OPENGL ES 2.0 Sample example
2,299 次查看
deeksha
Hi All,
I'm trying to test Opengl Es 2.0 and OpenVG library in i.MX6 DL. So I' trying to execute sample programs in the
/opt/imx-gpu-sdk/GLES2 and OpenVG
but I'm getting as
WARNING: Window Size/Position values not set, setting them to Full Resolution of Primary CRT
Please help me in resolving this
Deeksha
2 回复数
2,279 次查看
deeksha
There is no readme.txt available in the folder. Could you help me on the same
How can I get the source code for above sample program.
Deeksha
2,290 次查看
Bio_TICFSL
Hello deeksha,
There is a Readme.txt in the same folder. You can follow the instruction for howto use the demo.
