eiq problem
eiq problem
4,976 次查看
BlueHav
I found some problem when I use the eiq
when I arrive the step of the validate after the model training ,the eiq  arise an error
the error is :
falied to query modelrunner at http://127.0.0.1:10818/v1
unexpected token \ in JSON at psoitional 296
after click this error
sometimes it will arise the error
failed to convert model
no convert found to convert
4,742 次查看
david_piskula
Hello @BlueHav, does this happen every time you try to validate a model? Can you please provide more information on how to reproduce this issue? Including the version of eIQ Toolkit/eIQ Portal you're using, the dataset and model you are trying to train etc.
David
