How to use Power Configuration Cluster?
4,356件の閲覧回数
LChll
I'd like to submit some voltage and power data.It's the  Power Configuration Cluster?How to use Power Configuration Cluster?  Thanks!
ad
9 返答(返信)
4,154件の閲覧回数
LChll
Yes, I configured attribute report according to JN-UG-3115 document.
ad
4,154件の閲覧回数
stephanie_m
Are you sure you followed the complete steps mentioned in this guides?
https://community.nxp.com/docs/DOC-335075
https://community.nxp.com/docs/DOC-333994
Estephania
4,154件の閲覧回数
LChll
Thank you very much!I've solved the problem!
ad
4,154件の閲覧回数
stephanie_m
Are you working with the KW41Z or the JN5168/69? You can check this guide on Chapter 9 Power Configuration Cluster for more details about this.
Estephania
4,154件の閲覧回数
LChll
Working with the JN5169.I have added the cluster.Now the problem is how to actively report this voltage.
ad
4,154件の閲覧回数
stephanie_m
But which problem are you having? Do you have some logs? Is your problem regarding the value gotten or is it when reporting? Could you please provide more details?
Estephania
4,154件の閲覧回数
LChll
I want to report BatteryVoltage and Occupancy two Attributes on the routine JN-AN-1220,There is no problem with sOccupancy being reported, but BatteryVoltage cannot be reported
ad
4,154件の閲覧回数
stephanie_m
And did you add and configure the attributes correctly as stated in the B.2 Configuring Attribute Reporting?
Estephania
4,154件の閲覧回数
LChll
  • Returns the specified ZCL status code 32,Am I missing something?
ad
