All Boards LTIB Config Ubuntu
Ubuntu distro uses dash instead of bash as shell, then change it to bash:
# cd /bin
# sudo rm sh
# sudo ln -s bash sh
Install all necessary packages by typing:
sudo apt-get install patch g++ rpm zlib1g-dev m4 bison libncurses5-dev libglib2.0-dev gettext \
build-essential tcl intltool libxml2-dev liborbit2-dev libx11-dev ccache flex uuid-dev liblzo2-dev
If under Ubuntu 64bit, install ia32-libs package:
sudo apt-get install ia32-libs
  • If you will install Xorg in your ltib, you will need to install this package:
sudo apt-get install x11proto-core-dev
  • If you will install gtk+ in your ltib, you will need to install the following packages:
sudo apt-get install libdbus-glib-1-dev libgtk2.0-dev libdbus-glib-1-dev
Configure visudo file, as root using the command "/usr/sbin/visudo", and add the following line in the User privilege section:
username ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
Where username is your user name, the name you use to do logon in your system.
Classic Error messages and solutions under Ubuntu
Can't exec "mconf": No such file or directory at /home/tic/ltib/bin/Ltibutils.pm line 972. exec: mconf /home/tic/ltib/config/main.lkc: No such file or directory at /home/tic/ltib/bin/Ltibutils.pm line 972. traceback:   Ltibutils::system_nb:972   main::get_plat_dir:2947     main:548 Started: Tue Feb 16 18:01:38 2010 Ended:  Tue Feb 16 18:59:26 2010 Elapsed: 3468 seconds Build Failed
Solution: edit the ltib script
line 925:
          # install the new package           $cmd  = "$cf->{sudo} $cf->{rpm} ";           $cmd .= "--root $cf->{rpmroot} ";           $cmd .= "--dbpath $cf->{rpmdb} ";           $cmd .= "--prefix $cf->{rpmipfx} " if $cf->{rpmipfx};           $cmd .= "--ignorearch -ivh ";           $cmd .= "--force "  unless $cf->{conflicts} || $cf->{hostinst};           $cmd .= "--replacepkgs --replacefiles " if $cf->{hostinst};           $cmd .= "--nodeps " if $cf->{nodeps};           $cmd .= "--excludedocs "; +        $cmd .= "--force-debian " if $rpm =~ m/rpm-fs/ && `uname -a` =~ m/ubuntu/i;           $cmd .= "--define '_tmppath $cf->{tmppath}' ";           $cmd .= "$rpm";
error: cannot open Name index using db3 - No such file or directory (2) error: cannot open Name index using db3 - No such file or directory (2) sudo rpm --root / --dbpath /tmp/rpm-tic/rpmdb -e --allmatches --nodeps --define '_tmppath /home/tic/ltib/tmp' rpm-fs 2>/dev/null sudo rpm --root / --dbpath /tmp/rpm-tic/rpmdb --ignorearch -ivh --force --nodeps --excludedocs --define '_tmppath /home/tic/ltib/tmp'  /tmp/rpm-tic/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm rpm: please use alien to install rpm packages on Debian, if you are really sure use --force-debian switch. See README.Debian for more details. sudo /opt/freescale/ltib/usr/bin/rpm --root / --dbpath /opt/freescale/ltib/var/lib/rpm -Uv --justdb --notriggers --noscripts --nodeps  /tmp/rpm-tic/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm sudo: /opt/freescale/ltib/usr/bin/rpm: command not found mkdir: cannot create directory `/opt/freescale': Permission denied Cannot create the download directory:   /opt/freescale/pkgs Either change to a global directory you have write permissions to, or create it as root.  Please set the permissions to 777 traceback:   main::check_dirs:2469   main::host_checks:1426     main:542 Started: Wed Nov 25 01:56:53 2009 Ended:  Wed Nov 25 02:07:42 2009 Elapsed: 649 seconds Build Failed
solution : sudo chmod 777 /opt
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8' Making all in tools make[2]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools' make[2]: *** No rule to make target `all'.  Stop. make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8' make: *** [all] Error 2 error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.U8vEdX (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.U8vEdX (%build) Build time for texinfo: 55 seconds Failed building texinfo Died at ./ltib line 1380. traceback:   main::build_host_rpms:1380   main::host_checks:1435     main:542 Started: Wed Nov 25 20:10:43 2009 Ended:  Wed Nov 25 20:31:42 2009 Elapsed: 1259 seconds These packages failed to build: texinfo Build Failed
solution : install ccache package in host
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD + cd lkc-1.4 + make -j1 conf mconf gcc -O0 -Wall -g -fPIC -c conf.c -o conf.o bison -l -b zconf -p zconf zconf.y flex -L -Pzconf zconf.l make: flex: Command not found make: *** [lex.zconf.c] Error 127 error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.010CjL (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.010CjL (%build) Build time for lkc: 2 seconds Failed building lkc Died at ./ltib line 1380. traceback:   main::build_host_rpms:1380   main::host_checks:1435     main:542 Started: Thu Nov 26 00:33:46 2009 Ended:  Thu Nov 26 01:19:39 2009 Elapsed: 2753 seconds These packages failed to build: lkc Build Failed
solution : install flex package in host
Making all in po make[2]: Entering directory `/home/tic/ltib/rpm/BUILD/alsa-utils-1.0.11rc2/alsaconf/po' mv: cannot stat `t-ja.gmo': No such file or directory make[2]: *** [ja.gmo] Error 1 make[2]: *** Waiting for unfinished jobs.... mv: cannot stat `t-ru.gmo': No such file or directory make[2]: *** [ru.gmo] Error 1 make[2]: Leaving directory `/home/tic/ltib/rpm/BUILD/alsa-utils-1.0.11rc2/alsaconf/po' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/tic/ltib/rpm/BUILD/alsa-utils-1.0.11rc2/alsaconf' make: *** [all-recursive] Error 1 error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.93730 (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.93730 (%build) Build time for alsa-utils: 84 seconds Failed building alsa-utils f_buildrpms() returned an error, exiting traceback:   main:560 Started: Sat Nov 28 07:39:40 2009 Ended:  Sat Nov 28 08:17:18 2009 Elapsed: 2258 seconds These packages failed to build: alsa-utils Build Failed Exiting on error or interrupt
solution : install package gettext and ja-trans
checking for glib-genmarshal... no configure: error: Could not find a glib-genmarshal in your PATH error: Bad exit status from /home/tic/ltib/tmp/rpm-tmp.13030 (%build) RPM build errors:     Bad exit status from /home/tic/ltib/tmp/rpm-tmp.13030 (%build) Build time for glib2: 107 seconds Failed building glib2 f_buildrpms() returned an error, exiting traceback:   main:560 Started: Sat Dec  5 03:19:36 2009 Ended:  Sat Dec  5 03:29:46 2009 Elapsed: 610 seconds These packages failed to build: glib2 Build Failed Exiting on error or interrupt
solution : install the package libglib2.0-dev
标记 (1)
评论
Great Documentation :smileyhappy:
Thanks a lot,
Saurabh
Hi, i have this error :-(
util.c:(.text+0xa4d): undefined reference to `waddch'
util.c:(.text+0xa58): undefined reference to `winch'
util.c:(.text+0xa6c): undefined reference to `waddch'
util.c:(.text+0xa8b): undefined reference to `wnoutrefresh'
collect2: ld returned 1 exit status
make: ** [mconf] Erro 1
erro: Código de saída inválido do /home/lucas/ltib/tmp/rpm-tmp.75915 (%build)
Erros de criação do RPM:
Build time for lkc: 3 seconds
Failed building lkc
Died at ./ltib line 1393.
traceback:
main::build_host_rpms:1393
  main::host_checks:1448
   main:554
Started: Tue May  7 17:43:23 2013
Ended:   Tue May  7 17:55:25 2013
Elapsed: 722 seconds
lkc
Build Failed
OBS: alls packages installed correctly, but always this erro
I edited the ltib file as you said above and added the line "$cmd .= "--force-debian " if $rpm =~ m/rpm-fs/ && `uname -a` =~ m/ubuntu/i;" but it still gives the same error :
defined(@array) is deprecated at /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/bin/Ltibutils.pm line 362.
    (Maybe you should just omit the defined()?)
Useless use of numeric eq (==) in void context at ./ltib line 2519.
Can't exec "mconf": No such file or directory at /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/bin/Ltibutils.pm line 1006.
exec: mconf /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/config/main.lkc: No such file or directory at /home/sarjak/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib/bin/Ltibutils.pm line 1006.
traceback:
Ltibutils::system_nb:1006
  main::get_plat_dir:2970
   main:560
Started: Sun Mar 29 21:19:06 2015
Ended:   Sun Mar 29 21:19:06 2015
Elapsed: 0 seconds
Build Failed
Died at ./ltib line 2970.
traceback:
  main:560
Elapsed: 0 seconds
Build Failed
sarjak@sarjak-OptiPlex-7011:~/Downloads/L2.6.35_1.1.0_130130_source/yes/ltib$
Can you please help?? It will be appreciated.
Thank you very much.
%3CLINGO-SUB%20id%3D%22lingo-sub-1128363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%89%80%E6%9C%89%E4%B8%BB%E6%9D%BF%20LTIB%20%E9%85%8D%E7%BD%AE%20Ubuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EUbuntu%20%E5%8F%91%E8%A1%8C%E7%89%88%E4%BD%BF%E7%94%A8%20dash%20%E8%80%8C%E4%B8%8D%E6%98%AF%20bash%20%E4%BD%9C%E4%B8%BA%20shell%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%20bash%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%23%20cd%20%2Fbin%0A%23%20sudo%20rm%20sh%0A%23%20sudo%20ln%20-s%20bash%20sh%0A%3C%2FPRE%3E%3CP%3E%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%AE%89%E8%A3%85%E6%89%80%E6%9C%89%E5%BF%85%E9%9C%80%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20%E5%AE%89%E8%A3%85%E8%A1%A5%E4%B8%81%20g%2B%2B%20rpm%20zlib1g-dev%20m4%20bison%20libncurses5-dev%20libglib2.0-dev%E8%8E%B7%E5%8F%96%E6%96%87%E6%9C%AC%20%5C%0A%E6%9E%84%E5%BB%BA%E5%9F%BA%E6%9C%AC%20tcl%20intltool%20libxml2-dev%20liborbit2-dev%20libx11-dev%20ccache%20flex%20uuid-dev%20liblzo2-dev%0A%3C%2FPRE%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%9C%A8%20Ubuntu%2064%20%E4%BD%8D%E4%B8%8B%EF%BC%8C%E5%AE%89%E8%A3%85%20ia32-libs%20%E5%8C%85%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20%E5%AE%89%E8%A3%85%20ia32-libs%0A%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%A6%81%E5%9C%A8%20ltib%20%E4%B8%AD%E5%AE%89%E8%A3%85%20Xorg%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E6%AD%A4%E5%8C%85%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20%E5%AE%89%E8%A3%85%20x11proto-core-dev%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%A6%81%E5%9C%A8%20ltib%20%E4%B8%AD%E5%AE%89%E8%A3%85%20gtk%2B%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E4%BB%A5%E4%B8%8B%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20install%20libdbus-glib-1-dev%20libgtk2.0-dev%20libdbus-glib-1-dev%0A%3C%2FPRE%3E%3CP%3E%E4%BB%A5%20root%20%E8%BA%AB%E4%BB%BD%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9C%2Fusr%2Fsbin%2Fvisudo%E2%80%9D%E9%85%8D%E7%BD%AE%20visudo%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E5%9C%A8%E7%94%A8%E6%88%B7%E6%9D%83%E9%99%90%E9%83%A8%E5%88%86%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E7%94%A8%E6%88%B7%E5%90%8D%20ALL%20%3D%20NOPASSWD%3A%20%2Fusr%2Fbin%2Frpm%2C%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fbin%2Frpm%0A%3C%2FPRE%3E%3CP%3E%E5%85%B6%E4%B8%AD%3CEM%3E%E7%94%A8%E6%88%B7%E5%90%8D%3C%2FEM%3E%E6%98%AF%E6%82%A8%E7%9A%84%E7%94%A8%E6%88%B7%E5%90%8D%EF%BC%8C%E5%8D%B3%E6%82%A8%E5%9C%A8%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%99%BB%E5%BD%95%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1414377942%22%20id%3D%22toc-hId--1414377942%22%20id%3D%22toc-hId--493592132%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EUbuntu%E4%B8%8B%E7%BB%8F%E5%85%B8%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%8F%8A%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FH2%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E6%97%A0%E6%B3%95%E6%89%A7%E8%A1%8C%E2%80%9Cmconf%E2%80%9D%EF%BC%9A%2Fhome%2Ftic%2Fltib%2Fbin%2FLtibutils.pm%20%E7%AC%AC%20972%20%E8%A1%8C%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E3%80%82%E6%89%A7%E8%A1%8C%EF%BC%9Amconf%20%2Fhome%2Ftic%2Fltib%2Fconfig%2Fmain.lkc%EF%BC%9A%2Fhome%2Ftic%2Fltib%2Fbin%2FLtibutils.pm%20%E7%AC%AC%20972%20%E8%A1%8C%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E3%80%82%E5%9B%9E%E6%BA%AF%EF%BC%9A%0A%20Ltibutils%3A%3Asystem_nb%3A972%0A%E4%B8%BB%E8%A6%81%3A%3A%E8%8E%B7%E5%8F%96%E5%B9%B3%E5%8F%B0%E7%9B%AE%E5%BD%95%3A2947%0A%E4%B8%BB%E8%A6%81%EF%BC%9A548%0A%0A%0A%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2010%20%E5%B9%B4%202%20%E6%9C%88%2016%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C%2018%3A01%3A38%0A%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2010%20%E5%B9%B4%202%20%E6%9C%88%2016%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C%2018%3A59%3A26%0A%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A3468%20%E7%A7%92%0A%0A%0A%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E7%BC%96%E8%BE%91%20ltib%20%E8%84%9A%E6%9C%AC%3C%2FP%3E%3CP%3E%E7%AC%AC%20925%20%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%3CP%3E%23%20%E5%AE%89%E8%A3%85%E6%96%B0%E5%8C%85%0A%24cmd%20%3D%20%22%24cf-%26gt%3B%7Bsudo%7D%20%24cf-%26gt%3B%7Brpm%7D%20%22%3B%0A%20%24cmd.