Compile L2.6.35_1.1.0_130130 for i.MX28 on Ubuntu 12.04 64bit OS
This is the procedure and patch to set up Ubuntu 12.04 64bit Linux Host PC and building i.MX28 L2.6.35_1.1.0_130130.  It has been tested to build GNOME profile and with FSL Standard MM codec.
A) Basic Requirement:
  • Set up the Linux Host PC using ubuntu-12.04.3-desktop-amd64.iso
  • Make sure the previous LTIB installation and the /opt/freescale have been removed
B) Installed the needed packages to the Linux Host PC
$ sudo apt-get update
$ sudo apt-get install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
$ sudo apt-get install libdbus-glib-1-dev liborbit2-dev intltool
$ sudo apt-get install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
$ sudo apt-get install uuid-dev liblzo2-dev
$ sudo apt-get install tcl dpkg
$ sudo apt-get install asciidoc texlive-latex-base dblatex xutils-dev
$ sudo apt-get install texlive texinfo
$ sudo apt-get install ia32-libs libc6-dev-i386 lib32z1
$ sudo apt-get install uboot-mkimage
$ sudo apt-get install scrollkeeper
$ sudo apt-get install gparted
$ sudo apt-get install nfs-common nfs-kernel-server
$ sudo apt-get install git-core git-doc git-email git-gui gitk
$ sudo apt-get install meld atftpd
C) Unpack and install the LTIB source package and assume done on the home directory:
$ cd ~
$ tar -zxvf L2.6.35_1.1.0_130130_source.tar.gz
$ ./L2.6.35_1.1.0_130130_source/install
After that, you will find ~/ltib directory created
D) Apply the patch to make L2.6.35_1.1.0 could be installed and compiled on Ubuntu 12.04 64bit OS
$ cd ~/ltib
$ git apply 0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch
a) The patch modifies the following files:
    •    dist/lfs-5.1/base_libs/base_libs.spec
    •    dist/lfs-5.1/lkc/lkc.spec
    •    dist/lfs-5.1/mux_server/mux_server.spec
    •    dist/lfs-5.1/ncurses/ncurses.spec
b) Add the following files to the pkgs directory:
    •    pkgs/lkc-1.4-lib.patch
    •    pkgs/lkc-1.4-lib.patch.md5
E) Then, it is ready to proceed the rest of the LTIB env setup process:
$ cd ~/ltib
$ ./ltib -m config
$ ./ltib
Reference:
NOTE:
When compiling gstreamer, this warning was pop up.  Just ignore it seems okay.
标签 (2)
附件
评论
git apply part , doesn't work
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch:89: space before tab in indent.
cd lxdialog && $(MAKE)
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch:90: trailing whitespace.
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch:94: trailing whitespace.
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch:96: space before tab in indent.
$(CC) $(LDFLAGS) $^ -o $@
error: patch failed: dist/lfs-5.1/lkc/lkc.spec:19
error: dist/lfs-5.1/lkc/lkc.spec: patch does not apply
error: patch failed: dist/lfs-5.1/mux_server/mux_server.spec:22
error: dist/lfs-5.1/mux_server/mux_server.spec: patch does not apply
%3CLINGO-SUB%20id%3D%22lingo-sub-1129265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%BC%96%E8%AF%91L2.6.35_1.1.0_130130%E9%80%82%E7%94%A8%E4%BA%8E%20Ubuntu%2012.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E7%9A%84%20i.MX28%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E6%98%AF%E8%AE%BE%E7%BD%AE%20Ubuntu%2012.04%2064%20%E4%BD%8D%20Linux%20%E4%B8%BB%E6%9C%BA%20PC%20%E5%92%8C%E6%9E%84%E5%BB%BA%20i.MX28%20L2.6.35_1.1.0_130130%20%E7%9A%84%E7%A8%8B%E5%BA%8F%E5%92%8C%E8%A1%A5%E4%B8%81%E3%80%82%E5%AE%83%E5%B7%B2%E7%BB%8F%E8%BF%87%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%9E%84%E5%BB%BA%20GNOME%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%B9%B6%E4%BD%BF%E7%94%A8%20FSL%20%E6%A0%87%E5%87%86%20MM%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EA)%20%E5%9F%BA%E6%9C%AC%E8%A6%81%E6%B1%82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20ubuntu-12.04.3-desktop-amd64.iso%20%E8%AE%BE%E7%BD%AE%20Linux%20%E4%B8%BB%E6%9C%BA%3C%2FLI%3E%3CLI%3E%E7%A1%AE%E4%BF%9D%E5%85%88%E5%89%8D%E7%9A%84%20LTIB%20%E5%AE%89%E8%A3%85%E5%92%8C%20%2Fopt%2Ffreescale%20%E5%B7%B2%E8%A2%AB%E5%88%A0%E9%99%A4%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EB)%20%E5%AE%89%E8%A3%85%E6%89%80%E9%9C%80%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%88%B0%20Linux%20%E4%B8%BB%E6%9C%BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20update%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20gettext%20libgtk2.0-devrpm%20bison%20m4%20libfreetype6-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20libdbus-glib-1-dev%20liborbit2-dev%20intltool%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20ccache%20ncurses-dev%20zlib1g%20zlib1g-dev%20gcc%20g%2B%2B%20libtool%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20uuid-dev%20liblzo2-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20tcl%20dpkg%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20asciidoc%20texlive-latex-base%20dblatex%20xutils-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20texlive%20texinfo%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20ia32-libs%20libc6-dev-i386%20lib32z1%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20%E5%AE%89%E8%A3%85%20uboot-mkimage%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20scrollkeeper%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20gparted%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20nfs-common%20nfs-kernel-server%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20git-core%20git-doc%20git-email%20git-gui%20gitk%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20meld%20atftpd%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EC)%20%E8%A7%A3%E5%8E%8B%E5%B9%B6%E5%AE%89%E8%A3%85%20LTIB%20%E6%BA%90%E5%8C%85%EF%BC%8C%E5%B9%B6%E5%81%87%E8%AE%BE%E5%9C%A8%E4%B8%BB%E7%9B%AE%E5%BD%95%E4%B8%8A%E5%AE%8C%E6%88%90%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20tar%20-zxvf%20L2.6.35_1.1.0_130130_source.tar.gz%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2FL2.6.35_1.1.0_130130_source%2Finstall%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E4%B9%8B%E5%90%8E%E4%BD%A0%E4%BC%9A%E5%8F%91%E7%8E%B0%E5%88%9B%E5%BB%BA%E4%BA%86~%2Fltib%20%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3ED)%20%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%E7%A8%8B%E5%BA%8F%E4%BB%A5%E7%94%9F%E6%88%90%20L2.6.35_1.1.0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Ubuntu%2012.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%AE%89%E8%A3%85%E5%92%8C%E7%BC%96%E8%AF%91%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%2Fltib%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20%E5%BA%94%E7%94%A8%200001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSTRONG%3Ea)%20%E8%AF%A5%E8%A1%A5%E4%B8%81%E4%BF%AE%E6%94%B9%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3Edist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Flkc%2Flkc.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fmux_server%2Fmux_server.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fncurses%2Fncurses.spec%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSTRONG%3Eb)%20%E5%B0%86%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20pkgs%20%E7%9B%AE%E5%BD%95%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%26nbsp%3B%26nbsp%3B%20pkgs%2Flkc-1.4-lib.patch%3C%2FLI%3E%3CLI%3E%26nbsp%3B%26nbsp%3B%20pkgs%2Flkc-1.4-lib.patch.md5%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3EE)%20%E7%84%B6%E5%90%8E%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E5%85%B6%E4%BD%99%E7%9A%84%20LTIB%20%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E8%BF%87%E7%A8%8B%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20cd%20~%2Fltib%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2Fltib%20-m%20config%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2Fltib%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3EL2.6.35_1.1.0_130130_docs%2Fdoc%2Fmx28%2FSetting_Up_LTIB_Host_on_Ubuntu_9_04.pdf%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93394%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93394%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F332385%23332385%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F332385%23332385%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F271675%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fthread%2F271675%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F360556%23360556%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F360556%23360556%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3Escrollkeeper%20%E9%80%82%E7%94%A8%E4%BA%8E%20gnome-desktop%20%E7%BC%96%E8%AF%91%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%BC%96%E8%AF%91%20gstreamer%20%E6%97%B6%E5%BC%B9%E5%87%BA%E6%AD%A4%E8%AD%A6%E5%91%8A%E3%80%82%E5%BF%BD%E7%95%A5%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel.jpg%22%20style%3D%22width%3A%20563px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42282iECD73307F318B32F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22panel.jpg%22%20alt%3D%22panel.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel2.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel2.jpg%22%20style%3D%22width%3A%20535px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111470i18E3E9477447086B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22panel2.jpg%22%20alt%3D%22panel2.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1129265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BC%96%E8%AF%91%20L2.6.35_1.1.0_130130%E9%80%82%E7%94%A8%E4%BA%8E%20Ubuntu%2012.04%2064%20%E4%BD%8D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E7%9A%84%20i.MX28%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Egit%20apply%20%E9%83%A8%E5%88%86%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egit%20%E5%BA%94%E7%94%A8%200001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch%3C%2FP%3E%3CP%3E0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A89%EF%BC%9A%E7%BC%A9%E8%BF%9B%E4%B8%AD%E5%88%B6%E8%A1%A8%E7%AC%A6%E5%89%8D%E7%9A%84%E7%A9%BA%E6%A0%BC%E3%80%82%3CBR%20%2F%3Ecd%20lxdialog%20%26amp%3B%26amp%3B%20%24(MAKE)%3CBR%20%2F%3E%200001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A90%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A94%EF%BC%9A%E5%B0%BE%E9%9A%8F%E7%A9%BA%E6%A0%BC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.%E8%A1%A5%E4%B8%81%EF%BC%9A96%EF%BC%9A%E7%BC%A9%E8%BF%9B%E4%B8%AD%E5%88%B6%E8%A1%A8%E7%AC%A6%E5%89%8D%E7%9A%84%E7%A9%BA%E6%A0%BC%E3%80%82%3CBR%20%2F%3E%24(CC)%20%24(LDFLAGS)%20%24%5E%20-o%20%24%40%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%A1%A5%E4%B8%81%E5%A4%B1%E8%B4%A5%EF%BC%9Adist%2Flfs-5.1%2Flkc%2Flkc.spec%3A19%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Adist%2Flfs-5.1%2Flkc%2Flkc.spec%EF%BC%9A%E8%A1%A5%E4%B8%81%E4%B8%8D%E9%80%82%E7%94%A8%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%A1%A5%E4%B8%81%E5%A4%B1%E8%B4%A5%EF%BC%9Adist%2Flfs-5.1%2Fmux_server%2Fmux_server.spec%3A22%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Adist%2Flfs-5.1%2Fmux_server%2Fmux_server.spec%EF%BC%9A%E8%A1%A5%E4%B8%81%E4%B8%8D%E9%80%82%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎12-09-2013 03:41 AM
更新人:
