SAMAV3 Master Key
SAMAV3 Master Key
2,290 次查看
Ramboooka
Hi...
I am using a SAMAV3 module in a product I am developing...
   - I want the Master Key of the SAM to be unique to each PCB.
   - I want the CPU Firmware Hex file to contain no tracers of the SAM's Mater key.
I am planning to use the CPU's silicon ID as the SAM Master key so they are bound together
Is there an industry standard way of creating a Master key for the SAM ?
Ray
标记 (2)
2,240 次查看
danielchen
Hi @Ramboooka
SAM module is secured with NDA.
I created a private case (00538933) for you to discuss this issue.
Thanks for understanding.
2,241 次查看
danielchen
Hi @Ramboooka
