KW38 CAN-FD 64bytes
14,904件の閲覧回数
Adam_Ho
I am using sample project "frdmkw38_flexcan_interrupt_transfer" to try CAN-FD.
If I want to send 64 bytes data through, I set "DLC" as 15.
In loopback mode, I send 64 bytes data, but I only receive 16 bytes.
Is there any configuration I miss?
Thanks.
タグ(1)
14,698件の閲覧回数
Christine_Li
Hi, @Adam_Ho
#define RX_MESSAGE_BUFFER_NUM (6)
#define TX_MESSAGE_BUFFER_NUM (5)
If use kFLEXCAN_64BperMB, the Maximum MBs is 7.
So the "RX_MESSAGE_BUFFER_NUM" and "TX_MESSAGE_BUFFER_NUM"  should less than 7. Pleas set "RX_MESSAGE_BUFFER_NUM" to 6, and "TX_MESSAGE_BUFFER_NUM" to 5, then the system would work normally.
I tested it on my side, it is ok. Please try it on your side and let me know your results.
Christine.
タグ(1)
12 返答(返信)
14,884件の閲覧回数
Christine_Li
Hi, @Adam_Ho
Thanks for creating case to us and hope you are doing well.
I checked our SDK code, and may I ask whether you only modified DLC from 10 to 15 or also changed DWORD_IN_MB and BYTES_IN_MB?
For your information:
Dword in each message buffer, Length of data in bytes, Payload size must align,
and the Message Buffers are limited corresponding to each payload configuration.
So please also modified DWORD_IN_MB and BYTES_IN_MB to the one related to DLC to have a try.
Christine.
タグ(1)
14,873件の閲覧回数
Adam_Ho
Hi @Christine_Li ,
I modify the parameters to fit "kFLEXCAN_64BperMB", but seems not work.
If I use "kFLEXCAN_32BperMB", it is work.
Please give me more hint.
Thanks.
14,844件の閲覧回数
Christine_Li
Hi, @Adam_Ho
Thanks for your feedback.
I checked your current settings, and also checked our Reference Manual.
In reception, this DLC field is written by the FlexCAN module, copied from the DLC (Data Length Code) field of the received frame.
In transmission, this DLC field is written by the CPU and corresponds to the DLC field value of the frame to be transmitted.
I think it should be matched with below:
 *    DWORD_IN_MB    DLC    BYTES_IN_MB             Maximum MBs
 *    2              8      kFLEXCAN_8BperMB        32
 *    4              10     kFLEXCAN_16BperMB       21
 *    8              13     kFLEXCAN_32BperMB       12
 *    16             15     kFLEXCAN_64BperMB       7
May I ask whether it can work well with below? It only has problem when you use in 64Byte, am I right?
Or you didn't tried 8Bytes and 32Bytes?
How about disable loop back mode?
Christine.
タグ(1)
14,830件の閲覧回数
Adam_Ho
Hi @Christine_Li ,
I check all the parameter in Table. and the result is in below.
Yes, It's only have problem in 64Byte.
I think the problem is on Rx buffer size, maybe this is the clue to find out the result.
I attach the source code for loopback mode, and comment the place I configurate.
You can find the place by //TODO: adam_test
 loopback enableloopback disable
kFLEXCAN_8BperMBPassPass
kFLEXCAN_16BperMBPassPass
kFLEXCAN_32BperMBPassPass
kFLEXCAN_64BperMBFailFail
14,815件の閲覧回数
Christine_Li
Hi, @Adam_Ho
Did you connect 12V power supply on J32 of the two boards?
I checked the Readme, it mentioned this point.
And also I am trying on my local side to repro this issue.
Christine.
タグ(1)
14,811件の閲覧回数
Adam_Ho
Hi @Christine_Li ,
Yes, I am using 12V as power voltage.
Thanks.
Adam
14,793件の閲覧回数
Christine_Li
Hi, @Adam_Ho
Thanks for your reply.
Just to confirm with you, after you change all parameters related to 64Bytes, then the board doesn't have any response, am I right?
I am trying to reproduce your issue, and above is what I saw on my two boards(one as TX, one as RX).
But when I changed back to 32Bytes related parameters, it can work properly.
Error phenomenon is like below:
Is is same as your side?
Christine.
タグ(1)
14,789件の閲覧回数
Adam_Ho
Hi @Christine_Li ,
Yes, you reproduce  my issue.
I think Rx buffer size is wrong, so system in 64Bytes parameter when rx data  coming system go to wrong address.
Then system halt.
14,783件の閲覧回数
Christine_Li
Hi, @Adam_Ho
Thanks for your quick reply.
I can't agree with you more.
I will create an internal case to track further.
Once receive any response from our internal team, I will share with you.
Thanks again for creating such an important issue to us, it give a great chance to make us better.
Have a nice weekend!
Christine.
タグ(1)
14,778件の閲覧回数
Adam_Ho
Hi @Christine_Li m
Thank for you kindly support.
When this issue have further step, please let me know.
Adam
14,699件の閲覧回数
Christine_Li
Hi, @Adam_Ho
Christine.
タグ(1)
14,685件の閲覧回数
Adam_Ho
@Christine_Li
It's work.
Best  Regards,
Adam
%3CLINGO-SUB%20id%3D%22lingo-sub-1861120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8Cfrdmkw38_flexcan_interrupt_transfer%E3%80%8D%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6CAN-FD%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E64%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CDLC%E3%80%8D%E3%82%9215%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%8164%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1861120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E8%A3%BD%E5%93%81%3A%20KW%2037%7C38%7C39%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1864260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1864260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E4%BB%95%E4%BA%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EADAM%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1864196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1864196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205916%22%20target%3D%22_blank%22%3E%40Adam_Ho%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20RX_MESSAGE_BUFFER_NUM%20(6)%0A%23define%20TX_MESSAGE_BUFFER_NUM%20(5)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EkFLEXCAN_64BperMB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%E6%9C%80%E5%A4%A7MB%E3%81%AF7%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%80%8C%3CSPAN%3ERX_MESSAGE_BUFFER_NUM%3C%2FSPAN%3E%E3%80%8D%E3%81%A8%E3%80%8C%3CSPAN%3ETX_MESSAGE_BUFFER_NUM%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8D%E3%81%AF7%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%98%86%E9%A1%98%E3%81%AF%E3%80%8CRX_MESSAGE_BUFFER_NUM%E3%80%8D%E3%82%926%E3%81%AB%E3%80%81%E3%80%8CTX_MESSAGE_BUFFER_NUM%E3%80%8D%E3%82%925%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B5%90%E6%9E%9C%E3%82%92%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3Bm%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%AE%E3%81%BB%E3%81%A9%E3%80%81%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%95%E3%82%89%E3%81%AB%E9%80%B2%E3%82%93%E3%81%A0%E3%82%89%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EADAM%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205916%22%20target%3D%22_blank%22%3E%40Adam_Ho%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%93%E3%82%8C%E4%BB%A5%E4%B8%8A%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%BF%BD%E8%B7%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%86%85%E9%83%A8%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A4%BE%E5%86%85%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%87%8D%E8%A6%81%E3%81%AA%E5%95%8F%E9%A1%8C%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E3%82%88%E3%82%8A%E8%89%AF%E3%81%8F%E3%81%99%E3%82%8B%E5%A4%A7%E3%81%8D%E3%81%AA%E3%83%81%E3%83%A3%E3%83%B3%E3%82%B9%E3%82%92%E4%B8%8E%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A5%BD%E3%81%97%E3%81%84%E9%80%B1%E6%9C%AB%E3%82%92%E9%81%8E%E3%81%94%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%20%3CSPAN%3E%E3%82%92%E5%86%8D%E7%8F%BE%3C%2FSPAN%3E%20%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFRx%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%86%E3%81%AE%E3%81%A7%E3%80%81%3CSPAN%3E64Bytes%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81rx%3C%2FSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E6%9D%A5%E3%82%8B%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E8%A1%8C%E3%81%8F%E3%81%A8%E3%81%8D%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205916%22%20target%3D%22_blank%22%3E%40Adam_Ho%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A2%BA%E8%AA%8D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%8164Bytes%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E4%B8%8A%E8%A8%98%E3%81%AF%E7%A7%81%E3%81%8C%E7%A7%81%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89(1%E3%81%A4%E3%81%AFTX%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AFRX%E3%81%A8%E3%81%97%E3%81%A6)%E3%81%A7%E8%A6%8B%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%8132Bytes%E9%96%A2%E9%80%A3%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E6%88%BB%E3%81%99%E3%81%A8%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E7%8F%BE%E8%B1%A1%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Christine_Li_1-1715336105257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Christine_Li_1-1715336105257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F278196iED6DBBD6A01BBBD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Christine_Li_1-1715336105257.png%22%20alt%3D%22Christine_Li_1-1715336105257.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E9%9B%BB%E6%BA%90%E9%9B%BB%E5%9C%A7%E3%81%A8%E3%81%97%E3%81%A612V%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EADAM%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205916%22%20target%3D%22_blank%22%3E%40Adam_Ho%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E2%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEJ32%E3%81%AB12V%E9%9B%BB%E6%BA%90%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EReadme%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%93%E3%81%AE%E7%82%B9%E3%81%8C%E8%BF%B0%E3%81%B9%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%AE%E5%9C%B0%E5%85%83%E3%81%AE%E5%81%B4%E3%81%A7%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3ETable%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%3CSPAN%3E64%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%E3%81%A7%E3%81%AE%E3%81%BF%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%95%8F%E9%A1%8C%E3%81%AFRx%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E7%B5%90%E6%9E%9C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E5%A0%B4%E6%89%80%E3%81%AFTODO%3C%2FSTRONG%3E%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99adam_test%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%2299.86425333805283%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2225px%22%3E%26nbsp%3B%3C%2FTD%3E%3CTD%20width%3D%2233.242876526458616%25%22%20height%3D%2225px%22%3E%3CSTRONG%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E6%9C%89%E5%8A%B9%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.28804347826087%25%22%20height%3D%2225px%22%3E%3CSTRONG%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%AE%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2225px%22%3E%3CSTRONG%3EkFLEXCAN_8BperMB%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.242876526458616%25%22%20height%3D%2225px%22%3E%E9%80%9A%E3%82%8B%3C%2FTD%3E%3CTD%20width%3D%2233.28804347826087%25%22%20height%3D%2225px%22%3E%E9%80%9A%E3%82%8B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2225px%22%3E%3CSTRONG%3EkFLEXCAN_16BperMB%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.242876526458616%25%22%20height%3D%2225px%22%3E%E9%80%9A%E3%82%8B%3C%2FTD%3E%3CTD%20width%3D%2233.28804347826087%25%22%20height%3D%2225px%22%3E%E9%80%9A%E3%82%8B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2225px%22%3E%3CSTRONG%3EkFLEXCAN_32BperMB%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.242876526458616%25%22%20height%3D%2225px%22%3E%E9%80%9A%E3%82%8B%3C%2FTD%3E%3CTD%20width%3D%2233.28804347826087%25%22%20height%3D%2225px%22%3E%E9%80%9A%E3%82%8B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2225px%22%3E%3CSTRONG%3EkFLEXCAN_64BperMB%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.242876526458616%25%22%20height%3D%2225px%22%3EFAIL%5BFAIL%5D%3C%2FTD%3E%3CTD%20width%3D%2233.28804347826087%25%22%20height%3D%2225px%22%3EFAIL%5BFAIL%5D%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205916%22%20target%3D%22_blank%22%3E%40Adam_Ho%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%94%E6%84%8F%E8%A6%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AEDLC%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AFFlexCAN%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AEDLC(Data%20Length%20Code)%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AEDLC%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AFCPU%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%80%81%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AEDLC%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E5%80%A4%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%95%E3%81%9B%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20*%20%20%20%20DWORD_IN_MB%20%20%20%20DLC%20%20%20%20BYTES_IN_MB%20%20%20%20%20%20%20%20%20%20%20%20%20Maximum%20MBs%0A%20*%20%20%20%202%20%20%20%20%20%20%20%20%20%20%20%20%20%208%20%20%20%20%20%20kFLEXCAN_8BperMB%20%20%20%20%20%20%20%2032%0A%20*%20%20%20%204%20%20%20%20%20%20%20%20%20%20%20%20%20%2010%20%20%20%20%20kFLEXCAN_16BperMB%20%20%20%20%20%20%2021%0A%20*%20%20%20%208%20%20%20%20%20%20%20%20%20%20%20%20%20%2013%20%20%20%20%20kFLEXCAN_32BperMB%20%20%20%20%20%20%2012%0A%20*%20%20%20%2016%20%20%20%20%20%20%20%20%20%20%20%20%2015%20%20%20%20%20kFLEXCAN_64BperMB%20%20%20%20%20%20%207%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E4%BB%A5%E4%B8%8B%E3%81%A8%E3%81%86%E3%81%BE%E3%81%8F%E9%80%A3%E6%90%BA%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%8A%E8%81%9E%E3%81%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F64%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%818%E3%83%90%E3%82%A4%E3%83%88%E3%81%A832%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20*%20%20%20%20DWORD_IN_MB%20%20%20%20DLC%20%20%20%20BYTES_IN_MB%20%20%20%20%20%20%20%20%20%20%20%20%20Maximum%20MBs%0A%20*%20%20%20%202%20%20%20%20%20%20%20%20%20%20%20%20%20%208%20%20%20%20%20%20kFLEXCAN_8BperMB%20%20%20%20%20%20%20%2032%0A%20*%20%20%20%208%20%20%20%20%20%20%20%20%20%20%20%20%20%2013%20%20%20%20%20kFLEXCAN_32BperMB%20%20%20%20%20%20%2012%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%E3%80%8CkFLEXCAN_64BperMB%E3%80%8D%E3%81%AB%E5%90%88%E3%81%86%E3%82%88%E3%81%86%E3%81%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8CkFLEXCAN_32BperMB%E3%80%8D%E3%82%92%E4%BD%BF%E3%81%88%E3%81%B0%E4%BB%95%E4%BA%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%A3%E3%81%A8%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Adam_Ho_0-1715164197494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Adam_Ho_0-1715164197494.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277727iA5481ADB11E84FDE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Adam_Ho_0-1715164197494.png%22%20alt%3D%22Adam_Ho_0-1715164197494.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Adam_Ho_1-1715164218949.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Adam_Ho_1-1715164218949.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277728iCFD1472095C960DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Adam_Ho_1-1715164218949.png%22%20alt%3D%22Adam_Ho_1-1715164218949.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AKW38%20CAN-FD%2064%E3%83%90%E3%82%A4%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205916%22%20target%3D%22_blank%22%3E%40Adam_Ho%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESDK%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81DLC%E3%82%9210%E3%81%8B%E3%82%8915%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82DWORD_IN_MB%E3%81%A8BYTES_IN_MB%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E3%81%8A%E8%81%9E%E3%81%8D%E3%81%97%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%EF%BC%9A%3C%2FP%3E%0A%3CDIV%20style%3D%22background-color%3A%20%23ffffff%3B%20padding%3A%200px%200px%200px%202px%3B%22%3E%0A%3CDIV%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'Consolas'%3B%20font-size%3A%2010pt%3B%20white-space%3A%20pre%3B%22%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E5%90%84%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E5%86%85%E3%81%AE%20Dword%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E9%95%B7%E3%81%95%20(%E3%83%90%E3%82%A4%E3%83%88%E5%8D%98%E4%BD%8D)%E3%80%81%3C%2FSPAN%3E%3CSPAN%3E%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%8F%83%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AF%E3%80%81%E5%90%84%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81DLC%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%82%E3%81%AE%E3%81%ABDWORD_IN_MB%E3%82%84BYTES_IN_MB%E3%82%82%E6%94%B9%E9%80%A0%E3%81%97%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%86%E3%82%A3%E3%83%B3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
