Changing IPU Color Space Conversion parameters
Inside IPU there are two block where color space conversion can be made: IC (Image Converter) and DP (Display processor).
On Linux, the CSC parameters are located at IPU (IC and DP) drivers, linux/drivers/mxc/ipu3 folder.
All negative coefficients are represented using two's complement.
Linux Image Converter driver:
The parameters are set on function _init_csc:
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/drivers/mxc/ipu3/ipu_ic.c?h=imx_3.1...
static void _init_csc(struct ipu_soc *ipu, uint8_t ic_task, ipu_color_space_t in_format,
 ipu_color_space_t out_format, int csc_index)
 * Y = 0.257 * R + 0.504 * G + 0.098 * B + 16;
 * U = -0.148 * R - 0.291 * G + 0.439 * B + 128;
 * V = 0.439 * R - 0.368 * G - 0.071 * B + 128;
 static const uint32_t rgb2ycbcr_coeff[4][3] = {
 {0x0042, 0x0081, 0x0019},
 {0x01DA, 0x01B6, 0x0070},
 {0x0070, 0x01A2, 0x01EE},
 {0x0040, 0x0200, 0x0200}, /* A0, A1, A2 */
 /* transparent RGB->RGB matrix for combining
 static const uint32_t rgb2rgb_coeff[4][3] = {
 {0x0080, 0x0000, 0x0000},
 {0x0000, 0x0080, 0x0000},
 {0x0000, 0x0000, 0x0080},
 {0x0000, 0x0000, 0x0000}, /* A0, A1, A2 */
/* R = (1.164 * (Y - 16)) + (1.596 * (Cr - 128));
  G = (1.164 * (Y - 16)) - (0.392 * (Cb - 128)) - (0.813 * (Cr - 128));
  B = (1.164 * (Y - 16)) + (2.017 * (Cb - 128); */
 static const uint32_t ycbcr2rgb_coeff[4][3] = {
 {149, 0, 204},
 {149, 462, 408},
 {149, 255, 0},
 {8192 - 446, 266, 8192 - 554}, /* A0, A1, A2 */
Linux Display Processor driver:
The parameters are set on constants (rgb2ycbcr_coeff and ycbcr2rgb_coeff):
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/drivers/mxc/ipu3/ipu_disp.c?h=imx_3...
/* Y = R * 1.200 + G * 2.343 + B * .453 + 0.250;
  U = R * -.672 + G * -1.328 + B * 2.000 + 512.250.;
  V = R * 2.000 + G * -1.672 + B * -.328 + 512.250.;*/
static const int rgb2ycbcr_coeff[5][3] = {
 {0x4D, 0x96, 0x1D},
 {-0x2B, -0x55, 0x80},
 {0x80, -0x6B, -0x15},
 {0x0000, 0x0200, 0x0200}, /* B0, B1, B2 */
 {0x2, 0x2, 0x2}, /* S0, S1, S2 */
static const int ycbcr2rgb_coeff[5][3] = {
 {0x095, 0x000, 0x0CC},
 {0x095, 0x3CE, 0x398},
 {0x095, 0x0FF, 0x000},
 {0x3E42, 0x010A, 0x3DD6}, /*B0,B1,B2 */
 {0x1, 0x1, 0x1}, /*S0,S1,S2 */
标签 (4)
标记 (2)
附件
评论
Hello,rogeriopimentel
Both IC and DP have the capability of CSC, so how to decide where the CSC to be done.
Thank you!
ZongbiaoLiao
Hi 宗標廖​,
On your project, if the only purpose of CSC is to correctly display the image, you can choose DP to make the CSC. Otherwise you can choose IC.
Rgds,
Rogerio
Hi everyone!
We plan to use Image Converter (IC) in IPU to adjust the parameters of YUV stream from a CMOS camera.
Does IC convert the stream up to 1024 x 1024 at a time?
If so, do we need to split the image to adjust the FullHD stream (1920 x 1080)?
I'd appreciate your response.
Kind Regards,
Tetsuo Maeda
[Rogerio] It's input: 4096x4096 and output: 1024x1024.
[Rogerio] Yes, need to split the image. If the purpose is to only display the image, I would suggest to use the Display Processor CSC insteade of IC CSC. So you won't need to split the image.
Rogerio
Hi Rogerio-san,
Thank you for the clarification.
We have tried to split the stream to four parts and do the conversion.
But because of the limitation of the transfer rate from IC to system memory (Up to 100Mpixels/sec) , the frame rate of the converted stream was around 20fps.
When we do the same conversion for the stream of 1280 x 720, we got the stream of 30fps.
Although the reference manual "IMX6DQRM" says that the output rate from IC to system memory is "Up to 100Mpixel/sec (eg. 1920 x 1080 30fps) on page 2736", is it actually difficult to output the FHD stream?
I'd appreciate your advice.
Tetsuo.
Hi tetsuomaeda‌,
Could you please tell me more about your application? Do you need to make this conversion to display the video on display? Or to save the video into some local storage or send by ethernet?
Best regrds,
Rogerio
Hi Rogerio-san,
Our application is recording a video stream from a CMOS camera to an SD card.
Flow is as follows.
Camera => CSI => DRAM => (IC => DRAM) x 4 => VPU
At first, we were thinking the following flow.
Camera => CSI => IC => DRAM => VPU.
But because of the limitation (up to1024 x 1024) of the output from IC, we have to split the stream so that the image size becomes less than 1024 x 1024.
As the result of stream splitting, it seems to become difficult to output the full HD stream of 30fps from IC to DRAM.
If we can avoid the splitting, we might be able to support FHD 30fps recording.
Thanks in advance for your advice.
Tetsuo Maeda
Hi tetsuomaeda‌,
What i.MX6 are you using? (e.g. i.MX6Quad, Dual,Dual Lite?)
For i.MX6 versions that has 2 IPUs, you can use both IPUs at the same time, so the bandwidth will double. For those i.MX6 with PxP, you can use it to perform CSC. It can reach 1080p@50fps.
Rogerio
Hi Rogerio-san,
Very sorry for my late response.
Actually, we are using QUAD and two IPU would be available!
We have not thought about it.
Are there sample codes that are using two ICs in parallel?
Regads,
Tetsuo Maeda
Hi tetsuomaeda‌,
You can call mxc_ipu device (using IOCTL) twice using Linux threads. Device driver will automatically choose the second IPU when the first one is busy.
See attached on the DOC (file csc_exe3.zip) a source file using threads.
Rogerio
We plan to use imx6 (and imx8  too) with LVDS 24-bit, but we need the alpa, so it seems we need RGBA8888 to RGBA6666 conversion (we don't mind the color reduced quality, we need the alpha)
I saw that in the past others had the same need, but they didn't seem to achieve it:
RGBA/ARGB LVDS output from i.MX6
Is it possible to do RGBA8888 to RGBA6666 conversion using the method in this article ?
Should we use the IC or DP conversion ? Is this the best way to achieve it or can we do it from ioctl framebuffer ?
Can you please give some points how we should do the conversion ?
Thank you very much,
ran
On latest ipu driver, display processor can only accept the following formats:
int _ipu_pixfmt_to_map(uint32_t fmt){
switch (fmt) {     c
ase
IPU_PIX_FMT_GENERIC:
case IPU_PIX_FMT_RGB24:
return 0;
case IPU_PIX_FMT_RGB666:
return 1;
case IPU_PIX_FMT_YUV444:
return 2;
case IPU_PIX_FMT_RGB565:
return 3;
case IPU_PIX_FMT_LVDS666:
return 4;
case IPU_PIX_FMT_VYUY:
return 6;
case IPU_PIX_FMT_UYVY:
return 8;
case IPU_PIX_FMT_YUYV:
return 10;
case IPU_PIX_FMT_YVYU:
return 12;
case IPU_PIX_FMT_GBR24:
case IPU_PIX_FMT_VYU444:
return 13;
case IPU_PIX_FMT_BGR24:
return 14;
     return -1;}
See the code above on ipu_disp.c\ipu3\mxc\drivers - linux-imx - i.MX Linux kernel
To make the LVDS also outputs the alpha value, I would recommend to use DP (Display Processor) instead of IC (Image Converter).
You can try to set the frame buffer to RGB8888 (RGB32) and add a new format RGBA6666 by creating a new display microcode to display.
For an example about how to create a new display microcode, you can check the following document:
Patch to Support BT656 and BT1120 Output For i.MX6 BSP
Rogerio
Hello Rogerio,
Thank you very much for the information!!
We plan to use qt application, with LVDS output 24-bit.
I am not sure about how to set framebuffer with qt. I said before RGBA8888, but actually the processing can be also reduced to lower resolution if it will make it easier for us (is it better that we use other format with qt than RGBA8888 to make the transfer to RGBA6666 easier ?)
We don't use any input in imx6 and just do the graphics in imx:
qt application graphics in imx6 -> lvds output(with alpha) -> blender (belnder not in imx)
So we actually do the blending with video outside imx6.
I'll take a deeper study of your answer now.
ran
"is it better that we use other format with qt than RGBA8888 to make the transfer to RGBA6666 easier ?"
I think it's better to keep the framebuffer in RGBA8888 (also called as RGB32) because this is an already known and existent format. The display processor microcode will get these 32 bits from framebuffer and "re-format" to RGB6666. With DP microcode you can created any waveform you need.
Just remember to set the framebuffer to RGB32 with local alpha blending. The local alpha uses one value of alpha for each pixel while gloal alpha uses only one value to the entire screen.
Rogerio
Hello Rogerio,
If I may please ask the following:
1. In the above list (from code snippet) of accepted formats, I don't find RGB32 formats  (it seems that all formats for DP are limited to 24 bits).
But shouldn't DP accept should reformat to 32-bit format containing alpha (such formats are used with HDMI devices for example) ?
2. kernel parameters usually appear as following:
mxcfb0:dev=ldb,LDB-XGA,if=RGB666
Does it mean that for a new microcode RGBA6666, it should be something like (after adding  IPU_PIX_FMT_RGBA6666):
mxcfb0:dev=ldb,LDB-XGA,if=RGBA6666
I am not sure why in the patch for bt656, there is dev=BT656 , BT656 is a device or format ?
Thank you,
ran
Hello Rogerio,
I took a look in the patch for BT656, and it seems very complex patch.
Currently it seems that using imx6 and imx8 in our next product without this feature available, and adding this format ourselves pus a lot of risk on the project.
Is there a chance that NXP will add a patch support for ARGB6666 ? (It seems that this feature is very much required by several people, so I think it is quite important.)
ran
I have never seen a display that uses alpha information, all blending processing is made before sending the image to display.
The case from threadRGBA/ARGB LVDS output from i.MX6  uses an FPGA in place of a display, this is why they wanted alpha to be sent with the image.
Do you mind to let me know your use case? Maybe we can find other solution.
Will i.MX drive directly the LCD that needs alpha? Could you let me know the LCD model?
About NXP to add support, we have a team who customers can contract to develop SW.
NXP Professional Services|NXP
Rogerio
Right , I understand now.
Our use case is:
dsp (RGB)---------------|
                     FPGA (blending)--->>-------DISPLAY
imx (LVDS) -------------|
We use FPGA which recieves the LVDS output from imx as an input, and also a dsp is connected to FPGA. The FPGA does the blending into a display.
In imx we plan to use a Qt application.
Any suggestions are appreciated,
Thank you very much for the help,
ran
I would suggest (if possible on your project) to connect the DSP to i.MX and let i.MX makes the image blending.
dsp(RGB) -----> i.MX (makes the blending from dsp + QT graphics) ------> Display
If not possible to make the configuration above, I would recomend to program the display microcode on i.MX as I mentioned ealier.
Rogerio
Thank you very much Rogerio!
I understand. We are familiar with the usecase of "doing it inside imx", but our system engineer is afraid that the latency will grow, becuase we can't allow that.
I also sent request to the team you've mentioned before for this
 develop SW. Yet, I think that this kind of feature should be a public feature, because there is such need from  several customers, as we saw in other posts in the community.
Thanks again,
Ran
%3CLINGO-SUB%20id%3D%22lingo-sub-1100972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EIPU%E5%86%85%E9%83%A8%E6%9C%89%E4%B8%A4%E4%B8%AA%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%9AIC%EF%BC%88%E5%9B%BE%E5%83%8F%E8%BD%AC%E6%8D%A2%E5%99%A8%EF%BC%89%E5%92%8CDP%EF%BC%88%E6%98%BE%E7%A4%BA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20Linux%20%E4%B8%8A%EF%BC%8CCSC%20%E5%8F%82%E6%95%B0%E4%BD%8D%E4%BA%8E%20IPU%EF%BC%88IC%20%E5%92%8C%20DP%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%81linux%2Fdrivers%2Fmxc%2Fipu3%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%80%E6%9C%89%E8%B4%9F%E7%B3%BB%E6%95%B0%E5%9D%87%E4%BD%BF%E7%94%A8%E4%BA%8C%E8%BF%9B%E5%88%B6%E8%A1%A5%E7%A0%81%E8%A1%A8%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ELinux%20%E5%9B%BE%E5%83%8F%E8%BD%AC%E6%8D%A2%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E6%95%B0%E5%9C%A8%E5%87%BD%E6%95%B0_init_csc%E4%B8%8A%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_ic.c%3Fh%3Dimx_3.14.28_1.0.0_ga%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_ic.c%3Fh%3Dimx_3.14.28_1.0.0_ga%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_ic.c%3Fh%3Dimx_3.14.28_1.0.0_ga%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22line-numbers%20language-csharp%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Evoid%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3E_init_csc%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Estruct%3C%2FSPAN%3E%20ipu_soc%20%3CSPAN%20class%3D%22operator%20token%22%3E*%3C%2FSPAN%3Eipu%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20uint8_t%20ic_task%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20ipu_color_space_t%20in_format%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20ipu_color_space_t%20out_format%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Eint%3C%2FSPAN%3E%20csc_index%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%0A%20*%20Y%20%3D%200.257%20*%20R%20%2B%200.504%20*%20G%20%2B%200.098%20*%20B%20%2B%2016%3B%0A%20*%20U%20%3D%20-0.148%20*%20R%20-%200.291%20*%20G%20%2B%200.439%20*%20B%20%2B%20128%3B%0A%20*%20V%20%3D%200.439%20*%20R%20-%200.368%20*%20G%20-%200.071%20*%20B%20%2B%20128%3B%0A%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20uint32_t%20rgb2ycbcr_coeff%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0042%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0081%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0019%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x01DA%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x01B6%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0070%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0070%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x01A2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x01EE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0040%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0200%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0200%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20A0%2C%20A1%2C%20A2%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20transparent%20RGB-%26gt%3BRGB%20matrix%20for%20combining%0A%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20uint32_t%20rgb2rgb_coeff%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0080%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0080%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0080%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20A0%2C%20A1%2C%20A2%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20R%20%3D%20(1.164%20*%20(Y%20-%2016))%20%2B%20(1.596%20*%20(Cr%20-%20128))%3B%0A%26nbsp%3B%20G%20%3D%20(1.164%20*%20(Y%20-%2016))%20-%20(0.392%20*%20(Cb%20-%20128))%20-%20(0.813%20*%20(Cr%20-%20128))%3B%0A%26nbsp%3B%20B%20%3D%20(1.164%20*%20(Y%20-%2016))%20%2B%20(2.017%20*%20(Cb%20-%20128)%3B%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20uint32_t%20ycbcr2rgb_coeff%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E149%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E204%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E149%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E462%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E408%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E149%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E255%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E8192%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E446%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E266%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E8192%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E554%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20A0%2C%20A1%2C%20A2%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ELinux%20%E6%98%BE%E7%A4%BA%E5%A4%84%E7%90%86%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%B8%B8%E9%87%8F%EF%BC%88rgb2ycbcr_coeff%20%E5%92%8C%20ycbcr2rgb_coeff%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3Fh%3Dimx_3.14.28_1.0.0_ga%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3Fh%3Dimx_3.14.28_1.0.0_ga%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3Fh%3Dimx_3.14.28_1.0.0_ga%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-cpp%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20Y%20%3D%20R%20*%201.200%20%2B%20G%20*%202.343%20%2B%20B%20*%20.453%20%2B%200.250%3B%0A%26nbsp%3B%20U%20%3D%20R%20*%20-.672%20%2B%20G%20*%20-1.328%20%2B%20B%20*%202.000%20%2B%20512.250.%3B%0A%26nbsp%3B%20V%20%3D%20R%20*%202.000%20%2B%20G%20*%20-1.672%20%2B%20B%20*%20-.328%20%2B%20512.250.%3B*%2F%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Eint%3C%2FSPAN%3E%20rgb2ycbcr_coeff%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x4D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x96%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x1D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x2B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x55%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x80%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x80%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x6B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x15%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x0000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0200%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0200%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20B0%2C%20B1%2C%20B2%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x2%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20S0%2C%20S1%2C%20S2%20*%2F%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%0A%3CSPAN%20class%3D%22comment%20token%22%3E%2F*%20R%20%3D%20(1.164%20*%20(Y%20-%2016))%20%2B%20(1.596%20*%20(Cr%20-%20128))%3B%0A%26nbsp%3B%20G%20%3D%20(1.164%20*%20(Y%20-%2016))%20-%20(0.392%20*%20(Cb%20-%20128))%20-%20(0.813%20*%20(Cr%20-%20128))%3B%0A%26nbsp%3B%20B%20%3D%20(1.164%20*%20(Y%20-%2016))%20%2B%20(2.017%20*%20(Cb%20-%20128)%3B%20*%2F%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22keyword%20token%22%3Estatic%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Eint%3C%2FSPAN%3E%20ycbcr2rgb_coeff%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x095%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0CC%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x095%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x3CE%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x398%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x095%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x0FF%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x3E42%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x010A%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x3DD6%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*B0%2CB1%2CB2%20*%2F%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0x1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F*S0%2CS1%2CS2%20*%2F%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%8F%8C%E6%A0%B8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E6%98%8E%E7%99%BD%E3%80%82%E6%88%91%E4%BB%AC%E7%86%9F%E6%82%89%E2%80%9C%E5%9C%A8IMX%E5%86%85%E9%83%A8%E6%89%A7%E8%A1%8C%E2%80%9D%E7%9A%84%E7%94%A8%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E7%9A%84%E7%B3%BB%E7%BB%9F%E5%B7%A5%E7%A8%8B%E5%B8%88%E6%8B%85%E5%BF%83%E5%BB%B6%E8%BF%9F%E4%BC%9A%E5%A2%9E%E5%8A%A0%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E4%B8%8D%E8%83%BD%E5%85%81%E8%AE%B8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%8F%91%E7%94%9F%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%B9%9F%E5%90%91%E6%82%A8%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%E5%9B%A2%E9%98%9F%E5%8F%91%E9%80%81%E4%BA%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%BC%80%E5%8F%91%E6%AD%A4%E8%BD%AF%E4%BB%B6%E7%9A%84%E8%AF%B7%E6%B1%82%E3%80%82%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E7%B1%BB%E5%8A%9F%E8%83%BD%E5%BA%94%E8%AF%A5%E4%BD%9C%E4%B8%BA%E5%85%AC%E5%85%B1%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%AD%A3%E5%A6%82%E6%88%91%E4%BB%AC%E5%9C%A8%E7%A4%BE%E5%8C%BA%E5%85%B6%E4%BB%96%E5%B8%96%E5%AD%90%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%8C%E6%9C%89%E5%BE%88%E5%A4%9A%E5%AE%A2%E6%88%B7%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E9%9C%80%E6%B1%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ERan%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E7%94%A8%E4%BE%8B%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edsp%20(RGB)---------------%7C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%7C%3C%2FP%3E%3CP%3EFPGA%EF%BC%88%E6%B7%B7%E5%90%88%EF%BC%89---%26gt%3B%26gt%3B-------%E6%98%BE%E7%A4%BA%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%7C%3C%2FP%3E%3CP%3Eimx%EF%BC%88LVDS%EF%BC%89-------------%7C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20FPGA%20%E6%8E%A5%E6%94%B6%E6%9D%A5%E8%87%AA%20imx%20%E7%9A%84%20LVDS%20%E8%BE%93%E5%87%BA%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%85%A5%EF%BC%8C%E5%B9%B6%E4%B8%94%20dsp%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20FPGA%E3%80%82FPGA%20%E8%B4%9F%E8%B4%A3%E6%B7%B7%E5%90%88%E5%B9%B6%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20imx%20%E4%B8%AD%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%20Qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E9%83%BD%E5%80%BC%E5%BE%97%E8%B5%9E%E8%B5%8F%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B7%91%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%E6%9C%AA%E8%A7%81%E8%BF%87%E4%BD%BF%E7%94%A8%20alpha%20%E4%BF%A1%E6%81%AF%E7%9A%84%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%8C%E6%89%80%E6%9C%89%E6%B7%B7%E5%90%88%E5%A4%84%E7%90%86%E9%83%BD%E6%98%AF%E5%9C%A8%E5%B0%86%E5%9B%BE%E5%83%8F%E5%8F%91%E9%80%81%E5%88%B0%E6%98%BE%E7%A4%BA%E5%99%A8%E4%B9%8B%E5%89%8D%E8%BF%9B%E8%A1%8C%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%22337488%22%20data-objecttype%3D%221%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F337488%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%E6%9D%A5%E8%87%AA%20i.MX6%20%E7%9A%84%E7%BA%BF%E7%A8%8B%20RGBA%2FARGB%20LVDS%20%E8%BE%93%E5%87%BA%3C%2FA%3E%E7%9A%84%E6%83%85%E5%86%B5%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BD%BF%E7%94%A8%20FPGA%20%E4%BB%A3%E6%9B%BF%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%8C%E8%BF%99%E5%B0%B1%E6%98%AF%E4%BB%96%E4%BB%AC%E5%B8%8C%E6%9C%9B%E5%B0%86%20alpha%20%E4%B8%8E%E5%9B%BE%E5%83%8F%E4%B8%80%E8%B5%B7%E5%8F%91%E9%80%81%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E4%BB%8B%E6%84%8F%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E6%82%A8%E7%9A%84%E7%94%A8%E4%BE%8B%E5%90%97%EF%BC%9F%E4%B9%9F%E8%AE%B8%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E5%85%B6%E4%BB%96%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ei.MX%20%E4%BC%9A%E7%9B%B4%E6%8E%A5%E9%A9%B1%E5%8A%A8%E9%9C%80%E8%A6%81%20alpha%20%E7%9A%84%20LCD%20%E5%90%97%EF%BC%9F%E4%BD%A0%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91LCD%E5%9E%8B%E5%8F%B7%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%85%B3%E4%BA%8E%20NXP%20%E5%A2%9E%E5%8A%A0%E6%94%AF%E6%8C%81%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%80%E4%B8%AA%E5%9B%A2%E9%98%9F%E5%8F%AF%E4%BB%A5%E4%B8%8E%E5%AE%A2%E6%88%B7%E7%AD%BE%E7%BA%A6%E6%9D%A5%E5%BC%80%E5%8F%91%20SW%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsupport%2Fnxp-professional-services%3APROFESSIONAL-SERVICE%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsupport%2Fnxp-professional-services%3A%E4%B8%93%E4%B8%9A%E6%9C%8D%E5%8A%A1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E4%B8%93%E4%B8%9A%E6%9C%8D%E5%8A%A1%7C%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E7%9C%8B%E4%BA%86%E4%B8%80%E4%B8%8B%20BT656%20%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%8C%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E9%9D%9E%E5%B8%B8%E5%A4%8D%E6%9D%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%9B%AE%E5%89%8D%E7%9C%8B%E6%9D%A5%EF%BC%8C%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E4%BA%A7%E5%93%81%E4%B8%AD%E4%BD%BF%E7%94%A8%E6%B2%A1%E6%9C%89%E6%AD%A4%E5%8A%9F%E8%83%BD%E7%9A%84%20imx6%20%E5%92%8C%20imx8%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E4%BB%AC%E8%87%AA%E5%B7%B1%E6%B7%BB%E5%8A%A0%E8%BF%99%E7%A7%8D%E6%A0%BC%E5%BC%8F%E4%BC%9A%E7%BB%99%E9%A1%B9%E7%9B%AE%E5%B8%A6%E6%9D%A5%E5%BE%88%E5%A4%A7%E7%9A%84%E9%A3%8E%E9%99%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ENXP%20%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E6%B7%BB%E5%8A%A0%E5%AF%B9%20ARGB6666%20%E7%9A%84%E8%A1%A5%E4%B8%81%E6%94%AF%E6%8C%81%EF%BC%9F%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BC%BC%E4%B9%8E%E5%BE%88%E5%A4%9A%E4%BA%BA%E9%83%BD%E9%9D%9E%E5%B8%B8%E9%9C%80%E8%A6%81%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%AE%A4%E4%B8%BA%E5%AE%83%E9%9D%9E%E5%B8%B8%E9%87%8D%E8%A6%81%E3%80%82%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%B7%91%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%AF%B7%E5%85%81%E8%AE%B8%E6%88%91%3C%2FSPAN%3E%E9%97%AE%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E5%9C%A8%E4%B8%8A%E9%9D%A2%E5%8F%AF%E6%8E%A5%E5%8F%97%E6%A0%BC%E5%BC%8F%E7%9A%84%E5%88%97%E8%A1%A8%EF%BC%88%E6%9D%A5%E8%87%AA%E4%BB%A3%E7%A0%81%E7%89%87%E6%AE%B5%EF%BC%89%E4%B8%AD%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%20RGB32%20%E6%A0%BC%E5%BC%8F%EF%BC%88%E4%BC%BC%E4%B9%8E%20DP%20%E7%9A%84%E6%89%80%E6%9C%89%E6%A0%BC%E5%BC%8F%E9%83%BD%E9%99%90%E5%88%B6%E4%B8%BA%2024%20%E4%BD%8D%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%20DP%20%E4%B8%8D%E5%BA%94%E8%AF%A5%E6%8E%A5%E5%8F%97%E9%87%8D%E6%96%B0%E6%A0%BC%E5%BC%8F%E5%8C%96%E4%B8%BA%E5%8C%85%E5%90%AB%20alpha%20%E7%9A%84%2032%20%E4%BD%8D%E6%A0%BC%E5%BC%8F%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E8%BF%99%E7%A7%8D%E6%A0%BC%E5%BC%8F%E7%94%A8%E4%BA%8E%20HDMI%20%E8%AE%BE%E5%A4%87%EF%BC%89%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E5%86%85%E6%A0%B8%E5%8F%82%E6%95%B0%E9%80%9A%E5%B8%B8%E5%87%BA%E7%8E%B0%E5%A6%82%E4%B8%8B%E6%83%85%E5%86%B5%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23787878%3B%20background-color%3A%20%23ffffff%3B%22%3Emxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23787878%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%E5%AF%B9%E4%BA%8E%E6%96%B0%E7%9A%84%E5%BE%AE%E4%BB%A3%E7%A0%81RGBA6666%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E6%98%AF%E7%B1%BB%E4%BC%BC%E7%9A%84%EF%BC%88%E6%B7%BB%E5%8A%A0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2013.3333px%3B%22%3EIPU_PIX_FMT_RGBA6666%E4%B9%8B%E5%90%8E%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23787878%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Emxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGBA6666%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23787878%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%20bt656%20%E7%9A%84%E8%A1%A5%E4%B8%81%E4%B8%AD%EF%BC%8C%E6%9C%89%3CSPAN%20style%3D%22color%3A%20%23787878%3B%20background-color%3A%20%23ffffff%3B%22%3Edev%3DBT656%20%EF%BC%8CBT656%20%E6%98%AF%E8%AE%BE%E5%A4%87%E8%BF%98%E6%98%AF%E6%A0%BC%E5%BC%8F%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B7%91%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CEM%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E2%80%9C%E6%88%91%E4%BB%AC%E5%9C%A8%20qt%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20RGBA8888%20%E4%BB%A5%E5%A4%96%E7%9A%84%E5%85%B6%E4%BB%96%E6%A0%BC%E5%BC%8F%E6%98%AF%E5%90%A6%E6%9B%B4%E5%A5%BD%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%9B%B4%E5%AE%B9%E6%98%93%E5%9C%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%20RGBA6666%EF%BC%9F%E2%80%9D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%9C%80%E5%A5%BD%E5%B0%86%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E4%BF%9D%E7%95%99%E5%9C%A8%20RGBA8888%EF%BC%88%E4%B9%9F%E7%A7%B0%E4%B8%BA%20RGB32%EF%BC%89%E4%B8%AD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E6%98%AF%E4%B8%80%E7%A7%8D%E5%B7%B2%E7%9F%A5%E4%B8%94%E5%AD%98%E5%9C%A8%E7%9A%84%E6%A0%BC%E5%BC%8F%E3%80%82%E6%98%BE%E7%A4%BA%E5%A4%84%E7%90%86%E5%99%A8%E5%BE%AE%E4%BB%A3%E7%A0%81%E5%B0%86%E4%BB%8E%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%8E%B7%E5%8F%96%E8%BF%99%2032%20%E4%BD%8D%E5%B9%B6%E2%80%9C%E9%87%8D%E6%96%B0%E6%A0%BC%E5%BC%8F%E5%8C%96%E2%80%9D%E4%B8%BA%20RGB6666%E3%80%82%E4%BD%BF%E7%94%A8%20DP%20%E5%BE%AE%E7%A0%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E6%89%80%E9%9C%80%E7%9A%84%E4%BB%BB%E4%BD%95%E6%B3%A2%E5%BD%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%8F%AA%E9%9C%80%E8%AE%B0%E4%BD%8F%E5%B0%86%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%85%B7%E6%9C%89%E5%B1%80%E9%83%A8%20alpha%20%E6%B7%B7%E5%90%88%E7%9A%84%20RGB32%E3%80%82%E5%B1%80%E9%83%A8%20alpha%20%E5%AF%B9%E6%AF%8F%E4%B8%AA%E5%83%8F%E7%B4%A0%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%20alpha%20%E5%80%BC%EF%BC%8C%E8%80%8C%E5%85%A8%E5%B1%80%20alpha%20%E5%AF%B9%E6%95%B4%E4%B8%AA%E5%B1%8F%E5%B9%95%E4%BB%85%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%E5%80%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%20qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B8%A6%E6%9C%89%2024%20%E4%BD%8D%20LVDS%20%E8%BE%93%E5%87%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20qt%20%E8%AE%BE%E7%BD%AE%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%E6%88%91%E4%B9%8B%E5%89%8D%E8%AF%B4%E8%BF%87%20RGBA8888%EF%BC%8C%E4%BD%86%E5%AE%9E%E9%99%85%E4%B8%8A%E5%A6%82%E6%9E%9C%E8%BF%99%E6%A0%B7%E5%AF%B9%E6%88%91%E4%BB%AC%E6%9D%A5%E8%AF%B4%E6%9B%B4%E5%AE%B9%E6%98%93%E7%9A%84%E8%AF%9D%EF%BC%8C%E5%A4%84%E7%90%86%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%99%8D%E4%BD%8E%E5%88%B0%E6%9B%B4%E4%BD%8E%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%88%E6%88%91%E4%BB%AC%E5%9C%A8%20qt%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20RGBA8888%20%E4%BB%A5%E5%A4%96%E7%9A%84%E5%85%B6%E4%BB%96%E6%A0%BC%E5%BC%8F%E6%98%AF%E5%90%A6%E6%9B%B4%E5%A5%BD%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%9B%B4%E5%AE%B9%E6%98%93%E5%9C%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%20RGBA6666%EF%BC%9F%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%BB%AC%E4%B8%8D%E4%BD%BF%E7%94%A8%20imx6%20%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E8%BE%93%E5%85%A5%EF%BC%8C%E5%8F%AA%E5%9C%A8%20imx%20%E4%B8%AD%E5%A4%84%E7%90%86%E5%9B%BE%E5%BD%A2%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eimx6%20%E4%B8%AD%E7%9A%84%20qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9B%BE%E5%BD%A2%20-%26gt%3B%20lvds%20%E8%BE%93%E5%87%BA%EF%BC%88%E5%B8%A6%20alpha%EF%BC%89-%26gt%3B%20blender%EF%BC%88belnder%20%E4%B8%8D%E5%9C%A8%20imx%20%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%89%80%E4%BB%A5%E6%88%91%E4%BB%AC%E5%AE%9E%E9%99%85%E4%B8%8A%E6%98%AF%E5%9C%A8%20imx6%20%E4%B9%8B%E5%A4%96%E8%BF%9B%E8%A1%8C%E8%A7%86%E9%A2%91%E6%B7%B7%E5%90%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B0%86%E6%9B%B4%E6%B7%B1%E5%85%A5%E5%9C%B0%E7%A0%94%E7%A9%B6%E6%82%A8%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%B7%91%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%9C%80%E6%96%B0%E7%9A%84%20ipu%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8A%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%A4%84%E7%90%86%E5%99%A8%E5%8F%AA%E8%83%BD%E6%8E%A5%E5%8F%97%E4%BB%A5%E4%B8%8B%E6%A0%BC%E5%BC%8F%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CPRE%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2013.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%20font-weight%3A%20bold%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230066bb%3B%20font-weight%3A%20bold%3B%22%3E_ipu_pixfmt_to_map%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23888888%3B%20font-weight%3A%20bold%3B%22%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%7B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Eswitch%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efmt%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%7B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ec%3CBR%20%2F%3Ease%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_GENERIC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_RGB24%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_RGB666%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_YUV444%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_RGB565%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_LVDS666%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_VYUY%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E6%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_UYVY%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_YUYV%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E10%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_YVYU%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E12%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_GBR24%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_VYU444%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E13%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ecase%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23336699%3B%22%3EIPU_PIX_FMT_BGR24%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E14%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22%22%3E%7D%3CBR%20%2F%3E%3C%2FSPAN%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008800%3B%20font-weight%3A%20bold%3B%22%3Ereturn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%230000dd%3B%20font-weight%3A%20bold%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%7D%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3Fh%3Dimx_4.1.15_2.0.0_ga%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2Ftree%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3Fh%3Dimx_4.1.15_2.0.0_ga%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eipu_disp.c%5Cipu3%5Cmxc%5Cdrivers%20-%20linux-imx%20-%20i.MX%20Linux%20%E5%86%85%E6%A0%B8%3C%2FA%3E%E4%B8%8A%E7%9A%84%E4%B8%8A%E8%BF%B0%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E4%BD%BF%20LVDS%20%E4%B9%9F%E8%BE%93%E5%87%BA%20alpha%20%E5%80%BC%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20DP%EF%BC%88%E6%98%BE%E7%A4%BA%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%89%E8%80%8C%E4%B8%8D%E6%98%AF%20IC%EF%BC%88%E5%9B%BE%E5%83%8F%E8%BD%AC%E6%8D%A2%E5%99%A8%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%B0%86%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E8%AE%BE%E7%BD%AE%E4%B8%BARGB8888%EF%BC%88RGB32%EF%BC%89%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%E6%98%BE%E7%A4%BA%E5%BE%AE%E7%A0%81%E6%9D%A5%E6%B7%BB%E5%8A%A0%E6%96%B0%E6%A0%BC%E5%BC%8FRGBA6666%E8%BF%9B%E8%A1%8C%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%E6%98%BE%E7%A4%BA%E5%BE%AE%E7%A0%81%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E4%BB%A5%E4%B8%8B%E6%96%87%E6%A1%A3%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94019%22%20target%3D%22_blank%22%3E%E6%94%AF%E6%8C%81%20i.MX6%20BSP%20%E7%9A%84%20BT656%20%E5%92%8C%20BT1120%20%E8%BE%93%E5%87%BA%E7%9A%84%E8%A1%A5%E4%B8%81%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3ERogerio%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20LVDS%2024%20%E4%BD%8D%E7%9A%84%20imx6%EF%BC%88%E4%BB%A5%E5%8F%8A%20imx8%EF%BC%89%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%20alpa%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BC%BC%E4%B9%8E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%20RGBA8888%20%E5%88%B0%20RGBA6666%20%E7%9A%84%E8%BD%AC%E6%8D%A2%EF%BC%88%E6%88%91%E4%BB%AC%E4%B8%8D%E4%BB%8B%E6%84%8F%E8%89%B2%E5%BD%A9%E8%B4%A8%E9%87%8F%E4%B8%8B%E9%99%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%20alpha%EF%BC%89%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E8%BF%87%E5%8E%BB%E5%85%B6%E4%BB%96%E4%BA%BA%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%9C%80%E6%B1%82%EF%BC%8C%E4%BD%86%E4%BB%96%E4%BB%AC%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%AE%9E%E7%8E%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F337488%22%20target%3D%22_blank%22%3E%E6%9D%A5%E8%87%AA%20i.MX6%20%E7%9A%84%20RGBA%2FARGB%20LVDS%20%E8%BE%93%E5%87%BA%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%3CSPAN%3E%E4%BD%BF%E7%94%A8%E6%9C%AC%E6%96%87%E4%B8%AD%E7%9A%84%E6%96%B9%E6%B3%95%E8%BF%9B%E8%A1%8C%20RGBA8888%20%E5%88%B0%20RGBA6666%20%E7%9A%84%E8%BD%AC%E6%8D%A2%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20IC%20%E8%BF%98%E6%98%AF%20DP%20%E8%BD%AC%E6%8D%A2%EF%BC%9F%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%99%E6%98%AF%E5%AE%9E%E7%8E%B0%E5%AE%83%E7%9A%84%E6%9C%80%E4%BD%B3%E6%96%B9%E6%B3%95%E5%90%97%EF%BC%9F%E8%BF%98%E6%98%AF%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BB%8E%20ioctl%20%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E6%9D%A5%E5%AE%9E%E7%8E%B0%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E7%BB%99%E5%87%BA%E4%B8%80%E4%BA%9B%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B7%91%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Ftetsuomaeda%22%20target%3D%22_blank%22%3Etetsuomaeda%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20Linux%20%E7%BA%BF%E7%A8%8B%E8%B0%83%E7%94%A8%20mxc_ipu%20%E8%AE%BE%E5%A4%87%EF%BC%88%E4%BD%BF%E7%94%A8%20IOCTL%EF%BC%89%E4%B8%A4%E6%AC%A1%E3%80%82%E5%BD%93%E7%AC%AC%E4%B8%80%E4%B8%AA%20IPU%20%E7%B9%81%E5%BF%99%E6%97%B6%EF%BC%8C%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B0%86%E8%87%AA%E5%8A%A8%E9%80%89%E6%8B%A9%E7%AC%AC%E4%BA%8C%E4%B8%AA%20IPU%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%20DOC%20%E9%99%84%E4%BB%B6%EF%BC%88%E6%96%87%E4%BB%B6%20csc_exe3.zip%EF%BC%89%E4%BD%BF%E7%94%A8%E7%BA%BF%E7%A8%8B%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3ERogerio%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Rogerio-san%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%8A%B1%E6%AD%89%E6%88%91%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20QUAD%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%9C%89%E4%B8%A4%E4%B8%AA%20IPU%20%E5%8F%AF%E7%94%A8%EF%BC%81%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E8%BF%98%E6%B2%A1%E6%9C%89%E6%83%B3%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%B9%B6%E8%81%94%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AA%20IC%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%89%8D%E7%94%B0%E5%93%B2%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Ftetsuomaeda%22%20target%3D%22_blank%22%3Etetsuomaeda%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%20i.MX6%EF%BC%9F%EF%BC%88%E4%BE%8B%E5%A6%82i.MX6Quad%E3%80%81Dual%E3%80%81Dual%20Lite%EF%BC%9F%EF%BC%89%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E5%85%B7%E6%9C%89%202%20%E4%B8%AA%20IPU%20%E7%9A%84%20i.MX6%20%E7%89%88%E6%9C%AC%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AA%20IPU%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%B8%A6%E5%AE%BD%E5%B0%86%E7%BF%BB%E5%80%8D%E3%80%82%E5%AF%B9%E4%BA%8E%E5%B8%A6%E6%9C%89%20PxP%20%E7%9A%84%20i.MX6%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E6%89%A7%E8%A1%8C%20CSC%E3%80%82%E5%8F%AF%E8%BE%BE%E5%88%B0%3CA%20href%3D%22mailto%3A1080p%4050fps%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E1080p%4050fps%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3ERogerio%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Rogerio-san%2C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%AD%A3%E5%9C%A8%E5%B0%86%E8%A7%86%E9%A2%91%E6%B5%81%E4%BB%8E%20CMOS%20%E6%91%84%E5%83%8F%E6%9C%BA%E5%BD%95%E5%88%B6%E5%88%B0%20SD%20%E5%8D%A1%E3%80%82%3C%2FP%3E%3CP%3E%E6%B5%81%E7%A8%8B%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3ECamera%20%3D%26gt%3B%20CSI%20%3D%26gt%3B%20DRAM%20%3D%26gt%3B%20(IC%20%3D%26gt%3B%20DRAM)%20x%204%20%3D%26gt%3B%20VPU%3C%2FP%3E%3CP%3E%E4%B8%80%E5%BC%80%E5%A7%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E8%80%83%E8%99%91%E7%9A%84%E6%98%AF%E4%BB%A5%E4%B8%8B%E6%B5%81%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3ECamera%20%3D%26gt%3B%20CSI%20%3D%26gt%3B%20IC%20%3D%26gt%3B%20DRAM%26nbsp%3B%3D%26gt%3B%20VPU.%3C%2FP%3E%3CP%3E%E4%BD%86%E7%94%B1%E4%BA%8E%20IC%20%E8%BE%93%E5%87%BA%E7%9A%84%E9%99%90%E5%88%B6%EF%BC%88%E6%9C%80%E5%A4%A7%E4%B8%BA%201024%20x%201024%EF%BC%89%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E5%88%86%E5%89%B2%E6%B5%81%EF%BC%8C%E4%BB%A5%E4%BD%BF%E5%9B%BE%E5%83%8F%E5%A4%A7%E5%B0%8F%E5%B0%8F%E4%BA%8E%201024%20x%201024%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%B5%81%E5%88%86%E5%89%B2%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8C%E5%B0%86%2030fps%20%E7%9A%84%E5%85%A8%E9%AB%98%E6%B8%85%E6%B5%81%E4%BB%8E%20IC%20%E8%BE%93%E5%87%BA%E5%88%B0%20DRAM%20%E4%BC%BC%E4%B9%8E%E5%8F%98%E5%BE%97%E5%BE%88%E5%9B%B0%E9%9A%BE%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E9%81%BF%E5%85%8D%E5%88%86%E8%A3%82%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E8%83%BD%E8%83%BD%E5%A4%9F%E6%94%AF%E6%8C%81%20FHD%2030fps%20%E5%BD%95%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%89%8D%E7%94%B0%E5%93%B2%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Ftetsuomaeda%22%20target%3D%22_blank%22%3Etetsuomaeda%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E6%9B%B4%E5%A4%9A%E6%9C%89%E5%85%B3%E6%82%A8%E7%9A%84%E7%94%B3%E8%AF%B7%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9F%E6%82%A8%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E6%AD%A4%E8%BD%AC%E6%8D%A2%E6%89%8D%E8%83%BD%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E6%98%BE%E7%A4%BA%E8%A7%86%E9%A2%91%EF%BC%9F%E6%88%96%E8%80%85%E5%B0%86%E8%A7%86%E9%A2%91%E4%BF%9D%E5%AD%98%E5%88%B0%E6%9C%AC%E5%9C%B0%E5%AD%98%E5%82%A8%E5%99%A8%E6%88%96%E9%80%9A%E8%BF%87%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%8F%91%E9%80%81%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3ERogerio%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Rogerio-san%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%BE%84%E6%B8%85%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E5%B0%86%E6%B5%81%E5%88%86%E6%88%90%E5%9B%9B%E4%B8%AA%E9%83%A8%E5%88%86%E5%B9%B6%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E7%94%B1%E4%BA%8EIC%E5%88%B0%E7%B3%BB%E7%BB%9F%E5%86%85%E5%AD%98%E7%9A%84%E4%BC%A0%E8%BE%93%E9%80%9F%E7%8E%87%E9%99%90%E5%88%B6%EF%BC%88%E6%9C%80%E9%AB%98100Mpixels%2Fsec%EF%BC%89%EF%BC%8C%E8%BD%AC%E6%8D%A2%E5%90%8E%E7%9A%84%E6%B5%81%E7%9A%84%E5%B8%A7%E7%8E%87%E5%A4%A7%E7%BA%A6%E4%B8%BA20fps%E3%80%82%3CBR%20%2F%3E%E5%BD%93%E6%88%91%E4%BB%AC%E5%AF%B9%201280%20x%20720%20%E7%9A%84%E6%B5%81%E8%BF%9B%E8%A1%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E8%BD%AC%E6%8D%A2%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BE%97%E5%88%B0%E4%BA%86%2030fps%20%E7%9A%84%E6%B5%81%E3%80%82%3CBR%20%2F%3E%E8%99%BD%E7%84%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E2%80%9CIMX6DQRM%E2%80%9D%E8%AF%B4%E4%BB%8EIC%E5%88%B0%E7%B3%BB%E7%BB%9F%E5%86%85%E5%AD%98%E7%9A%84%E8%BE%93%E5%87%BA%E9%80%9F%E7%8E%87%E2%80%9C%E9%AB%98%E8%BE%BE100Mpixel%2Fsec%EF%BC%88%E4%BE%8B%E5%A6%82%E3%80%821920%20x%201080%2030fps)%20%E5%9C%A8%E7%AC%AC2736%E9%A1%B5%E2%80%9D%EF%BC%8C%E8%BE%93%E5%87%BAFHD%E6%B5%81%E7%9C%9F%E7%9A%84%E5%BE%88%E9%9A%BE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETetsuo.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EIC%20%E6%98%AF%E5%90%A6%E6%AF%8F%E6%AC%A1%E5%B0%86%E6%B5%81%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9C%80%E5%A4%A7%201024%20x%201024%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%5BRogerio%5D%20%E5%AE%83%E7%9A%84%E8%BE%93%E5%85%A5%E6%98%AF%EF%BC%9A4096x4096%EF%BC%8C%E8%BE%93%E5%87%BA%E6%98%AF%EF%BC%9A1024x1024%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%88%86%E5%89%B2%E5%9B%BE%E5%83%8F%E6%9D%A5%E8%B0%83%E6%95%B4%E5%85%A8%E9%AB%98%E6%B8%85%E6%B5%81%EF%BC%881920%20x%201080%EF%BC%89%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%5BRogerio%5D%20%E6%98%AF%E7%9A%84%EF%BC%8C%E9%9C%80%E8%A6%81%E5%88%86%E5%89%B2%E5%9B%BE%E5%83%8F%E3%80%82%E5%A6%82%E6%9E%9C%E7%9B%AE%E7%9A%84%E5%8F%AA%E6%98%AF%E4%B8%BA%E4%BA%86%E6%98%BE%E7%A4%BA%E5%9B%BE%E5%83%8F%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E6%98%BE%E7%A4%BA%E5%A4%84%E7%90%86%E5%99%A8%20CSC%20%E8%80%8C%E4%B8%8D%E6%98%AF%20IC%20CSC%E3%80%82%E5%9B%A0%E6%AD%A4%E6%82%A8%E4%B8%8D%E9%9C%80%E8%A6%81%E5%88%86%E5%89%B2%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3ERogerio%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8IPU%E4%B8%AD%E7%9A%84%E5%9B%BE%E5%83%8F%E8%BD%AC%E6%8D%A2%E5%99%A8%EF%BC%88IC%EF%BC%89%E6%9D%A5%E8%B0%83%E6%95%B4%E6%9D%A5%E8%87%AACMOS%E7%9B%B8%E6%9C%BA%E7%9A%84YUV%E6%B5%81%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3EIC%20%E6%98%AF%E5%90%A6%E6%AF%8F%E6%AC%A1%E5%B0%86%E6%B5%81%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9C%80%E5%A4%A7%201024%20x%201024%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%88%86%E5%89%B2%E5%9B%BE%E5%83%8F%E6%9D%A5%E8%B0%83%E6%95%B4%E5%85%A8%E9%AB%98%E6%B8%85%E6%B5%81%EF%BC%881920%20x%201080%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E6%BF%80%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%89%8D%E7%94%B0%E5%93%B2%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9IPU%E8%89%B2%E5%BD%A9%E7%A9%BA%E9%97%B4%E8%BD%AC%E6%8D%A2%E5%8F%82%E6%95%B0%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frogeriopimentel%22%20target%3D%22_blank%22%3Erogeriopimentel%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIC%E5%92%8CDP%E9%83%BD%E5%85%B7%E5%A4%87CSC%E7%9A%84%E8%83%BD%E5%8A%9B%EF%BC%8C%E9%82%A3%E4%B9%88%E5%A6%82%E4%BD%95%E5%86%B3%E5%AE%9A%E5%9C%A8%E5%93%AA%E9%87%8C%E8%BF%9B%E8%A1%8CCSC%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EZongbiaoLiao%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 01:40 AM
更新人:
