All Boards LTIB Config Ubuntu
Ubuntu distro uses dash instead of bash as shell, then change it to bash:
# cd /bin
# sudo rm sh
# sudo ln -s bash sh
Install all necessary packages by typing:
sudo apt-get install patch g++ rpm zlib1g-dev m4 bison libncurses5-dev libglib2.0-dev gettext \
build-essential tcl intltool libxml2-dev liborbit2-dev libx11-dev ccache flex uuid-dev liblzo2-dev
If under Ubuntu 64bit, install ia32-libs package:
sudo apt-get install ia32-libs
  • If you will install Xorg in your ltib, you will need to install this package:
sudo apt-get install x11proto-core-dev
  • If you will install gtk+ in your ltib, you will need to install the following packages:
sudo apt-get install libdbus-glib-1-dev libgtk2.0-dev libdbus-glib-1-dev
Configure visudo file, as root using the command "/usr/sbin/visudo", and add the following line in the User privilege section:
username ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
Where username is your user name, the name you use to do logon in your system.
Classic Error messages and solutions under Ubuntu
Can't exec "mconf": No such file or directory at /home/tic/ltib/bin/Ltibutils.pm line 972. exec: mconf /home/tic/ltib/config/main.lkc: No such file or directory at /home/tic/ltib/bin/Ltibutils.pm line 972. traceback:   Ltibutils::system_nb:972   main::get_plat_dir:2947     main:548 Started: Tue Feb 16 18:01:38 2010 Ended:  Tue Feb 16 18:59:26 2010 Elapsed: 3468 seconds Build Failed
Solution: edit the ltib script
line 925:
          # install the new package           $cmd  = "$cf->{sudo} $cf->{rpm} ";           $cmd .= "--root $cf->{rpmroot} ";           $cmd .= "--dbpath $cf->{rpmdb} ";           $cmd .= "--prefix $cf->{rpmipfx} " if $cf->{rpmipfx};           $cmd .= "--ignorearch -ivh ";           $cmd .= "--force "  unless $cf->{conflicts} || $cf->{hostinst};           $cmd .= "--replacepkgs --replacefiles " if $cf->{hostinst};           $cmd .= "--nodeps " if $cf->{nodeps};           $cmd .= "--excludedocs "; +        $cmd .= "--force-debian " if $rpm =~ m/rpm-fs/ && `uname -a` =~ m/ubuntu/i;           $cmd .= "--define '_tmppath $cf->{tmppath}' ";           $cmd .= "$rpm";
error: cannot open Name index using db3 - No such file or directory (2) error: cannot open Name index using db3 - No such file or directory (2) sudo rpm --root / --dbpath /tmp/rpm-tic/rpmdb -e --allmatches --nodeps --define '_tmppath /home/tic/ltib/tmp' rpm-fs 2>/dev/null sudo rpm --root / --dbpath /tmp/rpm-tic/rpmdb --ignorearch -ivh --force --nodeps --excludedocs --define '_tmppath /home/tic/ltib/tmp'  /tmp/rpm-tic/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm rpm: please use alien to install rpm packages on Debian, if you are really sure use --force-debian switch. See README.Debian for more details. sudo /opt/freescale/ltib/usr/bin/rpm --root / --dbpath /opt/freescale/ltib/var/lib/rpm -Uv --justdb --notriggers --noscripts --nodeps  /tmp/rpm-tic/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm sudo: /opt/freescale/ltib/usr/bin/rpm: command not found mkdir: cannot create directory `/opt/freescale': Permission denied Cannot create the download directory:   /opt/freescale/pkgs Either change to a global directory you have write permissions to, or create it as root.  Please set the permissions to 777 traceback:   main::check_dirs:2469   main::host_checks:1426     main:542 Started: Wed Nov 25 01:56:53 2009 Ended:  Wed Nov 25 02:07:42 2009 Elapsed: 649 seconds Build Failed
solution : sudo chmod 777 /opt
