jn5189,debug
jn5189,debug
3,610 次查看
lan_liu
Hello, when I debugged the "Hello word" sample program, I encountered the problem of unable to display and interrupt. According to your solution, I reinstalled Python 2.7, but the debugging result did not change. The problem is still the same. Why is this? We look forward to your reply.
3,557 次查看
mario_castaneda
Hi @lan_liu,
I hope you are doing great.
Sure you have to update your python version also with the pycryptodome packet.
5.5 Python3 Installation
Mario
3,598 次查看
mario_castaneda
Hi @lan_liu,
What is the SDK version that you are working on? Did you install the 2.6.2 version?
Please look at the JN-AN-1260 You could double-check the process for the python section, also you need to update the for a new version.
Please let me know if you have any further questions.
Mario
3,571 次查看
lan_liu
hello Mario,
Thank you very much for your reply, it is of great help to me.
The IDE I downloaded is 11.2.1 version, and python only downloaded 2.7.18 version. Do I need to delete the python2.7.18 version and download the python3.0 version.
Looking forward to your reply.
