[JN5189] Unlock ISP mode
3,404 次查看
Johnny9
I am programming using DK6 programmer and jn5189's isp mode. I am locking the ISP using the " -w isp_level=" option, but I don't know how to unlock it. I did a search and it seems that there is a way to unlock the ISP using the "unlock key", but it is not explained well enough for me to understand, can someone explain it easily?
3,363 次查看
EduardoZamora
Hello @Johnny9
Hope you are doing well.
Please, refer to the file attached to this post, there you can find the script to create an unlock key and a document explaining ISP Access Levels and more information about the lock/unlock process.
Eduardo.
3,277 次查看
Johnny9
hello,
It's working fine as per your guide.
Thank you for your help.
I have an additional question,
What do 'Device ID', 'Max Device ID', 'Min Device ID' and 'Customer ID' mean and how do I use them in pFlash? They all default to '0'.
Johnny9.
3,364 次查看
EduardoZamora
Hello @Johnny9
Eduardo.
3,137 次查看
seunghokims
Hello EduardoZamora
I have the same problem.
Please let us know which attachments you provided.
I would like to know how to unlock it.
SeunhoKims.
