How to observe the timing of BLE scans
775 次查看
Hiroki_Shimizu
I would like to know how to observe the timing of scanning in BLE communication of KW45-EVK.
Is it possible to observe the timing of the scans in terms of voltage? (I want to observe the scans of 37, 38, 39ch one by one.)
Microcontroller board in use : KW45B41Z-EVK
Sample programs of the SDK in use : kw45b41zevk_eatt_central_bm (SDK_2_16_000_KW45B41Z-EVK)
标记 (1)
740 次查看
Ricardo_Zamora
Hope you are doing well. Could you please clarify what do you mean with "observe the timing of scanning"?
Maybe this Application Note could help you: Kinetis KW45 and K32W Bluetooth LE Power Consumption.
Ricardo
