MC145158 Program
MC145158 Program
3,174 次查看
raveendrareddy
I have MC145158 in my previous board and i want to program this PLL to check the board performance.  I checked the data for programming information and i didn't find anything about that. Could you please provide the information about the device programming and share any programming data if you have.
I attached some reference programming information of some other PLL, if you have same kind please do share
Raveendra
2,804 次查看
Wlodek_D_
Senior Contributor II
Dear Raveendra Reddy,
Your MC145158 device is not manufactured already (Last Order Date passed 13 Jun 2003), so on Freescale webpage (http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC145158_2 ) you can find short info with ARCHIVED notice - this means that page content is no longer updated and is made available for historical reference only.
Under Documentation tab you can find data sheet of similar device (MC145151), unfortunately there is no more application documents stored in our archive.
The MC145158 data sheet you can find on the web and download it from public repositories (e.g.  http://www.datasheetarchive.com/MC145158-2-datasheet.html or http://www.datasheetarchive.com/dl/Datasheets-IS76/DSAH00331177.pdf ).
In MC145158 datasheet in section Pin Description there is data entry format explained, it is not exactly the info in format you require, however it should help. Also description of other MC14515x family members should be helpful as well.
Wlodek_D.
