RW612 roaming setting
2,154 次查看
johnny_h
Dear community, I have a few questions about the roaming setting. I’m running the wifi-wpa-supplicant example and enable roaming (wlan_set_roaming(1, 70))when connected to a network. I’ve noticed that it triggers a low rssi event when the rssi drops below 70 and initiates a regular scan instead of background scan. However, if I disable wpa_supplicant, it performs a background scan instead of a regular scan. Why is there a difference?
WPA_supplicant supports background scan(CONFIG_BGSCAN), but it (bgscan.c) appears to be removed from the example program. Is there a reason for this?
In my current setup, roaming will only be initiated when the RSSI drops below a specific threshold. How can I set up a scheduled scan to initiate roaming when it discovers a stronger access point?
Many thanks and regards
1,999 次查看
weidong_sun
Dear @johnny_h ,
See the following explanations for your questions from our internal team, please!
Dear community, I have a few questions about the roaming setting. I’m running the wifi-wpa-supplicant example and enable roaming (wlan_set_roaming(1, 70))when connected to a network. I’ve noticed that it triggers a low rssi event when the rssi drops below 70 and initiates a regular scan instead of background scan. However, if I disable wpa_supplicant, it performs a background scan instead of a regular scan. Why is there a difference?WPA_supplicant supports background scan(CONFIG_BGSCAN), but it (bgscan.c) appears to be removed from the example program. Is there a reason for this?
[NXP]
  • This is not an issue, it is expected behavior in 24.12.00 SDK version.
  • This is an improvement in 24.12.00 SDK.
  • Before 24.12.00, the behavior was, during roam bgscan happened and bgscan scans all 36 channels and during that ~3 sec of time period no data exchange happens.
  • Now, to improve this behavior NXP implemented and instead of bgscan executing normal scan during roaming. Normal roaming do split scan so, we will not get continuous data drop.
[NXP] Are you expecting to roam before low rssi event come. Normally low rssi event come when we cross the rssi threshold.
Thanks!
weidong
2,000 次查看
weidong_sun
Dear @johnny_h ,
[NXP]
Thanks!
weidong
2,151 次查看
johnny_h
The SDK version is 24_12_00
%3CLINGO-SUB%20id%3D%22lingo-sub-2063238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%E6%BC%AB%E6%B8%B8%E8%AE%BE%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E7%A4%BE%E5%8C%BA%EF%BC%8C%E6%88%91%E5%AF%B9%E6%BC%AB%E6%B8%B8%E8%AE%BE%E7%BD%AE%E6%9C%89%E5%87%A0%E4%B8%AA%E7%96%91%E9%97%AE%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%20wifi-wpa-supplicant%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%B9%B6%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%BD%91%E7%BB%9C%E6%97%B6%E5%90%AF%E7%94%A8%E6%BC%AB%E6%B8%B8%EF%BC%88wlan_set_roaming(1%2C%2070)%EF%BC%89%E3%80%82%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%BD%93%20rssi%20%E9%99%8D%E8%87%B3%2070%20%E4%BB%A5%E4%B8%8B%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E8%A7%A6%E5%8F%91%E4%BD%8E%20rssi%20%E4%BA%8B%E4%BB%B6%E5%B9%B6%E5%90%AF%E5%8A%A8%E5%B8%B8%E8%A7%84%E6%89%AB%E6%8F%8F%E8%80%8C%E4%B8%8D%E6%98%AF%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E7%A6%81%E7%94%A8%20wpa_supplicant%EF%BC%8C%E5%AE%83%E4%BC%9A%E6%89%A7%E8%A1%8C%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%E8%80%8C%E4%B8%8D%E6%98%AF%E5%B8%B8%E8%A7%84%E6%89%AB%E6%8F%8F%E3%80%82%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E6%9C%89%E5%8C%BA%E5%88%AB%EF%BC%9F%3C%2FP%3E%3CP%20class%3D%22%22%3EWPA_supplicant%20%E6%94%AF%E6%8C%81%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%EF%BC%88CONFIG_BGSCAN%EF%BC%89%EF%BC%8C%E4%BD%86%E5%AE%83%EF%BC%88bgscan.c%EF%BC%89%E4%BC%BC%E4%B9%8E%E5%B7%B2%E4%BB%8E%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%88%A0%E9%99%A4%E3%80%82%E8%BF%99%E6%9C%89%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%9C%A8%E6%88%91%E5%BD%93%E5%89%8D%E7%9A%84%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8C%E4%BB%85%E5%BD%93%20RSSI%20%E9%99%8D%E8%87%B3%E7%89%B9%E5%AE%9A%E9%98%88%E5%80%BC%E4%BB%A5%E4%B8%8B%E6%97%B6%E6%89%8D%E4%BC%9A%E5%90%AF%E5%8A%A8%E6%BC%AB%E6%B8%B8%E3%80%82%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E8%AE%A1%E5%88%92%E6%89%AB%E6%8F%8F%E4%BB%A5%E4%BE%BF%E5%9C%A8%E5%8F%91%E7%8E%B0%E6%9B%B4%E5%BC%BA%E7%9A%84%E6%8E%A5%E5%85%A5%E7%82%B9%E6%97%B6%E5%90%AF%E5%8A%A8%E6%BC%AB%E6%B8%B8%EF%BC%9F%3C%2FP%3E%3CP%20class%3D%22%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E5%B9%B6%E8%87%B4%E4%BB%A5%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ARW612%E6%BC%AB%E6%B8%B8%E8%AE%BE%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESDK%E7%89%88%E6%9C%AC%E4%B8%BA24_12_00%3C%2FP%3E%3C%2FLINGO-BODY%3E
