Openvg library support in iMX8mm
已解决
跳至解决方案
2,599 次查看
deeksha
Hello All,
I would like to know whether Openvg library is supported in imx8 mm. If so then how to add this library in yocto.
Thanks in advance
Deeksha
标记 (2)
1 解答
2,573 次查看
joanxie
when you boot up the board, you can find the viv_samples under /opt, then you should find different test demo, choose what you need
在原帖中查看解决方案
3 回复数
2,589 次查看
joanxie
yes, current bsp includes this, the directory viv_samples is found under /opt. It contains binary samples for OpenGL ES 1.1/2.0 and OpenVG 1.1.
2,579 次查看
deeksha
Hi ,
Could you tell me the procedure to run the sample programs.
Deeksha
2,574 次查看
joanxie
