JN5196XK020 Documentation?? -- Commissioning without NFC?
jackjl
Can anyone point me to documentation on the JN5169XK020 Zigbee Lighting/Sensor Node Expansion kits?
The kits points to documentation in the JN516x-EK004 kit, but that documentation is minimal at best.
In theory the kit can be commissioned by normal Zigbee commissioning, but only NFC commissioning is explained. No details were given (that I found) to put the module into standard Zigbee commissioning mode.
If anyone has any details, it would be appreciated.
mario_castaneda
Hi Jack,
You can take a look to the Zigbee Link Light examples.
Also, you can find the ZLL Commissioning Cluster.
ZLL commissioning involves forming a ZLL network or adding a new node to an existing ZLL network.
For a better reference please take check the JN-UG-3091 ZigBee Light Link User Guide
http://www.nxp.com/documents/user_manual/JN-UG-3091.pdf  Chapter 6
Hope it helps,
Mario
