GStreamer i.MX6 Multi-Display
Multiple-Display means video playback on multiple screens. In case playback needs to be in a unique screen, the mfw_isink element must be used and some pipelines examples can be found on this link: GStreamer iMX6 Multi-Overlay.
Number of DisplaysDisplay typeKernel parameters
Pipelines
# Set these shells variables before running the pipelines
alias gl=gst-launch
SINK_1="\"mfw_v4lsink device=/dev/video17\""
SINK_2="\"mfw_v4lsink device=/dev/video18\""
SINK_3="\"mfw_v4lsink device=/dev/video20\""
media1=file:///root/media1
media2=file:///root/media2
media3=file:///root/media3
2hdmi + lvds
video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666
gl playbin2 uri=$media1 video-sink=$SINK_1 playbin2 uri=$media2 video-sink=$SINK_2
2lvds + lvds
video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666
2lcd + lvds
video=mxcfb0:dev=lcd,800x480M@55,if=RGB565
3
hdmi + lvds + lvds
video=mxcfb2:dev=ldb,LDB-XGA,if=RGB666
gl playbin2 uri=$media1 video-sink=$SINK_1 playbin2 uri=$media2 video-sink=$SINK_2 playbin2 uri=$media3 video-sink=$SINK_3
ラベル(4)
コメント
HDMI + LCD is OK ?
It should be. Just set proper u-boot values.
Leo
I need to display same video on two display at the same time.
Can gst-launch do this?
Thank you
hi ,
it can do this.I used qmx6 4 core to test.
Can you tell me the comand line  to do this?
Thank you.
Hi ,
gst-launch playbin2 uri=file: /home/media/bbb_short_1080p.avi video-sink="mfw_v4lsink device=/dev/video17" &
gst-launch playbin2 uri=file: /home/media/bbb_short_1080p.avi video-sink="mfw_v4lsink device=/dev/video19"
You need to set the kernel and u-boot values
4
Andy 曾石堂
Kancotec 深圳康控科技有限公司
Address : 深圳市宝安区龙华街道建辉路121号信伟大厦11楼1112-1115房
Room 1112-1115, Xin Wei Building, Jianhui No.121, Longhua Town, Baoan District, Shenzhen City
Mobile :+8618681522956
+8615989242961
Tel : +86-755-26653899 EXT 821
Fax : +86-755-26653866
Q Q : 2270806966
skype:andy.kancotec
Email : <mailto:[email protected]> [email protected]
http:// <http://www.kancotec.com> www.kancotec.com
发件人: Gao Jianzhong
发送时间: 2013年8月14日 12:11
收件人: imx6 zeng
主题: Re: - GStreamer i.MX6 Multi-Display
<https://community.freescale.com/> Freescale Community
new comment by Gao <https://community.freescale.com/people/GaoJianzhong?et=watches.email.document_comment> Jianzhong View <https://community.freescale.com/docs/DOC-93449?et=watches.email.document_comment#comment-6211> all comments on this document
Thank you very much.
It seems like that the two display is the same, but it is not.
The process which is excuted later will display the delay content.
My require is to display the same thing totally.
You can use the 2 LVDS interface,set the mode
  • "ldb=spl0/1" -- split mode on DI0/1
  • "ldb=dul0/1" -- dual mode on DI0/1
  • "ldb=sin0/1" -- single mode on LVDS0/1
  • "ldb=sep0/1" -- separate mode begin from LVDS0/1
Config board infor information:linux-3.0\arch\arm\mach-mx6\board-xxx.c
static struct fsl_mxc_ldb_platform_data ldb_data = {
.ipu_id = 1,
.disp_id = 0,
.ext_ref = 1,
.mode = LDB_SEP0,
.sec_ipu_id = 1,
.sec_disp_id = 1,
mode:
spl0: mode = LDB_SPL_DI0;
spl1 : mode = LDB_SPL_DI1;
dul0 : mode = LDB_DUL_DI0;
dul1 : mode = LDB_DUL_DI1;
sep0 : mode = LDB_SEP0;
sep1: mode = LDB_SEP1;
4
Andy 曾石堂
Kancotec 深圳康控科技有限公司
+8615989242961
Q Q : 2270806966
skype:andy.kancotec
发件人: Gao Jianzhong
发送时间: 2013年8月14日 15:03
收件人: imx6 zeng
<https://community.freescale.com/> 图像已被发件人删除。 Freescale Community
new comment by Gao <https://community.freescale.com/people/GaoJianzhong?et=watches.email.document_comment> Jianzhong View <https://community.freescale.com/docs/DOC-93449?et=watches.email.document_comment#comment-6212> all comments on this document
Thank you for your help,
I am not relly understand the differences of bellow modes:
split mode
dual mode
single mode
separate mode
Could you explain it to me? thank you very much.
  • there are two LVDS channels(LVDS0 and LVDS1) which can transfer video
  • datas, there two channels can be used as split/dual/single/separate mode.
  • split mode means display data from DI0 or DI1 will send to both channels
  • LVDS0+LVDS1.
  • dual mode means display data from DI0 or DI1 will be duplicated on LVDS0
  • and LVDS1, it said, LVDS0 and LVDS1 has the same content.
  • single mode means only work for DI0/DI1->LVDS0 or DI0/DI1->LVDS1.
  • separate mode means you can make DI0/DI1->LVDS0 and DI0/DI1->LVDS1 work
  • at the same time.
发件人: Gao Jianzhong
发送时间: 2013年8月14日 17:14
收件人: imx6 zeng
new comment by Gao <https://community.freescale.com/people/GaoJianzhong?et=watches.email.document_comment> Jianzhong View <https://community.freescale.com/docs/DOC-93449?et=watches.email.document_comment#comment-6214> all comments on this document
So I have the following u-boot args, but the terminal says "bootconsole disabled" and then I get the console data on the HDMI display, and I lose my console.
setenv bootargs_mmc 'setenv bootargs ip=none root=/dev/mmcblk1p1 rootwait video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi, 1920x1080M@60,if=RGB24'
Hello guys,
I also have same problem. I have sabre IMX6  board and I am trying to connect two LVDS to this board. I can not make separate mode with boot command like as
setenv bootargs_mmc 'setenv bootargs ${bootargs} root=/dev/mmcblk0p1 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 ldb=sep1' ]
I think it is impossible without modifying source code in kernel according to Zeng's. Am I correct? If then, please let me know the fix point. FYI, I am going to build with L3.0.35_4.1.0_130816_source.tar.gz version.
From Jack.
Hello, gstreamer of my kernel may be not normal ,so I just program applications on V4L2 to let VGA signals to display by LCD and HDMI at the same time , it works ,but we need another function , that is LCD and HDMI can display the kernel starting message at the same time, how can I do , I am looking forward to have your help.Thank you!!
%3CLINGO-SUB%20id%3D%22lingo-sub-1127569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGStreamer%20i.MX6%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%AF%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%8B%AC%E8%87%AA%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%A7%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81mfw_isink%E8%A6%81%E7%B4%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E4%BE%8B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93788%22%20target%3D%22_blank%22%3EGStreamer%20iMX6%20Multi-Overlay%3C%2FA%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%22451%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20923px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E6%95%B0%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%BF%E3%82%A4%E3%83%97%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3EKernel%20parameters%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FSTRONG%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSTRONG%3E%23%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B7%E3%82%A7%E3%83%AB%E5%A4%89%E6%95%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B9gl%20%3D%20gst-launch%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESINK_1%3D%22%5C%22mfw_v4lsink%20device%3D%2Fdev%2Fvideo17%5C%22%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESINK_2%3D%22%5C%22mfw_v4lsink%20device%3D%2Fdev%2Fvideo18%5C%22%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ESINK_3%3D%22%5C%22mfw_v4lsink%20device%3D%2Fdev%2Fvideo20%5C%22%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A21%3D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%2F%2F%2Froot%2Fmedia1%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A22%3D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%2F%2F%2Froot%2Fmedia2%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A23%3D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%2F%2F%2Froot%2Fmedia3%3C%2FSTRONG%3E%3C%2FP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E2%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3EHDMI%20%2B%20LVDS%E3%81%AE%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%3C%2FSTRONG%3E%3C%2FP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3Egl%20playbin2%20uri%3D%24media%201%20video-sink%3D%24SINK_1%20playbin2%20uri%3D%24media%202%20video-sink%3D%24SINK_2%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E2%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3ELVDS%2BLVDS%E3%81%AE%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3Egl%20playbin2%20uri%3D%24media%201%20video-sink%3D%24SINK_1%20playbin2%20uri%3D%24media%202%20video-sink%3D%24SINK_2%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E2%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E%E6%B6%B2%E6%99%B6%20%2B%20LVDS%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb0%3Adev%3Dlcd%2C800x480M%4055%2Cif%3DRGB565%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3Egl%20playbin2%20uri%3D%24media%201%20video-sink%3D%24SINK_1%20playbin2%20uri%3D%24media%202%20video-sink%3D%24SINK_2%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3E3%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EHDMI%20%2B%20LVDS%20%2B%20LVDS%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB6%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Evideo%3Dmxcfb2%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSTRONG%3Egl%20playbin2%20uri%3D%24media%201%20video-sink%3D%24SINK_1%20playbin2%20uri%3D%24media%202%20video-sink%3D%24SINK_2%20playbin2%20uri%3D%24media%203%20video-sink%3D%24SINK_3%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEgstreamer%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9V4L2%E3%81%A7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%A6%E3%80%81VGA%E4%BF%A1%E5%8F%B7%E3%81%8CLCD%E3%81%A8HDMI%E3%81%A7%E5%90%8C%E6%99%82%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%88%A5%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8ALCD%E3%81%A8HDMI%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E9%96%8B%E5%A7%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%20%E7%9A%86%E6%A7%98%E3%81%AE%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%EF%BC%81%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%BF%E3%82%93%E3%81%AA%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BCIMX6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB2%E3%81%A4%E3%81%AELVDS%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%88%A5%E3%80%85%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%22%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20ldb%3Dsep1'%3C%2FSPAN%3E%20%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EZeng%E3%81%AE%E8%A8%80%E3%81%86%E9%80%9A%E3%82%8A%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%86%85%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BF%AE%E6%AD%A3%E7%82%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'%EB%A7%91%EC%9D%80%20%EA%B3%A0%EB%94%95'%3B%20color%3A%20red%3B%22%3E%E7%A7%81%E3%81%AFL3.0.35_4.1.0_130816_source.tar.gz%20%3C%2FSPAN%3E%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%81%8B%E3%82%89%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AEu-boot%E5%BC%95%E6%95%B0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%AF%E3%80%8Cbootconsole%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%84%E3%80%81HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E5%A4%B1%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20ip%3Dnone%20root%3D%2Fdev%2Fmmcblk1p1%20rootwait%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dhdmi%2C%201920x1080M%4060%2Cif%3DRGB24'%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Dspl0%2F1%22%20--%20DI0%2F1%20%E3%81%AE%E5%88%86%E5%89%B2%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Ddul0%2F1%22%20--%20DI0%2F1%20%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Dsin0%2F1%22%20--%20LVDS0%2F1%20%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Dsep0%2F1%22%20--%20LVDS0%2F1%20%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20*%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E8%BB%A2%E9%80%81%E3%81%A7%E3%81%8D%E3%82%8B2%E3%81%A4%E3%81%AELVDS%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB(LVDS0%E3%81%A8LVDS1)%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%83%87%E3%83%BC%E3%82%BF%E3%80%812%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B9%E3%83%97%E3%83%AA%E3%83%83%E3%83%88%2F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%2F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%2F%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20*%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%82%B9%E3%83%97%E3%83%AA%E3%83%83%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81DI0%E3%81%BE%E3%81%9F%E3%81%AFDI1%E3%81%8B%E3%82%89%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20LVDS0%2BLVDS1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81DI0%E3%81%BE%E3%81%9F%E3%81%AFDI1%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8CLVDS0%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81LVDS1%E3%81%AF%E3%80%81LVDS0%E3%81%A8LVDS1%E3%81%AF%E5%90%8C%E3%81%98%E5%86%85%E5%AE%B9%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AF%E3%80%81DI0%2FDI1-%26gt%3BLVDS0%20%E3%81%BE%E3%81%9F%E3%81%AF%20DI0%2FDI1-%26gt%3BLVDS1%20%E3%81%A7%E3%81%AE%E3%81%BF%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81DI0%2FDI1-%26gt%3BLVDS0%E3%81%A8DI0%2FDI1-%26gt%3BLVDS1%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%E5%90%8C%E6%99%82%E3%81%AB%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E4%BB%B6%E4%BA%BA%3A%20Gao%20Jianzhong%20%20%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%E6%97%B6%E9%97%B4%3A%202013%E5%B9%B48%E6%9C%8814%E6%97%A5%2017%3A14%3C%2FP%3E%3CP%3E%E6%94%B6%E4%BB%B6%E4%BA%BA%3A%20imx6%20zeng%3C%2FP%3E%3CP%3E%E4%B8%BB%E9%A2%98%3A%20Re%3A%20%20-%20GStreamer%20i.MX6%20Multi-Display%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%26lt%3B%26gt%3B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGStreamer%20i.MX6%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGao%20%26lt%3B%26gt%3B%E3%81%95%E3%82%93%E3%81%AB%E3%82%88%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88Jianzhong%E3%83%93%E3%83%A5%E3%83%BC%26lt%3B%26gt%3B%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%B8%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E9%81%95%E3%81%84%E3%82%92%E3%82%88%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%97%E3%83%AA%E3%83%83%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E2%20LVDS%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Dspl0%2F1%22%20--%20DI0%2F1%20%E3%81%AE%E5%88%86%E5%89%B2%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Ddul0%2F1%22%20--%20DI0%2F1%20%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Dsin0%2F1%22%20--%20LVDS0%2F1%20%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CUL%3E%3CLI%20level%3D%221%22%20type%3D%22ul%22%3E%3CP%3E%20%20%20%22ldb%3Dsep0%2F1%22%20--%20LVDS0%2F1%20%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%83%9C%E3%83%BC%E3%83%89%E6%83%85%E5%A0%B1%3Alinux-3.0%5Carch%5Carm%5Cmach-mx6%5Cboard-xxx.c%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20fsl_mxc_ldb_platform_data%20ldb_data%20%3D%20%7B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20.ipu_id%20%3D%201%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20.disp_id%20%3D%200%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20.ext_ref%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20.mode%20%3D%20LDB_SEP0%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20.sec_ipu_id%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20.sec_disp_id%20%3D%201%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20spl0%EF%BC%9A%20mode%20%3D%20LDB_SPL_DI0%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20spl1%20%20%20%EF%BC%9A%20%20mode%20%3D%20LDB_SPL_DI1%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20dul0%20%20%20%EF%BC%9A%20%20mode%20%3D%20LDB_DUL_DI0%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edul1%20%20%20%EF%BC%9A%20%20mode%20%3D%20LDB_DUL_DI1%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20sep0%20%20%20%EF%BC%9A%20%20mode%20%3D%20LDB_SEP0%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20sep1%EF%BC%9A%20mode%20%3D%20LDB_SEP1%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAndy%20%E6%9B%BE%E7%9F%B3%E5%A0%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKancotec%20%E6%B7%B1%E5%9C%B3%E5%BA%B7%E6%8E%A7%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAddress%20%3A%20%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%AE%9D%E5%AE%89%E5%8C%BA%E9%BE%99%E5%8D%8E%E8%A1%97%E9%81%93%E5%BB%BA%E8%BE%89%E8%B7%AF121%E5%8F%B7%E4%BF%A1%E4%BC%9F%E5%A4%A7%E5%8E%A611%E6%A5%BC1112-1115%E6%88%BF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%A01112-1115%E3%80%81Xin%20Wei%20Building%E3%80%81Jianhui%20No.121%E3%80%81Longhua%20Town%E3%80%81Baoan%20District%E3%80%81Shenzhen%20City%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%3A%2B8618681522956%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20%20%2B8615989242961%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9B%BB%E8%A9%B1%20%3A%20%2B86-755-26653899%20%E5%86%85%E7%B7%9A%20821%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%83%E3%82%AF%E3%82%B9%20%3A%20%2B86-755-26653866%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQ%20Q%20%20%3A%202270806966%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eskype%EF%BC%9Aandy.kancotec%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEmail%20%20%3A%20%20%3CANDY%3E%20andy%40kancotec.com%3C%2FANDY%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ehttp%3A%2F%2F%20%20%26lt%3B%26gt%3B%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.kancotec.com%22%20target%3D%22test_blank%22%3Ewww.kancotec.com%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E4%BB%B6%E4%BA%BA%3A%20Gao%20Jianzhong%20%20%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%E6%97%B6%E9%97%B4%3A%202013%E5%B9%B48%E6%9C%8814%E6%97%A5%2015%3A03%3C%2FP%3E%3CP%3E%E6%94%B6%E4%BB%B6%E4%BA%BA%3A%20imx6%20zeng%3C%2FP%3E%3CP%3E%E4%B8%BB%E9%A2%98%3A%20Re%3A%20%20-%20GStreamer%20i.MX6%20Multi-Display%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%26lt%3B%26gt%3B%E5%9B%BE%E5%83%8F%E5%B7%B2%E8%A2%AB%E5%8F%91%E4%BB%B6%E4%BA%BA%E5%88%A0%E9%99%A4%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGStreamer%20i.MX6%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGao%20%26lt%3B%26gt%3B%E3%81%95%E3%82%93%E3%81%AB%E3%82%88%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88Jianzhong%E3%83%93%E3%83%A5%E3%83%BC%20%26lt%3B%26gt%3B%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%B8%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%BE%8C%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E9%81%85%E5%BB%B6%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A6%81%E6%B1%82%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Egst-launch%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-launch%20playbin2%20uri%3D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%2Fhome%2Fmedia%2Fbbb_short_1080p.avi%20video-sink%3D%22mfw_v4lsink%20device%3D%2Fdev%2Fvideo17%22%20%26amp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-launch%20playbin2%20uri%3D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%2Fhome%2Fmedia%2Fbbb_short_1080p.avi%20video-sink%3D%22mfw_v4lsink%20device%3D%2Fdev%2Fvideo19%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%20u-boot%20%E3%81%AE%E5%80%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAndy%20%E6%9B%BE%E7%9F%B3%E5%A0%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKancotec%20%E6%B7%B1%E5%9C%B3%E5%BA%B7%E6%8E%A7%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAddress%20%3A%20%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%AE%9D%E5%AE%89%E5%8C%BA%E9%BE%99%E5%8D%8E%E8%A1%97%E9%81%93%E5%BB%BA%E8%BE%89%E8%B7%AF121%E5%8F%B7%E4%BF%A1%E4%BC%9F%E5%A4%A7%E5%8E%A611%E6%A5%BC1112-1115%E6%88%BF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%A01112-1115%E3%80%81Xin%20Wei%20Building%E3%80%81Jianhui%20No.121%E3%80%81Longhua%20Town%E3%80%81Baoan%20District%E3%80%81Shenzhen%20City%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%3A%2B8618681522956%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20%20%2B8615989242961%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9B%BB%E8%A9%B1%20%3A%20%2B86-755-26653899%20%E5%86%85%E7%B7%9A%20821%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%83%E3%82%AF%E3%82%B9%20%3A%20%2B86-755-26653866%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQ%20Q%20%20%3A%202270806966%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eskype%EF%BC%9Aandy.kancotec%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEmail%20%20%3A%20%20%3CANDY%3E%20andy%40kancotec.com%3C%2FANDY%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ehttp%3A%2F%2F%20%20%26lt%3B%26gt%3B%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.kancotec.com%22%20target%3D%22test_blank%22%3Ewww.kancotec.com%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E4%BB%B6%E4%BA%BA%3A%20Gao%20Jianzhong%20%20%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%E6%97%B6%E9%97%B4%3A%202013%E5%B9%B48%E6%9C%8814%E6%97%A5%2012%3A11%3C%2FP%3E%3CP%3E%E6%94%B6%E4%BB%B6%E4%BA%BA%3A%20imx6%20zeng%3C%2FP%3E%3CP%3E%E4%B8%BB%E9%A2%98%3A%20Re%3A%20%20-%20GStreamer%20i.MX6%20Multi-Display%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%26lt%3B%26gt%3B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGStreamer%20i.MX6%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGao%20%26lt%3B%26gt%3B%E3%81%95%E3%82%93%E3%81%AB%E3%82%88%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88Jianzhong%E3%83%93%E3%83%A5%E3%83%BC%20%26lt%3B%26gt%3B%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%B8%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82qmx6%204%E3%82%B3%E3%82%A2%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P1180142.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P1180142.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40418iFACFEDA04F536923%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22P1180142.JPG.jpg%22%20alt%3D%22P1180142.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EP1180142.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E3%83%93%E3%83%87%E3%82%AA%E3%82%922%E3%81%A4%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%90%8C%E6%99%82%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Egst-launch%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%81%86%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%E9%81%A9%E5%88%87%E3%81%AAu-boot%E5%80%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E3%83%9E%E3%83%AB%E3%83%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%20%2B%20LCD%E3%81%AFOK%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-28-2012 01:11 PM
更新者:
