How MCXW71 using I2C High Speed which frequency is 3 to 3.4M ?
915 次查看
dingyc
    I am using FRDM-MCXW71 Board , and want to communicate with Sensor by I2c Interface,  100Khz and 400Khz all work very ok,  but how can I enable I2C High Speed 3 to 3.4M ?
    IS there any configuration I need to do, Or just simply change the SDK code #define 100000 to #define 3400000?
858 次查看
sofiaurueta
Hope you are doing well. What SDK version are you using? What example are you using as a base?
What modifications did you implement?
Ana Sofia.
