HDMI Audio Setting
HDMI Audio Setting
HDMI Audio Setting
1. Set up HDMI
Set up your kernel to use HDMI adding the following code to bootargs on u-boot:
video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
2. Test raw audio
In order to test only raw audio, use the following command:
aplay -D hw:1,0 Kaleidoscope.wav
3. Make HDMI audio the default output
In order to configure audio output over HDMI, please, replace content of file ~/.asoundrc to the following one
pcm.dmix_48000{
     type dmix
     ipc_key 5678293
     ipc_key_add_uid yes
     slave{
          pcm "hw:1,0"
          period_time 0
          period_size 2048
          buffer_size 24576
          format S16_LE
          rate 48000
pcm.!dsnoop_44100{
     type dsnoop
     ipc_key 5778293
     ipc_key_add_uid yes
     slave{
          pcm "hw:0,0"
          period_time 0
          period_size 2048
          buffer_size 24576
          format S16_LE
          rate 44100
pcm.!dsnoop_48000{
     type dsnoop
     ipc_key 5778293
     ipc_key_add_uid yes
     slave{
          pcm "hw:1,0"
          period_time 0
          period_size 2048
          buffer_size 24576
          format S16_LE
          rate 48000
pcm.asymed{
     type asym
     playback.pcm "dmix_48000"
     capture.pcm "dsnoop_44100"
pcm.dsp0{
     type plug
     slave.pcm "asymed"
pcm.!default{
     type plug
     route_policy "average"
     slave.pcm "asymed"
ctl.mixer0{
     type hw
     card 0
This will configure alsa to use sound card hw:1,0. Please, pay attention to use the proper audio card name for your device.
In order to see available sound cards on board:
root@imx53qsb:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: imx3stack [imx-3stack], device 0: SGTL5000 SGTL5000-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: imx3stackspdif [imx-3stack-spdif], device 0: IMX SPDIF mxc spdif-0 []
  Subdevices: 1/1
For detail on how to create asound.conf, please see alsa-lib configuration introduction.
4. Encoded audio
For encoded (i.e. AC3, DTS) audio, you can use, for example, ac3dec, an utility provided by alsa-tools with the following command line:
ac3dec -D hw:1,0 -C test.ac3
This would work for both HDMI audio and SPDIF audio. Double check your hardware and/or schematic in order to know which one to use.
ラベル(2)
タグ(2)
コメント
Very beautiful guide, how to set default SPDIF audio card on Android ?
good, it really works if i use the native app to play audio in IMX6QSD :smileyhappy:
but there is no audio output from HDMI with the pulse audio server.
the output of audio just is from the "wm8962audio" as bellow in my IMX6QSD, any advices about this ?
i want to use pulse audio server to output in HDMI interface.
root@imx6qsabresd:~# aplay -l
card 0: wm8962audio [wm8962-audio], device 0: HiFi wm8962-0 []
  Subdevices: 1/1
card 1: imxhdmisoc [imx-hdmi-soc], device 0: IMX HDMI TX mxc-hdmi-soc-0 []
  Subdevices: 0/1
ohhhhhhhhhhhh you´re right! the way to configure pulseaudio is different....
From my old emails, I got this command line:
pacmd set-default-sink 1
Could you, please, give it a try and let us know the results?
     There is not the command "pacmd", just "pactl".
BTW, i use the YOCTO project of FSL community to build all, what is my next step about for your ask ?
Well, I think you make it work (by your comment on meta-freescale)
it looks like bad, i also stat up the daemon like what i said in mail list,
i restart again with command "pulseaudio -D", the output of audio is not from HDMI except the "card 0: wm8962audio [wm8962-audio], device 0: HiFi wm8962-0 []"
it's really strange, help...
i think the pulseaduio detect the output of audio, sometime is HDMI and sometime is the other, so i need to specify the HDMI as the default output, how to do ?
look for some pulseaudio conf file. Create a bbappend on your meta layer in order to add this by default on your image.
(sorry, i don't know pulseaudio :smileysad:)
Dear Daiane Angolini,
I want to know how to configure the HDMI Audio as 24bit in i.MX6Q / Linux 3.14.52.
Please let me know how to do that.
It's very helpful to me if you tell me how to confirm that in i.MX6Q Evaluation board.
Actually I could confirm the below contents in the some documents.
- HDMI Audio 24bit is supported in the i.MX6Q Reaference Manual
  . Table 33-6. Data Arrangement in System Memory for L-PCM (24 bits) in Chapter 33
- HDMI Audio 24bit is NOT supported in the i.MX6 Linux Reference Manual for Linux 3.14.52
  . Chapter 15 On-Chip High Definition Multimedia Interface (HDMI) Driver
Eric.
Could you, please, create a new ticket? Otherwise it might get off the radar
I created a new ticket through SR.
Please check the below case from SR.
[Case:00198948] How to configure the HDMI Audio as 24bit in i.MX6Q / Linux 3.14.52
Eric.
%3CLINGO-SUB%20id%3D%22lingo-sub-1127628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHDMI-Audio-Setting%2Fta-p%2F1127628%23toc-hId-1073107864%22%20target%3D%22_blank%22%3E1.HDMI%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHDMI-Audio-Setting%2Fta-p%2F1127628%23toc-hId--734346599%22%20target%3D%22_blank%22%3E2.%20%E7%94%9F%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHDMI-Audio-Setting%2Fta-p%2F1127628%23toc-hId-1753166234%22%20target%3D%22_blank%22%3E3.HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHDMI-Audio-Setting%2Fta-p%2F1127628%23toc-hId--54288229%22%20target%3D%22_blank%22%3E4.%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1414404969%22%20id%3D%22toc-hId--493594799%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1073107864%22%20id%3D%22toc-hId-1993918034%22%3E1.HDMI%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FH2%3E%3CP%3EHDMI%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81u-boot%20%E3%81%AE%20bootargs%20%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Evideo%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--734346599%22%20id%3D%22toc-hId-186463571%22%3E2.%20%E7%94%9F%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AA%E5%8A%A0%E5%B7%A5%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E3%81%BF%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22panelContent%20codeContent%22%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Eaplay%20-D%20hw%3A1%2C0%20Kaleidoscope.wav%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1753166234%22%20id%3D%22toc-hId--1620990892%22%3E3.HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3EHDMI%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81~%2F.asoundrc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Epcm.dmix_48000%7B%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%97dmix%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipc_key%205678293%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipc_key_add_uid%20yes%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20slave%7B%3C%2FP%3E%0A%3CP%3EPCM%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8Chw%3A1%2C0%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eperiod_time%200%3C%2FP%3E%0A%3CP%3Eperiod_size%202048%3C%2FP%3E%0A%3CP%3Ebuffer_size%2024576%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88S16_LE%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%83%BC%E3%83%88%2048000%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Epcm.!dsnoop_44100%7B%3C%2FP%3E%0A%3CP%3EDSNOOP%20%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipc_key%205778293%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipc_key_add_uid%20yes%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20slave%7B%3C%2FP%3E%0A%3CP%3EPCM%20%3CSPAN%20class%3D%22code-quote%22%3E%22hw%3A0%2C0%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eperiod_time%200%3C%2FP%3E%0A%3CP%3Eperiod_size%202048%3C%2FP%3E%0A%3CP%3Ebuffer_size%2024576%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88S16_LE%3C%2FP%3E%0A%3CP%3E%E6%96%99%E9%87%91%2044100%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Epcm.!dsnoop_48000%7B%3C%2FP%3E%0A%3CP%3EDSNOOP%20%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipc_key%205778293%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipc_key_add_uid%20yes%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20slave%7B%3C%2FP%3E%0A%3CP%3EPCM%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8Chw%3A1%2C0%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eperiod_time%200%3C%2FP%3E%0A%3CP%3Eperiod_size%202048%3C%2FP%3E%0A%3CP%3Ebuffer_size%2024576%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88S16_LE%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%83%BC%E3%83%88%2048000%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Epcm.asymed%7B%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%82%B7%E3%83%A0%E5%9E%8B%3C%2FP%3E%0A%3CP%3Eplayback.pcm%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8Cdmix_48000%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ecapture.pcm%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8Cdsnoop_44100%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Epcm.dsp0%7B%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%97%E3%83%97%E3%83%A9%E3%82%B0%3C%2FP%3E%0A%3CP%3Eslave.pcm%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8C%E3%82%A2%E3%82%B7%E3%83%A1%E3%83%89%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Epcm.!