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8' Making all in tools make[2]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools' make[2]: *** No rule to make target `all'.  Stop. make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8' make: *** [all] Error 2 error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.U8vEdX (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.U8vEdX (%build) Build time for texinfo: 55 seconds Failed building texinfo Died at ./ltib line 1380. traceback:   main::build_host_rpms:1380   main::host_checks:1435     main:542 Started: Wed Nov 25 20:10:43 2009 Ended:  Wed Nov 25 20:31:42 2009 Elapsed: 1259 seconds These packages failed to build: texinfo Build Failed
solution : install ccache package in host
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD + cd lkc-1.4 + make -j1 conf mconf gcc -O0 -Wall -g -fPIC -c conf.c -o conf.o bison -l -b zconf -p zconf zconf.y flex -L -Pzconf zconf.l make: flex: Command not found make: *** [lex.zconf.c] Error 127 error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.010CjL (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.010CjL (%build) Build time for lkc: 2 seconds Failed building lkc Died at ./ltib line 1380. traceback:   main::build_host_rpms:1380   main::host_checks:1435     main:542 Started: Thu Nov 26 00:33:46 2009 Ended:  Thu Nov 26 01:19:39 2009 Elapsed: 2753 seconds These packages failed to build: lkc Build Failed
solution : install flex package in host
Making all in po make[2]: Entering directory `/home/tic/ltib/rpm/BUILD/alsa-utils-1.0.11rc2/alsaconf/po' mv: cannot stat `t-ja.gmo': No such file or directory make[2]: *** [ja.gmo] Error 1 make[2]: *** Waiting for unfinished jobs.... mv: cannot stat `t-ru.gmo': No such file or directory make[2]: *** [ru.gmo] Error 1 make[2]: Leaving directory `/home/tic/ltib/rpm/BUILD/alsa-utils-1.0.11rc2/alsaconf/po' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/tic/ltib/rpm/BUILD/alsa-utils-1.0.11rc2/alsaconf' make: *** [all-recursive] Error 1 error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.93730 (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.93730 (%build) Build time for alsa-utils: 84 seconds Failed building alsa-utils f_buildrpms() returned an error, exiting traceback:   main:560 Started: Sat Nov 28 07:39:40 2009 Ended:  Sat Nov 28 08:17:18 2009 Elapsed: 2258 seconds These packages failed to build: alsa-utils Build Failed Exiting on error or interrupt
solution : install package gettext and ja-trans
checking for glib-genmarshal... no configure: error: Could not find a glib-genmarshal in your PATH error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.13030 (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.13030 (%build) Build time for glib2: 107 seconds Failed building glib2 f_buildrpms() returned an error, exiting traceback:   main:560 Started: Sat Dec  5 03:19:36 2009 Ended:  Sat Dec  5 03:29:46 2009 Elapsed: 610 seconds These packages failed to build: glib2 Build Failed Exiting on error or interrupt
solution : install the package libglib2.0-dev
タグ(1)
コメント
Great Documentation :smileyhappy:
Thanks a lot,
Saurabh
Hi, i have this error :-(
util.c:(.text+0xa4d): undefined reference to `waddch'
util.c:(.text+0xa58): undefined reference to `winch'
util.c:(.text+0xa6c): undefined reference to `waddch'
util.c:(.text+0xa8b): undefined reference to `wnoutrefresh'
collect2: ld returned 1 exit status
make: ** [mconf] Erro 1
erro: Código de saída inválido do /home/lucas/ltib/tmp/rpm-tmp.75915 (%build)
Erros de criação do RPM:
Build time for lkc: 3 seconds
Failed building lkc
Died at ./ltib line 1393.
traceback:
main::build_host_rpms:1393
  main::host_checks:1448
   main:554
Started: Tue May  7 17:43:23 2013
Ended:   Tue May  7 17:55:25 2013
Elapsed: 722 seconds
lkc
Build Failed
OBS: alls packages installed correctly, but always this erro
I edited the ltib file as you said above and added the line "$cmd .= "--force-debian " if $rpm =~ m/rpm-fs/ && `uname -a` =~ m/ubuntu/i;" but it still gives the same error :
defined(@array) is deprecated at /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/bin/Ltibutils.pm line 362.
    (Maybe you should just omit the defined()?)
Useless use of numeric eq (==) in void context at ./ltib line 2519.
Can't exec "mconf": No such file or directory at /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/bin/Ltibutils.pm line 1006.
exec: mconf /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/config/main.lkc: No such file or directory at /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/bin/Ltibutils.pm line 1006.
traceback:
Ltibutils::system_nb:1006
  main::get_plat_dir:2970
   main:560
Started: Sun Mar 29 21:19:06 2015
Ended:   Sun Mar 29 21:19:06 2015
Elapsed: 0 seconds
Build Failed
Died at ./ltib line 2970.
traceback:
  main:560
Elapsed: 0 seconds
Build Failed
sarjak@sarjak-OptiPlex-7011:~/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib$
Can you please help?? It will be appreciated.
Thank you very much.
%3CLINGO-SUB%20id%3D%22lingo-sub-1128363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89LTIB%E6%A7%8B%E6%88%90Ubuntu%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EUbuntu%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%82%B7%E3%82%A7%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6bash%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%80%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92bash%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%23%20cd%20%2Fbin%0A%23%20sudo%20rm%20sh%0A%23%20sudo%20ln%20-s%20bash%20sh%0A%3C%2FPRE%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20%E3%83%91%E3%83%83%E3%83%81%20g%2B%2B%20rpm%20zlib1g-dev%20m4%20bison%20libncurses5-dev%20libglib2.0-devgettext%20%5C%0Abuild-essential%20tcl%20intltool%20libxml2-dev%20liborbit2-dev%20libx11-dev%20ccache%20flex%20uuid-dev%20liblzo2-dev%0A%3C%2FPRE%3E%3CP%3EUbuntu%2064bit%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81ia32-libs%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20ia32-libs%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%0A%3C%2FPRE%3E%3CUL%3E%3CLI%3Eltib%20%E3%81%AB%20Xorg%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20x11proto-core-dev%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FPRE%3E%3CUL%3E%3CLI%3Eltib%20%E3%81%AB%20gtk%2B%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20install%20libdbus-glib-1-dev%20libgtk2.0-dev%20libdbus-glib-1-dev%0A%3C%2FPRE%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%22%2Fusr%2Fsbin%2Fvisudo%22%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20root%20%E3%81%A8%E3%81%97%E3%81%A6%20visudo%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%20ALL%20%3D%20NOPASSWD%3A%20%2Fusr%2Fbin%2Frpm%2C%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fbin%2Frpm%0A%3C%2FPRE%3E%3CP%3E%3CEM%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81username%3C%2FEM%3E%20%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%E3%81%A7%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%83%AD%E3%82%B0%E3%82%AA%E3%83%B3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%90%8D%E5%89%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1414377942%22%20id%3D%22toc-hId--1414377942%22%20id%3D%22toc-hId--493592004%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EUbuntu%E3%81%A7%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%3C%2FSPAN%3E%3C%2FH2%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%22mconf%22%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%2Fhome%2Ftic%2Fltib%2Fbin%2FLtibutils.pm%20%E3%81%AE%20972%20%E8%A1%8C%E7%9B%AE%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%AE%9F%E8%A1%8C%3A%20mconf%20%2Fhome%2Ftic%2Fltib%2Fconfig%2Fmain.lkc%3A%2Fhome%2Ftic%2Fltib%2Fbin%2FLtibutils.pm%20%E3%81%AE%20972%20%E8%A1%8C%E7%9B%AE%E3%81%AB%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%0A%26nbsp%3B%20Ltibutils%3A%3Asystem_nb%3A972%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Aget_plat_dir%3A2947%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A548%0A%0A%E9%96%8B%E5%A7%8B%3A%20Tue%20Feb%2016%2018%3A01%3A38%202010%0A%20%E7%B5%82%E4%BA%86%3A%20Tue%20Feb%2016%2018%3A59%3A26%202010%0A%20%E7%B5%8C%E9%81%8E%3A%203468%E7%A7%92%0A%0A%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%3Altib%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E925%E8%A1%8C%E7%9B%AE%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%3CP%3E%23%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20%3D%20%22%24cf-%26gt%3B%7Bsudo%7D%20%24cf-%26gt%3B%7Brpm%7D%20%22%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--root%20%24cf-%26gt%3B%7Brpmroot%7D%20%22%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--dbpath%20%24cf-%26gt%3B%7Brpmdb%7D%20%22%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--prefix%20%24cf-%26gt%3B%7Brpmipfx%7D%20%22%20%24cf-%26gt%3B%7Brpmipfx%7D%E3%81%AE%E5%A0%B4%E5%90%88%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--ignorearch%20-ivh%20%22%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--force%20%22%20unless%20%24cf-%26gt%3B%7Bconflicts%7D%20%7C%7C%24cf-%26gt%3B%7Bhostinst%7D%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--replacepkgs%20--replacefiles%20%22%20if%20%24cf-%26gt%3B%7Bhostinst%7D%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--nodeps%20%22%20if%20%24cf-%26gt%3B%7Bnodeps%7D%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--excludedocs%20%22%3B%0A%20%2B%20%24cmd%20.%3D%22--force-debian%22%20if%20%24rpm%20%3D~%20m%2Frpm-fs%2F%20%26amp%3B%26amp%3B%20'uname%20-a'%20%3D~%20m%2Fubuntu%2Fi%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22--define%20'_tmppath%20%24cf-%26gt%3B%7Btmppath%7D'%20%22%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24cmd%20.%3D%22%24rpm%22%3B%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Adb3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%90%8D%E5%89%8D%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93-%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(2)%0A%20%E3%82%A8%E3%83%A9%E3%83%BC%3Adb3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%90%8D%E5%89%8D%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93-%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(2)%0A%20sudo%20rpm%20--root%20%2F%20--dbpath%20%2Ftmp%2Frpm-tic%2Frpmdb%20-e%20--allmatches%20--nodeps%20--define%20'_tmppath%20%2Fhome%2Ftic%2Fltib%2Ftmp'%20rpm-fs%202%26gt%3B%2Fdev%2Fnull%0A%20sudo%20rpm%20--root%20%2F%20--dbpath%20%2Ftmp%2Frpm-tic%2Frpmdb%20--ignorearch%20-ivh%20--force%20--nodeps%20--excludedocs%20--define%20'_tmppath%20%2Fhome%2Ftic%2Fltib%2Ftmp'%20%2Ftmp%2Frpm-tic%2FRPMS%2Fi686%2Frpm-fs-4.0.4-1.i686.rpm%0A%20rpm%3A%20Debian%20%E3%81%AB%20rpm%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20alien%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%9C%AC%E5%BD%93%E3%81%AB%E7%A2%BA%E4%BF%A1%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81--force-debian%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82README%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Debian%20%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82sudo%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fbin%2Frpm%20--root%20%2F%20--dbpath%20%2Fopt%2Ffreescale%2Fltib%2Fvar%2Flib%2Frpm%20-Uv%20--justdb%20--notriggers%20--noscripts%20--nodeps%20%2Ftmp%2Frpm-tic%2FRPMS%2Fi686%2Frpm-fs-4.0.4-1.i686.rpm%0A%20sudo%3A%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fbin%2Frpm%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%20mkdir%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fopt%2Ffreescale'%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E6%A8%A9%E9%99%90%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%0A%0A%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%0A%26nbsp%3B%20%2Fopt%2Ffreescale%2Fpkgs%0A%0A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%E3%82%92%E6%8C%81%E3%81%A4%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%B8%E3%81%AE%E5%A4%89%E6%9B%B4%E3%80%81%0A%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81root%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%A8%A9%E9%99%90%E3%82%92%20777%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%0A%0A%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Acheck_dirs%3A2469%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Ahost_checks%3A1426%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A542%0A%0A%E9%96%8B%E5%A7%8B%3A%20Wed%20Nov%2025%2001%3A56%3A53%202009%0A%20%E7%B5%82%E4%BA%86%3A%20Wed%20Nov%2025%2002%3A07%3A42%202009%0A%20%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%20649%20%E7%A7%92%0A%0A%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%0A%20%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%20%3A%20sudo%20chmod%20777%20%2Fopt%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3Emake%5B1%5D%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8'%20%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%9C%E3%82%8B%0A%20make%20%5B2%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8%2Ftools'%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99make%5B2%5D%3A%20***%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%20'all'%20%E3%81%AB%E3%81%99%E3%82%8B%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AD%A2%E3%82%81%E3%82%8B%E3%80%82make%20%5B2%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8%2Ftools'%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99make%5B1%5D%3A%20***%20%5Ball-recursive%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%0A%20make%5B1%5D%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8'%20%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99make%3A%20***%20%5Ball%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%0A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82U8vEdX%20(%25%E3%83%93%E3%83%AB%E3%83%89)%0A%0ARPM%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3A%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82U8vEdX%20(%25%E3%83%93%E3%83%AB%E3%83%89)%0A%20texinfo%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E9%96%93%3A%2055%20%E7%A7%92%0A%0Atexinfo%20%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%20.%2Fltib%20line%201380%E3%81%A7%E6%AD%BB%E4%BA%A1%E3%80%82%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Abuild_host_rpms%3A1380%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Ahost_checks%3A1435%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A542%0A%0A%E9%96%8B%E5%A7%8B%3A%20Wed%20Nov%2025%2020%3A10%3A43%202009%0A%20%E7%B5%82%E4%BA%86%3A%202009%E5%B9%B411%E6%9C%8825%E6%97%A5(%E6%B0%B4)%2020%3A31%3A42%0A%20%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%201259%20%E7%A7%92%0A%0A%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%0A%20%E3%83%86%E3%83%83%E3%82%AF%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%95%E3%82%A9%0A%0A%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%0A%20%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%ABccache%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%2B%20cd%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%0A%20%2B%20cd%20lkc-1.4%2B%20make%20-j1%20conf%20mconf%0A%20gcc%20-O0%20-%E5%A3%81%20-g%20-fPIC%20-c%20conf.c-o%20conf.o%E3%83%90%E3%82%A4%E3%82%BD%E3%83%B3%20-l%20-b%20zconf%20-p%20zconf%20zconf.y%E3%83%95%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%20-L%20-Pzconf%20zconf.lmake%3A%20flex%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%20%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3A%20***%20%5Blex.zconf.c%5D%E3%82%A8%E3%83%A9%E3%83%BC%20127%0A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.010CjL%20(%25build)%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%0ARPM%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3A%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.010CjL%20(%25build)%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%0A%20lkc%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E9%96%93%3A%202%20%E7%A7%92%0A%0Alkc%20%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%20.%2Fltib%20line%201380%E3%81%A7%E6%AD%BB%E4%BA%A1%E3%80%82%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Abuild_host_rpms%3A1380%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Ahost_checks%3A1435%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A542%0A%0A%E9%96%8B%E5%A7%8B%3A%20Thu%20Nov%2026%2000%3A33%3A46%202009%0A%20%E7%B5%82%E4%BA%86%3A%202009%E5%B9%B411%E6%9C%8826%E6%97%A5(%E6%9C%A8)%2001%3A19%3A39%0A%20%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%202753%20%E7%A7%92%0A%0A%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%0A%20LKC%E3%81%AE%0A%0A%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%ABFlex%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%20po%20%E3%81%A7%E4%BD%9C%E3%82%8B%0A%20make%20%5B2%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fhome%2Ftic%2Fltib%2Frpm%2FBUILD%2Falsa-utils-1.0.11rc2%2Falsaconf%2Fpo'%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%0A%20MV%3A%20't-ja.gmo'%20%E3%82%92%20stat%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%20make%5B2%5D%3A%20***%20%5Bja.gmo%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%0A%20make%5B2%5D%3A%20***%20%E6%9C%AA%E5%AE%8C%E6%88%90%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%80%82%0A%20MV%3A%20'T-RU.GMO'%20%E3%82%92%20stat%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%20make%5B2%5D%3A%20***%20%5Bru.gmo%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%0A%20make%20%5B2%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fhome%2Ftic%2Fltib%2Frpm%2FBUILD%2Falsa-utils-1.0.11rc2%2Falsaconf%2Fpo'%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99%0A%20make%5B1%5D%3A%20***%20%5Ball-recursive%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%0A%20make%20%5B1%5D%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2Fhome%2Ftic%2Fltib%2Frpm%2FBUILD%2Falsa-utils-1.0.11rc2%2Falsaconf'%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%BE%E3%81%99%0A%20make%3A%20***%20%5Ball-recursive%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%0A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.93730%20(%25build)%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%0ARPM%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3A%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.93730%20(%25build)%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%0A%20alsa-utils%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E9%96%93%3A%2084%20%E7%A7%92%0A%0Aalsa-utils%20%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%0Af_buildrpms()%20%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%80%81%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A560%0A%0A%E9%96%8B%E5%A7%8B%3A%20Sat%20Nov%2028%2007%3A39%3A40%202009%0A%20%E7%B5%82%E4%BA%86%3A%202009%E5%B9%B411%E6%9C%8828%E6%97%A5(%E5%9C%9F)%2008%3A17%3A18%0A%20%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%202258%20%E7%A7%92%0A%0A%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%0A%20alsa-utils%E3%81%AE%0A%0A%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%0A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%0A%0A%20%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%3A%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8gettext%E3%81%A8ja-trans%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3Eglib-genmarshal%20%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%84%E3%81%84%E3%81%88%0A%20configure%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%20PATH%20%E3%81%AB%20glib-genmarshal%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%0A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.13030%20(%25build)%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%0A%0ARPM%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3A%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.13030%20(%25build)%20%E3%81%8B%E3%82%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%0A%20glib2%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E9%96%93%3A%20107%20%E7%A7%92%0A%0Aglib2%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%0Af_buildrpms()%20%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%80%81%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%0A%26nbsp%3B%20%E3%83%A1%E3%82%A4%E3%83%B3%3A560%0A%0A%E9%96%8B%E5%A7%8B%3A%20Sat%20Dec%205%2003%3A19%3A36%202009%0A%20%E7%B5%82%E4%BA%86%3A%202009%E5%B9%B412%E6%9C%885%E6%97%A5(%E5%9C%9F)%2003%3A29%3A46%0A%20%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%20610%20%E7%A7%92%0A%0A%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%0A%20%E3%82%B0%E3%83%AA%E3%83%962%0A%0A%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%0A%0A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%20%3A%20libglib2.0-dev%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89LTIB%E8%A8%AD%E5%AE%9AUbuntu%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8A%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%ABltib%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%80%81%E3%80%8C%24cmd.%3D%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%22--force-debian%20%22%20if%20%24rpm%20%3D~%20m%2Frpm-fs%2F%20%26amp%3B%26amp%3B%20'uname%20-a'%20%3D~%20m%2Fubuntu%2Fi%3B%22%20%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edefined(%40array)%20%E3%81%AF%20%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fbin%2FLtibutils.pm%20%E3%81%AE%20362%20%E8%A1%8C%E7%9B%AE%E3%81%A7%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E(%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%20defined()%E3%82%92%E7%9C%81%E7%95%A5%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E.%2Fltib%20%E8%A1%8C%202519%20%E3%81%AE%20void%20%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AE%E6%95%B0%E5%80%A4%20eq%20(%3D%3D)%20%E3%81%AE%E7%84%A1%E9%A7%84%E3%81%AA%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%22mconf%22%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fbin%2FLtibutils.pm%E3%81%AE1006%E8%A1%8C%E7%9B%AE%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%9F%E8%A1%8C%3A%20mconf%20%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fconfig%2Fmain.lkc%3A%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fbin%2FLtibutils.pm%E3%81%AE1006%E8%A1%8C%E7%9B%AE%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%3C%2FP%3E%3CP%3E%20Ltibutils%3A%3Asystem_nb%3A1006%3C%2FP%3E%3CP%3E%26nbsp%3B%20main%3A%3Aget_plat_dir%3A2970%3C%2FP%3E%3CP%3E%E3%83%A1%E3%82%A4%E3%83%B3%3A560%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%96%8B%E5%A7%8B%E6%97%A5%3A%20Sun%20Mar%2029%2021%3A19%3A06%202015%3C%2FP%3E%3CP%3E%E7%B5%82%E4%BA%86%3A%202015%E5%B9%B43%E6%9C%8829%E6%97%A5(%E6%97%A5)%2021%3A19%3A06%3C%2FP%3E%3CP%3E%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%200%20%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3E.%2Fltib%20line%202970%E3%81%A7%E6%AD%BB%E4%BA%A1%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%3C%2FP%3E%3CP%3E%20main%3A%3Aget_plat_dir%3A2970%3C%2FP%3E%3CP%3E%E3%83%A1%E3%82%A4%E3%83%B3%3A560%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%96%8B%E5%A7%8B%E6%97%A5%3A%20Sun%20Mar%2029%2021%3A19%3A06%202015%3C%2FP%3E%3CP%3E%E7%B5%82%E4%BA%86%3A%202015%E5%B9%B43%E6%9C%8829%E6%97%A5(%E6%97%A5)%2021%3A19%3A06%3C%2FP%3E%3CP%3E%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%200%20%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A7%E7%B5%82%E4%BA%86%3C%2FP%3E%3CP%3Esarjak%40sarjak-OptiPlex-7011%3A~%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%24%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89LTIB%E8%A8%AD%E5%AE%9AUbuntu%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A-(%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eutil.c%3A(.text%2B0xa4d)%3A'waddch'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Eutil.c%3A(.text%2B0xa58)%3A'winch'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Eutil.c%3A(.text%2B0xa6c)%3A'waddch'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Eutil.c%3A(.text%2B0xa8b)%3A'wnoutrefresh'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3CBR%20%2F%3Ecollect2%3A%20ld%20%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emake%3A%20**%20%5Bmconf%5D%20%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3Eerro%3A%20C%C3%B3digo%20de%20sa%C3%ADda%20inv%C3%A1lido%20do%20%2Fhome%2Flucas%2Fltib%2Ftmp%2Frpm-tmp.75915%20(%25build)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EErros%20de%20cria%C3%A7%C3%A3o%20do%20RPM%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20C%C3%B3digo%20de%20sa%C3%ADda%20inv%C3%A1lido%20do%20%2Fhome%2Flucas%2Fltib%2Ftmp%2Frpm-tmp.75915%20(%25build)%3CBR%20%2F%3EBuild%20time%20for%20lkc%3A%203%20seconds%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Elkc%20%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E.%2Fltib%20%E8%A1%8C%201393%20%E3%81%A7%E6%AD%BB%E4%BA%A1%E3%80%82%3CBR%20%2F%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%3A%3CBR%20%2F%3E%20%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Abuild_host_rpms%3A1393%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%83%B3%3A%3Ahost_checks%3A1448%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%83%B3%3A554%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%96%8B%E5%A7%8B%3A%20Tue%20May%207%2017%3A43%3A23%202013%3CBR%20%2F%3E%E7%B5%82%E4%BA%86%3A%202013%E5%B9%B45%E6%9C%887%E6%97%A5(%E7%81%AB)%2017%3A55%3A25%3CBR%20%2F%3E%E7%B5%8C%E9%81%8E%E6%99%82%E9%96%93%3A%20722%20%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ELKC%E3%81%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOBS%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%B8%B8%E3%81%AB%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89LTIB%E8%A8%AD%E5%AE%9AUbuntu%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%20%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%A9%E3%83%96%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:34 AM
更新者:
