Dear Sir,
I tried to burn NBU through SPSDK by looking at AN13883 , The version of python I use is V3.11.6。But I had a problem running script 5.2, My sb3 file cannot be generated。
@KW45
Solved! Go to Solution.
Thank you sir,
I followed the link you provided and modified some content, now it has been solved.The problem may be that the version written on AN is older.
Could you please confirm that you followed all the "KW45xx and K32W1xx Load NBU image" jupyter example?
What modifications did you make?
Ricardo