%3CSPAN%20class%3D%22code-keyword%22%3Edefault%3C%2FSPAN%3E%7B%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%97%E3%83%97%E3%83%A9%E3%82%B0%3C%2FP%3E%0A%3CP%3Eroute_policy%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8C%E5%B9%B3%E5%9D%87%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eslave.pcm%20%3CSPAN%20class%3D%22code-quote%22%3E%E3%80%8C%E3%82%A2%E3%82%B7%E3%83%A1%E3%83%89%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Ectl.mixer0%7B%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%97HW%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%890%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81alsa%20%E3%81%8C%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%20hw%3A1%2C0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%AB%E3%83%BC%E3%83%89%E5%90%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%88%B9%E5%86%85%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3A%3C%2FP%3E%3CP%20class%3D%22panelContent%20codeContent%22%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Eroot%40imx53qsb%3A~%23%20aplay%20-l%3C%2FP%3E%0A%3CP%3EPLAYBACK%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%20****%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%890%3AIMX3stack%20%5BIMX-3stack%5D%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3ASGTL5000%20SGTL5000-0%20%5B%5D%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A1%2F1%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3A%20%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3C%2FP%3E%0A%3CP%3Ecard%201%3A%20imx3stackspdif%20%5Bimx-3stack-spdif%5D%2C%20device%200%3A%20IMX%20SPDIF%20mxc%20spdif-0%20%5B%5D%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A1%2F1%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3A%20%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3Easound.conf%20%E3%81%AE%E4%BD%9C%E6%88%90%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93592%22%20target%3D%22_blank%22%3Ealsa-lib%20%E8%A8%AD%E5%AE%9A%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--54288229%22%20id%3D%22toc-hId-866521941%22%3E4.%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81AC3%2C%20DTS)%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%A7%E3%81%AF%E3%80%81alsa-tools%20%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%81%A7%E3%81%82%E3%82%8B%20ac3dec%20%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Eac3dec%20-D%20hw%3A1%2C0%20-C%20test.ac3%3C%2FP%3E%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%A8SPDIF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%84%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX53%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Daiane%20Angolini%2C%3C%2FP%3E%3CP%3ESR%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESR%E3%81%8B%E3%82%89%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%90%E4%BA%8B%E4%BE%8B%3A00198948%E3%80%91i.MX6Q%20%2F%20Linux%203.14.52%E3%81%A7HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%9224%E3%83%93%E3%83%83%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%83%AC%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89%E5%A4%96%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Daiane%20Angolini%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6Q%20%2F%20Linux%203.14.52%E3%81%A7HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%9224bit%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6Q%20Evaluation%20board%E3%81%A7%E3%81%AE%E7%A2%BA%E8%AA%8D%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%B3%87%E6%96%99%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E-%20HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA24bit%E3%81%AFi.MX6Q%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%A7%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E.%E8%A1%A8%2033-6.%E7%AC%AC33%E7%AB%A0%E3%81%AEL-PCM(24%E3%83%93%E3%83%83%E3%83%88)%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E9%85%8D%E7%BD%AE%3CBR%20%2F%3E.%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Novatron_MX6D_04-6.1_HDMI.Audio_24bit.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Novatron_MX6D_04-6.1_HDMI.Audio_24bit.png%22%20style%3D%22width%3A%20971px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69680i3DF1CB569D3069FA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Novatron_MX6D_04-6.1_HDMI.Audio_24bit.png%22%20alt%3D%22Novatron_MX6D_04-6.1_HDMI.Audio_24bit.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENovatron_MX6D_04-6.1_HDMI.Audio_24bit.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E-%20HDMI%20Audio%2024bit%20%E3%81%AF%E3%80%81i.MX6%20Linux%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%20for%20Linux%203.14.52%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E.