eIQ Portal crashes on windows 11
7,264 次查看
alberto_alvarez
I was trying to do some training using eIQ Portal v2.2.14 on Windows 11 but every time I try to start the training process I get this error:
    Server encountered error: TypeError: network error
Are there compatibility issues between Windows 11 and eIQ Toolkit software? I was not able to fix this.
I also share the main.log that I get with this problem. I am using CUDA and cuDNN on my setup.
Thanks!!
Alberto Alvarez
7,245 次查看
alberto_alvarez
The problem is solved. eIQ Toolkit is compatible with Windows 11. I thought that the problem was directly caused by eIQ Portal, but I was wrong.
Downgrading cuDNN from v8.3.0 to v8.2.4 solved the problem. I am using CUDA 11.5.
Thanks!
7,246 次查看
alberto_alvarez
Thanks!
