RW612 roaming setting
2,218件の閲覧回数
johnny_h
Dear community, I have a few questions about the roaming setting. I’m running the wifi-wpa-supplicant example and enable roaming (wlan_set_roaming(1, 70))when connected to a network. I’ve noticed that it triggers a low rssi event when the rssi drops below 70 and initiates a regular scan instead of background scan. However, if I disable wpa_supplicant, it performs a background scan instead of a regular scan. Why is there a difference?
WPA_supplicant supports background scan(CONFIG_BGSCAN), but it (bgscan.c) appears to be removed from the example program. Is there a reason for this?
In my current setup, roaming will only be initiated when the RSSI drops below a specific threshold. How can I set up a scheduled scan to initiate roaming when it discovers a stronger access point?
Many thanks and regards
2,063件の閲覧回数
weidong_sun
Dear @johnny_h ,
See the following explanations for your questions from our internal team, please!
Dear community, I have a few questions about the roaming setting. I’m running the wifi-wpa-supplicant example and enable roaming (wlan_set_roaming(1, 70))when connected to a network. I’ve noticed that it triggers a low rssi event when the rssi drops below 70 and initiates a regular scan instead of background scan. However, if I disable wpa_supplicant, it performs a background scan instead of a regular scan. Why is there a difference?WPA_supplicant supports background scan(CONFIG_BGSCAN), but it (bgscan.c) appears to be removed from the example program. Is there a reason for this?
[NXP]
  • This is not an issue, it is expected behavior in 24.12.00 SDK version.
  • This is an improvement in 24.12.00 SDK.
  • Before 24.12.00, the behavior was, during roam bgscan happened and bgscan scans all 36 channels and during that ~3 sec of time period no data exchange happens.
  • Now, to improve this behavior NXP implemented and instead of bgscan executing normal scan during roaming. Normal roaming do split scan so, we will not get continuous data drop.
[NXP] Are you expecting to roam before low rssi event come. Normally low rssi event come when we cross the rssi threshold.
Thanks!
weidong
2 返答(返信)
2,064件の閲覧回数
weidong_sun
Dear @johnny_h ,
[NXP]
Thanks!
weidong
2,215件の閲覧回数
johnny_h
The SDK version is 24_12_00
%3CLINGO-SUB%20id%3D%22lingo-sub-2063238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%E3%83%AD%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%83%AD%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFwifi-wpa-supplicant%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0(wlan_set_roaming(1%E3%80%8170))%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82rssi%E3%81%8C70%E3%82%92%E4%B8%8B%E5%9B%9E%E3%82%8A%E3%80%81%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BD%8Erssi%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81wpa_supplicant%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20class%3D%22%22%3EWPA_supplicant%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3(CONFIG_BGSCAN)%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C(bgscan.c)%E3%81%AF%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%A7%81%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81RSSI%E3%81%8C%E7%89%B9%E5%AE%9A%E3%81%AE%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E4%B8%8B%E5%9B%9E%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%AE%E3%81%BF%E3%83%AD%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8A%E5%BC%B7%E5%8A%9B%E3%81%AA%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E6%84%9F%E8%AC%9D%E3%81%A8%E6%95%AC%E6%84%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ARW612%E3%83%AD%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESDK%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%2024_12_00%20%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