%E7%AC%AC%2015%20%E7%AB%A0%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%20HD%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20(HDMI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3E.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Novatron_MX6D_04-6.2_HDMI.Audio_24bit.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Novatron_MX6D_04-6.2_HDMI.Audio_24bit.png%22%20style%3D%22width%3A%20611px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69756iC2B16AEFDBFDC7B8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Novatron_MX6D_04-6.2_HDMI.Audio_24bit.png%22%20alt%3D%22Novatron_MX6D_04-6.2_HDMI.Audio_24bit.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENovatron_MX6D_04-6.2_HDMI.Audio_24bit.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPulseAudio%20conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%A1%E3%82%BF%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%ABbbappend%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E7%94%BB%E5%83%8F%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E(%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AFpulseaudio%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPulseAduio%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%80%81%E3%81%82%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AFHDMI%E3%81%A7%E3%80%81%E3%81%82%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E4%BB%96%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6HDMI%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E6%82%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%82%82%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E8%A8%80%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92stat%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%22pulseaudio%20-D%22%20%E3%81%A7%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%20HDMI%20%E3%81%8B%E3%82%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%22%E3%82%AB%E3%83%BC%E3%83%89%200%3A%20wm8962audio%20%5Bwm8962-audio%5D%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200%3A%20HiFi%20wm8962-0%20%5B%5D%22%3C%2FP%3E%3CP%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E4%B8%8D%E6%80%9D%E8%AD%B0%E3%81%A7%E3%81%99%E3%80%81%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%82%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%80%8C%3CSTRONG%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%20color%3A%20%231f497d%3B%22%3Epacmd%3C%2FSTRONG%3E%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%80%8Cpactl%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%81%A0%E3%81%91%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AFFSL%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AEYOCTO%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E7%A7%81%E3%81%AE%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%82%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99!PulseAudio%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%8F%A4%E3%81%84%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Epacmd%20set-default-sink%201%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3E%E3%81%9C%E3%81%B2%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%231f497d%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%89%AF%E3%81%84%E3%80%81%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6IMX6QSD%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E3%81%A8%E6%9C%AC%E5%BD%93%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%91%E3%83%AB%E3%82%B9%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FHDMI%E3%81%8B%E3%82%89%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E5%87%BA%E5%8A%9B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AEIMX6QSD%E3%81%AB%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%8CWM8962audio%E3%80%8D%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPulse%20Audio%20Server%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6HDMI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6qsabresd%3A~%23%20aplay%20-l%3C%2FP%3E%3CP%3EPLAYBACK%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%20****%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%890%3Awm8962audio%20%5Bwm8962-audio%5D%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3AHiFi%20wm8962-0%20%5B%5D%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A1%2F1%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3A%20%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%89%201%3A%20imxhdmisoc%20%5Bimx-hdmi-soc%5D%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200%3A%20IMX%20HDMI%20TX%20mxc-hdmi-soc-0%20%5B%5D%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%200%2F1%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3A%20%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%230%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%BE%8E%E3%81%97%E3%81%84%E3%82%AC%E3%82%A4%E3%83%89%E3%80%81Android%E3%81%A7%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AESPDIF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-06-2012 10:41 AM
更新者:
