WPR15100 - BUCK
WPR15100 - BUCK
2,178 次查看
olivier_ctm
I would like to create a wireless power receiver with the component MWPR1516 and i'm working with the WPR1500 - Buck as an example. However, I have some questions about the schematic:
1 - How the Vrec protection work ? (on sheet 4/5)
When Vrec is higher than 20V (+Vgs threshold) , it enables the 2 Mos. But what are the consequences on Vrec ?
2 - What is the purpose of the Switch_En ? (on sheet 4/5)
Is it to discharge the capacitor when we turn the device off ?
Thank you for your help.
With best regards,
Olivier
2,166 次查看
diazmarin09
Hello Olivier,
I hope all is great with you. Thank you for using the NXP communities.
Could you please submit a new ticket? We would need further information about your project.
David
