KW45 SPSDK NBU Failed to execute the script file
1,552 次查看
Melton
Dear Sir,
         I tried to burn NBU through SPSDK by looking at AN13883 , The version of python I use is V3.11.6。But I had a problem running script 5.2, My sb3 file cannot be generated。
@KW45
1,503 次查看
Melton
Thank you sir,
      I followed the link you provided and modified some content, now it has been solved.The problem may be that the version written on AN is older.
1,521 次查看
Ricardo_Zamora
Could you please confirm that you followed all the "KW45xx and K32W1xx Load NBU image" jupyter example?
What modifications did you make?
Ricardo
Ricardo
1,504 次查看
Melton
Thank you sir,
