K32W HCI
K32W HCI
2,287 次查看
danieltseng
Contributor V
Using HCI as an example, whether the program has a reserved position to adjust the frequency offset(xtal Trim)?
  • KW
2,239 次查看
danieltseng
Contributor V
Dear Mario
Received, thank you for your support
2,239 次查看
mario_castaneda
Hi Daniel,
The example es doing the trim, please look at the board.c file BOARD_tcxo32M_compensation_run. In this case, the example is not sending a temperature threshold and a delay.
Also, the function is calling the CLOCK_Xtal32M_Trim(XO_32M_OSC_CAP_Delta_x1000, &BOARD_Clock32MCapacitanceCharacteristics);
Mario
