Dual ethernet on Android 14 i.MX8 MP
Overview
The purpose of this document is to provide a guide on how to enable Dual Ethernet with the GKI Development. Reference: How to enable dual ethernet on Android 11
For a better reference how to build Android i.MX image please look at the next chapter 3 Building the Android Platform for i.MX in the Android User's Guide
1. Build the Android Image with the next modifications
  • The 2nd ethernet port is DWMAC from synopsys and phy used is realtek RTL8211F. To add them into the SharedBoardConfig.mk and remove the camera drivers.
    diff --git a/imx8m/evk_8mp/SharedBoardConfig.mk b/imx8m/evk_8mp/SharedBoardConfig.mk
    index f68eb49e..3e95708e 100644
    --- a/imx8m/evk_8mp/SharedBoardConfig.mk
    +++ b/imx8m/evk_8mp/SharedBoardConfig.mk
    @@ -82,7 +82,12 @@ BOARD_VENDOR_KERNEL_MODULES += \
         $(KERNEL_OUT)/drivers/rtc/rtc-snvs.ko \
         $(KERNEL_OUT)/drivers/pci/controller/dwc/pci-imx6.ko \
         $(KERNEL_OUT)/drivers/net/phy/realtek.ko \
    -    $(KERNEL_OUT)/drivers/net/ethernet/freescale/fec.ko
    +    $(KERNEL_OUT)/drivers/net/ethernet/freescale/fec.ko \
    +    $(KERNEL_OUT)/drivers/net/phy/micrel.ko \
    +    $(KERNEL_OUT)/drivers/net/pcs/pcs_xpcs.ko \
    +    $(KERNEL_OUT)/drivers/net/ethernet/stmicro/stmmac/dwmac-imx.ko \
    +    $(KERNEL_OUT)/drivers/net/ethernet/stmicro/stmmac/stmmac.ko \
    +    $(KERNEL_OUT)/drivers/net/ethernet/stmicro/stmmac/stmmac-platform.ko
     ifeq ($(POWERSAVE),true)
         $(KERNEL_OUT)/drivers/soc/imx/lpa_ctrl.ko \
    @@ -219,15 +224,12 @@ BOARD_VENDOR_RAMDISK_KERNEL_MODULES +=     \
         $(KERNEL_OUT)/drivers/perf/fsl_imx8_ddr_perf.ko \
         $(KERNEL_OUT)/drivers/cpufreq/cpufreq-dt.ko \
         $(KERNEL_OUT)/drivers/cpufreq/imx-cpufreq-dt.ko \
    -    $(KERNEL_OUT)/drivers/media/i2c/ov5640.ko \
         $(KERNEL_OUT)/drivers/staging/media/imx/imx8-capture.ko \
         $(KERNEL_OUT)/drivers/staging/media/imx/imx8-isi-capture.ko \
         $(KERNEL_OUT)/drivers/staging/media/imx/imx8-isi-hw.ko \
         $(KERNEL_OUT)/drivers/staging/media/imx/imx8-isi-mem2mem.ko \
         $(KERNEL_OUT)/drivers/staging/media/imx/imx8-mipi-csi2-sam.ko \
         $(KERNEL_OUT)/drivers/dma/imx-sdma.ko \
    -    $(TARGET_OUT_INTERMEDIATES)/VVCAM_OBJ/basler-camera-driver-vvcam.ko \
    -    $(TARGET_OUT_INTERMEDIATES)/VVCAM_OBJ/os08a20.ko \
         $(KERNEL_OUT)/drivers/staging/media/imx/imx8-media-dev.ko \
         $(TARGET_OUT_INTERMEDIATES)/VVCAM_OBJ/vvcam-dwe.ko \
         $(TARGET_OUT_INTERMEDIATES)/VVCAM_OBJ/vvcam-isp.ko \​
  • To let the Android framework's EthernetTracker and EthernetNetworkFactory know which interfaces to manage, the framework level configure
    • config_ethernet_iface_regex
    • config_ethernet_interfaces
    must be overlay in device/nxp/imx8m/evk_8mp/overlay/frameworks/base/core/res/res/values/config.xml:
    diff --git a/imx8m/evk_8mp/overlay/frameworks/base/core/res/res/values/config.xml b/imx8m/evk_8mp/overlay/frameworks/base/core/res/res/values/config.xml
