Push button on the KW40Z connectivity software
fewo_c
Hi everybody, I'm creating a custom app on MKW40Z. I need to use the push button but is confused how to use the Keyboard library from the KW40Z Connectivity software. Did you have a simple example where the push button is used?
gerardo_rodriguez
Hi Carlos,
The bluetooth examples make use of the keyboard library. You can find these examples in ...\KW40Z_Connectivity_Software_1.0.1\ConnSw\examples\bluetooth\.
For more information about the keyboard library, you can read the connectivity framework reference manual (CONNFWKRM.pdf) found in ...\KW40Z_Connectivity_Software_1.0.1\ConnSw\doc\.
Gerardo
