How to program QN908x controller for BLE application without using RTOS?
1,773件の閲覧回数
aiswaryakrishna
Is there any example project using non rtos?
1,637件の閲覧回数
stephanie_m
Is there a specific reason why you would like to remove it? If you want to use our SDK I would recommend you to check the Bluetooth LE Application Developer's Guide for a deeper understanding of how it’s the stack working and which are the necessary elements to have it working, you can find the document in the SDK documentation, I would recommend you to check especially the chapter 9.5 RTOS.
There are some examples in bare metal in the SDK available, but there is no way to use the  Bluetooth LE application without the OS Abstraction layer due to the dependencies in the libraries and stack management.
Estephania