%3D%E2%80%9C--root%20%24cf-%26gt%3B%7Brpmroot%7D%E2%80%9D%EF%BC%9B%0A%20%24cmd.%3D%22--dbpath%20%24cf-%26gt%3B%7Brpmdb%7D%20%22%3B%0A%20%24cmd.%3D%E5%A6%82%E6%9E%9C%20%24cf-%26gt%3B%7Brpmipfx%7D%3B%20%22--prefix%20%24cf-%26gt%3B%7Brpmipfx%7D%22%0A%20%24cmd.%3D%E2%80%9C--ignorearch%20-ivh%E2%80%9D%EF%BC%9B%0A%20%24cmd.%3D%22--force%20%22%20%E9%99%A4%E9%9D%9E%20%24cf-%26gt%3B%7Bconflicts%7D%20%7C%7C%20%24cf-%26gt%3B%7Bhostinst%7D%3B%0A%20%24cmd.%3D%E5%A6%82%E6%9E%9C%20%24cf-%26gt%3B%7Bhostinst%7D%3B%20%E5%88%99%E4%B8%BA%E2%80%9C--replacepkgs%20--replacefiles%E2%80%9D%0A%20%24cmd.%3D%E5%A6%82%E6%9E%9C%20%24cf-%26gt%3B%7Bnodeps%7D%EF%BC%8C%E5%88%99%E4%B8%BA%E2%80%9C--nodeps%E2%80%9D%EF%BC%9B%0A%20%24cmd.%3D%E2%80%9C--%E6%8E%92%E9%99%A4%E6%96%87%E6%A1%A3%E2%80%9D%EF%BC%9B%0A%20%2B%20%24cmd%20.%3D%E2%80%9C--force-debian%E2%80%9D%20%E5%A6%82%E6%9E%9C%20%24rpm%20%3D~%20m%2Frpm-fs%2F%20%26amp%3B%26amp%3B%20%60uname%20-a%60%20%3D~%20m%2Fubuntu%2Fi%EF%BC%9B%0A%20%24cmd.%3D%E2%80%9C%E2%80%94%E2%80%94%E5%AE%9A%E4%B9%89%E2%80%98_tmppath%20%24cf-%26gt%3B%7Btmppath%7D%E2%80%99%E2%80%9D%EF%BC%9B%0A%20%24cmd.%3D%22%24rpm%22%EF%BC%9B%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20db3%20%E6%89%93%E5%BC%80%E5%90%8D%E7%A7%B0%E7%B4%A2%E5%BC%95%20-%20%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%20(2)%0A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20db3%20%E6%89%93%E5%BC%80%E5%90%8D%E7%A7%B0%E7%B4%A2%E5%BC%95%20-%20%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%20(2)%0A%20sudo%20rpm%20--root%20%2F%20--dbpath%20%2Ftmp%2Frpm-tic%2Frpmdb%20-e%20--allmatches%20--nodeps%20--define%20'_tmppath%20%2Fhome%2Ftic%2Fltib%2Ftmp'%20rpm-fs%202%26gt%3B%2Fdev%2Fnull%0A%20sudo%20rpm%20--root%20%2F%20--dbpath%20%2Ftmp%2Frpm-tic%2Frpmdb%20--ignorearch%20-ivh%20--force%20--nodeps%20--excludedocs%20--define%20'_tmppath%20%2Fhome%2Ftic%2Fltib%2Ftmp'%20%2Ftmp%2Frpm-tic%2FRPMS%2Fi686%2Frpm-fs-4.0.4-1.i686.rpm%0A%20rpm%EF%BC%9A%E8%AF%B7%E4%BD%BF%E7%94%A8%20Alien%20%E5%9C%A8%20Debian%20%E4%B8%8A%E5%AE%89%E8%A3%85%20rpm%20%E5%8C%85%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E7%A1%AE%E5%AE%9E%E7%A1%AE%E5%AE%9A%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20--force-debian%20%E5%BC%80%E5%85%B3%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%20README.Debian%20%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E3%80%82sudo%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fbin%2Frpm%20--root%20%2F%20--dbpath%20%2Fopt%2Ffreescale%2Fltib%2Fvar%2Flib%2Frpm%20-Uv%20--justdb%20--notriggers%20--noscripts%20--nodeps%20%2Ftmp%2Frpm-tic%2FRPMS%2Fi686%2Frpm-fs-4.0.4-1.i686.rpm%0A%20sudo%3A%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fbin%2Frpm%3A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%0Amkdir%3A%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%E7%9B%AE%E5%BD%95%E2%80%9C%2Fopt%2Ffreescale%E2%80%9D%EF%BC%9A%E6%9D%83%E9%99%90%E8%A2%AB%E6%8B%92%E7%BB%9D%0A%0A%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%E4%B8%8B%E8%BD%BD%E7%9B%AE%E5%BD%95%EF%BC%9A%0A%20%2Fopt%2Ffreescale%2Fpkgs%0A%0A%E8%A6%81%E4%B9%88%E5%88%87%E6%8D%A2%E5%88%B0%E6%82%A8%E6%9C%89%E5%86%99%E5%85%A5%E6%9D%83%E9%99%90%E7%9A%84%E5%85%A8%E5%B1%80%E7%9B%AE%E5%BD%95%EF%BC%8C%0A%E6%88%96%E8%80%85%E4%BB%A5%20root%20%E8%BA%AB%E4%BB%BD%E5%88%9B%E5%BB%BA%E5%AE%83%E3%80%82%E8%AF%B7%E5