Build Alexa SDK (AVS) image for i.mx7D PicoPi board (with Yocto Morty, Kernel4.9)
Recipes to include Amazon's Alexa Voice Services in your applications.
Step 1 : Get iMX Yocto AVS setup environment
Review the steps under Chapter 3 of the i.MX_Yocto_Project_User'sGuide.pdf on the L4.X LINUX_DOCS to prepare your host machine. Including at least the following essential Yocto packages
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo \
  gcc-multilib build-essential chrpath socat libsdl1.2-dev u-boot-tools
Install the i.MX NXP AVS repo
Create/Move to a directory where you want to install the AVS yocto build enviroment.
Let's call this as <yocto_dir>
$ cd <yocto_dir>
$ repo init -u https://source.codeaurora.org/external/imxsupport/meta-avs-demos -b master -m imx-alexa-sdk-4.9.11.xml
Download the AVS BSP build environment:
$ repo sync
Step 2: Setup yocto for Alexa_SDK image with AVS-SETUP-DEMO script:
Run the avs-setup-demo script as follows to setup your environment for the imx7d-pico board:
$ MACHINE=imx7d-pico DISTRO=fsl-imx-x11 source avs-setup-demo.sh -b <build_sdk>
Where <build_sdk> is the name you will give to your build folder.
After acepting the EULA the script will prompt if you want to enable: a
Sound Card selection
The following Sound Cards are supported on the build:
  • SGTL (In-board Audio Codec for PicoPi)
  • 2-Mic Synaptics/Conexant
  • 2-Mic TechNexion Voice Hat (with DSPConcepts SW)
The script will prompt to select the soundcard you will be using:
Which Sound Card are you going to use?
Sigmatel .............................. 1
Synaptics/Conexant .................... 2
VoiceHat (for DSPConcepts SW) ......... 3
Type the number of your selection and press Enter...
Install Alexa SDK
Next option is to select if you want to pre-install the AVS SDK software on the image.
Do you want to build/include the AVS_SDK package on this image(Y/N)?
If you select YES, then your image will contain the AVS SDK ready to use (after authentication). Note this AVS_SDK will not have WakeWord detection support, but it can be added on runtime.
If your selection was NO, then you can always manually fetch and build the AVS_SDK on runtime. All the packages dependencies will be already there, so only fetching the AVS_SDK source code and building it is required.
Install WiFi support
Te WiFi support is optional and requires to get from NXP an additional meta-picopi-wifi layer. Contact NXP to get this layer to be able to support WiFi on your image
The image will prompt:
Do you want to include WiFi support on this image(Y/N)?
Select YES if you already have the complementary meta-avs-demos-wifi layer
Finish avs-image configuration
At the end you will see a text according with the configuration you select for your image build.
Next is an example for a Preinstalled AVS_SDK with Synaptics Sound Card support and WiFi/BT not enabled for PicoPi board.
AVS configuration is now ready at conf/local.conf
- Sound Card = Synaptics
- Alexa SDK 1.7 pre-installed
- Wifi supported
You are ready to bitbake your AVS demo image now:
bitbake avs-image
If you want to use QT5DisplayCards, use then:
bitbake avs-image-qt5
Step 3: Build the AVS image
Go to your <build_sdk> directory and start the build of the avs-image
There are 2 options
  • Regular Build:
    $ cd  <yocto_dir>/<build_sdk>
    $ bitbake avs-image
  • With QT5 support included:
    $ bitbake avs-image-qt5
The image with QT5 is useful if you want to add some GUI for example to render DisplayCards.
Step 4 : Deploying the built images to SD/MMC card to boot on target board.
After a build has succesfully completed, the created image resides at
<build_sdk>/tmp/deploy/images/imx7d-pico/
In this directory, you will find imx7d-pico-avs--.sdcard image or imx7d-pico-avs-qt5--.sdcard, depending on the build you chose on Step3.
To Flash the .sdcard image into the eMMC device of your PicoPi board follow the next steps:
  • Download the bootbomb flasher
  • Follow the instruction on Section 4. Board Reflashing of the Quick Start Guide for AVS kit to setup your board on flashing mode.
  • Copy the built SDCARD file
    $ sudo dd if=imx7d-pico-avs.sdcard of=/dev/sd<partition> bs=1M && sync
    $ sync
  • Properly eject the pico-imx7d board:
    $ sudo eject /dev/sd<partition>
NXP Documentation
Refer to the Quick Start Quide for AVS SDK to fully setup your PicoPi board with Synaptics 2Mic and PicoPi i.mx7D
For a more comprehensive understanding of Yocto, its features and setup; more image build and deployment options and customization, please take a look at the i.MX_Yocto_Project_User's_Guide.pdf document from the Linux documents bundle mentioned at the beginning of this document.
For a more detailed description of the Linux BSP, u-boot use and configuration, please take a look at the i.MX_Linux_User's_Guide.pdf document from the Linux documents bundle mentioned at the beginning of this document.
Comments
I appreciate the build instructions but as of August 22, 2018 a number of the upstream packages do not download rendering the demo unbuildable.
Following these instructions, I get:
1699:Installing perl-module-e.. ######################################## [ 99%]
1700:Installing perl-module-e.. ######################################## [ 99%]
1701:Installing perl-module-e.. ######################################## [ 99%]
1702:Installing perl-module-e.. ######################################## [ 99%]
1703:Installing perl-module-e.. ######################################## [ 99%]
1704:Installing perl-module-e.. ######################################## [ 99%]
1705:Installing perl-module-e.. ######################################## [ 99%]
1706:Installing perl-module-e.. ######################################## [100%]
error: Unknown error
util-linux-sfdisk
util-linux-sulogin
util-linux-swaponoff
util-linux-umount
v4l-utils
valgrind
vlan
volatile-binds
wireless-tools
wpa-supplicant
wpa-supplicant-cli
wpa-supplicant-passphrase
x11perf
x11vnc
xauth
xcursor-transparent-theme
xdotool
xdpyinfo
xf86-input-evdev
xf86-video-fbdev
xhost
xinit
xinput
xinput-calibrator
xkbcomp
xkeyboard-config
xmodmap
xprop
xrandr
xrestop
xserver-common
xserver-nodm-init
xserver-xf86-config
xserver-xorg
xset
xvideo-tests
xwininfo
2759.3MB of package files are needed. 3330.6MB will be used.
DEBUG: avs-image-1.0-r0 do_rootfs: Python function do_rootfs finished
ERROR: avs-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /media/leisner/vdi/src/better-boards/mailnote/with-avs/tmp/work/imx7d_pico-poky-linux-gnueabi/avs-image/1.0-r0/temp/log.do_rootfs.30847
ERROR: Task (/media/leisner/vdi/src/better-boards/mailnote/sources/meta-avs-demos/recipes-avs/images/avs-image.bb:do_rootfs) failed with exit code '1'
DEBUG: Teardown for bitbake-worker
NOTE: Tasks Summary: Attempted 7984 tasks of which 7983 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
when I include the AVS sdk...
Unfortunately "unknown error" doesn't give much guidance.
No ratings
Version history
Last update:
‎09-10-2020 02:57 AM
Updated by:
