Strange compilation error
377086561
mario_castaneda‌
 did not call the ZPS_vRegisterGreenPower function during the compilation process, but I did not report an error.
If I go to comment on him, I can compile successfully.
I feel very strange, I hope I can get pointers, how can I do it better?
Labels (2)
Tags (3)
377086561
Yes,i don't use Green Power Cluster.
 SDK is JN-SW-4141
mario_castaneda
Did you install the JN-SW-4170 SDK? The JN-SW-4141 is Beyond Studio Software.
Mario
mario_castaneda
What is the AN that you are working on?
Did you define GP_SUPPORT = 1?
Mario
377086561
I am using JN-AN-1229
And I didn't make any definitions
After this error occurs, is it possible that the compiler is having problems?
mario_castaneda
Could you please download the example again. The JN-AN-1229 is not using Green Power Cluster.
What are the SDKs that you have installed?
Mario