%B0%86%E6%9D%83%E9%99%90%E8%AE%BE%E7%BD%AE%E4%B8%BA777%0A%0A%E5%9B%9E%E6%BA%AF%EF%BC%9A%0A%E4%B8%BB%E8%A6%81%3A%3Acheck_dirs%3A2469%0A%E4%B8%BB%E8%A6%81%3A%3Ahost_checks%3A1426%0A%E4%B8%BB%E8%A6%81%EF%BC%9A542%0A%0A%0A%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8825%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%8901%3A56%3A53%0A%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8825%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%8902%3A07%3A42%0A%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A649%E7%A7%92%0A%0A%0A%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%0A%20%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9Asudo%20chmod%20777%20%2Fopt%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3Emake%5B1%5D%3A%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%E2%80%9C%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8%E2%80%9D%E7%94%A8%E5%B7%A5%E5%85%B7%E5%88%B6%E9%80%A0%E4%B8%80%E5%88%87%0Amake%5B2%5D%3A%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%E2%80%9C%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8%2Ftools%E2%80%9Dmake%5B2%5D%3A%20***%20%E6%B2%A1%E6%9C%89%E8%A7%84%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%9B%AE%E6%A0%87%E5%8F%98%E4%B8%BA%E2%80%9C%E5%85%A8%E9%83%A8%E2%80%9D%E3%80%82%E5%81%9C%E6%AD%A2%E3%80%82make%5B2%5D%3A%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%9C%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8%2Ftools%E2%80%9Dmake%5B1%5D%3A%20***%20%5B%E5%85%A8%E9%80%92%E5%BD%92%5D%20%E9%94%99%E8%AF%AF%201%0A%20make%5B1%5D%3A%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%9C%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%2Ftexinfo-4.8%E2%80%9Dmake%3A%20***%20%5B%E5%85%A8%E9%83%A8%5D%20%E9%94%99%E8%AF%AF%202%0A%E9%94%99%E8%AF%AF%EF%BC%9A%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.U8vEdX%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0A%0A%0ARPM%20%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%9A%0A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.U8vEdX%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0Atexinfo%20%E7%9A%84%E6%9E%84%E5%BB%BA%E6%97%B6%E9%97%B4%EF%BC%9A55%20%E7%A7%92%0A%0Atexinfo%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%0A%E6%AD%BB%E4%BA%8E.%2Fltib%20%E7%AC%AC%201380%20%E8%A1%8C%E3%80%82%E5%9B%9E%E6%BA%AF%EF%BC%9A%0A%E4%B8%BB%E8%A6%81%3A%3Abuild_host_rpms%3A1380%0A%E4%B8%BB%E8%A6%81%3A%3Ahost_checks%3A1435%0A%E4%B8%BB%E8%A6%81%EF%BC%9A542%0A%0A%0A%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8825%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%89%2020%3A10%3A43%0A%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8825%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%89%2020%3A31%3A42%0A%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A1259%20%E7%A7%92%0A%0A%E8%BF%99%E4%BA%9B%E5%8C%85%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%9A%0A%20texinfo%0A%0A%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%0A%20%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E5%AE%89%E8%A3%85%20ccache%20%E5%8C%85%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%2B%20cd%20%2Fopt%2Ffreescale%2Fltib%2Fusr%2Fsrc%2Frpm%2FBUILD%0A%20%2B%20CD%20lkc-1.4%2B%20make%20-j1%20conf%20mconf%0A%20gcc%20-O0%20-Wall%20-g%20-fPIC%20-c%20conf.c-o%20conf.obison%20-l%20-b%20zconf%20-p%20zconf%20zconf.yflex%20-L%20-Pzconf%20zconf.lmake%EF%BC%9Aflex%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%0A%E5%88%B6%E4%BD%9C%EF%BC%9A***%20%5Blex.zconf.c%5D%E9%94%99%E8%AF%AF%20127%0A%E9%94%99%E8%AF%AF%EF%BC%9A%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.010CjL%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0A%0A%0ARPM%20%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%9A%0A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.010CjL%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0Alkc%20%E6%9E%84%E5%BB%BA%E6%97%B6%E9%97%B4%EF%BC%9A2%20%E7%A7%92%0A%0Alkc%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%0A%E6%AD%BB%E4%BA%8E.%2Fltib%20%E7%AC%AC%201380%20%E8%A1%8C%E3%80%82%E5%9B%9E%E6%BA%AF%EF%BC%9A%0A%E4%B8%BB%E8%A6%81%3A%3Abuild_host_rpms%3A1380%0A%E4%B8%BB%E8%A6%81%3A%3Ahost_checks%3A1435%0A%E4%B8%BB%E8%A6%81%EF%BC%9A542%0A%0A%0A%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8826%E6%97%A5%E6%98%9F%E6%9C%9F%E5%9B%9B00%3A33%3A46%0A%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8826%E6%97%A5%E6%98%9F%E6%9C%9F%E5%9B%9B01%3A19%3A39%0A%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A2753%20%E7%A7%92%0A%0A%E8%BF%99%E4%BA%9B%E5%8C%85%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%9A%0A%20lkc%0A%0A%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%AD%E5%AE%89%E8%A3%85%20flex%20%E5%8C%85%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E8%AE%A9%E4%B8%80%E5%88%87%E9%83%BD%E4%BA%95%E7%84%B6%E6%9C%89%E5%BA%8F%0Amake%5B2%5D%3A%20%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Ftic%2Fltib%2Frpm%2FBUILD%2Falsa-utils-1.0.11rc2%2Falsaconf%2Fpo'%0A%20mv%3A%20%E6%97%A0%E6%B3%95%E7%BB%9F%E8%AE%A1%E2%80%9Ct-ja.gmo%E2%80%9D%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%0A%E5%88%B6%E9%80%A0%5B2%5D%EF%BC%9A***%20%5Bja.gmo%5D%E9%94%99%E8%AF%AF%201%0A%20make%5B2%5D%EF%BC%9A***%20%E7%AD%89%E5%BE%85%E6%9C%AA%E5%AE%8C%E6%88%90%E7%9A%84%E4%BD%9C%E4%B8%9A....%0A%20mv%3A%20%E6%97%A0%E6%B3%95%E7%BB%9F%E8%AE%A1%E2%80%9Ct-ru.gmo%E2%80%9D%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%0A%E5%88%B6%E9%80%A0%5B2%5D%EF%BC%9A***%20%5Bru.gmo%5D%E9%94%99%E8%AF%AF%201%0A%20make%5B2%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%9C%2Fhome%2Ftic%2Fltib%2Frpm%2FBUILD%2Falsa-utils-1.0.11rc2%2Falsaconf%2Fpo%E2%80%9D%0A%20make%5B1%5D%3A%20***%20%5B%E5%85%A8%E9%80%92%E5%BD%92%5D%20%E9%94%99%E8%AF%AF%201%0A%20make%5B1%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%9C%2Fhome%2Ftic%2Fltib%2Frpm%2FBUILD%2Falsa-utils-1.0.11rc2%2Falsaconf%E2%80%9D%0A%20make%EF%BC%9A***%20%5B%E5%85%A8%E9%80%92%E5%BD%92%5D%20%E9%94%99%E8%AF%AF%201%0A%E9%94%99%E8%AF%AF%EF%BC%9A%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.93730%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0A%0A%0ARPM%20%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%9A%0A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.93730%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0Aalsa-utils%20%E7%9A%84%E6%9E%84%E5%BB%BA%E6%97%B6%E9%97%B4%EF%BC%9A84%20%E7%A7%92%0A%0A%E6%9E%84%E5%BB%BA%20alsa-utils%20%E5%A4%B1%E8%B4%A5%0A%0A%0Af_buildrpms()%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%EF%BC%8C%E9%80%80%E5%87%BA%0A%E5%9B%9E%E6%BA%AF%EF%BC%9A%0A%E4%B8%BB%E8%A6%81%EF%BC%9A560%0A%0A%0A%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8828%E6%97%A5%E6%98%9F%E6%9C%9F%E5%85%AD%2007%3A39%3A40%0A%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B411%E6%9C%8828%E6%97%A5%E6%98%9F%E6%9C%9F%E5%85%AD08%3A17%3A18%0A%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A2258%20%E7%A7%92%0A%0A%E8%BF%99%E4%BA%9B%E5%8C%85%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%9A%0A%20alsa%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%0A%0A%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%0A%0A%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E6%88%96%E4%B8%AD%E6%96%AD%E6%97%B6%E9%80%80%E5%87%BA%3C%2FP%3E%0A%0A%20%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%AE%89%E8%A3%85%E5%8C%85%20gettext%20%E5%92%8C%20ja-trans%3C%2FP%3E%3CHR%20%2F%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3E%E6%A3%80%E6%9F%A5%20glib-genmarshal...%20%E6%B2%A1%E6%9C%89%0A%E9%85%8D%E7%BD%AE%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%9C%A8%E6%82%A8%E7%9A%84%20PATH%20%E4%B8%AD%E6%89%BE%E5%88%B0%20glib-genmarshal%0A%E9%94%99%E8%AF%AF%EF%BC%9A%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.13030%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0A%0A%0ARPM%20%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%9A%0A%20%2Fhome%2Ftic%2Fltib%2Ftmp%2Frpm-tmp.13030%20(%25build)%20%E7%9A%84%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%E9%94%99%E8%AF%AF%0Aglib2%20%E7%9A%84%E6%9E%84%E5%BB%BA%E6%97%B6%E9%97%B4%EF%BC%9A107%20%E7%A7%92%0A%0A%E6%9E%84%E5%BB%BA%20glib2%20%E5%A4%B1%E8%B4%A5%0A%0A%0Af_buildrpms()%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%EF%BC%8C%E9%80%80%E5%87%BA%0A%E5%9B%9E%E6%BA%AF%EF%BC%9A%0A%E4%B8%BB%E8%A6%81%EF%BC%9A560%0A%0A%0A%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B412%E6%9C%885%E6%97%A5%E6%98%9F%E6%9C%9F%E5%85%AD03%3A19%3A36%0A%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2009%E5%B9%B412%E6%9C%885%E6%97%A5%E6%98%9F%E6%9C%9F%E5%85%AD03%3A29%3A46%0A%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A610%20%E7%A7%92%0A%0A%E8%BF%99%E4%BA%9B%E5%8C%85%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%9A%0A%20glib2%0A%0A%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%0A%0A%E5%9B%A0%E9%94%99%E8%AF%AF%E6%88%96%E4%B8%AD%E6%96%AD%E8%80%8C%E9%80%80%E5%87%BA%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%AE%89%E8%A3%85%E8%BD%AF%E4%BB%B6%E5%8C%85%20libglib2.0-dev%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%89%80%E6%9C%89%E4%B8%BB%E6%9D%BFLTIB%E9%85%8D%E7%BD%AEUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%B8%8A%E9%9D%A2%E8%AF%B4%E7%9A%84%E7%BC%96%E8%BE%91%E4%BA%86%20ltib%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BA%86%E8%A1%8C%E2%80%9C%24cmd%20.%3D%E2%80%9C--force-debian%E2%80%9Cif%20%24rpm%20%3D~%20m%2Frpm-fs%2F%20%26amp%3B%26amp%3B%20%60uname%20-a%60%20%3D~%20m%2Fubuntu%2Fi%3B%E2%80%9D%E4%BD%86%E5%AE%83%E4%BB%8D%E7%84%B6%E7%BB%99%E5%87%BA%E7%9B%B8%E5%90%8C%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fbin%2FLtibutils.pm%20%E7%AC%AC%20362%20%E8%A1%8C%EF%BC%8Cdefined(%40array)%20%E5%B7%B2%E8%A2%AB%E5%BC%83%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E4%B9%9F%E8%AE%B8%E4%BD%A0%E5%BA%94%E8%AF%A5%E7%9C%81%E7%95%A5defined()%EF%BC%9F%EF%BC%89%3C%2FP%3E%3CP%3E%E5%9C%A8%20.%2Fltib%20%E7%AC%AC%202519%20%E8%A1%8C%E7%9A%84%20void%20%E4%B8%8A%E4%B8%8B%E6%96%87%E4%B8%AD%EF%BC%8C%E6%95%B0%E5%AD%97%20eq%20(%3D%3D)%20%E7%9A%84%E4%BD%BF%E7%94%A8%E6%AF%AB%E6%97%A0%E6%84%8F%E4%B9%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E6%89%A7%E8%A1%8C%E2%80%9Cmconf%E2%80%9D%EF%BC%9A%E5%9C%A8%20%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fbin%2FLtibutils.pm%20%E7%AC%AC%201006%20%E8%A1%8C%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%A7%E8%A1%8C%EF%BC%9Amconf%20%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fconfig%2Fmain.lkc%EF%BC%9A%2Fhome%2Fsarjak%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%2Fbin%2FLtibutils.pm%20%E7%AC%AC%201006%20%E8%A1%8C%E6%B2%A1%E6%9C%89%E8%AF%A5%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%9E%E6%BA%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%20Ltibutils%3A%3Asystem_nb%3A1006%3C%2FP%3E%3CP%3E%26nbsp%3B%20main%3A%3Aget_plat_dir%3A2970%3C%2FP%3E%3CP%3E%E4%B8%BB%E8%A6%81%EF%BC%9A560%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2015%E5%B9%B43%E6%9C%8829%E6%97%A5%20%E5%91%A8%E6%97%A5%2021%3A19%3A06%3C%2FP%3E%3CP%3E%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2015%E5%B9%B43%E6%9C%8829%E6%97%A5%20%E5%91%A8%E6%97%A5%2021%3A19%3A06%3C%2FP%3E%3CP%3E%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A0%20%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E9%94%99%E8%AF%AF%E6%88%96%E4%B8%AD%E6%96%AD%E8%80%8C%E9%80%80%E5%87%BA%3C%2FP%3E%3CP%3E%E6%AD%BB%E4%BA%8E.%2Fltib%20%E7%AC%AC%202970%20%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%9E%E6%BA%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%20main%3A%3Aget_plat_dir%3A2970%3C%2FP%3E%3CP%3E%E4%B8%BB%E8%A6%81%EF%BC%9A560%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2015%E5%B9%B43%E6%9C%8829%E6%97%A5%20%E5%91%A8%E6%97%A5%2021%3A19%3A06%3C%2FP%3E%3CP%3E%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2015%E5%B9%B43%E6%9C%8829%E6%97%A5%20%E5%91%A8%E6%97%A5%2021%3A19%3A06%3C%2FP%3E%3CP%3E%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A0%20%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E9%94%99%E8%AF%AF%E6%88%96%E4%B8%AD%E6%96%AD%E8%80%8C%E9%80%80%E5%87%BA%3C%2FP%3E%3CP%3Esarjak%40sarjak-OptiPlex-7011%3A~%2FDownloads%2FL2.6.35_1.1.0_130130_source%2Fyes%2Fltib%24%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E5%BF%99%E5%90%97%EF%BC%9F%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%89%80%E6%9C%89%E4%B8%BB%E6%9D%BFLTIB%E9%85%8D%E7%BD%AEUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%3A-(%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eutil.c%3A(.%E6%96%87%E6%9C%AC%2B0xa4d)%3A%E5%AF%B9%E2%80%9Cwaddch%E2%80%9D%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3CBR%20%2F%3Eutil.c%3A(.%E6%96%87%E6%9C%AC%2B0xa58)%3A%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%AF%B9%E2%80%9C%E7%BB%9E%E7%9B%98%E2%80%9D%E7%9A%84%E5%BC%95%E7%94%A8%3CBR%20%2F%3Eutil.c%3A(.%E6%96%87%E6%9C%AC%2B0xa6c)%3A%E5%AF%B9%E2%80%9Cwaddch%E2%80%9D%E7%9A%84%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3CBR%20%2F%3Eutil.c%3A(.%E6%96%87%E6%9C%AC%2B0xa8b)%3A%E5%AF%B9%E2%80%9Cwnoutrefresh%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3CBR%20%2F%3Ecollect2%EF%BC%9Ald%20%E8%BF%94%E5%9B%9E%201%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3CBR%20%2F%3Emake%3A%20**%20%5Bmconf%5D%20%E9%94%99%E8%AF%AF%201%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%20%2Fhome%2Flucas%2Fltib%2Ftmp%2Frpm-tmp.75915%20(%25build)%20%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EErros%20de%20cria%C3%A7%C3%A3o%20do%20RPM%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20C%C3%B3digo%20de%20sa%C3%ADda%20inv%C3%A1lido%20do%20%2Fhome%2Flucas%2Fltib%2Ftmp%2Frpm-tmp.75915%20(%25build)%3CBR%20%2F%3EBuild%20time%20for%20lkc%3A%203%20seconds%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Elkc%20%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%E6%AD%BB%E4%BA%8E.%2Fltib%20%E7%AC%AC%201393%20%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%E5%9B%9E%E6%BA%AF%EF%BC%9A%3CBR%20%2F%3E%E4%B8%BB%E8%A6%81%3A%3Abuild_host_rpms%3A1393%3CBR%20%2F%3E%E4%B8%BB%E8%A6%81%3A%3Ahost_checks%3A1448%3CBR%20%2F%3E%E4%B8%BB%E8%A6%81%EF%BC%9A554%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%BC%80%E5%A7%8B%E6%97%B6%E9%97%B4%EF%BC%9A2013%E5%B9%B45%E6%9C%887%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C17%3A43%3A23%3CBR%20%2F%3E%E7%BB%93%E6%9D%9F%E6%97%B6%E9%97%B4%EF%BC%9A2013%E5%B9%B45%E6%9C%887%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C17%3A55%3A25%3CBR%20%2F%3E%E5%B7%B2%E7%94%A8%E6%97%B6%EF%BC%9A722%20%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E5%8C%85%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%9A%3CBR%20%2F%3E%20lkc%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOBS%EF%BC%9A%E6%89%80%E6%9C%89%E8%BD%AF%E4%BB%B6%E5%8C%85%E9%83%BD%E5%AE%89%E8%A3%85%E6%AD%A3%E7%A1%AE%EF%BC%8C%E4%BD%86%E6%80%BB%E6%98%AF%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%89%80%E6%9C%89%E4%B8%BB%E6%9D%BFLTIB%E9%85%8D%E7%BD%AEUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BE%88%E6%A3%92%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%9Asmileyhappy%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E5%A4%9A%E8%B0%A2%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%B4%A2%E6%8B%89%E5%B8%83%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 03:34 AM
更新人:
