kw36 phase based ranging issue
2,246 次查看
Larry3
Hello.
I want to measure BLE carrier signal, then develop phase-based ranging solution on KW36.
Is there any sample application? or Is there any new development board I can use?
Help me plz.
2,223 次查看
Christine_Li
Hi, @Larry3
Could you please help me with more details about your implementation/project?
Our current SDK contains APIs to capture IQ, nonetheless, you will need to develop your own examples with those API's.
The API's can be found at the following path.
              <installation path>\ middleware\wireless\framework_x.y.z\XCVR\MKW36Z
You can find the APIs to capture IQ in the dbg_ram_capture or the dma_capture files.
Besides, Would you mind to think about the method of  Localization Based on RSSI Ranging?
If not, you can refer to this AN for details:
KW36 Localization Based on RSSI Ranging Application
Christine.
标记 (1)
2,217 次查看
Christine_Li
Hi @Larry3
Anything else I can do for you on this case?
Christine.
标记 (1)
