)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6QP%20rev1.0%20996%20MHz%20(792%20MHz%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E4%B8%AD)%3CBR%20%2F%3ECPU%3A%20%E8%BB%8A%E8%BC%89%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%20(-40%E2%84%83%EF%BD%9E125%E2%84%83)%20(28%E2%84%83)%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%8E%9F%E5%9B%A0%3A%20POR%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%20MX6Q-Sabreauto%20revA%3CBR%20%2F%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3EPMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3ENAND%3A%200%20MiB%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%E3%80%81FSL_SDHC%3A%201%3CBR%20%2F%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%20Hannstar-XGA%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3A%20Hannstar-XGA%20(1024x768)%E5%85%A5%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%87%BA%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%230%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OKmmc1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3A%20FEC%20%5BPRIME%5D%E9%80%9A%E5%B8%B8%E8%B5%B7%E5%8B%95%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%200%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%87%BA%E5%8A%9B%E3%82%92HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AB%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%80%94%E4%B8%AD%E3%81%A7%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E*%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E4%BF%9D%E5%AD%98%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E5%81%9C%E6%AD%A2%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%5B%20OK%20%5D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EU-Boot%202015.04%20(2016%E5%B9%B411%E6%9C%8802%E6%97%A5%20-%2023%3A46%3A14)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6QP%20rev1.0%20(792%20MHz)%3CBR%20%2F%3E%20CPU%3A%20%E6%B8%A9%E5%BA%A6%2033%E2%84%83%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%8E%9F%E5%9B%A0%3A%20POR%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%20MX6Q-Sabreauto%20revA%3CBR%20%2F%3E%20I2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3E%20PMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3E%20NAND%3A%200%20MiB%3CBR%20%2F%3E%20MMC%3A%20FSL_SDHC%3A%200%E3%80%81FSL_SDHC%3A%201%3CBR%20%2F%3E%20***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%9AHannstar-XGA%20%E3%81%AB%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%EF%BC%9AHannstar-XGA%20(1024x768)%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%230%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%EF%BC%9AFEC%20%5BPRIME%5D%3CBR%20%2F%3E%E9%80%9A%E5%B8%B8%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A0%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%230%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3Eboot.scr%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E**%20boot.scr%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3CBR%20%2F%3EzImage%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E6022776%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%20309%20%E3%83%9F%E3%83%AA%E7%A7%92%20(18.6%20MiB%2F%E7%A7%92)%20%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emmc%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3Eimx6qp-sabreauto.dtb%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E46893%E3%83%90%E3%82%A4%E3%83%88%E3%82%9220%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20(2.2%20MiB%2F%E7%A7%92)%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%40%200x12000000%20%5B%200x000000%20-%200x5be678%20%5D%3CBR%20%2F%3E%23%23%2018000000%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%20fdt%3CBR%20%2F%3E%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A60x18000000%E3%81%A7%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3E%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%9218000000%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%811800e72c%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%E7%89%A9%E7%90%86%20CPU%200x0%20%E3%81%A7%20Linux%20%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%ADLinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.14.52%20(r59400%40Latitude)%20(gcc%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.8.5%20(Linaro%20GCC%204.8-2015.06)%20)%20%233%20SMP%20PREEMPT%202016%E5%B9%B411%E6%9C%882%E6%97%A5%2023%3A55%3A53%20CETCPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7dCPU%3A%20PIPT%20%2F%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%A2%E3%83%87%E3%83%AB%3A%20Freescale%20i.MX6%20Quad%20Plus%20SABRE%20Automotive%20Boardcma%3A%20CMA%3A%206a000000%20%E3%81%AB%20320%20MiB%20%E3%82%92%E4%BA%88%E7%B4%84%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6PERCPU%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%208%20%E3%83%9A%E3%83%BC%E3%82%B8%2FCPU%20%40ee71d000%20s8320%20r8192%20d16256%20u327681%20%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB%E6%A7%8B%E7%AF%89%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E6%9C%89%E5%8A%B9%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A%20520%2C720%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk2p2%20rootwait%20rwPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204%2C096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016%2C384%20%E3%83%90%E3%82%A4%E3%83%88)Dentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20262%2C144%20(%E9%A0%86%E5%BA%8F%3A%208%2C%201%2C048%2C576%20%E3%83%90%E3%82%A4%E3%83%88)Inode%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131%2C072%20(%E9%A0%86%E5%BA%8F%3A%207%2C%20524%2C288%20%E3%83%90%E3%82%A4%E3%83%88)%E3%83%A1%E3%83%A2%E3%83%AA%3A%201%2C739%2C228K%2F2%2C097%2C152K%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%20(7%2C452K%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81460K%20rwdata%E3%80%812%2C596K%20rodata%E3%80%81392K%20init%E3%80%81433K%20bss%E3%80%81357%2C924K%20%E4%BA%88%E7%B4%84%E3%80%81270%2C336K%20%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA)%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%9A%20%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%EF%BC%9A0xffff0000%20-%200xffff1000%20(4%20kB)%20%E5%9B%BA%E5%AE%9A%E3%83%9E%E3%83%83%E3%83%97%EF%BC%9A0xfff00000%20-%200xfffe0000%20(896%20kB)%20vmalloc%EF%BC%9A0xf0000000%20-%200xff000000%20(240%20MB)%20lowmem%20%3A%200x80000000%20-%200xef800000%20(1%2C784%20MB)%20pkmap%20%3A%200x7fe00000%20-%200x80000000%20(2%20MB)%20modules%20%3A%200x7f000000%20-%200x7fe00000%20(14%20MB).text%3A%200x80008000%EF%BD%9E0x809d82d4%EF%BC%8810049%20kB%EF%BC%89%20.init%3A%200x809d9000%20-%200x80a3b080%20(%20393%20kB)%3CBR%20%2F%3E%20.data%20%3A%200x80a3c000%20-%200x80aaf340%20(%20461%20kB)%3CBR%20%2F%3E%20.bss%20%3A%200x80aaf34c%20-%200x80b1b99c%20(%20434%20kB)%3CBR%20%2F%3ESLUB%3A%20HWalign%3D64%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3CBR%20%2F%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E9%9A%8E%E5%B1%A4%E5%9E%8BRCU%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016L310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fl2x0%3A%2016%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%80%81CACHE_ID%200x410000c8%E3%80%81AUX_CTRL%200x32070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B5%E3%82%A4%E3%82%BA%3A%201024%20kB%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E4%B8%ADsched_clock%3A%2032%20%E3%83%93%E3%83%83%E3%83%88%E3%80%813000kHz%E3%80%81%E5%88%86%E8%A7%A3%E8%83%BD%20333ns%E3%80%811431655765682ns%20%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2080x30%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97)%E3%80%81%E5%80%A4%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99..6.00%20BogoMIPS%20(lpj%3D30000)pid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)CPU%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%83%86%E3%82%B9%E3%83%88%3A%20OKCPU0%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%2C%20CPU%200%2C%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%2C%20mpidr%20800000000x10718008%20-%200x10718060%20%E3%81%AE%E9%9D%99%E7%9A%84%E3%82%A2%E3%82%A4%E3%83%87%E3%83%B3%E3%83%86%E3%82%A3%E3%83%86%E3%82%A3%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E8%A8%AD%E5%AE%9A%E4%B8%ADCPU1%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FCPU1%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%201%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81MPIDR%2080000001CPU2%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FCPU2%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%202%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81MPIDR%2080000002CPU3%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FCPU3%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%203%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81MPIDR%20800000034%20%E3%81%A4%E3%81%AE%20CPU%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FSMP%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E7%B7%8F%E6%95%B0%3A%204%20(24.00%20BogoMIPS)CPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECPU%E3%81%8CSVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%80%82%3CBR%20%2F%3Edevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BFVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20%E5%AE%9F%E8%A3%85%E8%80%85%2041%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%203%20%E3%83%91%E3%83%BC%E3%83%88%2030%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%209%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%204pinctrl%20%E3%82%B3%E3%82%A2%3A%20pinctrl%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AA%E3%81%97NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2016%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FDMA%3A%20%E5%8E%9F%E5%AD%90%E7%9A%84%E3%81%AA%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB%20256%20KiB%20%E3%81%AE%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6cpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8cpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8CPU%20%E3%81%AF%20i.MX6QP%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%201.0%20%E3%81%A8%E3%81%97%E3%81%A6%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FWDOG1%20%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8syscon%2020c8000.anatop%3Aregmap%20%5Bmem%200x020c8000-0x020c8fff%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20vdd1p1%3A%20800%EF%BD%9E1375%26lt%3B--%26gt%3B%20mV%20at%201100%20mV%20vdd3p0%3A%202625%EF%BD%9E3400%26lt%3B--%26gt%3B%20mV%20at%203000%20mV%20vdd2p5%3A%202000%EF%BD%9E2750%26lt%3B--%26gt%3B%20mV%20at%202400%20mV%20vddarm%3A%20725%EF%BD%9E1450%26lt%3B--%26gt%3B%20mV%20at%201150%20mV%20vddpu%3A%20725%EF%BD%9E1450%26lt%3B--%26gt%3B%20mV%20at%201150%20mV%20vddsoc%3A%20725%EF%BD%9E1450%26lt%3B--%26gt%3B%20mV%20at%201175%20mV%20syscon%2020e0000.iomuxc-gpr%3Aregmap%20%5Bmem%200x020e0000-0x020e0037%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Eyscon%2021bc000.ocotp-ctrl%3A%20regmap%20%5Bmem%200x021bc000-0x021bffff%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ehw-breakpoint%3A%205%E5%80%8B%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%EF%BC%88%2B1%E5%80%8B%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%EF%BC%89%E3%81%A81%E5%80%8B%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%3A%20%E6%9C%80%E5%A4%A7%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20IMX%E3%83%94%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%E7%95%A5%E6%AD%B4%3A%E3%82%B9%E3%83%A9%E3%83%96%20%3CBIO-0%3E%20%E3%82%920%20mxs-dma%20110000.dma-apbh%E3%81%AB%3CBR%20%2F%3E%E4%BD%9C%E6%88%90%3A%E5%88%9D%E6%9C%9F%E5%8C%96cs42888_supply%3A%203300%20mV3P3V%3A%203300%20mVvio1%3A%203300%20mVvio2%3A%203300%20mVvd%3A%203300%20mVva%3A%205000%20mV%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20usb_h1_vbus.30%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%9B%BA%E5%AE%9A%E9%9B%BB%E5%9C%A7%E8%A6%81%E6%B1%82%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20usb_otg_vbus.31%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90reg-fixed-voltage%E3%81%AF%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99P3V3_SDa_SWITCHED%3A%203300%20mVi2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmax17135%5D%20%E3%81%AF%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99i2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmax17135%5D%20%E3%81%AF%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99SCSI%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usbfs%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20hub%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbphy_nop1.12%20%E4%BE%9B%E7%B5%A6%20vcc%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99usbphy_nop2.13%20%E4%BE%9B%E7%B5%A6%20vcc%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99i2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fi2c%20i2c-2%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FLinux%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20v2.00pps_core%3A%20LinuxPPS%20API%20ver.%201%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3Epps_core%3A%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20ver.%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3EPTP%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-ipuv3%202400000.ipu%EF%BC%9AIPU%20DMFC%20%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3A%201%EF%BC%880%EF%BD%9E1%EF%BC%89%E3%80%815B%EF%BC%884%2C5%EF%BC%89%E3%80%815F%EF%BC%886%2C7%EF%BC%89%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3A%20IPU%20DMFC%20%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A1%EF%BC%880%EF%BD%9E1%EF%BC%89%E3%80%815B%EF%BC%884%2C5%EF%BC%89%E3%80%815F%EF%BC%886%2C7%EF%BC%89imx-prg%2021cc000.prg%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8Cimx-prg%2021cd000.prg%20%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8Cimx-pre%2021c8000.pre%20%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8Cimx-pre%2021c9000.pre%20%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8Cimx-pre%2021ca000.pre%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8Cimx-pre%2021cb000.pre%20%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FAdvanced%20Linux%20Sound%20Architecture%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Bluetooth%3A%20%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.18%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC31%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20L2CAP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20SCO%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecfg80211%3A%20CRDA%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92mxc_timer1%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC2%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ETCP%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2016384%20(%E9%A0%86%E5%BA%8F%3A%204%2C%2065536%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2016384%20(%E9%A0%86%E5%BA%8F%3A%205%2C%20131072%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(%E7%A2%BA%E7%AB%8B%2016384%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%2016384)%3CBR%20%2F%3ETCP%3A%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EUDP-Lite%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC1%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ERPC%3A%20%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%EF%BC%9AARMv7%20Cortex-A9%20PMU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%80%817%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3Eimx%20rpmsg%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eimx_busfreq%20busfreq.16%3ADDR%20%E3%81%AE%E4%B8%AD%E9%80%9F%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Efutex%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%3A%204%E3%80%8165536%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%83%97%E3%83%BC%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%20%E3%83%9A%E3%83%BC%E3%82%B8%3CBR%20%2F%3EVFS%3A%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%20dquot_6.5.2%3CBR%20%2F%3EDquot-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A1024%EF%BC%88%E9%A0%86%E5%BA%8F%200%E3%80%814096%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3ENFS%3A%20id_resolver%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_resolver%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_legacy%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ejffs2%EF%BC%9A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.fuse%20init%20(API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.22)msgmni%20%E3%81%8C%203508%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fio%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%20noop%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fio%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%20deadline%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fio%20%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%20cfq%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88.17%20%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%9A%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99MIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fmxc_sdc_fb%20fb.23%3A%20mxc%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ldb%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fimx-ipuv3%202800000.ipu%3AIPU%20DMFC%20DP%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%201(0%2C1)%E3%80%815B(2%EF%BD%9E5)%E3%80%815F(6%2C7)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9128x48%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Emxc_hdmi%2020e0000.hdmi_video%3A%20%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FHDMI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%200x13%3A0xa%3A0xa0%3A0xc1fbcvt%3A%201920x1080%4060%3A%20CVT%20%E5%90%8D%20-%202.073M9mxc_sdc_fb%20fb.24%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9Fmxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90hdmimxc_sdc_fb%20fb.25%3A%20mxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81mxc_sdc_fb%20fb.26%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9Fmxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ldbimx-sdma%2020ec000.sdma%3AIRAM%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%A4%96%E9%83%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%86%8D%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%203.2%20%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82mxc_hdmi%2020e0000.hdmi_video%3AEDID%20%E3%82%92%E5%86%8D%E5%BA%A6%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80imx-sdma%2020ec000.sdma%EF%BC%9A%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A%202%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A%201%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20FAB%3A%200%E3%80%81FIN%3A%200%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20pfuze100%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESW1AB%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E3%81%A7%201375%20mVSW1C%3A%20300%20%26lt%3B--%26gt%3B%201875%20mV%20%E3%81%A7%201375%20mVSW2%3A%20800%20%26lt%3B--%26gt%3B%201975%20mV%20%E3%81%A7%201375%20mVSW3A%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E3%81%A7%201350%20mVSW3B%3A%20400%20%26lt%3B--%26gt%3B%201975%20mV%20%E3%81%A7%201350%20mVSW4%3A%20800%20%26lt%3B--%26gt%3B%201975%20mV%20%E3%81%A7%201825%20mVSWBST%3A%205000%20%26lt%3B--%26gt%3B%205150%20mV%20%E3%81%A7%205000%20mVVSNVS%3A%201000%20%26lt%3B--%26gt%3B%203000%20mV%20%E3%81%A7%203000%20mVVREFDDR%3A%20750%20mVVGEN1%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E3%81%A7%201200%20mVVGEN2%3A%20800%20%26lt%3B--%26gt%3B%201550%20mV%20%E3%81%A7%201500%20mVVGEN3%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E3%81%A7%201800%20mVVGEN4%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E3%81%A7%203000%20mVVGEN5%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E3%81%A7%202500%20mVVGEN6%3A%201800%20%26lt%3B--%26gt%3B%203300%20mV%20%E3%81%A7%202800%20mV%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20IMX%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%9021ec000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20ttymxc2%20%E3%81%AF%20MMIO%200x21ec000%20(irq%20%3D%2060%E3%80%81base_baud%20%3D%205000000)%20%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81IMX%3CBR%20%2F%3E21f0000.serial%20%E3%81%A7%E3%81%99%E3%80%82ttymxc3%20%E3%81%AF%20MMIO%200x21f0000%20(irq%20%3D%2061%E3%80%81base_baud%20%3D%205000000)%20%E3%81%AB%E3%81%82%E3%82%8B%20IMXmxc_hdmi%2020e0000.hdmi_video%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc3%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%EF%BC%9AFreescale%20lpuart%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90imx%20sema4%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%5Bdrm%5D%20drm%201.1.0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F20060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%E3%82%92minor%200%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ebrd%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Esi476x-core%201-0063%3A%20IRQ%20%E7%95%AA%E5%8F%B7%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%890x11%E3%81%AE%E9%80%81%E4%BF%A1%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esi476x-core%201-0063%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E9%9B%BB%E6%BA%90%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Ctransmit-level-mV%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8100000024%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Ctransmit-boost-mdB%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8100000480%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%E3%80%81transmit-atten-16ths%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%8100002000%20%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%3Afsl%2Creceive-eq-mdB%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%8105000000%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eahci-imx%202200000.sata%3ASSS%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%83%90%E3%82%B9%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ahci-imx%202200000.sata%EF%BC%9AAHCI%200001.0300%2032%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%201%20%E3%83%9D%E3%83%BC%E3%83%88%203%20Gbps%200x1%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89ahci-imx%202200000.sata%3A%20%E3%83%95%E3%83%A9%E3%82%B0%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apstscsi0%20%3A%20ahci_%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0ata1%3A%20SATA%20%E6%9C%80%E5%A4%A7%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02203fff%5D%20%E3%83%9D%E3%83%BC%E3%83%88%200x100%20irq%2071CAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B92094000.can%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8flexcan%202094000.can%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(reg_base%3Df0238000%2C%20irq%3D143)2188000.ethernet%20%E7%89%A9%E7%90%86%E5%B1%A4%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99pps%20pps0%3A%20%E6%96%B0%E3%81%97%E3%81%84PPS%E3%82%BD%E3%83%BC%E3%82%B9ptp0libphy%3A%20fec_enet_mii_bus%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%B8%88%E3%81%BFfec%202188000.ethernet%20eth0%3A%20PHC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fehci_hcd%3A%20USB%202.0%E3%80%8CEnhanced%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ehci-mxc%3A%20Freescale%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usb-storage%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usb_ehset_test%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F2184800.usbmisc%20%E9%9B%BB%E6%BA%90vbus-wakeup%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99imx_usb%202184000.usb%3Aci_hdrc%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%202184000.usb%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20imx_usb%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eimx_usb%202184200.usb%3Aci_hdrc%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%3D-517%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%202184200.usb%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20imx_usb%20%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82mousedev%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AB%E5%85%B1%E9%80%9A%E3%81%AE%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9egalax_ts%201-0004%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97egalax_ts%3A%201-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%972-0044%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%9A%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E5%85%A5%E5%8A%9B%3A%20isl29023%20%E5%85%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%20%2Fdevices%2Fvirtual%2Finput%2Finput1%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BAisl29023%202-0044%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.0%20%E3%81%8C%E6%9C%89%E5%8A%B9i2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bisl29023%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8i2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bisl29023%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8snvs_rtc%2020cc034.snvs-rtc-lp%3Asnvs-rtc%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Esnvs_rtc%2020cc034.snvs-rtc-lp%3Artc%E3%82%B3%E3%82%A2%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF20cc034.snvs-rtc-lprtc0%E3%81%A8%E3%81%97%E3%81%A6i2c%20%2Fdev%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90IR%20NEC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20RC5(x)%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20RC6%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20JVC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20Sony%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20RC5%20(streamzap)%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20SANYO%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FIR%20MCE%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fmxc_v4l2_output%20v4l2_out.35%3Avideo16%20mxc_v4l2_output%20v4l2_output%20v4l2_out.35%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3Avideo17%20mxc_v4l2_output%20v4l2_output%20v4l2_out.35%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3Avideo18%20mxc_v4l2_output%20v4l2_output%20v4l2_out.35%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3Avideo19%20mxc_v4l2_output%20v4l2_output%20v4l2_out.35%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AV4L2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%20video20%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F2-000e%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%992-000e%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vddio%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99mag3110%202-000e%3A%20mag3110%20%E3%83%81%E3%83%83%E3%83%97%20ID%20%E3%82%92%E7%A2%BA%E8%AA%8D%E5%85%A5%E5%8A%9B%3A%20mag3110%20%E3%81%8C%20%2Fdevices%2Fvirtual%2Finput%2Finput2%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fmag3110%202-000e%3A%20mag3110%20%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fi2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmag3110%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99i2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmag3110%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%992-001c%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vdd%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%992-001c%20%E3%81%AE%E9%9B%BB%E6%BA%90%20vddio%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99ata1%3A%20SATA%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%80%E3%82%A6%E3%83%B3%20(SStatus%200%20SControl%20300)ahci-imx%202200000.sata%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ahci-imx%202200000.sata%3A%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81ahci_imx..hotplug%3D1%20%E3%82%92%E6%B8%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E5%85%A5%E5%8A%9B%3A%20mma845x%20%E3%82%92%20%2Fdevices%2Fvirtual%2Finput%2Finput3%20%E3%81%A8%E3%81%97%E3%81%A6imx2-wdt%2020bc000.wdog%3A%20IMX2%2B%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%EF%BC%88nowayout%3D0%EF%BC%89Bluetooth%3A%20HCI%20UART%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2Bluetooth%3A%20HCI%20H4%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20HCI%20BCSP%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20bcm203x%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20btusb%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ath3k%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fsdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90sdhci%3A%20%C2%A9%20Pierre%20Ossmansdhci-pltfm%3A%20SDHCI%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%8A%E3%82%88%E3%81%B3%20OF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%98%E3%83%AB%E3%83%91%E3%83%BCmmc0%3A%20vqmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93mmc0%3A%20vmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93mmc0%3A%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%202190000.usdhc%20%5B2190000.usdhc%5D%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99ADMA%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%ADmmc2%3A%20vqmmc%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93mmc2%3A%202198000.usdhc%E3%81%AESDHCI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%5B2198000.usdhc%5DADMA%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%AD%E8%AD%A6%E5%91%8A%EF%BC%9AGPU%E7%94%A8%E3%81%AE%E9%80%A3%E7%B6%9A%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%EF%BC%81%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%EF%BC%88134%2C217%2C728%EF%BC%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGalcore%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B35.0.11.41671mmc2%3A%20%E9%9B%BB%E6%B5%81%E5%88%B6%E9%99%90%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%81mmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9aaaa%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E8%B6%85%E9%AB%98%E9%80%9FDDR50%20SDHC%E3%82%AB%E3%83%BC%E3%83%89mmcblk2%3A%20mmc2%3Aaaaa%20SU08G%207.40%20GiB%20mmcblk2%3A%20p1%20p2mxc_vdoa%2021e4000.vdoa%3A%20i.MX%20%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fmxc_vpu%202040000.vpu%3AVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fcaam%202100000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH0caam%202100000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH1caam%202100000.caam%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%20%3D%200x0a160100%EF%BC%88Era%204%EF%BC%89caam%202100000.caam%3A%20%E3%82%B8%E3%83%A7%E3%83%96%E3%83%AA%E3%83%B3%E3%82%B0%20%3D%202%E3%80%81qi%20%3D%200caam%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%20%2Fproc%2Fcrypto%20%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99caam_jr%202101000.jr0%3Arng-caam%20%E3%81%AE%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20blkkey_ex%3A%204%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20e5%2067%201a%2032%2044%2012%203e%2071%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2035%20de%2020%202e%2043%20ce%20ec%2082%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20d4%20b2%20d2%20cd%20de%2016%20e3%20b1%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2013%207c%201e%20af%204c%20a4%2040%2014%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D3d%204f%201d%20c9%2083%2084%20b5%208a%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2050%208e%20de%2015%208e%2002%2000%208d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2067%20cd%2031%202d%20c6%209c%2013%2060%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2035%202d%20b7%20c2%2010%2076%2036%20e9%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20c4%204e%20d7%20b6%203e%2043%202f%2066%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2036%20df%20f3%20c9%201c%20b4%20d5%2028%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%204b%2048%20f0%20e6%2004%202e%2087%202c%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2030%20f4%2010%208d%20c6%2091%20bd%2077%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20196%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%96%E3%83%AD%E3%83%96%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D00%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%20blob%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D9c%205f%20c6%20a9%2006%2033%20a5%20a5%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%20de%2027%2035%20d8%2015%20e5%20a1%204f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%20f7%20e1%20e8%20d0%2074%2023%20fd%20a8%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D68%2081%2069%2046%2049%2013%2017%203e%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%209c%20fc%2015%20f5%2039%200a%20c6%203d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20d7%2000%20d0%2049%209a%20bb%203f%20c3%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%20e4%20ef%2005%20f9%20e5%2038%20da%20f8%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%20blob%20%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D84%206e%2068%201d%2003%206b%20f8%203b%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2009%20da%207c%2060%2070%20f4%20df%2065%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2095%20b5%2048%209d%2070%20e4%2047%20ca%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%20e9%201f%205a%20e5%20f0%2043%2026%20a7%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%20a9%2090%2065%2092%2042%20ab%20fd%2046%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%20fb%203d%20e9%2013%205c%2024%20f1%20e9%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%208b%20ca%20b4%20c1%2010%2023%209d%2066%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%2085%2068%2014%2030%2047%20ce%2043%20c0%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%20blob%20%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%2057%20a6%2097%203f%2043%2096%20cf%2087%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%201f%2072%2089%20a6%20a0%20ad%200e%2048%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%207a%20ad%205c%20e4%206e%2037%2004%203d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%20e4%2095%20c9%2009%20aa%20c7%2012%20bb%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0032%5D%2056%203c%20d7%20dc%2003%206b%202f%20e1%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0040%5D%2016%20a8%20c2%20c3%2078%207a%2095%20ce%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%2005%2075%20fc%20d4%20a6%2084%20be%20d3%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D%20c7%20df%2001%204f%20bc%2017%20fd%209d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%2098%2025%2068%2026%20f6%209b%205c%2099%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%81%8C%E3%83%96%E3%83%AD%E3%83%96%E5%86%85%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20fe%20a8%2022%20dd%2034%20d2%2000%203e%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%207e%20e8%2032%2093%2059%20a4%2096%2072%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2047%209a%20dd%203e%20fe%202a%2083%2027%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2092%2005%20b2%20c8%20cc%203e%20fe%2064%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0032%5D%209b%206b%202d%2047%20bc%2058%20ca%201c%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0040%5D%208d%20c2%20b4%2094%2081%20b1%2080%20bf%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0048%5D%200e%2059%2038%2050%2047%2061%2009%20f4%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0056%5D22%20c2%20fa%2092%2056%2092%20df%202e%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0064%5D%2062%2084%2043%2056%2069%203a%2085%20f1%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0072%5D%20c4%20f4%20f7%2054%2046%204c%200b%20ca%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20c8%20bd%2051%2012%200f%208c%203c%209b%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2094%20ac%2086%2067%2055%2065%2075%2024%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0000%5D%20d4%20b2%20d2%20cd%20de%2016%20e3%20b1%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2013%207c%201e%20af%204c%20a4%2040%2014%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D3d%204f%201d%20c9%2083%2084%20b5%208a%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0008%5D%2050%208e%20de%2015%208e%2002%2000%208d%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0016%5D%2047%206b%20e3%20e8%2062%206f%2089%208f%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0024%5D%207c%20dc%206f%20eb%20cc%2073%2030%201c%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%E3%82%92%E5%BE%A9%E5%85%83%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0000%5D%20c4%204e%20d7%20b6%203e%2043%202f%2066%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0008%5D%2036%20df%20f3%20c9%201c%20b4%20d5%2028%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%5B0016%5D%204b%2048%20f0%20e6%2004%202e%2087%202c%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%5B0024%5D%2030%20f4%2010%208d%20c6%2091%20bd%2077snvs-secvio%2020cc000.caam-snvs%3Asnvs%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93snvs-secvio%2020cc000.caam-snvs%3A%E9%81%95%E5%8F%8D%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E8%B5%B7%E5%8B%95%20-%20%E9%9D%9E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E7%8A%B6%E6%85%8Busbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2usbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90cs42xx8%201-0048%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BA%E8%A6%8B%E3%80%81%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%204fsl-asrc%202034000.asrc%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fsnd-soc-dummy%20snd-soc-dummy%3A%20ASoC%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AEdebugfs%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9Fimx-cs42888%20sound-cs42888.27%3Acs42888%26lt%3B-%26gt%3B%202024000.esai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OKimx-cs42888%20sound-cs42888.27%3Asnd-soc-dummy-dai%20%26lt%3B-%26gt%3B%202034000.asrc%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20okimx-cs42888%20sound-cs42888.27%3A%20cs42888%20%26lt%3B-%26gt%3B%202024000.esai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E5%AE%8C%E4%BA%86imx-spdif%20sound-spdif.20%3A%20snd-soc-dummy-dai%20%26lt%3B-%26gt%3B%202004000.spdif%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OKimx-audio-hdmi%20sound-hdmi.21%3A%20hdmi-hifi%26lt%3B-%26gt%3B%20hdmi_audio.3%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OKimx-tuner-si476x%20sound-fm.33%EF%BC%9AFM%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82imx-tuner-si476x%3A%20sound-fm.33%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2026%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82TCP%3A%20cubic%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2010%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82sit%3A%20IPv6%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2017%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82can%3A%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2%20(rev%2020120528%20abi%209)%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82NET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2029%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82can%3A%20raw%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528)can%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528%20t)can%3A%20netlink%20%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%20(rev%2020130117)%20max_hops%3D1Bluetooth%3A%20RFCOMM%20TTY%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20RFCOMM%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20RFCOMM%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.11Bluetooth%3A%20BNEP%20(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.3Bluetooth%3A%20BNEP%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88Bluetooth%3A%20BNEP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FBluetooth%3A%20HIDP%20(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.2Bluetooth%3A%20HIDP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F8021q%3A%20802.1Q%20VLAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20dns_resolver%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FVGEN2%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96SWBST%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96SW4%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96imx%20mcc%20%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82usb_h1_vbus%3A%205000%20mVusb_otg_vbus%3A%205000%20mVci_hdrc%20ci_hdrc.0%3A%20EHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9ci_hdrc%20ci_hdrc.0%3A%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B7%201%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ci_hdrc%20ci_hdrc.0%3AUSB%202.0%20%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81EHCI%201.00%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fci_hdrc%20ci_hdrc.1%3A%E3%82%AC%E3%82%B8%E3%82%A7%E3%83%83%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93ci_hdrc%20ci_hdrc.1%EF%BC%9AEHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9ci_hdrc%20ci_hdrc.1%3A%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B7%202%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fci_hdrc%20ci_hdrc.1%3AUSB%202.0%20%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81EHCI%201.00%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E5%85%A5%E5%8A%9B%3A%20gpio-keys.18%20as%20%2Fdevices%2Fsoc0%2Fgpio-keys.18%2Finput%2Finput4snvs_rtc%2020cc034.snvs-rtc-lp%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A02%20UTC%20%E3%81%AB%E8%A8%AD%E5%AE%9A%20(2)ALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%20%230%3A%20cs42888-audio%20%231%3A%20imx-spdif%20%232%3A%20imx-hdmi-socusb%201-1%3A%20ci_hdrc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%202%E3%83%8F%E3%83%96%201-1%3A1.0%3AUSB%20%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%8F%E3%83%96%201-1%3A1.0%3A%204%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fkjournald%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92EXT3-fs%20(mmcblk2p2)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8EXT3-fs%20(mmcblk2p2)%3A%20%E5%BE%A9%E6%97%A7%E5%AE%8C%E4%BA%86EXT3-fs%20(mmcblk2p2)%3A%20%E9%A0%86%E5%BA%8F%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0VFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A2%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82devtmpfs%3A%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E6%B8%88%E3%81%BF%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A7%A3%E6%94%BE%E4%B8%AD%3A%20392K%20(809d9000%20-%2080a3b000)usb%201-1.2%3A%20ci_hdrc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9F%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%203%20%E3%82%92%E4%BD%BF%E7%94%A8%2Fsys%2Ffs%2Fselinux%20%E3%81%AB%20selinuxfs%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%20init%20urandom%20%E3%81%8C%2068%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E3%81%A7%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%92%E9%96%8B%E5%A7%8B%E5%85%A5%E5%8A%9B%3A%20DELL%20DELL%20USB%20Laser%20Mouse%20%E3%81%8C%20%2Fdevices%2Fsoc0%2Fsoc.0%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.2%2F1-1.2%3A1.0%2F0003%3A046D%3AC063.0001%2Finput%2Finput5%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Fhid-generic%200003%3A046D%3AC063.0001%3A%E5%85%A5%E5%8A%9B%3A%20USB%20HID%20v1.10%20%E3%83%9E%E3%82%A6%E3%82%B9%20%5BDELL%20DELL%20USB%20%E3%83%AC%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%82%A6%E3%82%B9%5D%20on%20usb-ci_hdrc.0-1.2%2Finput0usb%201-1.3%3A%20%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9F%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%204%20%E3%81%8C%20ci_hdrc%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82init%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(177)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82init%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82init%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(187)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82init%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82init%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(190)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82init%3A%20plymouth-upstart-bridge%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82input%3A%20Dell%20Dell%20QuietKey%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%20%2Fdevices%2Fsoc0%2Fsoc.0%2F2100000.aips-bus%2F2184000.usb%2Fci_hdrc.0%2Fusb1%2F1-1%2F1-1.3%2F1-1.3%3A1.0%2F0003%3A413C%3A2106.0002%2Finput%2Finput6hid-generic%200003%3A413C%3A2106.0002%3A%E5%85%A5%E5%8A%9B%EF%BC%9AUSB%20HID%20v1.10%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20%5BDell%20Dell%20QuietKey%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%5D%20on%20usb-ci_hdrc.0-1.3%2F%E5%85%A5%E5%8A%9B0init%3A%20ureadahead%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(180)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%205%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9Finit%3A%20mounted-proc%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20(204)%20%E3%81%8C%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9FDBG%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%207f010190%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20*%20%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%5B%20OK%20%5D%20*%20plymouth%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%20%5B%20OK%20%5D%20*%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%20sysvinit%20%E3%81%AB%E9%80%9A%E7%9F%A5%20%5B%20OK%20%5D%20*%20%2Ftmp%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20%5B%20OK%20%5D%20*%20%2Frun%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%83%AA%E3%83%B3%E3%82%AF%20%5B%20OK%20%5D%20*%20%2Frun%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%2Ftmp%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20upstart%20%E3%81%8C%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E5%86%85%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E3%83%88%E3%83%A9%E3%83%83%E3%82%AF%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20resolvconf%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%80%E7%B5%82%E5%8C%96%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E4%BB%AE%E6%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%20sysvinit%20%E3%81%AB%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%82%92%E9%80%81%E4%BF%A1%20%5B%20OK%20%5D%20*%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81sysvinit%20%E3%81%AB%E4%BB%AE%E6%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%99%E3%82%8B%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20udev%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%20upstart%20%E3%81%AB%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%5B%20OK%20%5D%20*%20sysvinit%20%E3%81%AB%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%99%E3%82%8B%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20sysvinit%20%E3%81%AB%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%99%E3%82%8B%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E6%97%A9%E6%9C%9F%E3%82%B8%E3%83%A7%E3%83%96%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%AD%E3%82%B0%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%5B%20OK%20%5D%20*%20%2Fetc%2Fmodules%20%E3%81%8B%E3%82%89%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%20%5B%20OK%20%5D%20*%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%89%E3%83%97%E3%83%A9%E3%82%B0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%BD%9C%E6%88%90%E3%81%AE%E3%83%AD%E3%82%B0%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E6%97%A9%E6%9C%9F%E3%82%B8%E3%83%A7%E3%83%96%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%AD%E3%82%B0%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%2Fetc%2Fmodules%20%E3%81%8B%E3%82%89%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%20%5B%20OK%20%5D%20*%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%B3%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20plymouth%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%20%5B%20OK%20%5D%20*%20plymouth%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%20upstart%20%E3%81%AB%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%20upstart%20%E3%81%AB%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%BB%E3%83%BC%E3%83%95%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20System%20V%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20System%20V%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20System%20V%20%E3%83%A9%E3%83%B3%E3%83%AC%E3%83%99%E3%83%AB%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E4%BF%9D%E5%AD%98%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E8%A8%AD%E5%AE%9A%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AA%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E5%87%A6%E7%90%86%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%20%5B%20OK%20%5D%20*%20System%20V%20%E3%83%A9%E3%83%B3%E3%83%AC%E3%83%99%E3%83%AB%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%20*%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E4%BF%9D%E5%AD%98%E3%82%92%E5%81%9C%E6%AD%A2%20%5B%20OK%20%5D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Erik%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A9%A6%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%20i.mx%206%20QuadPlus%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%A9%A6%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E7%B5%90%E6%9E%9C%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EWenming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX%206QuadPlus%20SABRE-AI%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E6%A9%9F%E4%BC%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84BSP%20rel_imx_4.1.15_1.1.0_ga%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3CSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3Eim53qsb%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%201%20%E3%81%A4%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81imx5_pm_init%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82imx_v7_defconfig%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AB%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B9%E3%82%84%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81pm%E6%A7%8B%E6%88%90%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202015.04%20(2016%E5%B9%B410%E6%9C%884%E6%97%A5%20-%2012%3A17%3A39)%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX53%20LOCO%3CBR%20%2F%3EI2C%3A%E5%AF%BE%E5%BF%9C%3CBR%20%2F%3EDRAM%3A%201%20GiB%3CBR%20%2F%3EMMC%3AFSL_SDHC%3A0%E3%80%81FSL_SDHC%3A1%3CBR%20%2F%3E***%20%E8%AD%A6%E5%91%8A%20-%20%E4%B8%8D%E6%AD%A3%E3%81%AACRC%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3A%20FEC%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%200%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%230%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc0%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3Eboot.scr%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E**%20boot.scr%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3CBR%20%2F%3EzImage%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E5997120%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%20346%20%E3%83%9F%E3%83%AA%E7%A7%92%20(16.5%20MiB%2F%E7%A7%92)%20%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3Emmc%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3Eimx53-qsrb.dtb%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%3CBR%20%2F%3E24491%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%2019%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20(1.2%20MiB%2F%E7%A7%92)%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%40%200x72000000%20%5B%200x000000%20-%200x5b8240%20%5D%3CBR%20%2F%3E%23%23%20%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%83%96%E3%83%AD%E3%83%96%2071000000%3CBR%20%2F%3E%20fdt%20%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%200x71000000%20%E3%81%A7%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%208f552000%20%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%818f55afaa%20%E3%81%A7%E7%B5%82%E4%BA%86...%20OK%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%E7%89%A9%E7%90%86%20CPU%200x0%20%E3%81%A7%20Linux%20%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%3CBR%20%2F%3ELinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.14.38%20(lucid%40ubuntu)%20(gcc%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.8.5%20(Linaro%20GCC%204.8-2015.06)%20)%20%231%20SMP%20PREEMPT%202016%E5%B9%B410%E6%9C%885%E6%97%A5%2006%3A56%3A31%20PDT%3CBR%20%2F%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc085%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%205%20(ARMv7)%E3%80%81cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%A2%E3%83%87%E3%83%AB%3A%20Freescale%20i.MX53%20Quick%20Start%20Board%3CBR%20%2F%3Ecma%3A%20CMA%3A%20bc000000%20%E3%81%AB%20320%20MiB%20%E3%82%92%E4%BA%88%E7%B4%84%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%82%AF%3CBR%20%2F%3ECPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20CPU%20%E3%81%8C%20SVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EPERCPU%3A%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%208%20%E3%83%9A%E3%83%BC%E3%82%B8%2FCPU%20%40cb33f000%20s8320%20r8192%20d16256%20u32768%3CBR%20%2F%3E1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%EF%BC%9A259072%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%9Aconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p2%20rw%20rootwait%3CBR%20%2F%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A4096%EF%BC%88%E9%A0%86%E5%BA%8F%EF%BC%9A2%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A131072%EF%BC%88%E9%A0%86%E5%BA%8F%EF%BC%9A7%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3EInode%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A65536%EF%BC%88%E9%A0%86%E5%BA%8F%EF%BC%9A6%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%EF%BC%9A699820K%2F1048576K%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%EF%BC%887423K%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81456K%20rwdata%E3%80%812584K%20rodata%E3%80%81384K%20init%E3%80%81432K%20bss%E3%80%81348756K%20%E4%BA%88%E7%B4%84%E3%80%810K%20highmem%EF%BC%89%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%20%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%EF%BC%9A0xffff0000%20-%200xffff1000%EF%BC%884%20kB%EF%BC%89%3CBR%20%2F%3E%20%E5%9B%BA%E5%AE%9A%E3%83%9E%E3%83%83%E3%83%97%EF%BC%9A0xfff00000%20-%200xfffe0000%EF%BC%88896%20kB%EF%BC%89%3CBR%20%2F%3Evmalloc%EF%BC%9A0xe0800000%20-%200xff000000%EF%BC%88488%20MB%EF%BC%89%3CBR%20%2F%3E%20lowmem%EF%BC%9A0x80000000%20-%200xe0000000%EF%BC%881536%20MB%EF%BC%89%3CBR%20%2F%3E%20pkmap%EF%BC%9A0x7fe00000%20-%200x80000000%EF%BC%882%20MB%EF%BC%89%3CBR%20%2F%3E%20modules%EF%BC%9A0x7f000000%20-%200x7fe00000%EF%BC%8814%20MB%EF%BC%89%3CBR%20%2F%3E.text%3A%200x80008000%20-%200x809ce000%20(10008%20kB)%3CBR%20%2F%3E%20.init%3A%200x809ce000%20-%200x80a2e080%20(%20385%20kB)%3CBR%20%2F%3E%20.data%3A%200x80a30000%20-%200x80aa20c0%20(457%20kB)%3CBR%20%2F%3E%20.bss%3A%200x80aa20cc%20-%200x80b0e25c%20(%20433%20kB)%3CBR%20%2F%3ESLUB%3A%20HWalign%3D64%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D1%E3%80%81Nodes%3D1%3CBR%20%2F%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8BRCU%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3ERCU%E3%81%AFNR_CPUS%3D4%E3%81%8B%E3%82%89nr_cpu_ids%3D1%E3%81%BE%E3%81%A7CPU%E3%82%92%E5%88%B6%E9%99%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ERCU%3A%20rcu_fanout_leaf%3D16%E3%80%81nr_cpu_ids%3D1%20%E3%81%AE%E3%82%B8%E3%82%AA%E3%83%A1%E3%83%88%E3%83%AA%E3%82%92%E8%AA%BF%E6%95%B4%E4%B8%AD%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3ETrustZone%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(TZIC)%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3ECPU%20%E3%81%8C%20i.MX53%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%202.1%20%E3%81%A8%E3%81%97%E3%81%A6%E8%AD%98%E5%88%A5%3CBR%20%2F%3E%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Esched_clock%3A%2032%20%E3%83%93%E3%83%83%E3%83%88%E3%80%8133MHz%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%2030ns%E3%80%81128849019873ns%20%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3CBR%20%2F%3Eclocksource_of_init%3A%20%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2080x30%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97)%E3%80%81%E5%80%A4%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%8266.66%20BogoMIPS%20(lpj%3D333333)%3CBR%20%2F%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%202048%20(%E9%A0%86%E5%BA%8F%3A%201%2C%208192%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%202048%20(%E9%A0%86%E5%BA%8F%3A%201%2C%208192%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ECPU%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%83%86%E3%82%B9%E3%83%88%3A%20OKCPU0%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%200%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20-1%E3%80%81MPIDR%200%3CBR%20%2F%3E0x70710420%20-%200x70710478%20%E7%94%A8%E3%81%AE%E9%9D%99%E7%9A%84%20ID%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E8%A8%AD%E5%AE%9A1%20%E3%81%A4%E3%81%AE%20CPU%20%E3%82%92%E8%B5%B7%E5%8B%95%3CBR%20%2F%3ESMP%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E7%B7%8F%E6%95%B0%3A%201%20(66.66%20BogoMIPS)%3CBR%20%2F%3ECPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECPU%E3%81%8CSVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%80%82%3CBR%20%2F%3Edevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3EVFP%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20%E5%AE%9F%E8%A3%85%E8%80%85%2041%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%203%20%E9%83%A8%E5%93%81%2030%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%20c%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%202%3CBR%20%2F%3Epinctrl%E3%82%B3%E3%82%A2%3A%20pinctrl%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC16%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3EDMA%3A%20%E5%8E%9F%E5%AD%90%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%83%88%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB256%20KiB%E3%81%AE%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E4%BA%8B%E5%89%8D%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3CBR%20%2F%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EWDOG1%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Esyscon%2053fa8000.iomuxc-gpr%3Aregmap%20%5Bmem%200x53fa8000-0x53fa800b%5D%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%3A%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%200x4%20%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3Eimx53-pinctrl%2053fa8000.iomuxc%3AIMX%20pinctrl%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ebio%3A%20%E3%82%B9%E3%83%A9%E3%83%96%20%3CBIO-0%3E%20%E3%82%92%200%20%E3%81%A7%E4%BD%9C%E6%88%90%3CBR%20%2F%3E3P2V%3A%203200%20mV%3CBR%20%2F%3Eusb_vbus%3A%205000%20mV%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmax17135%5D%20%E3%82%92%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%81%A7%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmax17135%5D%20%E3%82%92%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E5%86%8D%E9%96%8B%E6%96%B9%E5%BC%8F%E3%81%A7%E4%BD%BF%E7%94%A8%3CBR%20%2F%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20hub%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbphy.1%20%E3%81%AE%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Eusbphy.2%E4%BE%9B%E7%B5%A6VCC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eda9052%3A%200-0048%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-5%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ei2c%20i2c-0%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20v2.00%3CBR%20%2F%3E%3CBR%20%2F%3Epps_core%3A%20LinuxPPS%20API%20ver.%201%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CSPAN%3Epps_core%3A%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B35.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-ipuv3%3A%2018000000.ipu%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EMIPI%20CSI2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EBluetooth%3A%20%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.18%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2031%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20L2CAP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20SCO%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%20mxc_timer1%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%202%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%208192%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%208192%20(%E9%A0%86%E5%BA%8F%3A%204%2C%2065536%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(%E7%A2%BA%E7%AB%8B%3A%208192%E3%80%81%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%3A%208192)TCP%3A%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%2C%2016384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%201%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ERPC%3A%20%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%EF%BC%9A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%20TCP%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3Eimx%20rpmsg%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Efutex%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A256%EF%BC%88%E9%A0%86%E5%BA%8F%EF%BC%9A2%E3%80%8116384%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3EVFS%EF%BC%9A%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%82%AF%E3%82%A9%E3%83%BC%E3%82%BF%20dquot_6.5.2%3CBR%20%2F%3EDquot-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%EF%BC%9A1024%EF%BC%88%E9%A0%86%E5%BA%8F%200%E3%80%814096%20%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3ENFS%3A%20id_resolver%20%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_resolver%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20id_legacy%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3CBR%20%2F%3Ejffs2%EF%BC%9A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2%E3%80%82(NAND)%20%C2%A9%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3Efuse%20init%20(API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.22)%3CBR%20%2F%3Emsgmni%20%E3%81%AF%202006%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EI%2FO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9noop%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EI%2FO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9deadline%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EI%2FO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9cfq%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%89%3CBR%20%2F%3EMIPI%20DSI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%3A%20IRAM%E3%81%AF%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%A4%96%E9%83%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%3A%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%86%8D%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-2%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%EF%BC%9A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Eimx-sdma%2063fb0000.sdma%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%EF%BC%9AIMX%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E53fbc000.serial%3Attymxc0%20%E3%81%AF%20MMIO%200x53fbc000%20(irq%20%3D%2047%2C%20base_baud%20%3D%204166666)%20%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81IMX%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20Freescale%20lpuart%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eimx%20sema4%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20drm%201.1.0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F20060810%3CBR%20%2F%3E%5Bdrm%5D%20vivante%201.0.0%2020120216%20%E3%82%92%E3%83%9E%E3%82%A4%E3%83%8A%E3%83%BC%200%20%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3Ebrd%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ECAN%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E63fec000.ethernet%20%E3%82%B5%E3%83%97%E3%83%A9%E3%82%A4%20phy%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%20'Enhanced'%20%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eehci-mxc%3A%20Freescale%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%20EHCI%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb-storage%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usb_ehset_test%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E53f80800.usbmisc%20%E9%9B%BB%E6%BA%90%20vbus-wakeup%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%E3%82%AC%E3%82%B8%E3%82%A7%E3%83%83%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%EF%BC%9AEHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B7%201%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%20USB%202.0%20%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81EHCI%201.00%3CBR%20%2F%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%20%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emousedev%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%AB%E5%85%B1%E9%80%9A%E3%81%AE%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Einput%3A%20mma8450%20%E3%82%92%20%2Fdevices%2Fvirtual%2Finput%2Finput0%20%E3%81%A8%E3%81%97%E3%81%A6%E5%85%A5%E5%8A%9B%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bisl29023%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bisl29023%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E5%86%8D%E9%96%8B%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Ei2c%20%2Fdev%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3EIR%20NEC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC5(x)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC6%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20JVC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20Sony%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20RC5%20(streamzap)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20SANYO%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIR%20MCE%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecoda%2063ff4000.vpu%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-2%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Ecoda%2063ff4000.vpu%EF%BC%9A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmag3110%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ei2c-core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5Bmag3110%5D%20%E3%81%8C%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eimx2-wdt%2053f98000.wdog%3AIMX2%2B%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%EF%BC%88nowayout%3D0%EF%BC%89%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2%3CBR%20%2F%3EBluetooth%3A%20HCI%20H4%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCI%20BCSP%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20bcm203x%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20btusb%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20ath3k%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3Esdhci%3A%20%C2%A9%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%3A%20SDHCI%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%8A%E3%82%88%E3%81%B3%20OF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%3CBR%20%2F%3Emmc0%3A%20vqmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc0%3A%20vmmc%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc0%3A%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%2050004000.esdhc%20%5B50004000.esdhc%5D%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99ADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emmc1%3A%20VQMMC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc1%3A%20VMMC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emmc0%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Emmc1%3A%2050020000.esdhc%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%5B50020000.esdhc%5DADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emmc0%3A%20%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9FSDHC%E3%82%AB%E3%83%BC%E3%83%89%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200007)%3CBR%20%2F%3E%E5%A4%89%E6%8F%9B%E7%94%A8%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emmcblk0%3A%20mmc0%3A0007%20SD16G%2014.5%20GiB%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90usbhid%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbhid%3A%20USB%20HID%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3E%20mmcblk0%3A%20p1%20p2%3CBR%20%2F%3Esgtl5000%201-000a%3A%20sgtl5000%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B30x11%3CBR%20%2F%3Eimx-sgtl5000%20sound.8%3A%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%20%3CBR%20%2F%3Eimx-sgtl5000%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%BB%E3%82%AA%E3%83%96%E3%83%BB%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%80%828%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2026%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ETCP%3A%20cubic%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2010%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2017%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecan%3A%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2%20(rev%2020120528%20abi%209)%3CBR%20%2F%3ENET%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%2029%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecan%3A%20raw%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528)%3CBR%20%2F%3Ecan%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(rev%2020120528%20t)%3CBR%20%2F%3Ecan%3A%20netlink%20%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%20(rev%2020130117)%20max_hops%3D1%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20TTY%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.11%3CBR%20%2F%3EBluetooth%3A%20BNEP%20(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.3%3CBR%20%2F%3EBluetooth%3A%20BNEP%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3CBR%20%2F%3EBluetooth%3A%20BNEP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%20HIDP%20(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.2%3CBR%20%2F%3EBluetooth%3A%20HIDP%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v1.8%3CBR%20%2F%3E%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20dns_resolver%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20f51a000c%20%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E8%A6%81%E6%B1%82%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3Epgd%20%3D%2080004000%3CBR%20%2F%3E%5Bf51a000c%5D%20*pgd%3D00000000%3CBR%20%2F%3E%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Oops%3A%205%20%5B%231%5D%20PREEMPT%20SMP%20ARM%3CBR%20%2F%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3CBR%20%2F%3ECPU%3A%200%20PID%3A%201%20Comm%3A%20swapper%2F0%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%203.14.38%20%231%3CBR%20%2F%3E%E3%82%BF%E3%82%B9%E3%82%AF%3A%20c8068000%20ti%3A%20c806c000%20%E3%82%BF%E3%82%B9%E3%82%AF.ti%3Ac806c000%3CBR%20%2F%3EPC%20%E3%81%AF%20mx5_cpu_lp_set%2B0x10%2F0xfc%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3ELR%20%E3%81%AF%20imx5_pm_init%2B0x64%2F0x80%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Epc%20%3A%20%5B%26lt%3B8001d804%26gt%3B%5D%20lr%20%3A%20%5B%26lt%3B809da58c%26gt%3B%5D%20psr%3A%2060000113%3CBR%20%2F%3Esp%20%3A%20c806dedc%20ip%20%3A%2000000072%20fp%20%3A%2000000000%3CBR%20%2F%3Er10%3A%20c806c038%20r9%20%3A%2080a1ee7c%20r8%20%3A%20809d1190r7%20%3A%2080aa2100%20r6%20%3A%2080aa2100%20r5%20%3A%2000000007%20r4%20%3A%20c801b600%3CBR%20%2F%3Er3%20%3A%20f51a0000%20r2%20%3A%208001d8f0%20r1%20%3A%2000000002%20r0%20%3A%2000000002%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%20nZCv%20IRQs%20on%20FIQs%20on%20Mode%20SVC_32%20ISA%20ARM%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%3A%2010c5387d%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A%2070004019%20DAC%3A%2000000015%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%2F0%20(pid%3A%201%2C%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E5%88%B6%E9%99%90%20%3D%200xc806c238)%3CBR%20%2F%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3A%20(0xc806dedc%20%E3%81%8B%E3%82%89%200xc806e000)%3CBR%20%2F%3Edec0%3A%20c801b600%3CBR%20%2F%3Edee0%3A%2000000007%20809da58c%2080a2b80c%20809d11b0%2000000000%20800088bc%20c800ccc0%20808c7d28%3CBR%20%2F%3Edf00%3A%20c8096200%2080714144%2000000000%2000000000%2000000000%208012a57c%2000000000%2080a446b0%3CBR%20%2F%3Edf20%3A%2060000113%2000000001%20cbfffc2e%208073b938%200000010b%20800498e0%2080996644%2000000007%3CBR%20%2F%3Edf40%3A%20cbfffc36%2000000007%2080a446a0%2080a2b80c%2000000007%2080aa2100%2080aa2100%20809ce50c%3CBR%20%2F%3Edf60%3A%2080a1ee7c%200000010b%2080a1ee74%20809cec38%2000000007%2000000007%20809ce50c%208070fbd8%3CBR%20%2F%3Edf80%3A%2000000000%2000002100%2080706164%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3Edfa0%3A%2000000000%2080706170%2000000000%208000e278%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3Edfc0%3A%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3Edfe0%3A%2000000000%2000000000%2000000000%2000000000%2000000013%2000000000%2080000220%2008040010%3CBR%20%2F%3E%5B%26lt%3B8001d804%26gt%3B%5D%20(mx5_cpu_lp_set)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B809da58c%26gt%3B%5D%20(imx5_pm_init%2B0x64%2F0x80)%3CBR%20%2F%3E%5B%26lt%3B809da58c%26gt%3B%5D%20(imx5_pm_init)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B809d11b0%26gt%3B%5D%20(init_machine_late%2B0x20%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B809d11b0%26gt%3B%5D%20(init_machine_late)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B800088bc%26gt%3B%5D%20(do_one_initcall%2B0xf8%2F0x144)%3CBR%20%2F%3E%5B%26lt%3B800088bc%26gt%3B%5D%20(do_one_initcall)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B809cec38%26gt%3B%5D%20(kernel_init_freeable%2B0x13c%2F0x1dc)%3CBR%20%2F%3E%5B%26lt%3B809cec38%26gt%3B%5D%20(kernel_init_freeable)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B80706170%26gt%3B%5D%20(kernel_init%2B0xc%2F0xe8)%3CBR%20%2F%3E%5B%26lt%3B80706170%26gt%3B%5D%20(kernel_init)%20%E3%81%8B%E3%82%89%20%5B%26lt%3B8000e278%26gt%3B%5D%20(ret_from_fork%2B0x14%2F0x3c)%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%3A%20e3a03000%20e92d4030%20e1a01000%20e34f351a%20(e593c00c)%3CBR%20%2F%3E---%5B%20end%20trace%2065acb852349b9d5b%20%5D---%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%20-%20%E5%90%8C%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20init%20%E3%82%92%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%3D0x0000000b%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ET%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUbuntu%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%96%E3%83%AD%E3%82%B0%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E3%81%82%E3%82%8B%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGary%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Euboot%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%EF%BC%88%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E6%B7%BB%E4%BB%98%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Ebaudrate%3D115200%3CBR%20%2F%3Eboard%3Dsabrelite%3CBR%20%2F%3Ebootargs%3Dconsole%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk2p1%20rootwait%20rw%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3CBR%20%2F%3Ebootargs_base%3Dsetenv%20bootargs%20console%3Dttymxc0%2C115200%3CBR%20%2F%3Ebootargs_mmc%3Dsetenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk2p1%20rootwait%20rw%3CBR%20%2F%3Ebootcmd%3Drun%20bootcmd_mmc%3CBR%20%2F%3Ebootcmd_mmc%3Drun%20bootargs_base%20bootargs_mmc%3Bmmc%20dev%201%3Bmmc%20read%20%24%7Bloadaddr%7D%200x800%200x4000%3Bmmc%20read%20%24%7Bfdt_addr%7D%200x5000%200x800%3Bbootm%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3CBR%20%2F%3Ebootdelay%3D3%3CBR%20%2F%3Ebootdevs%3Dsata%20mmc%20usb%3CBR%20%2F%3Eclearenv%3Dif%20sf%20probe%20%7C%7C%20sf%20probe%20%7C%7C%20sf%20probe%201%20%3B%20then%20sf%20erase%200xc0000%200x2000%20%26amp%3B%26amp%3B%E3%82%A8%E3%82%B3%E3%83%BC%E3%81%8C%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%82%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3B%20fi%3CBR%20%2F%3Ecmd_hdmi%3Dfdt%20set%20fb_hdmi%20status%20okay%3Bfdt%20set%20fb_hdmi%20mode_str%201280x720M%4060%3B%3CBR%20%2F%3Ecmd_lcd%3Dfdt%20set%20fb_lcd%20status%20disabled%3CBR%20%2F%3Ecmd_lvds%3Dfdt%20set%20fb_lvds%20status%20disabled%3CBR%20%2F%3Econsole%3Dttymxc1%3CBR%20%2F%3Ecpu%3D6Q%3CBR%20%2F%3Edfu_alt_info%3Du-boot%20raw%200x0%200xc0000%3CBR%20%2F%3Eethact%3DFEC%3CBR%20%2F%3Eethaddr%3D00%3A19%3Ab8%3A02%3A79%3A6c%3CBR%20%2F%3Eethprime%3DFEC%3CBR%20%2F%3Efdt_addr%3D0x18000000%3CBR%20%2F%3Efdt_high%3D0xffffffff%3CBR%20%2F%3Efilesize%3D70c00%3CBR%20%2F%3Einitrd_high%3D0xffffffff%3CBR%20%2F%3Ekernel%3DuImage%3CBR%20%2F%3Eloadaddr%3D0x80800000%3CBR%20%2F%3Eloadsplash%3Dif%20sf%20probe%20%3B%20then%20sf%20read%20%24%7Bsplashimage%7D%20c2000%20%24%7Bsplashsize%7D%20%3B%20fi%3CBR%20%2F%3Ereset_cause%3D1%3CBR%20%2F%3Erundfu%3Ddfu%200%20sf%200%3A0%3A25000000%3A0%3CBR%20%2F%3Estdout%3Dserial%2Cvga%3CBR%20%2F%3Euboot_defconfig%3Dnitrogen6q%3CBR%20%2F%3Eumsdevs%3Dsata%20mmc%3CBR%20%2F%3Eupgradeu%3Dfor%20dtype%20in%20%24%7Bbootdevs%7D%3B%20do%20for%20disk%20in%200%201%20%3B%20do%20%24%7Bdtype%7D%20dev%20%24%7Bdisk%7D%3Bload%20%24%7Bdtype%7D%20%24%7Bdisk%7D%3A1%2010008000%20%2F6x_upgrade%20%26amp%3B%26amp%3B%20source%2010008000%20%3B%20done%20%3B%20done%3CBR%20%2F%3Eusbnet_devaddr%3D00%3A19%3Ab8%3A00%3A00%3A02%3CBR%20%2F%3Eusbnet_hostaddr%3D00%3A19%3Ab8%3A00%3A00%3A01%3CBR%20%2F%3Eusbrecover%3Dsetenv%20ethact%20usb_ether%3B%20setenv%20ipaddr%2010.0.0.2%3B%20setenv%20netmask%20255.255.255.0%3B%20setenv%20serverip%2010.0.0.1%3B%20%3CBR%20%2F%3Esetenv%20bootargs%20console%3Dttymxc1%2C115200%3B%20tftp%20boot%2010800000%2010.0.0.1%3AuImage-%24%7Bboard%7D-recovery%26amp%3B%26amp%3B%20tftpboot%2012800000%2010.0.0.1%3Auramdisk-%24%7Bboard%7D-recovery.img%20%26amp%3B%26amp%3B%20bootm%2010800000%2012800000%3C%2FP%3E%3CP%3E%E7%92%B0%E5%A2%83%E3%82%B5%E3%82%A4%E3%82%BA%3A%201701%2F8188%20%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%3D%26gt%3B%20%E3%83%96%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%81OK%3CBR%20%2F%3Emmc1%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3EMMC%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%201%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%202048%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%2016384...16384%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%20OK%3C%2FP%3E%3CP%3EMMC%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%9A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%23%201%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%23%2020480%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%202048%20...%202048%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%9AOK%3CBR%20%2F%3Ebootm%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%BD%A2%E5%BC%8F%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGary%E6%A7%98%E3%80%81%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E7%8A%B6%E6%B3%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0TV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%20(adv7343)%20%E3%82%92imx6%20(BDSL)%E3%81%AERGB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20(3.14.52_1.1.0_ga)%E3%81%AEmxc_lcd.if%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81LCD%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92V_SYNC%20%7C%20H_SYNC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E7%A7%81%E3%81%AB%E3%81%AF%E9%81%B8%E6%8A%9E%E8%82%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%EF%BC%89%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%EF%BC%88%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AA%E3%81%AE%E3%81%A7%EF%BC%89%E4%BB%A5%E5%A4%96%E3%81%AB%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E8%87%AA%E5%88%86%E3%81%A7%E8%B5%B7%E5%8B%95%E5%8F%AF%E8%83%BD%E3%81%AASD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E8%80%83%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESD%E3%81%AE%E6%BA%96%E5%82%99%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%86%85%E5%AE%B9%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3Eexport%20DISK%3D%2Fdev%2Fsdg%3CBR%20%2F%3Esudo%20dd%20if%3D%2Fdev%2Fzero%20of%3D%24%7BDISK%7D%20bs%3D1M%20count%3D10%3CBR%20%2F%3Ecd%20binary%2F%3CBR%20%2F%3Esudo%20dd%20if%3Du-boot.imx%20of%3D%24%7BDISK%7D%20bs%3D512%20seek%3D2%3CBR%20%2F%3Esync%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F------------%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Esudo%20fdisk%20%24%7BDISK%7D%3CBR%20%2F%3E%20d%20%2F%2F%20%E7%8F%BE%E5%9C%A8SD%E4%B8%8A%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%89%8A%E9%99%A4%3CBR%20%2F%3En%20%2F%2F%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3Ep%20%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%3CBR%20%2F%3E1%20%2F%2F%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E7%95%AA%E5%8F%B71%3CBR%20%2F%3E%202048%20%2F%2F%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3E%2B1G%20%2F%2F%3CBR%20%2F%3E%20n%20%2F%2F%202%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3Ep%3CBR%20%2F%3E%202%3CBR%20%2F%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3Ew%3CBR%20%2F%3Esudo%20mkfs.vfat%20%24%7BDISK%7D1%3CBR%20%2F%3E%20sudo%20mkfs.ext3%20%24%7BDISK%7D2%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eext3%20SD%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%20%2Fmedia%2Frootfs%20%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3A%3CBR%20%2F%3Esudo%20mount%20%24%7BDISK1%7D%20%2Fmedia%2Fkernel_target%3CBR%20%2F%3Esudo%20mount%20%24%7BDISK%7D2%20%2Fmedia%2Frootfs_target%3CBR%20%2F%3Esudo%20cp%20%E2%80%93v%20binary%2F%20i%24target-%24board.dtb%20%2Fmedia%2Fkernel_target%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2Fdtb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CBR%20%2F%3Esudo%20cp%20%E2%80%93v%20binary%2FuImage%20%2Fmedia%2Fkernel_target%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2FuImage%26nbsp%3B%3CBR%20%2F%3Esudo%20mv%20%2Fmedia%2Frootfs%2F*%20%2Fmedia%2Frootfs_target%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F%2F%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81NAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%9Fuboot%E3%81%AB%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81uboot%E3%81%AE%E3%80%8Cprint%E3%80%8D%E3%81%8C%E3%81%93%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82uboot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%230%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%99%E3%80%81OK%3CBR%20%2F%3Emmc1%20%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EMMC%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%201%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%202048%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%2016384...16384%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%20OK%3C%2FP%3E%3CP%3EMMC%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%9A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%23%201%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%23%2020480%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%202048%20...%202048%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%9AOK%3CBR%20%2F%3Ebootm%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%BD%A2%E5%BC%8F%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%8B%E3%82%89%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%80%B2%E3%82%81%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%8C%E3%83%A9%E3%83%80%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%80%81SabreLite%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%99%E3%81%90%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8BUbuntu%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fubuntu-xenial-mx67-boards-august-2016-kernel-4-1-15%2F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81Debian%E3%82%92%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fdebian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fdebian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fdebian-8-3-jessie-for-i-mx6-boards-february-2016-kernel-3-14-28%2F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%81VPU%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81Chrome%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AA%E3%81%A9%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AENXP%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E3%80%8Capt%20update%20%26amp%3B%26amp%3B%20apt%20upgrade%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E6%9C%80%E6%96%B0%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGary%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAnuradha%E6%A7%98%E3%80%81%3CA%20_jive_internal%3D%22true%22%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F836641%3FcommentID%3D836641%26amp%3Bet%3Dwatches.email.thread%23comment-836641%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F836641%3FcommentID%3D836641%26amp%3Bet%3Dwatches.email.thread%23comment-836641%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F836641%3FcommentID%3D836641%26amp%3Bet%3Dwatches.email.thread%23comment-836641%3C%2FA%3E%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%8F%A4%E3%81%84uboot%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82rootfs%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFimx6%20sabrelite%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E6%AD%A3%E7%A2%BA%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Ubuntu%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%E3%82%A2%E3%83%B3%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E5%BE%8C%E3%81%ABSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF6x_bootscript%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%80%81%E5%8F%A4%E3%81%84uBoot%E3%81%8CNand%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E7%8B%AC%E8%87%AA%E3%81%AEuBoot%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81rootfs%E3%81%A8zImage%E3%82%92%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%97%E3%81%A6%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23f6f6f6%3B%22%3Egcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux.tar.xz%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%8Cubuntu14.04%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82gcc-linaro-4.8-2015.06-x86_64_arm-linux-xxxx%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%82%89%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E6%95%AC%E5%85%B7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%20background-color%3A%20%23f6f6f6%3B%22%3EWenming%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%2C%3C%2FP%3E%3CP%3E%2Fbin%2Fsh%201%3A%20arm-linux-gnueabihf-gcc%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%82%8C%E3%81%AF%20arm-linux-gnueabihf-gcc-4.9.4%20%E3%81%B8%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%87%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20NXP%20i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEUbuntu%20Rootfs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82HDMI%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:07 AM
更新者:
