Recipes to include Amazon's Alexa Voice Services in your applications.
Step 1 : Get iMX Yocto AVS setup environment
Review the steps under Chapter 3 of the i.MX_Yocto_Project_User'sGuide.pdf on the L4.X LINUX_DOCS to prepare your host machine. Including at least the following essential Yocto packages
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo \
gcc-multilib build-essential chrpath socat libsdl1.2-dev u-boot-tools
Install the i.MX NXP AVS repo
Create/Move to a directory where you want to install the AVS yocto build enviroment.
Let's call this as <yocto_dir>
$ cd <yocto_dir>
$ repo init -u https://source.codeaurora.org/external/imxsupport/meta-avs-demos -b master -m imx-alexa-sdk-4.9.11.xml
Download the AVS BSP build environment:
$ repo sync
Step 2: Setup yocto for Alexa_SDK image with AVS-SETUP-DEMO script:
Run the avs-setup-demo script as follows to setup your environment for the imx7d-pico board:
$ MACHINE=imx7d-pico DISTRO=fsl-imx-x11 source avs-setup-demo.sh -b <build_sdk>
Where <build_sdk> is the name you will give to your build folder.
After acepting the EULA the script will prompt if you want to enable: a
Sound Card selection
The following Sound Cards are supported on the build:
- SGTL (In-board Audio Codec for PicoPi)
- 2-Mic Synaptics/Conexant
- 2-Mic TechNexion Voice Hat (with DSPConcepts SW)
The script will prompt to select the soundcard you will be using:
Which Sound Card are you going to use?
Sigmatel .............................. 1
Synaptics/Conexant .................... 2
VoiceHat (for DSPConcepts SW) ......... 3
Type the number of your selection and press Enter...
Install Alexa SDK
Next option is to select if you want to pre-install the AVS SDK software on the image.
Do you want to build/include the AVS_SDK package on this image(Y/N)?
If you select YES, then your image will contain the AVS SDK ready to use (after authentication). Note this AVS_SDK will not have WakeWord detection support, but it can be added on runtime.
If your selection was NO, then you can always manually fetch and build the AVS_SDK on runtime. All the packages dependencies will be already there, so only fetching the AVS_SDK source code and building it is required.
Install WiFi support
Te WiFi support is optional and requires to get from NXP an additional meta-picopi-wifi layer. Contact NXP to get this layer to be able to support WiFi on your image
The image will prompt:
Do you want to include WiFi support on this image(Y/N)?
Select YES if you already have the complementary meta-avs-demos-wifi layer
Finish avs-image configuration
At the end you will see a text according with the configuration you select for your image build.
Next is an example for a Preinstalled AVS_SDK with Synaptics Sound Card support and WiFi/BT not enabled for PicoPi board.
AVS configuration is now ready at conf/local.conf
- Sound Card = Synaptics
- Alexa SDK 1.7 pre-installed
- Wifi supported
You are ready to bitbake your AVS demo image now:
bitbake avs-image
If you want to use QT5DisplayCards, use then:
bitbake avs-image-qt5
Step 3: Build the AVS image
Go to your <build_sdk> directory and start the build of the avs-image
There are 2 options
Regular Build:
$ cd <yocto_dir>/<build_sdk>
$ bitbake avs-image
With QT5 support included:
$ bitbake avs-image-qt5
The image with QT5 is useful if you want to add some GUI for example to render DisplayCards.
Step 4 : Deploying the built images to SD/MMC card to boot on target board.
After a build has succesfully completed, the created image resides at
<build_sdk>/tmp/deploy/images/imx7d-pico/
In this directory, you will find imx7d-pico-avs--.sdcard image or imx7d-pico-avs-qt5--.sdcard, depending on the build you chose on Step3.
To Flash the .sdcard image into the eMMC device of your PicoPi board follow the next steps:
Download the bootbomb flasher
Follow the instruction on Section 4. Board Reflashing of the Quick Start Guide for AVS kit to setup your board on flashing mode.
Copy the built SDCARD file
$ sudo dd if=imx7d-pico-avs.sdcard of=/dev/sd<partition> bs=1M && sync
$ sync
Properly eject the pico-imx7d board:
$ sudo eject /dev/sd<partition>
NXP Documentation
Refer to the Quick Start Quide for AVS SDK to fully setup your PicoPi board with Synaptics 2Mic and PicoPi i.mx7D
For a more comprehensive understanding of Yocto, its features and setup; more image build and deployment options and customization, please take a look at the i.MX_Yocto_Project_User's_Guide.pdf document from the Linux documents bundle mentioned at the beginning of this document.
For a more detailed description of the Linux BSP, u-boot use and configuration, please take a look at the i.MX_Linux_User's_Guide.pdf document from the Linux documents bundle mentioned at the beginning of this document.
