How to use pressure and temperature Related custer
1,014件の閲覧回数
vishal_zadafiy1
Can i used relative Humidity/temperature/pressure Sensor related Cluster on same EP?
962件の閲覧回数
mario_castaneda
Hi Vishal,
Yes, you can use in the same EndPoint. This is part of the application so, also it will depend on the cluster that you are reading/writing information.
https://community.nxp.com/docs/DOC-335075
Mario
