De-interlace Capture Device
In some cases it is desired to directly have progressive content available from a TV-IN interface through the V4L2 capture device. In the BSP, HW accelerated de-interlacing is only supported in the V4L2 output stream. Below is a patch created against a rather old BSP version that adds support for de-interlaced V4L2 capture. The patch might need to be adapted to newer BSPs, However, the logic and functionality is there and should shorten the development time.
This patch adds another input device to the V4L2 framework that can be selected to perform the deinterlacing on the way to memory. The selection is done by passing the index “2” as an argument to the VIDIOC_S_INPUT  V4L2 ioctl. Attached is also a modified the tvin unit test to give an example of how to use the new driver. An example sequence for running the test is as follows:
modprobe mxc_v4l2_capture
./mxc_v4l2_tvin_vdi.out -ow 720 -oh 480 -ol 10 -ot 20 -f YU12
Some key things to note:
This driver does not support resize or color space conversion on the way to memory.
The requested format and size should match what can be provided directly by the sensor.
The driver was tested on a Sabre AI Rev A board running Linux 12.02.
This code is not an official delivery and as such no guarantee of support for this code is provided by Freescale.
标签 (3)
附件
评论
I am working on ipu, my target is capture the data from adv7180 and resize it, then put it into vpu and encoder to jpeg picture.
I use your patch to solve the problem de-interlace.
Now i want to resize the data captured from (720x480) to (640x480), I think the MEM_VDI_PRP_VF_MEM support the resize.
Can you give me some ideas about what to modify in your patch file.
Thank you.
I think the main thing you need to do is to set the enc.mem_prp_vf_mem.out_width and enc.mem_prp_vf_mem.out_height variables appropriately.  Currently, these are fixed in vdi_enc_setup() to be the same dimensions as for the input:
enc.mem_prp_vf_mem.out_width = cam->v2f.fmt.pix.width;
enc.mem_prp_vf_mem.out_height = cam->v2f.fmt.pix.height;
You should be able to change this to use a value passed by the application and the resize should be performed for you.
Philip_FSL,
Thank you very much.Now i can resize the capture memory.
And in your file:ipu_vdi_enc.c , it use queue_work() in callback of IPU_IRQ_CSI0_OUT_EOF interrupt.
is it ok to direct call vdi_work_func() here?
This should probably be OK.  Although, it is generally best to do as little as possible in the context of the interrupt routine.
Hi, Philip
I have another question now.
Now mxc_v4l2_tvin capture data from adv7180 with H/V sync information ememded in data.
But I want to let it use the external H/V sync signal from adv7180.
I want to let adv7180 work as a cmos sensor.
Do you know how to do this?
Thank you.
Hi.  I would recommend that you move this discussion to the discussions area as we are now going beyond the scope of the initial post.
Hi Gao,
Can you please start a new discussion on ADV 7180 question to help keep discussions limited to single topics?
Thank you,
I got the patch working on our i.MX53 based board. Recording de-interlaced video with Gstreamer works but one thing is missing: the preview.
Starting a pipe with enabled preview does not work:
gst-launch -v mfw_v4lsrc capture-mode=2 preview=true ! fakesink
I can see no preview on the display and no data arrives at the fakesink. After a few seconds gst-launch aborts with the error message:
ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
So what would I have to do, to add preview support to the de-interlacing task chain?
I assume the goal is to encode and preview in parallel.
In that case, there are probably two options available.
1) tee the stream from the v4lsrc and route one stream to v4lsink and the other to the decoder
2) Merge the preview driver with the deinterlace driver that this patch creates to make a preview + deinterlace driver and then modify the v4l capture driver to route the stream to both the preview and the decoder.
The second options is likely to be more complicated and introduce synchronization related issues that are not easy to address within the V4L framework.  So, I would recommend taking the first route if possible.
fcs
We found the VDI deinterlacing algorithms weren't good for video with small-font text in the video as it tends to blur or remove whole lines. Instead using deinterlacing in the CSI -> MEM channel works well for our needs (see ILO and Stride settings in CPMEM) however this requires substantial changes to the drivers.
BSP: L3.0.35_4.0.0
CVBS PAL/NTSC video is input to Video decoder ADV7180, and ADV7180 connect to I.MX6Q CSI BT656.
The de-interlace is set, but the quality is not good. Please check the picture attached.
I have patch the file into kernel follow the instruction in I.MX6Q + ADV7180.
https://community.freescale.com/docs/DOC-93633
It seem that some thread has occupancy the ipu task 1.
This patch I have used in imx53 platform before, It can run normally.
But when I run the mxc_v4l2_tvin, I got the error as bellow:
root@freescale ~$ ./mxc_v4l2_tvin -ow 720 -oh 480
FIXME-------ioctl_g_fmt_cap
NOW IS PALTV decoder chip is adv7180_decodeFIXME-------ioctl_g_fmt_cap
r
NOW IS PALNOW IS PAL
In mxc_v4l2_s_std ff
rawdata0: 0x00, rawdata1: 0x00
NOW IS PALVIDIOC_G_FMT failed
driver=mxc_vout, card=DISP3 FG, bus=, version=0x00000000, capabilities=0x04000002
fmt RGB565: fourcc = 0x50424752
fmt BGR24: fourcc = 0x33524742
fmt RGB24: fourcc = 0x33424752
fmt RGB32: fourcc = 0x34424752
fmt BGR32: fourcc = 0x34524742
fmt NV12: fourcc = 0x3231564e
fmt UYVY: fourcc = 0x59565955
fmt YUYV: fourcc = 0x56595559
fmt YUV422 planar: fourcc = 0x50323234
fmt YUV444: fourcc = 0x34343459
fmt YUV420: fourcc = 0x32315559
fmt YVU420: fourcc = 0x32315659
fmt TILED NV12P: fourcc = 0x50564e54
fmt TILED NV12F: fourcc = 0x46564e54
fmt YUV444 planar: fourcc = 0x50343434
UYVY
imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_10 = 0x00000001
imx-ipuv3 imx-ipuv3.0: IDMAC21's EBA0 is not 8-byte aligned
imx-ipuv3 imx-ipuv3.0: IDMAC21's EBA1 is not 8-byte aligned
start time = 473 s, 145035 usFIXME-------ioctl_g_fmt_cap
mc_pfuze 1-0008: recv failed!:-5,bf
COULD NOT SET GP VOLTAGE!!!!
imx-ipuv3 imx-ipuv3.0: ERR[0xbfcd7200-no:0x220]ipu task_id:1 busy!
imx-ipuv3 imx-ipuv3.0: ERR:[0xbfcd7200] no-0x220 state: ipu busy
imx-ipuv3 imx-ipuv3.0: ERR: [0xbfcd7200] no-0x220,state 8: ipu busy
imx-ipuv3 imx-ipuv3.0: ERR: no-0x220,ipu_queue_task err:-125
mxc_v4l2_output mxc_v4l2_output.0: display work fail ret = -125
imx-ipuv3 imx-ipuv3.0: ERR[0xbfcd7400-no:0x230]ipu task_id:1 busy!
imx-ipuv3 imx-ipuv3.0: ERR:[0xbfcd7400] no-0x230 state: ipu busy
imx-ipuv3 imx-ipuv3.0: ERR: [0xbfcd7400] no-0x230,state 8: ipu busy
imx-ipuv3 imx-ipuv3.0: ERR: no-0x230,ipu_queue_task err:-125
imx-ipuv3 imx-ipuv3.0: ERR[0xba25e600-no:0x240]ipu task_id:1 busy!
imx-ipuv3 imx-ipuv3.0: ERR:[0xba25e600] no-0x240 state: ipu busy
imx-ipuv3 imx-ipuv3.0: ERR: [0xba25e600] no-0x240,state 8: ipu busy
imx-ipuv3 imx-ipuv3.0: ERR: no-0x240,ipu_queue_task err:-125
VIDIOC_QBUF failed
imx-ipuv3 imx-ipuv3.0: handler already installed on irq 0
imx-ipuv3 imx-ipuv3.0: CSI irq 0 in use
Hi Philip_FSL
Does the above add-csi-deinterlace-capture.patch.zip patch will support De-interlaced PAL format?
I have added the patch in our BSP and NTSC is working fine with De-interlaced format. But when I tried with PAL, I'm getting captured image with a little top portion missing out. Though I can able to control the scrolling and even the image also coming as proper w.r.t color, I still not able to make the top portion of the captured image into proper. The bottom and sides of the same captured image is proper.
Please provide solution on how to resolve this issue.
Thanks in advance,
Ajith
Hi all
     I am do a work about capturing video on imx6. I have use your patch about de-interlace,now I have serverl problem. MEM_VDI_PRP_VF_MEM,MEM_VDI_PRP_VF_MEM_P,MEM_VDI_PRP_VF_MEM_N
channels is fed to VDIC?I understand the path is CSI->MEM,then the video data fed from MEM->VDIC->IC->MEM. There are three fields data, f(n-1),f(n),f(n+1).They respectively flow the three channels on above. What do you think of my understanding right?Now my video data quality is not very good,Is it the deinterlaceing problem?
    camera senser is tvp5151,data format is bt656(YCbCr4:2:2  interlaced),dispaly is 7inch lcd 24bits
     think you!
Hi all,
The above patch is now more than one year old, and "is not an official delivery and as such no guarantee of support for this code is provided by Freescale". Is there an "official delivery" of video deinterlacer code for i.MX6 ?
We have tested the patch with PAL camera input and are not fully satisfied by the result (as exposed by i.MX6 PAL deinterlacer artifact)
Moreover, if the patch running in a gstreamer pipeline for each of the 2 CSI seems stable without any other traffic, it doesn't comply with additional traffic (Ethernet 80Mb/s incoming + 50Mb/s outgoing + SATA 100Mb/s outgoing) : it usually runs less than one hour before ending up in DMA channel busy that can't be freed, for which the process can't be killed and only a reset can make it recover ! The root cause is usually because an overflow is detected on VDI, such as :
imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_5 = 0x00000500
imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_9 = 0x00000001
... or:
imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_5 = 0x00000400
imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_5 = 0x00000400
Last point, we have tested the software deinterlacer of gstreamer (deinterlace plugin) with a pipeline such as:
gst-launch -v --gst-debug=2 -e mfw_v4lsrc device=/dev/video0 fps-n=25 ! deinterlace ! vpuenc codec=avc framerate-nu=25 bitrate=4194304 ! rtph264pay ! udpsink sync=false -v host=10.100.57.5 port=5000
It doesn't work, even when specifying other kind of method parameter (tomsmocomp / greedyh / greedyl / linear / scalerbob) for the deinterlace plugin.
As a result, we still have no acceptable deinterlacing solution for our i.MX6 platform and are quite disappointed.
Thanks in advance.
Hi all,
You’ll find below a fix for the VDI code that solved our problem using PAL video input. In fact, the problem isn’t specific to PAL as the VDI fields were not correctly referenced, which explains the artifacts…
Could anyone (at Freescale or other forum members) review this code, test it in their configuration and share the results on the forum?
Our feeling is that this fix makes now the VDI usable but performance is still the main issue: IDMA can’t recover from a video frame overflow, and the occurrence probability becomes high when you cumulate different I/O traffic (Ethernet and SATA in our case). In our case, we usually have a crash using i.MX6Q in less than 1 hour in the following configuration:
  • 2 PAL video inputs – with VDI – active simultaneously,
  • 50 Mb/s outgoing Ethernet traffic,
  • 80 Mb/s incoming traffic,
  • 100 Mb/s outgoing SATA traffic.
And then, the average CPU load is around 25%.
Moreover, we have updated the “tvin” application adding 3 new options:
1.       -vi <capture_num> to allow specifying your capture device (/dev/video0 by default)
2.       -vo <output_num> to allow specifying your output device (/dev/video16 by default)
3.       -dv to disable VDI (always activated otherwise)
Example:
mxc_v4l2_tvin -ow 720 -oh 576 -vi 0 -vo 16 -m 0
mxc_v4l2_tvin -ow 720 -oh 576 -vi 1 -vo 17 -dv
Fix for the VDI code
--- a/drivers/media/video/mxc/capture/ipu_vdi_enc.c
+++ b/drivers/media/video/mxc/capture/ipu_vdi_enc.c
@@ -31,6 +31,9 @@
        #define CAMERA_TRACE(x)
#endif
+#define PREVIOUS_INDEX ((cam->ping_pong_vdi + 2) %3)
+#define CURRENT_INDEX  ( cam->ping_pong_vdi        )
+#define NEXT_INDEX     ((cam->ping_pong_vdi + 1) %3)
  * Function definitions
@@ -47,8 +50,7 @@ static void vdi_work_func(struct work_struct *work)
         err = ipu_update_channel_buffer(cam->ipu, MEM_VDI_PRP_VF_MEM_P,
                 IPU_INPUT_BUFFER, 0,
-                cam->vdi_enc_bufs[(cam->ping_pong_vdi + 2) %3] +
-                cam->v2f.fmt.pix.bytesperline);
+                cam->vdi_enc_bufs[PREVIOUS_INDEX]);
         if (err != 0) {
             ipu_clear_buffer_ready(cam->ipu, MEM_VDI_PRP_VF_MEM_P,
@@ -57,8 +59,7 @@ static void vdi_work_func(struct work_struct *work)
                     IPU_INPUT_BUFFER,
                     0,
             if (err != 0) {
                 pr_err("ERROR: v4l2 capture: fail to update vdi P buffer");
@@ -68,7 +69,7 @@ static void vdi_work_func(struct work_struct *work)
         err = ipu_update_channel_buffer(cam->ipu, MEM_VDI_PRP_VF_MEM,
-                cam->vdi_enc_bufs[cam->ping_pong_vdi]);
+                cam->vdi_enc_bufs[CURRENT_INDEX]);
         if (err != 0) {
             ipu_clear_buffer_ready(cam->ipu, MEM_VDI_PRP_VF_MEM,
@@ -77,7 +78,7 @@ static void vdi_work_func(struct work_struct *work)
                     IPU_INPUT_BUFFER,
                     0,
             if (err != 0) {
                 pr_err("ERROR: v4l2 capture: fail to update vdi buffer");
@@ -87,8 +88,7 @@ static void vdi_work_func(struct work_struct *work)
         err = ipu_update_channel_buffer(cam->ipu, MEM_VDI_PRP_VF_MEM_N,
-                cam->vdi_enc_bufs[cam->ping_pong_vdi]+
+                cam->vdi_enc_bufs[NEXT_INDEX]);
         if (err != 0) {
             ipu_clear_buffer_ready(cam->ipu, MEM_VDI_PRP_VF_MEM_N,
@@ -97,8 +97,7 @@ static void vdi_work_func(struct work_struct *work)
                     IPU_INPUT_BUFFER,
                     0,
-                    cam->vdi_enc_bufs[cam->ping_pong_vdi] +
             if (err != 0) {
                 pr_err("ERROR: v4l2 capture: fail to update vdi N buffer");
@@ -109,11 +108,11 @@ static void vdi_work_func(struct work_struct *work)
     cam->vdi_enc_first_frame = 0;
-    cam->ping_pong_vdi = (cam->ping_pong_vdi + 1)%3;
+    cam->ping_pong_vdi = NEXT_INDEX;
     //Point the CSI output to the next buffer
     err = ipu_update_channel_buffer(cam->ipu, CSI_MEM,
             IPU_OUTPUT_BUFFER, 0,
     if (err != 0) {
         ipu_clear_buffer_ready(cam->ipu, CSI_MEM,
@@ -121,7 +120,7 @@ static void vdi_work_func(struct work_struct *work)
                 0);
         if (err != 0) {
             pr_err("ERROR: v4l2 capture: fail to update CSI buffer");
@@ -275,7 +274,7 @@ static int vdi_enc_setup(cam_data *cam)
                 cam->v2f.fmt.pix.bytesperline /
                 bytes_per_pixel(enc.mem_prp_vf_mem.
                     out_pixel_fmt), IPU_ROTATE_NONE,
-                cam->vdi_enc_bufs[cam->ping_pong_vdi], 0, 0,
+                cam->vdi_enc_bufs[CURRENT_INDEX], 0, 0,
                 cam->offset.u_offset,
                 cam->offset.v_offset);
@@ -306,7 +305,7 @@ static int vdi_enc_setup(cam_data *cam)
                                        out_pixel_fmt),
                                IPU_ROTATE_NONE,
-                                cam->vdi_enc_bufs[(cam->ping_pong_vdi + 1) %3],
+                                cam->vdi_enc_bufs[NEXT_INDEX],
                                 0, 0,
@@ -335,8 +334,7 @@ static int vdi_enc_setup(cam_data *cam)
                                        out_pixel_fmt),
                                IPU_ROTATE_NONE,
-                                cam->v2f.fmt.pix.bytesperline,
                                 0, 0,
@@ -380,8 +378,7 @@ static int vdi_enc_setup(cam_data *cam)
                                        out_pixel_fmt),
                                IPU_ROTATE_NONE,
-                                cam->vdi_enc_bufs[(cam->ping_pong_vdi + 1) %3] +
                                 0, 0,
Updated “tvin” application
* Copyright 2007-2012 Freescale Semiconductor, Inc. All rights reserved.
* The code contained herein is licensed under the GNU General Public
* License. You may obtain a copy of the GNU General Public License
* Version 2 or later at the following locations:
* http://www.opensource.org/licenses/gpl-license.html
* http://www.gnu.org/copyleft/gpl.html
* @file mxc_v4l2_tvin.c
* @brief Mxc TVIN For Linux 2 driver test application
#ifdef __cplusplus
extern "C"{
#endif
                        INCLUDE FILES
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
#include <stdint.h>
#include <sys/types.h>
#include <stdint.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <sys/time.h>
#include <unistd.h>
#include <asm/types.h>
#include <linux/videodev2.h>
#include <sys/mman.h>
#include <math.h>
#include <string.h>
#include <malloc.h>
#include "linux/mxcfb.h"
#include "linux/mxc_v4l2.h"
#define TFAIL -1
#define TPASS 0
char v4l_capture_dev[100] = "/dev/video";
char v4l_output_dev[100] = "/dev/video";
int fd_capture_v4l = 0;
int fd_output_v4l = 0;
int g_cap_mode = 0;
int g_input = 2;
int g_fmt = V4L2_PIX_FMT_UYVY;
int g_rotate = 0;
int g_vflip = 0;
int g_hflip = 0;
int g_vdi_enable = 0;
int g_vdi_motion = 0;
int g_tb = 0;
int g_output = 3;
int g_output_num_buffers = 4;
int g_capture_num_buffers = 3;
int g_in_width = 0;
int g_in_height = 0;
int g_display_width = 0;
int g_display_height = 0;
int g_display_top = 0;
int g_display_left = 0;
int g_frame_size;
int g_frame_period = 33333;
v4l2_std_id g_current_std = V4L2_STD_NTSC;
struct testbuffer
        unsigned char *start;
        size_t offset;
        unsigned int length;
struct testbuffer output_buffers[4];
struct testbuffer capture_buffers[3];
int start_capturing(void)
        unsigned int i;
        struct v4l2_buffer buf;
        enum v4l2_buf_type type;
        for (i = 0; i < g_capture_num_buffers; i++)
                memset(&buf, 0, sizeof (buf));
                buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
                buf.memory = V4L2_MEMORY_MMAP;
                buf.index = i;
                if (ioctl(fd_capture_v4l, VIDIOC_QUERYBUF, &buf) < 0)
                        printf("VIDIOC_QUERYBUF error\n");
                        return TFAIL;
                capture_buffers[i].length = buf.length;
                capture_buffers[i].offset = (size_t) buf.m.offset;
                capture_buffers[i].start = mmap (NULL, capture_buffers[i].length,
                    PROT_READ | PROT_WRITE, MAP_SHARED,
                    fd_capture_v4l, capture_buffers[i].offset);
                memset(capture_buffers[i].start, 0xFF, capture_buffers[i].length);
                buf.index = i;
                buf.m.offset = capture_buffers[i].offset;
                if (ioctl (fd_capture_v4l, VIDIOC_QBUF, &buf) < 0) {
                        printf("VIDIOC_QBUF error\n");
                        return TFAIL;
        if (ioctl (fd_capture_v4l, VIDIOC_STREAMON, &type) < 0) {
                printf("VIDIOC_STREAMON error\n");
                return TFAIL;
        return 0;
int prepare_output(void)
        int i;
        struct v4l2_buffer output_buf;
        for (i = 0; i < g_output_num_buffers; i++)
                memset(&output_buf, 0, sizeof(output_buf));
                output_buf.type = V4L2_BUF_TYPE_VIDEO_OUTPUT;
                output_buf.memory = V4L2_MEMORY_MMAP;
                output_buf.index = i;
                if (ioctl(fd_output_v4l, VIDIOC_QUERYBUF, &output_buf) < 0)
                        return TFAIL;
                output_buffers[i].length = output_buf.length;
                output_buffers[i].offset = (size_t) output_buf.m.offset;
                output_buffers[i].start = mmap (NULL, output_buffers[i].length,
                                                fd_output_v4l, output_buffers[i].offset);
               if (output_buffers[i].start == NULL) {
                        printf("v4l2 tvin test: output mmap failed\n");
                        return TFAIL;
return 0;
int v4l_capture_setup(void)
        struct v4l2_capability cap;
        struct v4l2_cropcap cropcap;
        struct v4l2_crop crop;
        struct v4l2_format fmt;
        struct v4l2_requestbuffers req;
        struct v4l2_dbg_chip_ident chip;
        struct v4l2_streamparm parm;
        v4l2_std_id id;
        unsigned int min;
        if (ioctl (fd_capture_v4l, VIDIOC_QUERYCAP, &cap) < 0) {
                if (EINVAL == errno) {
                        fprintf (stderr, "%s is no V4L2 device\n",
                                        v4l_capture_dev);
                        return TFAIL;
                } else {
                        fprintf (stderr, "%s isn not V4L device,unknow error\n",
                        v4l_capture_dev);
                        return TFAIL;
        if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE)) {
                fprintf (stderr, "%s is no video capture device\n",
                        v4l_capture_dev);
                return TFAIL;
        if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
                fprintf (stderr, "%s does not support streaming i/o\n",
                        v4l_capture_dev);
                return TFAIL;
        if (ioctl(fd_capture_v4l, VIDIOC_DBG_G_CHIP_IDENT, &chip))
                printf("VIDIOC_DBG_G_CHIP_IDENT failed.\n");
                close(fd_capture_v4l);
                return TFAIL;
        printf("TV decoder chip is %s\n", chip.match.name);
        if (ioctl(fd_capture_v4l, VIDIOC_S_INPUT, &g_input) < 0)
                printf("VIDIOC_S_INPUT failed\n");
                return TFAIL;
        if (ioctl(fd_capture_v4l, VIDIOC_G_STD, &id) < 0)
               printf("VIDIOC_G_STD failed\n");
                return TFAIL;
        g_current_std = id;
        if (ioctl(fd_capture_v4l, VIDIOC_S_STD, &id) < 0)
                printf("VIDIOC_S_STD failed\n");
                return TFAIL;
        /* Select video input, video standard and tune here. */
        memset(&cropcap, 0, sizeof(cropcap));
        cropcap.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
        if (ioctl (fd_capture_v4l, VIDIOC_CROPCAP, &cropcap) < 0) {
                crop.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
                crop.c = cropcap.defrect; /* reset to default */
                if (ioctl (fd_capture_v4l, VIDIOC_S_CROP, &crop) < 0) {
                       switch (errno) {
                                case EINVAL:
                                        /* Cropping not supported. */
                                        fprintf (stderr, "%s  doesn't support crop\n",
                                                v4l_capture_dev);
                                        break;
                                default:
                                        /* Errors ignored. */
                                        break;
        } else {
        parm.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
        parm.parm.capture.timeperframe.numerator = 1;
        parm.parm.capture.timeperframe.denominator = 0;
        parm.parm.capture.capturemode = 0;
        if (ioctl(fd_capture_v4l, VIDIOC_S_PARM, &parm) < 0)
                printf("VIDIOC_S_PARM failed\n");
                return TFAIL;
        memset(&fmt, 0, sizeof(fmt));
        fmt.type                = V4L2_BUF_TYPE_VIDEO_CAPTURE;
        fmt.fmt.pix.width       = 0;
        fmt.fmt.pix.height      = 0;
        fmt.fmt.pix.pixelformat = g_fmt;
        fmt.fmt.pix.field       = V4L2_FIELD_INTERLACED;
        if (ioctl (fd_capture_v4l, VIDIOC_S_FMT, &fmt) < 0){
                fprintf (stderr, "%s iformat not supported \n",
                        v4l_capture_dev);
                return TFAIL;
        /* Note VIDIOC_S_FMT may change width and height. */
        /* Buggy driver paranoia. */
        min = fmt.fmt.pix.width * 2;
        if (fmt.fmt.pix.bytesperline < min)
                fmt.fmt.pix.bytesperline = min;
        min = fmt.fmt.pix.bytesperline * fmt.fmt.pix.height;
        if (fmt.fmt.pix.sizeimage < min)
                fmt.fmt.pix.sizeimage = min;
        if (ioctl(fd_capture_v4l, VIDIOC_G_FMT, &fmt) < 0)
                printf("VIDIOC_G_FMT failed\n");
                return TFAIL;
        g_in_width = fmt.fmt.pix.width;
        g_in_height = fmt.fmt.pix.height;
        memset(&req, 0, sizeof (req));
        req.count               = g_capture_num_buffers;
        req.type                = V4L2_BUF_TYPE_VIDEO_CAPTURE;
        req.memory              = V4L2_MEMORY_MMAP;
        if (ioctl (fd_capture_v4l, VIDIOC_REQBUFS, &req) < 0) {
                        fprintf (stderr, "%s does not support "
                                         "memory mapping\n", v4l_capture_dev);
                        return TFAIL;
                } else {
                                         "memory mapping, unknow error\n", v4l_capture_dev);
                        return TFAIL;
        if (req.count < 2) {
                fprintf (stderr, "Insufficient buffer memory on %s\n",
                         v4l_capture_dev);
                return TFAIL;
        return 0;
int v4l_output_setup(void)
        struct v4l2_control ctrl;
        struct v4l2_framebuffer fb;
        struct v4l2_fmtdesc fmtdesc;
        struct v4l2_requestbuffers buf_req;
        if (!ioctl(fd_output_v4l, VIDIOC_QUERYCAP, &cap)) {
                printf("driver=%s, card=%s, bus=%s, "
                        "version=0x%08x, "
                        "capabilities=0x%08x\n",
                        cap.driver, cap.card, cap.bus_info,
                        cap.version,
                        cap.capabilities);
        fmtdesc.index = 0;
        fmtdesc.type = V4L2_BUF_TYPE_VIDEO_OUTPUT;
        while (!ioctl(fd_output_v4l, VIDIOC_ENUM_FMT, &fmtdesc)) {
                printf("fmt %s: fourcc = 0x%08x\n",
                        fmtdesc.description,
                        fmtdesc.pixelformat);
                fmtdesc.index++;
        cropcap.type = V4L2_BUF_TYPE_VIDEO_OUTPUT;
        if (ioctl(fd_output_v4l, VIDIOC_CROPCAP, &cropcap) < 0)
                printf("get crop capability failed\n");
                close(fd_output_v4l);
                return TFAIL;
        crop.type = V4L2_BUF_TYPE_VIDEO_OUTPUT;
        crop.c.top = g_display_top;
        crop.c.left = g_display_left;
        crop.c.width = g_display_width;
        crop.c.height = g_display_height;
        if (ioctl(fd_output_v4l, VIDIOC_S_CROP, &crop) < 0)
                printf("set crop failed\n");
                return TFAIL;
        // Set rotation
        ctrl.id = V4L2_CID_ROTATE;
        ctrl.value = g_rotate;
        if (ioctl(fd_output_v4l, VIDIOC_S_CTRL, &ctrl) < 0)
                printf("set ctrl rotate failed\n");
                return TFAIL;
        ctrl.id = V4L2_CID_VFLIP;
        ctrl.value = g_vflip;
                printf("set ctrl vflip failed\n");
                return TFAIL;
        ctrl.id = V4L2_CID_HFLIP;
        ctrl.value = g_hflip;
                printf("set ctrl hflip failed\n");
                return TFAIL;
        if (g_vdi_enable) {
                ctrl.id = V4L2_CID_MXC_MOTION;
                ctrl.value = g_vdi_motion;
                        printf("set ctrl motion failed\n");
                        return TFAIL;
        fb.flags = V4L2_FBUF_FLAG_OVERLAY;
       ioctl(fd_output_v4l, VIDIOC_S_FBUF, &fb);
        fmt.type = V4L2_BUF_TYPE_VIDEO_OUTPUT;
        fmt.fmt.pix.width= g_in_width;
        fmt.fmt.pix.height= g_in_height;
        fmt.fmt.pix.bytesperline = g_in_width;
        fmt.fmt.pix.priv = 0;
        fmt.fmt.pix.sizeimage = 0;
        if (g_tb)
                fmt.fmt.pix.field = V4L2_FIELD_INTERLACED_TB;
        else
                fmt.fmt.pix.field = V4L2_FIELD_INTERLACED_BT;
        //Avoid deinterlace in display
        fmt.fmt.pix.field = V4L2_FIELD_NONE;
        if (ioctl(fd_output_v4l, VIDIOC_S_FMT, &fmt) < 0)
                printf("set format failed\n");
                return TFAIL;
        if (ioctl(fd_output_v4l, VIDIOC_G_FMT, &fmt) < 0)
                printf("get format failed\n");
                return TFAIL;
        g_frame_size = fmt.fmt.pix.sizeimage;
        memset(&buf_req, 0, sizeof(buf_req));
        buf_req.count = g_output_num_buffers;
        buf_req.type = V4L2_BUF_TYPE_VIDEO_OUTPUT;
        buf_req.memory = V4L2_MEMORY_MMAP;
        if (ioctl(fd_output_v4l, VIDIOC_REQBUFS, &buf_req) < 0)
                printf("request buffers failed\n");
                return TFAIL;
        return 0;
int
mxc_v4l_tvin_test(void)
        struct v4l2_buffer capture_buf, output_buf;
        v4l2_std_id id;
        int i, j;
        int total_time;
        struct timeval tv_start, tv_current;
        if (prepare_output() < 0)
                printf("prepare_output failed\n");
                return TFAIL;
        if (start_capturing() < 0)
                printf("start_capturing failed\n");
                return TFAIL;
        gettimeofday(&tv_start, 0);
        printf("start time = %d s, %d us\n", (unsigned int) tv_start.tv_sec,
                (unsigned int) tv_start.tv_usec);
        for (i = 0; ; i++) {
begin:
                if (ioctl(fd_capture_v4l, VIDIOC_G_STD, &id)) {
                        printf("VIDIOC_G_STD failed.\n");
                        return TFAIL;
                if (id == g_current_std)
                        goto next;
                else if (id == V4L2_STD_PAL || id == V4L2_STD_NTSC) {
                        ioctl(fd_output_v4l, VIDIOC_STREAMOFF, &type);
                        ioctl(fd_capture_v4l, VIDIOC_STREAMOFF, &type);
                        for (j = 0; j < g_output_num_buffers; j++)
                                munmap(output_buffers[j].start, output_buffers[j].length);
                        for (j = 0; j < g_capture_num_buffers; j++)
                                munmap(capture_buffers[j].start, capture_buffers[j].length);
                        if (v4l_capture_setup() < 0) {
                                printf("Setup v4l capture failed.\n");
                                return TFAIL;
                        if (v4l_output_setup() < 0) {
                                printf("Setup v4l output failed.\n");
                                return TFAIL;
                                return TFAIL;
                                return TFAIL;
                        i = 0;
                        printf("TV standard changed\n");
                } else {
                        sleep(1);
                        /* Try again */
                                return TFAIL;
                        if (id != V4L2_STD_ALL)
                                goto begin;
                        printf("Cannot detect TV standard\n");
                        return 0;
next:
                memset(&capture_buf, 0, sizeof(capture_buf));
                capture_buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
                capture_buf.memory = V4L2_MEMORY_MMAP;
                if (ioctl(fd_capture_v4l, VIDIOC_DQBUF, &capture_buf) < 0) {
                        printf("VIDIOC_DQBUF failed.\n");
                        return TFAIL;
                if (i < g_output_num_buffers) {
                                printf("VIDIOC_QUERYBUF failed\n");
                                return TFAIL;
                } else {
                        if (ioctl(fd_output_v4l, VIDIOC_DQBUF, &output_buf) < 0)
                                printf("VIDIOC_DQBUF failed\n");
                                return TFAIL;
                memcpy(output_buffers[output_buf.index].start, capture_buffers[capture_buf.index].start, g_frame_size);
                if (ioctl(fd_capture_v4l, VIDIOC_QBUF, &capture_buf) < 0) {
                        printf("VIDIOC_QBUF failed\n");
                        return TFAIL;
                output_buf.timestamp.tv_sec = tv_start.tv_sec;
                output_buf.timestamp.tv_usec = tv_start.tv_usec + (g_frame_period * i);
                if (ioctl(fd_output_v4l, VIDIOC_QBUF, &output_buf) < 0)
                        return TFAIL;
                if (i == 1) {
                        if (ioctl(fd_output_v4l, VIDIOC_STREAMON, &type) < 0) {
                                printf("Could not start stream\n");
                                return TFAIL;
        gettimeofday(&tv_current, 0);
        total_time = (tv_current.tv_sec - tv_start.tv_sec) * 1000000L;
        total_time += tv_current.tv_usec - tv_start.tv_usec;
        printf("total time for %u frames = %u us =  %lld fps\n", i, total_time, (i * 1000000ULL) / total_time);
        return 0;
int process_cmdline(int argc, char **argv)
        int i;
        int vi_set = 0;
        int vo_set = 0;
        for (i = 1; i < argc; i++) {
                if (strcmp(argv[i], "-ow") == 0) {
                        g_display_width = atoi(argv[++i]);
                else if (strcmp(argv[i], "-oh") == 0) {
                        g_display_height = atoi(argv[++i]);
                else if (strcmp(argv[i], "-ot") == 0) {
                        g_display_top = atoi(argv[++i]);
                else if (strcmp(argv[i], "-ol") == 0) {
                        g_display_left = atoi(argv[++i]);
                else if (strcmp(argv[i], "-r") == 0) {
                        g_rotate = atoi(argv[++i]);
                else if (strcmp(argv[i], "-f") == 0) {
                        i++;
                        g_fmt = v4l2_fourcc(argv[i][0], argv[i][1],argv[i][2],argv[i][3]);
                        if ((g_fmt != V4L2_PIX_FMT_NV12) &&
                                (g_fmt != V4L2_PIX_FMT_UYVY) &&
                                (g_fmt != V4L2_PIX_FMT_YUYV) &&
                                (g_fmt != V4L2_PIX_FMT_YUV420)) {
                                        printf("Default format is used: UYVY\n");
                else if (strcmp(argv[i], "-vi") == 0) {
                        strcat(v4l_capture_dev, argv[++i]);
                        vi_set = 1;
                else if (strcmp(argv[i], "-vo") == 0) {
                        strcat(v4l_output_dev, argv[++i]);
                        vo_set = 1;
                else if (strcmp(argv[i], "-dv") == 0) {
                        g_input = 1; // Back to "CSI MEM" instead of "CSI VDI MEM"
                else if (strcmp(argv[i], "-m") == 0) {
                        g_vdi_enable = 1;
                        g_vdi_motion = atoi(argv[++i]);
                else if (strcmp(argv[i], "-tb") == 0) {
                        g_tb = 1;
                else if (strcmp(argv[i], "-help") == 0) {
                        printf("MXC Video4Linux TVin Test\n\n"
                                   "Syntax: mxc_v4l2_tvin.out\n"
                                   " -ow <capture display width>\n"
                                   " -oh <capture display height>\n"
                                   " -ot <display top>\n"
                                   " -ol <display left>\n"
                                   " -r <rotation> -c <capture counter>\n"
                                   " -m <motion> 0:medium 1:low 2:high, 0-default\n"
                                   " -vi <capture_num> uses capture /dev/video<capture_num>\n"
                                   " -vo <output_num> uses output /dev/video<output_num>\n"
                                   " -dv disable VDI\n"
                                   " -tb top field first, bottom field first-default\n"
                                   " -f <format, only YU12, YUYV, UYVY and NV12 are supported> \n");
                        return TFAIL;
        if (!vi_set) {
                strcat(v4l_capture_dev, "0"); // Use /dev/video0 as default capture device
        if (!vo_set) {
                strcat(v4l_output_dev, "16"); // Use /dev/video16 as default output device
        if ((g_display_width == 0) || (g_display_height == 0)) {
                printf("Zero display width or height\n");
                return TFAIL;
        return 0;
int main(int argc, char **argv)
        char fb_device[100] = "/dev/fb0";
        int fd_fb = 0, i;
        struct mxcfb_gbl_alpha alpha;
        if (process_cmdline(argc, argv) < 0) {
                return TFAIL;
        if ((fd_capture_v4l = open(v4l_capture_dev, O_RDWR, 0)) < 0)
                printf("Unable to open %s\n", v4l_capture_dev);
                return TFAIL;
        if ((fd_output_v4l = open(v4l_output_dev, O_RDWR, 0)) < 0)
                printf("Unable to open %s\n", v4l_output_dev);
                return TFAIL;
                return TFAIL;
                return TFAIL;
        if ((fd_fb = open(fb_device, O_RDWR )) < 0) {
                printf("Unable to open frame buffer\n");
                return TFAIL;
        /* Overlay setting */
        alpha.alpha = 0;
        alpha.enable = 1;
        if (ioctl(fd_fb, MXCFB_SET_GBL_ALPHA, &alpha) < 0) {
                printf("Set global alpha failed\n");
                close(fd_fb);
                return TFAIL;
        mxc_v4l_tvin_test();
                munmap(output_buffers[i].start, output_buffers[i].length);
                munmap(capture_buffers[i].start, capture_buffers[i].length);
        close(fd_fb);
        return 0;
     I had finished BT1120 input function with parallel CSI port,and this function was workable now.
but video quality was very bad with interlaced video content.
I tried to enable De-interlace fuction by add-csi-deinterlace-capture.patch that you provided.
But I can't finish this function.
when I enabled CONFIG_MXC_IPU_VDI_ENC=y then the system crashed with following log.
Does this patch also support for IMX6???
====>_ipu_smfc_init
====>_ipu_smfc_init success
====> _ipu_csi_init
====> CSI_DATA_DEST_IDMAC
csi=0, ipu=-1064052716, offset=0x746bb000
Unable to handle kernel paging request at virtual address 746bb000 pgd = d674c000
Could you please give me some suggestions for this problem?
Thank you.
Can this patch work in android 4.3?
m_c
Add apply patch, the image became blur. Is this right? How to improve it?
01_original = Freescale Android JB4.3 1.1.0
After apply deinterlance patch
Hello.
I tested HDMI input using this patch in i.MX6DL.
In 720x480i60 , it works well.
but In 1920x1080i60, it cannot capture image. the following message is printed continuously.
imx-ipuv3 imx-ipuv3.0: warning: disable ipu dma channel 8 during its busy state
According to reference manual,  VDIC supports upto 1080i60.
But, in above message, idmac dma channel 8 means previous field and it's busy.
Are there anyone  who knows the reason ?
Thnak you.
Hyungjun Yoon
All, this document is being closed to any new comments/replies.  If you have posted a question here, or if you have a question about this topic, please create a discussion so that our support team can see it and respond to it.
Sorry for any inconvenience.
%3CLINGO-SUB%20id%3D%22lingo-sub-1114964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E6%9F%90%E4%BA%9B%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%B8%8C%E6%9C%9B%E9%80%9A%E8%BF%87%20V4L2%20%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%E7%9B%B4%E6%8E%A5%E4%BB%8E%20TV-IN%20%E6%8E%A5%E5%8F%A3%E8%8E%B7%E5%8F%96%E6%B8%90%E8%BF%9B%E5%BC%8F%E5%86%85%E5%AE%B9%E3%80%82%E5%9C%A8%20BSP%20%E4%B8%AD%EF%BC%8C%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E5%8E%BB%E9%9A%94%E8%A1%8C%E4%BB%85%E5%9C%A8%20V4L2%20%E8%BE%93%E5%87%BA%E6%B5%81%E4%B8%AD%E5%8F%97%E6%94%AF%E6%8C%81%E3%80%82%E4%B8%8B%E9%9D%A2%E6%98%AF%E9%92%88%E5%AF%B9%E7%9B%B8%E5%BD%93%E6%97%A7%E7%9A%84%20BSP%20%E7%89%88%E6%9C%AC%E5%88%9B%E5%BB%BA%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%8C%E5%AE%83%E5%A2%9E%E5%8A%A0%E4%BA%86%E5%AF%B9%E5%8E%BB%E9%9A%94%E8%A1%8C%20V4L2%20%E6%8D%95%E8%8E%B7%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E8%AF%A5%E8%A1%A5%E4%B8%81%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E9%80%82%E5%BA%94%E8%BE%83%E6%96%B0%E7%9A%84%20BSP%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E9%80%BB%E8%BE%91%E5%92%8C%E5%8A%9F%E8%83%BD%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E7%BC%A9%E7%9F%AD%E5%BC%80%E5%8F%91%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%A1%A5%E4%B8%81%E4%B8%BA%20V4L2%20%E6%A1%86%E6%9E%B6%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E8%BE%93%E5%85%A5%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E8%AF%A5%E8%AE%BE%E5%A4%87%E5%9C%A8%E8%BF%9B%E5%85%A5%E5%86%85%E5%AD%98%E7%9A%84%E9%80%94%E4%B8%AD%E6%89%A7%E8%A1%8C%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E9%80%9A%E8%BF%87%E5%B0%86%E7%B4%A2%E5%BC%95%E2%80%9C2%E2%80%9D%E4%BD%9C%E4%B8%BA%E5%8F%82%E6%95%B0%E4%BC%A0%E9%80%92%E7%BB%99%20VIDIOC_S_INPUT%20V4L2%20ioctl%20%E6%9D%A5%E5%AE%8C%E6%88%90%E9%80%89%E6%8B%A9%E3%80%82%E9%99%84%E4%BB%B6%E4%B8%AD%E8%BF%98%E9%99%84%E6%9C%89%E4%BF%AE%E6%94%B9%E5%90%8E%E7%9A%84%20tvin%20%E5%8D%95%E5%85%83%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BB%A5%E6%8F%90%E4%BE%9B%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E6%96%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%E8%BF%90%E8%A1%8C%E6%B5%8B%E8%AF%95%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%BA%8F%E5%88%97%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emodprobe%20mxc_v4l2_capture%3C%2FP%3E%3CP%3E.%2Fmxc_v4l2_tvin_vdi.out-ow%20720-oh%20480-ol%2010-ot%2020-f%20YU12%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E4%B8%80%E4%BA%9B%E5%85%B3%E9%94%AE%E4%BA%8B%E9%A1%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%AD%A4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8D%E6%94%AF%E6%8C%81%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E8%B0%83%E6%95%B4%E5%A4%A7%E5%B0%8F%E6%88%96%E8%BF%9B%E8%A1%8C%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B1%82%E7%9A%84%E6%A0%BC%E5%BC%8F%E5%92%8C%E5%A4%A7%E5%B0%8F%E5%BA%94%E4%B8%8E%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9B%B4%E6%8E%A5%E6%8F%90%E4%BE%9B%E7%9A%84%E6%A0%BC%E5%BC%8F%E5%92%8C%E5%A4%A7%E5%B0%8F%E7%9B%B8%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E8%BF%90%E8%A1%8C%20Linux%2012.02%20%E7%9A%84%20Sabre%20AI%20Rev%20A%20%E6%9D%BF%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E4%BB%A3%E7%A0%81%E5%B9%B6%E9%9D%9E%E5%AE%98%E6%96%B9%E4%BA%A4%E4%BB%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E4%B8%8D%E4%BF%9D%E8%AF%81%E6%94%AF%E6%8C%81%E6%AD%A4%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%80%E6%9C%89%E4%BA%BA%EF%BC%8C%E6%AD%A4%E6%96%87%E6%A1%A3%E5%B0%86%E4%B8%8D%E5%86%8D%E6%8E%A5%E5%8F%97%E4%BB%BB%E4%BD%95%E6%96%B0%E8%AF%84%E8%AE%BA%2F%E5%9B%9E%E5%A4%8D%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E6%AD%A4%E5%A4%84%E5%8F%91%E5%B8%83%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%96%E8%80%85%E5%AF%B9%E6%AD%A4%E4%B8%BB%E9%A2%98%E6%9C%89%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E5%88%9B%E5%BB%BA%E8%AE%A8%E8%AE%BA%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E7%9A%84%E6%94%AF%E6%8C%81%E5%9B%A2%E9%98%9F%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E5%B9%B6%E5%81%9A%E5%87%BA%E5%9B%9E%E5%BA%94%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E4%BE%BF%E4%B9%8B%E5%A4%84%EF%BC%8C%E6%95%AC%E8%AF%B7%E8%B0%85%E8%A7%A3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20i.MX6DL%20%E4%B8%AD%E7%9A%84%E8%BF%99%E4%B8%AA%E8%A1%A5%E4%B8%81%E6%B5%8B%E8%AF%95%E4%BA%86%20HDMI%20%E8%BE%93%E5%85%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20720x480i60%20%E4%B8%8B%EF%BC%8C%E5%AE%83%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%201920x1080i60%20%E4%B8%8B%EF%BC%8C%E5%AE%83%E6%97%A0%E6%B3%95%E6%8D%95%E8%8E%B7%E5%9B%BE%E5%83%8F%E3%80%82%E8%BF%9E%E7%BB%AD%E6%89%93%E5%8D%B0%E4%BB%A5%E4%B8%8B%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E--------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%9C%A8%20ipu%20dma%20%E9%80%9A%E9%81%93%208%20%E7%B9%81%E5%BF%99%E7%8A%B6%E6%80%81%E4%B8%8B%E7%A6%81%E7%94%A8%E5%AE%83%3C%2FP%3E%3CP%3E--------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%8CVDIC%20%E6%9C%80%E9%AB%98%E6%94%AF%E6%8C%81%201080i60%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%B6%88%E6%81%AF%E4%B8%AD%EF%BC%8Cidmac%20dma%20%E9%80%9A%E9%81%93%208%20%E8%A1%A8%E7%A4%BA%E5%89%8D%E4%B8%80%E4%B8%AA%E5%AD%97%E6%AE%B5%E5%B9%B6%E4%B8%94%E5%AE%83%E5%BE%88%E5%BF%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E8%B0%81%E7%9F%A5%E9%81%93%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%B9%E4%BA%A8%E4%BF%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B7%BB%E5%8A%A0%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%E5%90%8E%EF%BC%8C%E5%9B%BE%E5%83%8F%E5%8F%98%E5%BE%97%E6%A8%A1%E7%B3%8A%E3%80%82%E8%BF%99%E6%98%AF%E5%AF%B9%E7%9A%84%E5%90%97%EF%BC%9F%E5%A6%82%E4%BD%95%E6%94%B9%E5%96%84%EF%BC%9F%3C%2FP%3E%3CP%3E01_original%20%3D%20%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20Android%20JB4.3%201.1.0%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2203_original_zoom.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2203_original_zoom.png%22%20style%3D%22width%3A%20709px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45807iE0FDB38A0CE82E65%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2203_original_zoom.png%22%20alt%3D%2203_original_zoom.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E03_original_zoom.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E02_deinterlace.png%3C%2FP%3E%3CP%3E%E5%BA%94%E7%94%A8%20deinterlance%20%E8%A1%A5%E4%B8%81%E5%90%8E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2204_deinterlace_zoom.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2204_deinterlace_zoom.png%22%20style%3D%22width%3A%20709px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45844i6C262FC042A78EDB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2204_deinterlace_zoom.png%22%20alt%3D%2204_deinterlace_zoom.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E04_deinterlace_zoom.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B8%AA%E8%A1%A5%E4%B8%81%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Android%204.3%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%E4%BA%86BT1120%E9%80%9A%E8%BF%87%E5%B9%B6%E8%A1%8CCSI%E7%AB%AF%E5%8F%A3%E8%BE%93%E5%85%A5%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%AF%A5%E5%8A%9F%E8%83%BD%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E9%9A%94%E8%A1%8C%E6%89%AB%E6%8F%8F%E8%A7%86%E9%A2%91%E5%86%85%E5%AE%B9%E7%9A%84%E8%A7%86%E9%A2%91%E8%B4%A8%E9%87%8F%E9%9D%9E%E5%B8%B8%E5%B7%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%20add-csi-deinterlace-capture.patch%20%E5%90%AF%E7%94%A8%20De-interlace%20%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E5%AE%8C%E6%88%90%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%90%AF%E7%94%A8%20CONFIG_MXC_IPU_VDI_ENC%3Dy%20%E6%97%B6%EF%BC%8C%E7%B3%BB%E7%BB%9F%E5%B4%A9%E6%BA%83%E5%B9%B6%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%A1%A5%E4%B8%81%E4%B9%9F%E6%94%AF%E6%8C%81%20IMX6%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%26gt%3B_ipu_smfc_init%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%26gt%3B_ipu_smfc_init%20%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%26gt%3B%20_ipu_csi_init%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%26gt%3B%20CSI_DATA_DEST_IDMAC%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9AIDMAC21%20%E7%9A%84%20EBA0%20%E4%B8%8D%E6%98%AF%208%20%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%E7%9A%84%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9AIDMAC21%20%E7%9A%84%20EBA1%20%E4%B8%8D%E6%98%AF%208%20%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%E7%9A%84%3C%2FP%3E%3CP%3Ecsi%3D0%2C%20ipu%3D-1064052716%2C%20offset%3D0x746bb000%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%99%9A%E6%8B%9F%E5%9C%B0%E5%9D%80%20746bb000%20pgd%20%3D%20d674c000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E5%88%86%E9%A1%B5%E8%AF%B7%E6%B1%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E9%92%88%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E6%82%A8%E5%B0%86%E5%9C%A8%E4%B8%8B%E9%9D%A2%E6%89%BE%E5%88%B0%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%E9%92%88%E5%AF%B9%20VDI%20%E4%BB%A3%E7%A0%81%E7%9A%84%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%EF%BC%8C%3C%2FSTRONG%3E%E8%AF%A5%E4%BB%A3%E7%A0%81%E8%A7%A3%E5%86%B3%E4%BA%86%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20PAL%20%E8%A7%86%E9%A2%91%E8%BE%93%E5%85%A5%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E8%AF%A5%E9%97%AE%E9%A2%98%E5%B9%B6%E9%9D%9E%20PAL%20%E6%89%80%E7%89%B9%E6%9C%89%EF%BC%8C%E5%9B%A0%E4%B8%BA%20VDI%20%E5%AD%97%E6%AE%B5%E6%9C%AA%E5%BE%97%E5%88%B0%E6%AD%A3%E7%A1%AE%E5%BC%95%E7%94%A8%EF%BC%8C%E8%BF%99%E8%A7%A3%E9%87%8A%E4%BA%86%E8%BF%99%E4%BA%9B%E7%91%95%E7%96%B5%E2%80%A6%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E4%BB%BB%E4%BD%95%E4%BA%BA%EF%BC%88%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%88%96%E5%85%B6%E4%BB%96%E8%AE%BA%E5%9D%9B%E6%88%90%E5%91%98%EF%BC%89%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%AE%A1%E6%9F%A5%E6%AD%A4%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%9C%A8%E4%BB%96%E4%BB%AC%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%B5%8B%E8%AF%95%E5%AE%83%E5%B9%B6%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%E5%88%86%E4%BA%AB%E7%BB%93%E6%9E%9C%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E6%88%91%E4%BB%AC%E7%9A%84%E6%84%9F%E8%A7%89%E6%98%AF%EF%BC%8C%E8%BF%99%E4%B8%AA%E4%BF%AE%E5%A4%8D%E4%BD%BF%E5%BE%97%20VDI%20%E7%8E%B0%E5%9C%A8%E5%8F%AF%E7%94%A8%EF%BC%8C%E4%BD%86%E6%80%A7%E8%83%BD%E4%BB%8D%E7%84%B6%E6%98%AF%E4%B8%BB%E8%A6%81%E9%97%AE%E9%A2%98%EF%BC%9AIDMA%20%E6%97%A0%E6%B3%95%E4%BB%8E%E8%A7%86%E9%A2%91%E5%B8%A7%E6%BA%A2%E5%87%BA%E4%B8%AD%E6%81%A2%E5%A4%8D%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BD%93%E6%82%A8%E7%B4%AF%E7%A7%AF%E4%B8%8D%E5%90%8C%E7%9A%84%20I%2FO%20%E6%B5%81%E9%87%8F%EF%BC%88%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%E6%98%AF%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%92%8C%20SATA%EF%BC%89%E6%97%B6%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E7%9A%84%E6%A6%82%E7%8E%87%E4%BC%9A%E5%8F%98%E5%BE%97%E5%BE%88%E9%AB%98%E3%80%82%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%8C%E5%9C%A8%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%E4%B8%8B%EF%BC%8C%E4%BD%BF%E7%94%A8%20i.MX6Q%20%E9%80%9A%E5%B8%B8%E4%BC%9A%E5%9C%A8%E4%B8%8D%E5%88%B0%201%20%E5%B0%8F%E6%97%B6%E5%86%85%E5%8F%91%E7%94%9F%E5%B4%A9%E6%BA%83%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E2%20%E4%B8%AA%20PAL%20%E8%A7%86%E9%A2%91%E8%BE%93%E5%85%A5%EF%BC%88%E5%B8%A6%20VDI%EF%BC%89%E5%90%8C%E6%97%B6%E6%BF%80%E6%B4%BB%EF%BC%8C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Symbol%3B%20mso-list%3A%20Ignore%3B%20font%3A%207.0pt%20'Times%20New%20Roman'%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20Symbol%3B%20mso-fareast-font-family%3A%20Symbol%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E50%20Mb%2Fs%20%E4%BC%A0%E5%87%BA%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%B5%81%E9%87%8F%EF%BC%8C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E80%20Mb%2Fs%20%E4%BC%A0%E5%85%A5%E6%B5%81%E9%87%8F%EF%BC%8C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E100%20Mb%2Fs%20%E4%BC%A0%E5%87%BA%20SATA%20%E6%B5%81%E9%87%8F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E5%B9%B3%E5%9D%87%20CPU%20%E8%B4%9F%E8%BD%BD%E7%BA%A6%E4%B8%BA%2025%25%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E4%BB%AC%E8%BF%98%E6%9B%B4%E6%96%B0%E4%BA%86%E2%80%9Ctvin%E2%80%9D%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%A2%9E%E5%8A%A0%E4%BA%86%203%20%E4%B8%AA%E6%96%B0%E9%80%89%E9%A1%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpFirst%22%20style%3D%22text-indent%3A%20-18.0pt%3B%20mso-list%3A%20l1%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Calibri%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20EN-US%3B%20mso-bidi-theme-font%3A%20minor-latin%3B%22%3E1.%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20-vi%3CCAPTURE_NUM%3E%3C%2FCAPTURE_NUM%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%E5%85%81%E8%AE%B8%E6%8C%87%E5%AE%9A%E6%82%A8%E7%9A%84%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%EF%BC%88%20%E9%BB%98%E8%AE%A4%E4%B8%BA%3C%2FSPAN%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Courier%20New'%3B%20mso-ansi-language%3A%20EN-US%3B%22%3E%20%2Fdev%2Fvideo0%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-18.0pt%3B%20mso-list%3A%20l1%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Calibri%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20EN-US%3B%20mso-bidi-theme-font%3A%20minor-latin%3B%22%3E2.%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20-vo%3COUTPUT_NUM%3E%3C%2FOUTPUT_NUM%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%E5%85%81%E8%AE%B8%E6%8C%87%E5%AE%9A%E8%BE%93%E5%87%BA%E8%AE%BE%E5%A4%87%EF%BC%88%20%E9%BB%98%E8%AE%A4%E4%B8%BA%3C%2FSPAN%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Courier%20New'%3B%20mso-ansi-language%3A%20EN-US%3B%22%3E%20%2Fdev%2Fvideo16%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%20style%3D%22text-indent%3A%20-18.0pt%3B%20mso-list%3A%20l1%20level1%20lfo1%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Calibri%3B%20mso-list%3A%20Ignore%3B%20mso-ansi-language%3A%20EN-US%3B%20mso-bidi-theme-font%3A%20minor-latin%3B%22%3E3.%3CSPAN%20style%3D%22font%3A%207.0pt%20'Times%20New%20Roman'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E-dv%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E7%A6%81%E7%94%A8%20VDI%EF%BC%88%E5%90%A6%E5%88%99%E5%A7%8B%E7%BB%88%E6%BF%80%E6%B4%BB%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%20style%3D%22text-indent%3A%20-18.0pt%3B%20mso-list%3A%20l1%20level1%20lfo1%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22background%3A%20%23FDE9D9%3B%20mso-background-themecolor%3A%20accent6%3B%20mso-background-themetint%3A%2051%3B%22%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Courier%20New'%3B%20mso-ansi-language%3A%20EN-US%3B%22%3Emxc_v4l2_tvin%20-ow%20720%20-oh%20576%20-vi%200%20-vo%2016%20-m%200%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22background%3A%20%23FDE9D9%3B%20mso-background-themecolor%3A%20accent6%3B%20mso-background-themetint%3A%2051%3B%22%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Courier%20New'%3B%20mso-ansi-language%3A%20EN-US%3B%22%3Emxc_v4l2_tvin%20-ow%20720%20-oh%20576%20-vi%201%20-vo%2017%20-dv%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22mso-ansi-language%3A%20EN-US%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22FR%22%20style%3D%22font-size%3A%2016.0pt%3B%20line-height%3A%20115%25%3B%20mso-ansi-language%3A%20FR%3B%22%3E%E4%BF%AE%E5%A4%8D%20VDI%20%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSTRONG%20style%3D%22mso-bidi-font-family%3A%20'Courrier%20New'%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%22%3E---%20a%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E5%AA%92%E4%BD%93%2F%E8%A7%86%E9%A2%91%2Fmxc%2F%E6%8D%95%E8%8E%B7%2Fipu_vdi_enc.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSTRONG%20style%3D%22mso-bidi-font-family%3A%20'Courrier%20New'%3B%20font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%22%3E%2B%2B%2Bb%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E5%AA%92%E4%BD%93%2F%E8%A7%86%E9%A2%91%2Fmxc%2F%E6%8D%95%E8%8E%B7%2Fipu_vdi_enc.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-31%2C6%20%2B31%2C9%20%40%40%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%23%E5%AE%9A%E4%B9%89%20CAMERA_TRACE%EF%BC%88x%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%23endif%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%23define%20PREVIOUS_INDEX%20((cam-%26gt%3Bping_pong_vdi%20%2B%202)%20%253)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%23%E5%AE%9A%E4%B9%89%E5%BD%93%E5%89%8D%E7%B4%A2%E5%BC%95%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%EF%BC%88%E6%91%84%E5%83%8F%E5%A4%B4-%26gt%3Bping_pong_vdi%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%23%E5%AE%9A%E4%B9%89NEXT_INDEX%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E((cam-%26gt%3Bping_pong_vdi%20%2B%201)%20%253)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E*%20%E5%87%BD%E6%95%B0%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-47%2C8%20%2B50%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%3D%20ipu_update_channel_buffer%EF%BC%88cam-%26gt%3B%20ipu%EF%BC%8CMEM_VDI_PRP_VF_MEM_P%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5B(cam-%26gt%3Bping_pong_vdi%20%2B%202)%20%253%5D%20%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BPREVIOUS_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eipu_clear_buffer_ready%EF%BC%88cam-%26gt%3Bipu%EF%BC%8CMEM_VDI_PRP_VF_MEM_P%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-57%2C8%20%2B59%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%3D%20ipu_update_channel_buffer%EF%BC%88cam-%26gt%3B%20ipu%EF%BC%8CMEM_VDI_PRP_VF_MEM_P%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5B(cam-%26gt%3Bping_pong_vdi%20%2B%202)%20%253%5D%20%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BPREVIOUS_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Epr_err(%22%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9A%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%20vdi%20P%20%E7%BC%93%E5%86%B2%E5%8C%BA%22)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-68%2C7%20%2B69%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eerr%20%3D%20ipu_update_channel_buffer(cam-%26gt%3Bipu%2C%20MEM_VDI_PRP_VF_MEM%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BCURRENT_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eipu_clear_buffer_ready%EF%BC%88cam-%26gt%3Bipu%EF%BC%8CMEM_VDI_PRP_VF_MEM%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-77%2C7%20%2B78%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eerr%20%3D%20ipu_update_channel_buffer(cam-%26gt%3Bipu%2C%20MEM_VDI_PRP_VF_MEM%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BCURRENT_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Epr_err(%22%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9A%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%20vdi%20%E7%BC%93%E5%86%B2%E5%8C%BA%22)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-87%2C8%20%2B88%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%3D%20ipu_update_channel_buffer%EF%BC%88cam-%26gt%3B%20ipu%EF%BC%8CMEM_VDI_PRP_VF_MEM_N%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BNEXT_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eipu_clear_buffer_ready%EF%BC%88cam-%26gt%3Bipu%EF%BC%8CMEM_VDI_PRP_VF_MEM_N%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-97%2C8%20%2B97%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%3D%20ipu_update_channel_buffer%EF%BC%88cam-%26gt%3B%20ipu%EF%BC%8CMEM_VDI_PRP_VF_MEM_N%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D%20%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BNEXT_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Epr_err(%22%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9A%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%20vdi%20N%20%E7%BC%93%E5%86%B2%E5%8C%BA%22)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-109%2C11%20%2B108%2C11%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_first_frame%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bping_pong_vdi%20%3D%20(cam-%26gt%3Bping_pong_vdi%20%2B%201)%253%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bping_pong_vdi%20%3D%20%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%B4%A2%E5%BC%95%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%2F%2F%E5%B0%86CSI%E8%BE%93%E5%87%BA%E6%8C%87%E5%90%91%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eerr%20%3D%20ipu_update_channel_buffer%EF%BC%88cam-%26gt%3Bipu%EF%BC%8CCSI_MEM%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BCURRENT_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eipu_clear_buffer_ready%EF%BC%88cam-%26gt%3Bipu%EF%BC%8CCSI_MEM%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-121%2C7%20%2B120%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20void%20vdi_work_func(struct%20work_struct%20*work)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eerr%20%3D%20ipu_update_channel_buffer%EF%BC%88cam-%26gt%3Bipu%EF%BC%8CCSI_MEM%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8C0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BCURRENT_INDEX%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eif%20(err%20!%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Epr_err(%22%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9A%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%20CSI%20%E7%BC%93%E5%86%B2%E5%8C%BA%22)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-275%2C7%20%2B274%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20int%20vdi_enc_setup(cam_data%20*cam)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline%20%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebytes_per_pixel(enc.mem_prp_vf_mem.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E5%83%8F%E7%B4%A0fmt%EF%BC%89%EF%BC%8CIPU%E6%97%8B%E8%BD%AC%E6%97%A0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D%2C%200%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5BCURRENT_INDEX%5D%2C%200%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%87%B8%E8%BD%AE-%26gt%3B%E5%81%8F%E7%A7%BB.u_%E5%81%8F%E7%A7%BB%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Boffset.v_offset)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-306%2C7%20%2B305%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20int%20vdi_enc_setup(cam_data%20*cam)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebytes_per_pixel(enc.mem_prp_vf_mem.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eout_pixel_fmt)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU_ROTATE_NONE%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5B(cam-%26gt%3Bping_pong_vdi%20%2B%201)%20%253%5D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5B%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%B4%A2%E5%BC%95%5D%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%87%B8%E8%BD%AE-%26gt%3B%E5%81%8F%E7%A7%BB.u_%E5%81%8F%E7%A7%BB%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Boffset.v_offset)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-335%2C8%20%2B334%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20int%20vdi_enc_setup(cam_data%20*cam)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebytes_per_pixel(enc.mem_prp_vf_mem.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eout_pixel_fmt)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU_ROTATE_NONE%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5Bcam-%26gt%3Bping_pong_vdi%5D%20%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23307f30%3B%22%3Ecam-%26gt%3Bvdi_enc_bufs%5B%E5%BD%93%E5%89%8D%E7%B4%A2%E5%BC%95%5D%EF%BC%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%87%B8%E8%BD%AE-%26gt%3B%E5%81%8F%E7%A7%BB.u_%E5%81%8F%E7%A7%BB%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Boffset.v_offset)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%231b7f7f%3B%22%3E%40%40%20-380%2C8%20%2B378%2C7%20%40%40%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%E9%9D%99%E6%80%81%20int%20vdi_enc_setup(cam_data%20*cam)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebytes_per_pixel(enc.mem_prp_vf_mem.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eout_pixel_fmt)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EIPU_ROTATE_NONE%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5B(cam-%26gt%3Bping_pong_vdi%20%2B%201)%20%253%5D%20%2B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%237f3030%3B%22%3E-%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bv2f.fmt.pix.bytesperline%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%20color%3A%20%23307f30%3B%22%3E%2B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Bvdi_enc_bufs%5B%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%B4%A2%E5%BC%95%5D%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E0%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%87%B8%E8%BD%AE-%26gt%3B%E5%81%8F%E7%A7%BB.u_%E5%81%8F%E7%A7%BB%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Courrier%20New'%3B%20mso-bidi-font-family%3A%20'Courrier%20New'%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecam-%26gt%3Boffset.v_offset)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22FR%22%20style%3D%22mso-ansi-language%3A%20FR%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22FR%22%20style%3D%22mso-ansi-language%3A%20FR%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSTRONG%20style%3D%22mso-bidi-font-weight%3A%20normal%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2016.0pt%3B%20line-height%3A%20115%25%3B%20mso-ansi-language%3A%20EN-US%3B%22%3E%E6%9B%B4%E6%96%B0%E4%BA%86%E2%80%9Ctvin%E2%80%9D%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%202007-2012%20%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%8D%8A%E5%AF%BC%E4%BD%93%E5%85%AC%E5%8F%B8%E3%80%82%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%20%E6%9C%AC%E6%96%87%E5%8C%85%E5%90%AB%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B7%B2%E8%8E%B7%E5%BE%97%20GNU%20%E9%80%9A%E7%94%A8%E5%85%AC%E5%85%B1%E8%AE%B8%E5%8F%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%20%E6%89%A7%E7%85%A7%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%20GNU%20%E9%80%9A%E7%94%A8%E5%85%AC%E5%85%B1%E8%AE%B8%E5%8F%AF%E8%AF%81%E7%9A%84%E5%89%AF%E6%9C%AC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%20%E7%89%88%E6%9C%AC%202%20%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E4%BD%8D%E4%BA%8E%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E*%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.opensource.org%2Flicenses%2Fgpl-license.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.opensource.org%2Flicenses%2Fgpl-license.html%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E*%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Fcopyleft%2Fgpl.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Fcopyleft%2Fgpl.html%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%40%E6%96%87%E4%BB%B6mxc_v4l2_tvin.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%20%40brief%20Mxc%20TVIN%20For%20Linux%202%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B5%8B%E8%AF%95%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23ifdef%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20__cplusplus%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%E5%A4%96%E9%83%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CC%E2%80%9D%3C%2FSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23endif%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%2F*%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20green%3B%22%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSTDIO.H%3E%3C%2FSTDIO.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSTDLIB.H%3E%3C%2FSTDLIB.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CERRNO.H%3E%3C%2FERRNO.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSTDINT.H%3E%3C%2FSTDINT.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSYS%3E%3C%2FSYS%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSTDINT.H%3E%3C%2FSTDINT.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSYS%3E%3C%2FSYS%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CFCNTL.H%3E%3C%2FFCNTL.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSYS%3E%3C%2FSYS%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSYS%3E%3C%2FSYS%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CUNISTD.H%3E%3C%2FUNISTD.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CASM%3E%3C%2FASM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CLINUX%3E%3C%2FLINUX%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSYS%3E%3C%2FSYS%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CMATH.H%3E%3C%2FMATH.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSTRING.H%3E%3C%2FSTRING.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CMALLOC.H%3E%3C%2FMALLOC.H%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23include%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%3CSYS%3E%3C%2FSYS%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23%E5%8C%85%E6%8B%AC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9Clinux%2Fmxcfb.h%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23%E5%8C%85%E6%8B%AC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9Clinux%2Fmxc_v4l2.h%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3ETFAIL-1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%23%E5%AE%9A%E4%B9%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3ETPASS%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Echar%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Ev4l_capture_dev%5B100%5D%20%3D%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%2Fdev%2Fvideo%22%3C%2FSPAN%3E%20%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Echar%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Ev4l_output_dev%5B100%5D%20%3D%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%2Fdev%2Fvideo%22%3C%2FSPAN%3E%20%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Efd_capture_v4l%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20fd_output_v4l%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_cap_mode%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_input%20%3D%202%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_fmt%20%3D%20V4L2_PIX_FMT_UYVY%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_rotate%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_vflip%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_hflip%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_vdi_enable%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_vdi_motion%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_tb%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_%E8%BE%93%E5%87%BA%3D3%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_output_num_buffers%20%3D%204%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_capture_num_buffers%20%3D%203%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_in_width%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_in_height%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_display_width%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_display_height%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_display_top%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20g_display_left%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_frame_size%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eg_frame_period%20%3D%2033333%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Ev4l2_std_id%20g_current_std%20%3D%20V4L2_STD_NTSC%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E6%B5%8B%E8%AF%95%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AD%97%E7%AC%A6%3C%2FSPAN%3E*%E5%BC%80%E5%A7%8B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Esize_t%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%95%B4%E6%95%B0%3C%2FSPAN%3E%E9%95%BF%E5%BA%A6%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E6%B5%8B%E8%AF%95%E7%BC%93%E5%86%B2%E5%8C%BA%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5B4%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E6%B5%8B%E8%AF%95%E7%BC%93%E5%86%B2%E5%8C%BAcapture_buffers%5B3%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Estart_capturing%EF%BC%88%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%95%B4%E6%95%B0%3C%2FSPAN%3Ei%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_buffer%20buf%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eenum%3C%2FSPAN%3E%20v4l2_buf_type%20type%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88i%20%3D%200%EF%BC%9Bi%20%26lt%3B%20g_capture_num_buffers%EF%BC%9Bi%20%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bbuf%2C%200%2C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(buf))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%BC%93%E5%86%B2%E5%8C%BA.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebuf.index%20%3D%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_QUERYBUF%EF%BC%8C%EF%BC%86buf%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_QUERYBUF%E9%94%99%E8%AF%AF%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E9%95%BF%E5%BA%A6%20%3D%20%E7%BC%93%E5%86%B2%E5%8C%BA.%E9%95%BF%E5%BA%A6%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%20(size_t)%20buf.m.%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.start%20%3D%20mmap%20(NULL%2C%20%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.length%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E4%BF%9D%E6%8A%A4%E8%AF%BB%E5%8F%96%20%7C%20%E4%BF%9D%E6%8A%A4%E5%86%99%E5%85%A5%EF%BC%8C%E6%98%A0%E5%B0%84%E5%85%B1%E4%BA%AB%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efd_capture_v4l%EF%BC%8Ccapture_buffers%5Bi%5D.%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(capture_buffers%5Bi%5D.start%2C%200xFF%2C%20capture_buffers%5Bi%5D.length)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88i%20%3D%200%EF%BC%9Bi%20%26lt%3B%20g_capture_num_buffers%EF%BC%9Bi%20%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bbuf%2C%200%2C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(buf))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%BC%93%E5%86%B2%E5%8C%BA.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebuf.index%20%3D%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebuf.m.%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%20%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_QBUF%EF%BC%8C%26amp%3Bbuf%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22VIDIOC_QBUF%20%E9%94%99%E8%AF%AF%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl%20(fd_capture_v4l%2C%20VIDIOC_STREAMON%2C%20%26amp%3Btype)%20%26lt%3B%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22VIDIOC_STREAMON%20%E9%94%99%E8%AF%AF%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20prepare_output(%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Evoid%3C%2FSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_buffer%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88i%20%3D%200%EF%BC%9Bi%20%26lt%3B%20g_output_num_buffers%EF%BC%9Bi%20%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Boutput_buf%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(output_buf))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eoutput_buf.index%20%3D%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_QUERYBUF%2C%20%26amp%3Boutput_buf)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_QUERYBUF%E9%94%99%E8%AF%AF%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E9%95%BF%E5%BA%A6%20%3D%20%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA.%E9%95%BF%E5%BA%A6%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%20(size_t)%20%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA.m.%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eoutput_buffers%5Bi%5D.start%20%3D%20mmap%20(NULL%2C%20output_buffers%5Bi%5D.length%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E4%BF%9D%E6%8A%A4%E8%AF%BB%E5%8F%96%20%7C%20%E4%BF%9D%E6%8A%A4%E5%86%99%E5%85%A5%EF%BC%8C%E6%98%A0%E5%B0%84%E5%85%B1%E4%BA%AB%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efd_output_v4l%EF%BC%8Coutput_buffers%5Bi%5D.%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88output_buffers%5Bi%5D.%E5%BC%80%E5%A7%8B%3D%3D%20%E7%A9%BA)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9Cv4l2%20tvin%E6%B5%8B%E8%AF%95%EF%BC%9A%E8%BE%93%E5%87%BAmmap%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Ev4l_capture_setup%EF%BC%88%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_capability%E4%B8%8A%E9%99%90%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Estruct%3C%2FSPAN%3E%20v4l2_cropcap%20cropcap%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_crop%20%E8%A3%81%E5%89%AA%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_format%20fmt%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_requestbuffers%E8%AF%B7%E6%B1%82%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_dbg_chip_ident%E8%8A%AF%E7%89%87%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_streamparm%20%E5%8F%82%E6%95%B0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l2_std_id%20id%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%95%B4%E6%95%B0%3C%2FSPAN%3E%E5%88%86%E9%92%9F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_QUERYCAP%EF%BC%8C%EF%BC%86cap%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(EINVAL%20%3D%3D%20errno)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%EF%BC%85s%20%E4%B8%8D%E6%98%AF%20V4L2%20%E8%AE%BE%E5%A4%87%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%EF%BC%85s%20%E4%B8%8D%E6%98%AF%20V4L%20%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%9C%AA%E7%9F%A5%E9%94%99%E8%AF%AF%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%81%EF%BC%88cap.%E8%83%BD%E5%8A%9B%26amp%3BV4L2_CAP_VIDEO_CAPTURE))%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%25s%20%E6%B2%A1%E6%9C%89%E8%A7%86%E9%A2%91%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%5Cn%22%3C%2FSPAN%3E%20%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%81%EF%BC%88cap.%E8%83%BD%E5%8A%9B%26amp%3B%20V4L2_CAP_STREAMING))%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%EF%BC%85s%20%E4%B8%8D%E6%94%AF%E6%8C%81%E6%B5%81%E5%BC%8F%20i%2Fo%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_DBG_G_CHIP_IDENT%EF%BC%8C%EF%BC%86chip%EF%BC%89%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_DBG_G_CHIP_IDENT%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E7%94%B5%E8%A7%86%E8%A7%A3%E7%A0%81%E8%8A%AF%E7%89%87%E4%B8%BA%20%25s%5Cn%22%3C%2FSPAN%3E%20%2C%20chip.match.name)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_capture_v4l%2C%20VIDIOC_S_INPUT%2C%20%26amp%3Bg_input)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_S_INPUT%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_G_STD%EF%BC%8C%EF%BC%86id%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_G_STD%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_current_std%20%3D%20id%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_S_STD%EF%BC%8C%EF%BC%86id%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_S_STD%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E5%9C%A8%E6%AD%A4%E5%A4%84%E9%80%89%E6%8B%A9%E8%A7%86%E9%A2%91%E8%BE%93%E5%85%A5%E3%80%81%E8%A7%86%E9%A2%91%E6%A0%87%E5%87%86%E5%B9%B6%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%E3%80%82%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bcropcap%2C%200%2C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E(cropcap))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecropcap.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl%20(fd_capture_v4l%2C%20VIDIOC_CROPCAP%2C%20%26amp%3Bcropcap)%20%26lt%3B%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%A3%81%E5%89%AA.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecrop.c%20%3D%20cropcap.defrect%3B%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E9%87%8D%E7%BD%AE%E4%B8%BA%E9%BB%98%E8%AE%A4%E5%80%BC%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_S_CROP%EF%BC%8C%EF%BC%86crop%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%BC%80%E5%85%B3%3C%2FSPAN%3E%EF%BC%88errno%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ecase%3C%2FSPAN%3E%20EINVAL%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E4%B8%8D%E6%94%AF%E6%8C%81%E8%A3%81%E5%89%AA%E3%80%82%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%25s%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%E4%B8%8D%E6%94%AF%E6%8C%81%E8%A3%81%E5%89%AA%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ebreak%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E9%BB%98%E8%AE%A4%3C%2FSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E5%BF%BD%E7%95%A5%E9%94%99%E8%AF%AF%E3%80%82%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ebreak%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E5%BF%BD%E7%95%A5%E9%94%99%E8%AF%AF%E3%80%82%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%8F%82%E6%95%B0%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eparm.parm.%E6%8D%95%E8%8E%B7.timeperframe.numerator%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eparm.parm.%E6%8D%95%E8%8E%B7.%E6%AF%8F%E5%B8%A7%E6%97%B6%E9%97%B4.%E5%88%86%E6%AF%8D%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eparm.parm.capture.%E6%8D%95%E8%8E%B7%E6%A8%A1%E5%BC%8F%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_S_PARM%EF%BC%8C%EF%BC%86parm%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_S_PARM%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bfmt%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(fmt))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.type%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E5%AE%BD%E5%BA%A6%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%200%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E9%AB%98%E5%BA%A6%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%200%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.pixelformat%20%3D%20g_fmt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.field%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%20V4L2_FIELD_INTERLACED%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_S_FMT%EF%BC%8C%EF%BC%86fmt%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%EF%BC%85s%20iformat%20%E4%B8%8D%E6%94%AF%E6%8C%81%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E6%B3%A8%E6%84%8F%20VIDIOC_S_FMT%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%94%B9%E5%8F%98%E5%AE%BD%E5%BA%A6%E5%92%8C%E9%AB%98%E5%BA%A6%E3%80%82%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E9%94%99%E8%AF%AF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%81%8F%E6%89%A7%E3%80%82%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emin%20%3D%20fmt.fmt.pix.width%20*%202%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(fmt.fmt.pix.bytesperline%20%26lt%3B%20min)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.bytesperline%20%3D%20min%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emin%20%3D%20fmt.fmt.pix.bytesperline%20*%20fmt.fmt.pix.height%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88fmt.fmt.pix.sizeimage%20%26lt%3B%20min%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.sizeimage%20%3D%20min%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_G_FMT%EF%BC%8C%EF%BC%86fmt%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_G_FMT%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_in_width%20%3D%20fmt.fmt.pix.width%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_in_height%20%3D%20fmt.fmt.pix.height%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Breq%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(req))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%AF%B7%E6%B1%82%E6%95%B0%E9%87%8F%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%20g_capture_num_buffers%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%AF%B7%E6%B1%82%E7%B1%BB%E5%9E%8B%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%89%80%E9%9C%80%E5%86%85%E5%AD%98%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_REQBUFS%EF%BC%8C%26amp%3Breq%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(EINVAL%20%3D%3D%20errno)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%EF%BC%85s%20%E4%B8%8D%E6%94%AF%E6%8C%81%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%5Cn%22%3C%2FSPAN%3E%20%2C%20v4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%EF%BC%85s%20%E4%B8%8D%E6%94%AF%E6%8C%81%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%EF%BC%8C%E6%9C%AA%E7%9F%A5%E9%94%99%E8%AF%AF%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8Cv4l_capture_dev%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%E8%AF%B7%E6%B1%82%E6%95%B0%26lt%3B2%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efprintf%20(stderr%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%25s%5Cn%20%E4%B8%8A%E7%9A%84%E7%BC%93%E5%86%B2%E5%86%85%E5%AD%98%E4%B8%8D%E8%B6%B3%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3Ev4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20v4l_output_setup(%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Evoid%3C%2FSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_control%20ctrl%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_format%20fmt%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_framebuffer%20fb%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Estruct%3C%2FSPAN%3E%20v4l2_cropcap%20cropcap%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_crop%20%E8%A3%81%E5%89%AA%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_capability%E4%B8%8A%E9%99%90%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Estruct%3C%2FSPAN%3E%20v4l2_fmtdesc%20fmtdesc%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_requestbuffers%20buf_req%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%81ioctl%EF%BC%88fd_output_v4l%EF%BC%8CVIDIOC_QUERYCAP%EF%BC%8C%EF%BC%86cap%EF%BC%89%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3D%25s%2C%E5%8D%A1%3D%25s%2C%E6%80%BB%E7%BA%BF%3D%25s%2C%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%E7%89%88%E6%9C%AC%3D0x%2508x%EF%BC%8C%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%E5%8A%9F%E8%83%BD%3D0x%2508x%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%8F%B8%E6%9C%BA%E7%AB%AF%E3%80%81%E5%8D%A1%E7%AB%AF%E3%80%81%E6%80%BB%E7%BA%BF%E4%BF%A1%E6%81%AF%E7%AB%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecap.version%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%83%BD%E5%8A%9B)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmtdesc.index%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmtdesc.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%BD%93%3C%2FSPAN%3E%EF%BC%88%EF%BC%81ioctl%EF%BC%88fd_output_v4l%EF%BC%8CVIDIOC_ENUM_FMT%EF%BC%8C%EF%BC%86fmtdesc%EF%BC%89%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%A0%BC%E5%BC%8F%EF%BC%85s%EF%BC%9Afourcc%20%3D%200x%EF%BC%8508x%5Cn%22%3C%2FSPAN%3E%20%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmtdesc.%E6%8F%8F%E8%BF%B0%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmtdesc.pixelformat)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmtdesc.index%2B%2B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bcropcap%2C%200%2C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E(cropcap))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecropcap.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_CROPCAP%2C%20%26amp%3Bcropcap)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%8E%B7%E5%8F%96%E8%A3%81%E5%89%AA%E5%8A%9F%E8%83%BD%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%A3%81%E5%89%AA.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecrop.c.top%20%3D%20g_display_top%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecrop.c.left%20%3D%20g_display_left%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ecrop.c.%E5%AE%BD%E5%BA%A6%20%3D%20g_display_width%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%A3%81%E5%89%AA.c.%E9%AB%98%E5%BA%A6%20%3D%20g_display_height%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_S_CROP%2C%20%26amp%3Bcrop)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%E8%A3%81%E5%89%AA%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F%2F%20Set%20rotation%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.id%20%3D%20V4L2_CID_ROTATE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.%E5%80%BC%3Dg_rotate%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_S_CTRL%2C%20%26amp%3Bctrl)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20ctrl%20%E6%97%8B%E8%BD%AC%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.id%20%3D%20V4L2_CID_VFLIP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.%E5%80%BC%3Dg_vflip%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_S_CTRL%2C%20%26amp%3Bctrl)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20ctrl%20vflip%20%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.id%20%3D%20V4L2_CID_HFLIP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.%E5%80%BC%3Dg_hflip%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_S_CTRL%2C%20%26amp%3Bctrl)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20ctrl%20hflip%20%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88g_vdi_enable%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.id%20%3D%20V4L2_CID_MXC_MOTION%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ectrl.%E5%80%BC%3Dg_vdi_motion%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_S_CTRL%2C%20%26amp%3Bctrl)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AEctrl%E5%8A%A8%E4%BD%9C%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efb.%E6%A0%87%E5%BF%97%20%3D%20V4L2_FBUF_FLAG_OVERLAY%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3Eioctl%EF%BC%88fd_output_v4l%EF%BC%8CVIDIOC_S_FBUF%EF%BC%8C%EF%BC%86fb%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bfmt%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(fmt))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E5%AE%BD%E5%BA%A6%3D%E5%AE%BD%E5%BA%A6%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E9%AB%98%E5%BA%A6%3D%E9%AB%98%E5%BA%A6%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.pixelformat%20%3D%20g_fmt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.bytesperline%20%3D%20g_in_width%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.priv%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.sizeimage%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88g_tb%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E5%9C%BA%20%3D%20V4L2_FIELD_INTERLACED_TB%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E5%9C%BA%20%3D%20V4L2_FIELD_INTERLACED_BT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F%2F%E9%81%BF%E5%85%8D%E6%98%BE%E7%A4%BA%E6%97%B6%E5%8E%BB%E9%9A%94%E8%A1%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Efmt.fmt.pix.%E5%9C%BA%20%3D%20V4L2_FIELD_NONE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_S_FMT%2C%20%26amp%3Bfmt)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%E6%A0%BC%E5%BC%8F%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_G_FMT%2C%20%26amp%3Bfmt)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%8E%B7%E5%8F%96%E6%A0%BC%E5%BC%8F%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_frame_size%20%3D%20fmt.fmt.pix.sizeimage%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bbuf_req%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(buf_req))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebuf_req.count%20%3D%20g_output_num_buffers%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebuf_req.%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ebuf_req.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_REQBUFS%2C%20%26amp%3Bbuf_req)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AF%B7%E6%B1%82%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3E%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Emxc_v4l_tvin_test(%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Evoid%3C%2FSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Ev4l2_buffer%20%E6%8D%95%E8%8E%B7_buf%EF%BC%8C%E8%BE%93%E5%87%BA_buf%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ev4l2_std_id%20id%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20i%2C%20j%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eenum%3C%2FSPAN%3E%20v4l2_buf_type%20type%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%E6%80%BB%E6%97%B6%E9%97%B4%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3E%E6%97%B6%E9%97%B4%E5%80%BC%20tv_start%E3%80%81tv_current%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(prepare_output()%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22prepare_output%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88start_capturing%EF%BC%88%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E5%90%AF%E5%8A%A8%E6%8D%95%E8%8E%B7%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%8E%B7%E5%8F%96%E6%97%B6%E9%97%B4%EF%BC%88%26amp%3Btv_start%EF%BC%8C0%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%20%25ds%2C%20%25d%20us%5Cn%22%3C%2FSPAN%3E%20%2C%20(%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eunsigned%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20)%20tv_start.tv_sec%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%EF%BC%88%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E6%95%B4%E6%95%B0%3C%2FSPAN%3E%EF%BC%89tv_start.tv_usec%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Efor%3C%2FSPAN%3E%20(i%20%3D%200%3B%20%3B%20i%2B%2B)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Ebegin%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_G_STD%EF%BC%8C%26amp%3Bid%EF%BC%89%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_G_STD%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88id%20%3D%3D%20g_current_std%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BD%AC%E5%88%B0%3C%2FSPAN%3E%E4%B8%8B%E4%B8%80%E4%B8%AA%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(id%20%3D%3D%20V4L2_STD_PAL%20%7C%7C%20id%20%3D%3D%20V4L2_STD_NTSC)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eioctl(fd_output_v4l%2C%20VIDIOC_STREAMOFF%2C%20%26amp%3Btype)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eioctl(fd_capture_v4l%2C%20VIDIOC_STREAMOFF%2C%20%26amp%3Btype)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88j%20%3D%200%EF%BC%9Bj%20%26lt%3B%20g_output_num_buffers%EF%BC%9Bj%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emunmap(%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5Bj%5D.%E5%BC%80%E5%A7%8B%EF%BC%8C%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5Bj%5D.%E9%95%BF%E5%BA%A6)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88j%20%3D%200%EF%BC%9Bj%20%26lt%3B%20g_capture_num_buffers%EF%BC%9Bj%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emunmap(%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bj%5D.%E5%BC%80%E5%A7%8B%EF%BC%8C%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5Bj%5D.%E9%95%BF%E5%BA%A6)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88v4l_capture_setup%EF%BC%88%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20v4l%20%E6%8D%95%E8%8E%B7%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(v4l_output_setup()%20%26lt%3B%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20v4l%20%E8%BE%93%E5%87%BA%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(prepare_output()%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22prepare_output%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88start_capturing%EF%BC%88%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E5%90%AF%E5%8A%A8%E6%8D%95%E8%8E%B7%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%88%91%EF%BC%9D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E7%94%B5%E8%A7%86%E6%A0%87%E5%87%86%E5%B7%B2%E6%9B%B4%E6%94%B9%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%9D%A1%E7%9C%A0%EF%BC%881%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_G_STD%EF%BC%8C%26amp%3Bid%EF%BC%89%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_G_STD%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(id%20!%3D%20V4L2_STD_ALL)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Egoto%3C%2FSPAN%3E%20begin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%97%A0%E6%B3%95%E6%A3%80%E6%B5%8B%E7%94%B5%E8%A7%86%E6%A0%87%E5%87%86%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E4%B8%8B%E4%B8%80%E4%B8%AA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Bcapture_buf%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(capture_buf))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_DQBUF%EF%BC%8C%EF%BC%86capture_buf%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_DQBUF%20%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememset(%26amp%3Boutput_buf%EF%BC%8C%200%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Esizeof%3C%2FSPAN%3E%20(output_buf))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88i%20%26lt%3B%20g_output_num_buffers%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eoutput_buf.index%20%3D%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_QUERYBUF%2C%20%26amp%3Boutput_buf)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_QUERYBUF%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA.%E5%86%85%E5%AD%98%20%3D%20V4L2_MEMORY_MMAP%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_DQBUF%2C%20%26amp%3Boutput_buf)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_DQBUF%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ememcpy%EF%BC%88output_buffers%5Boutput_buf.index%5D.start%EF%BC%8C%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA%5B%E6%8D%95%E8%8E%B7%E7%BC%93%E5%86%B2%E5%8C%BA.%E7%B4%A2%E5%BC%95%5D.%E5%BC%80%E5%A7%8B%EF%BC%8Cg_%E5%B8%A7%E5%A4%A7%E5%B0%8F%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_capture_v4l%EF%BC%8CVIDIOC_QBUF%EF%BC%8C%EF%BC%86capture_buf%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_QBUF%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eoutput_buf.timestamp.tv_sec%20%3D%20tv_start.tv_sec%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eoutput_buf.timestamp.tv_usec%3D%20tv_start.tv_usec%2B%EF%BC%88g_frame_period%20*%20i%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_QBUF%2C%20%26amp%3Boutput_buf)%20%26lt%3B%200)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9CVIDIOC_QBUF%E5%A4%B1%E8%B4%A5%5Cn%E2%80%9D%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(i%20%3D%3D%201)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(ioctl(fd_output_v4l%2C%20VIDIOC_STREAMON%2C%20%26amp%3Btype)%20%26lt%3B%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E6%B5%81%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E8%8E%B7%E5%8F%96%E6%97%B6%E9%97%B4%EF%BC%88%26amp%3Btv_current%EF%BC%8C0%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Etotal_time%20%3D%20(tv_current.tv_sec%20-%20tv_start.tv_sec)%20*%201000000L%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%80%BB%E6%97%B6%E9%97%B4%20%2B%3D%20tv_current.tv_usec%20-%20tv_start.tv_usec%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%25u%20%E5%B8%A7%E7%9A%84%E6%80%BB%E6%97%B6%E9%97%B4%20%3D%20%25u%20us%20%3D%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%EF%BC%85lld%20fps%20%5Cn%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8Ci%EF%BC%8C%E6%80%BB%E6%97%B6%E9%97%B4%EF%BC%8C%EF%BC%88i%20*%201000000ULL%EF%BC%89%2F%E6%80%BB%E6%97%B6%E9%97%B4%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eprocess_cmdline%EF%BC%88%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20argc%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Echar%3C%2FSPAN%3E%20**argv%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20vi_set%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20vo_set%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Efor%3C%2FSPAN%3E%20(i%20%3D%201%3B%20i%20%26lt%3B%20argc%3B%20i%2B%2B)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-ow%22%3C%2FSPAN%3E%20)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_display_width%20%3D%20atoi(argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%90%A6%E5%88%99%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88strcmp%EF%BC%88argv%5Bi%5D%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-oh%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%89%3D%3D%200%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_display_height%20%3D%20atoi(argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%90%A6%E5%88%99%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88strcmp%EF%BC%88argv%5Bi%5D%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-ot%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%89%3D%3D0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_display_top%20%3D%20atoi(argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-ol%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_display_left%20%3D%20atoi(argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%90%A6%E5%88%99%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88strcmp%EF%BC%88argv%5Bi%5D%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-r%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%89%3D%3D%200%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_rotate%20%3D%20atoi(argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-f%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E6%88%91%2B%2B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3Eg_fmt%20%3D%20v4l2_fourcc(argv%5Bi%5D%5B0%5D%2C%20argv%5Bi%5D%5B1%5D%2Cargv%5Bi%5D%5B2%5D%2Cargv%5Bi%5D%5B3%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20((g_fmt%20!%3D%20V4L2_PIX_FMT_NV12)%20%26amp%3B%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(g_fmt%20!%3D%20V4L2_PIX_FMT_UYVY)%20%26amp%3B%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(g_fmt%20!%3D%20V4L2_PIX_FMT_YUYV)%20%26amp%3B%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(g_fmt%20!%3D%20V4L2_PIX_FMT_YUV420))%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E6%A0%BC%E5%BC%8F%EF%BC%9AUYVY%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-vi%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Estrcat(v4l_capture_dev%2C%20argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Evi_set%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-vo%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Estrcat(v4l_output_dev%2C%20argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Evo_set%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-dv%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_input%20%3D%201%3B%20%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F%2F%20%E8%BF%94%E5%9B%9E%E2%80%9CCSI%20MEM%E2%80%9D%E8%80%8C%E4%B8%8D%E6%98%AF%E2%80%9CCSI%20VDI%20MEM%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-m%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_vdi_%E5%90%AF%E7%94%A8%3D1%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_vdi_motion%20%3D%20atoi(argv%5B%2B%2Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-tb%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eg_tb%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eelse%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(strcmp(argv%5Bi%5D%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22-help%22%3C%2FSPAN%3E)%20%3D%3D%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22MXC%20Video4Linux%20TV%20%E6%B5%8B%E8%AF%95%E4%B8%AD%5Cn%5Cn%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%E8%AF%AD%E6%B3%95%EF%BC%9Amxc_v4l2_tvin.out%5Cn%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%20-ow%3CCAPTURE%20display%3D%22%22%20width%3D%22%22%3E%20%5Cn%E2%80%9D%3C%2FCAPTURE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%20-oh%20%3CCAPTURE%20display%3D%22%22%20height%3D%22%22%3E%5Cn%22%3C%2FCAPTURE%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-ot%3CDISPLAY%20top%3D%22%22%3E%20%5Cn%E2%80%9D%3C%2FDISPLAY%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%20-ol%20%3CDISPLAY%20left%3D%22%22%3E%5Cn%22%3C%2FDISPLAY%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%20-r%3CROTATION%3E%20-c%3CCAPTURE%20counter%3D%22%22%3E%20%5Cn%E2%80%9D%3C%2FCAPTURE%3E%3C%2FROTATION%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-m%3CMOTION%3E%200%EF%BC%9A%E4%B8%AD%201%EF%BC%9A%E4%BD%8E%202%EF%BC%9A%E9%AB%98%EF%BC%8C0-%E9%BB%98%E8%AE%A4%5Cn%E2%80%9D%3C%2FMOTION%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-vi%20%3CCAPTURE_NUM%3E%20%E4%BD%BF%E7%94%A8%E6%8D%95%E8%8E%B7%20%2Fdev%2Fvideo%3CCAPTURE_NUM%3E%5Cn%E2%80%9D%3C%2FCAPTURE_NUM%3E%3C%2FCAPTURE_NUM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%20-vo%20%3COUTPUT_NUM%3E%20%E4%BD%BF%E7%94%A8%E8%BE%93%E5%87%BA%20%2Fdev%2Fvideo%3COUTPUT_NUM%3E%5Cn%E2%80%9D%3C%2FOUTPUT_NUM%3E%3C%2FOUTPUT_NUM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C-dv%20%E7%A6%81%E7%94%A8%20VDI%5Cn%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%E2%80%9C%20-tb%20%E9%A1%B6%E5%9C%BA%E4%BC%98%E5%85%88%EF%BC%8C%E5%BA%95%E5%9C%BA%E4%BC%98%E5%85%88-%E9%BB%98%E8%AE%A4%5Cn%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%20-f%20%20%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%81vi_set%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Estrcat(v4l_capture_dev%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%220%22%3C%2FSPAN%3E%20)%3B%20%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F%2F%20%E4%BD%BF%E7%94%A8%20%2Fdev%2Fvideo0%20%E4%BD%9C%E4%B8%BA%E9%BB%98%E8%AE%A4%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(!vo_set)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Estrcat(v4l_output_dev%2C%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%2216%22%3C%2FSPAN%3E%20)%3B%20%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F%2F%20%E4%BD%BF%E7%94%A8%20%2Fdev%2Fvideo16%20%E4%BD%9C%E4%B8%BA%E9%BB%98%E8%AE%A4%E8%BE%93%E5%87%BA%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E((g_display_width%20%3D%3D%200)%20%7C%7C%20(g_display_height%20%3D%3D%200))%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%98%BE%E7%A4%BA%E5%AE%BD%E5%BA%A6%E6%88%96%E9%AB%98%E5%BA%A6%E4%B8%BA%E9%9B%B6%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3Emain(%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20argc%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Echar%3C%2FSPAN%3E%20**argv)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Echar%3C%2FSPAN%3E%20fb_device%5B100%5D%20%3D%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%2Fdev%2Ffb0%22%3C%2FSPAN%3E%20%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eint%3C%2FSPAN%3E%20fd_fb%20%3D%200%2C%20i%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E7%BB%93%E6%9E%84%3C%2FSPAN%3Emxcfb_gbl_alpha%20alpha%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eenum%3C%2FSPAN%3E%20v4l2_buf_type%20type%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88process_cmdline%EF%BC%88argc%EF%BC%8Cargv%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%88fd_capture_v4l%20%3D%20%E6%89%93%E5%BC%80%EF%BC%88v4l_capture_dev%EF%BC%8CO_RDWR%EF%BC%8C0%EF%BC%89%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20%25s%5Cn%22%3C%2FSPAN%3E%20%2C%20v4l_capture_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%88fd_output_v4l%20%3D%E6%89%93%E5%BC%80%EF%BC%88v4l_output_dev%EF%BC%8CO_RDWR%EF%BC%8C0%EF%BC%89%EF%BC%89%26lt%3B0%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20%25s%5Cn%22%3C%2FSPAN%3E%20%2C%20v4l_output_dev)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88v4l_capture_setup%EF%BC%88%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20v4l%20%E6%8D%95%E8%8E%B7%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Eif%3C%2FSPAN%3E%20(v4l_output_setup()%20%26lt%3B%200)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%20v4l%20%E8%BE%93%E5%87%BA%E5%A4%B1%E8%B4%A5%E3%80%82%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88%EF%BC%88fd_fb%20%3D%20%E6%89%93%E5%BC%80%EF%BC%88fb_device%EF%BC%8CO_RDWR%EF%BC%89%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20green%3B%22%3E%2F*%20%E8%A6%86%E7%9B%96%E8%AE%BE%E7%BD%AE%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ealpha.alpha%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Ealpha.%E5%90%AF%E7%94%A8%3D1%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%EF%BC%88ioctl%EF%BC%88fd_fb%EF%BC%8CMXCFB_SET_GBL_ALPHA%EF%BC%8C%CE%B1%EF%BC%89%26lt%3B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eprintf(%20%3CSPAN%20style%3D%22color%3A%20%23a31515%3B%22%3E%22%E8%AE%BE%E7%BD%AE%E5%85%A8%E5%B1%80%20alpha%20%E5%A4%B1%E8%B4%A5%5Cn%22%3C%2FSPAN%3E%20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_fb%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3ETFAIL%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emxc_v4l_tvin_test()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_OUTPUT%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eioctl(fd_output_v4l%2C%20VIDIOC_STREAMOFF%2C%20%26amp%3Btype)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E7%B1%BB%E5%9E%8B%20%3D%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Eioctl(fd_capture_v4l%2C%20VIDIOC_STREAMOFF%2C%20%26amp%3Btype)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88i%20%3D%200%EF%BC%9Bi%20%26lt%3B%20g_output_num_buffers%EF%BC%9Bi%20%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emunmap(%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E5%BC%80%E5%A7%8B%EF%BC%8C%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%5Bi%5D.%E9%95%BF%E5%BA%A6)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%EF%BC%88i%20%3D%200%EF%BC%9Bi%20%26lt%3B%20g_capture_num_buffers%EF%BC%9Bi%20%2B%2B%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3Emunmap%EF%BC%88capture_buffers%5Bi%5D.start%EF%BC%8Ccapture_buffers%5Bi%5D.length%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_capture_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_output_v4l%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E5%85%B3%E9%97%AD%EF%BC%88fd_fb%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22mso-spacerun%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20blue%3B%22%3Ereturn%3C%2FSPAN%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%20mso-layout-grid-align%3A%20none%3B%20text-autospace%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%BF%B0%E8%A1%A5%E4%B8%81%E7%8E%B0%E5%B7%B2%E5%8F%91%E5%B8%83%E4%B8%80%E5%B9%B4%E5%A4%9A%E4%BA%86%EF%BC%8C%E5%B9%B6%E4%B8%94%E2%80%9C%E4%B8%8D%E6%98%AF%E5%AE%98%E6%96%B9%E4%BA%A4%E4%BB%98%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E4%B8%8D%E4%BF%9D%E8%AF%81%E6%94%AF%E6%8C%81%E8%AF%A5%E4%BB%A3%E7%A0%81%E2%80%9D%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E9%92%88%E5%AF%B9%20i.MX6%20%E7%9A%84%E2%80%9C%E5%AE%98%E6%96%B9%E4%BA%A4%E4%BB%98%E2%80%9D%E8%A7%86%E9%A2%91%E5%8E%BB%E9%9A%94%E8%A1%8C%E5%99%A8%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20PAL%20%E6%91%84%E5%83%8F%E6%9C%BA%E8%BE%93%E5%85%A5%E6%B5%8B%E8%AF%95%E4%BA%86%E8%A1%A5%E4%B8%81%EF%BC%8C%E4%BD%86%E5%AF%B9%E7%BB%93%E6%9E%9C%E5%B9%B6%E4%B8%8D%E5%AE%8C%E5%85%A8%E6%BB%A1%E6%84%8F%EF%BC%88%E7%94%B1%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F363529%22%20target%3D%22_blank%22%3Ei.MX6%20PAL%20%E5%8E%BB%E9%9A%94%E8%A1%8C%E5%99%A8%E5%B7%A5%E4%BB%B6%3C%2FA%3E%E6%98%BE%E7%A4%BA%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%9C%A8%202%20%E4%B8%AA%20CSI%20%E7%9A%84%E6%AF%8F%E4%B8%AA%20CSI%20%E7%9A%84%20gstreamer%20%E7%AE%A1%E9%81%93%E4%B8%AD%E8%BF%90%E8%A1%8C%E7%9A%84%E8%A1%A5%E4%B8%81%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E6%B5%81%E9%87%8F%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E7%A8%B3%E5%AE%9A%EF%BC%8C%E9%82%A3%E4%B9%88%E5%AE%83%E5%B0%B1%E4%B8%8D%E7%AC%A6%E5%90%88%E9%A2%9D%E5%A4%96%E7%9A%84%E6%B5%81%E9%87%8F%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%2080Mb%2Fs%20%E4%BC%A0%E5%85%A5%20%2B%2050Mb%2Fs%20%E4%BC%A0%E5%87%BA%20%2B%20SATA%20100Mb%2Fs%20%E4%BC%A0%E5%87%BA%EF%BC%89%EF%BC%9A%E5%AE%83%E9%80%9A%E5%B8%B8%E8%BF%90%E8%A1%8C%E4%B8%8D%E5%88%B0%E4%B8%80%E4%B8%AA%E5%B0%8F%E6%97%B6%E5%B0%B1%E4%BC%9A%E7%BB%93%E6%9D%9F%EF%BC%8C%E7%84%B6%E5%90%8E%20DMA%20%E9%80%9A%E9%81%93%E7%B9%81%E5%BF%99%E8%80%8C%E6%97%A0%E6%B3%95%E9%87%8A%E6%94%BE%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E7%BB%88%E6%AD%A2%E8%AF%A5%E8%BF%9B%E7%A8%8B%EF%BC%8C%E5%8F%AA%E6%9C%89%E9%87%8D%E7%BD%AE%E6%89%8D%E8%83%BD%E4%BD%BF%E5%85%B6%E6%81%A2%E5%A4%8D%EF%BC%81%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E9%80%9A%E5%B8%B8%E6%98%AF%E5%9B%A0%E4%B8%BA%E5%9C%A8%20VDI%20%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%88%B0%E4%BA%86%E6%BA%A2%E5%87%BA%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20Warning%20-%20IPU_INT_STAT_5%20%3D%200x00000500%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20Warning%20-%20IPU_INT_STAT_9%20%3D%200x00000001%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_dqueue%20%E8%B6%85%E6%97%B6%20enc_counter%200%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E...%20%E6%88%96%E8%80%85%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20Warning%20-%20IPU_INT_STAT_5%20%3D%200x00000400%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20Warning%20-%20IPU_INT_STAT_5%20%3D%200x00000400%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Av4l2%20%E6%8D%95%E8%8E%B7%EF%BC%9Amxc_v4l_dqueue%20%E8%B6%85%E6%97%B6%20enc_counter%200%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E5%A6%82%E4%B8%8B%E7%AE%A1%E9%81%93%E6%B5%8B%E8%AF%95%E4%BA%86%20gstreamer%20%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8E%BB%E9%9A%94%E8%A1%8C%E5%99%A8%EF%BC%88%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8F%92%E4%BB%B6%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst%E5%90%AF%E5%8A%A8-v--gst%E8%B0%83%E8%AF%95%3D2-e%20mfw_v4lsrc%E8%AE%BE%E5%A4%87%3D%2Fdev%2Fvideo0%20fps-n%3D25%EF%BC%81%E5%8E%BB%E9%9A%94%E8%A1%8C%EF%BC%81vpuenc%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3Davc%20%E5%B8%A7%E9%80%9F%E7%8E%87-nu%3D25%20%E6%AF%94%E7%89%B9%E7%8E%87%3D4194304%EF%BC%81rtph264%E6%94%AF%E4%BB%98%EF%BC%81udpsink%20sync%3Dfalse%20-v%20%E4%B8%BB%E6%9C%BA%3D10.100.57.5%20%E7%AB%AF%E5%8F%A3%3D5000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8D%B3%E4%BD%BF%E4%B8%BA%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8F%92%E4%BB%B6%E6%8C%87%E5%AE%9A%E5%85%B6%E4%BB%96%E7%B1%BB%E5%9E%8B%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%82%E6%95%B0%EF%BC%88tomsmocomp%20%2F%20greedyh%20%2F%20greedyl%20%2F%20linear%20%2F%20scalerbob%EF%BC%89%EF%BC%8C%E5%AE%83%E4%B9%9F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E9%80%82%E5%90%88%E6%88%91%E4%BB%AC%E7%9A%84%20i.MX6%20%E5%B9%B3%E5%8F%B0%E7%9A%84%E5%8F%AF%E6%8E%A5%E5%8F%97%E7%9A%84%E5%8E%BB%E9%9A%94%E8%A1%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E5%B9%B6%E4%B8%94%E9%9D%9E%E5%B8%B8%E5%A4%B1%E6%9C%9B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%81%9A%E4%B8%80%E9%A1%B9%E5%85%B3%E4%BA%8E%E5%9C%A8%20imx6%20%E4%B8%8A%E6%8D%95%E6%8D%89%E8%A7%86%E9%A2%91%E7%9A%84%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E4%BA%86%E6%82%A8%E5%85%B3%E4%BA%8E%E5%8E%BB%E9%9A%94%E8%A1%8C%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E6%9C%8D%E5%8A%A1%E5%99%A8%E9%97%AE%E9%A2%98%E3%80%82MEM_VDI_PRP_VF_MEM%E3%80%81MEM_VDI_PRP_VF_MEM_P%E3%80%81MEM_VDI_PRP_VF_MEM_N%3C%2FP%3E%3CP%3E%E9%80%9A%E9%81%93%E8%A2%AB%E8%BE%93%E9%80%81%E5%88%B0VDIC%EF%BC%9F%E6%88%91%E7%90%86%E8%A7%A3%E8%B7%AF%E5%BE%84%E6%98%AFCSI-%26gt%3BMEM%EF%BC%8C%E7%84%B6%E5%90%8E%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E4%BB%8EMEM-%26gt%3BVDIC-%26gt%3BIC-%26gt%3BMEM%E8%BE%93%E9%80%81%E3%80%82%E6%9C%89%E4%B8%89%E4%B8%AA%E5%AD%97%E6%AE%B5%E6%95%B0%E6%8D%AE%EF%BC%8Cf(n-1)%2Cf(n)%2Cf(n%2B1)%EF%BC%8C%E5%88%86%E5%88%AB%E6%B5%81%E5%85%A5%E4%B8%8A%E9%9D%A2%E7%9A%84%E4%B8%89%E4%B8%AA%E9%80%9A%E9%81%93%E3%80%82%E6%82%A8%E8%A7%89%E5%BE%97%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E5%AF%B9%E5%90%97%EF%BC%9F%E7%8E%B0%E5%9C%A8%E6%88%91%E7%9A%84%E8%A7%86%E9%A2%91%E6%95%B0%E6%8D%AE%E8%B4%A8%E9%87%8F%E4%B8%8D%E5%A4%AA%E5%A5%BD%EF%BC%8C%E6%98%AF%E5%8E%BB%E9%9A%94%E8%A1%8C%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%A0%E6%84%9F%E5%99%A8%E4%B8%BAtvp5151%EF%BC%8C%E6%95%B0%E6%8D%AE%E6%A0%BC%E5%BC%8F%E4%B8%BAbt656%EF%BC%88YCbCr4%3A2%3A2%E9%9A%94%E8%A1%8C%E6%89%AB%E6%8F%8F%EF%BC%89%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%BA7%E8%8B%B1%E5%AF%B824%E4%BD%8D%E6%B6%B2%E6%99%B6%E6%98%BE%E7%A4%BA%E5%B1%8F%3C%2FP%3E%3CP%3E%E6%83%B3%E4%BD%A0%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FPhilip_FSL%22%20target%3D%22_blank%22%3EPhilip_FSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%BF%B0%3CSPAN%20style%3D%22color%3A%20%233778c7%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23fdfdfd%3B%22%3Eadd-csi-deinterlace-capture.patch.zip%3C%2FSPAN%3E%E8%A1%A5%E4%B8%81%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E5%8E%BB%E9%9A%94%E8%A1%8C%20PAL%20%E6%A0%BC%E5%BC%8F%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%20BSP%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E8%A1%A5%E4%B8%81%EF%BC%8C%E5%B9%B6%E4%B8%94%20NTSC%20%E5%9C%A8%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%A0%BC%E5%BC%8F%E4%B8%8B%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20PAL%20%E6%97%B6%EF%BC%8C%E6%88%91%E6%8D%95%E8%8E%B7%E7%9A%84%E5%9B%BE%E5%83%8F%E7%BC%BA%E5%B0%91%E4%BA%86%E4%B8%80%E5%B0%8F%E9%83%A8%E5%88%86%E9%A1%B6%E9%83%A8%E3%80%82%E5%B0%BD%E7%AE%A1%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8E%A7%E5%88%B6%E6%BB%9A%E5%8A%A8%EF%BC%8C%E7%94%9A%E8%87%B3%E6%8E%A7%E5%88%B6%E5%9B%BE%E5%83%8F%E4%BB%A5%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%A2%9C%E8%89%B2%E5%91%88%E7%8E%B0%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E4%BD%BF%E6%8D%95%E8%8E%B7%E5%9B%BE%E5%83%8F%E7%9A%84%E9%A1%B6%E9%83%A8%E5%8F%98%E5%BE%97%E6%AD%A3%E7%A1%AE%E3%80%82%E5%90%8C%E4%B8%80%E6%8D%95%E8%8E%B7%E5%9B%BE%E5%83%8F%E7%9A%84%E5%BA%95%E9%83%A8%E5%92%8C%E4%BE%A7%E9%9D%A2%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%98%BF%E5%90%89%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3EBSP%EF%BC%9AL3.0.35_4.0.0%3CBR%20%2F%3E%3CBR%20%2F%3ECVBS%20PAL%2FNTSC%20%E8%A7%86%E9%A2%91%E8%BE%93%E5%85%A5%E5%88%B0%E8%A7%86%E9%A2%91%E8%A7%A3%E7%A0%81%E5%99%A8%20ADV7180%EF%BC%8CADV7180%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20I.MX6Q%20CSI%20BT656%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8E%BB%E9%9A%94%E8%A1%8C%E5%8A%9F%E8%83%BD%E5%B7%B2%E8%AE%BE%E7%BD%AE%EF%BC%8C%E4%BD%86%E8%B4%A8%E9%87%8F%E4%B8%8D%E4%BD%B3%E3%80%82%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%89%80%E9%99%84%E7%9A%84%E5%9B%BE%E7%89%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E6%8C%89%E7%85%A7%20I.MX6Q%20%2B%20ADV7180%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E5%B0%86%E6%96%87%E4%BB%B6%E4%BF%AE%E8%A1%A5%E5%88%B0%E5%86%85%E6%A0%B8%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93633%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93633%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20black%3B%22%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%9F%90%E4%BA%9B%E7%BA%BF%E7%A8%8B%E5%B7%B2%E7%BB%8F%E5%8D%A0%E7%94%A8%E4%BA%86%20ipu%20%E4%BB%BB%E5%8A%A1%201%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20black%3B%22%3E%E8%BF%99%E4%B8%AA%E8%A1%A5%E4%B8%81%E6%88%91%E4%B9%8B%E5%89%8D%E5%9C%A8imx53%E5%B9%B3%E5%8F%B0%E4%B8%8A%E7%94%A8%E8%BF%87%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%20mxc_v4l2_tvin%20%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eroot%40freescale%20~%24%20.%2Fmxc_v4l2_tvin-ow%20720%20-oh%20480%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E4%BF%AE%E5%A4%8D-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AFPALTV%E8%A7%A3%E7%A0%81%E8%8A%AF%E7%89%87%E6%98%AFadv7180_decodeFIXME-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Er%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%20%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3EIn%20mxc_v4l2_s_std%20ff%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Erawdata0%3A%200x00%2C%20rawdata1%3A%200x00%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E4%BF%AE%E5%A4%8D-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%20PALVIDIOC_G_FMT%20%E5%A4%B1%E8%B4%A5%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3Dmxc_vout%EF%BC%8C%E5%8D%A1%3DDISP3%20FG%EF%BC%8C%E6%80%BB%E7%BA%BF%3D%EF%BC%8C%E7%89%88%E6%9C%AC%3D0x00000000%EF%BC%8C%E5%8A%9F%E8%83%BD%3D0x04000002%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20RGB565%3A%20fourcc%20%3D%200x50424752%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20BGR24%3A%20fourcc%20%3D%200x33524742%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20RGB24%3A%20fourcc%20%3D%200x33424752%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20RGB32%3A%20fourcc%20%3D%200x34424752%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20BGR32%3A%20fourcc%20%3D%200x34524742%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20NV12%3A%20fourcc%20%3D%200x3231564e%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E6%A0%BC%E5%BC%8F%E5%8C%96%20UYVY%3A%20fourcc%20%3D%200x59565955%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E6%A0%BC%E5%BC%8F%E5%8C%96%20YUYV%3A%20fourcc%20%3D%200x56595559%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20YUV422%20%E5%B9%B3%E9%9D%A2%EF%BC%9Afourcc%20%3D%200x50323234%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20YUV444%3A%20fourcc%20%3D%200x34343459%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20YUV420%3A%20fourcc%20%3D%200x32315559%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E6%A0%BC%E5%BC%8F%20YVU420%3A%20fourcc%20%3D%200x32315659%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20TILED%20NV12P%3A%20fourcc%20%3D%200x50564e54%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20TILED%20NV12F%3A%20fourcc%20%3D%200x46564e54%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Efmt%20YUV444%20%E5%B9%B3%E9%9D%A2%EF%BC%9Afourcc%20%3D%200x50343434%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3EUYVY%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20Warning%20-%20IPU_INT_STAT_10%20%3D%200x00000001%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9AIDMAC21%20%E7%9A%84%20EBA0%20%E4%B8%8D%E6%98%AF%208%20%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%E7%9A%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9AIDMAC21%20%E7%9A%84%20EBA1%20%E4%B8%8D%E6%98%AF%208%20%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%E7%9A%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%20%3D%20473%20%E7%A7%92%EF%BC%8C145035%20usFIXME-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%20%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20Warning%20-%20IPU_INT_STAT_10%20%3D%200x00000001%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E4%BF%AE%E5%A4%8D-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%20%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Emc_pfuze%201-0008%EF%BC%9A%E6%8E%A5%E6%94%B6%E5%A4%B1%E8%B4%A5%EF%BC%81%EF%BC%9A-5%EF%BC%8Cbf%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E6%97%A0%E6%B3%95%E8%AE%BE%E7%BD%AE%20GP%20%E7%94%B5%E5%8E%8B%EF%BC%81%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E4%BF%AE%E5%A4%8D-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%5B0xbfcd7200-no%3A0x220%5Dipu%20task_id%3A1%20busy!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%5B0xbfcd7200%5D%20no-0x220%20state%3A%20ipu%20busy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%20%5B0xbfcd7200%5D%20no-0x220%2Cstate%208%3A%20ipu%20busy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%20%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%20no-0x220%2Cipu_queue_task%20err%3A-125%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9A%E6%98%BE%E7%A4%BA%E5%B7%A5%E4%BD%9C%E5%A4%B1%E8%B4%A5ret%20%3D%20-125%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E4%BF%AE%E5%A4%8D-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%5B0xbfcd7400-no%3A0x230%5Dipu%20task_id%3A1%20busy!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%5B0xbfcd7400%5D%20no-0x230%20state%3A%20ipu%20busy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%20%5B0xbfcd7400%5D%20no-0x230%2Cstate%208%3A%20ipu%20busy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%20%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%20no-0x230%2Cipu_queue_task%20err%3A-125%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9A%E6%98%BE%E7%A4%BA%E5%B7%A5%E4%BD%9C%E5%A4%B1%E8%B4%A5ret%20%3D%20-125%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E4%BF%AE%E5%A4%8D-------ioctl_g_fmt_cap%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%5B0xba25e600-no%3A0x240%5Dipu%20task_id%3A1%20busy!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%5B0xba25e600%5D%20no-0x240%20state%3A%20ipu%20busy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%20%5B0xba25e600%5D%20no-0x240%2Cstate%208%3A%20ipu%20busy%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3E%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%20%E7%8E%B0%E5%9C%A8%E6%98%AF%20PAL%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20ERR%3A%20no-0x240%2Cipu_queue_task%20err%3A-125%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Emxc_v4l2_%E8%BE%93%E5%87%BAmxc_v4l2_%E8%BE%93%E5%87%BA.0%EF%BC%9A%E6%98%BE%E7%A4%BA%E5%B7%A5%E4%BD%9C%E5%A4%B1%E8%B4%A5ret%20%3D%20-125%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3EVIDIOC_QBUF%20%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%EF%BC%9A%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%AE%89%E8%A3%85%E5%9C%A8%20irq%200%20%E4%B8%8A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20blue%3B%22%3Eimx-ipuv3%20imx-ipuv3.0%3A%20CSI%20irq%200%20in%20use%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220130708_190249.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220130708_190249.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117742iDE13589E18E064E5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220130708_190249.jpg%22%20alt%3D%2220130708_190249.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20130708_190249.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%20VDI%20%E5%8E%BB%E9%9A%94%E8%A1%8C%E7%AE%97%E6%B3%95%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%E5%8C%85%E5%90%AB%E5%B0%8F%E5%AD%97%E4%BD%93%E6%96%87%E6%9C%AC%E7%9A%84%E8%A7%86%E9%A2%91%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%BE%80%E5%BE%80%E4%BC%9A%E6%A8%A1%E7%B3%8A%E6%88%96%E5%88%A0%E9%99%A4%E6%95%B4%E8%A1%8C%E3%80%82%E7%9B%B8%E5%8F%8D%EF%BC%8C%E5%9C%A8%20CSI%20-%26gt%3B%20MEM%20%E9%80%9A%E9%81%93%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%8E%BB%E9%9A%94%E8%A1%8C%E5%8F%AF%E4%BB%A5%E5%BE%88%E5%A5%BD%E5%9C%B0%E6%BB%A1%E8%B6%B3%E6%88%91%E4%BB%AC%E7%9A%84%E9%9C%80%E6%B1%82%EF%BC%88%E5%8F%82%E8%A7%81%20CPMEM%20%E4%B8%AD%E7%9A%84%20ILO%20%E5%92%8C%20Stride%20%E8%AE%BE%E7%BD%AE%EF%BC%89%EF%BC%8C%E4%BD%86%E8%BF%99%E9%9C%80%E8%A6%81%E5%AF%B9%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E5%A4%A7%E9%87%8F%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E7%9B%AE%E6%A0%87%E6%98%AF%E5%B9%B6%E8%A1%8C%E7%BC%96%E7%A0%81%E5%92%8C%E9%A2%84%E8%A7%88%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%9C%89%E4%B8%A4%E7%A7%8D%E9%80%89%E6%8B%A9%E3%80%82%3C%2FP%3E%3CP%3E1)%20%E4%BB%8E%20v4lsrc%20%E5%90%AF%E5%8A%A8%E6%B5%81%EF%BC%8C%E5%B9%B6%E5%B0%86%E4%B8%80%E4%B8%AA%E6%B5%81%E8%B7%AF%E7%94%B1%E5%88%B0%20v4lsink%EF%BC%8C%E5%8F%A6%E4%B8%80%E4%B8%AA%E8%B7%AF%E7%94%B1%E5%88%B0%E8%A7%A3%E7%A0%81%E5%99%A8%3C%2FP%3E%3CP%3E2)%20%E5%B0%86%E9%A2%84%E8%A7%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8E%E6%9C%AC%E8%A1%A5%E4%B8%81%E5%88%9B%E5%BB%BA%E7%9A%84%E5%8E%BB%E9%9A%94%E8%A1%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%88%E5%B9%B6%EF%BC%8C%E4%BB%A5%E5%BD%A2%E6%88%90%E9%A2%84%E8%A7%88%20%2B%20%E5%8E%BB%E9%9A%94%E8%A1%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BF%AE%E6%94%B9%20v4l%20%E6%8D%95%E8%8E%B7%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%A5%E5%B0%86%E6%B5%81%E8%B7%AF%E7%94%B1%E5%88%B0%E9%A2%84%E8%A7%88%E5%92%8C%E8%A7%A3%E7%A0%81%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%BA%8C%E7%A7%8D%E9%80%89%E6%8B%A9%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9B%B4%E5%A4%8D%E6%9D%82%EF%BC%8C%E5%B9%B6%E4%BC%9A%E5%BC%95%E5%85%A5%E5%90%8C%E6%AD%A5%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%80%8C%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E5%9C%A8%20V4L%20%E6%A1%86%E6%9E%B6%E5%86%85%E4%B8%8D%E6%98%93%E8%A7%A3%E5%86%B3%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E9%87%87%E5%8F%96%E7%AC%AC%E4%B8%80%E6%9D%A1%E8%B7%AF%E7%BA%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A9%E8%A1%A5%E4%B8%81%E5%9C%A8%E5%9F%BA%E4%BA%8E%20i.MX53%20%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%E4%BD%BF%E7%94%A8%20Gstreamer%20%E5%BD%95%E5%88%B6%E5%8E%BB%E9%9A%94%E8%A1%8C%E8%A7%86%E9%A2%91%E6%98%AF%E5%8F%AF%E8%A1%8C%E7%9A%84%EF%BC%8C%E4%BD%86%E7%BC%BA%E5%B0%91%E4%B8%80%E4%BB%B6%E4%BA%8B%EF%BC%9A%E9%A2%84%E8%A7%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%E5%90%AF%E7%94%A8%E9%A2%84%E8%A7%88%E7%9A%84%E7%AE%A1%E9%81%93%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3Egst-launch%20-v%20mfw_v4lsrc%20capture-mode%3D2%20preview%3Dtrue%20!%20fakesink%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E7%9C%8B%E4%B8%8D%E5%88%B0%E9%A2%84%E8%A7%88%EF%BC%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%95%B0%E6%8D%AE%E5%88%B0%E8%BE%BE%20fakesink%E3%80%82%E5%87%A0%E7%A7%92%E9%92%9F%E5%90%8E%EF%BC%8Cgst-launch%20%E4%B8%AD%E6%AD%A2%E5%B9%B6%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3EERROR%3A%20v4l2%20capture%3A%20mxc_v4l_dqueue%20timeout%20enc_counter%200%3C%2FCODE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E6%88%91%E8%A6%81%E5%81%9A%E4%BB%80%E4%B9%88%E6%89%8D%E8%83%BD%E4%B8%BA%E5%8E%BB%E9%9A%94%E8%A1%8C%E4%BB%BB%E5%8A%A1%E9%93%BE%E6%B7%BB%E5%8A%A0%E9%A2%84%E8%A7%88%E6%94%AF%E6%8C%81%E5%91%A2%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gao%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%B1%20ADV%207180%20%E9%97%AE%E9%A2%98%E5%B1%95%E5%BC%80%E6%96%B0%E7%9A%84%E8%AE%A8%E8%AE%BA%EF%BC%8C%E4%BB%A5%E5%B8%AE%E5%8A%A9%E5%B0%86%E8%AE%A8%E8%AE%BA%E9%99%90%E5%88%B6%E5%9C%A8%E5%8D%95%E4%B8%AA%E4%B8%BB%E9%A2%98%E4%B8%8A%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%B0%86%E6%AD%A4%E8%AE%A8%E8%AE%BA%E7%A7%BB%E8%87%B3%E8%AE%A8%E8%AE%BA%E5%8C%BA%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E7%8E%B0%E5%9C%A8%E5%B7%B2%E7%BB%8F%E8%B6%85%E5%87%BA%E4%BA%86%E5%88%9D%E5%A7%8B%E5%B8%96%E5%AD%90%E7%9A%84%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%8F%B2%E5%88%A9%E6%99%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E8%BF%98%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%20mxc_v4l2_tvin%20%E4%BB%8E%20adv7180%20%E6%8D%95%E8%8E%B7%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%95%B0%E6%8D%AE%E4%B8%AD%E5%8C%85%E5%90%AB%20H%2FV%20%E5%90%8C%E6%AD%A5%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E6%83%B3%E8%AE%A9%E5%AE%83%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%20adv7180%20%E7%9A%84%E5%A4%96%E9%83%A8%20H%2FV%20%E5%90%8C%E6%AD%A5%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E8%AE%A9adv7180%E4%BD%9C%E4%B8%BAcmos%E4%BC%A0%E6%84%9F%E5%99%A8%E5%B7%A5%E4%BD%9C%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9F%A5%E9%81%93%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E5%B0%BD%E7%AE%A1%E5%A6%82%E6%AD%A4%EF%BC%8C%E9%80%9A%E5%B8%B8%E6%9C%80%E5%A5%BD%E5%9C%A8%E4%B8%AD%E6%96%AD%E4%BE%8B%E7%A8%8B%E4%B8%AD%E5%B0%BD%E5%8F%AF%E8%83%BD%E5%B0%91%E5%9C%B0%E6%89%A7%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPhilip_FSL%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%AF%E4%BB%A5%E8%B0%83%E6%95%B4%E6%8D%95%E8%8E%B7%E5%86%85%E5%AD%98%E7%9A%84%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%BD%A0%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9Aipu_vdi_enc.c%EF%BC%8C%E5%AE%83%E5%9C%A8IPU_IRQ_CSI0_OUT_EOF%E4%B8%AD%E6%96%AD%E7%9A%84%E5%9B%9E%E8%B0%83%E4%B8%AD%E4%BD%BF%E7%94%A8queue_work()%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E9%87%8C%E7%9B%B4%E6%8E%A5%E8%B0%83%E7%94%A8%20vdi_work_func()%20%E5%8F%AF%E4%BB%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E9%9C%80%E8%A6%81%E5%81%9A%E7%9A%84%E4%B8%BB%E8%A6%81%E4%BA%8B%E6%83%85%E6%98%AF%E8%AE%BE%E7%BD%AE%20enc.mem_prp_vf_mem.out_width%E5%92%8C%20enc.mem_prp_vf_mem.out_height%E9%80%82%E5%BD%93%E7%9A%84%E5%8F%98%E9%87%8F%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E8%BF%99%E4%BA%9B%E5%9C%A8%20vdi_enc_setup()%20%E4%B8%AD%E5%9B%BA%E5%AE%9A%E4%B8%BA%E4%B8%8E%E8%BE%93%E5%85%A5%E7%9B%B8%E5%90%8C%E7%9A%84%E5%B0%BA%E5%AF%B8%EF%BC%9A%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3Eenc.mem_prp_vf_mem.out_width%3D%20cam-%26gt%3Bv2f.fmt.pix.%E5%AE%BD%E5%BA%A6%EF%BC%9B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Eenc.mem_prp_vf_mem.out_height%3D%20cam-%26gt%3Bv2f.fmt.pix.%E9%AB%98%E5%BA%A6%EF%BC%9B%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%E4%BD%BF%E7%94%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BC%A0%E9%80%92%E7%9A%84%E5%80%BC%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BA%94%E8%AF%A5%E4%B8%BA%E6%82%A8%E6%89%A7%E8%A1%8C%E8%B0%83%E6%95%B4%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%8E%BB%E9%9A%94%E8%A1%8C%E6%8D%95%E8%8E%B7%E8%AE%BE%E5%A4%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20ipu%EF%BC%8C%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E4%BB%8E%20adv7180%20%E6%8D%95%E8%8E%B7%E6%95%B0%E6%8D%AE%E5%B9%B6%E8%B0%83%E6%95%B4%E5%85%B6%E5%A4%A7%E5%B0%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E5%85%B6%E6%94%BE%E5%85%A5%20vpu%20%E5%92%8C%E7%BC%96%E7%A0%81%E5%99%A8%E4%BB%A5%E8%BD%AC%E6%8D%A2%E4%B8%BA%20jpeg%20%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BD%A0%E7%9A%84%E8%A1%A5%E4%B8%81%E6%9D%A5%E8%A7%A3%E5%86%B3%E5%8E%BB%E9%9A%94%E8%A1%8C%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%83%B3%E5%B0%86%E6%8D%95%E8%8E%B7%E7%9A%84%E6%95%B0%E6%8D%AE%E4%BB%8E%EF%BC%88720x480%EF%BC%89%E8%B0%83%E6%95%B4%E4%B8%BA%EF%BC%88640x480%EF%BC%89%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%20MEM_VDI_PRP_VF_MEM%20%E6%94%AF%E6%8C%81%E8%B0%83%E6%95%B4%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E5%85%B3%E4%BA%8E%E8%A1%A5%E4%B8%81%E6%96%87%E4%BB%B6%E4%B8%AD%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E5%93%AA%E4%BA%9B%E5%86%85%E5%AE%B9%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-16-2012 02:05 AM
更新人:
