Ara240 - LPDDR4 Memory Compatibility Guide
The purpose of this document is to provide extended guidance for selection of compatible LPDDR4 memory devices that are supported by the Ara240 (aka Ara-2) processors. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the specific SoC requirement documents.
LPDDR4 - maximum supported densities
SoC Max Data bus width Maximum density Number of Interfaces Assumed memory organization Notes
Ara240 64-bit 128Gb/16GB 2
Dual rank,
Dual channel device with 17-row addresses
1
LPDDR4 - list of validated memories
The validation process is an ongoing effort - regular updates of the table are expected.
SoC Density Memory Vendor Validated Memory Part# Notes
Ara240
64Gb/(8GB)
Total 128Gb/(16GB)
(2 x 64Gb/8GB)
Micron
MT53E2G32D4DE-046 AUT:C
MT53E2G32D4DE-046 WT:C
64Gb/(8GB)
Total 128Gb/(16GB)
(2 x 64Gb/8GB)
FORESEE
FLXC4008G-30  2
16Gb/(2GB)
Total: 32Gb/(4GB)
(2 x 16Gb/2GB)
Micron
MT53E512M32D1ZW-046BAUT:B
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
Micron
MT53E1G32D2NP-046 WT:B
16Gb/(2GB)
Total: 32Gb/(4GB)
(2 x 16Gb/2GB)
SK Hynix
H54G46CYRQX053N
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
SK Hynix
H54G56CYRB-X247 421Y
H54G56CYRB-X247 316A
4Gb/(512MB)
Total 8Gb/1GB
(2 x 4Gb/1GB)
SK Hynix
H54G26AYRBX256
16Gb/(2GB)
Total: 32Gb/(4GB)
(2 x 16Gb/2GB)
Samsung
K4F6E3S4HB-KHCL
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
ISSI
IS43LQ32K01B
2
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
Samsung
K4UBE3D4AB-MGCL
8Gb/(1GB)
Total 16Gb/2GB
(2 x 8Gb/1GB)
Winbond
W66DP2RQQAHJ
2
Note: This device supports operation with LPDDR4 memories only. LPDDR4x operation is not supported.
Dual‑mode memories that support both LPDDR4 and LPDDR4x are allowed as long as the device can operate in LPDDR4 mode,
including using LPDDR4 I/O voltage levels and initialization sequences.
Note 1:
The numbers are based purely on the IP documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, SoC reference manual and on the JEDEC standards JESD209-4C (LPDDR4). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk.
Note 2:
The memory part number did not undergo full JEDEC verification however, it passed all functional testing items.
Note 3:
Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity.
Note 4:
All memory parts are in production unless stated otherwise. Checked June 2026
Note 5:
The processor does not support BYTE Mode (x8) memories.
コメント
%3CLINGO-SUB%20id%3D%22lingo-sub-2292171%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAra240%20-%20LPDDR4%E3%83%A1%E3%83%A2%E3%83%AA%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%AC%E3%82%A4%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292171%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E6%96%87%E6%9B%B8%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81Ara240%EF%BC%88%E5%88%A5%E5%90%8DAra-2%EF%BC%89%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8BLPDDR4%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AESoC%E8%A6%81%E4%BB%B6%E6%96%87%E6%9B%B8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BDRAM%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%82%92%E5%BC%B7%E3%81%8F%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1229582247%22%20id%3D%22toc-hId-2006054835%22%20id%3D%22toc-hId-2032927348%22%20id%3D%22toc-hId-2032927348%22%3ELPDDR4%20-%20%E6%9C%80%E5%A4%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%AF%86%E5%BA%A6%3C%2FH3%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%9C%80%E5%A4%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%B9%E5%B9%85%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%9C%80%E5%A4%A7%E5%AF%86%E5%BA%A6%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E6%95%B0%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E8%A8%98%E6%86%B6%E6%A7%8B%E9%80%A0%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E8%A8%98%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%83%A9240%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E64%E3%83%93%E3%83%83%E3%83%88%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E128GB%2F16GB%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%E3%80%81%20%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E17%E8%A1%8C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%8C%81%E3%81%A4%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E1%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH3%20id%3D%22toc-hId-198600372%22%20id%3D%22toc-hId-225472885%22%20id%3D%22toc-hId-225472885%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--577872216%22%20id%3D%22toc-hId--1608854091%22%20id%3D%22toc-hId--1581981578%22%20id%3D%22toc-hId--1581981578%22%3ELPDDR4%20-%20%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3E%E6%A4%9C%E8%A8%BC%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AA%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%A1%A8%E3%81%AE%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AA%E6%9B%B4%E6%96%B0%E3%81%8C%E4%BA%88%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CTABLE%20style%3D%22height%3A%201669px%3B%20width%3A%20100%25%3B%22%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2215%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22width%3A%2015%25%3B%20height%3A%2067px%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E5%AF%86%E5%BA%A6%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E8%A8%98%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20rowspan%3D%229%22%20width%3D%2215%25%22%20height%3D%221602px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%83%A9240%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E64GB%3C%2FSTRONG%3E%20%2F%20(8GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%3CSTRONG%3E128GB%3C%2FSTRONG%3E%20%2F%20(16GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%EF%BC%8864GB%C3%972%2F8GB%EF%BC%89%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%E3%83%9F%E3%82%AF%E3%83%AD%E3%83%B3%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e2g32d4de-046-aut-c%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMT53E2G32D4DE-046%20AUT%3AC%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e2g32d4de-046-wt-c%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMT53E2G32D4DE-046%20WT%3AC%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E64GB%3C%2FSTRONG%3E%20%2F%20(8GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%3CSTRONG%3E128GB%3C%2FSTRONG%3E%20%2F%20(16GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%EF%BC%8864GB%C3%972%2F8GB%EF%BC%89%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%E4%BA%88%E8%A6%8B%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22font-weight%3A%20400%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.longsys.com%2Fproducts%2Fembedded-storage%2Fembedded-storage%2Flpddr.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFLXC4008G-30%3C%2FA%3E%3C%2FFONT%3E%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E16GB%3C%2FSTRONG%3E%20%2F%20(2GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%EF%BC%9A%20%3CSTRONG%3E32GB%3C%2FSTRONG%3E%20%2F%20(4GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2016GB%2F2GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%E3%83%9F%E3%82%AF%E3%83%AD%E3%83%B3%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EMT53E512M32D1ZW-046BAUT%3AB%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E16GB%3C%2FSTRONG%3E%20%2F%20(2GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%EF%BC%9A%20%3CSTRONG%3E32GB%3C%2FSTRONG%3E%20%2F%20(4GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2016GB%2F2GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ESK%E3%83%8F%E3%82%A4%E3%83%8B%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EH54G46CYRQX053N%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E32GB%3C%2FSTRONG%3E%20%2F%20(4GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%3CSTRONG%3E64GB%3C%2FSTRONG%3E%20%2F%208GB%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%EF%BC%882%20x%2032GB%2F4GB%EF%BC%89%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ESK%E3%83%8F%E3%82%A4%E3%83%8B%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EH54G56CYRB-X247%20421Y%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E16GB%3C%2FSTRONG%3E%20%2F%20(2GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%EF%BC%9A%20%3CSTRONG%3E32GB%3C%2FSTRONG%3E%20%2F%20(4GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2016GB%2F2GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%E3%82%B5%E3%83%A0%E3%82%B9%E3%83%B3%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EK4F6E3S4HB-KHCL%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E32GB%3C%2FSTRONG%3E%20%2F%20(4GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%3CSTRONG%3E64GB%3C%2FSTRONG%3E%20%2F%208GB%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%EF%BC%882%20x%2032GB%2F4GB%EF%BC%89%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EISSI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EIS43LQ32K01B%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E32GB%3C%2FSTRONG%3E%20%2F%20(4GB)%3C%2FP%3E%0A%3CP%3E%E5%90%88%E8%A8%88%3CSTRONG%3E64GB%3C%2FSTRONG%3E%20%2F%208GB%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%EF%BC%882%20x%2032GB%2F4GB%EF%BC%89%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%E3%82%B5%E3%83%A0%E3%82%B9%E3%83%B3%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EK4UBE3D4AB-MGCL%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E-%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E8GB%3C%2FSTRONG%3E%20%2F%20(1GB)%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%E5%90%88%E8%A8%88%3CSTRONG%3E16GB%3C%2FSTRONG%3E%20%2F%202GB%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E(2%20x%208GB%2F1GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%9C%E3%83%B3%E3%83%89%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.winbond.com%2Fhq%2Fnew-online-purchasing-guide%2Findex.html%3F__locale%3Den%26amp%3BpLine%3D%2Fproduct%2Fcustomized-memory-solution%2Flpddr-lpsdr%2F%26amp%3BpNo%3DW66DP2RQQ%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CFONT%20size%3D%222%22%3EW66DP2RQQAHJ%3C%2FFONT%3E%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%3CSTRONG%3ENote%3A%3C%2FSTRONG%3E%20%3CFONT%20color%3D%22%230000FF%22%3EThis%20device%20supports%20operation%20with%20LPDDR4%20memories%20only.%20LPDDR4x%20operation%20is%20not%20supported.%20%3CBR%20%2F%3E%3C%2FFONT%3E%3CFONT%20color%3D%22%230000FF%22%3EDual%E2%80%91mode%20memories%20that%20support%20both%20LPDDR4%20and%20LPDDR4x%20are%20allowed%20as%20long%20as%20the%20device%20can%20operate%20in%20LPDDR4%20mode%2C%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3Eincluding%20using%20LPDDR4%20I%2FO%20voltage%20levels%20and%20initialization%20sequences.%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%AF%E3%80%81DDR%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8DDR%20PHY%E3%81%AEIP%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%81SoC%E3%81%B8%E3%81%AE%E7%B5%B1%E5%90%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E5%AE%9F%E8%A3%85%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%81SoC%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3JEDEC%E8%A6%8F%E6%A0%BCJESD209-4C%EF%BC%88LPDDR4%EF%BC%89%E3%81%AE%E3%81%BF%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E7%89%B9%E3%81%AB%E6%98%8E%E8%A8%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E6%A4%9C%E8%A8%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A3%8F%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%8C%E7%89%B9%E5%AE%9A%E3%81%AE%E5%AF%86%E5%BA%A6%E3%82%84%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E5%86%85%E9%83%A8%E6%A7%8B%E6%88%90%E3%82%92%E5%82%99%E3%81%88%E3%81%9FSoC%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E4%BF%9D%E8%A8%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%9C%80%E5%A4%A7%E5%AF%86%E5%BA%A6%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E4%BD%BF%E7%94%A8%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E6%83%B3%E5%AE%9A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E8%87%AA%E8%BA%AB%E3%81%AE%E8%B2%AC%E4%BB%BB%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E5%BD%93%E8%A9%B2%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AFJEDEC%E8%A6%8F%E6%A0%BC%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E6%A4%9C%E8%A8%BC%E3%82%92%E5%8F%97%E3%81%91%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E8%83%BD%E3%83%86%E3%82%B9%E3%83%88%E9%A0%85%E7%9B%AE%E3%81%AB%E5%90%88%E6%A0%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%B3%A83%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E5%AF%86%E5%BA%A6%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%811GB%E3%80%812GB%E3%80%814GB%EF%BC%89%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E6%96%B9%E5%BC%8F%E3%81%A8%E6%95%B4%E5%90%88%E3%81%97%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A4%87%E9%9B%91%E3%81%95%E3%82%92%E8%BB%BD%E6%B8%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%B0%A1%E7%B4%A0%E5%8C%96%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%A5%BD%E3%81%BE%E3%81%97%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSTRONG%3E%E6%B3%A84%EF%BC%9A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E7%89%B9%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%8C%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E9%83%A8%E5%93%81%E3%81%AF%E7%94%9F%E7%94%A3%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%822026%E5%B9%B45%E6%9C%88%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSTRONG%3E%E6%B3%A85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AF%E3%83%90%E3%82%A4%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%88x8%EF%BC%89%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ara240%20-%20LPDDR4%20Memory%20Compatibility%20Guide%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%BB%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAra-240-NVM-Memory-Compatibility-Guide%2Fta-p%2F2384132%22%20target%3D%22_blank%22%3EAra-240%20-%20NVM%E3%83%A1%E3%83%A2%E3%83%AA%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎06-22-2026 04:19 AM
更新者:
