Ara240 - LPDDR4 Memory Compatibility Guide
The purpose of this document is to provide extended guidance for selection of compatible LPDDR4 memory devices that are supported by the Ara240 (aka Ara-2) processors. In all cases, it is strongly recommended to follow the DRAM layout guidelines outlined in the specific SoC requirement documents.
LPDDR4 - maximum supported densities
SoC Max Data bus width Maximum density Number of Interfaces Assumed memory organization Notes
Ara240 64-bit 128Gb/16GB 2
Dual rank,
Dual channel device with 17-row addresses
1
LPDDR4 - list of validated memories
The validation process is an ongoing effort - regular updates of the table are expected.
SoC Density Memory Vendor Validated Memory Part# Notes
Ara240
64Gb/(8GB)
Total 128Gb/(16GB)
(2 x 64Gb/8GB)
Micron
MT53E2G32D4DE-046 AUT:C
MT53E2G32D4DE-046 WT:C
64Gb/(8GB)
Total 128Gb/(16GB)
(2 x 64Gb/8GB)
FORESEE
FLXC4008G-30  2
16Gb/(2GB)
Total: 32Gb/(4GB)
(2 x 16Gb/2GB)
Micron
MT53E512M32D1ZW-046BAUT:B
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
Micron
MT53E1G32D2NP-046 WT:B
16Gb/(2GB)
Total: 32Gb/(4GB)
(2 x 16Gb/2GB)
SK Hynix
H54G46CYRQX053N
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
SK Hynix
H54G56CYRB-X247 421Y
H54G56CYRB-X247 316A
4Gb/(512MB)
Total 8Gb/1GB
(2 x 4Gb/1GB)
SK Hynix
H54G26AYRBX256
16Gb/(2GB)
Total: 32Gb/(4GB)
(2 x 16Gb/2GB)
Samsung
K4F6E3S4HB-KHCL
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
ISSI
IS43LQ32K01B
2
32Gb/(4GB)
Total 64Gb/8GB
(2 x 32Gb/4GB)
Samsung
K4UBE3D4AB-MGCL
8Gb/(1GB)
Total 16Gb/2GB
(2 x 8Gb/1GB)
Winbond
W66DP2RQQAHJ
2
Note: This device supports operation with LPDDR4 memories only. LPDDR4x operation is not supported.
Dual‑mode memories that support both LPDDR4 and LPDDR4x are allowed as long as the device can operate in LPDDR4 mode,
including using LPDDR4 I/O voltage levels and initialization sequences.
Note 1:
The numbers are based purely on the IP documentation for the DDR Controller and the DDR PHY, on the settings of the implementation parameters chosen for their integration into the SoC, SoC reference manual and on the JEDEC standards JESD209-4C (LPDDR4). Therefore, they are not backed by validation, unless said otherwise and there is no guarantee that an SoC with the specific density and/or desired internal organization is offered by the memory vendors. Should the customers choose to use the maximum density and assume it in the intended use case, they do it at their own risk.
Note 2:
The memory part number did not undergo full JEDEC verification however, it passed all functional testing items.
Note 3:
Memory devices with binary densities (e.g., 1 GB, 2 GB, 4 GB) are preferred because they simplify memory management by aligning with system addressing schemes and reducing software complexity.
Note 4:
All memory parts are in production unless stated otherwise. Checked June 2026
Note 5:
The processor does not support BYTE Mode (x8) memories.
Comments
%3CLINGO-SUB%20id%3D%22lingo-sub-2292171%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAra240%20-%20LPDDR4%20Memory%20Compatibility%20Guide%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292171%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%3CP%3E%3CSPAN%3EThe%20purpose%20of%20this%20document%20is%20to%20provide%20extended%20guidance%20for%20selection%20of%20compatible%20LPDDR4%20memory%20devices%20that%20are%20supported%20by%20the%20Ara240%20(aka%20Ara-2)%20processors.%26nbsp%3BIn%20all%20cases%2C%20it%20is%20strongly%20recommended%20to%20follow%20the%20DRAM%20layout%20guidelines%20outlined%20in%20the%20specific%20SoC%20requirement%20documents.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1229582247%22%20id%3D%22toc-hId-2006054835%22%20id%3D%22toc-hId-2031919161%22%20id%3D%22toc-hId-2031919161%22%3ELPDDR4%20-%20maximum%20supported%20densities%3C%2FH3%3E%0A%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EMax%20Data%20bus%20width%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EMaximum%20density%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ENumber%20of%20Interfaces%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EAssumed%20memory%20organization%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2269px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ENotes%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EAra240%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E64-bit%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E128Gb%2F16GB%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%0A%3CTD%20width%3D%2210%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EDual%20rank%2C%20%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EDual%20channel%20device%20with%2017-row%20addresses%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%2220%25%22%20height%3D%2225px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E1%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH3%20id%3D%22toc-hId-198600372%22%20id%3D%22toc-hId-224464698%22%20id%3D%22toc-hId-224464698%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--577872216%22%20id%3D%22toc-hId--1608854091%22%20id%3D%22toc-hId--1582989765%22%20id%3D%22toc-hId--1582989765%22%3ELPDDR4%20-%20list%20of%20validated%20memories%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3EThe%20validation%20process%20is%20an%20ongoing%20effort%20-%20regular%20updates%20of%20the%20table%20are%20expected.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CTABLE%20style%3D%22height%3A%201669px%3B%20width%3A%20100%25%3B%22%20border%3D%221%22%20width%3D%22100%25%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2215%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22width%3A%2015%25%3B%20height%3A%2067px%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EDensity%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EMemory%20Vendor%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EValidated%20Memory%20Part%23%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%2267px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ENotes%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20rowspan%3D%2211%22%20width%3D%2215%25%22%20height%3D%221602px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3EAra240%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E64Gb%3C%2FSTRONG%3E%2F(8GB)%3C%2FP%3E%0A%3CP%3ETotal%20%3CSTRONG%3E128Gb%3C%2FSTRONG%3E%2F(16GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%26nbsp%3B64Gb%2F8GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EMicron%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e2g32d4de-046-aut-c%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMT53E2G32D4DE-046%20AUT%3AC%26nbsp%3B%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e2g32d4de-046-wt-c%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMT53E2G32D4DE-046%20WT%3AC%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22206px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E64Gb%3C%2FSTRONG%3E%2F(8GB)%3C%2FP%3E%0A%3CP%3ETotal%20%3CSTRONG%3E128Gb%3C%2FSTRONG%3E%2F(16GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%26nbsp%3B64Gb%2F8GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EFORESEE%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22font-weight%3A%20400%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.longsys.com%2Fproducts%2Fembedded-storage%2Fembedded-storage%2Flpddr.html%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFLXC4008G-30%26nbsp%3B%3C%2FA%3E%3C%2FFONT%3E%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E16Gb%3C%2FSTRONG%3E%2F(2GB)%3C%2FP%3E%0A%3CP%3ETotal%3A%20%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2016Gb%2F2GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EMicron%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EMT53E512M32D1ZW-046BAUT%3AB%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3ETotal%20%3CSTRONG%3E64Gb%3C%2FSTRONG%3E%2F8GB%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E(2%20x%2032Gb%2F4GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EMicron%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3EMT53E1G32D2NP-046%20WT%3AB%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E16Gb%3C%2FSTRONG%3E%2F(2GB)%3C%2FP%3E%0A%3CP%3ETotal%3A%20%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2016Gb%2F2GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ESK%20Hynix%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EH54G46CYRQX053N%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%3ETotal%20%3CSTRONG%3E64Gb%3C%2FSTRONG%3E%2F8GB%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2032Gb%2F4GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ESK%20Hynix%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EH54G56CYRB-X247%20421Y%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EH54G56CYRB-X247%20316A%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E4Gb%3C%2FSTRONG%3E%2F(512MB)%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3ETotal%20%3CSTRONG%3E8Gb%3C%2FSTRONG%3E%2F1GB%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E(2%20x%204Gb%2F1GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3ESK%20Hynix%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3EH54G26AYRBX256%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E16Gb%3C%2FSTRONG%3E%2F(2GB)%3C%2FP%3E%0A%3CP%3ETotal%3A%20%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2016Gb%2F2GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3ESamsung%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EK4F6E3S4HB-KHCL%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B-%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%3ETotal%20%3CSTRONG%3E64Gb%3C%2FSTRONG%3E%2F8GB%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2032Gb%2F4GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3EISSI%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EIS43LQ32K01B%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CSTRONG%3E32Gb%3C%2FSTRONG%3E%2F(4GB)%3C%2FP%3E%0A%3CP%3ETotal%20%3CSTRONG%3E64Gb%3C%2FSTRONG%3E%2F8GB%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E(2%20x%2032Gb%2F4GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3ESamsung%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EK4UBE3D4AB-MGCL%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22151px%22%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%0A%3CP%3E-%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%2225%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E8Gb%3C%2FSTRONG%3E%2F(1GB)%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3ETotal%20%3CSTRONG%3E16Gb%3C%2FSTRONG%3E%2F2GB%3C%2FP%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CFONT%20size%3D%222%22%3E(2%20x%208Gb%2F1GB)%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3EWinbond%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%226.25%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.winbond.com%2Fhq%2Fnew-online-purchasing-guide%2Findex.html%3F__locale%3Den%26amp%3BpLine%3D%2Fproduct%2Fcustomized-memory-solution%2Flpddr-lpsdr%2F%26amp%3BpNo%3DW66DP2RQQ%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CFONT%20size%3D%222%22%3EW66DP2RQQAHJ%3C%2FFONT%3E%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%229.290703275529864%25%22%20height%3D%22188px%22%3E%0A%3CP%20class%3D%22lia-align-center%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%20style%3D%22text-align%3A%20center%3B%22%3E2%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CPRE%3E%3CSPAN%3E%3CSTRONG%3ENote%3A%3C%2FSTRONG%3E%20%3CFONT%20color%3D%22%230000FF%22%3EThis%20device%20supports%20operation%20with%20LPDDR4%20memories%20only.%20LPDDR4x%20operation%20is%20not%20supported.%20%3CBR%20%2F%3E%3C%2FFONT%3E%3CFONT%20color%3D%22%230000FF%22%3EDual%E2%80%91mode%20memories%20that%20support%20both%20LPDDR4%20and%20LPDDR4x%20are%20allowed%20as%20long%20as%20the%20device%20can%20operate%20in%20LPDDR4%20mode%2C%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3Eincluding%20using%20LPDDR4%20I%2FO%20voltage%20levels%20and%20initialization%20sequences.%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3ENote%201%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EThe%20numbers%20are%20based%20purely%20on%20the%20IP%20documentation%20for%20the%20DDR%20Controller%20and%20the%20DDR%20PHY%2C%20on%20the%20settings%20of%20the%20implementation%20parameters%20chosen%20for%20their%20integration%20into%20the%20SoC%2C%20SoC%20reference%20manual%20and%20on%20the%20JEDEC%20standards%20JESD209-4C%20(LPDDR4).%20Therefore%2C%20they%20are%20not%20backed%20by%20validation%2C%20unless%20said%20otherwise%20and%20there%20is%20no%20guarantee%20that%20an%20SoC%20with%20the%20specific%20density%20and%2For%20desired%20internal%20organization%20is%20offered%20by%20the%20memory%20vendors.%20Should%20the%20customers%20choose%20to%20use%20the%20maximum%20density%20and%20assume%20it%20in%20the%20intended%20use%20case%2C%20they%20do%20it%20at%20their%20own%20risk.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ENote%202%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EThe%20memory%20part%20number%20did%20not%20undergo%20full%20JEDEC%20verification%20however%2C%20it%20passed%20all%20functional%20testing%20items.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ENote%203%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E%3CSPAN%3EMemory%20devices%20with%20binary%20densities%20(e.g.%2C%201%20GB%2C%202%20GB%2C%204%20GB)%20are%20preferred%20because%20they%20simplify%20memory%20management%20by%20aligning%20with%20system%20addressing%20schemes%20and%20reducing%20software%20complexity.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSTRONG%3ENote%204%3A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EAll%20memory%20parts%20are%20in%20production%20unless%20stated%20otherwise.%20Checked%20June%202026%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%223%22%3E%3CSTRONG%3ENote%205%3A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3EThe%20processor%20does%20not%20support%20BYTE%20Mode%20(x8)%20memories.%26nbsp%3B%3C%2FFONT%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ara240%20-%20LPDDR4%20Memory%20Compatibility%20Guide%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECross%20reference%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAra-240-NVM-Memory-Compatibility-Guide%2Fta-p%2F2384132%22%20target%3D%22_blank%22%3EAra-240%20-%20NVM%20Memory%20Compatibility%20Guide%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎06-22-2026 04:19 AM
Updated by:
