Dear Sir,
Where can I download the NTP5312 errata? I can't find this information under this product page.
Thanks!
解決済! 解決策の投稿を見る。
Hello @kiku541
There is not any limitation for NTP5312 i2C read/write. Maybe, you can refer the below logic to communication with NTP5312.
There doesn't seem to be an errata here, I would like to ask what information you want to know? Maybe there is another document I can refer to.
Under i2C slave mode, occasionally, the NTP5312 does not acknowledge the first address byte. So, I would like to know if there is any restriction in NTP5312 i2C read/write..
