QN9080 Crystals Load Capacitance Calibration
1,716 次查看
li-chinwang
Is that 32K external crystal is necessary for the Crystals Load Capacitance Calibration?
Or I still can run this case even I sourcing internal RCO32K?
1,617 次查看
stephanie_m
Could you please check the following application note ? I believe you will find a full explanation in the chapter 5. Clock
Estephania