    index 298d50cc..63f6787e 100644
    --- a/imx8m/evk_8mp/overlay/frameworks/base/core/res/res/values/config.xml
    +++ b/imx8m/evk_8mp/overlay/frameworks/base/core/res/res/values/config.xml
    @@ -22,7 +22,12 @@
     <resources>
         <!--For Android we support eth0 now -->
    -    <string translatable="false" name="config_ethernet_iface_regex">eth0</string>
    +    <string translatable="false" name="config_ethernet_iface_regex">eth\\d</string>
    +    <string-array translatable="false" name="config_ethernet_interfaces">
    +        <item>eth0;12,13,14,15,16,18,19</item>
    +        <item>eth1;12,13,14,15,16,18,19</item>
    +    </string-array>
         <!-- List of regexpressions describing the interface (if any) that represent tetherable
              USB interfaces.  If the device doesn't want to support tething over USB this should
  • Apply the patch 0001-PATCH-Add-defines-for-ETH-support-drivers.patch
  • Build the Android Image
    # Change to the MY_ANDROID Directory
    $ source build/envsetup.sh
    $ lunch evk_8mp-userdebug
    $ ./imx-make.sh -j4 2>&1 | tee build-log.txt​
GKI Development
Follow and apply the next community post: Export new symbols of GKI development Android 14
Set the GKI repo
  1. $ repo init -u https://android.googlesource.com/kernel/manifest -b common-android14-6.1
    $ repo sync
    $ git remote add device https://github.com/nxp-imx/linux-imx.git
    $ git remote update
    $ git fetch device --tags
    $ git checkout android-14.0.0_1.2.0
    $ cd ..
    #Be sure that symbolic links are created correctly
    $ ln -s ${MY_ANDROID}/vendor/nxp-opensource/verisilicon_sw_isp_vvcam verisilicon_sw_isp_vvcam
    $ ln -s ${MY_ANDROID}/vendor/nxp-opensource/nxp-mwifiex nxp-mwifiex
    $ BUILD_FOR_GKI=yes
    $ BUILD_CONFIG=common/build.config.imx
    $ tools/bazel run //common:imx_abi_update_symbol_list
  2. Apply the following changes in the GKI Kernel tree: gki/common: Patch: 0001-PATCH-GKI-Kernel-tree-Drivers-for-the-ETH1-Interface.patch
  3. Build the GKI Image
    tools/bazel run //common:kernel_aarch64_dist​
  4. Follow the build android boot.img and system_dlkm.img
    $ cp out/kernel_aarch64/dist/boot.img ${MY_ANDROID}/vendor/nxp/fsl-proprietary/
    gki/boot.img
    $ cd ${MY_ANDROID}
    $ TARGET_IMX_KERNEL=true make bootimage
    # Change directory to the gki folder
    $ cp out/kernel_aarch64/dist/system_dlkm_staging_archive.tar.gz ${MY_ANDROID}/vendor/nxp/fsl-proprietary/gki/system_dlkm_staging_archive.tar.gz
    $ cd ${MY_ANDROID}/vendor/nxp/fsl-proprietary/gki
    $ tar -xzf system_dlkm_staging_archive.tar.gz -C system_dlkm_staging
    $ cd ${MY_ANDROID}
    $ make system_dlkmimag​e
  5. Create the tar.gz file for flash the android image (*.img, *.bat, *.sh, *.bin, *.imx)
  6. Boot the image and type lsmod to ensure the drivers are installed.mario_castaneda_0-1719280397418.pngmario_castaneda_0-1719280397418.png
Mario
添付
コメント
Can you please give information on why do we need to disable camera drivers to enable ethernet?
Regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-1893152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%20MP%E4%B8%8A%E3%81%AEAndroid%2014%E3%81%A7%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1893152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--1380440254%22%20id%3D%22toc-hId--1207660147%22%20id%3D%22toc-hId--493718925%22%3E%3CFONT%20size%3D%224%22%3EOverview%3C%2FFONT%3E%3C%2FH2%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%96%87%E6%9B%B8%E3%81%A7%E3%81%AF%E3%80%81GKI%E9%96%8B%E7%99%BA%E3%81%A7%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FiMX-and-Vybrid-Support%2FHow-to-enable-dual-ethernet-on-Android-11%2Fta-p%2F1280957%22%20target%3D%22_self%22%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3EAndroid%2011%E3%81%A7%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EAndroid%20i.MX%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A7%8B%E7%AF%89%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FANDROID_USERS_GUIDE.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAndroid%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%E3%80%8F%E3%83%81%E3%83%A3%E3%83%97%E3%82%BF%E3%83%BC3%E3%80%8Ci.MX%E7%94%A8Android%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E6%A7%8B%E7%AF%89%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1232149816%22%20id%3D%22toc-hId--517098673%22%20id%3D%22toc-hId-196842549%22%3E1.%20%E6%AC%A1%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6Android%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3E2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AFSynopsys%E3%81%AEDWMAC%E3%80%81PHY%E3%81%AFRealtek%E3%81%AERTL8211F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%82%92SharedBoardConfig.mk%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Fimx8m%2Fevk_8mp%2FSharedBoardConfig.mk%20b%2Fimx8m%2Fevk_8mp%2FSharedBoardConfig.mk%0Aindex%20f68eb49e..3e95708e%20100644%0A---%20a%2Fimx8m%2Fevk_8mp%2FSharedBoardConfig.mk%0A%2B%2B%2B%20b%2Fimx8m%2Fevk_8mp%2FSharedBoardConfig.mk%0A%40%40%20-82%2C7%20%2B82%2C12%20%40%40%20BOARD_VENDOR_KERNEL_MODULES%20%2B%3D%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Frtc%2Frtc-snvs.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fpci%2Fcontroller%2Fdwc%2Fpci-imx6.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fphy%2Frealtek.ko%20%5C%0A-%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fethernet%2Ffreescale%2Ffec.ko%0A%2B%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fethernet%2Ffreescale%2Ffec.ko%20%5C%0A%2B%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fphy%2Fmicrel.ko%20%5C%0A%2B%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fpcs%2Fpcs_xpcs.ko%20%5C%0A%2B%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fethernet%2Fstmicro%2Fstmmac%2Fdwmac-imx.ko%20%5C%0A%2B%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fethernet%2Fstmicro%2Fstmmac%2Fstmmac.ko%20%5C%0A%2B%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fnet%2Fethernet%2Fstmicro%2Fstmmac%2Fstmmac-platform.ko%0A%20ifeq%20(%24(POWERSAVE)%2Ctrue)%0A%20BOARD_VENDOR_KERNEL_MODULES%20%2B%3D%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fsoc%2Fimx%2Flpa_ctrl.ko%20%5C%0A%40%40%20-219%2C15%20%2B224%2C12%20%40%40%20BOARD_VENDOR_RAMDISK_KERNEL_MODULES%20%2B%3D%20%20%20%20%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fperf%2Ffsl_imx8_ddr_perf.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fcpufreq%2Fcpufreq-dt.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fcpufreq%2Fimx-cpufreq-dt.ko%20%5C%0A-%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fmedia%2Fi2c%2Fov5640.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-capture.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-isi-capture.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-isi-hw.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-isi-mem2mem.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2-sam.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fdma%2Fimx-sdma.ko%20%5C%0A-%20%20%20%20%24(TARGET_OUT_INTERMEDIATES)%2FVVCAM_OBJ%2Fbasler-camera-driver-vvcam.ko%20%5C%0A-%20%20%20%20%24(TARGET_OUT_INTERMEDIATES)%2FVVCAM_OBJ%2Fos08a20.ko%20%5C%0A%20%20%20%20%20%24(KERNEL_OUT)%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-media-dev.ko%20%5C%0A%20%20%20%20%20%24(TARGET_OUT_INTERMEDIATES)%2FVVCAM_OBJ%2Fvvcam-dwe.ko%20%5C%0A%20%20%20%20%20%24(TARGET_OUT_INTERMEDIATES)%2FVVCAM_OBJ%2Fvvcam-isp.ko%20%5C%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E7%AE%A1%E7%90%86%E3%81%AE%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%AA%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92Android%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AEEthernetTracker%E3%81%A8EthernetNetworkFactory%E3%81%AB%E4%BC%9D%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%BB%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Econfig_ethernet_iface_regex%3C%2FLI%3E%0A%3CLI%3Econfig_ethernet_interfaces%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Edevice%2Fnxp%2Fimx8m%2Fevk_8mp%2Foverlay%2Fframeworks%2Fbase%2Fcore%2Fres%2Fres%2Fvalues%2Fconfig.xml%20%E3%81%AB%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Fimx8m%2Fevk_8mp%2Foverlay%2Fframeworks%2Fbase%2Fcore%2Fres%2Fres%2Fvalues%2Fconfig.xml%20b%2Fimx8m%2Fevk_8mp%2Foverlay%2Fframeworks%2Fbase%2Fcore%2Fres%2Fres%2Fvalues%2Fconfig.xml%0Aindex%20298d50cc..63f6787e%20100644%0A---%20a%2Fimx8m%2Fevk_8mp%2Foverlay%2Fframeworks%2Fbase%2Fcore%2Fres%2Fres%2Fvalues%2Fconfig.xml%0A%2B%2B%2B%20b%2Fimx8m%2Fevk_8mp%2Foverlay%2Fframeworks%2Fbase%2Fcore%2Fres%2Fres%2Fvalues%2Fconfig.xml%0A%40%40%20-22%2C7%20%2B22%2C12%20%40%40%0A%20%3CRESOURCES%3E%0A%20%0A%20%20%20%20%20%3C!--For%20Android%20we%20support%20eth0%20now%20--%3E%0A-%20%20%20%20%3CSTRING%20translatable%3D%22false%22%20name%3D%22config_ethernet_iface_regex%22%3Eeth0%3C%2FSTRING%3E%0A%2B%20%20%20%20%3CSTRING%20translatable%3D%22false%22%20name%3D%22config_ethernet_iface_regex%22%3Eeth%5C%5Cd%3C%2FSTRING%3E%0A%2B%0A%2B%20%20%20%20%3CSTRING-ARRAY%20translatable%3D%22false%22%20name%3D%22config_ethernet_interfaces%22%3E%0A%2B%20%20%20%20%20%20%20%20%3CITEM%3Eeth0%3B12%2C13%2C14%2C15%2C16%2C18%2C19%3C%2FITEM%3E%0A%2B%20%20%20%20%20%20%20%20%3CITEM%3Eeth1%3B12%2C13%2C14%2C15%2C16%2C18%2C19%3C%2FITEM%3E%0A%2B%20%20%20%20%3C%2FSTRING-ARRAY%3E%0A%20%0A%20%20%20%20%20%3C!--%20List%20of%20regexpressions%20describing%20the%20interface%20(if%20any)%20that%20represent%20tetherable%0A%20%20%20%20%20%20%20%20%20%20USB%20interfaces.%20%20If%20the%20device%20doesn't%20want%20to%20support%20tething%20over%20USB%20this%20should%0A--%20%3C%2Fcode--%3E%3C%2FRESOURCES%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%E3%83%91%E3%83%83%E3%83%81%20%3CSTRONG%3E%3CEM%3E0001-PATCH-Add-defines-for-ETH-support-drivers.patch%3C%2FEM%3E%3C%2FSTRONG%3E%20%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%0A%3CLI%3EAndroid%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3E%23%20Change%20to%20the%20MY_ANDROID%20Directory%0A%24%20source%20build%2Fenvsetup.sh%0A%24%20lunch%20evk_8mp-userdebug%0A%24%20.%2Fimx-make.sh%20-j4%202%26gt%3B%26amp%3B1%20%7C%20tee%20build-log.txt%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3EGKI%20%E9%96%8B%E7%99%BA%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E8%A8%98%E4%BA%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FExport-new-symbols-of-GKI-development-Android-14%2Fta-p%2F1867360%22%20target%3D%22_self%22%3EGKI%E9%96%8B%E7%99%BA%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%20-%20Android%2014%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EGKI%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20repo%20init%20-u%20https%3A%2F%2Fandroid.googlesource.com%2Fkernel%2Fmanifest%20-b%20common-android14-6.1%0A%24%20repo%20sync%0A%24%20git%20remote%20add%20device%20https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx.git%0A%24%20git%20remote%20update%0A%24%20git%20fetch%20device%20--tags%0A%24%20git%20checkout%20android-14.0.0_1.2.0%0A%24%20cd%20..%0A%23Be%20sure%20that%20symbolic%20links%20are%20created%20correctly%0A%24%20ln%20-s%20%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp-opensource%2Fverisilicon_sw_isp_vvcam%20verisilicon_sw_isp_vvcam%0A%24%20ln%20-s%20%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp-opensource%2Fnxp-mwifiex%20nxp-mwifiex%0A%24%20BUILD_FOR_GKI%3Dyes%0A%24%20BUILD_CONFIG%3Dcommon%2Fbuild.config.imx%0A%24%20tools%2Fbazel%20run%20%2F%2Fcommon%3Aimx_abi_update_symbol_list%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3EGKI%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E6%AC%A1%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20gki%2Fcommon%3A%20%E3%83%91%E3%83%83%E3%83%81%3A%200001-PATCH-GKI-Kernel-tree-Drivers-for-the-ETH1-Interface.patch%3C%2FLI%3E%0A%3CLI%3EGKI%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3Etools%2Fbazel%20run%20%2F%2Fcommon%3Akernel_aarch64_dist%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%BE%8C%E3%81%A7%E3%80%81Android%E3%81%AEboot.img%E3%81%A8system_dlkm.img%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20cp%20out%2Fkernel_aarch64%2Fdist%2Fboot.img%20%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp%2Ffsl-proprietary%2F%0Agki%2Fboot.img%0A%24%20cd%20%24%7BMY_ANDROID%7D%0A%24%20TARGET_IMX_KERNEL%3Dtrue%20make%20bootimage%0A%23%20Change%20directory%20to%20the%20gki%20folder%0A%24%20cp%20out%2Fkernel_aarch64%2Fdist%2Fsystem_dlkm_staging_archive.tar.gz%20%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp%2Ffsl-proprietary%2Fgki%2Fsystem_dlkm_staging_archive.tar.gz%0A%24%20cd%20%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp%2Ffsl-proprietary%2Fgki%0A%24%20tar%20-xzf%20system_dlkm_staging_archive.tar.gz%20-C%20system_dlkm_staging%0A%24%20cd%20%24%7BMY_ANDROID%7D%0A%24%20make%20system_dlkmimag%E2%80%8Be%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLI%3E%0A%3CLI%3EAndroid%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20tar.gz%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88*.img%E3%80%81*.bat%E3%80%81*.sh%E3%80%81*.bin%E3%80%81*.imx%EF%BC%89%3C%2FLI%3E%0A%3CLI%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%80%8Clsmod%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mario_castaneda_0-1719280397418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mario_castaneda_0-1719280397418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F285539iBBD1B3BB8933CB04%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mario_castaneda_0-1719280397418.png%22%20alt%3D%22mario_castaneda_0-1719280397418.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emario_castaneda_0-1719280397418.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EMario%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1893152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20MP%E4%B8%8A%E3%81%AEAndroid%2014%E3%81%A7%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%BB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E7%90%86%E7%94%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E6%95%99%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎06-24-2024 10:15 PM
更新者:
